[U-Boot] [PATCH] at91sam9/at91cap: spi init wadd hardware chip select support
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/arm926ejs/at91/at91cap9_spi.c | 37 ++++++++++++++++++++++++++++----- cpu/arm926ejs/at91/at91sam9260_spi.c | 36 +++++++++++++++++++++++++++----- cpu/arm926ejs/at91/at91sam9261_spi.c | 36 +++++++++++++++++++++++++++----- cpu/arm926ejs/at91/at91sam9263_spi.c | 36 +++++++++++++++++++++++++++----- cpu/arm926ejs/at91/at91sam9rl_spi.c | 18 +++++++++++++-- 5 files changed, 136 insertions(+), 27 deletions(-)
diff --git a/cpu/arm926ejs/at91/at91cap9_spi.c b/cpu/arm926ejs/at91/at91cap9_spi.c index 356a804..cd8143b 100644 --- a/cpu/arm926ejs/at91/at91cap9_spi.c +++ b/cpu/arm926ejs/at91/at91cap9_spi.c @@ -38,15 +38,27 @@ void at91_spi0_hw_init(unsigned long cs_mask) at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_SPI0);
if (cs_mask & (1 << 0)) { - at91_set_gpio_output(AT91_PIN_PA5, 1); + at91_set_B_periph(AT91_PIN_PA5, 1); } if (cs_mask & (1 << 1)) { - at91_set_gpio_output(AT91_PIN_PA3, 1); + at91_set_B_periph(AT91_PIN_PA3, 1); } if (cs_mask & (1 << 2)) { - at91_set_gpio_output(AT91_PIN_PD0, 1); + at91_set_B_periph(AT91_PIN_PD0, 1); } if (cs_mask & (1 << 3)) { + at91_set_B_periph(AT91_PIN_PD1, 1); + } + if (cs_mask & (1 << 4)) { + at91_set_gpio_output(AT91_PIN_PA5, 1); + } + if (cs_mask & (1 << 5)) { + at91_set_gpio_output(AT91_PIN_PA3, 1); + } + if (cs_mask & (1 << 6)) { + at91_set_gpio_output(AT91_PIN_PD0, 1); + } + if (cs_mask & (1 << 7)) { at91_set_gpio_output(AT91_PIN_PD1, 1); } } @@ -61,15 +73,28 @@ void at91_spi1_hw_init(unsigned long cs_mask) at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_SPI1);
if (cs_mask & (1 << 0)) { - at91_set_gpio_output(AT91_PIN_PB15, 1); + at91_set_A_periph(AT91_PIN_PB15, 1); } if (cs_mask & (1 << 1)) { - at91_set_gpio_output(AT91_PIN_PB16, 1); + at91_set_A_periph(AT91_PIN_PB16, 1); } if (cs_mask & (1 << 2)) { - at91_set_gpio_output(AT91_PIN_PB17, 1); + at91_set_A_periph(AT91_PIN_PB17, 1); } if (cs_mask & (1 << 3)) { + at91_set_A_periph(AT91_PIN_PB18, 1); + } + if (cs_mask & (1 << 4)) { + at91_set_gpio_output(AT91_PIN_PB15, 1); + } + if (cs_mask & (1 << 5)) { + at91_set_gpio_output(AT91_PIN_PB16, 1); + } + if (cs_mask & (1 << 6)) { + at91_set_gpio_output(AT91_PIN_PB17, 1); + } + if (cs_mask & (1 << 7)) { at91_set_gpio_output(AT91_PIN_PB18, 1); } + } diff --git a/cpu/arm926ejs/at91/at91sam9260_spi.c b/cpu/arm926ejs/at91/at91sam9260_spi.c index 0105072..d6fd80e 100644 --- a/cpu/arm926ejs/at91/at91sam9260_spi.c +++ b/cpu/arm926ejs/at91/at91sam9260_spi.c @@ -38,15 +38,27 @@ void at91_spi0_hw_init(unsigned long cs_mask) at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_SPI0);
if (cs_mask & (1 << 0)) { - at91_set_gpio_output(AT91_PIN_PA3, 1); + at91_set_A_periph(AT91_PIN_PA3, 1); } if (cs_mask & (1 << 1)) { - at91_set_gpio_output(AT91_PIN_PC11, 1); + at91_set_B_periph(AT91_PIN_PC11, 1); } if (cs_mask & (1 << 2)) { - at91_set_gpio_output(AT91_PIN_PC16, 1); + at91_set_B_periph(AT91_PIN_PC16, 1); } if (cs_mask & (1 << 3)) { + at91_set_B_periph(AT91_PIN_PC17, 1); + } + if (cs_mask & (1 << 4)) { + at91_set_gpio_output(AT91_PIN_PA3, 1); + } + if (cs_mask & (1 << 5)) { + at91_set_gpio_output(AT91_PIN_PC11, 1); + } + if (cs_mask & (1 << 6)) { + at91_set_gpio_output(AT91_PIN_PC16, 1); + } + if (cs_mask & (1 << 7)) { at91_set_gpio_output(AT91_PIN_PC17, 1); } } @@ -61,15 +73,27 @@ void at91_spi1_hw_init(unsigned long cs_mask) at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_SPI1);
if (cs_mask & (1 << 0)) { - at91_set_gpio_output(AT91_PIN_PB3, 1); + at91_set_A_periph(AT91_PIN_PB3, 1); } if (cs_mask & (1 << 1)) { - at91_set_gpio_output(AT91_PIN_PC5, 1); + at91_set_B_periph(AT91_PIN_PC5, 1); } if (cs_mask & (1 << 2)) { - at91_set_gpio_output(AT91_PIN_PC4, 1); + at91_set_B_periph(AT91_PIN_PC4, 1); } if (cs_mask & (1 << 3)) { at91_set_gpio_output(AT91_PIN_PC3, 1); } + if (cs_mask & (1 << 4)) { + at91_set_gpio_output(AT91_PIN_PB3, 1); + } + if (cs_mask & (1 << 5)) { + at91_set_gpio_output(AT91_PIN_PC5, 1); + } + if (cs_mask & (1 << 6)) { + at91_set_gpio_output(AT91_PIN_PC4, 1); + } + if (cs_mask & (1 << 7)) { + at91_set_gpio_output(AT91_PIN_PC3, 1); + } } diff --git a/cpu/arm926ejs/at91/at91sam9261_spi.c b/cpu/arm926ejs/at91/at91sam9261_spi.c index f70320d..9383dc6 100644 --- a/cpu/arm926ejs/at91/at91sam9261_spi.c +++ b/cpu/arm926ejs/at91/at91sam9261_spi.c @@ -38,15 +38,27 @@ void at91_spi0_hw_init(unsigned long cs_mask) at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_SPI0);
if (cs_mask & (1 << 0)) { - at91_set_gpio_output(AT91_PIN_PA3, 1); + at91_set_A_periph(AT91_PIN_PA3, 1); } if (cs_mask & (1 << 1)) { - at91_set_gpio_output(AT91_PIN_PA4, 1); + at91_set_A_periph(AT91_PIN_PA4, 1); } if (cs_mask & (1 << 2)) { - at91_set_gpio_output(AT91_PIN_PA5, 1); + at91_set_A_periph(AT91_PIN_PA5, 1); } if (cs_mask & (1 << 3)) { + at91_set_A_periph(AT91_PIN_PA6, 1); + } + if (cs_mask & (1 << 4)) { + at91_set_gpio_output(AT91_PIN_PA3, 1); + } + if (cs_mask & (1 << 5)) { + at91_set_gpio_output(AT91_PIN_PA4, 1); + } + if (cs_mask & (1 << 6)) { + at91_set_gpio_output(AT91_PIN_PA5, 1); + } + if (cs_mask & (1 << 7)) { at91_set_gpio_output(AT91_PIN_PA6, 1); } } @@ -61,15 +73,27 @@ void at91_spi1_hw_init(unsigned long cs_mask) at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_SPI1);
if (cs_mask & (1 << 0)) { - at91_set_gpio_output(AT91_PIN_PB28, 1); + at91_set_A_periph(AT91_PIN_PB28, 1); } if (cs_mask & (1 << 1)) { - at91_set_gpio_output(AT91_PIN_PA24, 1); + at91_set_B_periph(AT91_PIN_PA24, 1); } if (cs_mask & (1 << 2)) { - at91_set_gpio_output(AT91_PIN_PA25, 1); + at91_set_B_periph(AT91_PIN_PA25, 1); } if (cs_mask & (1 << 3)) { + at91_set_A_periph(AT91_PIN_PA26, 1); + } + if (cs_mask & (1 << 4)) { + at91_set_gpio_output(AT91_PIN_PB28, 1); + } + if (cs_mask & (1 << 5)) { + at91_set_gpio_output(AT91_PIN_PA24, 1); + } + if (cs_mask & (1 << 6)) { + at91_set_gpio_output(AT91_PIN_PA25, 1); + } + if (cs_mask & (1 << 7)) { at91_set_gpio_output(AT91_PIN_PA26, 1); } } diff --git a/cpu/arm926ejs/at91/at91sam9263_spi.c b/cpu/arm926ejs/at91/at91sam9263_spi.c index 1dda04c..e52dd61 100644 --- a/cpu/arm926ejs/at91/at91sam9263_spi.c +++ b/cpu/arm926ejs/at91/at91sam9263_spi.c @@ -38,15 +38,27 @@ void at91_spi0_hw_init(unsigned long cs_mask) at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_SPI0);
if (cs_mask & (1 << 0)) { - at91_set_gpio_output(AT91_PIN_PA5, 1); + at91_set_B_periph(AT91_PIN_PA5, 1); } if (cs_mask & (1 << 1)) { - at91_set_gpio_output(AT91_PIN_PA3, 1); + at91_set_B_periph(AT91_PIN_PA3, 1); } if (cs_mask & (1 << 2)) { - at91_set_gpio_output(AT91_PIN_PA4, 1); + at91_set_B_periph(AT91_PIN_PA4, 1); } if (cs_mask & (1 << 3)) { + at91_set_B_periph(AT91_PIN_PB11, 1); + } + if (cs_mask & (1 << 4)) { + at91_set_gpio_output(AT91_PIN_PA5, 1); + } + if (cs_mask & (1 << 5)) { + at91_set_gpio_output(AT91_PIN_PA3, 1); + } + if (cs_mask & (1 << 6)) { + at91_set_gpio_output(AT91_PIN_PA4, 1); + } + if (cs_mask & (1 << 7)) { at91_set_gpio_output(AT91_PIN_PB11, 1); } } @@ -61,15 +73,27 @@ void at91_spi1_hw_init(unsigned long cs_mask) at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_SPI1);
if (cs_mask & (1 << 0)) { - at91_set_gpio_output(AT91_PIN_PB15, 1); + at91_set_A_periph(AT91_PIN_PB15, 1); } if (cs_mask & (1 << 1)) { - at91_set_gpio_output(AT91_PIN_PB16, 1); + at91_set_A_periph(AT91_PIN_PB16, 1); } if (cs_mask & (1 << 2)) { - at91_set_gpio_output(AT91_PIN_PB17, 1); + at91_set_A_periph(AT91_PIN_PB17, 1); } if (cs_mask & (1 << 3)) { + at91_set_A_periph(AT91_PIN_PB18, 1); + } + if (cs_mask & (1 << 4)) { + at91_set_gpio_output(AT91_PIN_PB15, 1); + } + if (cs_mask & (1 << 5)) { + at91_set_gpio_output(AT91_PIN_PB16, 1); + } + if (cs_mask & (1 << 6)) { + at91_set_gpio_output(AT91_PIN_PB17, 1); + } + if (cs_mask & (1 << 7)) { at91_set_gpio_output(AT91_PIN_PB18, 1); } } diff --git a/cpu/arm926ejs/at91/at91sam9rl_spi.c b/cpu/arm926ejs/at91/at91sam9rl_spi.c index aa9c183..389d6d8 100644 --- a/cpu/arm926ejs/at91/at91sam9rl_spi.c +++ b/cpu/arm926ejs/at91/at91sam9rl_spi.c @@ -38,15 +38,27 @@ void at91_spi0_hw_init(unsigned long cs_mask) at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_SPI);
if (cs_mask & (1 << 0)) { - at91_set_gpio_output(AT91_PIN_PA28, 1); + at91_set_A_periph(AT91_PIN_PA28, 1); } if (cs_mask & (1 << 1)) { - at91_set_gpio_output(AT91_PIN_PB7, 1); + at91_set_B_periph(AT91_PIN_PB7, 1); } if (cs_mask & (1 << 2)) { - at91_set_gpio_output(AT91_PIN_PD8, 1); + at91_set_A_periph(AT91_PIN_PD8, 1); } if (cs_mask & (1 << 3)) { + at91_set_B_periph(AT91_PIN_PD9, 1); + } + if (cs_mask & (1 << 4)) { + at91_set_gpio_output(AT91_PIN_PA28, 1); + } + if (cs_mask & (1 << 5)) { + at91_set_gpio_output(AT91_PIN_PB7, 1); + } + if (cs_mask & (1 << 6)) { + at91_set_gpio_output(AT91_PIN_PD8, 1); + } + if (cs_mask & (1 << 7)) { at91_set_gpio_output(AT91_PIN_PD9, 1); } }
Dear Jean-Christophe PLAGNIOL-VILLARD,
In message 1238158665-21317-1-git-send-email-plagnioj@jcrosoft.com you wrote:
What exactly is this commit message supposed to tell me? I cannot make head nor tail of it.
