[U-Boot] [PATCH 0/5] MSCC: Add Serval SoC family.
This patch series adds support for MSCC Serval SoC family. In this family there are the following boards: pcb105 and pcb106.
This is based off the patch series[1].
[1] https://lists.denx.de/pipermail/u-boot/2019-January/355031.html
Horatiu Vultur (5): pinctrl: mscc: Add gpio and pinctrl for Serval SoC family. MSCC: Add support for Serval SoC family. MSCC: add device tree for Serval pcb105 board MSCC: Add device tree for Serval pcb106 board MSCC: Add board support for Serval SoC family.
arch/mips/dts/Makefile | 1 + arch/mips/dts/mscc,serval.dtsi | 149 ++++++++++ arch/mips/dts/serval_pcb105.dts | 56 ++++ arch/mips/dts/serval_pcb106.dts | 56 ++++ arch/mips/mach-mscc/Kconfig | 9 + arch/mips/mach-mscc/Makefile | 1 + arch/mips/mach-mscc/cpu.c | 2 +- arch/mips/mach-mscc/dram.c | 2 +- arch/mips/mach-mscc/include/mach/common.h | 5 + arch/mips/mach-mscc/include/mach/ddr.h | 20 +- arch/mips/mach-mscc/include/mach/serval/serval.h | 24 ++ .../include/mach/serval/serval_devcpu_gcb.h | 21 ++ .../mach/serval/serval_devcpu_gcb_miim_regs.h | 25 ++ .../include/mach/serval/serval_icpu_cfg.h | 314 +++++++++++++++++++++ arch/mips/mach-mscc/reset.c | 25 +- board/mscc/serval/Kconfig | 14 + board/mscc/serval/Makefile | 3 + board/mscc/serval/serval.c | 74 +++++ configs/mscc_serval_defconfig | 62 ++++ drivers/pinctrl/mscc/Kconfig | 10 + drivers/pinctrl/mscc/Makefile | 1 + drivers/pinctrl/mscc/pinctrl-serval.c | 233 +++++++++++++++ include/configs/vcoreiii.h | 5 +- 23 files changed, 1098 insertions(+), 14 deletions(-) create mode 100644 arch/mips/dts/mscc,serval.dtsi create mode 100644 arch/mips/dts/serval_pcb105.dts create mode 100644 arch/mips/dts/serval_pcb106.dts create mode 100644 arch/mips/mach-mscc/include/mach/serval/serval.h create mode 100644 arch/mips/mach-mscc/include/mach/serval/serval_devcpu_gcb.h create mode 100644 arch/mips/mach-mscc/include/mach/serval/serval_devcpu_gcb_miim_regs.h create mode 100644 arch/mips/mach-mscc/include/mach/serval/serval_icpu_cfg.h create mode 100644 board/mscc/serval/Kconfig create mode 100644 board/mscc/serval/Makefile create mode 100644 board/mscc/serval/serval.c create mode 100644 configs/mscc_serval_defconfig create mode 100644 drivers/pinctrl/mscc/pinctrl-serval.c
The Serval SoC family has 32 pins. Currently there is no support for Serval in Linux kernel.
Signed-off-by: Horatiu Vultur horatiu.vultur@microchip.com --- drivers/pinctrl/mscc/Kconfig | 10 ++ drivers/pinctrl/mscc/Makefile | 1 + drivers/pinctrl/mscc/pinctrl-serval.c | 233 ++++++++++++++++++++++++++++++++++ 3 files changed, 244 insertions(+) create mode 100644 drivers/pinctrl/mscc/pinctrl-serval.c
diff --git a/drivers/pinctrl/mscc/Kconfig b/drivers/pinctrl/mscc/Kconfig index 0269565..aab67fa 100644 --- a/drivers/pinctrl/mscc/Kconfig +++ b/drivers/pinctrl/mscc/Kconfig @@ -38,3 +38,13 @@ config PINCTRL_MSCC_SERVALT help Support pin multiplexing and pin configuration control on Microsemi servalt SoCs. + +config PINCTRL_MSCC_SERVAL + depends on SOC_SERVAL && PINCTRL_FULL && OF_CONTROL + select PINCTRL_MSCC + default y + bool "Microsemi serval family pin control driver" + help + Support pin multiplexing and pin configuration control on + Microsemi serval SoCs. + diff --git a/drivers/pinctrl/mscc/Makefile b/drivers/pinctrl/mscc/Makefile index c6b0373..fd7eba2 100644 --- a/drivers/pinctrl/mscc/Makefile +++ b/drivers/pinctrl/mscc/Makefile @@ -5,3 +5,4 @@ obj-$(CONFIG_PINCTRL_MSCC_OCELOT) += pinctrl-ocelot.o obj-$(CONFIG_PINCTRL_MSCC_LUTON) += pinctrl-luton.o obj-$(CONFIG_PINCTRL_MSCC_JR2) += pinctrl-jr2.o obj-$(CONFIG_PINCTRL_MSCC_SERVALT) += pinctrl-servalt.o +obj-$(CONFIG_PINCTRL_MSCC_SERVAL) += pinctrl-serval.o diff --git a/drivers/pinctrl/mscc/pinctrl-serval.c b/drivers/pinctrl/mscc/pinctrl-serval.c new file mode 100644 index 0000000..d59f08d --- /dev/null +++ b/drivers/pinctrl/mscc/pinctrl-serval.c @@ -0,0 +1,233 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * Microsemi SoCs pinctrl driver + * + * Author: horatiu.vultur@microchip.com + * Copyright (c) 2019 Microsemi Corporation + */ + +#include <common.h> +#include <config.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/lists.h> +#include <dm/pinctrl.h> +#include <dm/root.h> +#include <errno.h> +#include <fdtdec.h> +#include <linux/io.h> +#include <asm/gpio.h> +#include <asm/system.h> +#include "mscc-common.h" + +enum { + FUNC_NONE, + FUNC_GPIO, + FUNC_IRQ0, + FUNC_IRQ1, + FUNC_MIIM1, + FUNC_PCI_WAKE, + FUNC_PTP0, + FUNC_PTP1, + FUNC_PTP2, + FUNC_PTP3, + FUNC_PWM, + FUNC_RECO_CLK0, + FUNC_RECO_CLK1, + FUNC_SFP0, + FUNC_SFP1, + FUNC_SFP2, + FUNC_SFP3, + FUNC_SFP4, + FUNC_SFP5, + FUNC_SFP6, + FUNC_SFP7, + FUNC_SFP8, + FUNC_SFP9, + FUNC_SFP10, + FUNC_SIO, + FUNC_SI, + FUNC_TACHO, + FUNC_TWI, + FUNC_TWI_SCL_M, + FUNC_UART, + FUNC_UART2, + FUNC_MD, + FUNC_PTP1588, + FUNC_MAX +}; + +static char * const serval_function_names[] = { + [FUNC_NONE] = "none", + [FUNC_GPIO] = "gpio", + [FUNC_IRQ0] = "irq0", + [FUNC_IRQ1] = "irq1", + [FUNC_MIIM1] = "miim1", + [FUNC_PCI_WAKE] = "pci_wake", + [FUNC_PTP0] = "ptp0", + [FUNC_PTP1] = "ptp1", + [FUNC_PTP2] = "ptp2", + [FUNC_PTP3] = "ptp3", + [FUNC_PWM] = "pwm", + [FUNC_RECO_CLK0] = "reco_clk0", + [FUNC_RECO_CLK1] = "reco_clk1", + [FUNC_SFP0] = "sfp0", + [FUNC_SFP1] = "sfp1", + [FUNC_SFP2] = "sfp2", + [FUNC_SFP3] = "sfp3", + [FUNC_SFP4] = "sfp4", + [FUNC_SFP5] = "sfp5", + [FUNC_SFP6] = "sfp6", + [FUNC_SFP7] = "sfp7", + [FUNC_SFP8] = "sfp8", + [FUNC_SFP9] = "sfp9", + [FUNC_SFP10] = "sfp10", + [FUNC_SIO] = "sio", + [FUNC_SI] = "si", + [FUNC_TACHO] = "tacho", + [FUNC_TWI] = "twi", + [FUNC_TWI_SCL_M] = "twi_scl_m", + [FUNC_UART] = "uart", + [FUNC_UART2] = "uart2", + [FUNC_MD] = "md", + [FUNC_PTP1588] = "1588", +}; + +MSCC_P(0, SIO, NONE, NONE); +MSCC_P(1, SIO, NONE, NONE); +MSCC_P(2, SIO, NONE, NONE); +MSCC_P(3, SIO, NONE, NONE); +MSCC_P(4, TACHO, NONE, NONE); +MSCC_P(5, PWM, NONE, NONE); +MSCC_P(6, TWI, NONE, NONE); +MSCC_P(7, TWI, NONE, NONE); +MSCC_P(8, SI, NONE, NONE); +MSCC_P(9, SI, MD, NONE); +MSCC_P(10, SI, MD, NONE); +MSCC_P(11, SFP0, MD, TWI_SCL_M); +MSCC_P(12, SFP1, MD, TWI_SCL_M); +MSCC_P(13, SFP2, UART2, TWI_SCL_M); +MSCC_P(14, SFP3, UART2, TWI_SCL_M); +MSCC_P(15, SFP4, PTP1588, TWI_SCL_M); +MSCC_P(16, SFP5, PTP1588, TWI_SCL_M); +MSCC_P(17, SFP6, PCI_WAKE, TWI_SCL_M); +MSCC_P(18, SFP7, NONE, TWI_SCL_M); +MSCC_P(19, SFP8, NONE, TWI_SCL_M); +MSCC_P(20, SFP9, NONE, TWI_SCL_M); +MSCC_P(21, SFP10, NONE, TWI_SCL_M); +MSCC_P(22, NONE, NONE, NONE); +MSCC_P(23, NONE, NONE, NONE); +MSCC_P(24, NONE, NONE, NONE); +MSCC_P(25, NONE, NONE, NONE); +MSCC_P(26, UART, NONE, NONE); +MSCC_P(27, UART, NONE, NONE); +MSCC_P(28, IRQ0, NONE, NONE); +MSCC_P(29, IRQ1, NONE, NONE); +MSCC_P(30, PTP1588, NONE, NONE); +MSCC_P(31, PTP1588, NONE, NONE); + +#define SERVAL_PIN(n) { \ + .name = "GPIO_"#n, \ + .drv_data = &mscc_pin_##n \ +} + +static const struct mscc_pin_data serval_pins[] = { + SERVAL_PIN(0), + SERVAL_PIN(1), + SERVAL_PIN(2), + SERVAL_PIN(3), + SERVAL_PIN(4), + SERVAL_PIN(5), + SERVAL_PIN(6), + SERVAL_PIN(7), + SERVAL_PIN(8), + SERVAL_PIN(9), + SERVAL_PIN(10), + SERVAL_PIN(11), + SERVAL_PIN(12), + SERVAL_PIN(13), + SERVAL_PIN(14), + SERVAL_PIN(15), + SERVAL_PIN(16), + SERVAL_PIN(17), + SERVAL_PIN(18), + SERVAL_PIN(19), + SERVAL_PIN(20), + SERVAL_PIN(21), + SERVAL_PIN(22), + SERVAL_PIN(23), + SERVAL_PIN(24), + SERVAL_PIN(25), + SERVAL_PIN(26), + SERVAL_PIN(27), + SERVAL_PIN(28), + SERVAL_PIN(29), + SERVAL_PIN(30), + SERVAL_PIN(31), +}; + +static const unsigned long serval_gpios[] = { + [MSCC_GPIO_OUT_SET] = 0x00, + [MSCC_GPIO_OUT_CLR] = 0x04, + [MSCC_GPIO_OUT] = 0x08, + [MSCC_GPIO_IN] = 0x0c, + [MSCC_GPIO_OE] = 0x10, + [MSCC_GPIO_INTR] = 0x14, + [MSCC_GPIO_INTR_ENA] = 0x18, + [MSCC_GPIO_INTR_IDENT] = 0x1c, + [MSCC_GPIO_ALT0] = 0x20, + [MSCC_GPIO_ALT1] = 0x24, +}; + +static int serval_gpio_probe(struct udevice *dev) +{ + struct gpio_dev_priv *uc_priv; + + uc_priv = dev_get_uclass_priv(dev); + uc_priv->bank_name = "serval-gpio"; + uc_priv->gpio_count = ARRAY_SIZE(serval_pins); + + return 0; +} + +static struct driver serval_gpio_driver = { + .name = "serval-gpio", + .id = UCLASS_GPIO, + .probe = serval_gpio_probe, + .ops = &mscc_gpio_ops, +}; + +static int serval_pinctrl_probe(struct udevice *dev) +{ + int ret; + + ret = mscc_pinctrl_probe(dev, FUNC_MAX, serval_pins, + ARRAY_SIZE(serval_pins), + serval_function_names, + serval_gpios); + + if (ret) + return ret; + + ret = device_bind(dev, &serval_gpio_driver, "serval-gpio", NULL, + dev_of_offset(dev), NULL); + + if (ret) + return ret; + + return 0; +} + +static const struct udevice_id serval_pinctrl_of_match[] = { + { .compatible = "mscc,serval-pinctrl" }, + {}, +}; + +U_BOOT_DRIVER(serval_pinctrl) = { + .name = "serval-pinctrl", + .id = UCLASS_PINCTRL, + .of_match = of_match_ptr(serval_pinctrl_of_match), + .probe = serval_pinctrl_probe, + .priv_auto_alloc_size = sizeof(struct mscc_pinctrl), + .ops = &mscc_pinctrl_ops, +};
Am 23.01.19 um 16:39 schrieb Horatiu Vultur:
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
As Ocelot, Servalt, Luton and Jaguar2, this family of SoCs are found in Microsemi Switches solution.
Signed-off-by: Horatiu Vultur horatiu.vultur@microchip.com --- arch/mips/mach-mscc/Kconfig | 9 + arch/mips/mach-mscc/cpu.c | 2 +- arch/mips/mach-mscc/dram.c | 2 +- arch/mips/mach-mscc/include/mach/common.h | 5 + arch/mips/mach-mscc/include/mach/ddr.h | 20 +- arch/mips/mach-mscc/include/mach/serval/serval.h | 24 ++ .../include/mach/serval/serval_devcpu_gcb.h | 21 ++ .../mach/serval/serval_devcpu_gcb_miim_regs.h | 25 ++ .../include/mach/serval/serval_icpu_cfg.h | 314 +++++++++++++++++++++ arch/mips/mach-mscc/reset.c | 25 +- include/configs/vcoreiii.h | 5 +- 11 files changed, 438 insertions(+), 14 deletions(-) create mode 100644 arch/mips/mach-mscc/include/mach/serval/serval.h create mode 100644 arch/mips/mach-mscc/include/mach/serval/serval_devcpu_gcb.h create mode 100644 arch/mips/mach-mscc/include/mach/serval/serval_devcpu_gcb_miim_regs.h create mode 100644 arch/mips/mach-mscc/include/mach/serval/serval_icpu_cfg.h
diff --git a/arch/mips/mach-mscc/Kconfig b/arch/mips/mach-mscc/Kconfig index 80e4b44..34584a1 100644 --- a/arch/mips/mach-mscc/Kconfig +++ b/arch/mips/mach-mscc/Kconfig @@ -47,6 +47,13 @@ config SOC_SERVALT help This supports MSCC Servalt family of SOCs.
+config SOC_SERVAL + bool "Serval SOC Family" + select SOC_VCOREIII + select MSCC_BB_SPI + help + This supports MSCC Serval family of SOCs. + endchoice
config SYS_CONFIG_NAME @@ -82,4 +89,6 @@ source "board/mscc/luton/Kconfig" source "board/mscc/jr2/Kconfig"
source "board/mscc/servalt/Kconfig" + +source "board/mscc/serval/Kconfig" endmenu diff --git a/arch/mips/mach-mscc/cpu.c b/arch/mips/mach-mscc/cpu.c index 1bfd636..ac75d51 100644 --- a/arch/mips/mach-mscc/cpu.c +++ b/arch/mips/mach-mscc/cpu.c @@ -87,7 +87,7 @@ int mach_cpu_init(void) ICPU_SPI_MST_CFG_CS_DESELECT_TIME(0x19) + ICPU_SPI_MST_CFG_CLK_DIV(9), BASE_CFG + ICPU_SPI_MST_CFG); #else -#ifdef CONFIG_SOC_OCELOT +#if defined(CONFIG_SOC_OCELOT) || defined(CONFIG_SOC_SERVAL) writel(ICPU_SPI_MST_CFG_CS_DESELECT_TIME(0x19) + ICPU_SPI_MST_CFG_CLK_DIV(9), BASE_CFG + ICPU_SPI_MST_CFG); #endif diff --git a/arch/mips/mach-mscc/dram.c b/arch/mips/mach-mscc/dram.c index 2073821..c43f7a5 100644 --- a/arch/mips/mach-mscc/dram.c +++ b/arch/mips/mach-mscc/dram.c @@ -20,7 +20,7 @@ static inline int vcoreiii_train_bytelane(void) ret = hal_vcoreiii_train_bytelane(0);
#if defined(CONFIG_SOC_OCELOT) || defined(CONFIG_SOC_JR2) || \ - defined(CONFIG_SOC_SERVALT) + defined(CONFIG_SOC_SERVALT) || defined(CONFIG_SOC_SERVAL) if (ret) return ret; ret = hal_vcoreiii_train_bytelane(1); diff --git a/arch/mips/mach-mscc/include/mach/common.h b/arch/mips/mach-mscc/include/mach/common.h index 97b3f82..8f9a9c2 100644 --- a/arch/mips/mach-mscc/include/mach/common.h +++ b/arch/mips/mach-mscc/include/mach/common.h @@ -26,6 +26,11 @@ #include <mach/servalt/servalt_devcpu_gcb.h> #include <mach/servalt/servalt_devcpu_gcb_miim_regs.h> #include <mach/servalt/servalt_icpu_cfg.h> +#elif defined(CONFIG_SOC_SERVAL) +#include <mach/serval/serval.h> +#include <mach/serval/serval_devcpu_gcb.h> +#include <mach/serval/serval_devcpu_gcb_miim_regs.h> +#include <mach/serval/serval_icpu_cfg.h> #else #error Unsupported platform #endif diff --git a/arch/mips/mach-mscc/include/mach/ddr.h b/arch/mips/mach-mscc/include/mach/ddr.h index ff32f22..84ecfbd 100644 --- a/arch/mips/mach-mscc/include/mach/ddr.h +++ b/arch/mips/mach-mscc/include/mach/ddr.h @@ -25,7 +25,7 @@ #define VC3_MPAR_CL 6 #define VC3_MPAR_tWTR 4 #define VC3_MPAR_tRC 16 -#define VC3_MPR_tFAW 16 +#define VC3_MPAR_tFAW 16 #define VC3_MPAR_tRP 5 #define VC3_MPAR_tRRD 4 #define VC3_MPAR_tRCD 5 @@ -162,7 +162,7 @@ #endif
#if defined(CONFIG_SOC_OCELOT) || defined(CONFIG_SOC_JR2) || \ - defined(CONFIG_SOC_SERVALT) + defined(CONFIG_SOC_SERVALT) || defined(CONFIG_SOC_SERVAL) #define MIPS_VCOREIII_MEMORY_16BIT 1 #endif
@@ -241,7 +241,7 @@ ICPU_MEMCTRL_CFG_MSB_COL_ADDR(VC3_MPAR_col_addr_cnt - 1)
#if defined(CONFIG_SOC_OCELOT) || defined(CONFIG_SOC_JR2) || \ - defined(CONFIG_SOC_SERVALT) + defined(CONFIG_SOC_SERVALT) || defined(CONFIG_SOC_SERVAL) #define MSCC_MEMPARM_PERIOD \ ICPU_MEMCTRL_REF_PERIOD_MAX_PEND_REF(8) | \ ICPU_MEMCTRL_REF_PERIOD_REF_PERIOD(VC3_MPAR_tREFI) @@ -381,7 +381,7 @@ static inline void memphy_soft_reset(void) }
#if defined(CONFIG_SOC_OCELOT) || defined(CONFIG_SOC_JR2) || \ - defined(CONFIG_SOC_SERVALT) + defined(CONFIG_SOC_SERVALT) || defined(CONFIG_SOC_SERVAL) static u8 training_data[] = { 0xfe, 0x11, 0x33, 0x55, 0x77, 0x99, 0xbb, 0xdd };
static inline void sleep_100ns(u32 val) @@ -452,7 +452,7 @@ static inline void hal_vcoreiii_ddr_failed(void)
panic("DDR init failed\n"); } -#else /* JR2 || ServalT */ +#else /* JR2 || ServalT || Serval */ static inline void hal_vcoreiii_ddr_reset_assert(void) { /* Ensure the memory controller physical iface is forced reset */ @@ -471,7 +471,7 @@ static inline void hal_vcoreiii_ddr_failed(void)
panic("DDR init failed\n"); } -#endif +#endif /* JR2 || ServalT || Serval */
/* * DDR memory sanity checking done, possibly enable ECC. @@ -778,7 +778,7 @@ static inline void hal_vcoreiii_init_memctl(void) writel(MSCC_MEMPARM_PERIOD, BASE_CFG + ICPU_MEMCTRL_REF_PERIOD);
#if defined(CONFIG_SOC_OCELOT) || defined(CONFIG_SOC_JR2) || \ - defined(CONFIG_SOC_SERVALT) + defined(CONFIG_SOC_SERVALT) || defined(CONFIG_SOC_SERVAL) writel(MSCC_MEMPARM_TIMING0, BASE_CFG + ICPU_MEMCTRL_TIMING0); #else /* Luton */ clrbits_le32(BASE_CFG + ICPU_MEMCTRL_TIMING0, ((1 << 20) - 1)); @@ -793,7 +793,7 @@ static inline void hal_vcoreiii_init_memctl(void) writel(MSCC_MEMPARM_MR2, BASE_CFG + ICPU_MEMCTRL_MR2_VAL); writel(MSCC_MEMPARM_MR3, BASE_CFG + ICPU_MEMCTRL_MR3_VAL);
-#if defined(CONFIG_SOC_OCELOT) +#if defined(CONFIG_SOC_OCELOT) || defined(CONFIG_SOC_SERVAL) /* Termination setup - enable ODT */ writel(ICPU_MEMCTRL_TERMRES_CTRL_LOCAL_ODT_RD_ENA | /* Assert ODT0 for any write */ @@ -801,7 +801,9 @@ static inline void hal_vcoreiii_init_memctl(void) BASE_CFG + ICPU_MEMCTRL_TERMRES_CTRL);
/* Release Reset from DDR */ +#if defined(CONFIG_SOC_OCELOT) hal_vcoreiii_ddr_reset_release(); +#endif
writel(readl(BASE_CFG + ICPU_GPR(7)) + 1, BASE_CFG + ICPU_GPR(7)); #elif defined(CONFIG_SOC_JR2) || defined(CONFIG_SOC_SERVALT) @@ -826,7 +828,7 @@ static inline void hal_vcoreiii_wait_memctl(void) /* Settle...? */ sleep_100ns(10000); #if defined(CONFIG_SOC_OCELOT) || defined(CONFIG_SOC_JR2) || \ - defined(CONFIG_SOC_SERVALT) + defined(CONFIG_SOC_SERVALT) || defined(CONFIG_SOC_SERVAL) /* Establish data contents in DDR RAM for training */
__raw_writel(0xcacafefe, ((void __iomem *)MSCC_DDR_TO)); diff --git a/arch/mips/mach-mscc/include/mach/serval/serval.h b/arch/mips/mach-mscc/include/mach/serval/serval.h new file mode 100644 index 0000000..763d18f --- /dev/null +++ b/arch/mips/mach-mscc/include/mach/serval/serval.h @@ -0,0 +1,24 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* + * Microsemi Serval Switch driver + * + * Copyright (c) 2018 Microsemi Corporation + */ + +#ifndef _MSCC_SERVAL_H_ +#define _MSCC_SERVAL_H_ + +#include <linux/bitops.h> +#include <dm.h> + +/* + * Target offset base(s) + */ +#define MSCC_IO_ORIGIN1_OFFSET 0x70000000 +#define MSCC_IO_ORIGIN1_SIZE 0x00200000 +#define MSCC_IO_ORIGIN2_OFFSET 0x71000000 +#define MSCC_IO_ORIGIN2_SIZE 0x01000000 +#define BASE_CFG ((void __iomem *)0x70000000) +#define BASE_DEVCPU_GCB ((void __iomem *)0x71070000) + +#endif diff --git a/arch/mips/mach-mscc/include/mach/serval/serval_devcpu_gcb.h b/arch/mips/mach-mscc/include/mach/serval/serval_devcpu_gcb.h new file mode 100644 index 0000000..9b80fdb --- /dev/null +++ b/arch/mips/mach-mscc/include/mach/serval/serval_devcpu_gcb.h @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#ifndef _MSCC_SERVAL_DEVCPU_GCB_H_ +#define _MSCC_SERVAL_DEVCPU_GCB_H_ + +#define CHIP_ID 0x0 + +#define PERF_GPR 0x4 + +#define PERF_SOFT_RST 0x8 + +#define PERF_SOFT_RST_SOFT_NON_CFG_RST BIT(2) +#define PERF_SOFT_RST_SOFT_SWC_RST BIT(1) +#define PERF_SOFT_RST_SOFT_CHIP_RST BIT(0) + +#define GPIO_ALT(x) (0x54 + 4 * (x)) + +#endif diff --git a/arch/mips/mach-mscc/include/mach/serval/serval_devcpu_gcb_miim_regs.h b/arch/mips/mach-mscc/include/mach/serval/serval_devcpu_gcb_miim_regs.h new file mode 100644 index 0000000..a3abbc40 --- /dev/null +++ b/arch/mips/mach-mscc/include/mach/serval/serval_devcpu_gcb_miim_regs.h @@ -0,0 +1,25 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#ifndef _MSCC_SERVAL_DEVCPU_GCB_MIIM_REGS_H_ +#define _MSCC_SERVAL_DEVCPU_GCB_MIIM_REGS_H_ + +#define MIIM_MII_STATUS(gi) (0x5c + (gi * 36)) +#define MIIM_MII_CMD(gi) (0x64 + (gi * 36)) +#define MIIM_MII_DATA(gi) (0x68 + (gi * 36)) + +#define MSCC_F_MII_STATUS_MIIM_STAT_BUSY(x) ((x) ? BIT(3) : 0) + +#define MSCC_F_MII_CMD_MIIM_CMD_VLD(x) ((x) ? BIT(31) : 0) +#define MSCC_F_MII_CMD_MIIM_CMD_PHYAD(x) (GENMASK(29, 25) & ((x) << 25)) +#define MSCC_F_MII_CMD_MIIM_CMD_REGAD(x) (GENMASK(24, 20) & ((x) << 20)) +#define MSCC_F_MII_CMD_MIIM_CMD_WRDATA(x) (GENMASK(19, 4) & ((x) << 4)) +#define MSCC_F_MII_CMD_MIIM_CMD_OPR_FIELD(x) (GENMASK(2, 1) & ((x) << 1)) +#define MSCC_F_MII_CMD_MIIM_CMD_SCAN(x) ((x) ? BIT(0) : 0) + +#define MSCC_M_MII_DATA_MIIM_DATA_SUCCESS GENMASK(17, 16) +#define MSCC_X_MII_DATA_MIIM_DATA_RDDATA(x) (((x) >> 0) & GENMASK(15, 0)) + +#endif diff --git a/arch/mips/mach-mscc/include/mach/serval/serval_icpu_cfg.h b/arch/mips/mach-mscc/include/mach/serval/serval_icpu_cfg.h new file mode 100644 index 0000000..b8c9d5c --- /dev/null +++ b/arch/mips/mach-mscc/include/mach/serval/serval_icpu_cfg.h @@ -0,0 +1,314 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#ifndef _MSCC_SERVAL_ICPU_CFG_H_ +#define _MSCC_SERVAL_ICPU_CFG_H_ + +#define ICPU_GPR(x) (0x4 * (x)) +#define ICPU_GPR_RSZ 0x8 + +#define ICPU_RESET 0x20 + +#define ICPU_RESET_CORE_RST_CPU_ONLY BIT(3) +#define ICPU_RESET_CORE_RST_PROTECT BIT(2) +#define ICPU_RESET_CORE_RST_FORCE BIT(1) +#define ICPU_RESET_MEM_RST_FORCE BIT(0) + +#define ICPU_GENERAL_CTRL 0x24 + +#define ICPU_GENERAL_CTRL_CPU_BUSIF_SLEEP_DIS BIT(11) +#define ICPU_GENERAL_CTRL_CPU_BUSIF_WERR_ENA BIT(10) +#define ICPU_GENERAL_CTRL_CPU_8051_IROM_ENA BIT(9) +#define ICPU_GENERAL_CTRL_CPU_MIPS_DIS BIT(8) +#define ICPU_GENERAL_CTRL_IF_MIIM_SLV_ENA BIT(7) +#define ICPU_GENERAL_CTRL_IF_PI_SLV_DONEPOL BIT(6) +#define ICPU_GENERAL_CTRL_IF_PI_MST_ENA BIT(5) +#define ICPU_GENERAL_CTRL_IF_PI_SLV_ENA BIT(4) +#define ICPU_GENERAL_CTRL_IF_SI_MST_ENA BIT(3) +#define ICPU_GENERAL_CTRL_CPU_BE_ENA BIT(2) +#define ICPU_GENERAL_CTRL_CPU_DIS BIT(1) +#define ICPU_GENERAL_CTRL_BOOT_MODE_ENA BIT(0) + +#define ICPU_SPI_MST_CFG 0x3c + +#define ICPU_SPI_MST_CFG_FAST_READ_ENA BIT(10) +#define ICPU_SPI_MST_CFG_CS_DESELECT_TIME(x) (((x) << 5) & GENMASK(9, 5)) +#define ICPU_SPI_MST_CFG_CS_DESELECT_TIME_M GENMASK(9, 5) +#define ICPU_SPI_MST_CFG_CS_DESELECT_TIME_X(x) (((x) & GENMASK(9, 5)) >> 5) +#define ICPU_SPI_MST_CFG_CLK_DIV(x) ((x) & GENMASK(4, 0)) +#define ICPU_SPI_MST_CFG_CLK_DIV_M GENMASK(4, 0) + +#define ICPU_SW_MODE 0x50 + +#define ICPU_SW_MODE_SW_PIN_CTRL_MODE BIT(13) +#define ICPU_SW_MODE_SW_SPI_SCK BIT(12) +#define ICPU_SW_MODE_SW_SPI_SCK_OE BIT(11) +#define ICPU_SW_MODE_SW_SPI_SDO BIT(10) +#define ICPU_SW_MODE_SW_SPI_SDO_OE BIT(9) +#define ICPU_SW_MODE_SW_SPI_CS(x) (((x) << 5) & GENMASK(8, 5)) +#define ICPU_SW_MODE_SW_SPI_CS_M GENMASK(8, 5) +#define ICPU_SW_MODE_SW_SPI_CS_X(x) (((x) & GENMASK(8, 5)) >> 5) +#define ICPU_SW_MODE_SW_SPI_CS_OE(x) (((x) << 1) & GENMASK(4, 1)) +#define ICPU_SW_MODE_SW_SPI_CS_OE_M GENMASK(4, 1) +#define ICPU_SW_MODE_SW_SPI_CS_OE_X(x) (((x) & GENMASK(4, 1)) >> 1) +#define ICPU_SW_MODE_SW_SPI_SDI BIT(0) + +#define ICPU_INTR_ENA 0x84 + +#define ICPU_DST_INTR_MAP(x) (0x94 + 0x4 * (x)) +#define ICPU_DST_INTR_MAP_RSZ 0x4 + +#define ICPU_TIMER_TICK_DIV 0xe0 + +#define ICPU_TIMER_VALUE(x) (0xe4 + 0x4 * (x)) +#define ICPU_TIMER_VALUE_RSZ 0x2 + +#define ICPU_TIMER_CTRL(x) (0xfc + 0x4 * (x)) +#define ICPU_TIMER_CTRL_RSZ 0x2 + +#define ICPU_TIMER_CTRL_MAX_FREQ_ENA BIT(3) +#define ICPU_TIMER_CTRL_ONE_SHOT_ENA BIT(2) +#define ICPU_TIMER_CTRL_TIMER_ENA BIT(1) +#define ICPU_TIMER_CTRL_FORCE_RELOAD BIT(0) + +#define ICPU_MEMCTRL_CTRL 0x108 + +#define ICPU_MEMCTRL_CTRL_PWR_DOWN BIT(3) +#define ICPU_MEMCTRL_CTRL_MDSET BIT(2) +#define ICPU_MEMCTRL_CTRL_STALL_REF_ENA BIT(1) +#define ICPU_MEMCTRL_CTRL_INITIALIZE BIT(0) + +#define ICPU_MEMCTRL_CFG 0x10c + +#define ICPU_MEMCTRL_CFG_DDR_512MBYTE_PLUS BIT(16) +#define ICPU_MEMCTRL_CFG_DDR_ECC_ERR_ENA BIT(15) +#define ICPU_MEMCTRL_CFG_DDR_ECC_COR_ENA BIT(14) +#define ICPU_MEMCTRL_CFG_DDR_ECC_ENA BIT(13) +#define ICPU_MEMCTRL_CFG_DDR_WIDTH BIT(12) +#define ICPU_MEMCTRL_CFG_DDR_MODE BIT(11) +#define ICPU_MEMCTRL_CFG_BURST_SIZE BIT(10) +#define ICPU_MEMCTRL_CFG_BURST_LEN BIT(9) +#define ICPU_MEMCTRL_CFG_BANK_CNT BIT(8) +#define ICPU_MEMCTRL_CFG_MSB_ROW_ADDR(x) (((x) << 4) & GENMASK(7, 4)) +#define ICPU_MEMCTRL_CFG_MSB_ROW_ADDR_M GENMASK(7, 4) +#define ICPU_MEMCTRL_CFG_MSB_ROW_ADDR_X(x) (((x) & GENMASK(7, 4)) >> 4) +#define ICPU_MEMCTRL_CFG_MSB_COL_ADDR(x) ((x) & GENMASK(3, 0)) +#define ICPU_MEMCTRL_CFG_MSB_COL_ADDR_M GENMASK(3, 0) + +#define ICPU_MEMCTRL_STAT 0x110 + +#define ICPU_MEMCTRL_STAT_RDATA_MASKED BIT(5) +#define ICPU_MEMCTRL_STAT_RDATA_DUMMY BIT(4) +#define ICPU_MEMCTRL_STAT_RDATA_ECC_ERR BIT(3) +#define ICPU_MEMCTRL_STAT_RDATA_ECC_COR BIT(2) +#define ICPU_MEMCTRL_STAT_PWR_DOWN_ACK BIT(1) +#define ICPU_MEMCTRL_STAT_INIT_DONE BIT(0) + +#define ICPU_MEMCTRL_REF_PERIOD 0x114 + +#define ICPU_MEMCTRL_REF_PERIOD_MAX_PEND_REF(x) (((x) << 16) & GENMASK(19, 16)) +#define ICPU_MEMCTRL_REF_PERIOD_MAX_PEND_REF_M GENMASK(19, 16) +#define ICPU_MEMCTRL_REF_PERIOD_MAX_PEND_REF_X(x) (((x) & GENMASK(19, 16)) >> 16) +#define ICPU_MEMCTRL_REF_PERIOD_REF_PERIOD(x) ((x) & GENMASK(15, 0)) +#define ICPU_MEMCTRL_REF_PERIOD_REF_PERIOD_M GENMASK(15, 0) + +#define ICPU_MEMCTRL_ZQCAL 0x118 + +#define ICPU_MEMCTRL_ZQCAL_ZQCAL_LONG BIT(1) +#define ICPU_MEMCTRL_ZQCAL_ZQCAL_SHORT BIT(0) + +#define ICPU_MEMCTRL_TIMING0 0x11c + +#define ICPU_MEMCTRL_TIMING0_RD_TO_WR_DLY(x) (((x) << 28) & GENMASK(31, 28)) +#define ICPU_MEMCTRL_TIMING0_RD_TO_WR_DLY_M GENMASK(31, 28) +#define ICPU_MEMCTRL_TIMING0_RD_TO_WR_DLY_X(x) (((x) & GENMASK(31, 28)) >> 28) +#define ICPU_MEMCTRL_TIMING0_WR_CS_CHANGE_DLY(x) (((x) << 24) & GENMASK(27, 24)) +#define ICPU_MEMCTRL_TIMING0_WR_CS_CHANGE_DLY_M GENMASK(27, 24) +#define ICPU_MEMCTRL_TIMING0_WR_CS_CHANGE_DLY_X(x) (((x) & GENMASK(27, 24)) >> 24) +#define ICPU_MEMCTRL_TIMING0_RD_CS_CHANGE_DLY(x) (((x) << 20) & GENMASK(23, 20)) +#define ICPU_MEMCTRL_TIMING0_RD_CS_CHANGE_DLY_M GENMASK(23, 20) +#define ICPU_MEMCTRL_TIMING0_RD_CS_CHANGE_DLY_X(x) (((x) & GENMASK(23, 20)) >> 20) +#define ICPU_MEMCTRL_TIMING0_RAS_TO_PRECH_DLY(x) (((x) << 16) & GENMASK(19, 16)) +#define ICPU_MEMCTRL_TIMING0_RAS_TO_PRECH_DLY_M GENMASK(19, 16) +#define ICPU_MEMCTRL_TIMING0_RAS_TO_PRECH_DLY_X(x) (((x) & GENMASK(19, 16)) >> 16) +#define ICPU_MEMCTRL_TIMING0_WR_TO_PRECH_DLY(x) (((x) << 12) & GENMASK(15, 12)) +#define ICPU_MEMCTRL_TIMING0_WR_TO_PRECH_DLY_M GENMASK(15, 12) +#define ICPU_MEMCTRL_TIMING0_WR_TO_PRECH_DLY_X(x) (((x) & GENMASK(15, 12)) >> 12) +#define ICPU_MEMCTRL_TIMING0_RD_TO_PRECH_DLY(x) (((x) << 8) & GENMASK(11, 8)) +#define ICPU_MEMCTRL_TIMING0_RD_TO_PRECH_DLY_M GENMASK(11, 8) +#define ICPU_MEMCTRL_TIMING0_RD_TO_PRECH_DLY_X(x) (((x) & GENMASK(11, 8)) >> 8) +#define ICPU_MEMCTRL_TIMING0_WR_DATA_XFR_DLY(x) (((x) << 4) & GENMASK(7, 4)) +#define ICPU_MEMCTRL_TIMING0_WR_DATA_XFR_DLY_M GENMASK(7, 4) +#define ICPU_MEMCTRL_TIMING0_WR_DATA_XFR_DLY_X(x) (((x) & GENMASK(7, 4)) >> 4) +#define ICPU_MEMCTRL_TIMING0_RD_DATA_XFR_DLY(x) ((x) & GENMASK(3, 0)) +#define ICPU_MEMCTRL_TIMING0_RD_DATA_XFR_DLY_M GENMASK(3, 0) + +#define ICPU_MEMCTRL_TIMING1 0x120 + +#define ICPU_MEMCTRL_TIMING1_RAS_TO_RAS_SAME_BANK_DLY(x) (((x) << 24) & GENMASK(31, 24)) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_RAS_SAME_BANK_DLY_M GENMASK(31, 24) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_RAS_SAME_BANK_DLY_X(x) (((x) & GENMASK(31, 24)) >> 24) +#define ICPU_MEMCTRL_TIMING1_BANK8_FAW_DLY(x) (((x) << 16) & GENMASK(23, 16)) +#define ICPU_MEMCTRL_TIMING1_BANK8_FAW_DLY_M GENMASK(23, 16) +#define ICPU_MEMCTRL_TIMING1_BANK8_FAW_DLY_X(x) (((x) & GENMASK(23, 16)) >> 16) +#define ICPU_MEMCTRL_TIMING1_PRECH_TO_RAS_DLY(x) (((x) << 12) & GENMASK(15, 12)) +#define ICPU_MEMCTRL_TIMING1_PRECH_TO_RAS_DLY_M GENMASK(15, 12) +#define ICPU_MEMCTRL_TIMING1_PRECH_TO_RAS_DLY_X(x) (((x) & GENMASK(15, 12)) >> 12) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_RAS_DLY(x) (((x) << 8) & GENMASK(11, 8)) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_RAS_DLY_M GENMASK(11, 8) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_RAS_DLY_X(x) (((x) & GENMASK(11, 8)) >> 8) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_CAS_DLY(x) (((x) << 4) & GENMASK(7, 4)) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_CAS_DLY_M GENMASK(7, 4) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_CAS_DLY_X(x) (((x) & GENMASK(7, 4)) >> 4) +#define ICPU_MEMCTRL_TIMING1_WR_TO_RD_DLY(x) ((x) & GENMASK(3, 0)) +#define ICPU_MEMCTRL_TIMING1_WR_TO_RD_DLY_M GENMASK(3, 0) + +#define ICPU_MEMCTRL_TIMING2 0x124 + +#define ICPU_MEMCTRL_TIMING2_PRECH_ALL_DLY(x) (((x) << 28) & GENMASK(31, 28)) +#define ICPU_MEMCTRL_TIMING2_PRECH_ALL_DLY_M GENMASK(31, 28) +#define ICPU_MEMCTRL_TIMING2_PRECH_ALL_DLY_X(x) (((x) & GENMASK(31, 28)) >> 28) +#define ICPU_MEMCTRL_TIMING2_MDSET_DLY(x) (((x) << 24) & GENMASK(27, 24)) +#define ICPU_MEMCTRL_TIMING2_MDSET_DLY_M GENMASK(27, 24) +#define ICPU_MEMCTRL_TIMING2_MDSET_DLY_X(x) (((x) & GENMASK(27, 24)) >> 24) +#define ICPU_MEMCTRL_TIMING2_REF_DLY(x) (((x) << 16) & GENMASK(23, 16)) +#define ICPU_MEMCTRL_TIMING2_REF_DLY_M GENMASK(23, 16) +#define ICPU_MEMCTRL_TIMING2_REF_DLY_X(x) (((x) & GENMASK(23, 16)) >> 16) +#define ICPU_MEMCTRL_TIMING2_INIT_DLY(x) ((x) & GENMASK(15, 0)) +#define ICPU_MEMCTRL_TIMING2_INIT_DLY_M GENMASK(15, 0) + +#define ICPU_MEMCTRL_TIMING3 0x128 + +#define ICPU_MEMCTRL_TIMING3_RMW_DLY(x) (((x) << 16) & GENMASK(19, 16)) +#define ICPU_MEMCTRL_TIMING3_RMW_DLY_M GENMASK(19, 16) +#define ICPU_MEMCTRL_TIMING3_RMW_DLY_X(x) (((x) & GENMASK(19, 16)) >> 16) +#define ICPU_MEMCTRL_TIMING3_ODT_RD_DLY(x) (((x) << 12) & GENMASK(15, 12)) +#define ICPU_MEMCTRL_TIMING3_ODT_RD_DLY_M GENMASK(15, 12) +#define ICPU_MEMCTRL_TIMING3_ODT_RD_DLY_X(x) (((x) & GENMASK(15, 12)) >> 12) +#define ICPU_MEMCTRL_TIMING3_ODT_WR_DLY(x) (((x) << 8) & GENMASK(11, 8)) +#define ICPU_MEMCTRL_TIMING3_ODT_WR_DLY_M GENMASK(11, 8) +#define ICPU_MEMCTRL_TIMING3_ODT_WR_DLY_X(x) (((x) & GENMASK(11, 8)) >> 8) +#define ICPU_MEMCTRL_TIMING3_LOCAL_ODT_RD_DLY(x) (((x) << 4) & GENMASK(7, 4)) +#define ICPU_MEMCTRL_TIMING3_LOCAL_ODT_RD_DLY_M GENMASK(7, 4) +#define ICPU_MEMCTRL_TIMING3_LOCAL_ODT_RD_DLY_X(x) (((x) & GENMASK(7, 4)) >> 4) +#define ICPU_MEMCTRL_TIMING3_WR_TO_RD_CS_CHANGE_DLY(x) ((x) & GENMASK(3, 0)) +#define ICPU_MEMCTRL_TIMING3_WR_TO_RD_CS_CHANGE_DLY_M GENMASK(3, 0) + +#define ICPU_MEMCTRL_TIMING4 0x12c + +#define ICPU_MEMCTRL_TIMING4_ZQCAL_INIT_DLY(x) (((x) << 20) & GENMASK(31, 20)) +#define ICPU_MEMCTRL_TIMING4_ZQCAL_INIT_DLY_M GENMASK(31, 20) +#define ICPU_MEMCTRL_TIMING4_ZQCAL_INIT_DLY_X(x) (((x) & GENMASK(31, 20)) >> 20) +#define ICPU_MEMCTRL_TIMING4_ZQCAL_LONG_DLY(x) (((x) << 8) & GENMASK(19, 8)) +#define ICPU_MEMCTRL_TIMING4_ZQCAL_LONG_DLY_M GENMASK(19, 8) +#define ICPU_MEMCTRL_TIMING4_ZQCAL_LONG_DLY_X(x) (((x) & GENMASK(19, 8)) >> 8) +#define ICPU_MEMCTRL_TIMING4_ZQCAL_SHORT_DLY(x) ((x) & GENMASK(7, 0)) +#define ICPU_MEMCTRL_TIMING4_ZQCAL_SHORT_DLY_M GENMASK(7, 0) + +#define ICPU_MEMCTRL_MR0_VAL 0x130 + +#define ICPU_MEMCTRL_MR1_VAL 0x134 + +#define ICPU_MEMCTRL_MR2_VAL 0x138 + +#define ICPU_MEMCTRL_MR3_VAL 0x13c + +#define ICPU_MEMCTRL_TERMRES_CTRL 0x140 + +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_RD_EXT BIT(11) +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_RD_ENA(x) (((x) << 7) & GENMASK(10, 7)) +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_RD_ENA_M GENMASK(10, 7) +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_RD_ENA_X(x) (((x) & GENMASK(10, 7)) >> 7) +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_WR_EXT BIT(6) +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_WR_ENA(x) (((x) << 2) & GENMASK(5, 2)) +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_WR_ENA_M GENMASK(5, 2) +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_WR_ENA_X(x) (((x) & GENMASK(5, 2)) >> 2) +#define ICPU_MEMCTRL_TERMRES_CTRL_LOCAL_ODT_RD_EXT BIT(1) +#define ICPU_MEMCTRL_TERMRES_CTRL_LOCAL_ODT_RD_ENA BIT(0) + +#define ICPU_MEMCTRL_DFT 0x144 + +#define ICPU_MEMCTRL_DFT_DDRDFT_LBW BIT(7) +#define ICPU_MEMCTRL_DFT_DDRDFT_GATE_ENA BIT(6) +#define ICPU_MEMCTRL_DFT_DDRDFT_TERM_ENA BIT(5) +#define ICPU_MEMCTRL_DFT_DDRDFT_A10 BIT(4) +#define ICPU_MEMCTRL_DFT_DDRDFT_STAT BIT(3) +#define ICPU_MEMCTRL_DFT_DDRDFT_MODE(x) (((x) << 1) & GENMASK(2, 1)) +#define ICPU_MEMCTRL_DFT_DDRDFT_MODE_M GENMASK(2, 1) +#define ICPU_MEMCTRL_DFT_DDRDFT_MODE_X(x) (((x) & GENMASK(2, 1)) >> 1) +#define ICPU_MEMCTRL_DFT_DDRDFT_ENA BIT(0) + +#define ICPU_MEMCTRL_DQS_DLY(x) (0x148 + 0x4 * (x)) +#define ICPU_MEMCTRL_DQS_DLY_RSZ 0x2 + +#define ICPU_MEMCTRL_DQS_DLY_TRAIN_DQ_ENA BIT(11) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY_TRM1(x) (((x) << 8) & GENMASK(10, 8)) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY_TRM1_M GENMASK(10, 8) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY_TRM1_X(x) (((x) & GENMASK(10, 8)) >> 8) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY_TRM0(x) (((x) << 5) & GENMASK(7, 5)) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY_TRM0_M GENMASK(7, 5) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY_TRM0_X(x) (((x) & GENMASK(7, 5)) >> 5) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY(x) ((x) & GENMASK(4, 0)) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY_M GENMASK(4, 0) + +#define ICPU_MEMCTRL_DQS_AUTO 0x150 +#define ICPU_MEMCTRL_DQS_AUTO_RSZ 0x2 + +#define ICPU_MEMCTRL_DQS_AUTO_DQS_DRIFT(x) (((x) << 6) & GENMASK(7, 6)) +#define ICPU_MEMCTRL_DQS_AUTO_DQS_DRIFT_M GENMASK(7, 6) +#define ICPU_MEMCTRL_DQS_AUTO_DQS_DRIFT_X(x) (((x) & GENMASK(7, 6)) >> 6) +#define ICPU_MEMCTRL_DQS_AUTO_DQS_OVERFLOW BIT(5) +#define ICPU_MEMCTRL_DQS_AUTO_DQS_UNDERFLOW BIT(4) +#define ICPU_MEMCTRL_DQS_AUTO_DQS_AUTO_SRC BIT(3) +#define ICPU_MEMCTRL_DQS_AUTO_DQS_AUTO_UP BIT(2) +#define ICPU_MEMCTRL_DQS_AUTO_DQS_AUTO_DOWN BIT(1) +#define ICPU_MEMCTRL_DQS_AUTO_DQS_AUTO_ENA BIT(0) + +#define ICPU_MEMPHY_CFG 0x158 + +#define ICPU_MEMPHY_CFG_PHY_FLUSH_DIS BIT(10) +#define ICPU_MEMPHY_CFG_PHY_RD_ADJ_DIS BIT(9) +#define ICPU_MEMPHY_CFG_PHY_DQS_EXT BIT(8) +#define ICPU_MEMPHY_CFG_PHY_FIFO_RST BIT(7) +#define ICPU_MEMPHY_CFG_PHY_DLL_BL_RST BIT(6) +#define ICPU_MEMPHY_CFG_PHY_DLL_CL_RST BIT(5) +#define ICPU_MEMPHY_CFG_PHY_ODT_OE BIT(4) +#define ICPU_MEMPHY_CFG_PHY_CK_OE BIT(3) +#define ICPU_MEMPHY_CFG_PHY_CL_OE BIT(2) +#define ICPU_MEMPHY_CFG_PHY_SSTL_ENA BIT(1) +#define ICPU_MEMPHY_CFG_PHY_RST BIT(0) + +#define ICPU_MEMPHY_ZCAL 0x180 + +#define ICPU_MEMPHY_ZCAL_ZCAL_CLK_SEL BIT(9) +#define ICPU_MEMPHY_ZCAL_ZCAL_PROG_ODT(x) (((x) << 5) & GENMASK(8, 5)) +#define ICPU_MEMPHY_ZCAL_ZCAL_PROG_ODT_M GENMASK(8, 5) +#define ICPU_MEMPHY_ZCAL_ZCAL_PROG_ODT_X(x) (((x) & GENMASK(8, 5)) >> 5) +#define ICPU_MEMPHY_ZCAL_ZCAL_PROG(x) (((x) << 1) & GENMASK(4, 1)) +#define ICPU_MEMPHY_ZCAL_ZCAL_PROG_M GENMASK(4, 1) +#define ICPU_MEMPHY_ZCAL_ZCAL_PROG_X(x) (((x) & GENMASK(4, 1)) >> 1) +#define ICPU_MEMPHY_ZCAL_ZCAL_ENA BIT(0) + +#define ICPU_MEMPHY_ZCAL_STAT 0x184 + +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_ZCTRL(x) (((x) << 12) & GENMASK(31, 12)) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_ZCTRL_M GENMASK(31, 12) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_ZCTRL_X(x) (((x) & GENMASK(31, 12)) >> 12) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_ODTPU(x) (((x) << 8) & GENMASK(9, 8)) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_ODTPU_M GENMASK(9, 8) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_ODTPU_X(x) (((x) & GENMASK(9, 8)) >> 8) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_ODTPD(x) (((x) << 6) & GENMASK(7, 6)) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_ODTPD_M GENMASK(7, 6) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_ODTPD_X(x) (((x) & GENMASK(7, 6)) >> 6) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_PU(x) (((x) << 4) & GENMASK(5, 4)) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_PU_M GENMASK(5, 4) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_PU_X(x) (((x) & GENMASK(5, 4)) >> 4) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_PD(x) (((x) << 2) & GENMASK(3, 2)) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_PD_M GENMASK(3, 2) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_PD_X(x) (((x) & GENMASK(3, 2)) >> 2) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_ERR BIT(1) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_DONE BIT(0) + +#endif diff --git a/arch/mips/mach-mscc/reset.c b/arch/mips/mach-mscc/reset.c index 3740225..a555fc9 100644 --- a/arch/mips/mach-mscc/reset.c +++ b/arch/mips/mach-mscc/reset.c @@ -27,7 +27,30 @@ void _machine_restart(void) ICPU_RESET_CORE_RST_CPU_ONLY | ICPU_RESET_CORE_RST_FORCE, BASE_CFG + ICPU_RESET); -#else +#elif defined(CONFIG_SOC_SERVAL) + register unsigned long i; + + /* Prevent VCore-III from being reset with a global reset */ + writel(ICPU_RESET_CORE_RST_PROTECT, BASE_CFG + ICPU_RESET); + + /* Do global reset */ + writel(PERF_SOFT_RST_SOFT_CHIP_RST, BASE_DEVCPU_GCB + PERF_SOFT_RST); + + for (i = 0; i < 1000; i++) + ; + + /* Power down DDR for clean DDR re-training */ + writel(readl(BASE_CFG + ICPU_MEMCTRL_CTRL) | + ICPU_MEMCTRL_CTRL_PWR_DOWN, + BASE_CFG + ICPU_MEMCTRL_CTRL); + + while (!(readl(BASE_CFG + ICPU_MEMCTRL_STAT) & + ICPU_MEMCTRL_STAT_PWR_DOWN_ACK)) + ; + + /* Reset VCore-III, only. */ + writel(ICPU_RESET_CORE_RST_FORCE, BASE_CFG + ICPU_RESET); +#else /* Luton || Ocelot */ register u32 resetbits = PERF_SOFT_RST_SOFT_CHIP_RST; (void)readl(BASE_DEVCPU_GCB + PERF_SOFT_RST);
diff --git a/include/configs/vcoreiii.h b/include/configs/vcoreiii.h index 4ea5f40..8c30c6f 100644 --- a/include/configs/vcoreiii.h +++ b/include/configs/vcoreiii.h @@ -14,10 +14,11 @@ #define CONFIG_SYS_LOAD_ADDR 0x00100000 #define CONFIG_SYS_INIT_SP_OFFSET 0x400000
-#define CPU_CLOCK_RATE 500000000 /* Clock for the MIPS core */ -#ifdef CONFIG_SOC_LUTON +#if defined(CONFIG_SOC_LUTON) || defined(CONFIG_SOC_SERVAL) +#define CPU_CLOCK_RATE 416666666 /* Clock for the MIPS core */ #define CONFIG_SYS_MIPS_TIMER_FREQ 208333333 #else +#define CPU_CLOCK_RATE 500000000 /* Clock for the MIPS core */ #define CONFIG_SYS_MIPS_TIMER_FREQ (CPU_CLOCK_RATE / 2) #endif #define CONFIG_SYS_NS16550_CLK CONFIG_SYS_MIPS_TIMER_FREQ
Add device tree based on evaluation board pcb105.
Signed-off-by: Horatiu Vultur horatiu.vultur@microchip.com --- arch/mips/dts/mscc,serval.dtsi | 149 ++++++++++++++++++++++++++++++++++++++++ arch/mips/dts/serval_pcb105.dts | 56 +++++++++++++++ 2 files changed, 205 insertions(+) create mode 100644 arch/mips/dts/mscc,serval.dtsi create mode 100644 arch/mips/dts/serval_pcb105.dts
diff --git a/arch/mips/dts/mscc,serval.dtsi b/arch/mips/dts/mscc,serval.dtsi new file mode 100644 index 0000000..bd60051 --- /dev/null +++ b/arch/mips/dts/mscc,serval.dtsi @@ -0,0 +1,149 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +/ { + #address-cells = <1>; + #size-cells = <1>; + compatible = "mscc,serval"; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + compatible = "mips,mips24KEc"; + device_type = "cpu"; + clocks = <&cpu_clk>; + reg = <0>; + }; + }; + + aliases { + serial0 = &uart0; + }; + + cpuintc: interrupt-controller@0 { + #address-cells = <0>; + #interrupt-cells = <1>; + interrupt-controller; + compatible = "mti,cpu-interrupt-controller"; + }; + + cpu_clk: cpu-clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <416666666>; + }; + + sys_clk: sys-clk { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <208333333>; + }; + + ahb_clk: ahb-clk { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <208333333>; + }; + + ahb { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x70000000 0x2000000>; + + interrupt-parent = <&intc>; + + cpu_ctrl: syscon@0 { + compatible = "mscc,serval-cpu-syscon", "syscon"; + reg = <0x0 0x2c>; + }; + + intc: interrupt-controller@70 { + compatible = "mscc,serval-icpu-intr"; + reg = <0x70 0x70>; + #interrupt-cells = <1>; + interrupt-controller; + interrupt-parent = <&cpuintc>; + interrupts = <2>; + }; + + uart0: serial@100000 { + pinctrl-0 = <&uart_pins>; + pinctrl-names = "default"; + compatible = "ns16550a"; + reg = <0x100000 0x20>; + interrupts = <6>; + clocks = <&ahb_clk>; + reg-io-width = <4>; + reg-shift = <2>; + + status = "disabled"; + }; + + uart2: serial@100800 { + pinctrl-0 = <&uart2_pins>; + pinctrl-names = "default"; + compatible = "ns16550a"; + reg = <0x100800 0x20>; + interrupts = <7>; + clocks = <&ahb_clk>; + reg-io-width = <4>; + reg-shift = <2>; + + status = "disabled"; + }; + + reset@1070008 { + compatible = "mscc,serval-chip-reset"; + reg = <0x1070008 0x4>; + }; + + gpio: pinctrl@1070034 { + compatible = "mscc,serval-pinctrl"; + reg = <0x1070034 0x68>; + gpio-controller; + #gpio-cells = <2>; + gpio-ranges = <&gpio 0 0 22>; + + sgpio_pins: sgpio-pins { + pins = "GPIO_0", "GPIO_2", "GPIO_3", "GPIO_1"; + function = "sio"; + }; + + uart_pins: uart-pins { + pins = "GPIO_26", "GPIO_27"; + function = "uart"; + }; + + uart2_pins: uart2-pins { + pins = "GPIO_13", "GPIO_14"; + function = "uart2"; + }; + }; + + spi0: spi-bitbang { + compatible = "mscc,luton-bb-spi"; + status = "okay"; + reg = <0x50 0x4>; + num-chipselects = <1>; + #address-cells = <1>; + #size-cells = <0>; + }; + + sgpio: gpio@10700b4 { + compatible = "mscc,luton-sgpio"; + status = "disabled"; + clocks = <&sys_clk>; + pinctrl-0 = <&sgpio_pins>; + pinctrl-names = "default"; + reg = <0x10700b4 0x100>; + gpio-controller; + #gpio-cells = <2>; + gpio-ranges = <&sgpio 0 0 64>; + }; + }; +}; diff --git a/arch/mips/dts/serval_pcb105.dts b/arch/mips/dts/serval_pcb105.dts new file mode 100644 index 0000000..d0d6fac --- /dev/null +++ b/arch/mips/dts/serval_pcb105.dts @@ -0,0 +1,56 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +/dts-v1/; +#include "mscc,serval.dtsi" + +/ { + model = "Serval PCB105 Reference Board"; + compatible = "mscc,serval-pcb105", "mscc,serval"; + + aliases { + spi0 = &spi0; + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + gpio-leds { + compatible = "gpio-leds"; + + status_green { + label = "pcb105:green:status"; + gpios = <&sgpio 43 1>; /* p11.1 */ + default-state = "on"; + }; + + status_red { + label = "pcb105:red:status"; + gpios = <&sgpio 11 1>; /* p11.0 */ + default-state = "off"; + }; + }; +}; + +&uart0 { + status = "okay"; +}; + +&spi0 { + status = "okay"; + spi-flash@0 { + compatible = "spi-flash"; + spi-max-frequency = <18000000>; /* input clock */ + reg = <0>; /* CS0 */ + spi-cs-high; + }; +}; + +&sgpio { + status = "okay"; + sgpio-ports = <0x00FFFFFF>; +};
Add device tree based on evaluation board pcb106.
Signed-off-by: Horatiu Vultur horatiu.vultur@microchip.com --- arch/mips/dts/serval_pcb106.dts | 56 +++++++++++++++++++++++++++++++++++++++++ 1 file changed, 56 insertions(+) create mode 100644 arch/mips/dts/serval_pcb106.dts
diff --git a/arch/mips/dts/serval_pcb106.dts b/arch/mips/dts/serval_pcb106.dts new file mode 100644 index 0000000..1198249 --- /dev/null +++ b/arch/mips/dts/serval_pcb106.dts @@ -0,0 +1,56 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +/dts-v1/; +#include "mscc,serval.dtsi" + +/ { + model = "Serval PCB106 Reference Board"; + compatible = "mscc,serval-pcb106", "mscc,serval"; + + aliases { + spi0 = &spi0; + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + gpio-leds { + compatible = "gpio-leds"; + + status_green { + label = "pcb106:green:status"; + gpios = <&sgpio 43 1>; /* p11.1 */ + default-state = "on"; + }; + + status_red { + label = "pcb106:red:status"; + gpios = <&sgpio 11 1>; /* p11.0 */ + default-state = "off"; + }; + }; +}; + +&uart0 { + status = "okay"; +}; + +&spi0 { + status = "okay"; + spi-flash@0 { + compatible = "spi-flash"; + spi-max-frequency = <18000000>; /* input clock */ + reg = <0>; /* CS0 */ + spi-cs-high; + }; +}; + +&sgpio { + status = "okay"; + sgpio-ports = <0x00FFFFFF>; +};
Add board support and configuration for Jaguar2 SoC family. The detection of the board type is based on the phy ids.
Signed-off-by: Horatiu Vultur horatiu.vultur@microchip.com --- arch/mips/dts/Makefile | 1 + arch/mips/mach-mscc/Makefile | 1 + board/mscc/serval/Kconfig | 14 ++++++++ board/mscc/serval/Makefile | 3 ++ board/mscc/serval/serval.c | 74 +++++++++++++++++++++++++++++++++++++++++++ configs/mscc_serval_defconfig | 62 ++++++++++++++++++++++++++++++++++++ 6 files changed, 155 insertions(+) create mode 100644 board/mscc/serval/Kconfig create mode 100644 board/mscc/serval/Makefile create mode 100644 board/mscc/serval/serval.c create mode 100644 configs/mscc_serval_defconfig
diff --git a/arch/mips/dts/Makefile b/arch/mips/dts/Makefile index af264ff..b94b582 100644 --- a/arch/mips/dts/Makefile +++ b/arch/mips/dts/Makefile @@ -21,6 +21,7 @@ dtb-$(CONFIG_SOC_LUTON) += luton_pcb090.dtb luton_pcb091.dtb dtb-$(CONFIG_SOC_OCELOT) += ocelot_pcb120.dtb ocelot_pcb123.dtb dtb-$(CONFIG_SOC_JR2) += jr2_pcb110.dtb jr2_pcb111.dtb serval2_pcb112.dtb dtb-$(CONFIG_SOC_SERVALT) += servalt_pcb116.dtb +dtb-$(CONFIG_SOC_SERVAL) += serval_pcb105.dtb serval_pcb106.dtb
targets += $(dtb-y)
diff --git a/arch/mips/mach-mscc/Makefile b/arch/mips/mach-mscc/Makefile index f5b6968..6d60020 100644 --- a/arch/mips/mach-mscc/Makefile +++ b/arch/mips/mach-mscc/Makefile @@ -5,3 +5,4 @@ CFLAGS_cpu.o += -finline-limit=64000 obj-y += cpu.o dram.o reset.o phy.o lowlevel_init.o obj-$(CONFIG_SOC_LUTON) += lowlevel_init_luton.o gpio.o obj-$(CONFIG_SOC_OCELOT) += gpio.o +obj-$(CONFIG_SOC_SERVAL) += gpio.o diff --git a/board/mscc/serval/Kconfig b/board/mscc/serval/Kconfig new file mode 100644 index 0000000..64f1c68 --- /dev/null +++ b/board/mscc/serval/Kconfig @@ -0,0 +1,14 @@ +# SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +config SYS_VENDOR + default "mscc" + +if SOC_SERVAL + +config SYS_BOARD + default "serval" + +config SYS_CONFIG_NAME + default "serval" + +endif diff --git a/board/mscc/serval/Makefile b/board/mscc/serval/Makefile new file mode 100644 index 0000000..c7ba56e --- /dev/null +++ b/board/mscc/serval/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +obj-$(CONFIG_SOC_SERVAL) := serval.o diff --git a/board/mscc/serval/serval.c b/board/mscc/serval/serval.c new file mode 100644 index 0000000..24ee5e5 --- /dev/null +++ b/board/mscc/serval/serval.c @@ -0,0 +1,74 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#include <common.h> +#include <asm/io.h> +#include <led.h> + +enum { + BOARD_TYPE_PCB106 = 0xAABBCD00, + BOARD_TYPE_PCB105, +}; + +int board_early_init_r(void) +{ + /* Prepare SPI controller to be used in master mode */ + writel(0, BASE_CFG + ICPU_SW_MODE); + + /* Address of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE; + + /* LED setup */ + if (IS_ENABLED(CONFIG_LED)) + led_default_state(); + + return 0; +} + +static void do_board_detect(void) +{ + u16 gpio_in_reg; + + /* Set MDIO and MDC */ + mscc_gpio_set_alternate(9, 2); + mscc_gpio_set_alternate(10, 2); + + /* Set GPIO page */ + mscc_phy_wr(1, 16, 31, 0x10); + if (!mscc_phy_rd(1, 16, 15, &gpio_in_reg)) { + if (gpio_in_reg & 0x200) + gd->board_type = BOARD_TYPE_PCB106; + else + gd->board_type = BOARD_TYPE_PCB105; + mscc_phy_wr(1, 16, 15, 0); + } else { + gd->board_type = BOARD_TYPE_PCB105; + } +} + +#if defined(CONFIG_MULTI_DTB_FIT) +int board_fit_config_name_match(const char *name) +{ + if (gd->board_type == BOARD_TYPE_PCB106 && + strcmp(name, "serval_pcb106") == 0) + return 0; + + if (gd->board_type == BOARD_TYPE_PCB105 && + strcmp(name, "serval_pcb105") == 0) + return 0; + + return -1; +} +#endif + +#if defined(CONFIG_DTB_RESELECT) +int embedded_dtb_select(void) +{ + do_board_detect(); + fdtdec_setup(); + + return 0; +} +#endif diff --git a/configs/mscc_serval_defconfig b/configs/mscc_serval_defconfig new file mode 100644 index 0000000..263e37d --- /dev/null +++ b/configs/mscc_serval_defconfig @@ -0,0 +1,62 @@ +CONFIG_MIPS=y +CONFIG_SYS_TEXT_BASE=0x40000000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ARCH_MSCC=y +CONFIG_SOC_SERVAL=y +CONFIG_DDRTYPE_H5TQ1G63BFA=y +CONFIG_SYS_LITTLE_ENDIAN=y +CONFIG_FIT=y +CONFIG_BOOTDELAY=3 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200" +CONFIG_LOGLEVEL=7 +CONFIG_DISPLAY_CPUINFO=y +CONFIG_SYS_PROMPT="serval # " +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_MD5SUM=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MEMTEST=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +# CONFIG_CMD_NFS is not set +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nor0=spi_flash" +CONFIG_MTDPARTS_DEFAULT="mtdparts=spi_flash:1m(UBoot),256k(Env),256k(Env.bk)" +# CONFIG_ISO_PARTITION is not set +CONFIG_DEFAULT_DEVICE_TREE="serval_pcb106" +CONFIG_OF_LIST="serval_pcb106 serval_pcb105" +CONFIG_DTB_RESELECT=y +CONFIG_MULTI_DTB_FIT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_CLK=y +CONFIG_DM_GPIO=y +CONFIG_MSCC_SGPIO=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_DM_ETH=y +CONFIG_PINCTRL=y +CONFIG_PINCONF=y +CONFIG_DM_SERIAL=y +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_MSCC_BB_SPI=y +CONFIG_LZMA=y +CONFIG_XZ=y
is this a resend or an extension of your v2 series?
Normally a resend is not necessary and should be annotated accordingly. If this is an update, then you should have sent it as a v3 with a proper changelog.
Hi Daniel,
Well, it is none, it is a new patch series. The one in [1] is for ServalT while this patch series is for Serval. There are 2 different SoC families.
- Daniel
Am 23.01.19 um 17:47 schrieb Horatiu Vultur:
Hi Daniel,
- Daniel
ah sorry, but with the Patchwork font it's hard to note the difference between "MSCC: Add Servalt SoC family" and "MSCC: Add Serval SoC family" ;)
series applied to u-boot-mips, thanks.
Daniel Schwierzeck
Horatiu Vultur
