[PATCH] fdt_support: fix comments syntax error
Fix comments syntax error in fdt_node_offset_by_compat_reg() description: compatiable -> compatible
Signed-off-by: Hugo Villeneuve hvilleneuve@dimonoff.com --- common/fdt_support.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index dbceec6f2d..2053fe3bad 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -1486,11 +1486,11 @@ out: }
/** - * fdt_node_offset_by_compat_reg: Find a node that matches compatiable and + * fdt_node_offset_by_compat_reg: Find a node that matches compatible and * who's reg property matches a physical cpu address * * @blob: ptr to device tree - * @compat: compatiable string to match + * @compat: compatible string to match * @compat_off: property name * */
Applied to u-boot-dm, thanks!
Hugo Villeneuve
