[U-Boot] [GIT PULL] AVR32 update
The following changes since commit ee1702d75a30d076139d1841383a1fa7220a0e11: Wolfgang Denk (1): Merge branch 'next' of ../next
git://git.denx.de/u-boot-avr32.git master
Sorry about all the merges at the end...I missed a couple of merge windows, so I had to beat the tree back into shape from time to time.
Gunnar Rangoy (1): AVR32: Make GPIO implmentation cpu dependent
Haavard Skinnemoen (15): avr32: Update README avr32: data_bits should reflect the actual number of data bits avr32: refactor the portmux/gpio code avr32: Add gclk helper functions hammerhead: Use gclk helper functions avr32: Use board_postclk_init instead of gclk_init avr32: use board_early_init_r instead of board_init_info atstk1000: Convert to new-style makefile avr32: Add support for "GPIO" port mux Merge branch 'fixes' into cleanups Merge branch 'cleanups' into next Merge branch 'mimc200' into next Merge branch 'evk1100-prep' into next Merge branch 'mimc200' Merge branch 'evk1100-prep'
Jean-Christophe PLAGNIOL-VILLARD (1): avr32: fix cacheflush.h location introducted by d8f2aa3298610b
Mark Jackson (3): MIMC200 board now uses CONFIG_DISABLE_CONSOLE MIMC200: tidy GCLK init code Setup extra MIMC200 chip selects
Olav Morken (3): AVR32: Make cacheflush cpu-dependent AVR32: Move addrspace.h to arch-directory, and move some functions from io.h to addrspace.h AVR32: Must add NOPs after disabling interrupts for AT32UC3A0512ES
board/atmel/atngw100/atngw100.c | 18 +- board/atmel/atstk1000/Makefile | 9 +- board/atmel/atstk1000/atstk1000.c | 15 +- board/atmel/atstk1000/flash.c | 2 +- board/earthlcd/favr-32-ezkit/favr-32-ezkit.c | 13 +- board/earthlcd/favr-32-ezkit/flash.c | 2 +- board/mimc/mimc200/mimc200.c | 117 ++++------- board/miromico/hammerhead/hammerhead.c | 26 +-- cpu/at32ap/Makefile | 3 +- cpu/at32ap/at32ap700x/Makefile | 2 +- cpu/at32ap/at32ap700x/clk.c | 25 +++ cpu/at32ap/at32ap700x/gpio.c | 199 ------------------- cpu/at32ap/at32ap700x/portmux.c | 204 +++++++++++++++++++ cpu/at32ap/cache.c | 2 +- cpu/at32ap/cpu.c | 3 - cpu/at32ap/pio.c | 116 ----------- cpu/at32ap/portmux-gpio.c | 107 ++++++++++ cpu/at32ap/portmux-pio.c | 92 +++++++++ doc/README.AVR32 | 24 +-- doc/README.AVR32-port-muxing | 208 ++++++++++++++++++++ include/asm-avr32/addrspace.h | 46 ----- include/asm-avr32/arch-at32ap700x/addrspace.h | 84 ++++++++ .../asm-avr32/{ => arch-at32ap700x}/cacheflush.h | 0 include/asm-avr32/arch-at32ap700x/clk.h | 101 +++++++++- include/asm-avr32/arch-at32ap700x/gpio-impl.h | 86 ++++++++ include/asm-avr32/arch-at32ap700x/gpio.h | 184 +----------------- include/asm-avr32/arch-at32ap700x/portmux.h | 89 +++++++++ include/asm-avr32/arch-common/portmux-gpio.h | 114 +++++++++++ include/asm-avr32/arch-common/portmux-pio.h | 138 +++++++++++++ include/asm-avr32/dma-mapping.h | 2 +- include/asm-avr32/initcalls.h | 1 - include/asm-avr32/io.h | 39 +---- include/asm-avr32/sdram.h | 4 +- include/configs/atngw100.h | 2 +- include/configs/atstk1002.h | 2 +- include/configs/atstk1003.h | 2 +- include/configs/atstk1004.h | 2 +- include/configs/atstk1006.h | 2 +- include/configs/favr-32-ezkit.h | 2 +- include/configs/hammerhead.h | 2 +- include/configs/mimc200.h | 8 +- lib_avr32/board.c | 14 ++- lib_avr32/bootm.c | 2 +- lib_avr32/interrupts.c | 7 + 44 files changed, 1388 insertions(+), 732 deletions(-) delete mode 100644 cpu/at32ap/at32ap700x/gpio.c create mode 100644 cpu/at32ap/at32ap700x/portmux.c delete mode 100644 cpu/at32ap/pio.c create mode 100644 cpu/at32ap/portmux-gpio.c create mode 100644 cpu/at32ap/portmux-pio.c create mode 100644 doc/README.AVR32-port-muxing delete mode 100644 include/asm-avr32/addrspace.h create mode 100644 include/asm-avr32/arch-at32ap700x/addrspace.h rename include/asm-avr32/{ => arch-at32ap700x}/cacheflush.h (100%) create mode 100644 include/asm-avr32/arch-at32ap700x/gpio-impl.h create mode 100644 include/asm-avr32/arch-at32ap700x/portmux.h create mode 100644 include/asm-avr32/arch-common/portmux-gpio.h create mode 100644 include/asm-avr32/arch-common/portmux-pio.h
Dear Haavard Skinnemoen,
Appliued, thanks.
Haavard Skinnemoen
