[U-Boot] [patch] csb337 board support (ARM at91rm9200)
Add support for csb337, an older at91rm9200 board. These boards originally shipped with MicroMonitor, not U-Boot. This config supports boot from Ethernet, and talks over I2C and console.
Open issues: - Console refuses to start at 115200 baud, and misbehaves if it's later changed to that speed. So, use 38400 (like MicroMonitor).
- USB didn't work; the software wouldn't detect usb-storage devices. So it's not yet enabled.
- There seems to be some issue copying lots of data from NOR flash. It works OK in chunks of up to 512 KB or so, but copying a kernel (1.4 MB) failed ... copying *way* over 15 MBytes, and trashing the DRAM image of U-Boot that was running. (Compiler issue?)
Sending this along anyway; it basically works, bugs can be fixed later.
Signed-off-by: David Brownell dbrownell@users.sourceforge.net --- NOTE: depends on cpu/arm920t/at91rm9200/ether.c patch to change how the Ethernet address is stored in chip registers so it matches the old MicroMonitor bug that Linux is working around.
MAKEALL | 1 Makefile | 3 board/csb337/Makefile | 49 +++++++++ board/csb337/config.mk | 1 board/csb337/csb337.c | 74 +++++++++++++++ board/csb337/u-boot.lds | 56 +++++++++++ include/configs/csb337.h | 222 +++++++++++++++++++++++++++++++++++++++++++++ 7 files changed, 406 insertions(+)
--- a/MAKEALL +++ b/MAKEALL @@ -579,6 +579,7 @@ LIST_at91=" \ at91sam9g20ek \ at91sam9rlek \ cmc_pu2 \ + csb337 \ csb637 \ kb9202 \ mp2usb \ --- a/Makefile +++ b/Makefile @@ -2638,6 +2638,9 @@ at91rm9200ek_config : unconfig cmc_pu2_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm920t cmc_pu2 NULL at91rm9200
+csb337_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm920t csb337 NULL at91rm9200 + csb637_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm920t csb637 NULL at91rm9200
--- /dev/null +++ b/board/csb337/Makefile @@ -0,0 +1,49 @@ +# +# (C) Copyright 2003-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS += $(BOARD).o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + --- /dev/null +++ b/board/csb337/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x21f00000 --- /dev/null +++ b/board/csb337/csb337.c @@ -0,0 +1,74 @@ +/* + * Copyright (C) 2009 David Brownell + * + * Based on csb637 support: + * + * (C) Copyright 2005 + * REA Elektronik GmbH <www.rea.de> + * Anders Larsen alarsen@rea.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/AT91RM9200.h> +#include <at91rm9200_net.h> +#include <lxt971a.h> + +DECLARE_GLOBAL_DATA_PTR; + + +int board_init(void) +{ + /* Enable Ctrlc */ + console_init_f(); + + gd->bd->bi_arch_number = MACH_TYPE_CSB337; + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + return 0; +} + +#if defined(CONFIG_DRIVER_ETHER) && defined(CONFIG_CMD_NET) + +/* The AT91 lxt972 glue modified the original lxt971 code by + * changing names and generalizing a bit. So we use "lxt972" + * names here even though the CSB337 has an lxt971 chip. + */ +extern unsigned char lxt972_InitPhy(AT91S_EMAC *mac); +extern unsigned lxt972_IsPhyConnected(AT91S_EMAC *mac); +extern unsigned char lxt972_GetLinkSpeed(AT91S_EMAC *mac); +extern unsigned char lxt972_AutoNegotiate(AT91S_EMAC *mac, int *status); + +void at91rm9200_GetPhyInterface(AT91S_PhyOps *ops) +{ + ops->Init = lxt972_InitPhy; + ops->IsPhyConnected = lxt972_IsPhyConnected; + ops->GetLinkSpeed = lxt972_GetLinkSpeed; + ops->AutoNegotiate = lxt972_AutoNegotiate; +} + +#endif --- /dev/null +++ b/board/csb337/u-boot.lds @@ -0,0 +1,56 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +/*OUTPUT_FORMAT("elf32-arm", "elf32-arm", "elf32-arm")*/ +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/arm920t/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss (NOLOAD) : { *(.bss) . = ALIGN(4); } + _end = .; +} --- /dev/null +++ b/include/configs/csb337.h @@ -0,0 +1,222 @@ +/* + * (C) Copyright 2005 REA Elektronik GmbH <www.rea.de> + * Anders Larsen alarsen@rea.de + * + * Configuation settings for the Cogent CSB337 board. + * Modified from CSB637 settings. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/sizes.h> + +/* CSB337 board from Cogent */ +#define CONFIG_MACH_CSB337 +#define CONFIG_AT91RM9200 + +//#define CONFIG_SKIP_LOWLEVEL_INIT + +#define AT91_SLOW_CLOCK 32768 /* slow clock crystal */ +#define AT91_MAIN_CLOCK 3686400 /* 3.6864 MHz crystal */ + +#define CONFIG_SYS_USE_MAIN_OSCILLATOR + +/* default timings shipped by Cogent (PLLA --> MCK): + * 184.32 MHz for CPU (PLLA) + * 46.08 MHz for memory and peripherals (PLL/4) + * 96.00 MHz for USB (PLLB) + */ +#define AT91_PLLA_DIV 1 +#define AT91_PLLA_MULT 50 +#define AT91_PLLA_CLOCK ((AT91_MAIN_CLOCK / AT91_PLLA_DIV) * AT91_PLLA_MULT) + +#define AT91_PLLB_DIV 24 +#define AT91_PLLB_MULT 625 +#define AT91_PLLB_CLOCK ((AT91_MAIN_CLOCK / AT91_PLLB_DIV) * AT91_PLLB_MULT) + +#define AT91C_MASTER_CLOCK (AT91_PLLA_CLOCK / 4) + +#define CONFIG_SYS_HZ 1000 + +/* NOTE: uses TC0, not system timer. */ +#define CONFIG_SYS_HZ_CLOCK (AT91C_MASTER_CLOCK / 2) + +/* clocks */ +#if 0 /* can't use this from startup.S, sigh */ +#define CONFIG_SYS_PLLAR_VAL \ + ( AT91C_CKGR_SRCA | AT91C_CKGR_OUTA_2 | (0x3e << 8) \ + | ((AT91_PLLA_MULT - 1) << 16) | (AT91_PLLA_DIV << 0)) +#define CONFIG_SYS_PLLBR_VAL \ + ( AT91C_CKGR_USB_PLL | AT91C_CKGR_OUTB_0 | (0x3e << 8) \ + | ((AT91_PLLB_MULT - 1) << 16) | (AT91_PLLB_DIV << 0)) +#define CONFIG_SYS_MCKR_VAL \ + (AT91C_PMC_MDIV_4 | AT91C_PMC_CSS_PLLA_CLK) +#else +#define CONFIG_SYS_PLLAR_VAL 0x20313e01 /* 184.32 MHz */ +#define CONFIG_SYS_PLLBR_VAL 0x12703e18 /* 96.00 MHz (+div2) */ +#define CONFIG_SYS_MCKR_VAL 0x00000302 /* 46.00 MHz */ +#endif + +#define CONFIG_SYS_MC_PUIA_VAL 0x00000000 /* NOTE: RESERVED ADDR! */ +#define CONFIG_SYS_MC_PUP_VAL 0x00000000 /* NOTE: RESERVED ADDR! */ +#define CONFIG_SYS_MC_PUER_VAL 0x00000000 /* NOTE: RESERVED ADDR! */ +#define CONFIG_SYS_MC_ASR_VAL 0x00000000 /* NOTE: READ-ONLY REG! */ +#define CONFIG_SYS_MC_AASR_VAL 0x00000000 /* NOTE: READ-ONLY REG! */ + +/* 32 bit bus */ +#define CONFIG_SYS_EBI_CSA_VAL 0x00000002 /* CS0=SMC, CS1=SDRAM */ +#define CONFIG_SYS_EBI_CFGR_VAL 0x00000000 /* internal d15..d0 pullups */ +#define CONFIG_SYS_PIOC_ASR_VAL 0Xffff0000 /* pc31..pc16 are d31..d16 */ +#define CONFIG_SYS_PIOC_BSR_VAL 0x00000000 +#define CONFIG_SYS_PIOC_PDR_VAL 0xffff0000 /* internal d31..d16 pullups */ + +/* CS0 == 16 bit flash */ +#define CONFIG_SYS_SMC_CSR0_VAL 0x1100328b /* 16 bit, 2 TDF, 10 WS */ + +/* CS1 == 32 bit SDRAM; timings are a function of the master clock speed */ +#define CONFIG_SYS_SDRC_CR_VAL 0x2188b0d5 /* SDRAM timings */ +#define CONFIG_SYS_SDRC_TR_VAL 0x00000200 /* Write refresh rate */ + +/* except maybe for SDRAM1, none of these are board-specic */ +#define CONFIG_SYS_SDRAM 0x20000000 /* address of SDRAM */ +#define CONFIG_SYS_SDRAM1 0x20000080 /* address of SDRAM + mode register value */ +#define CONFIG_SYS_SDRAM_VAL 0x00000000 /* scratch value written to SDRAM */ +#define CONFIG_SYS_SDRC_MR_VAL 0x00000002 /* Precharge All */ +#define CONFIG_SYS_SDRC_MR_VAL1 0x00000004 /* refresh */ +#define CONFIG_SYS_SDRC_MR_VAL2 0x00000003 /* Load Mode Register */ +#define CONFIG_SYS_SDRC_MR_VAL3 0x00000000 /* Normal Mode */ + +/* define one of CONFIG_{DBGU,USART0,USART1} for console */ +#define CONFIG_AT91RM9200_USART +#define CONFIG_DBGU + +#define CONFIG_BAUDRATE 38400 +#define CONFIG_SYS_BAUDRATE_TABLE {115200, 57600, 38400, 19200, 9600,} + +/* RAM info */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x20000000 +#define PHYS_SDRAM_SIZE SZ_32M + +/* NOR flash (boot device) */ +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE + +/* NOR FLASH - one 28F640J03A, 16 bits */ +#define PHYS_FLASH_SIZE SZ_8M +#define CONFIG_SYS_FLASH_BASE 0x10000000 +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT +#define CONFIG_SYS_FLASH_PROTECTION 1 /* hardware protection */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 64 + +#define NOR_SECTOR_SIZE SZ_128K + +#define CONFIG_MTD_PARTITIONS + +/* Ethernet, using full MII */ +#define CONFIG_DRIVER_ETHER + +#if 0 +/* REVISIT: USB failed to enumerate devices of any kind ... sw issues */ + +/* allow loading from USB media */ +#define CONFIG_USB_OHCI_NEW +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_SYS_USB_OHCI_REGS_BASE AT91_USB_HOST_BASE +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91-ohci" +#define CONFIG_USB_STORAGE +#endif + +/* I2C, RTC */ +#define CONFIG_HARD_I2C +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 0x08 /* SMBus host address */ + +#define CONFIG_RTC_DS1307 + +/* basic commands; and ones that need driver support */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_XIMG + +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_I2C +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_MTDPARTS +#define CONFIG_CMD_PING + +#ifdef CONFIG_USB_OHCI_NEW +#define CONFIG_CMD_USB +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#endif + +/* general U-Boot configuration */ +#undef CONFIG_USE_IRQ /* no IRQ/FIQ stuff */ + +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_CONSOLE_INFO_QUIET +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_PROMPT "CSB337# " +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_CMDLINE_EDITING +#define CONFIG_TIMESTAMP + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_NET_RETRY_COUNT 10 + +#define CONFIG_STACKSIZE SZ_64K /* regular stack */ +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* for initial data */ +#define CONFIG_SYS_MALLOC_LEN SZ_512K /* heap */ +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + SZ_16M) +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM + +#define CONFIG_SYS_CBSIZE SZ_1K /* Console I/O Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (2*CONFIG_SYS_CBSIZE) + +/* Linux interfacing */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_SYS_LOAD_ADDR 0x21000000 /* default load address */ + +/* flash layout: 3 sectors U-Boot, 1 sector env ... rest is configurable */ +#define UBOOT_SIZE (3 * NOR_SECTOR_SIZE) +#define CONFIG_ENV_SECT_SIZE NOR_SECTOR_SIZE + +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + UBOOT_SIZE) + +#define MTDIDS_DEFAULT "nor0=physmap-flash.0" +#define MTDPARTS_DEFAULT "mtdparts=physmap-flash.0" \ + ":512k(bootloader)ro,-(filesystem)" + +#endif /* __CONFIG_H */
Open issues:
A co-worker report me the same problem for the csb637 under uMON after trying U-Boot it's work fine I think there is a problem in the clock configuration I'll take a look later
what is the power on the USB?
Clock issue ot RAM timing issue
MAINTAINER entry missing
no need please remove
- csb337 \ csb637 \ kb9202 \ mp2usb \
- @$(MKCONFIG) $(@:_config=) arm arm920t csb337 NULL at91rm9200
<snip>
please remove the blank ine
- /* Enable Ctrlc */
- console_init_f();
no need
- gd->bd->bi_arch_number = MACH_TYPE_CSB337;
- gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- gd->bd->bi_dram[0].start = PHYS_SDRAM;
- gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE;
it will be better ot manage this in the config header
- changing names and generalizing a bit. So we use "lxt972"
- names here even though the CSB337 has an lxt971 chip.
:( please a header
- ops->Init = lxt972_InitPhy;
- ops->IsPhyConnected = lxt972_IsPhyConnected;
- ops->GetLinkSpeed = lxt972_GetLinkSpeed;
- ops->AutoNegotiate = lxt972_AutoNegotiate;
- (C) Copyright 2005 REA Elektronik GmbH <www.rea.de>
- Anders Larsen alarsen@rea.de
- Configuation settings for the Cogent CSB337 board.
- Modified from CSB637 settings.
- project.
- MA 02111-1307 USA
if no need please remove
- 184.32 MHz for CPU (PLLA)
- 46.08 MHz for memory and peripherals (PLL/4)
- 96.00 MHz for USB (PLLB)
- ( AT91C_CKGR_SRCA | AT91C_CKGR_OUTA_2 | (0x3e << 8) \
- | ((AT91_PLLA_MULT - 1) << 16) | (AT91_PLLA_DIV << 0))
- ( AT91C_CKGR_USB_PLL | AT91C_CKGR_OUTB_0 | (0x3e << 8) \
- | ((AT91_PLLB_MULT - 1) << 16) | (AT91_PLLB_DIV << 0))
- (AT91C_PMC_MDIV_4 | AT91C_PMC_CSS_PLLA_CLK)
+#if 0
please if CONFIG_CMD_USB
Best Regards, J.
Open issues:
Hmm, could be. This replicates the original clock settings and DRAM timings. DRAM is underclocked -- could be another 20 MHz faster or so (use divide-by-3 not divide-by-4). But changing that would mean re-computing *all* memory timings.
And I don't think I have copies of that old Strataflash stuff any more...
I don't understand the question. 5V of course. Not switchable.
Doesn't quite make sense. Something clobbered a termination condition, which would be in a register, or at worst in cache.
How would RAM timing cause breakage? The data copied was correct, in smaller chunks, and the termination condition wasn't stored in RAM. Or a clock issue, considering all the relevant cycles are inside the arm920t core?
I like the "compiler issue" theory better. :(
In mainline u-boot it seems to be needed. Can you maybe push your first set of patches to Wolfgang, which consolidate all that stuff?
You mean by defining an otherwise needless symbol, along the lines of CONFIG_SYS_AT91RM9200_LXT_PHY?
Probably simpler just always include those few lines, and not support building without Ethernet.
:( please a header
I'll stick it in hardware.h ... you can remove similar decls from other rm9200 boards then.
+#if 0
An #if 0 won't work without completely re-whacking things.
Right now the commands kick in *MUCH LATER* depending on whether the driver is available. And here, the driver (CONFIG_USB_OHCI_NEW driver) and its support is disabled since it's not working...
... and commands get configured starting here.
is the usb provide enough power to supply the usb key
the arm work need to be based on u-boot-arm tree
CONFIG_DRIVER_EHTER will be enough
:( please a header
a phy header will be better IMHO
+#if 0
so move it
Best Regards, J.
Well all the devices run on Linux just fine. Two were flash devices, one was an honest-to-gosh 200 MByte disk.
So it's fairly clear the issue relates to OHCI support in u-boot, perhaps specific to the rm9200. Not hardware.
+#if 0
so move it
That's what we call "way too much work". It involves completely restructuring things ... so that instead of enabling commands based on driver support (which may not be viable) it enables drivers (which may not work) based on commands (which should never have been enabled unless the relevant driver works).
IIRC it's work on my rm9200ek
+#if 0
so move it
so remove it until it will work
Best Regards, J.
Dear David Brownell,
Open issues:
Entry to MAINTAINERS missing.
Please don't add trailing empty lines.
Only one blank line here.
How about using get_ram_size() to auto-detect the size and test the memory?
Move prototypes to some header file, please.
Incorrect multiline comment style.
+#else
Please do not add dead code.
Line too long. (Please check globally).
David Brownell
