[U-Boot] [BUG] fs: fat: error when handling long file names
Hello Takahiro
I hope you have an idea what might be missing in the FAT file system support for long names.
When running the SCT I saw this error for the GetInfo functional test:
GetInfo() Basic Test - checkpoint3 -- PASS
E4F4F6A2-7538-4C79-AA3C-67184EC70E16
/home/supven01/work/sct_workspace/edk2/SctPkg/TestCase/UEFI/EFI/Protocol/SimpleFileSystem/BlackBoxTest/SimpleFileSystemBBTestFunction.c:8607: SystemInfo->Size - 18, BufferSize - 18, Tpl - 8
EFI: Entry efi_file_open(000000007ef8c250, 000000007edeb0c0, "BBTestGetInfoBasicTestCheckpoint3_File_0", 8000000000000003, 0) Error: allocating new dir entry
EFI: Exit: efi_file_open: 14
EFI: Entry efi_file_open(000000007ef8c250, 000000007edeb0c8, "BBTestGetInfoBasicTestCheckpoint3_File_1", 8000000000000003, 0) Error: allocating new dir entry
In the EFI shell output to a file with a long name sometimes fails (depending on the history of the volume).
FS0:> echo a > foo FS0:> echo a > abcdefgh.ijk FS0:> echo a > abcdefgh.ijkl ** Unable to write file /abcdefgh.ijkl ** FS0:>
Up to now the SCT test is the only thing that fails reproducibly.
I use this repo for building: https://github.com/xypron/u-boot-build/tree/qemu-arm64
make sct-prepare make sct
Best regards
Heinrich
Heinrich,
On Tue, Jun 18, 2019 at 09:00:56PM +0200, Heinrich Schuchardt wrote:
Hello Takahiro
If this happens again, can you send me the binary of the file system? Probably the first 1MB will be enough if you don't have lots of files/directories on it. This will help me analyze the volume's header.
SCT will create bunch of files and the logs can be quite big. It's kinda stress test.
-Takahiro Akashi
Best regards
Heinrich
AKASHI, Takahiro
