[U-Boot] ARM+uBoot
Hello,
Could you tell me what does it mean that booting stops after: Uncompressing Linux........... done, booting the kernel.
I load kernel using this command: disk 0x400000 1:6;bootm
where 1:6 is partition with raw uImage.
Cheers, mRon
mRon a écrit :
Hello,
Cheers, mRon
It can mean quite a lot of things, including some horrible death of the kernel in very early stages of its initialization, but the most probable cause is that the kernel doesn't have a console to display messages to, as "booting the kernel" is the last message u-boot displays; whatever appears after that is from the kernel.
What are the complete parameters that you pass the kernel? Is it configured to use the same physical console as u-boot uses?
Amicalement,
Albert ARIBAUD pisze:
Hello! Ekhm...I am the person who mailed you yesterday about uBoot :). I successfully flashed the Lacie - I mean that now it recognises the flash. I am able to save environment variables, but it hangs after the message I previously wrote.
I have already tried: setenv bootargs console=ttyS0,115200 root=/dev/sda7 rw setenv bootargs console=ttyS0,115200 root=/dev/sda7 ro setenv bootargs console=ttyS0,115200
//on sda7 I have Debian
combining with loading the kernel via these commands:
setenv serverip 192.168.0.46; setenv ipaddr 192.168.0.80; tftp 400000 sda6
//sda6 is raw image of original Lacie's uImage
Cheers, mRon
I'm moving this conversion either to the linux ARM kernel mailing list or in private e-mail, as this is definitely not an u-boot issue.
Amicalement,
Albert ARIBAUD
mRon
