[U-Boot-Users] [PATCH 2/2] fix pxa255_idp board
Yes, I know it's big, but that's mainly to do with the rename of memsetup to lowlevel_init adding 14 KB twice. Shouldn't there be a smarter way for renames in patches?
Signed-off-by: Marcel Ziswiler <marcel <at> ziswiler.com> --- diff --git a/board/pxa255_idp/memsetup.S b/board/pxa255_idp/memsetup.S deleted file mode 100644 index 7e485a2..0000000 --- a/board/pxa255_idp/memsetup.S +++ /dev/null @@ -1,496 +0,0 @@ -/* - * Most of this taken from Redboot hal_platform_setup.h with cleanup - * - * NOTE: I haven't clean this up considerably, just enough to get it - * running. See hal_platform_setup.h for the source. See - * board/cradle/memsetup.S for another PXA250 setup that is - * much cleaner. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <version.h> -#include <asm/arch/pxa-regs.h> - -DRAM_SIZE: .long CFG_DRAM_SIZE - -/* wait for coprocessor write complete */ - .macro CPWAIT reg - mrc p15,0,\reg,c2,c0,0 - mov \reg,\reg - sub pc,pc,#4 - .endm - -/* - * Memory setup - */ -.globl memsetup -memsetup: - - mov r10, lr - -#ifdef DEBUG_BLINK_ENABLE - /* 3rd blink */ - bl blink -#endif - - /* Set up GPIO pins first ----------------------------------------- */ - ldr r0, =GPSR0 - ldr r1, =CFG_GPSR0_VAL - str r1, [r0] - - ldr r0, =GPSR1 - ldr r1, =CFG_GPSR1_VAL - str r1, [r0] - - ldr r0, =GPSR2 - ldr r1, =CFG_GPSR2_VAL - str r1, [r0] - - ldr r0, =GPCR0 - ldr r1, =CFG_GPCR0_VAL - str r1, [r0] - - ldr r0, =GPCR1 - ldr r1, =CFG_GPCR1_VAL - str r1, [r0] - - ldr r0, =GPCR2 - ldr r1, =CFG_GPCR2_VAL - str r1, [r0] - - ldr r0, =GPDR0 - ldr r1, =CFG_GPDR0_VAL - str r1, [r0] - - ldr r0, =GPDR1 - ldr r1, =CFG_GPDR1_VAL - str r1, [r0] - - ldr r0, =GPDR2 - ldr r1, =CFG_GPDR2_VAL - str r1, [r0] - - ldr r0, =GAFR0_L - ldr r1, =CFG_GAFR0_L_VAL - str r1, [r0] - - ldr r0, =GAFR0_U - ldr r1, =CFG_GAFR0_U_VAL - str r1, [r0] - - ldr r0, =GAFR1_L - ldr r1, =CFG_GAFR1_L_VAL - str r1, [r0] - - ldr r0, =GAFR1_U - ldr r1, =CFG_GAFR1_U_VAL - str r1, [r0] - - ldr r0, =GAFR2_L - ldr r1, =CFG_GAFR2_L_VAL - str r1, [r0] - - ldr r0, =GAFR2_U - ldr r1, =CFG_GAFR2_U_VAL - str r1, [r0] - - ldr r0, =PSSR /* enable GPIO pins */ - ldr r1, =CFG_PSSR_VAL - str r1, [r0] - -#ifdef DEBUG_BLINK_ENABLE - /* 4th debug blink */ - bl blink -#endif - - /* ---------------------------------------------------------------- */ - /* Enable memory interface */ - /* */ - /* The sequence below is based on the recommended init steps */ - /* detailed in the Intel PXA250 Operating Systems Developers Guide, */ - /* Chapter 10. */ - /* ---------------------------------------------------------------- */ - - /* ---------------------------------------------------------------- */ - /* Step 1: Wait for at least 200 microsedonds to allow internal */ - /* clocks to settle. Only necessary after hard reset... */ - /* FIXME: can be optimized later */ - /* ---------------------------------------------------------------- */ - - ldr r3, =OSCR /* reset the OS Timer Count to zero */ - mov r2, #0 - str r2, [r3] - ldr r4, =0x300 /* really 0x2E1 is about 200usec, */ - /* so 0x300 should be plenty */ -1: - ldr r2, [r3] - cmp r4, r2 - bgt 1b - -mem_init: - - ldr r1, =MEMC_BASE /* get memory controller base addr. */ - - /* ---------------------------------------------------------------- */ - /* Step 2a: Initialize Asynchronous static memory controller */ - /* ---------------------------------------------------------------- */ - - /* MSC registers: timing, bus width, mem type */ - - /* MSC0: nCS(0,1) */ - ldr r2, =CFG_MSC0_VAL - str r2, [r1, #MSC0_OFFSET] - ldr r2, [r1, #MSC0_OFFSET] /* read back to ensure */ - /* that data latches */ - /* MSC1: nCS(2,3) */ - ldr r2, =CFG_MSC1_VAL - str r2, [r1, #MSC1_OFFSET] - ldr r2, [r1, #MSC1_OFFSET] - - /* MSC2: nCS(4,5) */ - ldr r2, =CFG_MSC2_VAL - str r2, [r1, #MSC2_OFFSET] - ldr r2, [r1, #MSC2_OFFSET] - - /* ---------------------------------------------------------------- */ - /* Step 2b: Initialize Card Interface */ - /* ---------------------------------------------------------------- */ - - /* MECR: Memory Expansion Card Register */ - ldr r2, =CFG_MECR_VAL - str r2, [r1, #MECR_OFFSET] - ldr r2, [r1, #MECR_OFFSET] - - /* MCMEM0: Card Interface slot 0 timing */ - ldr r2, =CFG_MCMEM0_VAL - str r2, [r1, #MCMEM0_OFFSET] - ldr r2, [r1, #MCMEM0_OFFSET] - - /* MCMEM1: Card Interface slot 1 timing */ - ldr r2, =CFG_MCMEM1_VAL - str r2, [r1, #MCMEM1_OFFSET] - ldr r2, [r1, #MCMEM1_OFFSET] - - /* MCATT0: Card Interface Attribute Space Timing, slot 0 */ - ldr r2, =CFG_MCATT0_VAL - str r2, [r1, #MCATT0_OFFSET] - ldr r2, [r1, #MCATT0_OFFSET] - - /* MCATT1: Card Interface Attribute Space Timing, slot 1 */ - ldr r2, =CFG_MCATT1_VAL - str r2, [r1, #MCATT1_OFFSET] - ldr r2, [r1, #MCATT1_OFFSET] - - /* MCIO0: Card Interface I/O Space Timing, slot 0 */ - ldr r2, =CFG_MCIO0_VAL - str r2, [r1, #MCIO0_OFFSET] - ldr r2, [r1, #MCIO0_OFFSET] - - /* MCIO1: Card Interface I/O Space Timing, slot 1 */ - ldr r2, =CFG_MCIO1_VAL - str r2, [r1, #MCIO1_OFFSET] - ldr r2, [r1, #MCIO1_OFFSET] - -#ifdef DEBUG_BLINK_ENABLE - /* 5th blink */ - bl blink -#endif - - /* ---------------------------------------------------------------- */ - /* Step 2c: Write FLYCNFG FIXME: what's that??? */ - /* ---------------------------------------------------------------- */ - - /* ---------------------------------------------------------------- */ - /* Step 2d: Initialize Timing for Sync Memory (SDCLK0) */ - /* ---------------------------------------------------------------- */ - - /* Before accessing MDREFR we need a valid DRI field, so we set */ - /* this to power on defaults + DRI field. */ - - ldr r3, =CFG_MDREFR_VAL - ldr r2, =0xFFF - and r3, r3, r2 - ldr r4, =0x03ca4000 - orr r4, r4, r3 - str r4, [r1, #MDREFR_OFFSET] /* write back MDREFR */ - ldr r4, [r1, #MDREFR_OFFSET] - - /* Note: preserve the mdrefr value in r4 */ - - /* ---------------------------------------------------------------- */ - /* Step 3: Initialize Synchronous Static Memory (Flash/Peripherals) */ - /* ---------------------------------------------------------------- */ - - /* Initialize SXCNFG register. Assert the enable bits */ - - /* Write SXMRS to cause an MRS command to all enabled banks of */ - /* synchronous static memory. Note that SXLCR need not be written */ - /* at this time. */ - - /* FIXME: we use async mode for now */ - - /* ---------------------------------------------------------------- */ - /* Step 4: Initialize SDRAM */ - /* ---------------------------------------------------------------- */ - - /* set MDREFR according to user define with exception of a few bits */ - - ldr r4, =CFG_MDREFR_VAL - orr r4, r4, #(MDREFR_SLFRSH) - bic r4, r4, #(MDREFR_E1PIN|MDREFR_E0PIN) - str r4, [r1, #MDREFR_OFFSET] /* write back MDREFR */ - ldr r4, [r1, #MDREFR_OFFSET] - - /* Step 4b: de-assert MDREFR:SLFRSH. */ - - bic r4, r4, #(MDREFR_SLFRSH) - str r4, [r1, #MDREFR_OFFSET] /* write back MDREFR */ - ldr r4, [r1, #MDREFR_OFFSET] - - /* Step 4c: assert MDREFR:E1PIN and E0PIO as desired */ - - ldr r4, =CFG_MDREFR_VAL - str r4, [r1, #MDREFR_OFFSET] /* write back MDREFR */ - ldr r4, [r1, #MDREFR_OFFSET] - - - /* Step 4d: write MDCNFG with MDCNFG:DEx deasserted (set to 0), to */ - /* configure but not enable each SDRAM partition pair. */ - - ldr r4, =CFG_MDCNFG_VAL - bic r4, r4, #(MDCNFG_DE0|MDCNFG_DE1) - - str r4, [r1, #MDCNFG_OFFSET] /* write back MDCNFG */ - ldr r4, [r1, #MDCNFG_OFFSET] - - /* Step 4e: Wait for the clock to the SDRAMs to stabilize, */ - /* 100..200 µsec. */ - - ldr r3, =OSCR /* reset the OS Timer Count to zero */ - mov r2, #0 - str r2, [r3] - ldr r4, =0x300 /* really 0x2E1 is about 200usec, */ - /* so 0x300 should be plenty */ -1: - ldr r2, [r3] - cmp r4, r2 - bgt 1b - - /* Step 4f: Trigger a number (usually 8) refresh cycles by */ - /* attempting non-burst read or write accesses to disabled */ - /* SDRAM, as commonly specified in the power up sequence */ - /* documented in SDRAM data sheets. The address(es) used */ - /* for this purpose must not be cacheable. */ - - ldr r3, =CFG_DRAM_BASE - str r2, [r3] - str r2, [r3] - str r2, [r3] - str r2, [r3] - str r2, [r3] - str r2, [r3] - str r2, [r3] - str r2, [r3] - - /* Step 4g: Write MDCNFG with enable bits asserted */ - /* (MDCNFG:DEx set to 1). */ - - ldr r3, [r1, #MDCNFG_OFFSET] - orr r3, r3, #(MDCNFG_DE0|MDCNFG_DE1) - str r3, [r1, #MDCNFG_OFFSET] - - /* Step 4h: Write MDMRS. */ - - ldr r2, =CFG_MDMRS_VAL - str r2, [r1, #MDMRS_OFFSET] - - /* We are finished with Intel's memory controller initialisation */ -#if 0 - /* FIXME turn on serial ports */ - /* look into moving this to board_init() */ - ldr r2, =(PXA_CS5_PHYS + 0x03C0002c) - mov r3, #0x13 - str r3, [r2] -#endif - -#ifdef DEBUG_BLINK_ENABLE - /* 6th blink */ - bl blink -#endif - - /* ---------------------------------------------------------------- */ - /* Disable (mask) all interrupts at interrupt controller */ - /* ---------------------------------------------------------------- */ - -initirqs: - - mov r1, #0 /* clear int. level register (IRQ, not FIQ) */ - ldr r2, =ICLR - str r1, [r2] - - ldr r2, =ICMR /* mask all interrupts at the controller */ - str r1, [r2] - - /* ---------------------------------------------------------------- */ - /* Clock initialisation */ - /* ---------------------------------------------------------------- */ - -initclks: - - /* Disable the peripheral clocks, and set the core clock frequency */ - /* (hard-coding at 398.12MHz for now). */ - - /* Turn Off ALL on-chip peripheral clocks for re-configuration */ - /* Note: See label 'ENABLECLKS' for the re-enabling */ -#if 0 - ldr r1, =CKEN - mov r2, #0 - str r2, [r1] - - /* default value in case no valid rotary switch setting is found */ - ldr r2, =(CCCR_L27|CCCR_M2|CCCR_N10) /* DEFAULT: {200/200/100} */ - - /* ... and write the core clock config register */ - ldr r1, =CCCR - str r2, [r1] - -#endif - -#ifdef RTC - /* enable the 32Khz oscillator for RTC and PowerManager */ - - ldr r1, =OSCC - mov r2, #OSCC_OON - str r2, [r1] - - /* NOTE: spin here until OSCC.OOK get set, meaning the PLL */ - /* has settled. */ -60: - ldr r2, [r1] - ands r2, r2, #1 - beq 60b -#endif - - /* ---------------------------------------------------------------- */ - /* */ - /* ---------------------------------------------------------------- */ - - /* Save SDRAM size */ - ldr r1, =DRAM_SIZE - str r8, [r1] - - /* Interrupt init: Mask all interrupts */ - ldr r0, =ICMR /* enable no sources */ - mov r1, #0 - str r1, [r0] - - /* FIXME */ - -#define NODEBUG -#ifdef NODEBUG - /*Disable software and data breakpoints */ - mov r0,#0 - mcr p15,0,r0,c14,c8,0 /* ibcr0 */ - mcr p15,0,r0,c14,c9,0 /* ibcr1 */ - mcr p15,0,r0,c14,c4,0 /* dbcon */ - - /*Enable all debug functionality */ - mov r0,#0x80000000 - mcr p14,0,r0,c10,c0,0 /* dcsr */ -#endif - - /* ---------------------------------------------------------------- */ - /* End memsetup */ - /* ---------------------------------------------------------------- */ - -#ifdef DEBUG_BLINK_ENABLE - /* 7th blink */ - bl blink -#endif - -endmemsetup: - - mov pc, r10 - - -#ifdef DEBUG_BLINK_ENABLE - -/* debug LED code */ - -/* delay about 200ms */ -delay: - - /* reset OSCR to 0 */ - ldr r8, =OSCR - mov r9, #0 - str r9, [r8] - - /* make sure new value has stuck */ -1: - ldr r8, =OSCR - ldr r9, [r8] - mov r8, #0x10000 - cmp r9, r8 - bgt 1b - - /* now, wait for delay to expire */ -1: - ldr r8, =OSCR - ldr r9, [r8] - mov r8, #0xd4000 - cmp r8, r9 - bgt 1b - - mov pc, lr - -/* blink code -- trashes r7, r8, r9 */ - -.globl blink -blink: - - mov r7, lr - - /* set GPIO10 as outout */ - ldr r8, =GPDR0 - ldr r9, [r8] - orr r9, r9, #(1<<10) - str r9, [r8] - - /* turn LED off */ - mov r9, #(1<<10) - ldr r8, =GPCR0 - str r9, [r8] - bl delay - - /* turn LED on */ - mov r9, #(1<<10) - ldr r8, =GPSR0 - str r9, [r8] - bl delay - - /* turn LED off */ - mov r9, #(1<<10) - ldr r8, =GPCR0 - str r9, [r8] - - mov pc, r7 - -#endif diff --git a/board/pxa255_idp/u-boot.lds b/board/pxa255_idp/u-boot.lds index 20ce108..2facd83 100644 --- a/board/pxa255_idp/u-boot.lds +++ b/board/pxa255_idp/u-boot.lds @@ -44,6 +44,7 @@ SECTIONS . = ALIGN(4); .got : { *(.got) }
+ . = .; __u_boot_cmd_start = .; .u_boot_cmd : { *(.u_boot_cmd) } __u_boot_cmd_end = .; diff --git a/cpu/pxa/config.mk b/cpu/pxa/config.mk index fb810ca..f0b86b7 100644 --- a/cpu/pxa/config.mk +++ b/cpu/pxa/config.mk @@ -25,8 +25,7 @@ PLATFORM_RELFLAGS += -fno-strict-aliasing -fno-common -ffixed-r8 \ -msoft-float
-#PLATFORM_CPPFLAGS += -mapcs-32 -march=armv4 -mtune=strongarm1100 -PLATFORM_CPPFLAGS += -march=armv5 -mtune=xscale +PLATFORM_CPPFLAGS += -march=armv5te -mtune=xscale # ========================================================================= # # Supply options according to compiler version diff --git a/cpu/pxa/serial.c b/cpu/pxa/serial.c index 51e7f65..9ba457e 100644 --- a/cpu/pxa/serial.c +++ b/cpu/pxa/serial.c @@ -35,17 +35,17 @@
DECLARE_GLOBAL_DATA_PTR;
-#define FFUART 0 -#define BTUART 1 -#define STUART 2 +#define FFUART_INDEX 0 +#define BTUART_INDEX 1 +#define STUART_INDEX 2
#ifndef CONFIG_SERIAL_MULTI #if defined (CONFIG_FFUART) -#define UART_INDEX FFUART +#define UART_INDEX FFUART_INDEX #elif defined (CONFIG_BTUART) -#define UART_INDEX BTUART +#define UART_INDEX BTUART_INDEX #elif defined (CONFIG_STUART) -#define UART_INDEX STUART +#define UART_INDEX STUART_INDEX #else #error "Bad: you didn't configure serial ..." #endif @@ -71,7 +71,7 @@ void pxa_setbrg_dev (unsigned int uart_index) hang ();
switch (uart_index) { - case FFUART: + case FFUART_INDEX: #ifdef CONFIG_CPU_MONAHANS CKENA |= CKENA_22_FFUART; #else @@ -90,7 +90,7 @@ void pxa_setbrg_dev (unsigned int uart_index) FFIER = IER_UUE; /* Enable FFUART */ break;
- case BTUART: + case BTUART_INDEX: #ifdef CONFIG_CPU_MONAHANS CKENA |= CKENA_21_BTUART; #else @@ -110,7 +110,7 @@ void pxa_setbrg_dev (unsigned int uart_index)
break;
- case STUART: + case STUART_INDEX: #ifdef CONFIG_CPU_MONAHANS CKENA |= CKENA_23_STUART; #else @@ -154,20 +154,20 @@ int pxa_init_dev (unsigned int uart_index) void pxa_putc_dev (unsigned int uart_index,const char c) { switch (uart_index) { - case FFUART: + case FFUART_INDEX: /* wait for room in the tx FIFO on FFUART */ while ((FFLSR & LSR_TEMT) == 0) WATCHDOG_RESET (); /* Reset HW Watchdog, if needed */ FFTHR = c; break;
- case BTUART: + case BTUART_INDEX: while ((BTLSR & LSR_TEMT ) == 0 ) WATCHDOG_RESET (); /* Reset HW Watchdog, if needed */ BTTHR = c; break;
- case STUART: + case STUART_INDEX: while ((STLSR & LSR_TEMT ) == 0 ) WATCHDOG_RESET (); /* Reset HW Watchdog, if needed */ STTHR = c; @@ -187,11 +187,11 @@ void pxa_putc_dev (unsigned int uart_index,const char c) int pxa_tstc_dev (unsigned int uart_index) { switch (uart_index) { - case FFUART: + case FFUART_INDEX: return FFLSR & LSR_DR; - case BTUART: + case BTUART_INDEX: return BTLSR & LSR_DR; - case STUART: + case STUART_INDEX: return STLSR & LSR_DR; } return -1; @@ -205,16 +205,16 @@ int pxa_tstc_dev (unsigned int uart_index) int pxa_getc_dev (unsigned int uart_index) { switch (uart_index) { - case FFUART: + case FFUART_INDEX: while (!(FFLSR & LSR_DR)) WATCHDOG_RESET (); /* Reset HW Watchdog, if needed */ return (char) FFRBR & 0xff;
- case BTUART: + case BTUART_INDEX: while (!(BTLSR & LSR_DR)) WATCHDOG_RESET (); /* Reset HW Watchdog, if needed */ return (char) BTRBR & 0xff; - case STUART: + case STUART_INDEX: while (!(STLSR & LSR_DR)) WATCHDOG_RESET (); /* Reset HW Watchdog, if needed */ return (char) STRBR & 0xff; @@ -233,32 +233,32 @@ pxa_puts_dev (unsigned int uart_index,const char *s) #if defined (CONFIG_FFUART) static int ffuart_init(void) { - return pxa_init_dev(FFUART); + return pxa_init_dev(FFUART_INDEX); }
static void ffuart_setbrg(void) { - return pxa_setbrg_dev(FFUART); + return pxa_setbrg_dev(FFUART_INDEX); }
static void ffuart_putc(const char c) { - return pxa_putc_dev(FFUART,c); + return pxa_putc_dev(FFUART_INDEX,c); }
static void ffuart_puts(const char *s) { - return pxa_puts_dev(FFUART,s); + return pxa_puts_dev(FFUART_INDEX,s); }
static int ffuart_getc(void) { - return pxa_getc_dev(FFUART); + return pxa_getc_dev(FFUART_INDEX); }
static int ffuart_tstc(void) { - return pxa_tstc_dev(FFUART); + return pxa_tstc_dev(FFUART_INDEX); }
struct serial_device serial_ffuart_device = @@ -277,32 +277,32 @@ struct serial_device serial_ffuart_device = #if defined (CONFIG_BTUART) static int btuart_init(void) { - return pxa_init_dev(BTUART); + return pxa_init_dev(BTUART_INDEX); }
static void btuart_setbrg(void) { - return pxa_setbrg_dev(BTUART); + return pxa_setbrg_dev(BTUART_INDEX); }
static void btuart_putc(const char c) { - return pxa_putc_dev(BTUART,c); + return pxa_putc_dev(BTUART_INDEX,c); }
static void btuart_puts(const char *s) { - return pxa_puts_dev(BTUART,s); + return pxa_puts_dev(BTUART_INDEX,s); }
static int btuart_getc(void) { - return pxa_getc_dev(BTUART); + return pxa_getc_dev(BTUART_INDEX); }
static int btuart_tstc(void) { - return pxa_tstc_dev(BTUART); + return pxa_tstc_dev(BTUART_INDEX); }
struct serial_device serial_btuart_device = @@ -321,32 +321,32 @@ struct serial_device serial_btuart_device = #if defined (CONFIG_STUART) static int stuart_init(void) { - return pxa_init_dev(STUART); + return pxa_init_dev(STUART_INDEX); }
static void stuart_setbrg(void) { - return pxa_setbrg_dev(STUART); + return pxa_setbrg_dev(STUART_INDEX); }
static void stuart_putc(const char c) { - return pxa_putc_dev(STUART,c); + return pxa_putc_dev(STUART_INDEX,c); }
static void stuart_puts(const char *s) { - return pxa_puts_dev(STUART,s); + return pxa_puts_dev(STUART_INDEX,s); }
static int stuart_getc(void) { - return pxa_getc_dev(STUART); + return pxa_getc_dev(STUART_INDEX); }
static int stuart_tstc(void) { - return pxa_tstc_dev(STUART); + return pxa_tstc_dev(STUART_INDEX); }
struct serial_device serial_stuart_device = diff --git a/cpu/pxa/start.S b/cpu/pxa/start.S index ffaa30f..b922485 100644 --- a/cpu/pxa/start.S +++ b/cpu/pxa/start.S @@ -166,13 +166,17 @@ _start_armboot: .word start_armboot /* */ /****************************************************************************/ /* mk@tbd: Fix this! */ -#ifdef CONFIG_CPU_MONAHANS +#if defined(CONFIG_PXA250) || defined(CONFIG_CPU_MONAHANS) #undef ICMR #undef OSMR3 #undef OSCR #undef OWER #undef OIER #endif +#ifdef CONFIG_PXA250 +#undef RCSR +#undef CCCR +#endif
/* Interrupt-Controller base address */ IC_BASE: .word 0x40d00000 diff --git a/include/configs/pxa255_idp.h b/include/configs/pxa255_idp.h index 0e884fc..4a9cadb 100644 --- a/include/configs/pxa255_idp.h +++ b/include/configs/pxa255_idp.h @@ -38,10 +38,11 @@ #include <asm/arch/pxa-regs.h>
/* - * If we are developing, we might want to start armboot from ram + * If we are developing, we might want to start U-Boot from RAM * so we MUST NOT initialize critical regs like mem-timing ... */ -#define CONFIG_INIT_CRITICAL /* undef for developing */ +#undef CONFIG_SKIP_LOWLEVEL_INIT /* define for developing */ +#undef CONFIG_SKIP_RELOCATE_UBOOT /* define for developing */
/* * define the following to enable debug blinks. A debug blink function @@ -62,6 +63,7 @@ #endif
#define CONFIG_MMC 1 +#define CONFIG_DOS_PARTITION 1 #define BOARD_LATE_INIT 1
#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ @@ -121,7 +123,6 @@ #define CONFIG_CMD_FAT #define CONFIG_CMD_DHCP
- #define CONFIG_BOOTDELAY 3 #define CONFIG_BOOTCOMMAND "bootm 40000" #define CONFIG_BOOTARGS "root=/dev/mtdblock2 rootfstype=cramfs console=ttyS0,115200" @@ -332,7 +333,7 @@ #define CFG_FLASH_CFI_DRIVER 1
#define CFG_MONITOR_BASE 0 -#define CFG_MONITOR_LEN 0x40000 +#define CFG_MONITOR_LEN PHYS_FLASH_SECT_SIZE
#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ #define CFG_MAX_FLASH_SECT 128 /* max number of sectors on one chip */ @@ -347,7 +348,7 @@ #define CFG_ENV_IS_IN_FLASH 1 /* Addr of Environment Sector */ #define CFG_ENV_ADDR (PHYS_FLASH_1 + PHYS_FLASH_SIZE - 0x40000) -#define CFG_ENV_SIZE 0x40000 /* Total Size of Environment Sector */ -#define CFG_ENV_SECT_SIZE 0x40000 +#define CFG_ENV_SIZE PHYS_FLASH_SECT_SIZE /* Total Size of Environment Sector */ +#define CFG_ENV_SECT_SIZE (PHYS_FLASH_SECT_SIZE / 16)
#endif /* __CONFIG_H */ diff --git a/include/part.h b/include/part.h index 29c0320..37b2b68 100644 --- a/include/part.h +++ b/include/part.h @@ -38,9 +38,9 @@ typedef struct block_dev_desc { #endif lbaint_t lba; /* number of blocks */ unsigned long blksz; /* block size */ - unsigned char vendor [40+1]; /* IDE model, SCSI Vendor */ - unsigned char product[20+1]; /* IDE Serial no, SCSI product */ - unsigned char revision[8+1]; /* firmware revision */ + char vendor [40+1]; /* IDE model, SCSI Vendor */ + char product[20+1]; /* IDE Serial no, SCSI product */ + char revision[8+1]; /* firmware revision */ unsigned long (*block_read)(int dev, unsigned long start, lbaint_t blkcnt, --
Marcel Ziswiler
