[U-Boot] [PATCH] dm: ti_qspi: Fix conversion of address to a pointer
TI QSPI driver directly typecasts fdt_addr_t to a pointer. This is not strictly correct, as it gives a build warning when fdt_addr_t is u64. So, use map_physmem for a proper typecasts.
This is inspired by commit 167efe01bc5a9 ("dm: ns16550: Use an address instead of a pointer for the uart base")
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- drivers/spi/ti_qspi.c | 10 +++++++--- 1 file changed, 7 insertions(+), 3 deletions(-)
diff --git a/drivers/spi/ti_qspi.c b/drivers/spi/ti_qspi.c index 409a5c4..e69ec0d 100644 --- a/drivers/spi/ti_qspi.c +++ b/drivers/spi/ti_qspi.c @@ -534,11 +534,15 @@ static int ti_qspi_ofdata_to_platdata(struct udevice *bus) const void *blob = gd->fdt_blob; int node = bus->of_offset; fdt_addr_t addr; + void *mmap;
- priv->base = (struct ti_qspi_regs *)dev_get_addr(bus); - priv->memory_map = (void *)dev_get_addr_index(bus, 1); + priv->base = map_physmem(dev_get_addr(bus), sizeof(struct ti_qspi_regs), + MAP_NOCACHE); + priv->memory_map = map_physmem(dev_get_addr_index(bus, 1), 0, + MAP_NOCACHE); addr = dev_get_addr_index(bus, 2); - priv->ctrl_mod_mmap = (addr == FDT_ADDR_T_NONE) ? NULL : (void *)addr; + mmap = map_physmem(dev_get_addr_index(bus, 2), 0, MAP_NOCACHE); + priv->ctrl_mod_mmap = (addr == FDT_ADDR_T_NONE) ? NULL : mmap;
priv->max_hz = fdtdec_get_int(blob, node, "spi-max-frequency", -1); if (priv->max_hz < 0) {
Reviewed-by: Jagan Teki jteki@openedev.com
thanks! -- Jagan.
Reviewed-by: Mugunthan V N mugunthanvnm@ti.com
Regards Mugunthan V N
Jagan Teki
Lokesh Vutla
Mugunthan V N
