[PATCH 0/2] sf: dataflash: add support for AT45DB641E
Since AT45DB641E uses "extended device information" for reading JEDEC ID we must first introduce support for this feature. All code is borrowed from Linux kernel source code: drivers/mtd/devices/mtd_dataflash.c
Luca Ellero (2): sf: dataflash: add support for "extended ID" sf: dataflash: add support for AT45DB641E
drivers/mtd/spi/sf_dataflash.c | 101 ++++++++++++++++++++++----------- 1 file changed, 67 insertions(+), 34 deletions(-)
Take as reference Linux kernel code: drivers/mtd/devices/mtd_dataflash.c
Signed-off-by: Luca Ellero l.ellero@asem.it --- drivers/mtd/spi/sf_dataflash.c | 98 ++++++++++++++++++++++------------ 1 file changed, 64 insertions(+), 34 deletions(-)
diff --git a/drivers/mtd/spi/sf_dataflash.c b/drivers/mtd/spi/sf_dataflash.c index b59edd152c..351c41039a 100644 --- a/drivers/mtd/spi/sf_dataflash.c +++ b/drivers/mtd/spi/sf_dataflash.c @@ -70,6 +70,9 @@ #define OP_WRITE_SECURITY_REVC 0x9A #define OP_WRITE_SECURITY 0x9B /* revision D */
+#define DATAFLASH_SHIFT_EXTID 24 +#define DATAFLASH_SHIFT_ID 40 + struct dataflash { uint8_t command[16]; unsigned short page_offset; /* offset in flash address */ @@ -455,7 +458,7 @@ struct data_flash_info { * JEDEC id has a high byte of zero plus three data bytes: * the manufacturer id, then a two byte device id. */ - uint32_t jedec_id; + uint64_t jedec_id;
/* The size listed here is what works with OP_ERASE_PAGE. */ unsigned nr_pages; @@ -463,6 +466,7 @@ struct data_flash_info { uint16_t pageoffset;
uint16_t flags; +#define SUP_EXTID 0x0004 /* supports extended ID data */ #define SUP_POW2PS 0x0002 /* supports 2^N byte pages */ #define IS_POW2PS 0x0001 /* uses 2^N byte pages */ }; @@ -508,48 +512,26 @@ static struct data_flash_info dataflash_data[] = { { "at45db642d", 0x1f2800, 8192, 1024, 10, SUP_POW2PS | IS_POW2PS}, };
-static struct data_flash_info *jedec_probe(struct spi_slave *spi) +static struct data_flash_info *jedec_lookup(struct spi_slave *spi, + u64 jedec, bool use_extid) + { - int tmp; - uint8_t id[5]; - uint32_t jedec; - struct data_flash_info *info; - u8 opcode = CMD_READ_ID; + struct data_flash_info *info; int status;
- /* - * JEDEC also defines an optional "extended device information" - * string for after vendor-specific data, after the three bytes - * we use here. Supporting some chips might require using it. - * - * If the vendor ID isn't Atmel's (0x1f), assume this call failed. - * That's not an error; only rev C and newer chips handle it, and - * only Atmel sells these chips. - */ - tmp = spi_write_then_read(spi, &opcode, 1, NULL, id, sizeof(id)); - if (tmp < 0) { - printf("dataflash: error %d reading JEDEC ID\n", tmp); - return ERR_PTR(tmp); - } - if (id[0] != 0x1f) - return NULL; - - jedec = id[0]; - jedec = jedec << 8; - jedec |= id[1]; - jedec = jedec << 8; - jedec |= id[2]; + for (info = dataflash_data; + info < dataflash_data + ARRAY_SIZE(dataflash_data); + info++) { + if (use_extid && !(info->flags & SUP_EXTID)) + continue;
- for (tmp = 0, info = dataflash_data; - tmp < ARRAY_SIZE(dataflash_data); - tmp++, info++) { if (info->jedec_id == jedec) { if (info->flags & SUP_POW2PS) { status = dataflash_status(spi); if (status < 0) { debug("dataflash: status error %d\n", status); - return NULL; + return ERR_PTR(status); } if (status & 0x1) { if (info->flags & IS_POW2PS) @@ -564,12 +546,58 @@ static struct data_flash_info *jedec_probe(struct spi_slave *spi) } }
+ return ERR_PTR(-ENODEV); +} + +static struct data_flash_info *jedec_probe(struct spi_slave *spi) +{ + int tmp; + uint64_t jedec; + uint8_t id[sizeof(jedec)] = {0}; + const unsigned int id_size = 5; + struct data_flash_info *info; + u8 opcode = CMD_READ_ID; + + /* + * JEDEC also defines an optional "extended device information" + * string for after vendor-specific data, after the three bytes + * we use here. Supporting some chips might require using it. + * + * If the vendor ID isn't Atmel's (0x1f), assume this call failed. + * That's not an error; only rev C and newer chips handle it, and + * only Atmel sells these chips. + */ + tmp = spi_write_then_read(spi, &opcode, 1, NULL, id, id_size); + if (tmp < 0) { + printf("dataflash: error %d reading JEDEC ID\n", tmp); + return ERR_PTR(tmp); + } + + if (id[0] != 0x1f) + return NULL; + + jedec = be64_to_cpup((__be64 *)id); + + /* + * First, try to match device using extended device + * information + */ + info = jedec_lookup(spi, jedec >> DATAFLASH_SHIFT_EXTID, true); + if (!IS_ERR(info)) + return info; + /* + * If that fails, make another pass using regular ID + * information + */ + info = jedec_lookup(spi, jedec >> DATAFLASH_SHIFT_ID, false); + if (!IS_ERR(info)) + return info; /* * Treat other chips as errors ... we won't know the right page * size (it might be binary) even when we can tell which density * class is involved (legacy chip id scheme). */ - printf("dataflash: JEDEC id %06x not handled\n", jedec); + printf("dataflash: JEDEC id 0x%016llx not handled\n", jedec); return ERR_PTR(-ENODEV); }
@@ -618,6 +646,8 @@ static int spi_dataflash_probe(struct udevice *dev) (info->flags & SUP_POW2PS) ? 'd' : 'c'); if (status < 0) goto err_status; + else + return status; }
On Tue, Mar 22, 2022 at 4:26 PM Luca Ellero luca.ellero@brickedbrain.com wrote:
Linux commit id?
Linux commit id?
Hi Jagan, Linux kernel commit is the following:
commit 1da8869a428317a6d3cd8d47184cf87feb34a98b Author: Andrey Smirnov andrew.smirnov@gmail.com Date: Fri Apr 21 09:30:25 2017 -0700
Should I resend the 2 patches with this info added? Regards Luca Ellero
NOTE: this chip uses "extened device information"
Signed-off-by: Luca Ellero l.ellero@asem.it --- drivers/mtd/spi/sf_dataflash.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/mtd/spi/sf_dataflash.c b/drivers/mtd/spi/sf_dataflash.c index 351c41039a..85867817c7 100644 --- a/drivers/mtd/spi/sf_dataflash.c +++ b/drivers/mtd/spi/sf_dataflash.c @@ -510,6 +510,9 @@ static struct data_flash_info dataflash_data[] = {
{ "AT45DB642x", 0x1f2800, 8192, 1056, 11, SUP_POW2PS}, { "at45db642d", 0x1f2800, 8192, 1024, 10, SUP_POW2PS | IS_POW2PS}, + + { "AT45DB641E", 0x1f28000100ULL, 32768, 264, 9, SUP_EXTID | SUP_POW2PS}, + { "at45db641e", 0x1f28000100ULL, 32768, 256, 8, SUP_EXTID | SUP_POW2PS | IS_POW2PS}, };
Jagan Teki
Luca Ellero
