[U-Boot] [PATCH] drivers: pci: imx: fix enumeration logic error
By default, the subordinate is set equally to the secondary bus (1) when the RC boots, and does not alter afterwards.
This means that theoretically, the highest bus reachable downstream is bus 1.
Force the PCIe RC subordinate to 0xff, otherwise no downstream devices will be detected behind bus 1 if the booting OS does not allow enumerating a higher busnr than the subordinate value of the primary bus.
Signed-off-by: Koen Vandeputte koen.vandeputte@ncentric.com --- drivers/pci/pcie_imx.c | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/drivers/pci/pcie_imx.c b/drivers/pci/pcie_imx.c index 2900c8d..9277af9 100644 --- a/drivers/pci/pcie_imx.c +++ b/drivers/pci/pcie_imx.c @@ -612,6 +612,17 @@ static int imx_pcie_link_up(void) imx_pcie_regions_setup();
/* + * By default, the subordinate is set equally to the secondary + * bus (0x01) when the RC boots. + * This means that theoretically, only bus 1 is reachable from the RC. + * Force the PCIe RC subordinate to 0xff, otherwise no downstream + * devices will be detected if the enumeration is applied strictly. + */ + tmp = readl(MX6_DBI_ADDR + 0x18); + tmp |= (0xff << 16); + writel(tmp, MX6_DBI_ADDR + 0x18); + + /* * FIXME: Force the PCIe RC to Gen1 operation * The RC must be forced into Gen1 mode before bringing the link * up, otherwise no downstream devices are detected. After the
- tmp = readl(MX6_DBI_ADDR + 0x18);
- tmp |= (0xff << 16);
- writel(tmp, MX6_DBI_ADDR + 0x18);
- FIXME: Force the PCIe RC to Gen1 operation
- The RC must be forced into Gen1 mode before bringing the link
- up, otherwise no downstream devices are detected. After the
Best regards, Stefano Babic
Koen Vandeputte
Stefano Babic
