[U-Boot] [PATCH] [resubmit] Fix printf errors under -DDEBUG
Fix printf format-string/arg mismatches under -DDEBUG.
These warnings occur with DEBUG defined for a platform using cpu/mpc85xx. Users of other architectures can unearth similar problems by adding the line "CFLAGS += -DDEBUG=1" in config.mk right after "CFLAGS += $(call cc-option,-fno-stack-protector)".
Signed-off-by: Andrew Klossner andrew@cesa.opbu.xerox.com --- cpu/mpc85xx/interrupts.c | 14 +++++++------- drivers/mtd/cfi_flash.c | 2 +- lib_ppc/bootm.c | 2 +- 3 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/cpu/mpc85xx/interrupts.c b/cpu/mpc85xx/interrupts.c index 4fe1fac..ad11690 100644 --- a/cpu/mpc85xx/interrupts.c +++ b/cpu/mpc85xx/interrupts.c @@ -92,29 +92,29 @@ int interrupt_init (void)
#ifdef CONFIG_INTERRUPTS pic->iivpr1 = 0x810001; /* 50220 enable ecm interrupts */ - debug("iivpr1@%x = %x\n",&pic->iivpr1, pic->iivpr1); + debug("iivpr1@%x = %x\n", (uint)&pic->iivpr1, pic->iivpr1);
pic->iivpr2 = 0x810002; /* 50240 enable ddr interrupts */ - debug("iivpr2@%x = %x\n",&pic->iivpr2, pic->iivpr2); + debug("iivpr2@%x = %x\n", (uint)&pic->iivpr2, pic->iivpr2);
pic->iivpr3 = 0x810003; /* 50260 enable lbc interrupts */ - debug("iivpr3@%x = %x\n",&pic->iivpr3, pic->iivpr3); + debug("iivpr3@%x = %x\n", (uint)&pic->iivpr3, pic->iivpr3);
#ifdef CONFIG_PCI1 pic->iivpr8 = 0x810008; /* enable pci1 interrupts */ - debug("iivpr8@%x = %x\n",&pic->iivpr8, pic->iivpr8); + debug("iivpr8@%x = %x\n", (uint)&pic->iivpr8, pic->iivpr8); #endif #if defined(CONFIG_PCI2) || defined(CONFIG_PCIE2) pic->iivpr9 = 0x810009; /* enable pci1 interrupts */ - debug("iivpr9@%x = %x\n",&pic->iivpr9, pic->iivpr9); + debug("iivpr9@%x = %x\n", (uint)&pic->iivpr9, pic->iivpr9); #endif #ifdef CONFIG_PCIE1 pic->iivpr10 = 0x81000a; /* enable pcie1 interrupts */ - debug("iivpr10@%x = %x\n",&pic->iivpr10, pic->iivpr10); + debug("iivpr10@%x = %x\n", (uint)&pic->iivpr10, pic->iivpr10); #endif #ifdef CONFIG_PCIE3 pic->iivpr11 = 0x81000b; /* enable pcie3 interrupts */ - debug("iivpr11@%x = %x\n",&pic->iivpr11, pic->iivpr11); + debug("iivpr11@%x = %x\n", (uint)&pic->iivpr11, pic->iivpr11); #endif
pic->ctpr=0; /* 40080 clear current task priority register */ diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 58295fe..68de65a 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -516,7 +516,7 @@ static int flash_isequal (flash_info_t * info, flash_sect_t sect, retval = (flash_read16(addr) == cword.w); break; case FLASH_CFI_32BIT: - debug ("is= %8.8lx %8.8lx\n", flash_read32(addr), cword.l); + debug ("is= %8.8x %8.8lx\n", flash_read32(addr), cword.l); retval = (flash_read32(addr) == cword.l); break; case FLASH_CFI_64BIT: diff --git a/lib_ppc/bootm.c b/lib_ppc/bootm.c index e83c860..b442004 100644 --- a/lib_ppc/bootm.c +++ b/lib_ppc/bootm.c @@ -733,7 +733,7 @@ static int boot_get_fdt (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], *of_flat_tree = fdt_blob; *of_size = be32_to_cpu (fdt_totalsize (fdt_blob)); debug (" of_flat_tree at 0x%08lx size 0x%08lx\n", - *of_flat_tree, *of_size); + (ulong)*of_flat_tree, *of_size);
On Thu, Aug 21, 2008 at 9:12 AM, Andrew Klossner andrew@cesa.opbu.xerox.com wrote:
Applied with minor changes (lib_ppc/bootm.c code you changed got moved to common/image.c)
Thanks, Andy
Andrew Klossner
Andy Fleming
