[U-Boot] Kernel boot halts with "Verifying Checksum ... Bad Data CRC"
I'm not sure if this is specifically related to u boot.
I have compiled a linux kernel, which if I run on a system with flash memory with 256k sector size there are no problems, however if I rebuild for a system using flash with 64k sector size the boot process halts with the following errors
Booting image at 00060000 ... ## Copy image from flash 00060000 to ram 00200000 ... Image Name: Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 1759300 Bytes = 1.7 MB Load Address: 00008000 Entry Point: 00008000 Verifying Checksum ... Bad Data CRC
The script I'm using to make my kernel image is:
SRC=$2/arch/arm/boot/uImage if [ -f $SRC ]; then printf "Kernel source in: %s\n" $SRC else printf "Error: No kernel source in : %s\n" $SRC exit 0 fi mkimage -T kernel -C none -a 0x8000 -e 0x8000 -d $SRC scp_uimage
The above script is called with:
echo "Destination: scp_zimage"create_flash_image kernel linux-2.6.24/
What do I need to do differently with mkimage so that u boot is happy with the CRC?
Andrew
Dear Ellis Andrew,
I'd say it's a programming error (you're writing your flash incorrectly or your uboot is configured for 256kb flash)? This is not autodetected.
Also not, make uImage in the kernel tree should do the job.
Andrew
Best regards, Marek Vasut
Ellis Andrew
