[U-Boot] [PATCH v2] mmc: dw_mmc: fix timeout calculate method
There are two cases not been considered: - use uint for timeout, it will overflow when size bigger than 512KB for it *8*1000 at the beginning, but we may use size up to 32MB; The 'timeout' will overflow if size bigger than 51.2MB after this fix, which should be enough for U-Boot; - The timeout is using clock speed for data rate, but the device may not have such high speed, eg. clock is 52MHz while the device write speed may be less than 10MB/s, and we may use up to 150MHz clock.
Fix them in this patch, the max timeout is about 6500 when size is 32MB after fix.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
Changes in v2: - use u32 instead of u64 to fix undefined reference to `__udivdi3' in arc architecure.
drivers/mmc/dw_mmc.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/dw_mmc.c b/drivers/mmc/dw_mmc.c index 22f6c7eefd..ebe7bcdd90 100644 --- a/drivers/mmc/dw_mmc.c +++ b/drivers/mmc/dw_mmc.c @@ -119,11 +119,12 @@ static unsigned int dwmci_get_timeout(struct mmc *mmc, const unsigned int size) { unsigned int timeout;
- timeout = size * 8 * 1000; /* counting in bits and msec */ - timeout *= 2; /* wait twice as long */ + timeout = size * 8; /* counting in bits */ + timeout *= 10; /* wait 10 times as long */ timeout /= mmc->clock; timeout /= mmc->bus_width; timeout /= mmc->ddr_mode ? 2 : 1; + timeout *= 1000; /* counting in msec */ timeout = (timeout < 1000) ? 1000 : timeout;
return timeout;
Kever Yang
