Re: [U-Boot] [PATCH v1 4/4] ARM: DRA7: fastboot: Implement reboot-bootloader command - Implemented fb_set_reboot_flag() for DRA7 - Defined a weak function, fb_check_reboot_flag() - Implemented for DRA7
Corrected Tom Rini's Mail id.
Regards, Dileep
On 3 March 2015 at 16:40, Dileep Katta dileep.katta@linaro.org wrote:
Signed-off-by: Angela Stegmaier angelabaker@ti.com Signed-off-by: Dileep Katta dileep.katta@linaro.org
board/ti/dra7xx/Makefile | 1 + board/ti/dra7xx/fastboot.c | 45 ++++++++++++++++++++++++++++++++++++ common/cmd_bootm.c | 5 ++++ drivers/usb/gadget/f_fastboot.c | 5 ++++ include/configs/dra7xx_evm_android.h | 14 +++++++++++ 5 files changed, 70 insertions(+) create mode 100644 board/ti/dra7xx/fastboot.c
diff --git a/board/ti/dra7xx/Makefile b/board/ti/dra7xx/Makefile index 434e8d1..ae730ae 100644 --- a/board/ti/dra7xx/Makefile +++ b/board/ti/dra7xx/Makefile @@ -6,3 +6,4 @@ #
obj-y := evm.o +obj-$(CONFIG_CMD_FASTBOOT) += fastboot.o diff --git a/board/ti/dra7xx/fastboot.c b/board/ti/dra7xx/fastboot.c new file mode 100644 index 0000000..e05010d --- /dev/null +++ b/board/ti/dra7xx/fastboot.c @@ -0,0 +1,45 @@ +/*
- (C) Copyright 2013
- Texas Instruments Incorporated, <www.ti.com>
- Lokesh Vutla lokeshvutla@ti.com
- Based on previous work by:
- Aneesh V aneesh@ti.com
- Steve Sakoman steve@sakoman.com
+#include <common.h> +#include <asm/io.h> +#include <asm-generic/gpio.h> +#include <config.h>
+int fb_set_reboot_flag(void) +{
/* clear all reset events */
__raw_writel(DRA7XX_PRM_RSTST_CLR, PRM_RSTST);
strncpy((char *)DRA7XX_PUBLIC_SAR_RAM_1_FREE, "bootloader",
DRA7XX_REBOOT_REASON_SIZE - 1);
*(((char *)DRA7XX_PUBLIC_SAR_RAM_1_FREE) +
DRA7XX_REBOOT_REASON_SIZE - 1) = '\0';
/* trigger warm reset */
__raw_writel(DRA7XX_PRM_RSTCTRL_RESET_WARM_BIT,
DRA7XX_PRM_RSTCTRL);
+int fb_check_reboot_flag(void) +{
/* Check if we are coming from a warm reset */
if (__raw_readl(DRA7XX_PRM_RSTST) &
DRA7XX_PRM_RSTST_RESET_WARM_BIT)
if (!strncmp((const char *)DRA7XX_PUBLIC_SAR_RAM_1_FREE,
"bootloader", DRA7XX_REBOOT_REASON_SIZE)) {
strncpy((char *)DRA7XX_PUBLIC_SAR_RAM_1_FREE, "",
DRA7XX_REBOOT_REASON_SIZE);
return 1;
+} diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 48199bf..00791be 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -729,6 +729,11 @@ int do_booti(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { int ret;
+#if defined(CONFIG_CMD_FASTBOOT)
if (!fb_check_reboot_flag())
do_fastboot(cmdtp, flag, argc, argv);
/* Consume 'booti' */ argc--; argv++;
diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index 206b6d1..a450357 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -332,6 +332,11 @@ int __weak fb_set_reboot_flag(void) return -ENOSYS; }
+int __weak fb_check_reboot_flag(void) +{
return -ENOSYS;
static void cb_reboot(struct usb_ep *ep, struct usb_request *req) { char *cmd = req->buf; diff --git a/include/configs/dra7xx_evm_android.h b/include/configs/dra7xx_evm_android.h index 68e7eec..2038e00 100644 --- a/include/configs/dra7xx_evm_android.h +++ b/include/configs/dra7xx_evm_android.h @@ -310,4 +310,18 @@ #endif #endif /* NOR support */
+#define DRA7XX_PUBLIC_SAR_RAM_1_FREE (0x4AE26000 + 0xFE0) +#define DRA7XX_PRM_RSTCTRL_RESET_WARM_BIT (1<<0) +#define DRA7XX_PRM_RSTST_RESET_WARM_BIT (1<<1) +#define DRA7XX_PRM_RSTST 0x4AE07D04 +#define DRA7XX_PRM_RSTCTRL 0x4AE07D00 +#define DRA7XX_PRM_RSTST_CLR 0xfff +#define DRA7XX_REBOOT_REASON_SIZE 0xf
+#define CONFIG_BOARD_MACH_TYPE 4070 +#define MEMORY_BASE 0x80000000 +#define CONFIG_ADDR_ATAGS (MEMORY_BASE + 0x100) +#define CONFIG_ADDR_DOWNLOAD (MEMORY_BASE + 0x02000000) +#define DEVICE_TREE 0x82f80000
#endif /* __CONFIG_DRA7XX_EVM_ANDROID_H */
1.8.3.2
Dileep Katta
