[U-Boot] [PATCH] CFI: geometry reversal for STMicro M29W320DT
Follow up to the flash_fixup_stm to fix geometry reversal on STMicro M29W320ET flash chip. The M29W320DT has 4 erase region.
Signed-off-by: Richard Retanubun RichardRetanubun@RuggedCom.com
--- My baseline is 2009.03-rc1. If there are STMicro/Numonyx guys on this mailing list, can you help provide a more 'generic' way of detection? this way the exception list does not have to grow a lot.
drivers/mtd/cfi_flash.c | 5 +++-- 1 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index a66feac..391d169 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1806,8 +1806,9 @@ static void flash_fixup_stm(flash_info_t *info, struct cfi_qry *qry) if (qry->num_erase_regions > 1) { /* reverse geometry if top boot part */ if (info->cfi_version < 0x3131) { - /* CFI < 1.1, guess by device id (only M29W320ET now) */ - if (info->device_id == 0x2256) { + /* CFI < 1.1, guess by device id (M29W320{DT,ET} only) */ + if (info->device_id == 0x22CA || + info->device_id == 0x2256) { cfi_reverse_geometry(qry); } }
Did you take a look at the Linux driver to see how this is handled there? Maybe they have a more "generic" solution...
Best regards, Stefan
Hi Stefan,
Thanks for the comments. I took a quick look around /drivers/mtd, but can't find a similar geometry reversal.
Unfortunately, I found this in:
/driver/mtd/chips/cfi_cmdset_0001.c [snip] { CFI_MFR_ST, 0x00ba, /* M28W320CT */ fixup_st_m28w320ct, NULL }, { CFI_MFR_ST, 0x00bb, /* M28W320CB */ fixup_st_m28w320cb, NULL }, [/snip]
By no means am I a CFI expert, but my impression is, if there has to be a part number specific fixup function for any reason, then it is a good indication that there are just some part specific peculiarity.
What utilities exist in Linux-world to do the equivalent of "flinfo" in u-boot, just so I can see if Linux has a more generic way.
And just in case it matters, our board with these flash is MMU-less, so if there is a different tool for uCLinux that will help too :)
- Richard
Hi Stefan,
Right.
At this level you really need to "read" the code and/or use the embedded debug output (if available) or add some new code to see what's going on.
I don't think that uCLinux has different "tools" here.
Hi Stefan,
Just following up on this patch, the only other action I've seen on with regards to this is to fake the device identification from top-boot to bottom boot, but I think this is more 'masking' the problem and I don't have enough visibility to see if it is a safe thing to do.
In any case, even the reversal from top-boot to bottom-boot still needs identification on a chip-per-chip basis.
In any case, I'd like to know if this patch is [ACK|NACK]?
Many thanks for your time.
- Richard
Hi Richard,
It's an ACK. Sorry, I forgot to take care of this patch. I'll apply it in quickly and ask Wolfgang to pull shortly so that this fix can be included in the upcoming 2009-03 release.
Thanks.
Richard Retanubun
Stefan Roese
