[U-Boot] [PATCH V4 1/2] rockchip: dts: tinker: Move u-boot dmc initialization to specific section
dmc is used to initialize the memory controller. It's needed by u-boot. Move it in the specific section
Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- Changes: nothing --- arch/arm/dts/rk3288-tinker-u-boot.dtsi | 12 ++++++++++++ arch/arm/dts/rk3288-tinker.dts | 12 ------------ 2 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/arch/arm/dts/rk3288-tinker-u-boot.dtsi b/arch/arm/dts/rk3288-tinker-u-boot.dtsi index f7f9d6dc72..732aa4f91f 100644 --- a/arch/arm/dts/rk3288-tinker-u-boot.dtsi +++ b/arch/arm/dts/rk3288-tinker-u-boot.dtsi @@ -5,6 +5,18 @@
#include "rk3288-u-boot.dtsi"
+&dmc { + u-boot,dm-pre-reloc; + rockchip,pctl-timing = <0x215 0xc8 0x0 0x35 0x26 0x2 0x70 0x2000d + 0x6 0x0 0x8 0x4 0x17 0x24 0xd 0x6 + 0x4 0x8 0x4 0x76 0x4 0x0 0x30 0x0 + 0x1 0x2 0x2 0x4 0x0 0x0 0xc0 0x4 + 0x8 0x1f4>; + rockchip,phy-timing = <0x48d7dd93 0x187008d8 0x121076 + 0x0 0xc3 0x6 0x2>; + rockchip,sdram-params = <0x20d266a4 0x5b6 2 533000000 6 9 0>; +}; + &pinctrl { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/rk3288-tinker.dts b/arch/arm/dts/rk3288-tinker.dts index 94c3afe860..4b8405fd82 100644 --- a/arch/arm/dts/rk3288-tinker.dts +++ b/arch/arm/dts/rk3288-tinker.dts @@ -15,18 +15,6 @@ }; };
-&dmc { - rockchip,pctl-timing = <0x215 0xc8 0x0 0x35 0x26 0x2 0x70 0x2000d - 0x6 0x0 0x8 0x4 0x17 0x24 0xd 0x6 - 0x4 0x8 0x4 0x76 0x4 0x0 0x30 0x0 - 0x1 0x2 0x2 0x4 0x0 0x0 0xc0 0x4 - 0x8 0x1f4>; - rockchip,phy-timing = <0x48d7dd93 0x187008d8 0x121076 - 0x0 0xc3 0x6 0x2>; - rockchip,sdram-params = <0x20d266a4 0x5b6 2 533000000 6 9 0>; -}; - - &pinctrl { usb { host_vbus_drv: host-vbus-drv {
Support tinker-s board. The board is equivalent of tinker board except of emmc.
TODO: - support of usb current burst when the board is powered from pc
Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- Changes: v3->v4: Add mantainer and boot from to save the enviroment v2->v3: drop dmc section v1->v2: Add boot configuration for emmc --- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3288-tinker-s-u-boot.dtsi | 34 +++++++ arch/arm/dts/rk3288-tinker-s.dts | 29 ++++++ board/rockchip/tinker_rk3288/MAINTAINERS | 7 ++ board/rockchip/tinker_rk3288/tinker-rk3288.c | 12 +++ configs/tinker-s-rk3288_defconfig | 99 ++++++++++++++++++++ include/configs/tinker_rk3288.h | 1 + 7 files changed, 183 insertions(+) create mode 100644 arch/arm/dts/rk3288-tinker-s-u-boot.dtsi create mode 100644 arch/arm/dts/rk3288-tinker-s.dts create mode 100644 configs/tinker-s-rk3288_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 85ef00a2bd..dfaeea4a25 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -87,6 +87,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3288) += \ rk3288-popmetal.dtb \ rk3288-rock2-square.dtb \ rk3288-tinker.dtb \ + rk3288-tinker-s.dtb \ rk3288-veyron-jerry.dtb \ rk3288-veyron-mickey.dtb \ rk3288-veyron-minnie.dtb \ diff --git a/arch/arm/dts/rk3288-tinker-s-u-boot.dtsi b/arch/arm/dts/rk3288-tinker-s-u-boot.dtsi new file mode 100644 index 0000000000..a177fca73a --- /dev/null +++ b/arch/arm/dts/rk3288-tinker-s-u-boot.dtsi @@ -0,0 +1,34 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Amarula Solutions SRO + */ + +#include "rk3288-u-boot.dtsi" +#include "rk3288-tinker-u-boot.dtsi" + +/ { + chosen { + u-boot,spl-boot-order = \ + "same-as-spl", &sdmmc, &emmc; + }; +}; + +&emmc { + u-boot,dm-spl; +}; + +&emmc_clk { + u-boot,dm-spl; +}; + +&emmc_cmd { + u-boot,dm-spl; +}; + +&emmc_pwr { + u-boot,dm-spl; +}; + +&emmc_bus8 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/rk3288-tinker-s.dts b/arch/arm/dts/rk3288-tinker-s.dts new file mode 100644 index 0000000000..cc7ac5f881 --- /dev/null +++ b/arch/arm/dts/rk3288-tinker-s.dts @@ -0,0 +1,29 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd. + */ + +/dts-v1/; + +#include "rk3288-tinker.dtsi" + +/ { + model = "Rockchip RK3288 Asus Tinker Board S"; + compatible = "asus,rk3288-tinker-s", "rockchip,rk3288"; + + chosen { + stdout-path = &uart2; + }; +}; + +&emmc { + bus-width = <8>; + cap-mmc-highspeed; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_pwr &emmc_bus8>; + max-frequency = <150000000>; + mmc-hs200-1_8v; + mmc-ddr-1_8v; + status = "okay"; +}; diff --git a/board/rockchip/tinker_rk3288/MAINTAINERS b/board/rockchip/tinker_rk3288/MAINTAINERS index cddceafb6e..ed5de682c9 100644 --- a/board/rockchip/tinker_rk3288/MAINTAINERS +++ b/board/rockchip/tinker_rk3288/MAINTAINERS @@ -4,3 +4,10 @@ S: Maintained F: board/rockchip/tinker_rk3288 F: include/configs/tinker_rk3288.h F: configs/tinker-rk3288_defconfig + +TINKER-S-RK3288 +M: Michael Trimarchi michael@amarulasolutions.com +S: Maintained +F: board/rockchip/tinker_rk3288 +F: include/configs/tinker_rk3288.h +F: configs/tinker-s-rk3288_defconfig diff --git a/board/rockchip/tinker_rk3288/tinker-rk3288.c b/board/rockchip/tinker_rk3288/tinker-rk3288.c index 6c76c3c25c..7a0c3c997d 100644 --- a/board/rockchip/tinker_rk3288/tinker-rk3288.c +++ b/board/rockchip/tinker_rk3288/tinker-rk3288.c @@ -8,6 +8,8 @@ #include <env.h> #include <i2c_eeprom.h> #include <netdev.h> +#include <asm/arch-rockchip/bootrom.h> +#include <asm/io.h>
static int get_ethaddr_from_eeprom(u8 *addr) { @@ -33,3 +35,13 @@ int rk3288_board_late_init(void)
return 0; } + +int mmc_get_env_dev(void) +{ + u32 bootdevice_brom_id = readl(BROM_BOOTSOURCE_ID_ADDR); + + if (bootdevice_brom_id == BROM_BOOTSOURCE_EMMC) + return 0; + + return 1; +} diff --git a/configs/tinker-s-rk3288_defconfig b/configs/tinker-s-rk3288_defconfig new file mode 100644 index 0000000000..c851a93f31 --- /dev/null +++ b/configs/tinker-s-rk3288_defconfig @@ -0,0 +1,99 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_ROCKCHIP_RK3288=y +CONFIG_TARGET_TINKER_RK3288=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL_SIZE_LIMIT=307200 +CONFIG_SPL_STACK_R_ADDR=0x800000 +CONFIG_DEBUG_UART_BASE=0xff690000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART=y +CONFIG_TPL_SYS_MALLOC_F_LEN=0x4000 +CONFIG_SPL_SYS_MALLOC_F_LEN=0x4000 +CONFIG_SYS_MALLOC_F_LEN=0x4000 +# CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_USE_PREBOOT=y +CONFIG_SILENT_CONSOLE=y +CONFIG_CONSOLE_MUX=y +CONFIG_DEFAULT_FDT_FILE="rk3288-tinker-s.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x300000 +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_BMP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SPL_PARTITION_UUIDS=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="rk3288-tinker-s" +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +# CONFIG_SPL_SIMPLE_BUS is not set +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_I2C_EEPROM=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=20000000 +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_SPL_DM_REGULATOR_FIXED=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_DWC2=y +CONFIG_ROCKCHIP_USB2_PHY=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Rockchip" +CONFIG_USB_GADGET_VENDOR_NUM=0x2207 +CONFIG_USB_GADGET_PRODUCT_NUM=0x320a +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_CMD_DHRYSTONE=y +CONFIG_ERRNO_STR=y +CONFIG_DM_VIDEO=y +CONFIG_DISPLAY=y +CONFIG_VIDEO_ROCKCHIP=y +CONFIG_DISPLAY_ROCKCHIP_HDMI=y +CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/include/configs/tinker_rk3288.h b/include/configs/tinker_rk3288.h index 5adae68c91..f8a55a2cec 100644 --- a/include/configs/tinker_rk3288.h +++ b/include/configs/tinker_rk3288.h @@ -12,6 +12,7 @@ #undef BOOT_TARGET_DEVICES
#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ func(MMC, mmc, 1) \ func(USB, usb, 0) \ func(PXE, pxe, na) \
TODO:
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- rk3288-tinker-s.dtb \ rk3288-veyron-jerry.dtb \ rk3288-veyron-mickey.dtb \ rk3288-veyron-minnie.dtb \
- Copyright (C) 2019 Amarula Solutions SRO
- chosen {
+&emmc {
- u-boot,dm-spl;
+&emmc_clk {
- u-boot,dm-spl;
+&emmc_cmd {
- u-boot,dm-spl;
+&emmc_pwr {
- u-boot,dm-spl;
+&emmc_bus8 {
- u-boot,dm-spl;
- Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd.
+/dts-v1/;
- model = "Rockchip RK3288 Asus Tinker Board S";
- compatible = "asus,rk3288-tinker-s", "rockchip,rk3288";
- chosen {
+&emmc {
- bus-width = <8>;
- cap-mmc-highspeed;
- non-removable;
- pinctrl-names = "default";
- pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_pwr &emmc_bus8>;
- max-frequency = <150000000>;
- mmc-hs200-1_8v;
- mmc-ddr-1_8v;
- status = "okay";
return 0; }
- u32 bootdevice_brom_id = readl(BROM_BOOTSOURCE_ID_ADDR);
- if (bootdevice_brom_id == BROM_BOOTSOURCE_EMMC)
- return 1;
- func(MMC, mmc, 0) \ func(MMC, mmc, 1) \ func(USB, usb, 0) \ func(PXE, pxe, na) \
TODO:
Applied to u-boot-rockchip master.
Thanks, - Kever
Thanks,
- Kever
+/dts-v1/;
+TINKER-S-RK3288 +M: Michael Trimarchi michael@amarulasolutions.com +S: Maintained +F: board/rockchip/tinker_rk3288 +F: include/configs/tinker_rk3288.h +F: configs/tinker-s-rk3288_defconfig diff --git a/board/rockchip/tinker_rk3288/tinker-rk3288.c b/board/rockchip/tinker_rk3288/tinker-rk3288.c index 6c76c3c25c..7a0c3c997d 100644 --- a/board/rockchip/tinker_rk3288/tinker-rk3288.c +++ b/board/rockchip/tinker_rk3288/tinker-rk3288.c @@ -8,6 +8,8 @@ #include <env.h> #include <i2c_eeprom.h> #include <netdev.h> +#include <asm/arch-rockchip/bootrom.h> +#include <asm/io.h> static int get_ethaddr_from_eeprom(u8 *addr) { @@ -33,3 +35,13 @@ int rk3288_board_late_init(void) return 0; }
+ return 1; +} diff --git a/configs/tinker-s-rk3288_defconfig b/configs/tinker-s-rk3288_defconfig new file mode 100644 index 0000000000..c851a93f31 --- /dev/null +++ b/configs/tinker-s-rk3288_defconfig @@ -0,0 +1,99 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_ROCKCHIP_RK3288=y +CONFIG_TARGET_TINKER_RK3288=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL_SIZE_LIMIT=307200 +CONFIG_SPL_STACK_R_ADDR=0x800000 +CONFIG_DEBUG_UART_BASE=0xff690000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART=y +CONFIG_TPL_SYS_MALLOC_F_LEN=0x4000 +CONFIG_SPL_SYS_MALLOC_F_LEN=0x4000 +CONFIG_SYS_MALLOC_F_LEN=0x4000 +# CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_USE_PREBOOT=y +CONFIG_SILENT_CONSOLE=y +CONFIG_CONSOLE_MUX=y +CONFIG_DEFAULT_FDT_FILE="rk3288-tinker-s.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x300000 +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_BMP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SPL_PARTITION_UUIDS=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="rk3288-tinker-s" +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +# CONFIG_SPL_SIMPLE_BUS is not set +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_I2C_EEPROM=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=20000000 +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_SPL_DM_REGULATOR_FIXED=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_DWC2=y +CONFIG_ROCKCHIP_USB2_PHY=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Rockchip" +CONFIG_USB_GADGET_VENDOR_NUM=0x2207 +CONFIG_USB_GADGET_PRODUCT_NUM=0x320a +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_CMD_DHRYSTONE=y +CONFIG_ERRNO_STR=y +CONFIG_DM_VIDEO=y +CONFIG_DISPLAY=y +CONFIG_VIDEO_ROCKCHIP=y +CONFIG_DISPLAY_ROCKCHIP_HDMI=y +CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/include/configs/tinker_rk3288.h b/include/configs/tinker_rk3288.h index 5adae68c91..f8a55a2cec 100644 --- a/include/configs/tinker_rk3288.h +++ b/include/configs/tinker_rk3288.h @@ -12,6 +12,7 @@ #undef BOOT_TARGET_DEVICES #define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ func(MMC, mmc, 1) \ func(USB, usb, 0) \ func(PXE, pxe, na) \
Thanks, - Kever
Changes: nothing
+&dmc {
- u-boot,dm-pre-reloc;
0x8 0x1f4>;
0x0 0xc3 0x6 0x2>;
- &pinctrl { u-boot,dm-pre-reloc; };
-&dmc {
0x8 0x1f4>;
0x0 0xc3 0x6 0x2>;
Thanks, - Kever
Thanks,
- Kever
Changes: nothing
diff --git a/arch/arm/dts/rk3288-tinker-u-boot.dtsi b/arch/arm/dts/rk3288-tinker-u-boot.dtsi index f7f9d6dc72..732aa4f91f 100644 --- a/arch/arm/dts/rk3288-tinker-u-boot.dtsi +++ b/arch/arm/dts/rk3288-tinker-u-boot.dtsi @@ -5,6 +5,18 @@ #include "rk3288-u-boot.dtsi" +&dmc { + u-boot,dm-pre-reloc; + rockchip,pctl-timing = <0x215 0xc8 0x0 0x35 0x26 0x2 0x70 0x2000d + 0x6 0x0 0x8 0x4 0x17 0x24 0xd 0x6 + 0x4 0x8 0x4 0x76 0x4 0x0 0x30 0x0 + 0x1 0x2 0x2 0x4 0x0 0x0 0xc0 0x4 + 0x8 0x1f4>; + rockchip,phy-timing = <0x48d7dd93 0x187008d8 0x121076 + 0x0 0xc3 0x6 0x2>; + rockchip,sdram-params = <0x20d266a4 0x5b6 2 533000000 6 9 0>; +};
&pinctrl { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/rk3288-tinker.dts b/arch/arm/dts/rk3288-tinker.dts index 94c3afe860..4b8405fd82 100644 --- a/arch/arm/dts/rk3288-tinker.dts +++ b/arch/arm/dts/rk3288-tinker.dts @@ -15,18 +15,6 @@ }; }; -&dmc { - rockchip,pctl-timing = <0x215 0xc8 0x0 0x35 0x26 0x2 0x70 0x2000d - 0x6 0x0 0x8 0x4 0x17 0x24 0xd 0x6 - 0x4 0x8 0x4 0x76 0x4 0x0 0x30 0x0 - 0x1 0x2 0x2 0x4 0x0 0x0 0xc0 0x4 - 0x8 0x1f4>; - rockchip,phy-timing = <0x48d7dd93 0x187008d8 0x121076 - 0x0 0xc3 0x6 0x2>; - rockchip,sdram-params = <0x20d266a4 0x5b6 2 533000000 6 9 0>; -};
Kever Yang
Michael Trimarchi
