[U-Boot] [Patch 10/16] add supports to mips64 in io operation
diff --git a/arch/mips/include/asm/io.h b/arch/mips/include/asm/io.h index 025012a..80eab75 100644 --- a/arch/mips/include/asm/io.h +++ b/arch/mips/include/asm/io.h @@ -120,12 +120,20 @@ static inline void set_io_port_base(unsigned long base) */ extern inline phys_addr_t virt_to_phys(volatile void * address) { +#ifndef CONFIG_64BIT return CPHYSADDR(address); +#else + return XPHYSADDR(address); +#endif }
extern inline void * phys_to_virt(unsigned long address) { +#ifndef CONFIG_64BIT return (void *)KSEG0ADDR(address); +#else + return (void *)CKSEG0ADDR(address); +#endif }
/* @@ -133,12 +141,20 @@ extern inline void * phys_to_virt(unsigned long address) */ extern inline unsigned long virt_to_bus(volatile void * address) { +#ifndef CONFIG_64BIT return CPHYSADDR(address); +#else + return XPHYSADDR(address); +#endif }
extern inline void * bus_to_virt(unsigned long address) { +#ifndef CONFIG_64BIT return (void *)KSEG0ADDR(address); +#else + return (void *)CKSEG0ADDR(address); +#endif }
Zhi-zhou Zhang
