[U-Boot] OMAP3 patch to improve performance?
I came across this patch that might be useful
http://lists.denx.de/pipermail/u-boot/2010-February/067534.html
In any case since the u-boot structure has changed this cannot be applied. If anybody is interested please send a new patch.
Regards, Sandeep
Dear Sandeep,
In message 0554BEF07D437848AF01B9C9B5F0BC5DBD1C11AD@dlee01.ent.ti.com you wrote:
That's actually prtty straightforward. Here it comes (completely untested :-)
From 0223e42a48417ad18276d2709206b404c8796807 Mon Sep 17 00:00:00 2001
From: Siarhei Siamashka siarhei.siamashka@gmail.com Date: Sat, 6 Feb 2010 16:19:46 +0000 Subject: [PATCH] OMAP3: remove useless ASA bit from AUXCR
Setting ASA bit hurts performance for the code which has lots of I-cache misses and there are no Cortex-A8 errata workarounds which would require to have it.
A test program which intentionally stresses I-cache misses on conditional branches is attached.
ASA bit is not set:
real 0m2.940s user 0m2.930s sys 0m0.008s
ASA bit is set:
real 0m3.470s user 0m3.461s sys 0m0.008s
The difference on some real applications is much more modest and is just something like ~0.5%, but every little bit helps.
/**** start of bench_ASA.c ****/ void __attribute__((naked)) f(int count, void *rand) { asm volatile ( " push {r4, r5, r6, lr}\n" " mov r4, r0\n" " mov r5, r1\n" "0:\n" ".rept 4096\n" " blx r5\n" " tst r0, #1\n" " bne 1f\n" " b 2f\n" ".balign 64\n" "1:\n" ".rept 15\n" " add r0, r0, #0\n" ".endr\n" " b 3f\n" ".balign 64\n" "2:\n" ".rept 16\n" " add r0, r0, #0\n" ".endr\n" "3:\n" ".endr\n" " subs r4, r4, #1\n" " bgt 0b\n" " pop {r4, r5, r6, pc}\n" ); } int main() { f(1000, rand); return 0; } /**** end of bench_ASA.c ****/
Signed-off-by: Siarhei Siamashka siarhei.siamashka@gmail.com --- arch/arm/cpu/armv7/omap3/cache.S | 1 - 1 files changed, 0 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap3/cache.S b/arch/arm/cpu/armv7/omap3/cache.S index cda87ba..2854771 100644 --- a/arch/arm/cpu/armv7/omap3/cache.S +++ b/arch/arm/cpu/armv7/omap3/cache.S @@ -169,7 +169,6 @@ setup_auxcr: orr r1, r3, r2, lsr #20-4 @ combine variant and revision mov r12, #0x3 mrc p15, 0, r0, c1, c0, 1 - orr r0, r0, #0x10 @ Enable ASA @ Enable L1NEON on pre-r2p1 (erratum 621766 workaround) cmp r1, #0x21 orrlt r0, r0, #1 << 5
Dear Sandeep,
Thanks but this now effects both OMAP3 and OMAP4, it needs quite a bit of testing in my opinion.
From 0223e42a48417ad18276d2709206b404c8796807 Mon Sep 17 00:00:00 2001 From: Siarhei Siamashka siarhei.siamashka@gmail.com Date: Sat, 6 Feb 2010 16:19:46 +0000 Subject: [PATCH] OMAP3: remove useless ASA bit from AUXCR
ASA bit is not set:
ASA bit is set:
-- 1.7.3.2
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Never put off until tomorrow what you can put off indefinitely.
On Saturday 20 November 2010 01:12:22 Paulraj, Sandeep wrote:
Dear Sandeep,
Yes, this straightforward change looks ok to me.
Why do you think it affects OMAP4?
OMAP4 uses Cortex-A9 with totally different bits in Auxiliary Control Register. This ASA bit (and the patch) is only relevant for Cortex-A8.
Anyway, additional testing and ACK would be surely welcome :-)
Is there anything else expected to be done from my side? As I mentioned before, I would really prefer if TI could deal with this stuff themselves. Just because they ought to have all the most relevant information.
There are actually more problems (already known to TI) related to the use of ASA bit on OMAP3 Cortex-A8: http://article.gmane.org/gmane.linux.kernel/1048445
I don't know any of the details related to these reliability issues mentioned by Richard. But I still think that u-boot should not be setting ASA bit, there are just too many reasons not to do that.
Paulraj, Sandeep
Siarhei Siamashka
