[U-Boot] [PATCH 1/4] mx7dsabresd: Fix LCD_PWR_EN output setting
LCD_PWR_EN controls the G pin of Q13 PMOS which needs low voltage to connect D to S for outputting LCD 3.3V. If LCD_PWR_EN is high, we measured the LCD 3v3 is actually 1.2V.
Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com --- board/freescale/mx7dsabresd/mx7dsabresd.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/freescale/mx7dsabresd/mx7dsabresd.c b/board/freescale/mx7dsabresd/mx7dsabresd.c index c3062f1..1f4fc03 100644 --- a/board/freescale/mx7dsabresd/mx7dsabresd.c +++ b/board/freescale/mx7dsabresd/mx7dsabresd.c @@ -171,7 +171,7 @@ static enum qn_level seq[3][2] = {
static enum qn_func qn_output[8] = { qn_disable, qn_reset, qn_reset, qn_reset, qn_reset, qn_reset, qn_enable, - qn_enable + qn_disable };
static void iox74lv_init(void)
Fix 74LV OE gpio index. gpio index is wrong, so gpio output will not have effect, since we use wrong GPIO5_IO18, but not correct GPIO5_IO8.
And at the end of the initialization of 74lv init, should keep OE voltage level at LOW to make 74lv output the correct voltage.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com --- board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c index 88d3fbd..b861122 100644 --- a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c +++ b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c @@ -66,7 +66,7 @@ DECLARE_GLOBAL_DATA_PTR; #define IOX_SDI IMX_GPIO_NR(5, 10) #define IOX_STCP IMX_GPIO_NR(5, 7) #define IOX_SHCP IMX_GPIO_NR(5, 11) -#define IOX_OE IMX_GPIO_NR(5, 18) +#define IOX_OE IMX_GPIO_NR(5, 8)
static iomux_v3_cfg_t const iox_pads[] = { /* IOX_SDI */ @@ -154,8 +154,6 @@ static void iox74lv_init(void) * shift register will be output to pins */ gpio_direction_output(IOX_STCP, 1); - - gpio_direction_output(IOX_OE, 1); };
#ifdef CONFIG_SYS_I2C_MXC
Reviewed-by: Fabio Estevam fabio.estevam@nxp.com
Q901 is PMOS, LCD_nPWREN should be at low voltage then output is 3V3. If LCD_nPWREN is high, output is 2.4V which is not correct.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com --- board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c index b861122..112e6ab 100644 --- a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c +++ b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c @@ -117,7 +117,7 @@ static enum qn_level seq[3][2] = {
static enum qn_func qn_output[8] = { qn_reset, qn_reset, qn_reset, qn_enable, qn_disable, qn_reset, - qn_disable, qn_enable + qn_disable, qn_disable };
The current pad DSE for QSPI is 60ohm. This setting cause too strong drive to clock and data signals. Need to change the DSE to 120ohm for better signal quality.
diff --git a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c index 112e6ab..92c9211 100644 --- a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c +++ b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c @@ -303,7 +303,7 @@ static void setup_iomux_uart(void)
#define QSPI_PAD_CTRL1 \ (PAD_CTL_SRE_FAST | PAD_CTL_SPEED_MED | \ - PAD_CTL_PKE | PAD_CTL_PUE | PAD_CTL_PUS_47K_UP | PAD_CTL_DSE_60ohm) + PAD_CTL_PKE | PAD_CTL_PUE | PAD_CTL_PUS_47K_UP | PAD_CTL_DSE_120ohm)
static iomux_v3_cfg_t const quadspi_pads[] = { MX6_PAD_NAND_WP_B__QSPI_A_SCLK | MUX_PAD_CTRL(QSPI_PAD_CTRL1),
- qn_enable
- qn_disable
Applied to master (bug fix), thanks !
Best regards, Stefano Babic
Fabio Estevam
Peng Fan
Stefano Babic
