Re: [U-Boot-Users] [PATCH 1/2] fdt_support: fdt_fixup_dr_usb: add support for phy_type fixups
On Tue, Jul 08, 2008 at 08:38:37PM -0400, Jerry Van Baren wrote:
Anton Vorontsov wrote:
Currently U-Boot can only fixup the usb dr_mode, but some boards (namely MPC8315E-RDB) can use two PHY types: ULPI (stand-alone OTG port) or UTMI (connected to the four-ports hub, usb host only).
This patch implements support for passing Dual-Role USB controller's device tree property phy_type through the usb_phy_type environment variable.
Signed-off-by: Anton Vorontsov avorontsov@ru.mvista.com
common/fdt_support.c | 30 +++++++++++++++++++++++------- 1 files changed, 23 insertions(+), 7 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index 3828228..24bbed0 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c
Hi Anton, Kim,
This looks good to me.
Anton, I presume this is additional functionality for the next window, not a bug fix for the current (closed) window?
No, this isn't a bug fix. Just a new feature for the next window.
Kim, would you like to apply this as well as [PATCH 2/2] through the 83xx repository so the two halves go in at the same time?
Acked-by: Gerald Van Baren vanbaren@cideas.com
Thanks,
Anton Vorontsov
