[U-Boot] [PATCH v2 0/5] Fixes and improvements in BCB and Android docs
Resubmit the diff between [1] and [2] of the BCB/Android series, since the former has been pushed to master instead of the latter.
[1] https://patchwork.ozlabs.org/cover/1104242/ ("[v3,0/3] Add 'bcb' command to read/modify/write Android BCB") [2] https://patchwork.ozlabs.org/cover/1128661/ ("[v4,0/4] Add 'bcb' command to read/modify/write Android BCB")
v2: - Ensured git bisectability for the series - [Igor Opaniuk] Enriched patch description - No series-wide changes in the contents
v1: - https://patchwork.ozlabs.org/cover/1131295/
Eugeniu Rosca (5): doc: Move README.android-fastboot-protocol to doc/android/ treewide: Fix stale references of Android docs cmd: bcb: Fix duplicated handling in two case-branches cmd: bcb: Use strcmp() instead of strncmp() for string literals cmd: bcb: Apply non-functional refinements
cmd/Kconfig | 2 +- cmd/bcb.c | 68 +++++++++---------- .../fastboot-protocol.txt} | 0 doc/android/fastboot.txt | 2 +- test/py/tests/test_avb.py | 2 +- 5 files changed, 36 insertions(+), 38 deletions(-) rename doc/{README.android-fastboot-protocol => android/fastboot-protocol.txt} (100%)
Commit 9bdf0e8fef86 ("doc: relocate/rename Android README and add BCB overview") missed relocating README.android-fastboot-protocol. Fix it.
Fixes: 9bdf0e8fef86 ("doc: relocate/rename Android README and add BCB overview") Signed-off-by: Eugeniu Rosca erosca@de.adit-jv.com Reviewed-by: Igor Opaniuk igor.opaniuk@gmail.com --- v2: - Added 'Reviewed-by: Igor Opaniuk' from v1
v1: - https://patchwork.ozlabs.org/patch/1131298/ --- .../fastboot-protocol.txt} | 0 1 file changed, 0 insertions(+), 0 deletions(-) rename doc/{README.android-fastboot-protocol => android/fastboot-protocol.txt} (100%)
diff --git a/doc/README.android-fastboot-protocol b/doc/android/fastboot-protocol.txt similarity index 100% rename from doc/README.android-fastboot-protocol rename to doc/android/fastboot-protocol.txt
Reviewed-by: Sam Protsenko semen.protsenko@linaro.org
v2:
v1:
diff --git a/doc/README.android-fastboot-protocol b/doc/android/fastboot-protocol.txt similarity index 100% rename from doc/README.android-fastboot-protocol rename to doc/android/fastboot-protocol.txt -- 2.22.0
Commit 9bdf0e8fef86 ("doc: relocate/rename Android README and add BCB overview") left some obsolete references of Android documents/paths.
This has been pointed out by Sam (thanks!) in: https://patchwork.ozlabs.org/patch/1104245/#2208134
Fixes: 9bdf0e8fef86 ("doc: relocate/rename Android README and add BCB overview") Reported-by: Sam Protsenko semen.protsenko@linaro.org Suggested-by: Sam Protsenko semen.protsenko@linaro.org Signed-off-by: Eugeniu Rosca erosca@de.adit-jv.com Reviewed-by: Igor Opaniuk igor.opaniuk@gmail.com --- v2: - Added 'Reviewed-by: Igor Opaniuk' from v1
v1: - https://patchwork.ozlabs.org/patch/1131305/ --- cmd/Kconfig | 2 +- doc/android/fastboot.txt | 2 +- test/py/tests/test_avb.py | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 3afb760a816f..3cf8233df62e 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -707,7 +707,7 @@ config CMD_FASTBOOT Android devices. Fastboot requires either the network stack enabled or support for acting as a USB device.
- See doc/README.android-fastboot for more information. + See doc/android/fastboot.txt for more information.
config CMD_FDC bool "fdcboot - Boot from floppy device" diff --git a/doc/android/fastboot.txt b/doc/android/fastboot.txt index 431191c473f2..dcf824713f94 100644 --- a/doc/android/fastboot.txt +++ b/doc/android/fastboot.txt @@ -6,7 +6,7 @@ Overview ========
The protocol that is used over USB and UDP is described in the -``README.android-fastboot-protocol`` file in the same directory. +``fastboot-protocol.txt`` file in the same directory.
The current implementation supports the following standard commands:
diff --git a/test/py/tests/test_avb.py b/test/py/tests/test_avb.py index 2bb75ed6e2a2..813242343555 100644 --- a/test/py/tests/test_avb.py +++ b/test/py/tests/test_avb.py @@ -8,7 +8,7 @@ This tests Android Verified Boot 2.0 support in U-boot:
For additional details about how to build proper vbmeta partition -check doc/README.avb2 +check doc/android/avb2.txt
For configuration verification: - Corrupt boot partition and check for failure
v2:
v1:
-- 2.22.0
Fix warning V1037 reported by PVS-Studio Static Analyzer: Two or more case-branches perform the same actions. Check lines: 49, 53
Fixes: db7b7a05b267 ("cmd: Add 'bcb' command to read/modify/write BCB fields") Signed-off-by: Eugeniu Rosca erosca@de.adit-jv.com Reviewed-by: Igor Opaniuk igor.opaniuk@gmail.com --- v2: - Added 'Reviewed-by: Igor Opaniuk' from v1
v1: - https://patchwork.ozlabs.org/patch/1131301/ --- cmd/bcb.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/cmd/bcb.c b/cmd/bcb.c index 2bd5a744deb5..3b1c7434e287 100644 --- a/cmd/bcb.c +++ b/cmd/bcb.c @@ -46,9 +46,6 @@ static int bcb_is_misused(int argc, char *const argv[])
switch (cmd) { case BCB_CMD_LOAD: - if (argc != 3) - goto err; - break; case BCB_CMD_FIELD_SET: if (argc != 3) goto err;
v2:
v1:
if (argc != 3)
goto err;
-- 2.22.0
On Fri, Jul 12, 2019 at 4:37 PM Sam Protsenko semen.protsenko@linaro.org wrote:
v2:
v1:
if (argc != 3)
goto err;
break;
Wait, one note here... Can you please add /* Fall through */ comment here? I remember that new GCC was complaining on cases without break that don't have such comment or corresponding fall-through attribute. I can see that U-Boot build doesn't emit any warnings for that case, but I think such comment would be useful anyway.
-- 2.22.0
if (argc != 3)
goto err;
break;
Both U-Boot and Linux enable [-Wimplicit-fallthrough=] on "make W=1". Regardless of U-Boot and Linux, gcc doesn't seem to report any warning when two case statements are stacked on top of each other without any logic in between. The warning is only triggered if there is minimal processing done in between (e.g. a dummy printf call).
If we still want the /* fallthrough */ comment, I will add it in the next patch revision.
if (argc != 3)
goto err;
break;
Understood. Ok, let's not worry about this then. My R-b tag stands.
-- Best Regards, Eugeniu.
Quote from https://patchwork.ozlabs.org/patch/1104244/#2210814:
----------8<----------- strncmp() is chosen for the sake of paranoid/defensive programming. Indeed, strncmp() is not really needed when comparing a variable with a string literal. We expect strcmp() to behave safely even if the string variable is not NUL-terminated.
In the same scenario, Linux v5.2-rc7 uses both strcmp() and strncmp(), but the frequency of strcmp() is higher:
$ git --version git version 2.22.0 $ (Linux 5.2-rc7) git grep -En 'strncmp([^"]*"[[:alnum:]]+"' | wc -l 1066 $ (Linux 5.2-rc7) git grep -En 'strcmp([^"]*"[[:alnum:]]+"' | wc -l 1968
A quick "strcmp vs strncmp" object size test shows that strcmp() generates smaller memory footprint (gcc-8, x86_64):
$ (U-Boot) size cmd/bcb-strncmp.o cmd/bcb-strcmp.o text data bss dec hex filename 3373 400 2048 5821 16bd cmd/bcb-strncmp.o 3314 400 2048 5762 1682 cmd/bcb-strcmp.o
So, overall, I agree to use strcmp() whenever variables are compared with string literals. ----------8<-----------
Fixes: db7b7a05b267 ("cmd: Add 'bcb' command to read/modify/write BCB fields") Reported-by: Simon Glass sjg@chromium.org Signed-off-by: Eugeniu Rosca erosca@de.adit-jv.com --- v2: - Fixed accidental rename of field/size variables in bcb_field_get()
v1: - https://patchwork.ozlabs.org/patch/1131306/ --- cmd/bcb.c | 22 +++++++++++----------- 1 file changed, 11 insertions(+), 11 deletions(-)
diff --git a/cmd/bcb.c b/cmd/bcb.c index 3b1c7434e287..fa9fdeeb0dfc 100644 --- a/cmd/bcb.c +++ b/cmd/bcb.c @@ -24,17 +24,17 @@ static struct bootloader_message bcb = { { 0 } };
static int bcb_cmd_get(char *cmd) { - if (!strncmp(cmd, "load", sizeof("load"))) + if (!strcmp(cmd, "load")) return BCB_CMD_LOAD; - if (!strncmp(cmd, "set", sizeof("set"))) + if (!strcmp(cmd, "set")) return BCB_CMD_FIELD_SET; - if (!strncmp(cmd, "clear", sizeof("clear"))) + if (!strcmp(cmd, "clear")) return BCB_CMD_FIELD_CLEAR; - if (!strncmp(cmd, "test", sizeof("test"))) + if (!strcmp(cmd, "test")) return BCB_CMD_FIELD_TEST; - if (!strncmp(cmd, "store", sizeof("store"))) + if (!strcmp(cmd, "store")) return BCB_CMD_STORE; - if (!strncmp(cmd, "dump", sizeof("dump"))) + if (!strcmp(cmd, "dump")) return BCB_CMD_FIELD_DUMP; else return -1; @@ -85,19 +85,19 @@ err:
static int bcb_field_get(char *name, char **field, int *size) { - if (!strncmp(name, "command", sizeof("command"))) { + if (!strcmp(name, "command")) { *field = bcb.command; *size = sizeof(bcb.command); - } else if (!strncmp(name, "status", sizeof("status"))) { + } else if (!strcmp(name, "status")) { *field = bcb.status; *size = sizeof(bcb.status); - } else if (!strncmp(name, "recovery", sizeof("recovery"))) { + } else if (!strcmp(name, "recovery")) { *field = bcb.recovery; *size = sizeof(bcb.recovery); - } else if (!strncmp(name, "stage", sizeof("stage"))) { + } else if (!strcmp(name, "stage")) { *field = bcb.stage; *size = sizeof(bcb.stage); - } else if (!strncmp(name, "reserved", sizeof("reserved"))) { + } else if (!strcmp(name, "reserved")) { *field = bcb.reserved; *size = sizeof(bcb.reserved); } else {
v2:
v1:
-- 2.22.0
These have been reported by Simon in [1] and fixed in [2]. However, since [1] has already been pushed to u-boot/master, the improvements incorporated in [2] are now extracted and resubmitted.
The changes are in the area of coding style and best practices: * s/field/fieldp/, s/size/sizep/, to convey that the variables return an output to the caller * s/err_1/err_read_fail/, s/err_2/err_too_small/, to be more descriptive * Made sure 'static int do_bcb_load' appears on the same line * Placed a `/*` on top of multi-line comment
[1] https://patchwork.ozlabs.org/patch/1104244/#2200259 [2] https://patchwork.ozlabs.org/cover/1128661/ ("[v4,0/4] Add 'bcb' command to read/modify/write Android BCB")
Fixes: db7b7a05b267 ("cmd: Add 'bcb' command to read/modify/write BCB fields") Reported-by: Simon Glass sjg@chromium.org Signed-off-by: Eugeniu Rosca erosca@de.adit-jv.com --- v2: - [Igor Opaniuk] Enriched the patch description - Fixed inconsistent {field,size} variable rename
v1: - https://patchwork.ozlabs.org/patch/1131321/ --- cmd/bcb.c | 43 ++++++++++++++++++++++--------------------- 1 file changed, 22 insertions(+), 21 deletions(-)
diff --git a/cmd/bcb.c b/cmd/bcb.c index fa9fdeeb0dfc..9626f2c69e34 100644 --- a/cmd/bcb.c +++ b/cmd/bcb.c @@ -83,23 +83,23 @@ err: return -1; }
-static int bcb_field_get(char *name, char **field, int *size) +static int bcb_field_get(char *name, char **fieldp, int *sizep) { if (!strcmp(name, "command")) { - *field = bcb.command; - *size = sizeof(bcb.command); + *fieldp = bcb.command; + *sizep = sizeof(bcb.command); } else if (!strcmp(name, "status")) { - *field = bcb.status; - *size = sizeof(bcb.status); + *fieldp = bcb.status; + *sizep = sizeof(bcb.status); } else if (!strcmp(name, "recovery")) { - *field = bcb.recovery; - *size = sizeof(bcb.recovery); + *fieldp = bcb.recovery; + *sizep = sizeof(bcb.recovery); } else if (!strcmp(name, "stage")) { - *field = bcb.stage; - *size = sizeof(bcb.stage); + *fieldp = bcb.stage; + *sizep = sizeof(bcb.stage); } else if (!strcmp(name, "reserved")) { - *field = bcb.reserved; - *size = sizeof(bcb.reserved); + *fieldp = bcb.reserved; + *sizep = sizeof(bcb.reserved); } else { printf("Error: Unknown bcb field '%s'\n", name); return -1; @@ -108,8 +108,8 @@ static int bcb_field_get(char *name, char **field, int *size) return 0; }
-static int -do_bcb_load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +static int do_bcb_load(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) { struct blk_desc *desc; disk_partition_t info; @@ -119,28 +119,28 @@ do_bcb_load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
ret = blk_get_device_by_str("mmc", argv[1], &desc); if (ret < 0) - goto err_1; + goto err_read_fail;
part = simple_strtoul(argv[2], &endp, 0); if (*endp == '\0') { ret = part_get_info(desc, part, &info); if (ret) - goto err_1; + goto err_read_fail; } else { part = part_get_info_by_name(desc, argv[2], &info); if (part < 0) { ret = part; - goto err_1; + goto err_read_fail; } }
cnt = DIV_ROUND_UP(sizeof(struct bootloader_message), info.blksz); if (cnt > info.size) - goto err_2; + goto err_too_small;
if (blk_dread(desc, info.start, cnt, &bcb) != cnt) { ret = -EIO; - goto err_1; + goto err_read_fail; }
bcb_dev = desc->devnum; @@ -148,10 +148,10 @@ do_bcb_load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) debug("%s: Loaded from mmc %d:%d\n", __func__, bcb_dev, bcb_part);
return CMD_RET_SUCCESS; -err_1: +err_read_fail: printf("Error: mmc %s:%s read failed (%d)\n", argv[1], argv[2], ret); goto err; -err_2: +err_too_small: printf("Error: mmc %s:%s too small!", argv[1], argv[2]); goto err; err: @@ -304,7 +304,8 @@ static int do_bcb(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) return CMD_RET_USAGE;
if (bcb_is_misused(argc, argv)) { - /* We try to improve the user experience by reporting the + /* + * We try to improve the user experience by reporting the * root-cause of misusage, so don't return CMD_RET_USAGE, * since the latter prints out the full-blown help text */
- s/field/fieldp/, s/size/sizep/, to convey that the variables return an output to the caller
- s/err_1/err_read_fail/, s/err_2/err_too_small/, to be more descriptive
- Made sure 'static int do_bcb_load' appears on the same line
- Placed a `/*` on top of multi-line comment
v2:
v1:
*field = bcb.stage;
goto err_1;
goto err_read_fail; part = simple_strtoul(argv[2], &endp, 0); if (*endp == '\0') { ret = part_get_info(desc, part, &info); if (ret)
goto err_1;
goto err_1;
goto err_read_fail; } } cnt = DIV_ROUND_UP(sizeof(struct bootloader_message), info.blksz); if (cnt > info.size)
goto err_2;
goto err_too_small; if (blk_dread(desc, info.start, cnt, &bcb) != cnt) { ret = -EIO;
goto err_1;
goto err_read_fail; } bcb_dev = desc->devnum;
-- 2.22.0
Eugeniu Rosca
Sam Protsenko
