Re: [U-Boot] [PATCH 1/4] Armada100: Ethernet support for Marvell gplugD
Dear Wolfgang,
Thanks for info, I have seen that. But i am not adding support for GPIO commands.
In reference to
+#define GPLR(x) GPIO_REG(BANK_OFF((x) >> 5) + 0x00) +#define GPDR(x) GPIO_REG(BANK_OFF((x) >> 5) + 0x0c) +#define GPSR(x) GPIO_REG(BANK_OFF((x) >> 5) + 0x18) +#define GPCR(x) GPIO_REG(BANK_OFF((x) >> 5) + 0x24) +#define GSDR(x) GPIO_REG(BANK_OFF((x) >> 5) + 0x54) +#define GCDR(x) GPIO_REG(BANK_OFF((x) >> 5) + 0x60)
Please use a C struct to dsescribe the register layout.
I have followed similar way of using GPIO as used by "drivers/gpio/kw_gpio.c" and defined in "include/asm/arch-kirkwood/gpio.h", so actually i am not adding GPIO support rather i wrote functions that are required by the Ethernet and other drivers.
Regards, Ajay Bhargav
Dear Ajay Bhargav,
In message 867041231.46865.1310120597114.JavaMail.root@ahm.einfochips.com you wrote:
Like the gpio command, your code should use the same generic gpio API.
In reference to
To me this looks different.
You are not getting the point. I'm asking for two things:
- Do not use a "base address + offset" notation (with a declartion of register offsets in your header files), but use C structs instead to describe the regioster layout, and then use proper I/O accessor functions on them.
- Do not implement your own GPIO framework, but instead use existing code.
Ajay Bhargav
