[PATCH 1/1] cmd: move CONFIG_SYS_MEMTEST_START/END to cmd/Kconfig
These symbols are not specific to Keymile boards.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- board/keymile/km83xx/Kconfig | 6 ------ cmd/Kconfig | 8 ++++++++ 2 files changed, 8 insertions(+), 6 deletions(-)
diff --git a/board/keymile/km83xx/Kconfig b/board/keymile/km83xx/Kconfig index f87a2e6416..014dde37cf 100644 --- a/board/keymile/km83xx/Kconfig +++ b/board/keymile/km83xx/Kconfig @@ -14,12 +14,6 @@ config KM_ENABLE_FULL_DM_DTS_SUPPORT select PHYLIB endmenu
-config SYS_MEMTEST_START - default 0x00100000 - -config SYS_MEMTEST_END - default 0x00f00000 - if TARGET_KMETER1
config SYS_BOARD diff --git a/cmd/Kconfig b/cmd/Kconfig index 4fe2c75de2..bffb19924d 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -837,6 +837,14 @@ config CMD_MEMTEST
if CMD_MEMTEST
+config SYS_MEMTEST_START + default 0x00100000 if SYS_BOARD="km83xx" + default TEXT_BASE + +config SYS_MEMTEST_END + default 0x00f00000 if SYS_BOARD="km83xx" + default TEXT_BASE + config SYS_ALT_MEMTEST bool "Alternative test" help
Hello Heinrich,
if TARGET_KMETER1
if CMD_MEMTEST
- default 0x00100000 if SYS_BOARD="km83xx"
- default TEXT_BASE
- default 0x00f00000 if SYS_BOARD="km83xx"
- default TEXT_BASE
Hmm... for me with current HEAD: * b6904cc98a - (HEAD -> master, origin/master, origin/HEAD) Merge https://source.denx.de/u-boot/custodians/u-boot-spi
This symbols are already in cmd/Kconfig file:
857 config SYS_MEMTEST_START 858 hex "default start address for mtest" 859 default 0x0 860 help 861 This is the default start address for mtest for simple read/write 862 test. If no arguments are given to mtest, default address is used 863 as start address. 864 865 config SYS_MEMTEST_END 866 hex "default end address for mtest" 867 default 0x1000 868 help 869 This is the default end address for mtest for simple read/write 870 test. If no arguments are given to mtest, default address is used 871 as end address.
Please review, if with your patch they are not twice in cmd(Kconfig file, thanks!
bye, Heiko
Heiko Schocher
