[PATCH v1 0/1] Fix peripheral USB mode detection
In the older USB controllers like for example in ChipIdea controller used by the Tegra 2 the "USBADRA: Device Address Advance" bitflag does not exist, so the new device address set during SET_ADDRESS can't be deferred by hardware, which causes the host to not recognize the device and give an error.
Instead store it until ep completes to apply the change into the hw register as Linux kernel does. This should fix regression on old and and be compatible with newer controllers.
Fixes usb peripheral on Tegra 2 devices.
Ion Agorria (1): usb: ci_udc: don't use "advance" feature when setting address
drivers/usb/gadget/ci_udc.c | 24 +++++++++++++++++++++++- drivers/usb/gadget/ci_udc.h | 1 + 2 files changed, 24 insertions(+), 1 deletion(-)
Signed-off-by: Ion Agorria ion@agorria.com Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- drivers/usb/gadget/ci_udc.c | 24 +++++++++++++++++++++++- drivers/usb/gadget/ci_udc.h | 1 + 2 files changed, 24 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/gadget/ci_udc.c b/drivers/usb/gadget/ci_udc.c index bbe03cfff1f..4bff75da759 100644 --- a/drivers/usb/gadget/ci_udc.c +++ b/drivers/usb/gadget/ci_udc.c @@ -649,12 +649,30 @@ static void flip_ep0_direction(void) } }
+/* + * This function explicitly sets the address, without the "USBADRA" (advance) + * feature, which is not supported by older versions of the controller. + */ +static void ci_set_address(struct ci_udc *udc, u8 address) +{ + DBG("%s %x\n", __func__, address); + writel(address << 25, &udc->devaddr); +} + static void handle_ep_complete(struct ci_ep *ci_ep) { struct ept_queue_item *item, *next_td; int num, in, len, j; struct ci_req *ci_req;
+ /* Set the device address that was previously sent by SET_ADDRESS */ + if (controller.next_device_address != 0) { + struct ci_udc *udc = (struct ci_udc *)controller.ctrl->hcor; + + ci_set_address(udc, controller.next_device_address); + controller.next_device_address = 0; + } + num = ci_ep->desc->bEndpointAddress & USB_ENDPOINT_NUMBER_MASK; in = (ci_ep->desc->bEndpointAddress & USB_DIR_IN) != 0; item = ci_get_qtd(num, in); @@ -783,7 +801,7 @@ static void handle_setup(void) * write address delayed (will take effect * after the next IN txn) */ - writel((r.wValue << 25) | (1 << 24), &udc->devaddr); + controller.next_device_address = r.wValue; req->length = 0; usb_ep_queue(controller.gadget.ep0, req, 0); return; @@ -814,6 +832,9 @@ static void stop_activity(void) int i, num, in; struct ept_queue_head *head; struct ci_udc *udc = (struct ci_udc *)controller.ctrl->hcor; + + ci_set_address(udc, 0); + writel(readl(&udc->epcomp), &udc->epcomp); #ifdef CONFIG_CI_UDC_HAS_HOSTPC writel(readl(&udc->epsetupstat), &udc->epsetupstat); @@ -934,6 +955,7 @@ static int ci_pullup(struct usb_gadget *gadget, int is_on) struct ci_udc *udc = (struct ci_udc *)controller.ctrl->hcor; if (is_on) { /* RESET */ + controller.next_device_address = 0; writel(USBCMD_ITC(MICRO_8FRAME) | USBCMD_RST, &udc->usbcmd); udelay(200);
diff --git a/drivers/usb/gadget/ci_udc.h b/drivers/usb/gadget/ci_udc.h index bea2f9f3fe3..807f2084c1e 100644 --- a/drivers/usb/gadget/ci_udc.h +++ b/drivers/usb/gadget/ci_udc.h @@ -105,6 +105,7 @@ struct ci_drv { struct ept_queue_head *epts; uint8_t *items_mem; struct ci_ep ep[NUM_ENDPOINTS]; + u8 next_device_address; };
struct ept_queue_head {
Hi Svyatoslav,
Thank you for the patch.
Since this is based on a linux commit, can we please mention the revision in the commit message?
Per my understanding, this would be: https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/?i...
- This function explicitly sets the address, without the "USBADRA" (advance)
- feature, which is not supported by older versions of the controller.
- DBG("%s %x\n", __func__, address);
- writel(address << 25, &udc->devaddr);
- /* Set the device address that was previously sent by SET_ADDRESS */
- if (controller.next_device_address != 0) {
- num = ci_ep->desc->bEndpointAddress & USB_ENDPOINT_NUMBER_MASK; in = (ci_ep->desc->bEndpointAddress & USB_DIR_IN) != 0; item = ci_get_qtd(num, in);
req->length = 0; usb_ep_queue(controller.gadget.ep0, req, 0); return;controller.next_device_address = r.wValue;
- ci_set_address(udc, 0);
- writel(readl(&udc->epcomp), &udc->epcomp);
writel(USBCMD_ITC(MICRO_8FRAME) | USBCMD_RST, &udc->usbcmd); udelay(200);controller.next_device_address = 0;
- u8 next_device_address;
Comparing to https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/?i...,
Can we please keep similar logic ? Having both: - bool setaddr - u8 address
This way, we keep the diff with the linux driver a bit lower.
2.43.0
Hello,
Yes that's the correct commit I found when researching why the issue didn't happen in Linux, I already found that Tegra 2 reference docs had a different information about the register compared to Tegra 3.
I consider that a single variable is enough since the value is only non-zero when we want to set a new address. But if is necessary i can copy like Linux does.
Regards, Ion Agorria
El mar, 15 oct 2024 a las 11:56, Mattijs Korpershoek (mkorpershoek@baylibre.com) escribió:
Hi Svyatoslav,
- bool setaddr
- u8 address
2.43.0
On mer., oct. 16, 2024 at 21:57, Ion Agorria ionpl9@gmail.com wrote:
Hello,
You are right, a single variable is enough. I'd still prefer to have what Linux does because it will make it easier to compare with the Linux driver in the future,
Thanks Mattijs
Hi Svyatoslav,
- bool setaddr
- u8 address
2.43.0
чт, 17 жовт. 2024 р. о 15:21 Mattijs Korpershoek mkorpershoek@baylibre.com пише:
Hello,
Hello!
Proposed patch already does what Linux changes do. Your request to make it "same" as Linux is impossible to achieve since the u-boot driver itself does not descend from Linux, nor it is similar to Linux one. There is nothing to compare with Linux in the future.
Best regards, Svyatoslav R.
Thanks Mattijs
Hi Svyatoslav,
- bool setaddr
- u8 address
2.43.0
Hello,
Hello!
I'm not saying it should be a verbatim copy of the Linux driver. I'm saying that keeping similar variable names can help people comparing both.
Ion just send previously:
""" Yes that's the correct commit I found when researching why the issue didn't happen in Linux """
So clearly, comparison with the linux driver is valuable given that it was done for **this very patch**.
Thanks Mattijs
Hi Svyatoslav,
- bool setaddr
- u8 address
2.43.0
Hello,
I already finished the fix before looking up and only moved the set address function outside as a func after seeing the linux version.
I think drivers are different enough so there isnt much to compare.
Regards, Ion
On Thu, 17 Oct 2024, 15:13 Mattijs Korpershoek, mkorpershoek@baylibre.com wrote:
Hello,
Hello!
Thanks Mattijs
Hi Svyatoslav,
On dim., oct. 13, 2024 at 17:58, Svyatoslav Ryhel <
controller
recognize
and
"USBADRA" (advance)
controller.
SET_ADDRESS */
*gadget, int is_on)
&udc->usbcmd);
udelay(200);
Comparing to
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/?i... ,
- bool setaddr
- u8 address
2.43.0
On 10/13/24 4:58 PM, Svyatoslav Ryhel wrote:
Sorry for the late reply.
log_debug() or dev_dbg() please.
wValue is word , u16 , but next_device_address is u8 below , why ?
- writel(readl(&udc->epcomp), &udc->epcomp); #ifdef CONFIG_CI_UDC_HAS_HOSTPC writel(readl(&udc->epsetupstat), &udc->epsetupstat);
Should this be u16 ?
нд, 27 жовт. 2024 р. о 18:09 Marek Vasut marex@denx.de пише:
DBG macro is used across entire driver, if you wish to replace it, then pls, send a followup with patch for entire driver. This is out of scope of this patch.
wValue is u16 but only 8 bits are relevant since USB address is 8 bit, hence u8. Changing wValue to u8 is out of scope of this patch as well.
#ifdef CONFIG_CI_UDC_HAS_HOSTPC writel(readl(&udc->epsetupstat), &udc->epsetupstat);writel(readl(&udc->epcomp), &udc->epcomp);
No, USB address is only 8bits (u8)
нд, 27 жовт. 2024 р. о 18:42 Svyatoslav Ryhel clamor95@gmail.com пише:
If no other comments were proposed, may this patch be applied?
Hello,
Ah, sorry, i've been waiting for a v2 patch that includes a link to the related kernel commit as asked in [1].
Do you want me to fixup the commit message locally or will a v2 be send?
Thanks! Mattijs
[1] https://lore.kernel.org/all/87sesxzo2o.fsf@baylibre.com/
чт, 21 лист. 2024 р. о 13:14 Mattijs Korpershoek mkorpershoek@baylibre.com пише:
Hello,
Thanks! Mattijs
Both options are acceptable, it is up to you, what to choose.
Thanks! Mattijs
Please send a v2 then. Thanks
Ion Agorria
Mattijs Korpershoek
Svyatoslav Ryhel
