[U-Boot] [PATCH] topic-miamiplus: Run CPU at 800MHz for speedgrade-2
The miamiplus contains a speedgrade-2 device, which may run the CPU at 800MHz. Change the PLL setting to 800MHz, and adapt the setpoints in the devicetree.
Signed-off-by: Mike Looijmans mike.looijmans@topic.nl --- arch/arm/dts/zynq-topic-miamiplus.dts | 9 +++++++++ board/topic/zynq/zynq-topic-miamiplus/ps7_init_gpl.c | 4 ++-- 2 files changed, 11 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/zynq-topic-miamiplus.dts b/arch/arm/dts/zynq-topic-miamiplus.dts index 3036f6e..fef5941 100644 --- a/arch/arm/dts/zynq-topic-miamiplus.dts +++ b/arch/arm/dts/zynq-topic-miamiplus.dts @@ -12,6 +12,15 @@ compatible = "topic,miamiplus", "xlnx,zynq-7000"; };
+/* The miamiplus contains a speedgrade-2 device and runs at 800MHz */ +&cpu0 { + operating-points = < + /* kHz uV */ + 800000 1000000 + 400000 1000000 + >; +}; + &qspi { is-dual = <1>; }; diff --git a/board/topic/zynq/zynq-topic-miamiplus/ps7_init_gpl.c b/board/topic/zynq/zynq-topic-miamiplus/ps7_init_gpl.c index 5a92336..97a59a5 100644 --- a/board/topic/zynq/zynq-topic-miamiplus/ps7_init_gpl.c +++ b/board/topic/zynq/zynq-topic-miamiplus/ps7_init_gpl.c @@ -9,8 +9,8 @@
static unsigned long ps7_pll_init_data_3_0[] = { EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU, 0x0000DF0DU), - EMIT_MASKWRITE(0XF8000110, 0x003FFFF0U, 0x000FA220U), - EMIT_MASKWRITE(0XF8000100, 0x0007F000U, 0x00028000U), + EMIT_MASKWRITE(0XF8000110, 0x003FFFF0U, 0x000FA240U), + EMIT_MASKWRITE(0XF8000100, 0x0007F000U, 0x00030000U), EMIT_MASKWRITE(0XF8000100, 0x00000010U, 0x00000010U), EMIT_MASKWRITE(0XF8000100, 0x00000001U, 0x00000001U), EMIT_MASKWRITE(0XF8000100, 0x00000001U, 0x00000000U),
Mike Looijmans
