Please pull NXP i.MX nxp-imx-4-28
Hi Stefano,
Please pull this version nxp-imx-20200422, with patches sent out to ML. Based on yours master branch. Please see whether you are ok with this patchset. I take Marek's one patch in the patchset, and all patches have Fabio's R-b tag applied.
CI: https://travis-ci.org/github/MrVan/u-boot/builds/679980391
Sorry for this late pull request.
------------------------------------------------------- SCFW API update, including seco/snvs SNVS support for i.MX8 A53 clk fixes for i.MX8MQ Speed grade updating i.MX8M variants support misc clk update acquire ATF build info -------------------------------------------------------
Thanks, Peng.
The following changes since commit d1bbf833aa7b45c00a42227b9563134643e44237:
Merge branch 'master' of https://gitlab.denx.de/u-boot/custodians/u-boot-imx (2020-04-20 08:45:27 -0400)
https://github.com/MrVan/u-boot.git tags/nxp-imx-4-28
for you to fetch changes up to 98555c2bd835254866581098f5b0fb8d6218e1b6:
imx8: Configure SNVS (2020-04-28 10:00:36 +0800)
---------------------------------------------------------------- Breno Lima (2): doc: ahab: Add encrypted boot documentation for i.MX8/8x devices imx8: scu api: Add support for SECO manufacturing protection APIs
Franck LENORMAND (1): imx8: Configure SNVS
Marek Vasut (1): ARM: imx: imx8mm: Add missing clock entries for FEC clock
Peng Fan (13): imx: fix cpu_type helper imx8mn: Update speed grade imx: cpu: support speed grade for i.MX8MP imx: imx8m: add i.MX8MQ Dual and QuadLite support imx: imx8m: add i.MX8MN variants support imx: update is_imx6ull to include i.MX6ULZ imx8: move SIP macro to common header imx8m: acquire ATF commit hash imx8m: update clock root and fix core_sel imx8mq: Set ARM core clock directly from ARM PLL imx8: parser: fix 'end address' parameter of rm_find_memreg imx8: ahab: fix 'end address' parameter of rm_find_memreg imx8: parser: fix some bad debug message formating
Seb Fagard (1): imx8: ahab: fix some bad debug message formating
Ye Li (7): imx8mm: Update CPU speed grading imx8mq: Enable eMMC HS400 and SD UHS mode on EVK imx8m: Dump DRAM PLL rate by clocks command imx8: Change to use new SECO API commands imx8mm: clock: fix fracpll decode issue imx8m: Enable WDOG_B for timeout imx8: Update SCFW API to version 1.5
arch/arm/include/asm/arch-imx/cpu.h | 7 + arch/arm/include/asm/arch-imx8/sci/rpc.h | 86 +++++++++--- arch/arm/include/asm/arch-imx8/sci/sci.h | 10 ++ arch/arm/include/asm/arch-imx8/sci/svc/pad/api.h | 3 + arch/arm/include/asm/arch-imx8/sci/types.h | 6 + arch/arm/include/asm/arch-imx8/snvs_security_sc.h | 11 ++ arch/arm/include/asm/arch-imx8m/clock_imx8mm.h | 5 +- arch/arm/include/asm/arch-imx8m/clock_imx8mq.h | 3 +- arch/arm/include/asm/mach-imx/sys_proto.h | 17 ++- arch/arm/mach-imx/cpu.c | 38 ++++- arch/arm/mach-imx/imx8/Kconfig | 13 ++ arch/arm/mach-imx/imx8/Makefile | 1 + arch/arm/mach-imx/imx8/ahab.c | 15 +- arch/arm/mach-imx/imx8/misc.c | 8 +- arch/arm/mach-imx/imx8/parse-container.c | 18 +-- arch/arm/mach-imx/imx8/snvs_security_sc.c | 923 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/mach-imx/imx8m/clock_imx8mm.c | 73 ++++++++-- arch/arm/mach-imx/imx8m/clock_imx8mq.c | 57 +++++--- arch/arm/mach-imx/imx8m/clock_slice.c | 824 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++--- arch/arm/mach-imx/imx8m/soc.c | 73 ++++++++-- board/freescale/imx8qxp_mek/imx8qxp_mek.c | 10 ++ doc/imx/ahab/csf_examples/csf_enc_boot_image.txt | 27 ++++ doc/imx/ahab/guides/mx8_mx8x_encrypted_boot.txt | 293 +++++++++++++++++++++++++++++++++++++++ drivers/misc/imx8/scu_api.c | 194 ++++++++++++++++++++++++++ include/imx_sip.h | 5 +- 25 files changed, 2602 insertions(+), 118 deletions(-) create mode 100644 arch/arm/include/asm/arch-imx8/snvs_security_sc.h create mode 100644 arch/arm/mach-imx/imx8/snvs_security_sc.c create mode 100644 doc/imx/ahab/csf_examples/csf_enc_boot_image.txt create mode 100644 doc/imx/ahab/guides/mx8_mx8x_encrypted_boot.txt
Peng Fan
