[PATCH] net: tftp: Fix incorrect tftp_next_ack on no OACK
When the tftp server did not send any OACK, the tftp_next_ack variable was not set to the correct value . As the server was transmitting blocks we generated a lot of 'Received unexpected block: $n, expected $n+1' error messages. Depending on the timeout setting the transfer could still complete though.
Signed-off-by: Harm Berntsen harm.berntsen@nedap.com CC: Ramon Fried rfried.dev@gmail.com ---
net/tftp.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/net/tftp.c b/net/tftp.c index 6fdb1a821a..9371d7ef2c 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -624,8 +624,10 @@ static void tftp_handler(uchar *pkt, unsigned dest, struct in_addr sip, tftp_cur_block++; tftp_cur_block %= TFTP_SEQUENCE_SIZE;
- if (tftp_state == STATE_SEND_RRQ) + if (tftp_state == STATE_SEND_RRQ) { debug("Server did not acknowledge any options!\n"); + tftp_next_ack = tftp_windowsize; + }
if (tftp_state == STATE_SEND_RRQ || tftp_state == STATE_OACK || tftp_state == STATE_RECV_WRQ) {
On Fri, Nov 27, 2020 at 11:45 PM Harm Berntsen harm.berntsen@nedap.com wrote:
} if (tftp_state == STATE_SEND_RRQ || tftp_state == STATE_OACK || tftp_state == STATE_RECV_WRQ) {
-- 2.29.2
Reviewed-By: Ramon Fried rfried.dev@gmail.com
Signed-off-by: Harm Berntsen harm.berntsen@nedap.com CC: Ramon Fried rfried.dev@gmail.com Reviewed-By: Ramon Fried rfried.dev@gmail.com
Harm Berntsen
Ramon Fried
