[U-Boot] [PATCH 00/10] Add Marvell Dove and SolidRun CuBox
This patch set add support for the Marvell Dove 88AP510 SoC and the SolidRun CuBox board based on that SoC. The patch set is divided into the four following sections:
(1) Patches 1-5: Add support for the Dove SoC and related drivers. Where possible drivers from Marvell Kirkwood are reused (mvsata, mvgbe), or forked to allow more generic usage (SPI, GPIO). The SDHCI driver is different and a new driver is added for it. The forked drivers can also be reused on Kirkwood but that would have required patching existing boards.
(2) Patches 6-8: Allow mvgbe to use the phylib API, add support for 88E1310 PHY and allow Dove to use the driver.
(3) Patch 9 Add the SolidRun CuBox as the first board based on Marvell Dove SoC.
(4) Patch 10 Add support for different UART boot mode found on Dove.
Sebastian Hesselbarth (10): ARM: dove: add support for Marvell Dove SoC GPIO: add gpio driver for Orion SoCs MMC: sdhci: Add support for dove sdhci SPI: Add Orion SPI driver block: mvsata: add dove include NET: phy: add 88E1310 PHY initialization NET: mvgbe: add phylib support NET: mvgbe: add support for Dove Boards: Add support for SolidRun CuBox tools: Add support for Dove to kwboot
arch/arm/cpu/armv7/dove/Makefile | 49 +++++ arch/arm/cpu/armv7/dove/cpu.c | 266 ++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/dram.c | 116 +++++++++++ arch/arm/cpu/armv7/dove/lowlevel_init.S | 83 ++++++++ arch/arm/cpu/armv7/dove/mpp.c | 319 +++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/timer.c | 176 +++++++++++++++++ arch/arm/cpu/armv7/dove/usb.c | 101 ++++++++++ arch/arm/include/asm/arch-dove/config.h | 153 +++++++++++++++ arch/arm/include/asm/arch-dove/cpu.h | 204 ++++++++++++++++++++ arch/arm/include/asm/arch-dove/dove.h | 93 +++++++++ arch/arm/include/asm/arch-dove/gpio.h | 35 ++++ arch/arm/include/asm/arch-dove/mpp.h | 283 +++++++++++++++++++++++++++ board/solidrun/cubox/Makefile | 45 +++++ board/solidrun/cubox/cubox.c | 141 ++++++++++++++ board/solidrun/cubox/kwbimage.cfg | 76 ++++++++ boards.cfg | 1 + drivers/block/mvsata_ide.c | 2 + drivers/gpio/Makefile | 1 + drivers/gpio/orion_gpio.c | 167 ++++++++++++++++ drivers/mmc/Makefile | 1 + drivers/mmc/dove_sdhci.c | 101 ++++++++++ drivers/net/mvgbe.c | 70 ++++++- drivers/net/mvgbe.h | 7 + drivers/net/phy/marvell.c | 48 +++++ drivers/spi/Makefile | 1 + drivers/spi/orion_spi.c | 217 +++++++++++++++++++++ include/configs/cubox.h | 175 +++++++++++++++++ include/orion_gpio.h | 64 +++++++ tools/Makefile | 2 + tools/kwboot.c | 44 ++++- 30 files changed, 3033 insertions(+), 8 deletions(-) create mode 100644 arch/arm/cpu/armv7/dove/Makefile create mode 100644 arch/arm/cpu/armv7/dove/cpu.c create mode 100644 arch/arm/cpu/armv7/dove/dram.c create mode 100644 arch/arm/cpu/armv7/dove/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/dove/mpp.c create mode 100644 arch/arm/cpu/armv7/dove/timer.c create mode 100644 arch/arm/cpu/armv7/dove/usb.c create mode 100644 arch/arm/include/asm/arch-dove/config.h create mode 100644 arch/arm/include/asm/arch-dove/cpu.h create mode 100644 arch/arm/include/asm/arch-dove/dove.h create mode 100644 arch/arm/include/asm/arch-dove/gpio.h create mode 100644 arch/arm/include/asm/arch-dove/mpp.h create mode 100644 board/solidrun/cubox/Makefile create mode 100644 board/solidrun/cubox/cubox.c create mode 100644 board/solidrun/cubox/kwbimage.cfg create mode 100644 drivers/gpio/orion_gpio.c create mode 100644 drivers/mmc/dove_sdhci.c create mode 100644 drivers/spi/orion_spi.c create mode 100644 include/configs/cubox.h create mode 100644 include/orion_gpio.h
--- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Dieter Kiermaier dk-arm-linux@gmx.de
This patch adds initial support for the armv7-based Marvell Dove SoC (88AP510).
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Dieter Kiermaier dk-arm-linux@gmx.de --- arch/arm/cpu/armv7/dove/Makefile | 49 +++++ arch/arm/cpu/armv7/dove/cpu.c | 266 ++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/dram.c | 116 +++++++++++ arch/arm/cpu/armv7/dove/lowlevel_init.S | 83 ++++++++ arch/arm/cpu/armv7/dove/mpp.c | 319 +++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/timer.c | 176 +++++++++++++++++ arch/arm/cpu/armv7/dove/usb.c | 101 ++++++++++ arch/arm/include/asm/arch-dove/config.h | 153 +++++++++++++++ arch/arm/include/asm/arch-dove/cpu.h | 204 ++++++++++++++++++++ arch/arm/include/asm/arch-dove/dove.h | 93 +++++++++ arch/arm/include/asm/arch-dove/gpio.h | 35 ++++ arch/arm/include/asm/arch-dove/mpp.h | 283 +++++++++++++++++++++++++++ 12 files changed, 1878 insertions(+) create mode 100644 arch/arm/cpu/armv7/dove/Makefile create mode 100644 arch/arm/cpu/armv7/dove/cpu.c create mode 100644 arch/arm/cpu/armv7/dove/dram.c create mode 100644 arch/arm/cpu/armv7/dove/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/dove/mpp.c create mode 100644 arch/arm/cpu/armv7/dove/timer.c create mode 100644 arch/arm/cpu/armv7/dove/usb.c create mode 100644 arch/arm/include/asm/arch-dove/config.h create mode 100644 arch/arm/include/asm/arch-dove/cpu.h create mode 100644 arch/arm/include/asm/arch-dove/dove.h create mode 100644 arch/arm/include/asm/arch-dove/gpio.h create mode 100644 arch/arm/include/asm/arch-dove/mpp.h
diff --git a/arch/arm/cpu/armv7/dove/Makefile b/arch/arm/cpu/armv7/dove/Makefile new file mode 100644 index 0000000..127d67e --- /dev/null +++ b/arch/arm/cpu/armv7/dove/Makefile @@ -0,0 +1,49 @@ +# +# Marvell Dove SoC Makefile +# +# Sebastian Hesselbarth sebastian.hesselbarth@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).o + +SOBJS += lowlevel_init.o +COBJS-y := cpu.o dram.o timer.o mpp.o +COBJS-$(CONFIG_USB_EHCI_MARVELL) += usb.o + +COBJS := $(COBJS-y) +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/arm/cpu/armv7/dove/cpu.c b/arch/arm/cpu/armv7/dove/cpu.c new file mode 100644 index 0000000..b9e708c --- /dev/null +++ b/arch/arm/cpu/armv7/dove/cpu.c @@ -0,0 +1,266 @@ +/* + * Marvell Dove SoC cpu related functions + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <netdev.h> +#include <asm/cache.h> +#include <u-boot/md5.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> +#include <hush.h> + +void reset_cpu(unsigned long ignored) +{ + struct dovecpu_registers *cpureg = + (struct dovecpu_registers *)DOVE_CPU_REG_BASE; + + /* Enable soft reset to assert RSTOUTn */ + writel(readl(&cpureg->rstoutn_mask) | (1 << 2), + &cpureg->rstoutn_mask); + /* Assert soft reset */ + writel(readl(&cpureg->sys_soft_rst) | 1, + &cpureg->sys_soft_rst); + do {} while (1); +} + +#if defined(CONFIG_DISPLAY_CPUINFO) +int dove_print_cpu(void) +{ + char *cpu; + u32 idreg; + u16 part, rev; + + __asm__ __volatile__("mrc p15, 0, %0, c0, c0, 0" : "=r"(idreg)); + + part = (idreg >> ARM_ID_PARTNUM_OFFSET) & ARM_ID_PARTNUM_MASK; + rev = (idreg >> ARM_ID_REVISION_OFFSET) & ARM_ID_REVISION_MASK; + + switch (part) { + case DOVECPU_PART_SHEEVA: + cpu = "Marvell Sheeva"; + break; + default: + cpu = "Unknown CPU"; + } + + printf("CPU: %s (rev %d)\n", cpu, rev); + return 0; +} + +int dove_print_soc(void) +{ + char *soc, *rev; + u16 devid = (readl(DOVE_REG_PCIE_DEVID) >> 16) & 0xffff; + u8 revid = readl(DOVE_REG_PCIE_REVID) & 0xff; + + switch (devid) { + case DOVESOC_DEVID_AP510: + soc = "AP510"; + break; + case DOVESOC_DEVID_F6781: + soc = "F6781"; + break; + default: + printf("ERROR.. %s: Unsupported SoC %04x\n", __func__, devid); + return -1; + } + + switch (revid) { + case DOVESOC_REVID_Z0: + rev = "Z0"; + break; + case DOVESOC_REVID_Z1: + rev = "Z1"; + break; + case DOVESOC_REVID_Y0: + rev = "Y0"; + break; + case DOVESOC_REVID_Y1: + rev = "Y1"; + break; + case DOVESOC_REVID_X0: + rev = "X0"; + break; + case DOVESOC_REVID_A0: + rev = "A0"; + break; + case DOVESOC_REVID_A1: + rev = "A1"; + break; + default: + rev = "Unknown revision"; + }; + + printf("SoC: Dove 88%s (%s)\n", soc, rev); + return 0; +} + +int print_cpuinfo(void) +{ + if (dove_print_soc()) + return -1; + if (dove_print_cpu()) + return -1; + return 0; +} +#endif /* CONFIG_DISPLAY_CPUINFO */ + +/* + * dove_init_gpio - initial GPIO configuration + */ +void dove_init_gpio(struct dove_gpio_init *gpp) +{ + struct dovegpio_registers *gpio0reg = + (struct dovegpio_registers *)DOVE_GPIO0_BASE; + struct dovegpio_registers *gpio1reg = + (struct dovegpio_registers *)DOVE_GPIO1_BASE; + struct dovegpio_registers *gpio2reg = + (struct dovegpio_registers *)DOVE_GPIO2_BASE; + + /* Init GPIOS to default values as per board requirement */ + writel(gpp->val0, &gpio0reg->dout); + writel(gpp->val1, &gpio1reg->dout); + writel(gpp->val2, &gpio2reg->dout); + writel(gpp->oe0_n, &gpio0reg->oe); + writel(gpp->oe1_n, &gpio1reg->oe); + writel(gpp->oe2_n, &gpio2reg->oe); +} + +/* + * Window Size + * Used with the Base register to set the address window size and location. + * Must be programmed from LSB to MSB as sequence of ones followed by + * sequence of zeros. The number of ones specifies the size of the window in + * 64 KByte granularity (e.g., a value of 0x00FF specifies 256 = 16 MByte). + * NOTE: A value of 0x0 specifies 64-KByte size. + */ +unsigned int dove_winctrl_calcsize(unsigned int sizeval) +{ + int i; + unsigned int j = 0; + u32 val = sizeval >> 1; + + for (i = 0; val >= 0x10000; i++) { + j |= (1 << i); + val = val >> 1; + } + return 0x0000ffff & j; +} + +/* + * dove_config_adr_windows - Configure address Windows + * + * There are 8 address windows supported by Dove Soc to addess different + * devices. Windows 0-3 can be configured for size, BAR and remap addr. + * Windows 4-7 can be configured for size and BAR. + * Below configuration is standard for most of the cases + * + * If remap function not used, remap_lo must be set as base + */ +int dove_config_adr_windows(void) +{ + struct dovewin_registers *winregs = + (struct dovewin_registers *)DOVE_CPU_WIN_BASE; + + /* Window 0: 1M PCIE0 IO address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_1M, DOVECPU_TARGET_PCIE0, + DOVECPU_ATTR_PCIE_IO, DOVECPU_WIN_ENABLE), &winregs[0].ctrl); + + writel(DOVE_DEFADR_PCIE0_IO, &winregs[0].base); + writel(DOVE_DEFADR_PCIE0_IO_REMAP, &winregs[0].remap_lo); + writel(0x0, &winregs[0].remap_hi); + + /* Window 1: 1M PCIE1 IO address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_1M, DOVECPU_TARGET_PCIE1, + DOVECPU_ATTR_PCIE_IO, DOVECPU_WIN_ENABLE), &winregs[1].ctrl); + + writel(DOVE_DEFADR_PCIE1_IO, &winregs[1].base); + writel(DOVE_DEFADR_PCIE1_IO_REMAP, &winregs[1].remap_lo); + writel(0x0, &winregs[1].remap_hi); + + /* Window 2: 128M PCIE0 MEM address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_128M, DOVECPU_TARGET_PCIE0, + DOVECPU_ATTR_PCIE_MEM, DOVECPU_WIN_ENABLE), &winregs[2].ctrl); + + writel(DOVE_DEFADR_PCIE0_MEM, &winregs[2].base); + writel(DOVE_DEFADR_PCIE0_MEM, &winregs[2].remap_lo); + writel(0x0, &winregs[2].remap_hi); + + /* Window 3: 128M PCIE1 MEM address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_128M, DOVECPU_TARGET_PCIE1, + DOVECPU_ATTR_PCIE_MEM, DOVECPU_WIN_ENABLE), &winregs[3].ctrl); + + writel(DOVE_DEFADR_PCIE1_MEM, &winregs[3].base); + writel(DOVE_DEFADR_PCIE1_MEM, &winregs[3].remap_lo); + writel(0x0, &winregs[3].remap_hi); + + /* Window 4: 1M Cryptographic SRAM address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_1M, DOVECPU_TARGET_SASRAM, + DOVECPU_ATTR_SASRAM, DOVECPU_WIN_ENABLE), &winregs[4].ctrl); + writel(DOVE_DEFADR_SASRAM, &winregs[4].base); + + /* Window 5: 128M Bootrom address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_128M, DOVECPU_TARGET_BOOTROM, + DOVECPU_ATTR_BOOTROM, DOVECPU_WIN_ENABLE), &winregs[5].ctrl); + writel(DOVE_DEFADR_BOOTROM, &winregs[5].base); + + /* Window 6: 1M PMU Scratchpad address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_1M, DOVECPU_TARGET_PMURAM, + DOVECPU_ATTR_PMURAM, DOVECPU_WIN_ENABLE), &winregs[6].ctrl); + writel(DOVE_DEFADR_PMURAM, &winregs[6].base); + + /* Window 7: Disabled */ + writel(DOVECPU_WIN_DISABLE, &winregs[7].ctrl); + + return 0; +} + +#ifdef CONFIG_ARCH_CPU_INIT +int arch_cpu_init(void) +{ + dove_config_adr_windows(); +#ifdef CONFIG_USB_EHCI_MARVELL + dove_ehci_phy_init(0); + dove_ehci_phy_init(1); +#endif /* CONFIG_USB_EHCI_MARVELL */ + return 0; +} +#endif /* CONFIG_ARCH_CPU_INIT */ + +void enable_caches(void) +{ +#ifndef CONFIG_SYS_DCACHE_OFF + /* Enable D-cache. I-cache is already enabled in lowlevel_init.S */ + dcache_enable(); +#endif /* CONFIG_SYS_DCACHE_OFF */ +} + +#ifdef CONFIG_MVGBE +int cpu_eth_init(bd_t *bis) +{ + mvgbe_initialize(bis); + return 0; +} +#endif /* CONFIG_MVGBE */ diff --git a/arch/arm/cpu/armv7/dove/dram.c b/arch/arm/cpu/armv7/dove/dram.c new file mode 100644 index 0000000..f5e8246 --- /dev/null +++ b/arch/arm/cpu/armv7/dove/dram.c @@ -0,0 +1,116 @@ +/* + * Marvell Dove SoC DRAM initialization + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <config.h> +#include <common.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define DOVE_REG_DRAM_MAP(x) (DOVE_REGISTER(0x800100) + (x * 0x10)) +#define DRAM_START_MASK 0xff800000 +#define DRAM_SIZE_MASK 0xf +#define DRAM_SIZE_SHIFT 16 + +/* + * dove_sdram_start - reads start from Memory Address Map Register n + */ +u32 dove_dram_start(enum memory_bank bank) +{ + u32 reg = readl(DOVE_REG_DRAM_MAP(bank)); + u32 enable = 0x01 & reg; + + if ((!enable) || (bank > BANK1)) + return 0; + + return reg & DRAM_START_MASK; +} + +/* + * dove_sdram_size - reads size from Memory Address Map Register n + */ +u32 dove_dram_size(enum memory_bank bank) +{ + u32 reg = readl(DOVE_REG_DRAM_MAP(bank)); + u32 enable = 0x01 & reg; + u32 size; + + if ((!enable) || (bank > BANK1)) + return 0; + + /* + * area_length: 7 = 8M, 8 = 16M, ..., 15 = 2048M + * size = 1 << (area_length + 16) + */ + size = (reg >> DRAM_SIZE_SHIFT) & DRAM_SIZE_MASK; + size = 1 << (size + 16); + return size; +} + +#ifndef CONFIG_SYS_BOARD_DRAM_INIT +int dram_init(void) +{ + int i; + + gd->ram_size = 0; + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + gd->bd->bi_dram[i].start = dove_dram_start(i); + gd->bd->bi_dram[i].size = dove_dram_size(i); + + /* + * It is assumed that all memory banks are consecutive + * and without gaps. + * If the gap is found, ram_size will be reported for + * consecutive memory only + */ + if (gd->bd->bi_dram[i].start != gd->ram_size) + break; + + gd->ram_size += gd->bd->bi_dram[i].size; + + } + + for (; i < CONFIG_NR_DRAM_BANKS; i++) { + /* If above loop terminated prematurely, we need to set + * remaining banks' start address & size as 0. Otherwise other + * u-boot functions and Linux kernel gets wrong values which + * could result in crash */ + gd->bd->bi_dram[i].start = 0; + gd->bd->bi_dram[i].size = 0; + } + + return 0; +} + +/* + * If this function is not defined here, + * board.c alters dram bank zero configuration defined above. + */ +void dram_init_banksize(void) +{ + dram_init(); +} +#endif /* CONFIG_SYS_BOARD_DRAM_INIT */ diff --git a/arch/arm/cpu/armv7/dove/lowlevel_init.S b/arch/arm/cpu/armv7/dove/lowlevel_init.S new file mode 100644 index 0000000..105d12d --- /dev/null +++ b/arch/arm/cpu/armv7/dove/lowlevel_init.S @@ -0,0 +1,83 @@ +/* + * Marvell Dove SoC icache and reg base low level init + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm/arch/dove.h> +#include <generated/asm-offsets.h> +#include <linux/linkage.h> + +/* + * Enable Tauros2 L2 ICache + */ +.macro init_l2cc + mrc 15, 0, r0, c1, c0, 1 + orr r0, r0, #0x2 + mcr 15, 0, r0, c1, c0, 1 +.endm /* init_l2cc */ + +/* + * Init internal register base addresses + */ +.macro init_reg_base + /* set SB reg base to 0xf1000000 */ + ldr r1, =(DOVE_PREMAP_INT_REGS_BASE_ADDR) + ldr r6, =DOVE_SB_REGS_PHYS_BASE + str r6, [r1] + + /* set NB reg base to 0xf1800000 */ + ldr r1, =(DOVE_CPU_CTRL_REG) + ldr r4, =0xffff0000 + ldr r6, [r1] + and r6, r6, r4 + ldr r4, =DOVE_NB_REGS_PHYS_BASE + lsr r4, r6, #16 + orr r6, r6, r4 + str r6, [r1] + + /* Set AXI bridge address mapping to 0xf1800000 */ + ldr r1, =(DOVE_AXI_CTRL_REG) + ldr r4, =0x007fffff + ldr r6, [r1] + and r6, r6, r4 + ldr r4, =DOVE_NB_REGS_PHYS_BASE + orr r6, r6, r4 + str r6, [r1] + + /* set MC configuration register decode address to 0xf1800000 */ + ldr r1, =(DOVE_PREMAP_MC_DECODE_REG) + ldr r4, =0x0000ffff + ldr r6, [r1] + and r6, r6, r4 + ldr r4, =DOVE_NB_REGS_PHYS_BASE + orr r6, r6, r4 + str r6, [r1] + +.endm /* init_reg_base */ + +.section ".text.init", "x" + +ENTRY(lowlevel_init) + init_l2cc + init_reg_base + + /* r12 saved upper lr*/ + mov pc,lr +ENDPROC(lowlevel_init) diff --git a/arch/arm/cpu/armv7/dove/mpp.c b/arch/arm/cpu/armv7/dove/mpp.c new file mode 100644 index 0000000..6722858 --- /dev/null +++ b/arch/arm/cpu/armv7/dove/mpp.c @@ -0,0 +1,319 @@ +/* + * Marvell Dove SoC MPP pinmux + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> +#include <asm/arch/mpp.h> +#include <asm/arch/gpio.h> + +#define MPP_BITS 4 +#define MPP_MASK 0xf +#define MPPS_PER_REG 8 + +#define MPP_NUM(_x) ((_x) & 0xff) +#define MPP_SEL(_x) (((_x) >> 8) & 0x1f) +#define MPP_GPIO(_x) ((_x) & (1 << 15)) + +#define MPP_CTRL(i) (DOVE_MPP_BASE + (i * MPP_BITS)) +#define MPP_PMU_GENERAL_CTRL (DOVE_MPP_BASE + 0x010) +#define PMUG_AUDIO0_AC97_SEL (1 << 16) +#define MPP4_CTRL (DOVE_MPP_BASE + 0x240) +#define MPP4_SDIO0_GPIO_SEL (1 << 0) +#define MPP4_SDIO1_GPIO_SEL (1 << 1) +#define MPP4_CAMERA_GPIO_SEL (1 << 2) +#define MPP4_AUDIO1_GPIO_SEL (1 << 3) +#define MPP4_UART1_GPIO_SEL (1 << 4) +#define MPP4_SPI_GPIO_SEL (1 << 5) +#define MPP_GENERAL_CTRL (DOVE_PDMA_BASE + 0x403c) +#define MPPG_NAND_GPIO_SEL (1 << 0) +#define MPPG_AUDIO1_SPDIFO_GPIO_SEL (1 << 1) +#define GENERAL_CONFIG_1 (DOVE_PDMA_BASE + 0x002c) +#define GENERAL_TWSI_MUXEN_OPTION1 (1 << 7) +#define GENERAL_CONFIG_2 (DOVE_PDMA_BASE + 0x0030) +#define GENERAL_TWSI_OPTION3_SEL (1 << 22) +#define GENERAL_TWSI_MUXEN_OPTION3 (1 << 21) +#define GENERAL_TWSI_MUXEN_OPTION2 (1 << 20) +#define SSP_CONFIG_STATUS_1 (DOVE_PDMA_BASE + 0x0034) +#define SSP_SSP_ON_AUDIO1 (1 << 0) + +/* + * MPP0-23 have standard MPP register layout + */ +static void dove_mpp_std_set(u16 config) +{ + u8 num = MPP_NUM(config); + u32 off = (num / MPPS_PER_REG) * MPP_BITS; + u32 shift = (num % MPPS_PER_REG) * MPP_BITS; + u32 reg; + + /* configure standard MPP pin */ + reg = readl(MPP_CTRL(off)); + reg &= ~(MPP_MASK << shift); + reg |= MPP_SEL(config) << shift; + writel(reg, MPP_CTRL(off)); + + /* configure gpio capabilities */ + if (MPP_GPIO(config)) + orion_gpio_set_valid(num, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + else + orion_gpio_set_valid(num, 0); +} + +/* + * MPP0-15 also allow to mux PMU functions + */ +static void dove_mpp_pmu_set(u16 config) +{ + u8 num = MPP_NUM(config); + + if (MPP_SEL(config) == PMU) { + /* enable PMU on MPP */ + writel(readl(MPP_PMU_GENERAL_CTRL) | (1 << num), + MPP_PMU_GENERAL_CTRL); + /* disable gpio capabilities */ + orion_gpio_set_valid(num, 0); + } else { + /* disable PMU on MPP */ + writel(readl(MPP_PMU_GENERAL_CTRL) & ~(1 << num), + MPP_PMU_GENERAL_CTRL); + /* configure MPP */ + dove_mpp_std_set(config); + } +} + +/* + * MPP groups on MPP4_CTRL have different register layout + * and allow GPIO or special function only + */ +static void dove_mpp4_set(u16 config) +{ + u32 reg = readl(MPP4_CTRL); + u32 mask; + u8 n, nmin, nmax; + int gpio; + + switch (MPP_NUM(config)) { + case MPP_CAMERA: + mask = MPP4_CAMERA_GPIO_SEL; + nmin = MPP_CAMERA; + nmax = MPP_CAMERA_MAX; + break; + case MPP_SDIO0: + mask = MPP4_SDIO0_GPIO_SEL; + nmin = MPP_SDIO0; + nmax = MPP_SDIO0_MAX; + break; + case MPP_SDIO1: + mask = MPP4_SDIO1_GPIO_SEL; + nmin = MPP_SDIO1; + nmax = MPP_SDIO1_MAX; + break; + case MPP_SPI: + mask = MPP4_SPI_GPIO_SEL; + nmin = MPP_SPI; + nmax = MPP_SPI_MAX; + break; + case MPP_UART1: + mask = MPP4_UART1_GPIO_SEL; + nmin = MPP_UART1; + nmax = MPP_UART1_MAX; + break; + default: + return; + } + + reg &= ~mask; + if (MPP_SEL(config)) + reg |= mask; + writel(reg, MPP4_CTRL); + + /* configure gpio capabilities */ + gpio = 0; + if (MPP_GPIO(config)) + gpio = GPIO_INPUT_OK | GPIO_OUTPUT_OK; + for (n = nmin; n <= nmax; n++) + orion_gpio_set_valid(n, gpio); +} + +/* + * MPP_GENERAL_CTRL allows GPIO on NAND pins + */ +static void dove_mpp_nand_set(u16 config) +{ + u32 reg = readl(MPP_GENERAL_CTRL); + u8 n; + int gpio; + + reg &= ~MPPG_NAND_GPIO_SEL; + if (config == MPP_NAND_GPO) + reg |= MPPG_NAND_GPIO_SEL; + writel(reg, MPP_GENERAL_CTRL); + + /* configure gpio capabilities */ + gpio = (config == MPP_NAND_GPO) ? GPIO_OUTPUT_OK : 0; + for (n = MPP_NAND; n <= MPP_NAND_MAX; n++) + orion_gpio_set_valid(n, gpio); +} + +/* + * Dedicated audio1 pins can carry i2s, spdif, ssp or twsi + * and gpio in various combinations + */ +#define AUDIO1_TWSI (1 << 0) +#define AUDIO1_SPDIFO (1 << 1) +#define AUDIO1_SSP (1 << 2) +#define AUDIO1_GPIO (1 << 3) + +static void dove_mpp_audio1_set(u16 config) +{ + u32 mpp4 = readl(MPP4_CTRL); + u32 sspc1 = readl(SSP_CONFIG_STATUS_1); + u32 gmpp = readl(MPP_GENERAL_CTRL); + u32 gcfg2 = readl(GENERAL_CONFIG_2); + u8 n, sel = MPP_SEL(config); + int gpio; + + gcfg2 &= ~GENERAL_TWSI_OPTION3_SEL; + gmpp &= ~MPPG_AUDIO1_SPDIFO_GPIO_SEL; + sspc1 &= ~SSP_SSP_ON_AUDIO1; + mpp4 &= ~MPP4_AUDIO1_GPIO_SEL; + if (sel & AUDIO1_TWSI) + gcfg2 |= GENERAL_TWSI_OPTION3_SEL; + if (sel & AUDIO1_SPDIFO) + gmpp |= MPPG_AUDIO1_SPDIFO_GPIO_SEL; + if (sel & AUDIO1_SSP) + sspc1 |= SSP_SSP_ON_AUDIO1; + if (sel & AUDIO1_GPIO) + mpp4 |= MPP4_AUDIO1_GPIO_SEL; + + writel(mpp4, MPP4_CTRL); + writel(sspc1, SSP_CONFIG_STATUS_1); + writel(gmpp, MPP_GENERAL_CTRL); + writel(gcfg2, GENERAL_CONFIG_2); + + /* configure gpio capabilities */ + /* gpio allows gpio on all audio1 mpp pins */ + gpio = 0; + if (config == MPP_AUDIO1_GPIO) + gpio = GPIO_INPUT_OK | GPIO_OUTPUT_OK; + + for (n = MPP_AUDIO1; n <= MPP_AUDIO1_MAX; n++) + orion_gpio_set_valid(n, gpio); + + switch (config) { + /* spdifo and twsi allow gpio on mpp[52:55] */ + case MPP_AUDIO1_SPDIFO: + case MPP_AUDIO1_TWSI: + orion_gpio_set_valid(52, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + orion_gpio_set_valid(53, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + orion_gpio_set_valid(54, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + orion_gpio_set_valid(55, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + break; + /* i2s and ssp allow gpio on mpp[56:57] */ + case MPP_AUDIO1_I2S: + case MPP_AUDIO1_SSP: + orion_gpio_set_valid(56, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + orion_gpio_set_valid(57, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + break; + } +} + +/* + * MPP PMU switches audio0 pins to ac97 or i2s0 + */ +static void dove_mpp_audio0_set(u16 config) +{ + /* switch i2s or ac97 to audio0 */ + u32 reg = readl(MPP_PMU_GENERAL_CTRL); + + reg &= ~PMUG_AUDIO0_AC97_SEL; + if (config == MPP_AUDIO0_AC97) + reg |= PMUG_AUDIO0_AC97_SEL; + writel(reg, MPP_PMU_GENERAL_CTRL); +} + +/* + * TWSI has 3 optional pin sets that can be switched during runtime + */ +static void dove_mpp_twsi_set(u16 config) +{ + u32 gcfg1 = readl(GENERAL_CONFIG_1); + u32 gcfg2 = readl(GENERAL_CONFIG_2); + + gcfg1 &= ~GENERAL_TWSI_MUXEN_OPTION1; + gcfg2 &= ~(GENERAL_TWSI_MUXEN_OPTION2 | GENERAL_TWSI_MUXEN_OPTION3); + + switch (config) { + case MPP_TWSI_OPTION1: + gcfg1 |= GENERAL_TWSI_MUXEN_OPTION1; + break; + case MPP_TWSI_OPTION2: + gcfg2 |= GENERAL_TWSI_MUXEN_OPTION2; + break; + case MPP_TWSI_OPTION3: + gcfg2 |= GENERAL_TWSI_MUXEN_OPTION3; + break; + } + + writel(gcfg1, GENERAL_CONFIG_1); + writel(gcfg2, GENERAL_CONFIG_2); +} + +void dove_mpp_conf(u16 *mpp_list) +{ + while (*mpp_list) { + u8 num = MPP_NUM(*mpp_list); + + if (num <= MPP_PMU_MAX) + dove_mpp_pmu_set(*mpp_list); + else if (num <= MPP_STD_MAX) + dove_mpp_std_set(*mpp_list); + else { + switch (num) { + case MPP_CAMERA: + case MPP_SDIO0: + case MPP_SDIO1: + case MPP_SPI: + case MPP_UART1: + dove_mpp4_set(*mpp_list); + break; + case MPP_NAND: + dove_mpp_nand_set(*mpp_list); + break; + case MPP_AUDIO0: + dove_mpp_audio0_set(*mpp_list); + break; + case MPP_AUDIO1: + dove_mpp_audio1_set(*mpp_list); + break; + case MPP_TWSI: + dove_mpp_twsi_set(*mpp_list); + break; + } + } + mpp_list++; + } +} diff --git a/arch/arm/cpu/armv7/dove/timer.c b/arch/arm/cpu/armv7/dove/timer.c new file mode 100644 index 0000000..3be9b78 --- /dev/null +++ b/arch/arm/cpu/armv7/dove/timer.c @@ -0,0 +1,176 @@ +/* + * Marvell Dove SoC timer + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/dove.h> + +#define UBOOT_CNTR 0 /* counter to use for uboot timer */ + +/* Timer reload and current value registers */ +struct dovetmr_val { + u32 reload; /* Timer reload reg */ + u32 val; /* Timer value reg */ +}; + +/* Timer registers */ +struct dovetmr_registers { + u32 ctrl; /* Timer control reg */ + u32 pad[3]; + struct dovetmr_val tmr[2]; + u32 wdt_reload; + u32 wdt_val; +}; + +struct dovetmr_registers *dovetmr_regs = + (struct dovetmr_registers *)DOVE_TIMER_BASE; + +/* + * ARM Timers Registers Map + */ +#define CNTMR_CTRL_REG &dovetmr_regs->ctrl +#define CNTMR_RELOAD_REG(tmrnum) &dovetmr_regs->tmr[tmrnum].reload +#define CNTMR_VAL_REG(tmrnum) &dovetmr_regs->tmr[tmrnum].val + +/* + * ARM Timers Control Register + * CPU_TIMERS_CTRL_REG (CTCR) + */ +#define CTCR_ARM_TIMER_EN_OFFS(cntr) (cntr * 2) +#define CTCR_ARM_TIMER_EN_MASK(cntr) (1 << CTCR_ARM_TIMER_EN_OFFS) +#define CTCR_ARM_TIMER_EN(cntr) (1 << CTCR_ARM_TIMER_EN_OFFS(cntr)) +#define CTCR_ARM_TIMER_DIS(cntr) (0 << CTCR_ARM_TIMER_EN_OFFS(cntr)) + +#define CTCR_ARM_TIMER_AUTO_OFFS(cntr) ((cntr * 2) + 1) +#define CTCR_ARM_TIMER_AUTO_MASK(cntr) (1 << 1) +#define CTCR_ARM_TIMER_AUTO_EN(cntr) (1 << CTCR_ARM_TIMER_AUTO_OFFS(cntr)) +#define CTCR_ARM_TIMER_AUTO_DIS(cntr) (0 << CTCR_ARM_TIMER_AUTO_OFFS(cntr)) + +/* + * ARM Timer\Watchdog Reload Register + * CNTMR_RELOAD_REG (TRR) + */ +#define TRG_ARM_TIMER_REL_OFFS 0 +#define TRG_ARM_TIMER_REL_MASK 0xffffffff + +/* + * ARM Timer\Watchdog Register + * CNTMR_VAL_REG (TVRG) + */ +#define TVR_ARM_TIMER_OFFS 0 +#define TVR_ARM_TIMER_MASK 0xffffffff +#define TVR_ARM_TIMER_MAX 0xffffffff +#define TIMER_LOAD_VAL 0xffffffff + +#define READ_TIMER (readl(CNTMR_VAL_REG(UBOOT_CNTR)) / \ + (CONFIG_SYS_TCLK / 1000)) + +DECLARE_GLOBAL_DATA_PTR; + +#define timestamp gd->tbl +#define lastdec gd->lastinc + +ulong get_timer_masked(void) +{ + ulong now = READ_TIMER; + + if (lastdec >= now) { + /* normal mode */ + timestamp += lastdec - now; + } else { + /* we have an overflow ... */ + timestamp += lastdec + + (TIMER_LOAD_VAL / (CONFIG_SYS_TCLK / 1000)) - now; + } + lastdec = now; + + return timestamp; +} + +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +void __udelay(unsigned long usec) +{ + uint current; + ulong delayticks; + + current = readl(CNTMR_VAL_REG(UBOOT_CNTR)); + delayticks = (usec * (CONFIG_SYS_TCLK / 1000000)); + + if (current < delayticks) { + delayticks -= current; + do {} while (readl(CNTMR_VAL_REG(UBOOT_CNTR)) < current); + do {} while ((TIMER_LOAD_VAL - delayticks) < + readl(CNTMR_VAL_REG(UBOOT_CNTR))); + } else { + do {} while (readl(CNTMR_VAL_REG(UBOOT_CNTR)) > + (current - delayticks)); + } +} + +/* + * init the counter + */ +int timer_init(void) +{ + unsigned int cntmrctrl; + + /* load value into timer */ + writel(TIMER_LOAD_VAL, CNTMR_RELOAD_REG(UBOOT_CNTR)); + writel(TIMER_LOAD_VAL, CNTMR_VAL_REG(UBOOT_CNTR)); + + /* enable timer in auto reload mode */ + cntmrctrl = readl(CNTMR_CTRL_REG); + cntmrctrl |= CTCR_ARM_TIMER_EN(UBOOT_CNTR); + cntmrctrl |= CTCR_ARM_TIMER_AUTO_EN(UBOOT_CNTR); + writel(cntmrctrl, CNTMR_CTRL_REG); + + /* init the timestamp and lastdec value */ + lastdec = READ_TIMER; + timestamp = 0; + + return 0; +} + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On ARM it just returns the timer value. + */ +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + return (ulong)CONFIG_SYS_HZ; +} diff --git a/arch/arm/cpu/armv7/dove/usb.c b/arch/arm/cpu/armv7/dove/usb.c new file mode 100644 index 0000000..1b932db --- /dev/null +++ b/arch/arm/cpu/armv7/dove/usb.c @@ -0,0 +1,101 @@ +/* + * Marvell Dove SoC USB PHY init + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> + +/* Dove USB2.0 PHY registers */ +#define USB20_POWER_CTRL ((base) + 0x400) +#define USB20_PHY_PLL_CTRL ((base) + 0x410) +#define PHY_PLL_VCO_RECALIBRATE (1 << 21) +#define USB20_PHY_TX_CTRL ((base) + 0x420) +#define PHY_TX_HS_STRESS_CTRL (1 << 31) +#define PHY_TX_BLOCK_EN (1 << 21) +#define PHY_TX_IMP_CAL_VTH(x) (x << 14) +#define PHY_TX_IMP_CAL_VTH_MASK PHY_TX_IMP_CAL_VTH(0x7) +#define PHY_TX_RCAL_START (1 << 12) +#define PHY_TX_LOWVDD_EN (1 << 11) +#define USB20_PHY_RX_CTRL ((base) + 0x430) +#define PHY_RX_EDGE_DET(x) (x << 26) +#define PHY_RX_EDGE_DET_MASK PHY_RX_EDGE_DET(0x3) +#define PHY_RX_CDR_FASTLOCK_EN (1 << 21) +#define PHY_RX_SQ_LENGTH(x) (x << 15) +#define PHY_RX_SQ_LENGTH_MASK PHY_RX_SQ_LENGTH(0x3) +#define PHY_RX_SQ_THRESH(x) (x << 4) +#define PHY_RX_SQ_THRESH_MASK PHY_RX_SQ_THRESH(0xf) +#define PHY_RX_LPF_COEFF(x) (x << 2) +#define PHY_RX_LPF_COEFF_MASK PHY_RX_LPF_COEFF(0x3) +#define USB20_PHY_IVREF_CTRL ((base) + 0x440) +#define PHY_IVREF_TXVDD12(x) (x << 8) +#define PHY_IVREF_TXVDD12_MASK PHY_IVREF_TXVDD12(0x3) +#define USB20_PHY_TESTGRP_CTRL ((base) + 0x450) +#define PHY_TESTGRP_SQ_RST (1 << 15) + +void dove_ehci_phy_init(int port) +{ + u32 base = (port == 0) ? DOVE_USB20_0_BASE : DOVE_USB20_1_BASE; + u32 reg; + + /* USB PHY PLL control */ + reg = readl(USB20_PHY_PLL_CTRL); + writel(reg | PHY_PLL_VCO_RECALIBRATE, USB20_PHY_PLL_CTRL); + udelay(100); + writel(reg & ~PHY_PLL_VCO_RECALIBRATE, USB20_PHY_PLL_CTRL); + + /* USB PHY Tx control */ + reg = readl(USB20_PHY_TX_CTRL); + reg &= ~PHY_TX_IMP_CAL_VTH_MASK; + reg |= PHY_TX_IMP_CAL_VTH(0x5); + reg |= PHY_TX_LOWVDD_EN; + reg |= PHY_TX_RCAL_START; + reg |= PHY_TX_BLOCK_EN; + reg |= PHY_TX_HS_STRESS_CTRL; + writel(reg, USB20_PHY_TX_CTRL); + udelay(100); + writel(reg & ~PHY_TX_RCAL_START, USB20_PHY_TX_CTRL); + + /* USB PHY RX control */ + reg = readl(USB20_PHY_RX_CTRL); + reg &= ~(PHY_RX_LPF_COEFF_MASK | PHY_RX_SQ_THRESH_MASK | + PHY_RX_SQ_LENGTH_MASK | PHY_RX_EDGE_DET_MASK); + reg |= PHY_RX_LPF_COEFF(0x1); + reg |= PHY_RX_SQ_THRESH(0xc); + reg |= PHY_RX_SQ_LENGTH(0x1); + reg |= PHY_RX_EDGE_DET(0x0); + reg &= ~PHY_RX_CDR_FASTLOCK_EN; + writel(reg, USB20_PHY_RX_CTRL); + + /* USB PHY IVREF control */ + reg = readl(USB20_PHY_IVREF_CTRL); + reg &= ~PHY_IVREF_TXVDD12_MASK; + reg |= PHY_IVREF_TXVDD12(0x3); + writel(reg, USB20_PHY_IVREF_CTRL); + + /* USB PHY TEST GROUP control */ + reg = readl(USB20_PHY_TESTGRP_CTRL); + reg &= ~PHY_TESTGRP_SQ_RST; + writel(reg, USB20_PHY_TESTGRP_CTRL); +} diff --git a/arch/arm/include/asm/arch-dove/config.h b/arch/arm/include/asm/arch-dove/config.h new file mode 100644 index 0000000..2d94a48 --- /dev/null +++ b/arch/arm/include/asm/arch-dove/config.h @@ -0,0 +1,153 @@ +/* + * Marvell SoC config + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVE_CONFIG_H +#define _DOVE_CONFIG_H + +#include <asm/arch/dove.h> + +#define CONFIG_ARMV7 /* Basic Architecture */ +#define CONFIG_DOVE /* SOC Family Name */ +#define CONFIG_SHEEVA_88SV581 /* CPU Core subversion */ +#define CONFIG_SYS_CACHELINE_SIZE 32 + /* default Dcache Line length for Dove */ +#define CONFIG_SYS_ARM_CACHE_WRITETHROUGH +#define CONFIG_SYS_DCACHE_OFF /* Disable DCache by default */ + +/* + * By default kwbimage.cfg from board specific folder is used + * If for some board, different configuration file need to be used, + * CONFIG_SYS_KWD_CONFIG should be defined in board specific header file + */ +#ifndef CONFIG_SYS_KWD_CONFIG +#define CONFIG_SYS_KWD_CONFIG $(SRCTREE)/$(CONFIG_BOARDDIR)/kwbimage.cfg +#endif /* CONFIG_SYS_KWD_CONFIG */ + +/* Dove has 2k of Security SRAM, use it for SP */ +#define CONFIG_SYS_INIT_SP_ADDR 0xC8012000 +#define CONFIG_NR_DRAM_BANKS_MAX 2 + +#define CONFIG_I2C_MVTWSI_BASE DOVE_TWSI_BASE +#define MV_UART_CONSOLE_BASE DOVE_UART0_BASE +#define MV_SATA_BASE DOVE_SATA_BASE +#define MV_SATA_PORT0_OFFSET DOVE_SATA_PORT0_OFFSET + +/* + * NAND configuration + */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_KIRKWOOD 1 +#define CONFIG_SYS_NAND_BASE 0xD8000000 /* MV_DEFADR_NANDF */ +#define NAND_ALLOW_ERASE_ALL 1 +#endif + +/* + * SPI Flash configuration + */ +#ifdef CONFIG_CMD_SF +#define CONFIG_HARD_SPI 1 +#define CONFIG_ORION_SPI 1 +#define ORION_SPI_BASE DOVE_SPI_BASE +#ifndef CONFIG_ENV_SPI_BUS +# define CONFIG_ENV_SPI_BUS 0 +#endif +#ifndef CONFIG_ENV_SPI_CS +# define CONFIG_ENV_SPI_CS 0 +#endif +#ifndef CONFIG_ENV_SPI_MAX_HZ +# define CONFIG_ENV_SPI_MAX_HZ 25000000 +#endif +#endif + +/* + * Ethernet Driver configuration + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_CMD_MII +#define CONFIG_NETCONSOLE /* include NetConsole support */ +#define CONFIG_PHYLIB +#define CONFIG_MVGBE /* Enable Marvell Gbe Controller Driver */ +#define CONFIG_SYS_FAULT_ECHO_LINK_DOWN /* detect link using phy */ +#define CONFIG_ENV_OVERWRITE /* ethaddr can be reprogrammed */ +#endif /* CONFIG_CMD_NET */ + +/* + * SDHCI + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_MMC +#define CONFIG_MMC_SDMA +#define CONFIG_SDHCI +#define CONFIG_DOVE_SDHCI /* Enable Dove SDHCI controller driver */ +#define CONFIG_MMC_SDHCI_IO_ACCESSORS +#define CONFIG_SYS_MMC_MAX_DEVICE 2 +#endif + +/* + * USB/EHCI + */ +#ifdef CONFIG_CMD_USB +#define CONFIG_USB_EHCI_MARVELL +#define CONFIG_EHCI_IS_TDI +#endif /* CONFIG_CMD_USB */ + +/* + * IDE Support on SATA ports + */ +#ifdef CONFIG_CMD_IDE +#define __io +#define CONFIG_CMD_EXT2 +#define CONFIG_MVSATA_IDE +#define CONFIG_IDE_PREINIT +#define CONFIG_MVSATA_IDE_USE_PORT1 +/* Needs byte-swapping for ATA data register */ +#define CONFIG_IDE_SWAP_IO +/* Data, registers and alternate blocks are at the same offset */ +#define CONFIG_SYS_ATA_DATA_OFFSET (0x0100) +#define CONFIG_SYS_ATA_REG_OFFSET (0x0100) +#define CONFIG_SYS_ATA_ALT_OFFSET (0x0100) +/* Each 8-bit ATA register is aligned to a 4-bytes address */ +#define CONFIG_SYS_ATA_STRIDE 4 +/* Controller supports 48-bits LBA addressing */ +#define CONFIG_LBA48 +/* CONFIG_CMD_IDE requires some #defines for ATA registers */ +#define CONFIG_SYS_IDE_MAXBUS 2 +#define CONFIG_SYS_IDE_MAXDEVICE 2 +/* ATA registers base is at SATA controller base */ +#define CONFIG_SYS_ATA_BASE_ADDR MV_SATA_BASE +#endif /* CONFIG_CMD_IDE */ + +/* + * I2C related stuff + */ +#ifdef CONFIG_CMD_I2C +#ifndef CONFIG_SOFT_I2C +#define CONFIG_I2C_MVTWSI +#endif +#define CONFIG_SYS_I2C_SLAVE 0x0 +#define CONFIG_SYS_I2C_SPEED 100000 +#endif + +#endif /* _DOVE_CONFIG_H */ diff --git a/arch/arm/include/asm/arch-dove/cpu.h b/arch/arm/include/asm/arch-dove/cpu.h new file mode 100644 index 0000000..718dd59 --- /dev/null +++ b/arch/arm/include/asm/arch-dove/cpu.h @@ -0,0 +1,204 @@ +/* + * Marvell Dove SoC CPU + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVECPU_H +#define _DOVECPU_H + +#include <asm/system.h> + +#ifndef __ASSEMBLY__ + +#define DOVECPU_WIN_CTRL_DATA(size, target, attr, en) (en | (target << 4) \ + | (attr << 8) | (dove_winctrl_calcsize(size) << 16)) + +#define DOVEGBE_PORT_SERIAL_CONTROL1_REG (DOVE_EGIGA_BASE + 0x44c) +#define DOVE_REG_PCIE_DEVID (DOVE_REG_PCIE0_BASE + 0x00) +#define DOVE_REG_PCIE_REVID (DOVE_REG_PCIE0_BASE + 0x08) +#define DOVE_REG_SYSRST_CNT (DOVE_MPP_BASE + 0x50) +#define SYSRST_CNT_1SEC_VAL (25*1000000) +#define DOVE_REG_MPP_OUT_DRV_REG (DOVE_MPP_BASE + 0xE0) + +enum memory_bank { + BANK0, + BANK1, +}; + +enum dovecpu_winen { + DOVECPU_WIN_DISABLE, + DOVECPU_WIN_ENABLE +}; + +enum dovecpu_target { + DOVECPU_TARGET_DRAM = 0x0, + DOVECPU_TARGET_SASRAM = 0x3, + DOVECPU_TARGET_NAND = 0xc, + DOVECPU_TARGET_PMURAM = 0xd, + DOVECPU_TARGET_PCIE0 = 0x4, + DOVECPU_TARGET_PCIE1 = 0x8, + DOVECPU_TARGET_SPI = 0x1, + DOVECPU_TARGET_BOOTROM = 0x1, +}; + +enum dovecpu_attrib { + DOVECPU_ATTR_DRAM = 0x00, + DOVECPU_ATTR_SASRAM = 0x00, + DOVECPU_ATTR_NAND = 0x00, + DOVECPU_ATTR_PMURAM = 0x00, + DOVECPU_ATTR_PCIE_IO = 0xe0, + DOVECPU_ATTR_PCIE_MEM = 0xe8, + DOVECPU_ATTR_SPI0 = 0xfe, + DOVECPU_ATTR_SPI1 = 0xfb, + DOVECPU_ATTR_BOOTROM = 0xfd, +}; + +enum dovecpu_part { + DOVECPU_PART_SHEEVA = 0x581, +}; + +enum dovesoc_devid { + DOVESOC_DEVID_F6781 = 0x6781, + DOVESOC_DEVID_AP510 = 0x0510, +}; + +enum dovesoc_revid { + DOVESOC_REVID_Z0 = 0, + DOVESOC_REVID_Z1 = 1, + DOVESOC_REVID_Y0 = 2, + DOVESOC_REVID_Y1 = 3, + DOVESOC_REVID_X0 = 4, + DOVESOC_REVID_A0 = 6, + DOVESOC_REVID_A1 = 7, +}; + +/* + * Default Device Address MAP BAR values + */ +#define DOVE_DEFADR_PCIE0_MEM 0xe0000000 +#define DOVE_DEFADR_PCIE0_IO 0xf2000000 +#define DOVE_DEFADR_PCIE0_IO_REMAP 0x00000000 +#define DOVE_DEFADR_PCIE1_MEM 0xe8000000 +#define DOVE_DEFADR_PCIE1_IO 0xf2100000 +#define DOVE_DEFADR_PCIE1_IO_REMAP 0x00100000 +#define DOVE_DEFADR_SASRAM 0xc8000000 +#define DOVE_DEFADR_BOOTROM 0xf8000000 +#define DOVE_DEFADR_PMURAM 0xf0000000 + +/* + * ARM CPUID register + */ +#define ARM_ID_REVISION_OFFSET 0 +#define ARM_ID_REVISION_MASK 0xf +#define ARM_ID_PARTNUM_OFFSET 4 +#define ARM_ID_PARTNUM_MASK 0xfff +#define ARM_ID_ARCH_OFFSET 16 +#define ARM_ID_ARCH_MASK 0xf +#define ARM_ID_VAR_OFFSET 20 +#define ARM_ID_VAR_MASK 0xf +#define ARM_ID_ASCII_OFFSET 24 +#define ARM_ID_ASCII_MASK 0xff + +/* + * read feroceon/sheeva core extra feature register + * using co-proc instruction + */ +static inline unsigned int readfr_extra_feature_reg(void) +{ + unsigned int val; + asm volatile ("mrc p15, 1, %0, c15, c1, 0 @ readfr exfr" : "=r" + (val) : : "cc"); + return val; +} + +/* + * write feroceon/sheeva core extra feature register + * using co-proc instruction + */ +static inline void writefr_extra_feature_reg(unsigned int val) +{ + asm volatile ("mcr p15, 1, %0, c15, c1, 0 @ writefr exfr" : : "r" + (val) : "cc"); + isb(); +} + +/* + * Downstream Bridge Registers + */ +struct dovewin_registers { + u32 ctrl; + u32 base; + u32 remap_lo; + u32 remap_hi; +}; + +/* + * CPU control and status Registers + */ +struct dovecpu_registers { + u32 config; /* 0x20100 */ + u32 ctrl_stat; /* 0x20104 */ + u32 rstoutn_mask; /* 0x20108 */ + u32 sys_soft_rst; /* 0x2010C */ + u32 bridge_cause_irq; /* 0x20110 */ + u32 bridge_mask_irq; /* 0x20114 */ + u32 pad1; + u32 pmu_ctrl; /* 0x2011c */ +}; + +/* + * GPIO 0/1 Registers + * GPIO 2 Registers (no datain/irq) + */ +struct dovegpio_registers { + u32 dout; + u32 oe; + u32 blink_en; + u32 din_pol; + u32 din; + u32 irq_cause; + u32 irq_mask; + u32 irq_level; +}; + +struct dove_gpio_init { + u32 val0; + u32 val1; + u32 val2; + u32 oe0_n; + u32 oe1_n; + u32 oe2_n; +}; + +/* + * functions + */ +void reset_cpu(unsigned long ignored); +unsigned char get_random_hex(void); +u32 dove_dram_start(enum memory_bank bank); +u32 dove_dram_size(enum memory_bank bank); +int dove_config_adr_windows(void); +void dove_init_gpio(struct dove_gpio_init *); +unsigned int dove_winctrl_calcsize(unsigned int sizeval); + +#endif /* __ASSEMBLY__ */ +#endif /* _DOVECPU_H */ diff --git a/arch/arm/include/asm/arch-dove/dove.h b/arch/arm/include/asm/arch-dove/dove.h new file mode 100644 index 0000000..da5011b --- /dev/null +++ b/arch/arm/include/asm/arch-dove/dove.h @@ -0,0 +1,93 @@ +/* + * Marvell Dove SoC register offsets and config + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVE_H +#define _DOVE_H + +/* Dove TCLK is fixed to 166MHz */ +#define CONFIG_SYS_TCLK 166666667 + +/* SOC specific definitions */ +#define DOVE_PREMAP_REGS_PHYS_BASE 0xd0000000 +#define DOVE_PREMAP_INT_REGS_BASE_ADDR (DOVE_PREMAP_REGS_PHYS_BASE + 0x20080) +#define DOVE_PREMAP_MC_DECODE_REG (DOVE_PREMAP_REGS_PHYS_BASE + 0x800010) + +#define DOVE_SB_REGS_PHYS_BASE 0xf1000000 +#define DOVE_NB_REGS_PHYS_BASE 0xf1800000 +#define DOVE_REGISTER(x) (DOVE_SB_REGS_PHYS_BASE + x) + +#define DOVE_AXI_CTRL_REG (DOVE_REGISTER(0xd0224)) +#define DOVE_CPU_CTRL_REG (DOVE_REGISTER(0xd025c)) +#define DOVE_MC_CTRL_REG (DOVE_REGISTER(0xd0260)) +#define DOVE_MC_DECODE_REG (DOVE_REGISTER(0x800010)) + +#define DOVE_SPI_BASE (DOVE_REGISTER(0x10600)) +#define DOVE_TWSI_BASE (DOVE_REGISTER(0x11000)) +#define DOVE_UART0_BASE (DOVE_REGISTER(0x12000)) +#define DOVE_UART1_BASE (DOVE_REGISTER(0x12100)) +#define DOVE_UART2_BASE (DOVE_REGISTER(0x12200)) +#define DOVE_UART3_BASE (DOVE_REGISTER(0x12300)) +#define DOVE_CPU_WIN_BASE (DOVE_REGISTER(0x20000)) +#define DOVE_CPU_REG_BASE (DOVE_REGISTER(0x20100)) +#define DOVE_TIMER_BASE (DOVE_REGISTER(0x20300)) +#define DOVE_REG_PCIE0_BASE (DOVE_REGISTER(0x40000)) +#define DOVE_REG_PCIE1_BASE (DOVE_REGISTER(0x80000)) +#define DOVE_USB20_0_BASE (DOVE_REGISTER(0x50000)) +#define DOVE_USB20_1_BASE (DOVE_REGISTER(0x51000)) +#define DOVE_EGIGA_BASE (DOVE_REGISTER(0x72000)) +#define DOVE_SDIO1_BASE (DOVE_REGISTER(0x90000)) +#define DOVE_SDIO0_BASE (DOVE_REGISTER(0x92000)) +#define DOVE_CAMERA_BASE (DOVE_REGISTER(0x94000)) +#define DOVE_SATA_BASE (DOVE_REGISTER(0xa0000)) +#define DOVE_NANDF_BASE (DOVE_REGISTER(0xc0000)) +#define DOVE_PMU_BASE (DOVE_REGISTER(0xd0000)) +#define DOVE_MPP_BASE (DOVE_REGISTER(0xd0200)) +#define DOVE_GPIO0_BASE (DOVE_REGISTER(0xd0400)) +#define DOVE_GPIO1_BASE (DOVE_REGISTER(0xd0420)) +#define DOVE_RTC_BASE (DOVE_REGISTER(0xd8500)) +#define DOVE_AC97_BASE (DOVE_REGISTER(0xe0000)) +#define DOVE_PDMA_BASE (DOVE_REGISTER(0xe4000)) +#define DOVE_GPIO2_BASE (DOVE_REGISTER(0xe8400)) +#define DOVE_SSP_BASE (DOVE_REGISTER(0xec000)) + +/* Dove Sata controller has one port */ +#define DOVE_SATA_PORT0_OFFSET 0x2000 + +/* Dove GbE controller has one port */ +#define MAX_MVGBE_DEVS 1 +#define MVGBE0_BASE DOVE_EGIGA_BASE + +/* Dove USB Host controller */ +#define MVUSB0_BASE DOVE_USB20_0_BASE +#define MVUSB0_CPU_ATTR_DRAM_CS0 DOVECPU_ATTR_DRAM +#define MVUSB0_CPU_ATTR_DRAM_CS1 DOVECPU_ATTR_DRAM +#define MVUSB0_CPU_ATTR_DRAM_CS2 DOVECPU_WIN_DISABLE +#define MVUSB0_CPU_ATTR_DRAM_CS3 DOVECPU_WIN_DISABLE + +/* Dove CPU memory windows */ +#define MVCPU_WIN_CTRL_DATA DOVECPU_WIN_CTRL_DATA +#define MVCPU_WIN_ENABLE DOVECPU_WIN_ENABLE +#define MVCPU_WIN_DISABLE DOVECPU_WIN_DISABLE + +#endif diff --git a/arch/arm/include/asm/arch-dove/gpio.h b/arch/arm/include/asm/arch-dove/gpio.h new file mode 100644 index 0000000..71bef8e --- /dev/null +++ b/arch/arm/include/asm/arch-dove/gpio.h @@ -0,0 +1,35 @@ +/* + * Marvell Dove SoC gpio + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef __DOVE_GPIO_H +#define __DOVE_GPIO_H + +#include <orion_gpio.h> + +#define GPIO_MAX 70 +#define GPIO_BASE(pin) (((pin) >= 64) ? DOVE_GPIO2_BASE : \ + ((pin) >= 32) ? DOVE_GPIO1_BASE : \ + DOVE_GPIO0_BASE) + +#endif diff --git a/arch/arm/include/asm/arch-dove/mpp.h b/arch/arm/include/asm/arch-dove/mpp.h new file mode 100644 index 0000000..1279ac2 --- /dev/null +++ b/arch/arm/include/asm/arch-dove/mpp.h @@ -0,0 +1,283 @@ +/* + * Marvell Dove SoC pinmux + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVE_MPP_H +#define _DOVE_MPP_H + +#define DOVE_GPI (1 << 0) +#define DOVE_GPO (1 << 1) +#define DOVE_GPIO (DOVE_GPO | DOVE_GPI) + +#define MPP(_num, _sel, _gpio) ( \ + /* MPP number */ ((_num) & 0xff) | \ + /* MPP select value */ (((_sel) & 0x1f) << 8) | \ + /* is gpio config */ ((!!(_gpio)) << 15)) + +/* MPP0-15 allow PMU function */ +#define MPP_PMU_MAX 15 +#define PMU (0x10) +/* MPP0-23 have standard mpp register layout */ +#define MPP_STD_MAX 23 + +#define MPP0 0 +#define MPP0_GPIO MPP(0, 0x0, 1) +#define MPP0_UART2_RTS MPP(0, 0x2, 0) +#define MPP0_SDIO0_CD MPP(0, 0x3, 0) +#define MPP0_LCD0_PWM MPP(0, 0xf, 0) +#define MPP0_PMU MPP(0, PMU, 0) + +#define MPP1 1 +#define MPP1_GPIO MPP(1, 0x0, 1) +#define MPP1_UART2_CTS MPP(1, 0x2, 0) +#define MPP1_SDIO0_WP MPP(1, 0x3, 0) +#define MPP1_LCD1_PWM MPP(1, 0xf, 0) +#define MPP1_PMU MPP(1, PMU, 0) + +#define MPP2 2 +#define MPP2_GPIO MPP(2, 0x0, 1) +#define MPP2_SATA_PRSNT MPP(2, 0x1, 0) +#define MPP2_UART2_TXD MPP(2, 0x2, 0) +#define MPP2_SDIO0_BUSPWR MPP(2, 0x3, 0) +#define MPP2_UART1_RTS MPP(2, 0x4, 0) +#define MPP2_PMU MPP(2, PMU, 0) + +#define MPP3 3 +#define MPP3_GPIO MPP(3, 0x0, 1) +#define MPP3_SATA_ACT MPP(3, 0x1, 0) +#define MPP3_UART2_RXD MPP(3, 0x2, 0) +#define MPP3_SDIO0_LEDCTRL MPP(3, 0x3, 0) +#define MPP3_UART1_CTS MPP(3, 0x4, 0) +#define MPP3_LCD_SPI_CS1 MPP(3, 0xf, 0) +#define MPP3_PMU MPP(3, PMU, 0) + +#define MPP4 4 +#define MPP4_GPIO MPP(4, 0x0, 1) +#define MPP4_UART3_RTS MPP(4, 0x2, 0) +#define MPP4_SDIO1_CD MPP(4, 0x3, 0) +#define MPP4_SPI1_MISO MPP(4, 0x4, 0) +#define MPP4_PMU MPP(4, PMU, 0) + +#define MPP5 5 +#define MPP5_GPIO MPP(5, 0x0, 1) +#define MPP5_UART3_CTS MPP(5, 0x2, 0) +#define MPP5_SDIO1_WP MPP(5, 0x3, 0) +#define MPP5_SPI1_CS MPP(5, 0x4, 0) +#define MPP5_PMU MPP(5, PMU, 0) + +#define MPP6 6 +#define MPP6_GPIO MPP(6, 0x0, 1) +#define MPP6_UART3_TXD MPP(6, 0x2, 0) +#define MPP6_SDIO1_BUSPWR MPP(6, 0x3, 0) +#define MPP6_SPI1_MOSI MPP(6, 0x4, 0) +#define MPP6_PMU MPP(6, PMU, 0) + +#define MPP7 7 +#define MPP7_GPIO MPP(7, 0x0, 1) +#define MPP7_UART3_RXD MPP(7, 0x2, 0) +#define MPP7_SDIO1_LEDCTRL MPP(7, 0x3, 0) +#define MPP7_SPI1_SCK MPP(7, 0x4, 0) +#define MPP7_PMU MPP(7, PMU, 0) + +#define MPP8 8 +#define MPP8_GPIO MPP(8, 0x0, 1) +#define MPP8_WATCHDOG_RSTOUT MPP(8, 0x1, 0) +#define MPP8_PMU MPP(8, PMU, 0) + +#define MPP9 9 +#define MPP9_GPIO MPP(9, 0x0, 1) +#define MPP9_PEX1_CLKREQ MPP(9, 0x5, 0) +#define MPP9_PMU MPP(9, PMU, 0) + +#define MPP10 10 +#define MPP10_GPIO MPP(10, 0x0, 1) +#define MPP10_SSP_SCLK MPP(10, 0x5, 0) +#define MPP10_PMU MPP(10, PMU, 0) + +#define MPP11 11 +#define MPP11_GPIO MPP(11, 0x0, 1) +#define MPP11_SATA_PRSNT MPP(11, 0x1, 0) +#define MPP11_SATA_ACT MPP(11, 0x2, 0) +#define MPP11_SDIO0_LEDCTRL MPP(11, 0x3, 0) +#define MPP11_SDIO1_LEDCTRL MPP(11, 0x4, 0) +#define MPP11_PEX0_CLKREQ MPP(11, 0x5, 0) +#define MPP11_PMU MPP(11, PMU, 0) + +#define MPP12 12 +#define MPP12_GPIO MPP(12, 0x0, 1) +#define MPP12_SATA_ACT MPP(12, 0x1, 0) +#define MPP12_UART2_RTS MPP(12, 0x2, 0) +#define MPP12_AUDIO0_EXTCLK MPP(12, 0x3, 0) +#define MPP12_SDIO1_CD MPP(12, 0x4, 0) +#define MPP12_PMU MPP(12, PMU, 0) + +#define MPP13 13 +#define MPP13_GPIO MPP(13, 0x0, 1) +#define MPP13_UART2_CTS MPP(13, 0x2, 0) +#define MPP13_AUDIO1_EXTCLK MPP(13, 0x3, 0) +#define MPP13_SDIO1_WP MPP(13, 0x4, 0) +#define MPP13_SSP_EXTCLK MPP(13, 0x5, 0) +#define MPP13_PMU MPP(13, PMU, 0) + +#define MPP14 14 +#define MPP14_GPIO MPP(14, 0x0, 1) +#define MPP14_UART2_TXD MPP(14, 0x2, 0) +#define MPP14_SDIO1_BUSPWR MPP(14, 0x4, 0) +#define MPP14_SSP_TXD MPP(14, 0x5, 0) +#define MPP14_PMU MPP(14, PMU, 0) + +#define MPP15 15 +#define MPP15_GPIO MPP(15, 0x0, 1) +#define MPP15_UART2_RXD MPP(15, 0x2, 0) +#define MPP15_SDIO1_LEDCTRL MPP(15, 0x4, 0) +#define MPP15_SSP_SFRM MPP(15, 0x5, 0) +#define MPP15_PMU MPP(15, PMU, 0) + +#define MPP16 16 +#define MPP16_GPIO MPP(16, 0x0, 1) +#define MPP16_UART3_RTS MPP(16, 0x2, 0) +#define MPP16_SDIO0_CD MPP(16, 0x3, 0) +#define MPP16_LCD_SPI_CS1 MPP(16, 0x4, 0) +#define MPP16_AC97_SDI1 MPP(16, 0x5, 0) + +#define MPP17 17 +#define MPP17_GPIO MPP(17, 0x0, 1) +#define MPP17_AC97_SYSCLKO MPP(17, 0x1, 0) +#define MPP17_UART3_CTS MPP(17, 0x2, 0) +#define MPP17_SDIO0_WP MPP(17, 0x3, 0) +#define MPP17_TWSI_SDA MPP(17, 0x4, 0) +#define MPP17_AC97_SDI2 MPP(17, 0x5, 0) + +#define MPP18 18 +#define MPP18_GPIO MPP(18, 0x0, 1) +#define MPP18_UART3_TXD MPP(18, 0x2, 0) +#define MPP18_SDIO0_BUSPWR MPP(18, 0x3, 0) +#define MPP18_LCD0_PWM MPP(18, 0x4, 0) +#define MPP18_AC97_SDI3 MPP(18, 0x5, 0) + +#define MPP19 19 +#define MPP19_GPIO MPP(19, 0x0, 1) +#define MPP19_UART3_RXD MPP(19, 0x2, 0) +#define MPP19_SDIO0_LEDCTRL MPP(19, 0x3, 0) +#define MPP19_TWSI_SCK MPP(19, 0x4, 0) + +#define MPP20 20 +#define MPP20_GPIO MPP(20, 0x0, 1) +#define MPP20_AC97_SYSCLKO MPP(20, 0x1, 0) +#define MPP20_LCD_SPI_MISO MPP(20, 0x2, 0) +#define MPP20_SDIO1_CD MPP(20, 0x3, 0) +#define MPP20_SDIO0_CD MPP(20, 0x5, 0) +#define MPP20_SPI1_MISO MPP(20, 0x6, 0) + +#define MPP21 21 +#define MPP21_GPIO MPP(21, 0x0, 1) +#define MPP21_UART1_RTS MPP(21, 0x1, 0) +#define MPP21_LCD_SPI_CS0 MPP(21, 0x2, 0) +#define MPP21_SDIO1_WP MPP(21, 0x3, 0) +#define MPP21_SSP_SFRM MPP(21, 0x4, 0) +#define MPP21_SDIO0_WP MPP(21, 0x5, 0) +#define MPP21_SPI1_CS MPP(21, 0x6, 0) + +#define MPP22 22 +#define MPP22_GPIO MPP(22, 0x0, 1) +#define MPP22_UART1_CTS MPP(22, 0x1, 0) +#define MPP22_LCD_SPI_MOSI MPP(22, 0x2, 0) +#define MPP22_SDIO1_BUSPWR MPP(22, 0x3, 0) +#define MPP22_SSP_TXD MPP(22, 0x4, 0) +#define MPP22_SDIO0_BUSPWR MPP(22, 0x5, 0) +#define MPP22_SPI1_MOSI MPP(22, 0x6, 0) + +#define MPP23 23 +#define MPP23_GPIO MPP(23, 0x0, 1) +#define MPP23_LCD_SPI_SCK MPP(23, 0x2, 0) +#define MPP23_SDIO1_LEDCTRL MPP(23, 0x3, 0) +#define MPP23_SSP_SCLK MPP(23, 0x4, 0) +#define MPP23_SDIO0_LEDCTRL MPP(23, 0x5, 0) +#define MPP23_SPI1_SCK MPP(23, 0x6, 0) + +/* MPP_CAMERA = MPP[24:39] */ +#define MPP_CAMERA 24 +#define MPP_CAMERA_CAMERA MPP(24, 0x0, 0) +#define MPP_CAMERA_GPIO MPP(24, 0x1, 1) +#define MPP_CAMERA_MAX 39 + +/* MPP_SDIO0 = MPP[40:45] */ +#define MPP_SDIO0 40 +#define MPP_SDIO0_SDIO MPP(40, 0x0, 0) +#define MPP_SDIO0_GPIO MPP(40, 0x1, 1) +#define MPP_SDIO0_MAX 45 + +/* MPP_SDIO1 = MPP[46:51] */ +#define MPP_SDIO1 46 +#define MPP_SDIO1_SDIO MPP(46, 0x0, 0) +#define MPP_SDIO1_GPIO MPP(46, 0x1, 1) +#define MPP_SDIO1_MAX 51 + +/* MPP_AUDIO1 = MPP[52:57] */ +#define MPP_AUDIO1 52 +#define MPP_AUDIO1_I2S_SPDIFO MPP(52, 0x0, 0) +#define MPP_AUDIO1_I2S MPP(52, 0x2, 0) +#define MPP_AUDIO1_SPDIFO MPP(52, 0x8, 0) +#define MPP_AUDIO1_GPIO MPP(52, 0xa, 1) +#define MPP_AUDIO1_TWSI MPP(52, 0xb, 0) +#define MPP_AUDIO1_SSP_SPDIFO MPP(52, 0xc, 0) +#define MPP_AUDIO1_SSP MPP(52, 0xe, 0) +#define MPP_AUDIO1_SSP_TWSI MPP(52, 0xf, 0) +#define MPP_AUDIO1_MAX 57 + +/* MPP_SPI = MPP[58:61] */ +#define MPP_SPI 58 +#define MPP_SPI_SPI MPP(58, 0x0, 0) +#define MPP_SPI_GPIO MPP(58, 0x1, 1) +#define MPP_SPI_MAX 61 + +/* MPP_UART1 = MPP[62:63] */ +#define MPP_UART1 62 +#define MPP_UART1_UART1 MPP(62, 0x0, 0) +#define MPP_UART1_GPIO MPP(62, 0x1, 1) +#define MPP_UART1_MAX 63 + +/* MPP_NAND = MPP[64:71] */ +#define MPP_NAND 64 +#define MPP_NAND_NAND MPP(64, 0x0, 0) +#define MPP_NAND_GPO MPP(64, 0x1, 1) +#define MPP_NAND_MAX 71 + +/* MPP_AUDIO0 = Internal AC97/I2S mux for audio0 pins */ +#define MPP_AUDIO0 72 +#define MPP_AUDIO0_I2S MPP(72, 0x0, 0) +#define MPP_AUDIO0_AC97 MPP(72, 0x1, 0) + +/* MPP_TWSI = Internal TWSI option mux */ +#define MPP_TWSI 73 +#define MPP_TWSI_NONE MPP(73, 0x0, 0) +#define MPP_TWSI_OPTION1 MPP(73, 0x1, 0) +#define MPP_TWSI_OPTION2 MPP(73, 0x2, 0) +#define MPP_TWSI_OPTION3 MPP(73, 0x3, 0) + +#define MPP_MAX MPP_TWSI + +u8 dove_mpp_get_gpio_caps(u8 num); +void dove_mpp_conf(u16 *mpp_list); + +#endif
Hi Sebastian,
- for (; i < CONFIG_NR_DRAM_BANKS; i++) {
Please fix this comment style.
- /* configure gpio capabilities */
- /* gpio allows gpio on all audio1 mpp pins */
Here too.
Also, your patch to MAINTAINERS file is missing...
Luka
This adds a gpio driver for Marvell Orion SoCs, i.e. orion5x, kirkwood, dove. This is based on kw_gpio but as gpio capabilities depend heavily on the mpp configuration for dove, it allows to set gpi/gpo capabilities from mpp. This should be compatible with the current kw_gpio and porting mpp of kirkwood and orion5x is appreciated.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Dieter Kiermaier dk-arm-linux@gmx.de --- drivers/gpio/Makefile | 1 + drivers/gpio/orion_gpio.c | 167 +++++++++++++++++++++++++++++++++++++++++++++ include/orion_gpio.h | 64 +++++++++++++++++ 3 files changed, 232 insertions(+) create mode 100644 drivers/gpio/orion_gpio.c create mode 100644 include/orion_gpio.h
diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index d50ac3b..6fc163b 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -26,6 +26,7 @@ include $(TOPDIR)/config.mk LIB := $(obj)libgpio.o
COBJS-$(CONFIG_AT91_GPIO) += at91_gpio.o +COBJS-$(CONFIG_ORION_GPIO) += orion_gpio.o COBJS-$(CONFIG_KIRKWOOD_GPIO) += kw_gpio.o COBJS-$(CONFIG_MARVELL_GPIO) += mvgpio.o COBJS-$(CONFIG_MARVELL_MFP) += mvmfp.o diff --git a/drivers/gpio/orion_gpio.c b/drivers/gpio/orion_gpio.c new file mode 100644 index 0000000..209354d --- /dev/null +++ b/drivers/gpio/orion_gpio.c @@ -0,0 +1,167 @@ +/* + * Marvell Orion SoC GPIO handling. + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * Based on (mostly copied from) plat-orion based Linux 2.6 kernel driver. + * Removed orion_gpiochip struct and kernel level irq handling. + * Dieter Kiermaier dk-arm-linux@gmx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <asm/bitops.h> +#include <asm/io.h> +#include <asm/arch/gpio.h> +#include <orion_gpio.h> + +static unsigned long gpio_valid_input[BITS_TO_LONGS(GPIO_MAX)]; +static unsigned long gpio_valid_output[BITS_TO_LONGS(GPIO_MAX)]; + +void __set_direction(unsigned pin, int input) +{ + u32 base = GPIO_BASE(pin); + u32 u; + + u = readl(GPIO_IO_CONF(base)); + if (input) + u |= 1 << (pin & 31); + else + u &= ~(1 << (pin & 31)); + writel(u, GPIO_IO_CONF(base)); + + u = readl(GPIO_IO_CONF(base)); +} + +void __set_level(unsigned pin, int high) +{ + u32 base = GPIO_BASE(pin); + u32 u; + + u = readl(GPIO_OUT(base)); + if (high) + u |= 1 << (pin & 31); + else + u &= ~(1 << (pin & 31)); + writel(u, GPIO_OUT(base)); +} + +void __set_blinking(unsigned pin, int blink) +{ + u32 base = GPIO_BASE(pin); + u32 u; + + u = readl(GPIO_BLINK_EN(base)); + if (blink) + u |= 1 << (pin & 31); + else + u &= ~(1 << (pin & 31)); + writel(u, GPIO_BLINK_EN(base)); +} + +int orion_gpio_is_valid(unsigned pin, int mode) +{ + if (pin < GPIO_MAX) { + if ((mode & GPIO_INPUT_OK) && + !test_bit(pin, gpio_valid_input)) + goto err_out; + + if ((mode & GPIO_OUTPUT_OK) && + !test_bit(pin, gpio_valid_output)) + goto err_out; + return 0; + } + +err_out: + printf("%s: invalid GPIO %d/%d\n", __func__, pin, GPIO_MAX); + return 1; +} + +void orion_gpio_set_valid(unsigned pin, int mode) +{ + if (mode & GPIO_INPUT_OK) + __set_bit(pin, gpio_valid_input); + else + __clear_bit(pin, gpio_valid_input); + if (mode & GPIO_OUTPUT_OK) + __set_bit(pin, gpio_valid_output); + else + __clear_bit(pin, gpio_valid_output); +} + +/* + * GENERIC_GPIO primitives. + */ +int orion_gpio_direction_input(unsigned pin) +{ + if (orion_gpio_is_valid(pin, GPIO_INPUT_OK) != 0) + return 1; + + /* Configure GPIO direction. */ + __set_direction(pin, 1); + + return 0; +} + +int orion_gpio_direction_output(unsigned pin, int value) +{ + if (orion_gpio_is_valid(pin, GPIO_OUTPUT_OK) != 0) { + printf("%s: invalid GPIO %d\n", __func__, pin); + return 1; + } + + __set_blinking(pin, 0); + + /* Configure GPIO output value. */ + __set_level(pin, value); + + /* Configure GPIO direction. */ + __set_direction(pin, 0); + + return 0; +} + +int orion_gpio_get_value(unsigned pin) +{ + u32 base = GPIO_BASE(pin); + int val; + + if (readl(GPIO_IO_CONF(base)) & (1 << (pin & 31))) + val = readl(GPIO_DATA_IN(base)) ^ readl(GPIO_IN_POL(base)); + else + val = readl(GPIO_OUT(base)); + + return (val >> (pin & 31)) & 1; +} + +void orion_gpio_set_value(unsigned pin, int value) +{ + /* Configure GPIO output value. */ + __set_level(pin, value); +} + +void orion_gpio_set_blink(unsigned pin, int blink) +{ + /* Set output value to zero. */ + __set_level(pin, 0); + + /* Set blinking. */ + __set_blinking(pin, blink); +} diff --git a/include/orion_gpio.h b/include/orion_gpio.h new file mode 100644 index 0000000..ba67068 --- /dev/null +++ b/include/orion_gpio.h @@ -0,0 +1,64 @@ +/* + * Marvell Orion SoCs common gpio + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef __ORION_GPIO_H +#define __ORION_GPIO_H + +/* + * SoC-specific gpio.h defines + * GPIO_MAX and GPIO_BASE(pin) macro + */ + +#define GPIO_INPUT_OK (1 << 0) +#define GPIO_OUTPUT_OK (1 << 1) +#define GPIO_LOW 0 +#define GPIO_HIGH 1 + +/* got from kernel include/linux/bitops.h */ +#define BITS_PER_BYTE 8 +#define BITS_TO_LONGS(nr) DIV_ROUND_UP(nr, BITS_PER_BYTE * sizeof(long)) + +#define GPIO_OUT(base) ((base) + 0x00) +#define GPIO_IO_CONF(base) ((base) + 0x04) +#define GPIO_BLINK_EN(base) ((base) + 0x08) +#define GPIO_IN_POL(base) ((base) + 0x0c) +#define GPIO_DATA_IN(base) ((base) + 0x10) +#define GPIO_EDGE_CAUSE(base) ((base) + 0x14) +#define GPIO_EDGE_MASK(base) ((base) + 0x18) +#define GPIO_LEVEL_MASK(base) ((base) + 0x1c) + +/* + * Orion-specific GPIO API + */ + +void orion_gpio_set_valid(unsigned pin, int mode); +int orion_gpio_is_valid(unsigned pin, int mode); +int orion_gpio_direction_input(unsigned pin); +int orion_gpio_direction_output(unsigned pin, int value); +int orion_gpio_get_value(unsigned pin); +void orion_gpio_set_value(unsigned pin, int value); +void orion_gpio_set_blink(unsigned pin, int blink); +void orion_gpio_set_unused(unsigned pin); + +#endif
This adds a driver for the sdhci controller found on Dove SoCs.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Dieter Kiermaier dk-arm-linux@gmx.de --- drivers/mmc/Makefile | 1 + drivers/mmc/dove_sdhci.c | 101 ++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 102 insertions(+) create mode 100644 drivers/mmc/dove_sdhci.c
diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 65791aa..f7c731f 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -31,6 +31,7 @@ endif
COBJS-$(CONFIG_BFIN_SDH) += bfin_sdh.o COBJS-$(CONFIG_DAVINCI_MMC) += davinci_mmc.o +COBJS-$(CONFIG_DOVE_SDHCI) += dove_sdhci.o COBJS-$(CONFIG_FSL_ESDHC) += fsl_esdhc.o COBJS-$(CONFIG_FTSDC010) += ftsdc010_esdhc.o COBJS-$(CONFIG_GENERIC_MMC) += mmc.o diff --git a/drivers/mmc/dove_sdhci.c b/drivers/mmc/dove_sdhci.c new file mode 100644 index 0000000..ac15fd7 --- /dev/null +++ b/drivers/mmc/dove_sdhci.c @@ -0,0 +1,101 @@ +/* + * + * Marvell Dove SDHCI driver + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * Based on linux drivers/mmc/host/sdhci-dove.c + * by: Saeed Bishara saeed@marvell.com + * Mike Rapoport mike@compulab.co.il + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ + +#include <common.h> +#include <malloc.h> +#include <sdhci.h> +#include <asm/arch/dove.h> + +static u16 dove_sdhci_readw(struct sdhci_host *host, int reg) +{ + u16 ret; + + switch (reg) { + case SDHCI_HOST_VERSION: + case SDHCI_SLOT_INT_STATUS: + /* those registers don't exist */ + return 0; + default: + ret = readw(host->ioaddr + reg); + } + + return ret; +} + +static u32 dove_sdhci_readl(struct sdhci_host *host, int reg) +{ + u32 ret; + + switch (reg) { + case SDHCI_CAPABILITIES: + ret = readl(host->ioaddr + reg); + /* Mask the support for 3.0V */ + ret &= ~SDHCI_CAN_VDD_300; + break; + default: + ret = readl(host->ioaddr + reg); + } + + return ret; +} + +static struct sdhci_ops dove_sdhci_ops = { + .read_w = dove_sdhci_readw, + .read_l = dove_sdhci_readl, +}; + +static struct sdhci_host hosts[2] = { + { + .name = "Dove SDHCI0", + .ioaddr = (void *)DOVE_SDIO0_BASE, + }, + { + .name = "Dove SDHCI1", + .ioaddr = (void *)DOVE_SDIO1_BASE, + }, +}; + +int dove_sdhci_init(int num) +{ + struct sdhci_host *host; + + if (num < 0 || num > 1) + return 1; + + host = &hosts[num]; + + if (host->version) + return 1; + + host->quirks = + SDHCI_QUIRK_NO_HISPD_BIT | + SDHCI_QUIRK_BROKEN_R1B | + SDHCI_QUIRK_32BIT_DMA_ADDR; + host->version = SDHCI_SPEC_200; + host->ops = &dove_sdhci_ops; + + add_sdhci(host, 50000000, 4000000); + return 0; +}
This adds an SPI driver found on Marvell Orion SoCs. This driver is taken from kirkwood_spi but removes mpp configuration as dove has dedicated spi pins. To have a common driver for orion5x, kirkwood, and dove, mpp configuration should be handled in some cpu/board-specific setup.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Dieter Kiermaier dk-arm-linux@gmx.de --- drivers/spi/Makefile | 1 + drivers/spi/orion_spi.c | 217 +++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 218 insertions(+) create mode 100644 drivers/spi/orion_spi.c
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index f0b82c6..679ba61 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -34,6 +34,7 @@ COBJS-$(CONFIG_BFIN_SPI) += bfin_spi.o COBJS-$(CONFIG_CF_SPI) += cf_spi.o COBJS-$(CONFIG_CF_QSPI) += cf_qspi.o COBJS-$(CONFIG_DAVINCI_SPI) += davinci_spi.o +COBJS-$(CONFIG_ORION_SPI) += orion_spi.o COBJS-$(CONFIG_KIRKWOOD_SPI) += kirkwood_spi.o COBJS-$(CONFIG_MPC52XX_SPI) += mpc52xx_spi.o COBJS-$(CONFIG_MPC8XXX_SPI) += mpc8xxx_spi.o diff --git a/drivers/spi/orion_spi.c b/drivers/spi/orion_spi.c new file mode 100644 index 0000000..8a50531 --- /dev/null +++ b/drivers/spi/orion_spi.c @@ -0,0 +1,217 @@ +/* + * Marvell Orion SoCs common spi driver + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * based on kirkwood_spi.c written by + * Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <malloc.h> +#include <spi.h> +#include <asm/io.h> +#include <asm/arch/config.h> + +/* SPI Registers on orion SOC */ +struct orionspi_registers { + u32 ctrl; /* 0x00 */ + u32 cfg; /* 0x04 */ + u32 dout; /* 0x08 */ + u32 din; /* 0x0c */ + u32 irq_cause; /* 0x10 */ + u32 irq_mask; /* 0x14 */ +}; + +#define ORIONSPI_CLKPRESCL_MASK 0x1f +#define ORIONSPI_CLKPRESCL_MIN 0x12 +#define ORIONSPI_CSN_ACT 1 /* Activates serial memory interface */ +#define ORIONSPI_SMEMRDY (1 << 1) /* SerMem Data xfer ready */ +#define ORIONSPI_IRQUNMASK 1 /* unmask SPI interrupt */ +#define ORIONSPI_IRQMASK 0 /* mask SPI interrupt */ +#define ORIONSPI_SMEMRDIRQ 1 /* SerMem data xfer ready irq */ +#define ORIONSPI_XFERLEN_1BYTE 0 +#define ORIONSPI_XFERLEN_2BYTE (1 << 5) +#define ORIONSPI_XFERLEN_MASK (1 << 5) +#define ORIONSPI_ADRLEN_1BYTE 0 +#define ORIONSPI_ADRLEN_2BYTE (1 << 8) +#define ORIONSPI_ADRLEN_3BYTE (2 << 8) +#define ORIONSPI_ADRLEN_4BYTE (3 << 8) +#define ORIONSPI_ADRLEN_MASK (3 << 8) +#define ORIONSPI_TIMEOUT 10000 + +static struct orionspi_registers *spireg = + (struct orionspi_registers *)ORION_SPI_BASE; + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct spi_slave *slave; + u32 data; + u32 kwspi_mpp_config[] = { 0, 0 }; + + if (!spi_cs_is_valid(bus, cs)) + return NULL; + + slave = malloc(sizeof(struct spi_slave)); + if (!slave) + return NULL; + + slave->bus = bus; + slave->cs = cs; + + writel(~ORIONSPI_CSN_ACT | ORIONSPI_SMEMRDY, &spireg->ctrl); + + /* calculate spi clock prescaller using max_hz */ + data = ((CONFIG_SYS_TCLK / 2) / max_hz) + 0x10; + data = data < ORIONSPI_CLKPRESCL_MIN ? ORIONSPI_CLKPRESCL_MIN : data; + data = data > ORIONSPI_CLKPRESCL_MASK ? ORIONSPI_CLKPRESCL_MASK : data; + + /* program spi clock prescaller using max_hz */ + writel(ORIONSPI_ADRLEN_3BYTE | data, &spireg->cfg); + debug("data = 0x%08x\n", data); + + writel(ORIONSPI_SMEMRDIRQ, &spireg->irq_cause); + writel(ORIONSPI_IRQMASK, &spireg->irq_mask); + + return slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + free(slave); +} + +#if defined(CONFIG_SYS_KW_SPI_MPP) +u32 spi_mpp_backup[4]; +#endif + +__attribute__((weak)) int board_spi_claim_bus(struct spi_slave *slave) +{ + return 0; +} + +int spi_claim_bus(struct spi_slave *slave) +{ + return board_spi_claim_bus(slave); +} + +__attribute__((weak)) void board_spi_release_bus(struct spi_slave *slave) +{ +} + +void spi_release_bus(struct spi_slave *slave) +{ + board_spi_release_bus(slave); +} + +#ifndef CONFIG_SPI_CS_IS_VALID +/* + * you can define this function board specific + * define above CONFIG in board specific config file and + * provide the function in board specific src file + */ +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return (bus == 0 && (cs == 0 || cs == 1)); +} +#endif + +void spi_init(void) +{ +} + +void spi_cs_activate(struct spi_slave *slave) +{ + writel(readl(&spireg->ctrl) | ORIONSPI_IRQUNMASK, &spireg->ctrl); +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + writel(readl(&spireg->ctrl) & ORIONSPI_IRQMASK, &spireg->ctrl); +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, + void *din, unsigned long flags) +{ + unsigned int tmpdout, tmpdin; + int tm, isread = 0; + + debug("spi_xfer: slave %u:%u dout %p din %p bitlen %u\n", + slave->bus, slave->cs, dout, din, bitlen); + + if (flags & SPI_XFER_BEGIN) + spi_cs_activate(slave); + + /* + * handle data in 8-bit chunks + * TBD: 2byte xfer mode to be enabled + */ + writel(((readl(&spireg->cfg) & ~ORIONSPI_XFERLEN_MASK) | + ORIONSPI_XFERLEN_1BYTE), &spireg->cfg); + + while (bitlen > 4) { + debug("loopstart bitlen %d\n", bitlen); + tmpdout = 0; + + /* Shift data so it's msb-justified */ + if (dout) + tmpdout = *(u32 *) dout & 0x0ff; + + writel(~ORIONSPI_SMEMRDIRQ, &spireg->irq_cause); + writel(tmpdout, &spireg->dout); /* Write the data out */ + debug("*** spi_xfer: ... %08x written, bitlen %d\n", + tmpdout, bitlen); + + /* + * Wait for SPI transmit to get out + * or time out (1 second = 1000 ms) + * The NE event must be read and cleared first + */ + for (tm = 0, isread = 0; tm < ORIONSPI_TIMEOUT; ++tm) { + if (readl(&spireg->irq_cause) & ORIONSPI_SMEMRDIRQ) { + isread = 1; + tmpdin = readl(&spireg->din); + debug + ("spi_xfer: din %p..%08x read\n", + din, tmpdin); + + if (din) { + *((u8 *) din) = (u8) tmpdin; + din += 1; + } + if (dout) + dout += 1; + bitlen -= 8; + } + if (isread) + break; + } + if (tm >= ORIONSPI_TIMEOUT) + printf("*** spi_xfer: Time out during SPI transfer\n"); + + debug("loopend bitlen %d\n", bitlen); + } + + if (flags & SPI_XFER_END) + spi_cs_deactivate(slave); + + return 0; +}
Dove SoC also uses mvsata, therefore add a SoC specific include to allow to reuse the mvsata ide driver.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Dieter Kiermaier dk-arm-linux@gmx.de --- drivers/block/mvsata_ide.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/block/mvsata_ide.c b/drivers/block/mvsata_ide.c index a88d0f7..9918f80 100644 --- a/drivers/block/mvsata_ide.c +++ b/drivers/block/mvsata_ide.c @@ -29,6 +29,8 @@ #include <asm/arch/orion5x.h> #elif defined(CONFIG_KIRKWOOD) #include <asm/arch/kirkwood.h> +#elif defined(CONFIG_DOVE) +#include <asm/arch/dove.h> #endif
/* SATA port registers */
This adds PHY initialization for Marvell Alaska 88E1310 PHY.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Dieter Kiermaier dk-arm-linux@gmx.de --- drivers/net/phy/marvell.c | 48 +++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 48 insertions(+)
diff --git a/drivers/net/phy/marvell.c b/drivers/net/phy/marvell.c index e51e799..e920212 100644 --- a/drivers/net/phy/marvell.c +++ b/drivers/net/phy/marvell.c @@ -89,6 +89,12 @@
#define MIIM_88E1149_PHY_PAGE 29
+/* 88E1310 PHY defines */ +#define MIIM_88E1310_PHY_LED_CTRL 16 +#define MIIM_88E1310_PHY_IRQ_EN 18 +#define MIIM_88E1310_PHY_RGMII_CTRL 21 +#define MIIM_88E1310_PHY_PAGE 22 + /* Marvell 88E1011S */ static int m88e1011s_config(struct phy_device *phydev) { @@ -394,6 +400,37 @@ static int m88e1149_config(struct phy_device *phydev) return 0; }
+/* Marvell 88E1310 */ +static int m88e1310_config(struct phy_device *phydev) +{ + u16 reg; + + /* LED link and activity */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_PAGE, 0x0003); + reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_LED_CTRL); + reg = (reg & ~0xf) | 0x1; + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_LED_CTRL, reg); + + /* Set LED2/INT to INT mode, low active */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_PAGE, 0x0003); + reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_IRQ_EN); + reg = (reg & 0x77ff) | 0x0880; + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_IRQ_EN, reg); + + /* Set RGMII delay */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_PAGE, 0x0002); + reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_RGMII_CTRL); + reg |= 0x0030; + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_RGMII_CTRL, reg); + + /* Ensure to return to page 0 */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_PAGE, 0x0000); + + genphy_config_aneg(phydev); + phy_reset(phydev); + + return 0; +}
static struct phy_driver M88E1011S_driver = { .name = "Marvell 88E1011S", @@ -455,8 +492,19 @@ static struct phy_driver M88E1149S_driver = { .shutdown = &genphy_shutdown, };
+static struct phy_driver M88E1310_driver = { + .name = "Marvell 88E1310", + .uid = 0x01410e90, + .mask = 0xffffff0, + .features = PHY_GBIT_FEATURES, + .config = &m88e1310_config, + .startup = &m88e1011s_startup, + .shutdown = &genphy_shutdown, +}; + int phy_marvell_init(void) { + phy_register(&M88E1310_driver); phy_register(&M88E1149S_driver); phy_register(&M88E1145_driver); phy_register(&M88E1121R_driver);
This add phylib support to the Marvell GBE driver.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Dieter Kiermaier dk-arm-linux@gmx.de --- drivers/net/mvgbe.c | 68 ++++++++++++++++++++++++++++++++++++++++++++++++--- 1 file changed, 64 insertions(+), 4 deletions(-)
diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index 47bf27c..192c989 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -52,7 +52,7 @@ DECLARE_GLOBAL_DATA_PTR; #define MV_PHY_ADR_REQUEST 0xee #define MVGBE_SMI_REG (((struct mvgbe_registers *)MVGBE0_BASE)->smi)
-#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) +#if defined(CONFIG_PHYLIB) || defined(CONFIG_MII) || defined(CONFIG_CMD_MII) /* * smi_reg_read - miiphy_read callback function. * @@ -184,6 +184,24 @@ static int smi_reg_write(const char *devname, u8 phy_adr, u8 reg_ofs, u16 data) } #endif
+#if defined(CONFIG_PHYLIB) +int mvgbe_phy_read(struct mii_dev *bus, int phyAddr, int devAddr, int regAddr) +{ + u16 data; + int ret; + ret = smi_reg_read(bus->name, phyAddr, regAddr, &data); + if (ret) + return ret; + return data; +} + +int mvgbe_phy_write(struct mii_dev *bus, int phyAddr, int devAddr, int regAddr, + u16 data) +{ + return smi_reg_write(bus->name, phyAddr, regAddr, data); +} +#endif + /* Stop and checks all queues */ static void stop_queue(u32 * qreg) { @@ -467,8 +485,9 @@ static int mvgbe_init(struct eth_device *dev) /* Enable port Rx. */ MVGBE_REG_WR(regs->rqc, (1 << RXUQ));
-#if (defined (CONFIG_MII) || defined (CONFIG_CMD_MII)) \ - && defined (CONFIG_SYS_FAULT_ECHO_LINK_DOWN) +#if (defined(CONFIG_MII) || defined(CONFIG_CMD_MII)) \ + && !defined(CONFIG_PHYLIB) \ + && defined(CONFIG_SYS_FAULT_ECHO_LINK_DOWN) /* Wait up to 5s for the link status */ for (i = 0; i < 5; i++) { u16 phyadr; @@ -647,6 +666,45 @@ static int mvgbe_recv(struct eth_device *dev) return 0; }
+#if defined(CONFIG_PHYLIB) +int mvgbe_phylib_init(struct eth_device *dev, int phyid) +{ + struct mii_dev *bus; + struct phy_device *phydev; + int ret; + + bus = mdio_alloc(); + if (!bus) { + printf("mdio_alloc failed\n"); + return -ENOMEM; + } + bus->read = mvgbe_phy_read; + bus->write = mvgbe_phy_write; + sprintf(bus->name, dev->name); + + ret = mdio_register(bus); + if (ret) { + printf("mdio_register failed\n"); + free(bus); + return -ENOMEM; + } + + /* Set phy address of the port */ + mvgbe_phy_write(bus, MV_PHY_ADR_REQUEST, 0, MV_PHY_ADR_REQUEST, phyid); + + phydev = phy_connect(bus, phyid, dev, PHY_INTERFACE_MODE_RGMII); + if (!phydev) { + printf("phy_connect failed\n"); + return -ENODEV; + } + + phy_config(phydev); + phy_startup(phydev); + + return 0; +} +#endif + int mvgbe_initialize(bd_t *bis) { struct mvgbe_device *dmvgbe; @@ -729,7 +787,9 @@ error1:
eth_register(dev);
-#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) +#if defined(CONFIG_PHYLIB) + mvgbe_phylib_init(dev, PHY_BASE_ADR + devnum); +#elif defined(CONFIG_MII) || defined(CONFIG_CMD_MII) miiphy_register(dev->name, smi_reg_read, smi_reg_write); /* Set phy address of the port */ miiphy_write(dev->name, MV_PHY_ADR_REQUEST,
Marvell Dove also uses mvgbe as ethernet driver, therefore add support for Dove to reuse the current driver.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Dieter Kiermaier dk-arm-linux@gmx.de --- drivers/net/mvgbe.c | 2 ++ drivers/net/mvgbe.h | 7 +++++++ 2 files changed, 9 insertions(+)
diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index 192c989..590ea0b 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -43,6 +43,8 @@ #include <asm/arch/kirkwood.h> #elif defined(CONFIG_ORION5X) #include <asm/arch/orion5x.h> +#elif defined(CONFIG_DOVE) +#include <asm/arch/dove.h> #endif
#include "mvgbe.h" diff --git a/drivers/net/mvgbe.h b/drivers/net/mvgbe.h index d8a5429..7f5d98f 100644 --- a/drivers/net/mvgbe.h +++ b/drivers/net/mvgbe.h @@ -308,10 +308,17 @@ #define EBAR_TARGET_GUNIT 0x00000007
/* Window attrib */ +#if defined(CONFIG_DOVE) +#define EBAR_DRAM_CS0 0x00000000 +#define EBAR_DRAM_CS1 0x00000000 +#define EBAR_DRAM_CS2 0x00000000 +#define EBAR_DRAM_CS3 0x00000000 +#else #define EBAR_DRAM_CS0 0x00000E00 #define EBAR_DRAM_CS1 0x00000D00 #define EBAR_DRAM_CS2 0x00000B00 #define EBAR_DRAM_CS3 0x00000700 +#endif
/* DRAM Target interface */ #define EBAR_DRAM_NO_CACHE_COHERENCY 0x00000000
With latest support for Marvell Dove SoC, add the SolidRun CuBox as the very first board with that SoC.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Dieter Kiermaier dk-arm-linux@gmx.de --- board/solidrun/cubox/Makefile | 45 ++++++++++ board/solidrun/cubox/cubox.c | 141 ++++++++++++++++++++++++++++++ board/solidrun/cubox/kwbimage.cfg | 76 ++++++++++++++++ boards.cfg | 1 + include/configs/cubox.h | 175 +++++++++++++++++++++++++++++++++++++ 5 files changed, 438 insertions(+) create mode 100644 board/solidrun/cubox/Makefile create mode 100644 board/solidrun/cubox/cubox.c create mode 100644 board/solidrun/cubox/kwbimage.cfg create mode 100644 include/configs/cubox.h
diff --git a/board/solidrun/cubox/Makefile b/board/solidrun/cubox/Makefile new file mode 100644 index 0000000..c771d72 --- /dev/null +++ b/board/solidrun/cubox/Makefile @@ -0,0 +1,45 @@ +# +# SolidRun CuBox Makefile +# +# Sebastian Hesselbarth sebastian.hesselbarth@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := cubox.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/solidrun/cubox/cubox.c b/board/solidrun/cubox/cubox.c new file mode 100644 index 0000000..70c016f --- /dev/null +++ b/board/solidrun/cubox/cubox.c @@ -0,0 +1,141 @@ +/* + * SolidRun CuBox board support + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <miiphy.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> +#include <asm/arch/mpp.h> +#include <orion_gpio.h> + +DECLARE_GLOBAL_DATA_PTR; + +static u16 mpp_config[] = { + MPP0_GPIO, + MPP1_GPIO, /* USB power enable */ + MPP2_GPIO, /* USB over-current indication */ + MPP3_GPIO, /* micro button beneath eSATA port */ + MPP4_GPIO, + MPP5_GPIO, + MPP6_GPIO, + MPP7_GPIO, + + MPP8_GPIO, + MPP9_GPIO, + MPP10_GPIO, + MPP11_GPIO, + MPP12_GPIO, /* SDIO0 card detect */ + MPP13_AUDIO1_EXTCLK, /* Si5351a audio clock output */ + MPP14_GPIO, + MPP15_GPIO, + + MPP16_GPIO, + MPP17_GPIO, + MPP18_GPIO, /* Red front LED */ + MPP19_UART3_RXD, /* IR sensor */ + MPP20_GPIO, + MPP21_GPIO, + MPP22_GPIO, + MPP23_GPIO, + + MPP_CAMERA_GPIO, + MPP_SDIO0_SDIO, /* SDIO0 */ + MPP_SDIO1_GPIO, + MPP_AUDIO1_I2S_SPDIFO, /* SPDIF and HDMI audio */ + MPP_SPI_SPI, /* SPI */ + MPP_UART1_GPIO, + MPP_NAND_GPO, + + MPP_AUDIO0_I2S, + MPP_TWSI_OPTION1, /* TWSI on dedicated pins */ + 0 }; + +int board_early_init_f(void) +{ + struct dove_gpio_init gpp = { + .val0 = 0x00010186, + .oe0_n = 0xffffffff, + .val1 = 0x018000c0, + .oe1_n = 0xffffffff, + .val2 = 0x00000000, + .oe2_n = 0xffffffff, + }; + + dove_init_gpio(&gpp); + + return 0; +} + +int board_init(void) +{ + /* adress of boot parameters */ + gd->bd->bi_boot_params = dove_dram_start(0) + 0x100; + + /* configure mpp */ + dove_mpp_conf(mpp_config); + + /* usb power enable */ + orion_gpio_direction_output(MPP1, GPIO_HIGH); + + /* blink led */ + orion_gpio_direction_output(MPP18, GPIO_HIGH); + orion_gpio_set_blink(MPP18, 1); + + return 0; +} + +#ifdef CONFIG_MMC +int board_mmc_init(bd_t *bis) +{ + dove_sdhci_init(0); + return 0; +} +#endif + +#ifdef CONFIG_RESET_PHY_R +void dove_eth_phy_init(char *name) +{ + u16 devadr; + + if (miiphy_set_current_dev(name)) + return; + + /* command to read PHY dev address */ + if (miiphy_read(name, 0xEE, 0xEE, (u16 *) &devadr)) { + printf("Err..%s could not read PHY dev address\n", + __func__); + return; + } + + /* reset the phy */ + miiphy_reset(name, devadr); + + printf("%s PHY initialized\n", name); +} + +void reset_phy(void) +{ + dove_eth_phy_init("egiga0"); +} +#endif /* CONFIG_RESET_PHY_R */ diff --git a/board/solidrun/cubox/kwbimage.cfg b/board/solidrun/cubox/kwbimage.cfg new file mode 100644 index 0000000..c3f1ad9 --- /dev/null +++ b/board/solidrun/cubox/kwbimage.cfg @@ -0,0 +1,76 @@ +# +# Marvell BootROM config for SolidRun CuBox +# +# Sebastian Hesselbarth sebastian.hesselbarth@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# +# Refer docs/README.kwimage for more details about how-to configure +# and create kirkwood boot image +# + +# Boot Media configurations +BOOT_FROM spi + +# SOC registers configuration using bootrom header extension +# Maximum KWBIMAGE_MAX_CONFIG configurations allowed + +DATA 0xd0020104 0x00000000 # CPU Control and Status register + +# SDRAM initalization +DATA 0xd0800020 0x00022430 # SDRAM Configuration register 0 +DATA 0xd0800030 0x00022430 # SDRAM Configuration register 1 +DATA 0xd0800050 0x911500c3 # SDRAM Timing register 1 +DATA 0xd0800060 0x646602c4 # SDRAM Timing register 2 +DATA 0xd0800190 0xc2003053 # SDRAM Timing register 3 +DATA 0xd08001c0 0x34f4a187 # SDRAM Timing register 4 +DATA 0xd0800650 0x000f0121 # SDRAM Timing register 5 +DATA 0xd0800660 0x04040200 # SDRAM Timing register 6 +DATA 0xd0800080 0x00000000 # SDRAM Control register 1 +DATA 0xd0800090 0x00080000 # SDRAM Control register 2 +DATA 0xd08000f0 0xc0000000 # SDRAM Control register 3 +DATA 0xd08001a0 0x20c0c009 # SDRAM Control register 4 +DATA 0xd0800280 0x010e0202 # SDRAM Control register 5 +DATA 0xd0800760 0x00000000 # SDRAM Control register 6 +DATA 0xd0800770 0x0000000a # SDRAM Control register 7 +DATA 0xd0800140 0x20004044 # SDRAM PHY control register 3 +DATA 0xd08001d0 0x133c2339 # SDRAM PHY control register 7 +DATA 0xd08001e0 0x07700330 # SDRAM PHY control register 8 +DATA 0xd08001f0 0x00000033 # SDRAM PHY control register 9 +DATA 0xd0800200 0x0011311c # SDRAM PHY control register 10 +DATA 0xd0800210 0x00300000 # SDRAM PHY control register 11 +DATA 0xd0800240 0x80000000 # SDRAM PHY control register 14 +DATA 0xd0800510 0x010e0101 # SDRAM MCB control register 1 +DATA 0xd0800230 0x2028006a # SDRAM PHY control register 13 +DATA 0xd0800e10 0x00280062 # SDRAM PHY DLL control registers 2 +DATA 0xd0800e20 0x00280062 # SDRAM PHY DLL control registers 3 +DATA 0xd0800e30 0x00280062 # SDRAM PHY DLL control registers 4 + +# SDRAM memory map (2x512MB) +DATA 0xd0800100 0x000d0001 # SDRAM Memory Address Map register 1 +DATA 0xd0800110 0x200d0001 # SDRAM Memory Address Map register 1 + +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register + +# End of Header extension +DATA 0x0 0x0 diff --git a/boards.cfg b/boards.cfg index ca9b12b..1bd734b 100644 --- a/boards.cfg +++ b/boards.cfg @@ -289,6 +289,7 @@ whistler arm armv7:arm720t whistler nvidia colibri_t20_iris arm armv7:arm720t colibri_t20_iris toradex tegra20 u8500_href arm armv7 u8500 st-ericsson u8500 snowball arm armv7 snowball st-ericsson u8500 +cubox arm armv7 cubox solidrun dove kzm9g arm armv7 kzm9g kmc rmobile armadillo-800eva arm armv7 armadillo-800eva atmark-techno rmobile zynq arm armv7 zynq xilinx zynq diff --git a/include/configs/cubox.h b/include/configs/cubox.h new file mode 100644 index 0000000..223b1d7 --- /dev/null +++ b/include/configs/cubox.h @@ -0,0 +1,175 @@ +/* + * SolidRun CuBox config + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _CONFIG_CUBOX_H +#define _CONFIG_CUBOX_H +#include <asm/sizes.h> + +/* + * Version number information + */ +#define CONFIG_IDENT_STRING "\SolidRun CuBox" + +/* + * High Level Configuration Options + */ +#define CONFIG_MACH_SOLIDRUN_CUBOX /* Machine type */ +#define CONFIG_SHOW_BOOT_PROGRESS +#define CONFIG_ORION_GPIO /* Orion GPIO driver */ + +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +/* + * Enable u-boot API for standalone programs. + */ +#define CONFIG_API + +/* + * Enable devicetree support + */ +#define CONFIG_OF_LIBFDT + +/* + * Commands configuration + */ +#include <config_cmd_default.h> +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ELF +#define CONFIG_CMD_ENV +#define CONFIG_CMD_IDE +#define CONFIG_CMD_PING +#define CONFIG_CMD_SF +#define CONFIG_CMD_SPI +#define CONFIG_CMD_USB +#define CONFIG_CMD_MMC + +#define CONFIG_DOS_PARTITION +#define CONFIG_EFT_PARTITION + +/* + * mv-common.h should be defined after CMD configs since it used them + * to enable certain macros + */ +#include "mv-common.h" + +/* + * redefine mv-common.h macros for armv7/cubox + */ +#undef CONFIG_SYS_PROMPT /* previously defined in mv-common.h */ +#define CONFIG_SYS_PROMPT "CuBox> " /* Command Prompt */ + +/* There is no arch_misc_init on armv7 */ +#undef CONFIG_ARCH_MISC_INIT + +#undef CONFIG_SYS_MALLOC_LEN +#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) /* 4MiB for malloc() */ + +/* + * Environment variables configurations + */ +#if defined(CONFIG_CMD_SF) +#define CONFIG_SPI_FLASH_WINBOND +#define CONFIG_ENV_IS_IN_SPI_FLASH 1 +#define CONFIG_ENV_SECT_SIZE 0x1000 /* 4k */ +#define CONFIG_ENV_SIZE 0x20000 /* 128k */ +#define CONFIG_ENV_OFFSET 0xc0000 /* env starts here */ +#else +#define CONFIG_ENV_IS_NOWHERE 1 /* if env in SDRAM */ +#endif + +/* + * Default CuBox bootscript environment + */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "bootscript=boot.scr\0" \ + "loadaddr=0x02000000\0" \ + "mmc_started=0\0" \ + "ide_started=0\0" \ + "usb_started=0\0" \ + "mtdparts=mtdparts=spi0.0:768k(u-boot)ro,128k(uboot_env),128k(fdt),-(empty)\0" \ + "ethaddr=00:50:43:15:17:17\0" + +#define CONFIG_BOOTCOMMAND \ + "for devn in usb mmc ide ; do " \ + " for part in 0 1; do " \ + " for dir in / /boot/;do " \ + " for fs in ext2 fat; do " \ + " echo ===> Executing ${fs}load ${devn} 0:${part} ${loadaddr} ${dir}${bootscript};" \ + " if itest.s $devn -eq mmc; then" \ + " if itest.s $mmc_started -ne 1; then" \ + " mmcinfo; setenv mmc_started '1';fi;fi;" \ + " if itest.s $devn -eq usb; then" \ + " if itest.s $usb_started -ne 1; then" \ + " usb start; setenv usb_started '1';fi;fi;" \ + " if itest.s $devn -eq ide; then" \ + " if itest.s $ide_started -ne 1; then" \ + " ide reset; setenv ide_started '1';fi;fi;" \ + " if ${fs}load ${devn} 0:${part} ${loadaddr} ${dir}${bootscript}; then" \ + " source ${loadaddr}; fi;" \ + " if itest.s $devn -eq usb; then" \ + " echo ===> Executing ${fs}load ${devn} 1:${part} ${loadaddr} ${dir}${bootscript};" \ + " if ${fs}load ${devn} 1:${part} ${loadaddr} ${dir}${bootscript}; then" \ + " source ${loadaddr}; fi;" \ + " fi;" \ + " done;" \ + " done;" \ + " done;" \ + "done;" \ + "tftp ${loadaddr} ${bootscript};" \ + "source ${loadaddr};" + +/* + * Ethernet Driver configuration + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_MVGBE_PORTS {1} /* enable port 0 */ +#define CONFIG_PHY_BASE_ADR 1 +#define CONFIG_PHYLIB +#define CONFIG_PHY_MARVELL +#endif /* CONFIG_CMD_NET */ + +#ifdef CONFIG_CMD_IDE +#undef CONFIG_IDE_LED +#undef CONFIG_SYS_IDE_MAXBUS +#define CONFIG_SYS_IDE_MAXBUS 1 +#undef CONFIG_SYS_IDE_MAXDEVICE +#define CONFIG_SYS_IDE_MAXDEVICE 1 +#define CONFIG_SYS_ATA_IDE0_OFFSET MV_SATA_PORT0_OFFSET +#endif + +/* + * File system + */ +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_EXT4 +#define CONFIG_CMD_FAT +#define CONFIG_RBTREE +#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_MTDPARTS +#define CONFIG_LZO + +#endif /* _CONFIG_CUBOX_H */
Hi Sebastian,
- Enable devicetree support
Shouldn't this be "device tree"?
Luka
On Dove kwboot can also be used to boot an u-boot image into RAM. In contrast to Kirkwood, Dove does not support the UART boot mode sequence but requires the UART boot mode to be selected through strap pins. The SolidRun CuBox has a push button to allow uart boot mode but fails on the boot sequence sent by kwboot.
This patch adds another cmdline option to allow to send a boot image without the boot sequence and adds support for Dove.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Dieter Kiermaier dk-arm-linux@gmx.de --- tools/Makefile | 2 ++ tools/kwboot.c | 44 ++++++++++++++++++++++++++++++++++++++++---- 2 files changed, 42 insertions(+), 4 deletions(-)
diff --git a/tools/Makefile b/tools/Makefile index 686840a..845384f 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -73,6 +73,7 @@ BIN_FILES-$(CONFIG_MX28) += mxsboot$(SFX) BIN_FILES-$(CONFIG_NETCONSOLE) += ncb$(SFX) BIN_FILES-$(CONFIG_SHA1_CHECK_UB_IMG) += ubsha1$(SFX) BIN_FILES-$(CONFIG_KIRKWOOD) += kwboot$(SFX) +BIN_FILES-$(CONFIG_DOVE) += kwboot$(SFX)
# Source files which exist outside the tools directory EXT_OBJ_FILES-$(CONFIG_BUILD_ENVCRC) += common/env_embedded.o @@ -104,6 +105,7 @@ NOPED_OBJ_FILES-y += os_support.o OBJ_FILES-$(CONFIG_SHA1_CHECK_UB_IMG) += ubsha1.o NOPED_OBJ_FILES-y += ublimage.o OBJ_FILES-$(CONFIG_KIRKWOOD) += kwboot.o +OBJ_FILES-$(CONFIG_DOVE) += kwboot.o
# Don't build by default #ifeq ($(ARCH),ppc) diff --git a/tools/kwboot.c b/tools/kwboot.c index e773f01..199678a 100644 --- a/tools/kwboot.c +++ b/tools/kwboot.c @@ -293,6 +293,30 @@ kwboot_bootmsg(int tty, void *msg) }
static int +kwboot_bootmsg_uartmode(int tty) +{ + int rc; + char c; + + kwboot_printv("Please reboot the target into UART boot mode..."); + + do { + rc = tcflush(tty, TCIOFLUSH); + if (rc) + break; + + rc = kwboot_tty_recv(tty, &c, 1, KWBOOT_MSG_RSP_TIMEO); + + kwboot_spinner(); + + } while (rc || c != NAK); + + kwboot_printv("\n"); + + return rc; +} + +static int kwboot_xm_makeblock(struct kwboot_block *block, const void *data, size_t size, int pnum) { @@ -601,10 +625,11 @@ static void kwboot_usage(FILE *stream, char *progname) { fprintf(stream, - "Usage: %s -b <image> [ -p ] [ -t ] " + "Usage: %s -b <image> [ -p ] [ -t ] [ -u ] " "[-B <baud> ] <TTY>\n", progname); fprintf(stream, "\n"); fprintf(stream, " -b <image>: boot <image>\n"); + fprintf(stream, " -u: target requires UART boot mode (e.g. Dove)\n"); fprintf(stream, " -p: patch <image> to type 0x69 (uart boot)\n"); fprintf(stream, "\n"); fprintf(stream, " -t: mini terminal\n"); @@ -617,7 +642,7 @@ int main(int argc, char **argv) { const char *ttypath, *imgpath; - int rv, rc, tty, term, prot, patch; + int rv, rc, tty, uartmode, term, prot, patch; void *bootmsg; void *img; size_t size; @@ -628,6 +653,7 @@ main(int argc, char **argv) bootmsg = NULL; imgpath = NULL; img = NULL; + uartmode = 0; term = 0; patch = 0; size = 0; @@ -636,7 +662,7 @@ main(int argc, char **argv) kwboot_verbose = isatty(STDOUT_FILENO);
do { - int c = getopt(argc, argv, "hb:ptB:"); + int c = getopt(argc, argv, "hb:ptuB:"); if (c < 0) break;
@@ -654,6 +680,10 @@ main(int argc, char **argv) term = 1; break;
+ case 'u': + uartmode = 1; + break; + case 'B': speed = kwboot_tty_speed(atoi(optarg)); if (speed == -1) @@ -702,7 +732,13 @@ main(int argc, char **argv) } }
- if (bootmsg) { + if (uartmode) { + rc = kwboot_bootmsg_uartmode(tty); + if (rc) { + perror("bootmsg"); + goto out; + } + } else if (bootmsg) { rc = kwboot_bootmsg(tty, bootmsg); if (rc) { perror("bootmsg");
Hi Sebastian,
Please update the documentation too (doc/kwboot.1).
Luka
On Sun, 2012-12-02 at 20:15 +0100, Luka Perkov wrote:
Hi Sebastian,
Second that.
Hey Sebastian,
since the protocol remains the same, and just doesn't take a boot message while polling, better to keep the bootmsg_call() intact and just make the option parsing flip the message type?
The original BootROM had a couple more message, the tool just no immediate use for that. Eventual options to change message type wasn't unanticipated. Ok, no message at all was.
Sketchy patch attached for your consideration. Beware, I can't test it right now.
Also, while I've got nothing against adding a flag for that, I'm partly wondering whether this took a patch at all -- what's the target behavior if you keep shooting it with the original boot message?
I would assume it would keep responding with NAKs. But doesn't?
Cheers, Daniel
... since the protocol remains the same, and just doesn't take a boot message while polling, better to keep the bootmsg_call() intact and just make the option parsing flip the message type?
Hi Daniel,
I tried your patch and except that you forgot to add 'n' to the getopt call, it works as expected.
I tried original kwboot and it failed, then I checked the DS for the boot sequence and finally found out, that Dove doesn't support the "force into UART boot mode" sequence. But your are right, if I reboot Dove into UART boot mode it makes no difference if you send the sequence or not. It works on both kwboot modes.
It just doesn't work if you are doing a normal boot of Dove, as it ignores the sequence sent.
So finally, we have three options: - leave kwboot as is and hope the user will know about Dove's inability to use the boot sequence - add a note to usage() and kwboot that Dove doen't like the sequence - add an option to kwboot as you are proposing
Sebastian
Hi Daniel,
Thanks, mission accomplished :)
Okay, here's a deal.
We've got a bit of a backward compatibility problem anyway. Dave Purdy was so kind to write up a summary of popular devices known working and not working. That's mainly a matter of firmware revisions. [1]
- Let's add a message selector, -m <foo> or so.
Kirkwood specs list two types, let's make those -mdebug and -muart.
If we add -m debug, maybe that even results in someone on the web being ultimately able to explain wth debug mode does :)
Default is -m uart, that's what's going on right now.
- We add -mnone for pin-selected uart boot mode.
- Maybe a slightly less specific printv message.
- But most importantly, we add a COMPATIBILITY section to the manpage, and explain the difference between core revisions there.
We could drop the none case. But then again, if the target isn't reset yet, then not scribbling into getties and stuff where it's avoidable might be preferred by those who can. So why not.
Could you try to read us the boot firmware revision you're running? It's described under the link below. Not sure if it works on your platform though.
Daniel
Let's add a message selector, -m<foo> or so.
Daniel,
I did a little testing with kwboot and boot sequence.
First, BootROM version of my Dove is 2.33. The BootROM version address is a little different what is given on the webpage (ffff003c instead of ff00003c).
CuBox>> md ffff003c 1 ffff003c: 00000233 3...
Dove does not support UART boot sequences. It has to be selected by reset strapping, i.e. if there is no push button as on the cubox it will be difficult for most of the users ;)
I also tested the above on the Mirabox (Armada 370) and except that the BootROM there, prints out some message after reset it works if I first call kwboot with -b and then with -n or delay xmodem call by a second.
BootROM version on Armada 370 is 1.08 and the version register address is very different. It resets if I try to read ff00003c or ffff003c and I have neither a DS nor the u-boot source available.
Finally, I tested kwboot on 88F6282 (aka Armada 300) and there BootROM version is 1.21 (on ff00003c) and it does work as with Kirkwood (i.e. send boot sequence).
I think, for the patch set, that I will remove patch 10 from it and leave the required modifications up to you?
Sebastian
This patch set add support for the Marvell Dove 88AP510 SoC and the SolidRun CuBox board based on that SoC. The patch set is divided into the four following sections:
(1) Patches 1-5: Add support for the Dove SoC and related drivers. Where possible drivers from Marvell Kirkwood are reused (mvsata, mvgbe), or forked to allow more generic usage (SPI, GPIO). The SDHCI driver is different and a new driver is added for it. The forked drivers can also be reused on Kirkwood but that would have required patching existing boards.
(2) Patches 6-8: Allow mvgbe to use the phylib API, add support for 88E1310 PHY and allow Dove to use the driver.
(3) Patch 9 Add the SolidRun CuBox as the first board based on Marvell Dove SoC.
(4) Patch 10 Add support for different UART boot mode found on Dove.
Changelog: v1->v2: respect review comments by Luka Perkov - fix commenting styles and typos - add MAINTAINERS entry - also update kwboot.1 manpage
Sebastian Hesselbarth (10): ARM: dove: add support for Marvell Dove SoC GPIO: add gpio driver for Orion SoCs MMC: sdhci: Add support for dove sdhci SPI: Add Orion SPI driver block: mvsata: add dove include NET: phy: add 88E1310 PHY initialization NET: mvgbe: add phylib support NET: mvgbe: add support for Dove Boards: Add support for SolidRun CuBox tools: Add support for Dove to kwboot
MAINTAINERS | 4 + arch/arm/cpu/armv7/dove/Makefile | 49 +++++ arch/arm/cpu/armv7/dove/cpu.c | 266 ++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/dram.c | 118 ++++++++++++ arch/arm/cpu/armv7/dove/lowlevel_init.S | 83 ++++++++ arch/arm/cpu/armv7/dove/mpp.c | 318 +++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/timer.c | 176 +++++++++++++++++ arch/arm/cpu/armv7/dove/usb.c | 101 ++++++++++ arch/arm/include/asm/arch-dove/config.h | 153 +++++++++++++++ arch/arm/include/asm/arch-dove/cpu.h | 204 ++++++++++++++++++++ arch/arm/include/asm/arch-dove/dove.h | 93 +++++++++ arch/arm/include/asm/arch-dove/gpio.h | 35 ++++ arch/arm/include/asm/arch-dove/mpp.h | 283 +++++++++++++++++++++++++++ board/solidrun/cubox/Makefile | 45 +++++ board/solidrun/cubox/cubox.c | 141 ++++++++++++++ board/solidrun/cubox/kwbimage.cfg | 76 ++++++++ boards.cfg | 1 + doc/kwboot.1 | 13 +- drivers/block/mvsata_ide.c | 2 + drivers/gpio/Makefile | 1 + drivers/gpio/orion_gpio.c | 167 ++++++++++++++++ drivers/mmc/Makefile | 1 + drivers/mmc/dove_sdhci.c | 101 ++++++++++ drivers/net/mvgbe.c | 70 ++++++- drivers/net/mvgbe.h | 7 + drivers/net/phy/marvell.c | 48 +++++ drivers/spi/Makefile | 1 + drivers/spi/orion_spi.c | 217 +++++++++++++++++++++ include/configs/cubox.h | 175 +++++++++++++++++ include/orion_gpio.h | 64 +++++++ tools/Makefile | 2 + tools/kwboot.c | 44 ++++- 32 files changed, 3048 insertions(+), 11 deletions(-) create mode 100644 arch/arm/cpu/armv7/dove/Makefile create mode 100644 arch/arm/cpu/armv7/dove/cpu.c create mode 100644 arch/arm/cpu/armv7/dove/dram.c create mode 100644 arch/arm/cpu/armv7/dove/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/dove/mpp.c create mode 100644 arch/arm/cpu/armv7/dove/timer.c create mode 100644 arch/arm/cpu/armv7/dove/usb.c create mode 100644 arch/arm/include/asm/arch-dove/config.h create mode 100644 arch/arm/include/asm/arch-dove/cpu.h create mode 100644 arch/arm/include/asm/arch-dove/dove.h create mode 100644 arch/arm/include/asm/arch-dove/gpio.h create mode 100644 arch/arm/include/asm/arch-dove/mpp.h create mode 100644 board/solidrun/cubox/Makefile create mode 100644 board/solidrun/cubox/cubox.c create mode 100644 board/solidrun/cubox/kwbimage.cfg create mode 100644 drivers/gpio/orion_gpio.c create mode 100644 drivers/mmc/dove_sdhci.c create mode 100644 drivers/spi/orion_spi.c create mode 100644 include/configs/cubox.h create mode 100644 include/orion_gpio.h
--- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Luka Perkov luka@openwrt.org
This patch adds initial support for the armv7-based Marvell Dove SoC (88AP510).
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Changelog: v1->v2: - fix some commenting styles
Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Luka Perkov luka@openwrt.org --- arch/arm/cpu/armv7/dove/Makefile | 49 +++++ arch/arm/cpu/armv7/dove/cpu.c | 266 ++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/dram.c | 118 ++++++++++++ arch/arm/cpu/armv7/dove/lowlevel_init.S | 83 ++++++++ arch/arm/cpu/armv7/dove/mpp.c | 318 +++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/timer.c | 176 +++++++++++++++++ arch/arm/cpu/armv7/dove/usb.c | 101 ++++++++++ arch/arm/include/asm/arch-dove/config.h | 153 +++++++++++++++ arch/arm/include/asm/arch-dove/cpu.h | 204 ++++++++++++++++++++ arch/arm/include/asm/arch-dove/dove.h | 93 +++++++++ arch/arm/include/asm/arch-dove/gpio.h | 35 ++++ arch/arm/include/asm/arch-dove/mpp.h | 283 +++++++++++++++++++++++++++ 12 files changed, 1879 insertions(+) create mode 100644 arch/arm/cpu/armv7/dove/Makefile create mode 100644 arch/arm/cpu/armv7/dove/cpu.c create mode 100644 arch/arm/cpu/armv7/dove/dram.c create mode 100644 arch/arm/cpu/armv7/dove/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/dove/mpp.c create mode 100644 arch/arm/cpu/armv7/dove/timer.c create mode 100644 arch/arm/cpu/armv7/dove/usb.c create mode 100644 arch/arm/include/asm/arch-dove/config.h create mode 100644 arch/arm/include/asm/arch-dove/cpu.h create mode 100644 arch/arm/include/asm/arch-dove/dove.h create mode 100644 arch/arm/include/asm/arch-dove/gpio.h create mode 100644 arch/arm/include/asm/arch-dove/mpp.h
diff --git a/arch/arm/cpu/armv7/dove/Makefile b/arch/arm/cpu/armv7/dove/Makefile new file mode 100644 index 0000000..127d67e --- /dev/null +++ b/arch/arm/cpu/armv7/dove/Makefile @@ -0,0 +1,49 @@ +# +# Marvell Dove SoC Makefile +# +# Sebastian Hesselbarth sebastian.hesselbarth@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).o + +SOBJS += lowlevel_init.o +COBJS-y := cpu.o dram.o timer.o mpp.o +COBJS-$(CONFIG_USB_EHCI_MARVELL) += usb.o + +COBJS := $(COBJS-y) +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/arm/cpu/armv7/dove/cpu.c b/arch/arm/cpu/armv7/dove/cpu.c new file mode 100644 index 0000000..b9e708c --- /dev/null +++ b/arch/arm/cpu/armv7/dove/cpu.c @@ -0,0 +1,266 @@ +/* + * Marvell Dove SoC cpu related functions + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <netdev.h> +#include <asm/cache.h> +#include <u-boot/md5.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> +#include <hush.h> + +void reset_cpu(unsigned long ignored) +{ + struct dovecpu_registers *cpureg = + (struct dovecpu_registers *)DOVE_CPU_REG_BASE; + + /* Enable soft reset to assert RSTOUTn */ + writel(readl(&cpureg->rstoutn_mask) | (1 << 2), + &cpureg->rstoutn_mask); + /* Assert soft reset */ + writel(readl(&cpureg->sys_soft_rst) | 1, + &cpureg->sys_soft_rst); + do {} while (1); +} + +#if defined(CONFIG_DISPLAY_CPUINFO) +int dove_print_cpu(void) +{ + char *cpu; + u32 idreg; + u16 part, rev; + + __asm__ __volatile__("mrc p15, 0, %0, c0, c0, 0" : "=r"(idreg)); + + part = (idreg >> ARM_ID_PARTNUM_OFFSET) & ARM_ID_PARTNUM_MASK; + rev = (idreg >> ARM_ID_REVISION_OFFSET) & ARM_ID_REVISION_MASK; + + switch (part) { + case DOVECPU_PART_SHEEVA: + cpu = "Marvell Sheeva"; + break; + default: + cpu = "Unknown CPU"; + } + + printf("CPU: %s (rev %d)\n", cpu, rev); + return 0; +} + +int dove_print_soc(void) +{ + char *soc, *rev; + u16 devid = (readl(DOVE_REG_PCIE_DEVID) >> 16) & 0xffff; + u8 revid = readl(DOVE_REG_PCIE_REVID) & 0xff; + + switch (devid) { + case DOVESOC_DEVID_AP510: + soc = "AP510"; + break; + case DOVESOC_DEVID_F6781: + soc = "F6781"; + break; + default: + printf("ERROR.. %s: Unsupported SoC %04x\n", __func__, devid); + return -1; + } + + switch (revid) { + case DOVESOC_REVID_Z0: + rev = "Z0"; + break; + case DOVESOC_REVID_Z1: + rev = "Z1"; + break; + case DOVESOC_REVID_Y0: + rev = "Y0"; + break; + case DOVESOC_REVID_Y1: + rev = "Y1"; + break; + case DOVESOC_REVID_X0: + rev = "X0"; + break; + case DOVESOC_REVID_A0: + rev = "A0"; + break; + case DOVESOC_REVID_A1: + rev = "A1"; + break; + default: + rev = "Unknown revision"; + }; + + printf("SoC: Dove 88%s (%s)\n", soc, rev); + return 0; +} + +int print_cpuinfo(void) +{ + if (dove_print_soc()) + return -1; + if (dove_print_cpu()) + return -1; + return 0; +} +#endif /* CONFIG_DISPLAY_CPUINFO */ + +/* + * dove_init_gpio - initial GPIO configuration + */ +void dove_init_gpio(struct dove_gpio_init *gpp) +{ + struct dovegpio_registers *gpio0reg = + (struct dovegpio_registers *)DOVE_GPIO0_BASE; + struct dovegpio_registers *gpio1reg = + (struct dovegpio_registers *)DOVE_GPIO1_BASE; + struct dovegpio_registers *gpio2reg = + (struct dovegpio_registers *)DOVE_GPIO2_BASE; + + /* Init GPIOS to default values as per board requirement */ + writel(gpp->val0, &gpio0reg->dout); + writel(gpp->val1, &gpio1reg->dout); + writel(gpp->val2, &gpio2reg->dout); + writel(gpp->oe0_n, &gpio0reg->oe); + writel(gpp->oe1_n, &gpio1reg->oe); + writel(gpp->oe2_n, &gpio2reg->oe); +} + +/* + * Window Size + * Used with the Base register to set the address window size and location. + * Must be programmed from LSB to MSB as sequence of ones followed by + * sequence of zeros. The number of ones specifies the size of the window in + * 64 KByte granularity (e.g., a value of 0x00FF specifies 256 = 16 MByte). + * NOTE: A value of 0x0 specifies 64-KByte size. + */ +unsigned int dove_winctrl_calcsize(unsigned int sizeval) +{ + int i; + unsigned int j = 0; + u32 val = sizeval >> 1; + + for (i = 0; val >= 0x10000; i++) { + j |= (1 << i); + val = val >> 1; + } + return 0x0000ffff & j; +} + +/* + * dove_config_adr_windows - Configure address Windows + * + * There are 8 address windows supported by Dove Soc to addess different + * devices. Windows 0-3 can be configured for size, BAR and remap addr. + * Windows 4-7 can be configured for size and BAR. + * Below configuration is standard for most of the cases + * + * If remap function not used, remap_lo must be set as base + */ +int dove_config_adr_windows(void) +{ + struct dovewin_registers *winregs = + (struct dovewin_registers *)DOVE_CPU_WIN_BASE; + + /* Window 0: 1M PCIE0 IO address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_1M, DOVECPU_TARGET_PCIE0, + DOVECPU_ATTR_PCIE_IO, DOVECPU_WIN_ENABLE), &winregs[0].ctrl); + + writel(DOVE_DEFADR_PCIE0_IO, &winregs[0].base); + writel(DOVE_DEFADR_PCIE0_IO_REMAP, &winregs[0].remap_lo); + writel(0x0, &winregs[0].remap_hi); + + /* Window 1: 1M PCIE1 IO address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_1M, DOVECPU_TARGET_PCIE1, + DOVECPU_ATTR_PCIE_IO, DOVECPU_WIN_ENABLE), &winregs[1].ctrl); + + writel(DOVE_DEFADR_PCIE1_IO, &winregs[1].base); + writel(DOVE_DEFADR_PCIE1_IO_REMAP, &winregs[1].remap_lo); + writel(0x0, &winregs[1].remap_hi); + + /* Window 2: 128M PCIE0 MEM address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_128M, DOVECPU_TARGET_PCIE0, + DOVECPU_ATTR_PCIE_MEM, DOVECPU_WIN_ENABLE), &winregs[2].ctrl); + + writel(DOVE_DEFADR_PCIE0_MEM, &winregs[2].base); + writel(DOVE_DEFADR_PCIE0_MEM, &winregs[2].remap_lo); + writel(0x0, &winregs[2].remap_hi); + + /* Window 3: 128M PCIE1 MEM address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_128M, DOVECPU_TARGET_PCIE1, + DOVECPU_ATTR_PCIE_MEM, DOVECPU_WIN_ENABLE), &winregs[3].ctrl); + + writel(DOVE_DEFADR_PCIE1_MEM, &winregs[3].base); + writel(DOVE_DEFADR_PCIE1_MEM, &winregs[3].remap_lo); + writel(0x0, &winregs[3].remap_hi); + + /* Window 4: 1M Cryptographic SRAM address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_1M, DOVECPU_TARGET_SASRAM, + DOVECPU_ATTR_SASRAM, DOVECPU_WIN_ENABLE), &winregs[4].ctrl); + writel(DOVE_DEFADR_SASRAM, &winregs[4].base); + + /* Window 5: 128M Bootrom address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_128M, DOVECPU_TARGET_BOOTROM, + DOVECPU_ATTR_BOOTROM, DOVECPU_WIN_ENABLE), &winregs[5].ctrl); + writel(DOVE_DEFADR_BOOTROM, &winregs[5].base); + + /* Window 6: 1M PMU Scratchpad address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_1M, DOVECPU_TARGET_PMURAM, + DOVECPU_ATTR_PMURAM, DOVECPU_WIN_ENABLE), &winregs[6].ctrl); + writel(DOVE_DEFADR_PMURAM, &winregs[6].base); + + /* Window 7: Disabled */ + writel(DOVECPU_WIN_DISABLE, &winregs[7].ctrl); + + return 0; +} + +#ifdef CONFIG_ARCH_CPU_INIT +int arch_cpu_init(void) +{ + dove_config_adr_windows(); +#ifdef CONFIG_USB_EHCI_MARVELL + dove_ehci_phy_init(0); + dove_ehci_phy_init(1); +#endif /* CONFIG_USB_EHCI_MARVELL */ + return 0; +} +#endif /* CONFIG_ARCH_CPU_INIT */ + +void enable_caches(void) +{ +#ifndef CONFIG_SYS_DCACHE_OFF + /* Enable D-cache. I-cache is already enabled in lowlevel_init.S */ + dcache_enable(); +#endif /* CONFIG_SYS_DCACHE_OFF */ +} + +#ifdef CONFIG_MVGBE +int cpu_eth_init(bd_t *bis) +{ + mvgbe_initialize(bis); + return 0; +} +#endif /* CONFIG_MVGBE */ diff --git a/arch/arm/cpu/armv7/dove/dram.c b/arch/arm/cpu/armv7/dove/dram.c new file mode 100644 index 0000000..437263c --- /dev/null +++ b/arch/arm/cpu/armv7/dove/dram.c @@ -0,0 +1,118 @@ +/* + * Marvell Dove SoC DRAM initialization + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <config.h> +#include <common.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define DOVE_REG_DRAM_MAP(x) (DOVE_REGISTER(0x800100) + (x * 0x10)) +#define DRAM_START_MASK 0xff800000 +#define DRAM_SIZE_MASK 0xf +#define DRAM_SIZE_SHIFT 16 + +/* + * dove_sdram_start - reads start from Memory Address Map Register n + */ +u32 dove_dram_start(enum memory_bank bank) +{ + u32 reg = readl(DOVE_REG_DRAM_MAP(bank)); + u32 enable = 0x01 & reg; + + if ((!enable) || (bank > BANK1)) + return 0; + + return reg & DRAM_START_MASK; +} + +/* + * dove_sdram_size - reads size from Memory Address Map Register n + */ +u32 dove_dram_size(enum memory_bank bank) +{ + u32 reg = readl(DOVE_REG_DRAM_MAP(bank)); + u32 enable = 0x01 & reg; + u32 size; + + if ((!enable) || (bank > BANK1)) + return 0; + + /* + * area_length: 7 = 8M, 8 = 16M, ..., 15 = 2048M + * size = 1 << (area_length + 16) + */ + size = (reg >> DRAM_SIZE_SHIFT) & DRAM_SIZE_MASK; + size = 1 << (size + 16); + return size; +} + +#ifndef CONFIG_SYS_BOARD_DRAM_INIT +int dram_init(void) +{ + int i; + + gd->ram_size = 0; + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + gd->bd->bi_dram[i].start = dove_dram_start(i); + gd->bd->bi_dram[i].size = dove_dram_size(i); + + /* + * It is assumed that all memory banks are consecutive + * and without gaps. + * If the gap is found, ram_size will be reported for + * consecutive memory only + */ + if (gd->bd->bi_dram[i].start != gd->ram_size) + break; + + gd->ram_size += gd->bd->bi_dram[i].size; + + } + + for (; i < CONFIG_NR_DRAM_BANKS; i++) { + /* + * If above loop terminated prematurely, we need to set + * remaining banks' start address & size as 0. Otherwise other + * u-boot functions and Linux kernel gets wrong values which + * could result in crash + */ + gd->bd->bi_dram[i].start = 0; + gd->bd->bi_dram[i].size = 0; + } + + return 0; +} + +/* + * If this function is not defined here, + * board.c alters dram bank zero configuration defined above. + */ +void dram_init_banksize(void) +{ + dram_init(); +} +#endif /* CONFIG_SYS_BOARD_DRAM_INIT */ diff --git a/arch/arm/cpu/armv7/dove/lowlevel_init.S b/arch/arm/cpu/armv7/dove/lowlevel_init.S new file mode 100644 index 0000000..105d12d --- /dev/null +++ b/arch/arm/cpu/armv7/dove/lowlevel_init.S @@ -0,0 +1,83 @@ +/* + * Marvell Dove SoC icache and reg base low level init + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm/arch/dove.h> +#include <generated/asm-offsets.h> +#include <linux/linkage.h> + +/* + * Enable Tauros2 L2 ICache + */ +.macro init_l2cc + mrc 15, 0, r0, c1, c0, 1 + orr r0, r0, #0x2 + mcr 15, 0, r0, c1, c0, 1 +.endm /* init_l2cc */ + +/* + * Init internal register base addresses + */ +.macro init_reg_base + /* set SB reg base to 0xf1000000 */ + ldr r1, =(DOVE_PREMAP_INT_REGS_BASE_ADDR) + ldr r6, =DOVE_SB_REGS_PHYS_BASE + str r6, [r1] + + /* set NB reg base to 0xf1800000 */ + ldr r1, =(DOVE_CPU_CTRL_REG) + ldr r4, =0xffff0000 + ldr r6, [r1] + and r6, r6, r4 + ldr r4, =DOVE_NB_REGS_PHYS_BASE + lsr r4, r6, #16 + orr r6, r6, r4 + str r6, [r1] + + /* Set AXI bridge address mapping to 0xf1800000 */ + ldr r1, =(DOVE_AXI_CTRL_REG) + ldr r4, =0x007fffff + ldr r6, [r1] + and r6, r6, r4 + ldr r4, =DOVE_NB_REGS_PHYS_BASE + orr r6, r6, r4 + str r6, [r1] + + /* set MC configuration register decode address to 0xf1800000 */ + ldr r1, =(DOVE_PREMAP_MC_DECODE_REG) + ldr r4, =0x0000ffff + ldr r6, [r1] + and r6, r6, r4 + ldr r4, =DOVE_NB_REGS_PHYS_BASE + orr r6, r6, r4 + str r6, [r1] + +.endm /* init_reg_base */ + +.section ".text.init", "x" + +ENTRY(lowlevel_init) + init_l2cc + init_reg_base + + /* r12 saved upper lr*/ + mov pc,lr +ENDPROC(lowlevel_init) diff --git a/arch/arm/cpu/armv7/dove/mpp.c b/arch/arm/cpu/armv7/dove/mpp.c new file mode 100644 index 0000000..ed24b38 --- /dev/null +++ b/arch/arm/cpu/armv7/dove/mpp.c @@ -0,0 +1,318 @@ +/* + * Marvell Dove SoC MPP pinmux + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> +#include <asm/arch/mpp.h> +#include <asm/arch/gpio.h> + +#define MPP_BITS 4 +#define MPP_MASK 0xf +#define MPPS_PER_REG 8 + +#define MPP_NUM(_x) ((_x) & 0xff) +#define MPP_SEL(_x) (((_x) >> 8) & 0x1f) +#define MPP_GPIO(_x) ((_x) & (1 << 15)) + +#define MPP_CTRL(i) (DOVE_MPP_BASE + (i * MPP_BITS)) +#define MPP_PMU_GENERAL_CTRL (DOVE_MPP_BASE + 0x010) +#define PMUG_AUDIO0_AC97_SEL (1 << 16) +#define MPP4_CTRL (DOVE_MPP_BASE + 0x240) +#define MPP4_SDIO0_GPIO_SEL (1 << 0) +#define MPP4_SDIO1_GPIO_SEL (1 << 1) +#define MPP4_CAMERA_GPIO_SEL (1 << 2) +#define MPP4_AUDIO1_GPIO_SEL (1 << 3) +#define MPP4_UART1_GPIO_SEL (1 << 4) +#define MPP4_SPI_GPIO_SEL (1 << 5) +#define MPP_GENERAL_CTRL (DOVE_PDMA_BASE + 0x403c) +#define MPPG_NAND_GPIO_SEL (1 << 0) +#define MPPG_AUDIO1_SPDIFO_GPIO_SEL (1 << 1) +#define GENERAL_CONFIG_1 (DOVE_PDMA_BASE + 0x002c) +#define GENERAL_TWSI_MUXEN_OPTION1 (1 << 7) +#define GENERAL_CONFIG_2 (DOVE_PDMA_BASE + 0x0030) +#define GENERAL_TWSI_OPTION3_SEL (1 << 22) +#define GENERAL_TWSI_MUXEN_OPTION3 (1 << 21) +#define GENERAL_TWSI_MUXEN_OPTION2 (1 << 20) +#define SSP_CONFIG_STATUS_1 (DOVE_PDMA_BASE + 0x0034) +#define SSP_SSP_ON_AUDIO1 (1 << 0) + +/* + * MPP0-23 have standard MPP register layout + */ +static void dove_mpp_std_set(u16 config) +{ + u8 num = MPP_NUM(config); + u32 off = (num / MPPS_PER_REG) * MPP_BITS; + u32 shift = (num % MPPS_PER_REG) * MPP_BITS; + u32 reg; + + /* configure standard MPP pin */ + reg = readl(MPP_CTRL(off)); + reg &= ~(MPP_MASK << shift); + reg |= MPP_SEL(config) << shift; + writel(reg, MPP_CTRL(off)); + + /* configure gpio capabilities */ + if (MPP_GPIO(config)) + orion_gpio_set_valid(num, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + else + orion_gpio_set_valid(num, 0); +} + +/* + * MPP0-15 also allow to mux PMU functions + */ +static void dove_mpp_pmu_set(u16 config) +{ + u8 num = MPP_NUM(config); + + if (MPP_SEL(config) == PMU) { + /* enable PMU on MPP */ + writel(readl(MPP_PMU_GENERAL_CTRL) | (1 << num), + MPP_PMU_GENERAL_CTRL); + /* disable gpio capabilities */ + orion_gpio_set_valid(num, 0); + } else { + /* disable PMU on MPP */ + writel(readl(MPP_PMU_GENERAL_CTRL) & ~(1 << num), + MPP_PMU_GENERAL_CTRL); + /* configure MPP */ + dove_mpp_std_set(config); + } +} + +/* + * MPP groups on MPP4_CTRL have different register layout + * and allow GPIO or special function only + */ +static void dove_mpp4_set(u16 config) +{ + u32 reg = readl(MPP4_CTRL); + u32 mask; + u8 n, nmin, nmax; + int gpio; + + switch (MPP_NUM(config)) { + case MPP_CAMERA: + mask = MPP4_CAMERA_GPIO_SEL; + nmin = MPP_CAMERA; + nmax = MPP_CAMERA_MAX; + break; + case MPP_SDIO0: + mask = MPP4_SDIO0_GPIO_SEL; + nmin = MPP_SDIO0; + nmax = MPP_SDIO0_MAX; + break; + case MPP_SDIO1: + mask = MPP4_SDIO1_GPIO_SEL; + nmin = MPP_SDIO1; + nmax = MPP_SDIO1_MAX; + break; + case MPP_SPI: + mask = MPP4_SPI_GPIO_SEL; + nmin = MPP_SPI; + nmax = MPP_SPI_MAX; + break; + case MPP_UART1: + mask = MPP4_UART1_GPIO_SEL; + nmin = MPP_UART1; + nmax = MPP_UART1_MAX; + break; + default: + return; + } + + reg &= ~mask; + if (MPP_SEL(config)) + reg |= mask; + writel(reg, MPP4_CTRL); + + /* configure gpio capabilities */ + gpio = 0; + if (MPP_GPIO(config)) + gpio = GPIO_INPUT_OK | GPIO_OUTPUT_OK; + for (n = nmin; n <= nmax; n++) + orion_gpio_set_valid(n, gpio); +} + +/* + * MPP_GENERAL_CTRL allows GPIO on NAND pins + */ +static void dove_mpp_nand_set(u16 config) +{ + u32 reg = readl(MPP_GENERAL_CTRL); + u8 n; + int gpio; + + reg &= ~MPPG_NAND_GPIO_SEL; + if (config == MPP_NAND_GPO) + reg |= MPPG_NAND_GPIO_SEL; + writel(reg, MPP_GENERAL_CTRL); + + /* configure gpio capabilities */ + gpio = (config == MPP_NAND_GPO) ? GPIO_OUTPUT_OK : 0; + for (n = MPP_NAND; n <= MPP_NAND_MAX; n++) + orion_gpio_set_valid(n, gpio); +} + +/* + * Dedicated audio1 pins can carry i2s, spdif, ssp or twsi + * and gpio in various combinations + */ +#define AUDIO1_TWSI (1 << 0) +#define AUDIO1_SPDIFO (1 << 1) +#define AUDIO1_SSP (1 << 2) +#define AUDIO1_GPIO (1 << 3) + +static void dove_mpp_audio1_set(u16 config) +{ + u32 mpp4 = readl(MPP4_CTRL); + u32 sspc1 = readl(SSP_CONFIG_STATUS_1); + u32 gmpp = readl(MPP_GENERAL_CTRL); + u32 gcfg2 = readl(GENERAL_CONFIG_2); + u8 n, sel = MPP_SEL(config); + int gpio; + + gcfg2 &= ~GENERAL_TWSI_OPTION3_SEL; + gmpp &= ~MPPG_AUDIO1_SPDIFO_GPIO_SEL; + sspc1 &= ~SSP_SSP_ON_AUDIO1; + mpp4 &= ~MPP4_AUDIO1_GPIO_SEL; + if (sel & AUDIO1_TWSI) + gcfg2 |= GENERAL_TWSI_OPTION3_SEL; + if (sel & AUDIO1_SPDIFO) + gmpp |= MPPG_AUDIO1_SPDIFO_GPIO_SEL; + if (sel & AUDIO1_SSP) + sspc1 |= SSP_SSP_ON_AUDIO1; + if (sel & AUDIO1_GPIO) + mpp4 |= MPP4_AUDIO1_GPIO_SEL; + + writel(mpp4, MPP4_CTRL); + writel(sspc1, SSP_CONFIG_STATUS_1); + writel(gmpp, MPP_GENERAL_CTRL); + writel(gcfg2, GENERAL_CONFIG_2); + + /* gpio allows gpio on all audio1 mpp pins */ + gpio = 0; + if (config == MPP_AUDIO1_GPIO) + gpio = GPIO_INPUT_OK | GPIO_OUTPUT_OK; + + for (n = MPP_AUDIO1; n <= MPP_AUDIO1_MAX; n++) + orion_gpio_set_valid(n, gpio); + + switch (config) { + /* spdifo and twsi allow gpio on mpp[52:55] */ + case MPP_AUDIO1_SPDIFO: + case MPP_AUDIO1_TWSI: + orion_gpio_set_valid(52, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + orion_gpio_set_valid(53, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + orion_gpio_set_valid(54, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + orion_gpio_set_valid(55, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + break; + /* i2s and ssp allow gpio on mpp[56:57] */ + case MPP_AUDIO1_I2S: + case MPP_AUDIO1_SSP: + orion_gpio_set_valid(56, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + orion_gpio_set_valid(57, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + break; + } +} + +/* + * MPP PMU switches audio0 pins to ac97 or i2s0 + */ +static void dove_mpp_audio0_set(u16 config) +{ + /* switch i2s or ac97 to audio0 */ + u32 reg = readl(MPP_PMU_GENERAL_CTRL); + + reg &= ~PMUG_AUDIO0_AC97_SEL; + if (config == MPP_AUDIO0_AC97) + reg |= PMUG_AUDIO0_AC97_SEL; + writel(reg, MPP_PMU_GENERAL_CTRL); +} + +/* + * TWSI has 3 optional pin sets that can be switched during runtime + */ +static void dove_mpp_twsi_set(u16 config) +{ + u32 gcfg1 = readl(GENERAL_CONFIG_1); + u32 gcfg2 = readl(GENERAL_CONFIG_2); + + gcfg1 &= ~GENERAL_TWSI_MUXEN_OPTION1; + gcfg2 &= ~(GENERAL_TWSI_MUXEN_OPTION2 | GENERAL_TWSI_MUXEN_OPTION3); + + switch (config) { + case MPP_TWSI_OPTION1: + gcfg1 |= GENERAL_TWSI_MUXEN_OPTION1; + break; + case MPP_TWSI_OPTION2: + gcfg2 |= GENERAL_TWSI_MUXEN_OPTION2; + break; + case MPP_TWSI_OPTION3: + gcfg2 |= GENERAL_TWSI_MUXEN_OPTION3; + break; + } + + writel(gcfg1, GENERAL_CONFIG_1); + writel(gcfg2, GENERAL_CONFIG_2); +} + +void dove_mpp_conf(u16 *mpp_list) +{ + while (*mpp_list) { + u8 num = MPP_NUM(*mpp_list); + + if (num <= MPP_PMU_MAX) + dove_mpp_pmu_set(*mpp_list); + else if (num <= MPP_STD_MAX) + dove_mpp_std_set(*mpp_list); + else { + switch (num) { + case MPP_CAMERA: + case MPP_SDIO0: + case MPP_SDIO1: + case MPP_SPI: + case MPP_UART1: + dove_mpp4_set(*mpp_list); + break; + case MPP_NAND: + dove_mpp_nand_set(*mpp_list); + break; + case MPP_AUDIO0: + dove_mpp_audio0_set(*mpp_list); + break; + case MPP_AUDIO1: + dove_mpp_audio1_set(*mpp_list); + break; + case MPP_TWSI: + dove_mpp_twsi_set(*mpp_list); + break; + } + } + mpp_list++; + } +} diff --git a/arch/arm/cpu/armv7/dove/timer.c b/arch/arm/cpu/armv7/dove/timer.c new file mode 100644 index 0000000..3be9b78 --- /dev/null +++ b/arch/arm/cpu/armv7/dove/timer.c @@ -0,0 +1,176 @@ +/* + * Marvell Dove SoC timer + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/dove.h> + +#define UBOOT_CNTR 0 /* counter to use for uboot timer */ + +/* Timer reload and current value registers */ +struct dovetmr_val { + u32 reload; /* Timer reload reg */ + u32 val; /* Timer value reg */ +}; + +/* Timer registers */ +struct dovetmr_registers { + u32 ctrl; /* Timer control reg */ + u32 pad[3]; + struct dovetmr_val tmr[2]; + u32 wdt_reload; + u32 wdt_val; +}; + +struct dovetmr_registers *dovetmr_regs = + (struct dovetmr_registers *)DOVE_TIMER_BASE; + +/* + * ARM Timers Registers Map + */ +#define CNTMR_CTRL_REG &dovetmr_regs->ctrl +#define CNTMR_RELOAD_REG(tmrnum) &dovetmr_regs->tmr[tmrnum].reload +#define CNTMR_VAL_REG(tmrnum) &dovetmr_regs->tmr[tmrnum].val + +/* + * ARM Timers Control Register + * CPU_TIMERS_CTRL_REG (CTCR) + */ +#define CTCR_ARM_TIMER_EN_OFFS(cntr) (cntr * 2) +#define CTCR_ARM_TIMER_EN_MASK(cntr) (1 << CTCR_ARM_TIMER_EN_OFFS) +#define CTCR_ARM_TIMER_EN(cntr) (1 << CTCR_ARM_TIMER_EN_OFFS(cntr)) +#define CTCR_ARM_TIMER_DIS(cntr) (0 << CTCR_ARM_TIMER_EN_OFFS(cntr)) + +#define CTCR_ARM_TIMER_AUTO_OFFS(cntr) ((cntr * 2) + 1) +#define CTCR_ARM_TIMER_AUTO_MASK(cntr) (1 << 1) +#define CTCR_ARM_TIMER_AUTO_EN(cntr) (1 << CTCR_ARM_TIMER_AUTO_OFFS(cntr)) +#define CTCR_ARM_TIMER_AUTO_DIS(cntr) (0 << CTCR_ARM_TIMER_AUTO_OFFS(cntr)) + +/* + * ARM Timer\Watchdog Reload Register + * CNTMR_RELOAD_REG (TRR) + */ +#define TRG_ARM_TIMER_REL_OFFS 0 +#define TRG_ARM_TIMER_REL_MASK 0xffffffff + +/* + * ARM Timer\Watchdog Register + * CNTMR_VAL_REG (TVRG) + */ +#define TVR_ARM_TIMER_OFFS 0 +#define TVR_ARM_TIMER_MASK 0xffffffff +#define TVR_ARM_TIMER_MAX 0xffffffff +#define TIMER_LOAD_VAL 0xffffffff + +#define READ_TIMER (readl(CNTMR_VAL_REG(UBOOT_CNTR)) / \ + (CONFIG_SYS_TCLK / 1000)) + +DECLARE_GLOBAL_DATA_PTR; + +#define timestamp gd->tbl +#define lastdec gd->lastinc + +ulong get_timer_masked(void) +{ + ulong now = READ_TIMER; + + if (lastdec >= now) { + /* normal mode */ + timestamp += lastdec - now; + } else { + /* we have an overflow ... */ + timestamp += lastdec + + (TIMER_LOAD_VAL / (CONFIG_SYS_TCLK / 1000)) - now; + } + lastdec = now; + + return timestamp; +} + +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +void __udelay(unsigned long usec) +{ + uint current; + ulong delayticks; + + current = readl(CNTMR_VAL_REG(UBOOT_CNTR)); + delayticks = (usec * (CONFIG_SYS_TCLK / 1000000)); + + if (current < delayticks) { + delayticks -= current; + do {} while (readl(CNTMR_VAL_REG(UBOOT_CNTR)) < current); + do {} while ((TIMER_LOAD_VAL - delayticks) < + readl(CNTMR_VAL_REG(UBOOT_CNTR))); + } else { + do {} while (readl(CNTMR_VAL_REG(UBOOT_CNTR)) > + (current - delayticks)); + } +} + +/* + * init the counter + */ +int timer_init(void) +{ + unsigned int cntmrctrl; + + /* load value into timer */ + writel(TIMER_LOAD_VAL, CNTMR_RELOAD_REG(UBOOT_CNTR)); + writel(TIMER_LOAD_VAL, CNTMR_VAL_REG(UBOOT_CNTR)); + + /* enable timer in auto reload mode */ + cntmrctrl = readl(CNTMR_CTRL_REG); + cntmrctrl |= CTCR_ARM_TIMER_EN(UBOOT_CNTR); + cntmrctrl |= CTCR_ARM_TIMER_AUTO_EN(UBOOT_CNTR); + writel(cntmrctrl, CNTMR_CTRL_REG); + + /* init the timestamp and lastdec value */ + lastdec = READ_TIMER; + timestamp = 0; + + return 0; +} + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On ARM it just returns the timer value. + */ +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + return (ulong)CONFIG_SYS_HZ; +} diff --git a/arch/arm/cpu/armv7/dove/usb.c b/arch/arm/cpu/armv7/dove/usb.c new file mode 100644 index 0000000..1b932db --- /dev/null +++ b/arch/arm/cpu/armv7/dove/usb.c @@ -0,0 +1,101 @@ +/* + * Marvell Dove SoC USB PHY init + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> + +/* Dove USB2.0 PHY registers */ +#define USB20_POWER_CTRL ((base) + 0x400) +#define USB20_PHY_PLL_CTRL ((base) + 0x410) +#define PHY_PLL_VCO_RECALIBRATE (1 << 21) +#define USB20_PHY_TX_CTRL ((base) + 0x420) +#define PHY_TX_HS_STRESS_CTRL (1 << 31) +#define PHY_TX_BLOCK_EN (1 << 21) +#define PHY_TX_IMP_CAL_VTH(x) (x << 14) +#define PHY_TX_IMP_CAL_VTH_MASK PHY_TX_IMP_CAL_VTH(0x7) +#define PHY_TX_RCAL_START (1 << 12) +#define PHY_TX_LOWVDD_EN (1 << 11) +#define USB20_PHY_RX_CTRL ((base) + 0x430) +#define PHY_RX_EDGE_DET(x) (x << 26) +#define PHY_RX_EDGE_DET_MASK PHY_RX_EDGE_DET(0x3) +#define PHY_RX_CDR_FASTLOCK_EN (1 << 21) +#define PHY_RX_SQ_LENGTH(x) (x << 15) +#define PHY_RX_SQ_LENGTH_MASK PHY_RX_SQ_LENGTH(0x3) +#define PHY_RX_SQ_THRESH(x) (x << 4) +#define PHY_RX_SQ_THRESH_MASK PHY_RX_SQ_THRESH(0xf) +#define PHY_RX_LPF_COEFF(x) (x << 2) +#define PHY_RX_LPF_COEFF_MASK PHY_RX_LPF_COEFF(0x3) +#define USB20_PHY_IVREF_CTRL ((base) + 0x440) +#define PHY_IVREF_TXVDD12(x) (x << 8) +#define PHY_IVREF_TXVDD12_MASK PHY_IVREF_TXVDD12(0x3) +#define USB20_PHY_TESTGRP_CTRL ((base) + 0x450) +#define PHY_TESTGRP_SQ_RST (1 << 15) + +void dove_ehci_phy_init(int port) +{ + u32 base = (port == 0) ? DOVE_USB20_0_BASE : DOVE_USB20_1_BASE; + u32 reg; + + /* USB PHY PLL control */ + reg = readl(USB20_PHY_PLL_CTRL); + writel(reg | PHY_PLL_VCO_RECALIBRATE, USB20_PHY_PLL_CTRL); + udelay(100); + writel(reg & ~PHY_PLL_VCO_RECALIBRATE, USB20_PHY_PLL_CTRL); + + /* USB PHY Tx control */ + reg = readl(USB20_PHY_TX_CTRL); + reg &= ~PHY_TX_IMP_CAL_VTH_MASK; + reg |= PHY_TX_IMP_CAL_VTH(0x5); + reg |= PHY_TX_LOWVDD_EN; + reg |= PHY_TX_RCAL_START; + reg |= PHY_TX_BLOCK_EN; + reg |= PHY_TX_HS_STRESS_CTRL; + writel(reg, USB20_PHY_TX_CTRL); + udelay(100); + writel(reg & ~PHY_TX_RCAL_START, USB20_PHY_TX_CTRL); + + /* USB PHY RX control */ + reg = readl(USB20_PHY_RX_CTRL); + reg &= ~(PHY_RX_LPF_COEFF_MASK | PHY_RX_SQ_THRESH_MASK | + PHY_RX_SQ_LENGTH_MASK | PHY_RX_EDGE_DET_MASK); + reg |= PHY_RX_LPF_COEFF(0x1); + reg |= PHY_RX_SQ_THRESH(0xc); + reg |= PHY_RX_SQ_LENGTH(0x1); + reg |= PHY_RX_EDGE_DET(0x0); + reg &= ~PHY_RX_CDR_FASTLOCK_EN; + writel(reg, USB20_PHY_RX_CTRL); + + /* USB PHY IVREF control */ + reg = readl(USB20_PHY_IVREF_CTRL); + reg &= ~PHY_IVREF_TXVDD12_MASK; + reg |= PHY_IVREF_TXVDD12(0x3); + writel(reg, USB20_PHY_IVREF_CTRL); + + /* USB PHY TEST GROUP control */ + reg = readl(USB20_PHY_TESTGRP_CTRL); + reg &= ~PHY_TESTGRP_SQ_RST; + writel(reg, USB20_PHY_TESTGRP_CTRL); +} diff --git a/arch/arm/include/asm/arch-dove/config.h b/arch/arm/include/asm/arch-dove/config.h new file mode 100644 index 0000000..2d94a48 --- /dev/null +++ b/arch/arm/include/asm/arch-dove/config.h @@ -0,0 +1,153 @@ +/* + * Marvell SoC config + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVE_CONFIG_H +#define _DOVE_CONFIG_H + +#include <asm/arch/dove.h> + +#define CONFIG_ARMV7 /* Basic Architecture */ +#define CONFIG_DOVE /* SOC Family Name */ +#define CONFIG_SHEEVA_88SV581 /* CPU Core subversion */ +#define CONFIG_SYS_CACHELINE_SIZE 32 + /* default Dcache Line length for Dove */ +#define CONFIG_SYS_ARM_CACHE_WRITETHROUGH +#define CONFIG_SYS_DCACHE_OFF /* Disable DCache by default */ + +/* + * By default kwbimage.cfg from board specific folder is used + * If for some board, different configuration file need to be used, + * CONFIG_SYS_KWD_CONFIG should be defined in board specific header file + */ +#ifndef CONFIG_SYS_KWD_CONFIG +#define CONFIG_SYS_KWD_CONFIG $(SRCTREE)/$(CONFIG_BOARDDIR)/kwbimage.cfg +#endif /* CONFIG_SYS_KWD_CONFIG */ + +/* Dove has 2k of Security SRAM, use it for SP */ +#define CONFIG_SYS_INIT_SP_ADDR 0xC8012000 +#define CONFIG_NR_DRAM_BANKS_MAX 2 + +#define CONFIG_I2C_MVTWSI_BASE DOVE_TWSI_BASE +#define MV_UART_CONSOLE_BASE DOVE_UART0_BASE +#define MV_SATA_BASE DOVE_SATA_BASE +#define MV_SATA_PORT0_OFFSET DOVE_SATA_PORT0_OFFSET + +/* + * NAND configuration + */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_KIRKWOOD 1 +#define CONFIG_SYS_NAND_BASE 0xD8000000 /* MV_DEFADR_NANDF */ +#define NAND_ALLOW_ERASE_ALL 1 +#endif + +/* + * SPI Flash configuration + */ +#ifdef CONFIG_CMD_SF +#define CONFIG_HARD_SPI 1 +#define CONFIG_ORION_SPI 1 +#define ORION_SPI_BASE DOVE_SPI_BASE +#ifndef CONFIG_ENV_SPI_BUS +# define CONFIG_ENV_SPI_BUS 0 +#endif +#ifndef CONFIG_ENV_SPI_CS +# define CONFIG_ENV_SPI_CS 0 +#endif +#ifndef CONFIG_ENV_SPI_MAX_HZ +# define CONFIG_ENV_SPI_MAX_HZ 25000000 +#endif +#endif + +/* + * Ethernet Driver configuration + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_CMD_MII +#define CONFIG_NETCONSOLE /* include NetConsole support */ +#define CONFIG_PHYLIB +#define CONFIG_MVGBE /* Enable Marvell Gbe Controller Driver */ +#define CONFIG_SYS_FAULT_ECHO_LINK_DOWN /* detect link using phy */ +#define CONFIG_ENV_OVERWRITE /* ethaddr can be reprogrammed */ +#endif /* CONFIG_CMD_NET */ + +/* + * SDHCI + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_MMC +#define CONFIG_MMC_SDMA +#define CONFIG_SDHCI +#define CONFIG_DOVE_SDHCI /* Enable Dove SDHCI controller driver */ +#define CONFIG_MMC_SDHCI_IO_ACCESSORS +#define CONFIG_SYS_MMC_MAX_DEVICE 2 +#endif + +/* + * USB/EHCI + */ +#ifdef CONFIG_CMD_USB +#define CONFIG_USB_EHCI_MARVELL +#define CONFIG_EHCI_IS_TDI +#endif /* CONFIG_CMD_USB */ + +/* + * IDE Support on SATA ports + */ +#ifdef CONFIG_CMD_IDE +#define __io +#define CONFIG_CMD_EXT2 +#define CONFIG_MVSATA_IDE +#define CONFIG_IDE_PREINIT +#define CONFIG_MVSATA_IDE_USE_PORT1 +/* Needs byte-swapping for ATA data register */ +#define CONFIG_IDE_SWAP_IO +/* Data, registers and alternate blocks are at the same offset */ +#define CONFIG_SYS_ATA_DATA_OFFSET (0x0100) +#define CONFIG_SYS_ATA_REG_OFFSET (0x0100) +#define CONFIG_SYS_ATA_ALT_OFFSET (0x0100) +/* Each 8-bit ATA register is aligned to a 4-bytes address */ +#define CONFIG_SYS_ATA_STRIDE 4 +/* Controller supports 48-bits LBA addressing */ +#define CONFIG_LBA48 +/* CONFIG_CMD_IDE requires some #defines for ATA registers */ +#define CONFIG_SYS_IDE_MAXBUS 2 +#define CONFIG_SYS_IDE_MAXDEVICE 2 +/* ATA registers base is at SATA controller base */ +#define CONFIG_SYS_ATA_BASE_ADDR MV_SATA_BASE +#endif /* CONFIG_CMD_IDE */ + +/* + * I2C related stuff + */ +#ifdef CONFIG_CMD_I2C +#ifndef CONFIG_SOFT_I2C +#define CONFIG_I2C_MVTWSI +#endif +#define CONFIG_SYS_I2C_SLAVE 0x0 +#define CONFIG_SYS_I2C_SPEED 100000 +#endif + +#endif /* _DOVE_CONFIG_H */ diff --git a/arch/arm/include/asm/arch-dove/cpu.h b/arch/arm/include/asm/arch-dove/cpu.h new file mode 100644 index 0000000..718dd59 --- /dev/null +++ b/arch/arm/include/asm/arch-dove/cpu.h @@ -0,0 +1,204 @@ +/* + * Marvell Dove SoC CPU + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVECPU_H +#define _DOVECPU_H + +#include <asm/system.h> + +#ifndef __ASSEMBLY__ + +#define DOVECPU_WIN_CTRL_DATA(size, target, attr, en) (en | (target << 4) \ + | (attr << 8) | (dove_winctrl_calcsize(size) << 16)) + +#define DOVEGBE_PORT_SERIAL_CONTROL1_REG (DOVE_EGIGA_BASE + 0x44c) +#define DOVE_REG_PCIE_DEVID (DOVE_REG_PCIE0_BASE + 0x00) +#define DOVE_REG_PCIE_REVID (DOVE_REG_PCIE0_BASE + 0x08) +#define DOVE_REG_SYSRST_CNT (DOVE_MPP_BASE + 0x50) +#define SYSRST_CNT_1SEC_VAL (25*1000000) +#define DOVE_REG_MPP_OUT_DRV_REG (DOVE_MPP_BASE + 0xE0) + +enum memory_bank { + BANK0, + BANK1, +}; + +enum dovecpu_winen { + DOVECPU_WIN_DISABLE, + DOVECPU_WIN_ENABLE +}; + +enum dovecpu_target { + DOVECPU_TARGET_DRAM = 0x0, + DOVECPU_TARGET_SASRAM = 0x3, + DOVECPU_TARGET_NAND = 0xc, + DOVECPU_TARGET_PMURAM = 0xd, + DOVECPU_TARGET_PCIE0 = 0x4, + DOVECPU_TARGET_PCIE1 = 0x8, + DOVECPU_TARGET_SPI = 0x1, + DOVECPU_TARGET_BOOTROM = 0x1, +}; + +enum dovecpu_attrib { + DOVECPU_ATTR_DRAM = 0x00, + DOVECPU_ATTR_SASRAM = 0x00, + DOVECPU_ATTR_NAND = 0x00, + DOVECPU_ATTR_PMURAM = 0x00, + DOVECPU_ATTR_PCIE_IO = 0xe0, + DOVECPU_ATTR_PCIE_MEM = 0xe8, + DOVECPU_ATTR_SPI0 = 0xfe, + DOVECPU_ATTR_SPI1 = 0xfb, + DOVECPU_ATTR_BOOTROM = 0xfd, +}; + +enum dovecpu_part { + DOVECPU_PART_SHEEVA = 0x581, +}; + +enum dovesoc_devid { + DOVESOC_DEVID_F6781 = 0x6781, + DOVESOC_DEVID_AP510 = 0x0510, +}; + +enum dovesoc_revid { + DOVESOC_REVID_Z0 = 0, + DOVESOC_REVID_Z1 = 1, + DOVESOC_REVID_Y0 = 2, + DOVESOC_REVID_Y1 = 3, + DOVESOC_REVID_X0 = 4, + DOVESOC_REVID_A0 = 6, + DOVESOC_REVID_A1 = 7, +}; + +/* + * Default Device Address MAP BAR values + */ +#define DOVE_DEFADR_PCIE0_MEM 0xe0000000 +#define DOVE_DEFADR_PCIE0_IO 0xf2000000 +#define DOVE_DEFADR_PCIE0_IO_REMAP 0x00000000 +#define DOVE_DEFADR_PCIE1_MEM 0xe8000000 +#define DOVE_DEFADR_PCIE1_IO 0xf2100000 +#define DOVE_DEFADR_PCIE1_IO_REMAP 0x00100000 +#define DOVE_DEFADR_SASRAM 0xc8000000 +#define DOVE_DEFADR_BOOTROM 0xf8000000 +#define DOVE_DEFADR_PMURAM 0xf0000000 + +/* + * ARM CPUID register + */ +#define ARM_ID_REVISION_OFFSET 0 +#define ARM_ID_REVISION_MASK 0xf +#define ARM_ID_PARTNUM_OFFSET 4 +#define ARM_ID_PARTNUM_MASK 0xfff +#define ARM_ID_ARCH_OFFSET 16 +#define ARM_ID_ARCH_MASK 0xf +#define ARM_ID_VAR_OFFSET 20 +#define ARM_ID_VAR_MASK 0xf +#define ARM_ID_ASCII_OFFSET 24 +#define ARM_ID_ASCII_MASK 0xff + +/* + * read feroceon/sheeva core extra feature register + * using co-proc instruction + */ +static inline unsigned int readfr_extra_feature_reg(void) +{ + unsigned int val; + asm volatile ("mrc p15, 1, %0, c15, c1, 0 @ readfr exfr" : "=r" + (val) : : "cc"); + return val; +} + +/* + * write feroceon/sheeva core extra feature register + * using co-proc instruction + */ +static inline void writefr_extra_feature_reg(unsigned int val) +{ + asm volatile ("mcr p15, 1, %0, c15, c1, 0 @ writefr exfr" : : "r" + (val) : "cc"); + isb(); +} + +/* + * Downstream Bridge Registers + */ +struct dovewin_registers { + u32 ctrl; + u32 base; + u32 remap_lo; + u32 remap_hi; +}; + +/* + * CPU control and status Registers + */ +struct dovecpu_registers { + u32 config; /* 0x20100 */ + u32 ctrl_stat; /* 0x20104 */ + u32 rstoutn_mask; /* 0x20108 */ + u32 sys_soft_rst; /* 0x2010C */ + u32 bridge_cause_irq; /* 0x20110 */ + u32 bridge_mask_irq; /* 0x20114 */ + u32 pad1; + u32 pmu_ctrl; /* 0x2011c */ +}; + +/* + * GPIO 0/1 Registers + * GPIO 2 Registers (no datain/irq) + */ +struct dovegpio_registers { + u32 dout; + u32 oe; + u32 blink_en; + u32 din_pol; + u32 din; + u32 irq_cause; + u32 irq_mask; + u32 irq_level; +}; + +struct dove_gpio_init { + u32 val0; + u32 val1; + u32 val2; + u32 oe0_n; + u32 oe1_n; + u32 oe2_n; +}; + +/* + * functions + */ +void reset_cpu(unsigned long ignored); +unsigned char get_random_hex(void); +u32 dove_dram_start(enum memory_bank bank); +u32 dove_dram_size(enum memory_bank bank); +int dove_config_adr_windows(void); +void dove_init_gpio(struct dove_gpio_init *); +unsigned int dove_winctrl_calcsize(unsigned int sizeval); + +#endif /* __ASSEMBLY__ */ +#endif /* _DOVECPU_H */ diff --git a/arch/arm/include/asm/arch-dove/dove.h b/arch/arm/include/asm/arch-dove/dove.h new file mode 100644 index 0000000..da5011b --- /dev/null +++ b/arch/arm/include/asm/arch-dove/dove.h @@ -0,0 +1,93 @@ +/* + * Marvell Dove SoC register offsets and config + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVE_H +#define _DOVE_H + +/* Dove TCLK is fixed to 166MHz */ +#define CONFIG_SYS_TCLK 166666667 + +/* SOC specific definitions */ +#define DOVE_PREMAP_REGS_PHYS_BASE 0xd0000000 +#define DOVE_PREMAP_INT_REGS_BASE_ADDR (DOVE_PREMAP_REGS_PHYS_BASE + 0x20080) +#define DOVE_PREMAP_MC_DECODE_REG (DOVE_PREMAP_REGS_PHYS_BASE + 0x800010) + +#define DOVE_SB_REGS_PHYS_BASE 0xf1000000 +#define DOVE_NB_REGS_PHYS_BASE 0xf1800000 +#define DOVE_REGISTER(x) (DOVE_SB_REGS_PHYS_BASE + x) + +#define DOVE_AXI_CTRL_REG (DOVE_REGISTER(0xd0224)) +#define DOVE_CPU_CTRL_REG (DOVE_REGISTER(0xd025c)) +#define DOVE_MC_CTRL_REG (DOVE_REGISTER(0xd0260)) +#define DOVE_MC_DECODE_REG (DOVE_REGISTER(0x800010)) + +#define DOVE_SPI_BASE (DOVE_REGISTER(0x10600)) +#define DOVE_TWSI_BASE (DOVE_REGISTER(0x11000)) +#define DOVE_UART0_BASE (DOVE_REGISTER(0x12000)) +#define DOVE_UART1_BASE (DOVE_REGISTER(0x12100)) +#define DOVE_UART2_BASE (DOVE_REGISTER(0x12200)) +#define DOVE_UART3_BASE (DOVE_REGISTER(0x12300)) +#define DOVE_CPU_WIN_BASE (DOVE_REGISTER(0x20000)) +#define DOVE_CPU_REG_BASE (DOVE_REGISTER(0x20100)) +#define DOVE_TIMER_BASE (DOVE_REGISTER(0x20300)) +#define DOVE_REG_PCIE0_BASE (DOVE_REGISTER(0x40000)) +#define DOVE_REG_PCIE1_BASE (DOVE_REGISTER(0x80000)) +#define DOVE_USB20_0_BASE (DOVE_REGISTER(0x50000)) +#define DOVE_USB20_1_BASE (DOVE_REGISTER(0x51000)) +#define DOVE_EGIGA_BASE (DOVE_REGISTER(0x72000)) +#define DOVE_SDIO1_BASE (DOVE_REGISTER(0x90000)) +#define DOVE_SDIO0_BASE (DOVE_REGISTER(0x92000)) +#define DOVE_CAMERA_BASE (DOVE_REGISTER(0x94000)) +#define DOVE_SATA_BASE (DOVE_REGISTER(0xa0000)) +#define DOVE_NANDF_BASE (DOVE_REGISTER(0xc0000)) +#define DOVE_PMU_BASE (DOVE_REGISTER(0xd0000)) +#define DOVE_MPP_BASE (DOVE_REGISTER(0xd0200)) +#define DOVE_GPIO0_BASE (DOVE_REGISTER(0xd0400)) +#define DOVE_GPIO1_BASE (DOVE_REGISTER(0xd0420)) +#define DOVE_RTC_BASE (DOVE_REGISTER(0xd8500)) +#define DOVE_AC97_BASE (DOVE_REGISTER(0xe0000)) +#define DOVE_PDMA_BASE (DOVE_REGISTER(0xe4000)) +#define DOVE_GPIO2_BASE (DOVE_REGISTER(0xe8400)) +#define DOVE_SSP_BASE (DOVE_REGISTER(0xec000)) + +/* Dove Sata controller has one port */ +#define DOVE_SATA_PORT0_OFFSET 0x2000 + +/* Dove GbE controller has one port */ +#define MAX_MVGBE_DEVS 1 +#define MVGBE0_BASE DOVE_EGIGA_BASE + +/* Dove USB Host controller */ +#define MVUSB0_BASE DOVE_USB20_0_BASE +#define MVUSB0_CPU_ATTR_DRAM_CS0 DOVECPU_ATTR_DRAM +#define MVUSB0_CPU_ATTR_DRAM_CS1 DOVECPU_ATTR_DRAM +#define MVUSB0_CPU_ATTR_DRAM_CS2 DOVECPU_WIN_DISABLE +#define MVUSB0_CPU_ATTR_DRAM_CS3 DOVECPU_WIN_DISABLE + +/* Dove CPU memory windows */ +#define MVCPU_WIN_CTRL_DATA DOVECPU_WIN_CTRL_DATA +#define MVCPU_WIN_ENABLE DOVECPU_WIN_ENABLE +#define MVCPU_WIN_DISABLE DOVECPU_WIN_DISABLE + +#endif diff --git a/arch/arm/include/asm/arch-dove/gpio.h b/arch/arm/include/asm/arch-dove/gpio.h new file mode 100644 index 0000000..71bef8e --- /dev/null +++ b/arch/arm/include/asm/arch-dove/gpio.h @@ -0,0 +1,35 @@ +/* + * Marvell Dove SoC gpio + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef __DOVE_GPIO_H +#define __DOVE_GPIO_H + +#include <orion_gpio.h> + +#define GPIO_MAX 70 +#define GPIO_BASE(pin) (((pin) >= 64) ? DOVE_GPIO2_BASE : \ + ((pin) >= 32) ? DOVE_GPIO1_BASE : \ + DOVE_GPIO0_BASE) + +#endif diff --git a/arch/arm/include/asm/arch-dove/mpp.h b/arch/arm/include/asm/arch-dove/mpp.h new file mode 100644 index 0000000..1279ac2 --- /dev/null +++ b/arch/arm/include/asm/arch-dove/mpp.h @@ -0,0 +1,283 @@ +/* + * Marvell Dove SoC pinmux + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVE_MPP_H +#define _DOVE_MPP_H + +#define DOVE_GPI (1 << 0) +#define DOVE_GPO (1 << 1) +#define DOVE_GPIO (DOVE_GPO | DOVE_GPI) + +#define MPP(_num, _sel, _gpio) ( \ + /* MPP number */ ((_num) & 0xff) | \ + /* MPP select value */ (((_sel) & 0x1f) << 8) | \ + /* is gpio config */ ((!!(_gpio)) << 15)) + +/* MPP0-15 allow PMU function */ +#define MPP_PMU_MAX 15 +#define PMU (0x10) +/* MPP0-23 have standard mpp register layout */ +#define MPP_STD_MAX 23 + +#define MPP0 0 +#define MPP0_GPIO MPP(0, 0x0, 1) +#define MPP0_UART2_RTS MPP(0, 0x2, 0) +#define MPP0_SDIO0_CD MPP(0, 0x3, 0) +#define MPP0_LCD0_PWM MPP(0, 0xf, 0) +#define MPP0_PMU MPP(0, PMU, 0) + +#define MPP1 1 +#define MPP1_GPIO MPP(1, 0x0, 1) +#define MPP1_UART2_CTS MPP(1, 0x2, 0) +#define MPP1_SDIO0_WP MPP(1, 0x3, 0) +#define MPP1_LCD1_PWM MPP(1, 0xf, 0) +#define MPP1_PMU MPP(1, PMU, 0) + +#define MPP2 2 +#define MPP2_GPIO MPP(2, 0x0, 1) +#define MPP2_SATA_PRSNT MPP(2, 0x1, 0) +#define MPP2_UART2_TXD MPP(2, 0x2, 0) +#define MPP2_SDIO0_BUSPWR MPP(2, 0x3, 0) +#define MPP2_UART1_RTS MPP(2, 0x4, 0) +#define MPP2_PMU MPP(2, PMU, 0) + +#define MPP3 3 +#define MPP3_GPIO MPP(3, 0x0, 1) +#define MPP3_SATA_ACT MPP(3, 0x1, 0) +#define MPP3_UART2_RXD MPP(3, 0x2, 0) +#define MPP3_SDIO0_LEDCTRL MPP(3, 0x3, 0) +#define MPP3_UART1_CTS MPP(3, 0x4, 0) +#define MPP3_LCD_SPI_CS1 MPP(3, 0xf, 0) +#define MPP3_PMU MPP(3, PMU, 0) + +#define MPP4 4 +#define MPP4_GPIO MPP(4, 0x0, 1) +#define MPP4_UART3_RTS MPP(4, 0x2, 0) +#define MPP4_SDIO1_CD MPP(4, 0x3, 0) +#define MPP4_SPI1_MISO MPP(4, 0x4, 0) +#define MPP4_PMU MPP(4, PMU, 0) + +#define MPP5 5 +#define MPP5_GPIO MPP(5, 0x0, 1) +#define MPP5_UART3_CTS MPP(5, 0x2, 0) +#define MPP5_SDIO1_WP MPP(5, 0x3, 0) +#define MPP5_SPI1_CS MPP(5, 0x4, 0) +#define MPP5_PMU MPP(5, PMU, 0) + +#define MPP6 6 +#define MPP6_GPIO MPP(6, 0x0, 1) +#define MPP6_UART3_TXD MPP(6, 0x2, 0) +#define MPP6_SDIO1_BUSPWR MPP(6, 0x3, 0) +#define MPP6_SPI1_MOSI MPP(6, 0x4, 0) +#define MPP6_PMU MPP(6, PMU, 0) + +#define MPP7 7 +#define MPP7_GPIO MPP(7, 0x0, 1) +#define MPP7_UART3_RXD MPP(7, 0x2, 0) +#define MPP7_SDIO1_LEDCTRL MPP(7, 0x3, 0) +#define MPP7_SPI1_SCK MPP(7, 0x4, 0) +#define MPP7_PMU MPP(7, PMU, 0) + +#define MPP8 8 +#define MPP8_GPIO MPP(8, 0x0, 1) +#define MPP8_WATCHDOG_RSTOUT MPP(8, 0x1, 0) +#define MPP8_PMU MPP(8, PMU, 0) + +#define MPP9 9 +#define MPP9_GPIO MPP(9, 0x0, 1) +#define MPP9_PEX1_CLKREQ MPP(9, 0x5, 0) +#define MPP9_PMU MPP(9, PMU, 0) + +#define MPP10 10 +#define MPP10_GPIO MPP(10, 0x0, 1) +#define MPP10_SSP_SCLK MPP(10, 0x5, 0) +#define MPP10_PMU MPP(10, PMU, 0) + +#define MPP11 11 +#define MPP11_GPIO MPP(11, 0x0, 1) +#define MPP11_SATA_PRSNT MPP(11, 0x1, 0) +#define MPP11_SATA_ACT MPP(11, 0x2, 0) +#define MPP11_SDIO0_LEDCTRL MPP(11, 0x3, 0) +#define MPP11_SDIO1_LEDCTRL MPP(11, 0x4, 0) +#define MPP11_PEX0_CLKREQ MPP(11, 0x5, 0) +#define MPP11_PMU MPP(11, PMU, 0) + +#define MPP12 12 +#define MPP12_GPIO MPP(12, 0x0, 1) +#define MPP12_SATA_ACT MPP(12, 0x1, 0) +#define MPP12_UART2_RTS MPP(12, 0x2, 0) +#define MPP12_AUDIO0_EXTCLK MPP(12, 0x3, 0) +#define MPP12_SDIO1_CD MPP(12, 0x4, 0) +#define MPP12_PMU MPP(12, PMU, 0) + +#define MPP13 13 +#define MPP13_GPIO MPP(13, 0x0, 1) +#define MPP13_UART2_CTS MPP(13, 0x2, 0) +#define MPP13_AUDIO1_EXTCLK MPP(13, 0x3, 0) +#define MPP13_SDIO1_WP MPP(13, 0x4, 0) +#define MPP13_SSP_EXTCLK MPP(13, 0x5, 0) +#define MPP13_PMU MPP(13, PMU, 0) + +#define MPP14 14 +#define MPP14_GPIO MPP(14, 0x0, 1) +#define MPP14_UART2_TXD MPP(14, 0x2, 0) +#define MPP14_SDIO1_BUSPWR MPP(14, 0x4, 0) +#define MPP14_SSP_TXD MPP(14, 0x5, 0) +#define MPP14_PMU MPP(14, PMU, 0) + +#define MPP15 15 +#define MPP15_GPIO MPP(15, 0x0, 1) +#define MPP15_UART2_RXD MPP(15, 0x2, 0) +#define MPP15_SDIO1_LEDCTRL MPP(15, 0x4, 0) +#define MPP15_SSP_SFRM MPP(15, 0x5, 0) +#define MPP15_PMU MPP(15, PMU, 0) + +#define MPP16 16 +#define MPP16_GPIO MPP(16, 0x0, 1) +#define MPP16_UART3_RTS MPP(16, 0x2, 0) +#define MPP16_SDIO0_CD MPP(16, 0x3, 0) +#define MPP16_LCD_SPI_CS1 MPP(16, 0x4, 0) +#define MPP16_AC97_SDI1 MPP(16, 0x5, 0) + +#define MPP17 17 +#define MPP17_GPIO MPP(17, 0x0, 1) +#define MPP17_AC97_SYSCLKO MPP(17, 0x1, 0) +#define MPP17_UART3_CTS MPP(17, 0x2, 0) +#define MPP17_SDIO0_WP MPP(17, 0x3, 0) +#define MPP17_TWSI_SDA MPP(17, 0x4, 0) +#define MPP17_AC97_SDI2 MPP(17, 0x5, 0) + +#define MPP18 18 +#define MPP18_GPIO MPP(18, 0x0, 1) +#define MPP18_UART3_TXD MPP(18, 0x2, 0) +#define MPP18_SDIO0_BUSPWR MPP(18, 0x3, 0) +#define MPP18_LCD0_PWM MPP(18, 0x4, 0) +#define MPP18_AC97_SDI3 MPP(18, 0x5, 0) + +#define MPP19 19 +#define MPP19_GPIO MPP(19, 0x0, 1) +#define MPP19_UART3_RXD MPP(19, 0x2, 0) +#define MPP19_SDIO0_LEDCTRL MPP(19, 0x3, 0) +#define MPP19_TWSI_SCK MPP(19, 0x4, 0) + +#define MPP20 20 +#define MPP20_GPIO MPP(20, 0x0, 1) +#define MPP20_AC97_SYSCLKO MPP(20, 0x1, 0) +#define MPP20_LCD_SPI_MISO MPP(20, 0x2, 0) +#define MPP20_SDIO1_CD MPP(20, 0x3, 0) +#define MPP20_SDIO0_CD MPP(20, 0x5, 0) +#define MPP20_SPI1_MISO MPP(20, 0x6, 0) + +#define MPP21 21 +#define MPP21_GPIO MPP(21, 0x0, 1) +#define MPP21_UART1_RTS MPP(21, 0x1, 0) +#define MPP21_LCD_SPI_CS0 MPP(21, 0x2, 0) +#define MPP21_SDIO1_WP MPP(21, 0x3, 0) +#define MPP21_SSP_SFRM MPP(21, 0x4, 0) +#define MPP21_SDIO0_WP MPP(21, 0x5, 0) +#define MPP21_SPI1_CS MPP(21, 0x6, 0) + +#define MPP22 22 +#define MPP22_GPIO MPP(22, 0x0, 1) +#define MPP22_UART1_CTS MPP(22, 0x1, 0) +#define MPP22_LCD_SPI_MOSI MPP(22, 0x2, 0) +#define MPP22_SDIO1_BUSPWR MPP(22, 0x3, 0) +#define MPP22_SSP_TXD MPP(22, 0x4, 0) +#define MPP22_SDIO0_BUSPWR MPP(22, 0x5, 0) +#define MPP22_SPI1_MOSI MPP(22, 0x6, 0) + +#define MPP23 23 +#define MPP23_GPIO MPP(23, 0x0, 1) +#define MPP23_LCD_SPI_SCK MPP(23, 0x2, 0) +#define MPP23_SDIO1_LEDCTRL MPP(23, 0x3, 0) +#define MPP23_SSP_SCLK MPP(23, 0x4, 0) +#define MPP23_SDIO0_LEDCTRL MPP(23, 0x5, 0) +#define MPP23_SPI1_SCK MPP(23, 0x6, 0) + +/* MPP_CAMERA = MPP[24:39] */ +#define MPP_CAMERA 24 +#define MPP_CAMERA_CAMERA MPP(24, 0x0, 0) +#define MPP_CAMERA_GPIO MPP(24, 0x1, 1) +#define MPP_CAMERA_MAX 39 + +/* MPP_SDIO0 = MPP[40:45] */ +#define MPP_SDIO0 40 +#define MPP_SDIO0_SDIO MPP(40, 0x0, 0) +#define MPP_SDIO0_GPIO MPP(40, 0x1, 1) +#define MPP_SDIO0_MAX 45 + +/* MPP_SDIO1 = MPP[46:51] */ +#define MPP_SDIO1 46 +#define MPP_SDIO1_SDIO MPP(46, 0x0, 0) +#define MPP_SDIO1_GPIO MPP(46, 0x1, 1) +#define MPP_SDIO1_MAX 51 + +/* MPP_AUDIO1 = MPP[52:57] */ +#define MPP_AUDIO1 52 +#define MPP_AUDIO1_I2S_SPDIFO MPP(52, 0x0, 0) +#define MPP_AUDIO1_I2S MPP(52, 0x2, 0) +#define MPP_AUDIO1_SPDIFO MPP(52, 0x8, 0) +#define MPP_AUDIO1_GPIO MPP(52, 0xa, 1) +#define MPP_AUDIO1_TWSI MPP(52, 0xb, 0) +#define MPP_AUDIO1_SSP_SPDIFO MPP(52, 0xc, 0) +#define MPP_AUDIO1_SSP MPP(52, 0xe, 0) +#define MPP_AUDIO1_SSP_TWSI MPP(52, 0xf, 0) +#define MPP_AUDIO1_MAX 57 + +/* MPP_SPI = MPP[58:61] */ +#define MPP_SPI 58 +#define MPP_SPI_SPI MPP(58, 0x0, 0) +#define MPP_SPI_GPIO MPP(58, 0x1, 1) +#define MPP_SPI_MAX 61 + +/* MPP_UART1 = MPP[62:63] */ +#define MPP_UART1 62 +#define MPP_UART1_UART1 MPP(62, 0x0, 0) +#define MPP_UART1_GPIO MPP(62, 0x1, 1) +#define MPP_UART1_MAX 63 + +/* MPP_NAND = MPP[64:71] */ +#define MPP_NAND 64 +#define MPP_NAND_NAND MPP(64, 0x0, 0) +#define MPP_NAND_GPO MPP(64, 0x1, 1) +#define MPP_NAND_MAX 71 + +/* MPP_AUDIO0 = Internal AC97/I2S mux for audio0 pins */ +#define MPP_AUDIO0 72 +#define MPP_AUDIO0_I2S MPP(72, 0x0, 0) +#define MPP_AUDIO0_AC97 MPP(72, 0x1, 0) + +/* MPP_TWSI = Internal TWSI option mux */ +#define MPP_TWSI 73 +#define MPP_TWSI_NONE MPP(73, 0x0, 0) +#define MPP_TWSI_OPTION1 MPP(73, 0x1, 0) +#define MPP_TWSI_OPTION2 MPP(73, 0x2, 0) +#define MPP_TWSI_OPTION3 MPP(73, 0x3, 0) + +#define MPP_MAX MPP_TWSI + +u8 dove_mpp_get_gpio_caps(u8 num); +void dove_mpp_conf(u16 *mpp_list); + +#endif
-----Original Message----- From: Sebastian Hesselbarth [mailto:sebastian.hesselbarth@gmail.com] Sent: 04 December 2012 14:02 To: Sebastian Hesselbarth Cc: u-boot@lists.denx.de; Rabeeh Khoury; Albert Aribaud; Prafulla Wadaskar; Andy Fleming; Joe Hershberger; Daniel Stodden; Luka Perkov Subject: [PATCH v2 01/10] ARM: dove: add support for Marvell Dove SoC
I could not locate V3 of this patch in my inbox, so please consider these comments applicable for V3 if not changed between v2-to-v3.
Changelog: v1->v2:
I don't find a file CREDITs, either add it or remove above line :-)
Recommended: remove the above lines above and you may add the people to whom you wish to give credits here itself.
+$(LIB): $(OBJS)
+##################################################################### #### diff --git a/arch/arm/cpu/armv7/dove/cpu.c b/arch/arm/cpu/armv7/dove/cpu.c new file mode 100644 index 0000000..b9e708c --- /dev/null +++ b/arch/arm/cpu/armv7/dove/cpu.c @@ -0,0 +1,266 @@ +/*
- Marvell Dove SoC cpu related functions
- Sebastian Hesselbarth sebastian.hesselbarth@gmail.com
- project.
Ditto
- Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston,
- MA 02110-1301 USA
May you please replace magic numbers with macros?
do {} while (1);
char *cpu;
u32 idreg;
u16 part, rev;
switch (part) {
break;
default:
There are more than one spaces in the display string, do you really need them? Please remove them.
char *soc, *rev;
switch (devid) {
soc = "AP510";
break;
soc = "F6781";
break;
default:
return -1;
switch (revid) {
rev = "Z0";
break;
rev = "Z1";
break;
rev = "Y0";
break;
rev = "Y1";
break;
rev = "X0";
break;
rev = "A0";
break;
rev = "A1";
break;
default:
Same here...
return -1;
return -1;
- dove_init_gpio - initial GPIO configuration
- Window Size
- Used with the Base register to set the address window size and
location.
- Must be programmed from LSB to MSB as sequence of ones followed by
- sequence of zeros. The number of ones specifies the size of the
window in
- 64 KByte granularity (e.g., a value of 0x00FF specifies 256 = 16
MByte).
- NOTE: A value of 0x0 specifies 64-KByte size.
int i;
unsigned int j = 0;
Please replace magic no by SZ_64K or something similar
j |= (1 << i);
val = val >> 1;
Please replace with macro
- dove_config_adr_windows - Configure address Windows
- There are 8 address windows supported by Dove Soc to addess
different
- devices. Windows 0-3 can be configured for size, BAR and remap
addr.
- Windows 4-7 can be configured for size and BAR.
- Below configuration is standard for most of the cases
- If remap function not used, remap_lo must be set as base
&winregs[2].ctrl);
&winregs[3].ctrl);
dcache_enable();
- Marvell Dove SoC DRAM initialization
- project.
Ditto
- MA 02110-1301 USA
- dove_sdram_start - reads start from Memory Address Map Register n
- dove_sdram_size - reads size from Memory Address Map Register n
u32 size;
return size;
int i;
gd->ram_size = 0;
* and without gaps.
break;
- If this function is not defined here,
- board.c alters dram bank zero configuration defined above.
dram_init();
Please correct indentation here, use tab
- Marvell Dove SoC icache and reg base low level init
- MA 02111-1307 USA
- Enable Tauros2 L2 ICache
+.macro init_l2cc
orr r0, r0, #0x2
- Init internal register base addresses
str r6, [r1]
ldr r4, =0xffff0000
ldr r6, [r1]
and r6, r6, r4
lsr r4, r6, #16
orr r6, r6, r4
str r6, [r1]
ldr r4, =0x007fffff
ldr r6, [r1]
and r6, r6, r4
orr r6, r6, r4
str r6, [r1]
ldr r4, =0x0000ffff
ldr r6, [r1]
and r6, r6, r4
orr r6, r6, r4
str r6, [r1]
init_l2cc
init_reg_base
mov pc,lr
- Marvell Dove SoC MPP pinmux
- project.
- MA 02110-1301 USA
- MPP0-23 have standard MPP register layout
u32 reg;
else
Why it is orion_gpio*? it should be generic API call or SoC specific.
- MPP0-15 also allow to mux PMU functions
I think you are trying to reuse the framework implemented by orion, You may move generic part from orion to common area so that you can use it. Using other SoC direct calls doesn't sound good to me.
} else {
/* configure MPP */
- MPP groups on MPP4_CTRL have different register layout
- and allow GPIO or special function only
u32 mask;
u8 n, nmin, nmax;
int gpio;
case MPP_CAMERA:
nmin = MPP_CAMERA;
break;
case MPP_SDIO0:
nmin = MPP_SDIO0;
break;
case MPP_SDIO1:
nmin = MPP_SDIO1;
break;
case MPP_SPI:
nmin = MPP_SPI;
nmax = MPP_SPI_MAX;
break;
case MPP_UART1:
nmin = MPP_UART1;
break;
default:
return;
reg &= ~mask;
reg |= mask;
gpio = 0;
- MPP_GENERAL_CTRL allows GPIO on NAND pins
u8 n;
int gpio;
- Dedicated audio1 pins can carry i2s, spdif, ssp or twsi
- and gpio in various combinations
Move these defined on the top of in header file; preferred in header.
int gpio;
gpio = 0;
switch (config) {
break;
break;
- MPP PMU switches audio0 pins to ac97 or i2s0
- TWSI has 3 optional pin sets that can be switched during runtime
switch (config) {
break;
break;
break;
while (*mpp_list) {
else {
switch (num) {
case MPP_CAMERA:
case MPP_SDIO0:
case MPP_SDIO1:
case MPP_SPI:
case MPP_UART1:
break;
case MPP_NAND:
break;
case MPP_AUDIO0:
break;
case MPP_AUDIO1:
break;
case MPP_TWSI:
break;
mpp_list++;
- Marvell Dove SoC timer
- project.
- MA 02110-1301 USA
There are two blank lines here, Pls remove one.
u32 pad[3];
u32 wdt_reload;
u32 wdt_val;
- ARM Timers Registers Map
- ARM Timers Control Register
- CPU_TIMERS_CTRL_REG (CTCR)
- ARM Timer\Watchdog Reload Register
- CNTMR_RELOAD_REG (TRR)
- ARM Timer\Watchdog Register
- CNTMR_VAL_REG (TVRG)
/* normal mode */
} else {
lastdec = now;
return timestamp;
uint current;
ulong delayticks;
} else {
- init the counter
timestamp = 0;
- This function is derived from PowerPC code (read timebase as long
Does these comments stands valid, I think you reference is Kirkwood.
long).
- On ARM it just returns the timer value.
- This function is derived from PowerPC code (timebase clock
frequency).
- On ARM it returns the number of timer ticks per second.
- Marvell Dove SoC USB PHY init
- project.
- MA 02110-1301 USA
u32 reg;
udelay(100);
udelay(100);
- Marvell SoC config
- project.
- MA 02110-1301 USA
- By default kwbimage.cfg from board specific folder is used
I think you should use dvbimage.cfg naming convention, since kwb stands for Kirkwood boot image, same way it will be dove boot image
- If for some board, different configuration file need to be used,
- CONFIG_SYS_KWD_CONFIG should be defined in board specific header
file
Same: change all references to DOVE, secondly do you think DV is better than DOVE to shorten then name everywhere like KW for Kirkwood?
- NAND configuration
- SPI Flash configuration
- Ethernet Driver configuration
- SDHCI
- USB/EHCI
- IDE Support on SATA ports
- I2C related stuff
- Marvell Dove SoC CPU
- project.
- MA 02110-1301 USA
Please give the reference of the SoC documentation that you are referring here for all enums and macros.
+enum memory_bank {
BANK0,
BANK1,
DOVECPU_WIN_ENABLE
- Default Device Address MAP BAR values
- ARM CPUID register
- read feroceon/sheeva core extra feature register
- using co-proc instruction
unsigned int val;
(val) : : "cc");
return val;
- write feroceon/sheeva core extra feature register
(val) : "cc");
isb();
- Downstream Bridge Registers
u32 ctrl;
u32 base;
u32 remap_lo;
u32 remap_hi;
- CPU control and status Registers
u32 pad1;
Same here, documentation reference is needed.
- GPIO 0/1 Registers
- GPIO 2 Registers (no datain/irq)
u32 dout;
u32 oe;
u32 blink_en;
u32 din_pol;
u32 din;
u32 irq_cause;
u32 irq_mask;
u32 irq_level;
u32 val0;
u32 val1;
u32 val2;
u32 oe0_n;
u32 oe1_n;
u32 oe2_n;
Pls move to gpio.h
- functions
- Marvell Dove SoC register offsets and config
- project.
- MA 02110-1301 USA
- Marvell Dove SoC gpio
- project.
- MA 02110-1301 USA
DOVE_GPIO0_BASE)
- Marvell Dove SoC pinmux
- project.
- MA 02110-1301 USA
1.7.10.4
Regards... Prafulla . . .
Prafulla,
thanks for the review. I added some notes below at your comments.
u32 reg;
reg&= ~(MPP_MASK<< shift);
reg |= MPP_SEL(config)<< shift;
else
Dove is reusing orion gpio, orion refers to the SoC family not orion5x.
writel(readl(MPP_PMU_GENERAL_CTRL) | (1<< num),
Kirkwood and others using orion_gpio have very regular layout of mpp pins and gpio functionality, i.e. you have one pin with one mpp layout and if you want it to be gpio you choose "gpio" as it's mpp function.
Well, Dove is different here. You first have mpp0-15 which can be either "normal" mpp pins _or_ assigned to power management unit (pmu). Then there are mpp groups where more than one pin is controlled by a single mpp register value. As there are some groups that have some of the pins configured as gpios while others carry a special function, I chose to have gpio capabilities configured by mpp code not by gpio function.
With recent discussion about renaming kwboot to mvboot, shouldn't this become mvbimage.cfg?
file
Ditto, rename KWD to MV or MVB?
Again, Orion refers to SoC family and Dove is reusing the driver.
Sebastian
-----Original Message----- From: Sebastian Hesselbarth [mailto:sebastian.hesselbarth@gmail.com] Sent: 03 March 2013 17:01 To: Prafulla Wadaskar Cc: u-boot@lists.denx.de; Rabeeh Khoury; Albert Aribaud; Andy Fleming; Joe Hershberger; Daniel Stodden; Luka Perkov Subject: Re: [PATCH v2 01/10] ARM: dove: add support for Marvell Dove SoC
Prafulla,
u32 reg;
else
or SoC specific.
So let's rename them as "mv" as per strategy. I don't have any issue to refer "mv_gpio" in dove code.
(1<< num),
So we can have generic mv specific APIs and the SoC specific layer can be abstracted if possible. If the integration is not possible with generic code then you can always have dove_gpio driver.
folder is used
Tool could be mvboot, configuration image can be mv/kw/dvbimage.cfg. But I don't have any issue with name mvbimage.cfg
need to be used,
specific header
file
DOVE_SPI_BASE
Let's use mv if the code is being shared.
Sebastian
This adds a gpio driver for Marvell Orion SoCs, i.e. orion5x, kirkwood, dove. This is based on kw_gpio but as gpio capabilities depend heavily on the mpp configuration for dove, it allows to set gpi/gpo capabilities from mpp. This should be compatible with the current kw_gpio and porting mpp of kirkwood and orion5x is appreciated.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Luka Perkov luka@openwrt.org --- drivers/gpio/Makefile | 1 + drivers/gpio/orion_gpio.c | 167 +++++++++++++++++++++++++++++++++++++++++++++ include/orion_gpio.h | 64 +++++++++++++++++ 3 files changed, 232 insertions(+) create mode 100644 drivers/gpio/orion_gpio.c create mode 100644 include/orion_gpio.h
diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index d50ac3b..6fc163b 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -26,6 +26,7 @@ include $(TOPDIR)/config.mk LIB := $(obj)libgpio.o
COBJS-$(CONFIG_AT91_GPIO) += at91_gpio.o +COBJS-$(CONFIG_ORION_GPIO) += orion_gpio.o COBJS-$(CONFIG_KIRKWOOD_GPIO) += kw_gpio.o COBJS-$(CONFIG_MARVELL_GPIO) += mvgpio.o COBJS-$(CONFIG_MARVELL_MFP) += mvmfp.o diff --git a/drivers/gpio/orion_gpio.c b/drivers/gpio/orion_gpio.c new file mode 100644 index 0000000..209354d --- /dev/null +++ b/drivers/gpio/orion_gpio.c @@ -0,0 +1,167 @@ +/* + * Marvell Orion SoC GPIO handling. + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * Based on (mostly copied from) plat-orion based Linux 2.6 kernel driver. + * Removed orion_gpiochip struct and kernel level irq handling. + * Dieter Kiermaier dk-arm-linux@gmx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <asm/bitops.h> +#include <asm/io.h> +#include <asm/arch/gpio.h> +#include <orion_gpio.h> + +static unsigned long gpio_valid_input[BITS_TO_LONGS(GPIO_MAX)]; +static unsigned long gpio_valid_output[BITS_TO_LONGS(GPIO_MAX)]; + +void __set_direction(unsigned pin, int input) +{ + u32 base = GPIO_BASE(pin); + u32 u; + + u = readl(GPIO_IO_CONF(base)); + if (input) + u |= 1 << (pin & 31); + else + u &= ~(1 << (pin & 31)); + writel(u, GPIO_IO_CONF(base)); + + u = readl(GPIO_IO_CONF(base)); +} + +void __set_level(unsigned pin, int high) +{ + u32 base = GPIO_BASE(pin); + u32 u; + + u = readl(GPIO_OUT(base)); + if (high) + u |= 1 << (pin & 31); + else + u &= ~(1 << (pin & 31)); + writel(u, GPIO_OUT(base)); +} + +void __set_blinking(unsigned pin, int blink) +{ + u32 base = GPIO_BASE(pin); + u32 u; + + u = readl(GPIO_BLINK_EN(base)); + if (blink) + u |= 1 << (pin & 31); + else + u &= ~(1 << (pin & 31)); + writel(u, GPIO_BLINK_EN(base)); +} + +int orion_gpio_is_valid(unsigned pin, int mode) +{ + if (pin < GPIO_MAX) { + if ((mode & GPIO_INPUT_OK) && + !test_bit(pin, gpio_valid_input)) + goto err_out; + + if ((mode & GPIO_OUTPUT_OK) && + !test_bit(pin, gpio_valid_output)) + goto err_out; + return 0; + } + +err_out: + printf("%s: invalid GPIO %d/%d\n", __func__, pin, GPIO_MAX); + return 1; +} + +void orion_gpio_set_valid(unsigned pin, int mode) +{ + if (mode & GPIO_INPUT_OK) + __set_bit(pin, gpio_valid_input); + else + __clear_bit(pin, gpio_valid_input); + if (mode & GPIO_OUTPUT_OK) + __set_bit(pin, gpio_valid_output); + else + __clear_bit(pin, gpio_valid_output); +} + +/* + * GENERIC_GPIO primitives. + */ +int orion_gpio_direction_input(unsigned pin) +{ + if (orion_gpio_is_valid(pin, GPIO_INPUT_OK) != 0) + return 1; + + /* Configure GPIO direction. */ + __set_direction(pin, 1); + + return 0; +} + +int orion_gpio_direction_output(unsigned pin, int value) +{ + if (orion_gpio_is_valid(pin, GPIO_OUTPUT_OK) != 0) { + printf("%s: invalid GPIO %d\n", __func__, pin); + return 1; + } + + __set_blinking(pin, 0); + + /* Configure GPIO output value. */ + __set_level(pin, value); + + /* Configure GPIO direction. */ + __set_direction(pin, 0); + + return 0; +} + +int orion_gpio_get_value(unsigned pin) +{ + u32 base = GPIO_BASE(pin); + int val; + + if (readl(GPIO_IO_CONF(base)) & (1 << (pin & 31))) + val = readl(GPIO_DATA_IN(base)) ^ readl(GPIO_IN_POL(base)); + else + val = readl(GPIO_OUT(base)); + + return (val >> (pin & 31)) & 1; +} + +void orion_gpio_set_value(unsigned pin, int value) +{ + /* Configure GPIO output value. */ + __set_level(pin, value); +} + +void orion_gpio_set_blink(unsigned pin, int blink) +{ + /* Set output value to zero. */ + __set_level(pin, 0); + + /* Set blinking. */ + __set_blinking(pin, blink); +} diff --git a/include/orion_gpio.h b/include/orion_gpio.h new file mode 100644 index 0000000..ba67068 --- /dev/null +++ b/include/orion_gpio.h @@ -0,0 +1,64 @@ +/* + * Marvell Orion SoCs common gpio + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef __ORION_GPIO_H +#define __ORION_GPIO_H + +/* + * SoC-specific gpio.h defines + * GPIO_MAX and GPIO_BASE(pin) macro + */ + +#define GPIO_INPUT_OK (1 << 0) +#define GPIO_OUTPUT_OK (1 << 1) +#define GPIO_LOW 0 +#define GPIO_HIGH 1 + +/* got from kernel include/linux/bitops.h */ +#define BITS_PER_BYTE 8 +#define BITS_TO_LONGS(nr) DIV_ROUND_UP(nr, BITS_PER_BYTE * sizeof(long)) + +#define GPIO_OUT(base) ((base) + 0x00) +#define GPIO_IO_CONF(base) ((base) + 0x04) +#define GPIO_BLINK_EN(base) ((base) + 0x08) +#define GPIO_IN_POL(base) ((base) + 0x0c) +#define GPIO_DATA_IN(base) ((base) + 0x10) +#define GPIO_EDGE_CAUSE(base) ((base) + 0x14) +#define GPIO_EDGE_MASK(base) ((base) + 0x18) +#define GPIO_LEVEL_MASK(base) ((base) + 0x1c) + +/* + * Orion-specific GPIO API + */ + +void orion_gpio_set_valid(unsigned pin, int mode); +int orion_gpio_is_valid(unsigned pin, int mode); +int orion_gpio_direction_input(unsigned pin); +int orion_gpio_direction_output(unsigned pin, int value); +int orion_gpio_get_value(unsigned pin); +void orion_gpio_set_value(unsigned pin, int value); +void orion_gpio_set_blink(unsigned pin, int blink); +void orion_gpio_set_unused(unsigned pin); + +#endif
This adds a driver for the sdhci controller found on Dove SoCs.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Luka Perkov luka@openwrt.org --- drivers/mmc/Makefile | 1 + drivers/mmc/dove_sdhci.c | 101 ++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 102 insertions(+) create mode 100644 drivers/mmc/dove_sdhci.c
diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 65791aa..f7c731f 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -31,6 +31,7 @@ endif
COBJS-$(CONFIG_BFIN_SDH) += bfin_sdh.o COBJS-$(CONFIG_DAVINCI_MMC) += davinci_mmc.o +COBJS-$(CONFIG_DOVE_SDHCI) += dove_sdhci.o COBJS-$(CONFIG_FSL_ESDHC) += fsl_esdhc.o COBJS-$(CONFIG_FTSDC010) += ftsdc010_esdhc.o COBJS-$(CONFIG_GENERIC_MMC) += mmc.o diff --git a/drivers/mmc/dove_sdhci.c b/drivers/mmc/dove_sdhci.c new file mode 100644 index 0000000..ac15fd7 --- /dev/null +++ b/drivers/mmc/dove_sdhci.c @@ -0,0 +1,101 @@ +/* + * + * Marvell Dove SDHCI driver + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * Based on linux drivers/mmc/host/sdhci-dove.c + * by: Saeed Bishara saeed@marvell.com + * Mike Rapoport mike@compulab.co.il + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ + +#include <common.h> +#include <malloc.h> +#include <sdhci.h> +#include <asm/arch/dove.h> + +static u16 dove_sdhci_readw(struct sdhci_host *host, int reg) +{ + u16 ret; + + switch (reg) { + case SDHCI_HOST_VERSION: + case SDHCI_SLOT_INT_STATUS: + /* those registers don't exist */ + return 0; + default: + ret = readw(host->ioaddr + reg); + } + + return ret; +} + +static u32 dove_sdhci_readl(struct sdhci_host *host, int reg) +{ + u32 ret; + + switch (reg) { + case SDHCI_CAPABILITIES: + ret = readl(host->ioaddr + reg); + /* Mask the support for 3.0V */ + ret &= ~SDHCI_CAN_VDD_300; + break; + default: + ret = readl(host->ioaddr + reg); + } + + return ret; +} + +static struct sdhci_ops dove_sdhci_ops = { + .read_w = dove_sdhci_readw, + .read_l = dove_sdhci_readl, +}; + +static struct sdhci_host hosts[2] = { + { + .name = "Dove SDHCI0", + .ioaddr = (void *)DOVE_SDIO0_BASE, + }, + { + .name = "Dove SDHCI1", + .ioaddr = (void *)DOVE_SDIO1_BASE, + }, +}; + +int dove_sdhci_init(int num) +{ + struct sdhci_host *host; + + if (num < 0 || num > 1) + return 1; + + host = &hosts[num]; + + if (host->version) + return 1; + + host->quirks = + SDHCI_QUIRK_NO_HISPD_BIT | + SDHCI_QUIRK_BROKEN_R1B | + SDHCI_QUIRK_32BIT_DMA_ADDR; + host->version = SDHCI_SPEC_200; + host->ops = &dove_sdhci_ops; + + add_sdhci(host, 50000000, 4000000); + return 0; +}
This adds an SPI driver found on Marvell Orion SoCs. This driver is taken from kirkwood_spi but removes mpp configuration as dove has dedicated spi pins. To have a common driver for orion5x, kirkwood, and dove, mpp configuration should be handled in some cpu/board-specific setup.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Luka Perkov luka@openwrt.org --- drivers/spi/Makefile | 1 + drivers/spi/orion_spi.c | 217 +++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 218 insertions(+) create mode 100644 drivers/spi/orion_spi.c
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index f0b82c6..679ba61 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -34,6 +34,7 @@ COBJS-$(CONFIG_BFIN_SPI) += bfin_spi.o COBJS-$(CONFIG_CF_SPI) += cf_spi.o COBJS-$(CONFIG_CF_QSPI) += cf_qspi.o COBJS-$(CONFIG_DAVINCI_SPI) += davinci_spi.o +COBJS-$(CONFIG_ORION_SPI) += orion_spi.o COBJS-$(CONFIG_KIRKWOOD_SPI) += kirkwood_spi.o COBJS-$(CONFIG_MPC52XX_SPI) += mpc52xx_spi.o COBJS-$(CONFIG_MPC8XXX_SPI) += mpc8xxx_spi.o diff --git a/drivers/spi/orion_spi.c b/drivers/spi/orion_spi.c new file mode 100644 index 0000000..8a50531 --- /dev/null +++ b/drivers/spi/orion_spi.c @@ -0,0 +1,217 @@ +/* + * Marvell Orion SoCs common spi driver + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * based on kirkwood_spi.c written by + * Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <malloc.h> +#include <spi.h> +#include <asm/io.h> +#include <asm/arch/config.h> + +/* SPI Registers on orion SOC */ +struct orionspi_registers { + u32 ctrl; /* 0x00 */ + u32 cfg; /* 0x04 */ + u32 dout; /* 0x08 */ + u32 din; /* 0x0c */ + u32 irq_cause; /* 0x10 */ + u32 irq_mask; /* 0x14 */ +}; + +#define ORIONSPI_CLKPRESCL_MASK 0x1f +#define ORIONSPI_CLKPRESCL_MIN 0x12 +#define ORIONSPI_CSN_ACT 1 /* Activates serial memory interface */ +#define ORIONSPI_SMEMRDY (1 << 1) /* SerMem Data xfer ready */ +#define ORIONSPI_IRQUNMASK 1 /* unmask SPI interrupt */ +#define ORIONSPI_IRQMASK 0 /* mask SPI interrupt */ +#define ORIONSPI_SMEMRDIRQ 1 /* SerMem data xfer ready irq */ +#define ORIONSPI_XFERLEN_1BYTE 0 +#define ORIONSPI_XFERLEN_2BYTE (1 << 5) +#define ORIONSPI_XFERLEN_MASK (1 << 5) +#define ORIONSPI_ADRLEN_1BYTE 0 +#define ORIONSPI_ADRLEN_2BYTE (1 << 8) +#define ORIONSPI_ADRLEN_3BYTE (2 << 8) +#define ORIONSPI_ADRLEN_4BYTE (3 << 8) +#define ORIONSPI_ADRLEN_MASK (3 << 8) +#define ORIONSPI_TIMEOUT 10000 + +static struct orionspi_registers *spireg = + (struct orionspi_registers *)ORION_SPI_BASE; + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct spi_slave *slave; + u32 data; + u32 kwspi_mpp_config[] = { 0, 0 }; + + if (!spi_cs_is_valid(bus, cs)) + return NULL; + + slave = malloc(sizeof(struct spi_slave)); + if (!slave) + return NULL; + + slave->bus = bus; + slave->cs = cs; + + writel(~ORIONSPI_CSN_ACT | ORIONSPI_SMEMRDY, &spireg->ctrl); + + /* calculate spi clock prescaller using max_hz */ + data = ((CONFIG_SYS_TCLK / 2) / max_hz) + 0x10; + data = data < ORIONSPI_CLKPRESCL_MIN ? ORIONSPI_CLKPRESCL_MIN : data; + data = data > ORIONSPI_CLKPRESCL_MASK ? ORIONSPI_CLKPRESCL_MASK : data; + + /* program spi clock prescaller using max_hz */ + writel(ORIONSPI_ADRLEN_3BYTE | data, &spireg->cfg); + debug("data = 0x%08x\n", data); + + writel(ORIONSPI_SMEMRDIRQ, &spireg->irq_cause); + writel(ORIONSPI_IRQMASK, &spireg->irq_mask); + + return slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + free(slave); +} + +#if defined(CONFIG_SYS_KW_SPI_MPP) +u32 spi_mpp_backup[4]; +#endif + +__attribute__((weak)) int board_spi_claim_bus(struct spi_slave *slave) +{ + return 0; +} + +int spi_claim_bus(struct spi_slave *slave) +{ + return board_spi_claim_bus(slave); +} + +__attribute__((weak)) void board_spi_release_bus(struct spi_slave *slave) +{ +} + +void spi_release_bus(struct spi_slave *slave) +{ + board_spi_release_bus(slave); +} + +#ifndef CONFIG_SPI_CS_IS_VALID +/* + * you can define this function board specific + * define above CONFIG in board specific config file and + * provide the function in board specific src file + */ +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return (bus == 0 && (cs == 0 || cs == 1)); +} +#endif + +void spi_init(void) +{ +} + +void spi_cs_activate(struct spi_slave *slave) +{ + writel(readl(&spireg->ctrl) | ORIONSPI_IRQUNMASK, &spireg->ctrl); +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + writel(readl(&spireg->ctrl) & ORIONSPI_IRQMASK, &spireg->ctrl); +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, + void *din, unsigned long flags) +{ + unsigned int tmpdout, tmpdin; + int tm, isread = 0; + + debug("spi_xfer: slave %u:%u dout %p din %p bitlen %u\n", + slave->bus, slave->cs, dout, din, bitlen); + + if (flags & SPI_XFER_BEGIN) + spi_cs_activate(slave); + + /* + * handle data in 8-bit chunks + * TBD: 2byte xfer mode to be enabled + */ + writel(((readl(&spireg->cfg) & ~ORIONSPI_XFERLEN_MASK) | + ORIONSPI_XFERLEN_1BYTE), &spireg->cfg); + + while (bitlen > 4) { + debug("loopstart bitlen %d\n", bitlen); + tmpdout = 0; + + /* Shift data so it's msb-justified */ + if (dout) + tmpdout = *(u32 *) dout & 0x0ff; + + writel(~ORIONSPI_SMEMRDIRQ, &spireg->irq_cause); + writel(tmpdout, &spireg->dout); /* Write the data out */ + debug("*** spi_xfer: ... %08x written, bitlen %d\n", + tmpdout, bitlen); + + /* + * Wait for SPI transmit to get out + * or time out (1 second = 1000 ms) + * The NE event must be read and cleared first + */ + for (tm = 0, isread = 0; tm < ORIONSPI_TIMEOUT; ++tm) { + if (readl(&spireg->irq_cause) & ORIONSPI_SMEMRDIRQ) { + isread = 1; + tmpdin = readl(&spireg->din); + debug + ("spi_xfer: din %p..%08x read\n", + din, tmpdin); + + if (din) { + *((u8 *) din) = (u8) tmpdin; + din += 1; + } + if (dout) + dout += 1; + bitlen -= 8; + } + if (isread) + break; + } + if (tm >= ORIONSPI_TIMEOUT) + printf("*** spi_xfer: Time out during SPI transfer\n"); + + debug("loopend bitlen %d\n", bitlen); + } + + if (flags & SPI_XFER_END) + spi_cs_deactivate(slave); + + return 0; +}
Dove SoC also uses mvsata, therefore add a SoC specific include to allow to reuse the mvsata ide driver.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Luka Perkov luka@openwrt.org --- drivers/block/mvsata_ide.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/block/mvsata_ide.c b/drivers/block/mvsata_ide.c index a88d0f7..9918f80 100644 --- a/drivers/block/mvsata_ide.c +++ b/drivers/block/mvsata_ide.c @@ -29,6 +29,8 @@ #include <asm/arch/orion5x.h> #elif defined(CONFIG_KIRKWOOD) #include <asm/arch/kirkwood.h> +#elif defined(CONFIG_DOVE) +#include <asm/arch/dove.h> #endif
/* SATA port registers */
This adds PHY initialization for Marvell Alaska 88E1310 PHY.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Luka Perkov luka@openwrt.org --- drivers/net/phy/marvell.c | 48 +++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 48 insertions(+)
diff --git a/drivers/net/phy/marvell.c b/drivers/net/phy/marvell.c index e51e799..e920212 100644 --- a/drivers/net/phy/marvell.c +++ b/drivers/net/phy/marvell.c @@ -89,6 +89,12 @@
#define MIIM_88E1149_PHY_PAGE 29
+/* 88E1310 PHY defines */ +#define MIIM_88E1310_PHY_LED_CTRL 16 +#define MIIM_88E1310_PHY_IRQ_EN 18 +#define MIIM_88E1310_PHY_RGMII_CTRL 21 +#define MIIM_88E1310_PHY_PAGE 22 + /* Marvell 88E1011S */ static int m88e1011s_config(struct phy_device *phydev) { @@ -394,6 +400,37 @@ static int m88e1149_config(struct phy_device *phydev) return 0; }
+/* Marvell 88E1310 */ +static int m88e1310_config(struct phy_device *phydev) +{ + u16 reg; + + /* LED link and activity */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_PAGE, 0x0003); + reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_LED_CTRL); + reg = (reg & ~0xf) | 0x1; + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_LED_CTRL, reg); + + /* Set LED2/INT to INT mode, low active */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_PAGE, 0x0003); + reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_IRQ_EN); + reg = (reg & 0x77ff) | 0x0880; + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_IRQ_EN, reg); + + /* Set RGMII delay */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_PAGE, 0x0002); + reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_RGMII_CTRL); + reg |= 0x0030; + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_RGMII_CTRL, reg); + + /* Ensure to return to page 0 */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_PAGE, 0x0000); + + genphy_config_aneg(phydev); + phy_reset(phydev); + + return 0; +}
static struct phy_driver M88E1011S_driver = { .name = "Marvell 88E1011S", @@ -455,8 +492,19 @@ static struct phy_driver M88E1149S_driver = { .shutdown = &genphy_shutdown, };
+static struct phy_driver M88E1310_driver = { + .name = "Marvell 88E1310", + .uid = 0x01410e90, + .mask = 0xffffff0, + .features = PHY_GBIT_FEATURES, + .config = &m88e1310_config, + .startup = &m88e1011s_startup, + .shutdown = &genphy_shutdown, +}; + int phy_marvell_init(void) { + phy_register(&M88E1310_driver); phy_register(&M88E1149S_driver); phy_register(&M88E1145_driver); phy_register(&M88E1121R_driver);
This add phylib support to the Marvell GBE driver.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Luka Perkov luka@openwrt.org --- drivers/net/mvgbe.c | 68 ++++++++++++++++++++++++++++++++++++++++++++++++--- 1 file changed, 64 insertions(+), 4 deletions(-)
diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index 47bf27c..192c989 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -52,7 +52,7 @@ DECLARE_GLOBAL_DATA_PTR; #define MV_PHY_ADR_REQUEST 0xee #define MVGBE_SMI_REG (((struct mvgbe_registers *)MVGBE0_BASE)->smi)
-#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) +#if defined(CONFIG_PHYLIB) || defined(CONFIG_MII) || defined(CONFIG_CMD_MII) /* * smi_reg_read - miiphy_read callback function. * @@ -184,6 +184,24 @@ static int smi_reg_write(const char *devname, u8 phy_adr, u8 reg_ofs, u16 data) } #endif
+#if defined(CONFIG_PHYLIB) +int mvgbe_phy_read(struct mii_dev *bus, int phyAddr, int devAddr, int regAddr) +{ + u16 data; + int ret; + ret = smi_reg_read(bus->name, phyAddr, regAddr, &data); + if (ret) + return ret; + return data; +} + +int mvgbe_phy_write(struct mii_dev *bus, int phyAddr, int devAddr, int regAddr, + u16 data) +{ + return smi_reg_write(bus->name, phyAddr, regAddr, data); +} +#endif + /* Stop and checks all queues */ static void stop_queue(u32 * qreg) { @@ -467,8 +485,9 @@ static int mvgbe_init(struct eth_device *dev) /* Enable port Rx. */ MVGBE_REG_WR(regs->rqc, (1 << RXUQ));
-#if (defined (CONFIG_MII) || defined (CONFIG_CMD_MII)) \ - && defined (CONFIG_SYS_FAULT_ECHO_LINK_DOWN) +#if (defined(CONFIG_MII) || defined(CONFIG_CMD_MII)) \ + && !defined(CONFIG_PHYLIB) \ + && defined(CONFIG_SYS_FAULT_ECHO_LINK_DOWN) /* Wait up to 5s for the link status */ for (i = 0; i < 5; i++) { u16 phyadr; @@ -647,6 +666,45 @@ static int mvgbe_recv(struct eth_device *dev) return 0; }
+#if defined(CONFIG_PHYLIB) +int mvgbe_phylib_init(struct eth_device *dev, int phyid) +{ + struct mii_dev *bus; + struct phy_device *phydev; + int ret; + + bus = mdio_alloc(); + if (!bus) { + printf("mdio_alloc failed\n"); + return -ENOMEM; + } + bus->read = mvgbe_phy_read; + bus->write = mvgbe_phy_write; + sprintf(bus->name, dev->name); + + ret = mdio_register(bus); + if (ret) { + printf("mdio_register failed\n"); + free(bus); + return -ENOMEM; + } + + /* Set phy address of the port */ + mvgbe_phy_write(bus, MV_PHY_ADR_REQUEST, 0, MV_PHY_ADR_REQUEST, phyid); + + phydev = phy_connect(bus, phyid, dev, PHY_INTERFACE_MODE_RGMII); + if (!phydev) { + printf("phy_connect failed\n"); + return -ENODEV; + } + + phy_config(phydev); + phy_startup(phydev); + + return 0; +} +#endif + int mvgbe_initialize(bd_t *bis) { struct mvgbe_device *dmvgbe; @@ -729,7 +787,9 @@ error1:
eth_register(dev);
-#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) +#if defined(CONFIG_PHYLIB) + mvgbe_phylib_init(dev, PHY_BASE_ADR + devnum); +#elif defined(CONFIG_MII) || defined(CONFIG_CMD_MII) miiphy_register(dev->name, smi_reg_read, smi_reg_write); /* Set phy address of the port */ miiphy_write(dev->name, MV_PHY_ADR_REQUEST,
Marvell Dove also uses mvgbe as ethernet driver, therefore add support for Dove to reuse the current driver.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Luka Perkov luka@openwrt.org --- drivers/net/mvgbe.c | 2 ++ drivers/net/mvgbe.h | 7 +++++++ 2 files changed, 9 insertions(+)
diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index 192c989..590ea0b 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -43,6 +43,8 @@ #include <asm/arch/kirkwood.h> #elif defined(CONFIG_ORION5X) #include <asm/arch/orion5x.h> +#elif defined(CONFIG_DOVE) +#include <asm/arch/dove.h> #endif
#include "mvgbe.h" diff --git a/drivers/net/mvgbe.h b/drivers/net/mvgbe.h index d8a5429..7f5d98f 100644 --- a/drivers/net/mvgbe.h +++ b/drivers/net/mvgbe.h @@ -308,10 +308,17 @@ #define EBAR_TARGET_GUNIT 0x00000007
/* Window attrib */ +#if defined(CONFIG_DOVE) +#define EBAR_DRAM_CS0 0x00000000 +#define EBAR_DRAM_CS1 0x00000000 +#define EBAR_DRAM_CS2 0x00000000 +#define EBAR_DRAM_CS3 0x00000000 +#else #define EBAR_DRAM_CS0 0x00000E00 #define EBAR_DRAM_CS1 0x00000D00 #define EBAR_DRAM_CS2 0x00000B00 #define EBAR_DRAM_CS3 0x00000700 +#endif
/* DRAM Target interface */ #define EBAR_DRAM_NO_CACHE_COHERENCY 0x00000000
On Tue, Dec 4, 2012 at 2:32 AM, Sebastian Hesselbarth sebastian.hesselbarth@gmail.com wrote:
Applied, Thanks. -Joe
With latest support for Marvell Dove SoC, add the SolidRun CuBox as the very first board with that SoC.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Changelog: v1->v2: - add MAINTAINERS entry and fix a typo
Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Luka Perkov luka@openwrt.org --- MAINTAINERS | 4 + board/solidrun/cubox/Makefile | 45 ++++++++++ board/solidrun/cubox/cubox.c | 141 ++++++++++++++++++++++++++++++ board/solidrun/cubox/kwbimage.cfg | 76 ++++++++++++++++ boards.cfg | 1 + include/configs/cubox.h | 175 +++++++++++++++++++++++++++++++++++++ 6 files changed, 442 insertions(+) create mode 100644 board/solidrun/cubox/Makefile create mode 100644 board/solidrun/cubox/cubox.c create mode 100644 board/solidrun/cubox/kwbimage.cfg create mode 100644 include/configs/cubox.h
diff --git a/MAINTAINERS b/MAINTAINERS index c430574..d315cb6 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -677,6 +677,10 @@ Stefan Herbrechtsmeier stefan@code.herbrechtsmeier.net
dns325 ARM926EJS (Kirkwood SoC)
+Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + + cubox ARM ARMV7 (Dove SoC) + Vaibhav Hiremath hvaibhav@ti.com
am3517_evm ARM ARMV7 (AM35x SoC) diff --git a/board/solidrun/cubox/Makefile b/board/solidrun/cubox/Makefile new file mode 100644 index 0000000..c771d72 --- /dev/null +++ b/board/solidrun/cubox/Makefile @@ -0,0 +1,45 @@ +# +# SolidRun CuBox Makefile +# +# Sebastian Hesselbarth sebastian.hesselbarth@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := cubox.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/solidrun/cubox/cubox.c b/board/solidrun/cubox/cubox.c new file mode 100644 index 0000000..70c016f --- /dev/null +++ b/board/solidrun/cubox/cubox.c @@ -0,0 +1,141 @@ +/* + * SolidRun CuBox board support + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <miiphy.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> +#include <asm/arch/mpp.h> +#include <orion_gpio.h> + +DECLARE_GLOBAL_DATA_PTR; + +static u16 mpp_config[] = { + MPP0_GPIO, + MPP1_GPIO, /* USB power enable */ + MPP2_GPIO, /* USB over-current indication */ + MPP3_GPIO, /* micro button beneath eSATA port */ + MPP4_GPIO, + MPP5_GPIO, + MPP6_GPIO, + MPP7_GPIO, + + MPP8_GPIO, + MPP9_GPIO, + MPP10_GPIO, + MPP11_GPIO, + MPP12_GPIO, /* SDIO0 card detect */ + MPP13_AUDIO1_EXTCLK, /* Si5351a audio clock output */ + MPP14_GPIO, + MPP15_GPIO, + + MPP16_GPIO, + MPP17_GPIO, + MPP18_GPIO, /* Red front LED */ + MPP19_UART3_RXD, /* IR sensor */ + MPP20_GPIO, + MPP21_GPIO, + MPP22_GPIO, + MPP23_GPIO, + + MPP_CAMERA_GPIO, + MPP_SDIO0_SDIO, /* SDIO0 */ + MPP_SDIO1_GPIO, + MPP_AUDIO1_I2S_SPDIFO, /* SPDIF and HDMI audio */ + MPP_SPI_SPI, /* SPI */ + MPP_UART1_GPIO, + MPP_NAND_GPO, + + MPP_AUDIO0_I2S, + MPP_TWSI_OPTION1, /* TWSI on dedicated pins */ + 0 }; + +int board_early_init_f(void) +{ + struct dove_gpio_init gpp = { + .val0 = 0x00010186, + .oe0_n = 0xffffffff, + .val1 = 0x018000c0, + .oe1_n = 0xffffffff, + .val2 = 0x00000000, + .oe2_n = 0xffffffff, + }; + + dove_init_gpio(&gpp); + + return 0; +} + +int board_init(void) +{ + /* adress of boot parameters */ + gd->bd->bi_boot_params = dove_dram_start(0) + 0x100; + + /* configure mpp */ + dove_mpp_conf(mpp_config); + + /* usb power enable */ + orion_gpio_direction_output(MPP1, GPIO_HIGH); + + /* blink led */ + orion_gpio_direction_output(MPP18, GPIO_HIGH); + orion_gpio_set_blink(MPP18, 1); + + return 0; +} + +#ifdef CONFIG_MMC +int board_mmc_init(bd_t *bis) +{ + dove_sdhci_init(0); + return 0; +} +#endif + +#ifdef CONFIG_RESET_PHY_R +void dove_eth_phy_init(char *name) +{ + u16 devadr; + + if (miiphy_set_current_dev(name)) + return; + + /* command to read PHY dev address */ + if (miiphy_read(name, 0xEE, 0xEE, (u16 *) &devadr)) { + printf("Err..%s could not read PHY dev address\n", + __func__); + return; + } + + /* reset the phy */ + miiphy_reset(name, devadr); + + printf("%s PHY initialized\n", name); +} + +void reset_phy(void) +{ + dove_eth_phy_init("egiga0"); +} +#endif /* CONFIG_RESET_PHY_R */ diff --git a/board/solidrun/cubox/kwbimage.cfg b/board/solidrun/cubox/kwbimage.cfg new file mode 100644 index 0000000..c3f1ad9 --- /dev/null +++ b/board/solidrun/cubox/kwbimage.cfg @@ -0,0 +1,76 @@ +# +# Marvell BootROM config for SolidRun CuBox +# +# Sebastian Hesselbarth sebastian.hesselbarth@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# +# Refer docs/README.kwimage for more details about how-to configure +# and create kirkwood boot image +# + +# Boot Media configurations +BOOT_FROM spi + +# SOC registers configuration using bootrom header extension +# Maximum KWBIMAGE_MAX_CONFIG configurations allowed + +DATA 0xd0020104 0x00000000 # CPU Control and Status register + +# SDRAM initalization +DATA 0xd0800020 0x00022430 # SDRAM Configuration register 0 +DATA 0xd0800030 0x00022430 # SDRAM Configuration register 1 +DATA 0xd0800050 0x911500c3 # SDRAM Timing register 1 +DATA 0xd0800060 0x646602c4 # SDRAM Timing register 2 +DATA 0xd0800190 0xc2003053 # SDRAM Timing register 3 +DATA 0xd08001c0 0x34f4a187 # SDRAM Timing register 4 +DATA 0xd0800650 0x000f0121 # SDRAM Timing register 5 +DATA 0xd0800660 0x04040200 # SDRAM Timing register 6 +DATA 0xd0800080 0x00000000 # SDRAM Control register 1 +DATA 0xd0800090 0x00080000 # SDRAM Control register 2 +DATA 0xd08000f0 0xc0000000 # SDRAM Control register 3 +DATA 0xd08001a0 0x20c0c009 # SDRAM Control register 4 +DATA 0xd0800280 0x010e0202 # SDRAM Control register 5 +DATA 0xd0800760 0x00000000 # SDRAM Control register 6 +DATA 0xd0800770 0x0000000a # SDRAM Control register 7 +DATA 0xd0800140 0x20004044 # SDRAM PHY control register 3 +DATA 0xd08001d0 0x133c2339 # SDRAM PHY control register 7 +DATA 0xd08001e0 0x07700330 # SDRAM PHY control register 8 +DATA 0xd08001f0 0x00000033 # SDRAM PHY control register 9 +DATA 0xd0800200 0x0011311c # SDRAM PHY control register 10 +DATA 0xd0800210 0x00300000 # SDRAM PHY control register 11 +DATA 0xd0800240 0x80000000 # SDRAM PHY control register 14 +DATA 0xd0800510 0x010e0101 # SDRAM MCB control register 1 +DATA 0xd0800230 0x2028006a # SDRAM PHY control register 13 +DATA 0xd0800e10 0x00280062 # SDRAM PHY DLL control registers 2 +DATA 0xd0800e20 0x00280062 # SDRAM PHY DLL control registers 3 +DATA 0xd0800e30 0x00280062 # SDRAM PHY DLL control registers 4 + +# SDRAM memory map (2x512MB) +DATA 0xd0800100 0x000d0001 # SDRAM Memory Address Map register 1 +DATA 0xd0800110 0x200d0001 # SDRAM Memory Address Map register 1 + +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register + +# End of Header extension +DATA 0x0 0x0 diff --git a/boards.cfg b/boards.cfg index ca9b12b..1bd734b 100644 --- a/boards.cfg +++ b/boards.cfg @@ -289,6 +289,7 @@ whistler arm armv7:arm720t whistler nvidia colibri_t20_iris arm armv7:arm720t colibri_t20_iris toradex tegra20 u8500_href arm armv7 u8500 st-ericsson u8500 snowball arm armv7 snowball st-ericsson u8500 +cubox arm armv7 cubox solidrun dove kzm9g arm armv7 kzm9g kmc rmobile armadillo-800eva arm armv7 armadillo-800eva atmark-techno rmobile zynq arm armv7 zynq xilinx zynq diff --git a/include/configs/cubox.h b/include/configs/cubox.h new file mode 100644 index 0000000..88a2fda --- /dev/null +++ b/include/configs/cubox.h @@ -0,0 +1,175 @@ +/* + * SolidRun CuBox config + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _CONFIG_CUBOX_H +#define _CONFIG_CUBOX_H +#include <asm/sizes.h> + +/* + * Version number information + */ +#define CONFIG_IDENT_STRING "\SolidRun CuBox" + +/* + * High Level Configuration Options + */ +#define CONFIG_MACH_SOLIDRUN_CUBOX /* Machine type */ +#define CONFIG_SHOW_BOOT_PROGRESS +#define CONFIG_ORION_GPIO /* Orion GPIO driver */ + +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +/* + * Enable u-boot API for standalone programs. + */ +#define CONFIG_API + +/* + * Enable device tree support + */ +#define CONFIG_OF_LIBFDT + +/* + * Commands configuration + */ +#include <config_cmd_default.h> +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ELF +#define CONFIG_CMD_ENV +#define CONFIG_CMD_IDE +#define CONFIG_CMD_PING +#define CONFIG_CMD_SF +#define CONFIG_CMD_SPI +#define CONFIG_CMD_USB +#define CONFIG_CMD_MMC + +#define CONFIG_DOS_PARTITION +#define CONFIG_EFT_PARTITION + +/* + * mv-common.h should be defined after CMD configs since it used them + * to enable certain macros + */ +#include "mv-common.h" + +/* + * redefine mv-common.h macros for armv7/cubox + */ +#undef CONFIG_SYS_PROMPT /* previously defined in mv-common.h */ +#define CONFIG_SYS_PROMPT "CuBox> " /* Command Prompt */ + +/* There is no arch_misc_init on armv7 */ +#undef CONFIG_ARCH_MISC_INIT + +#undef CONFIG_SYS_MALLOC_LEN +#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) /* 4MiB for malloc() */ + +/* + * Environment variables configurations + */ +#if defined(CONFIG_CMD_SF) +#define CONFIG_SPI_FLASH_WINBOND +#define CONFIG_ENV_IS_IN_SPI_FLASH 1 +#define CONFIG_ENV_SECT_SIZE 0x1000 /* 4k */ +#define CONFIG_ENV_SIZE 0x20000 /* 128k */ +#define CONFIG_ENV_OFFSET 0xc0000 /* env starts here */ +#else +#define CONFIG_ENV_IS_NOWHERE 1 /* if env in SDRAM */ +#endif + +/* + * Default CuBox bootscript environment + */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "bootscript=boot.scr\0" \ + "loadaddr=0x02000000\0" \ + "mmc_started=0\0" \ + "ide_started=0\0" \ + "usb_started=0\0" \ + "mtdparts=mtdparts=spi0.0:768k(u-boot)ro,128k(uboot_env),128k(fdt),-(empty)\0" \ + "ethaddr=00:50:43:15:17:17\0" + +#define CONFIG_BOOTCOMMAND \ + "for devn in usb mmc ide ; do " \ + " for part in 0 1; do " \ + " for dir in / /boot/;do " \ + " for fs in ext2 fat; do " \ + " echo ===> Executing ${fs}load ${devn} 0:${part} ${loadaddr} ${dir}${bootscript};" \ + " if itest.s $devn -eq mmc; then" \ + " if itest.s $mmc_started -ne 1; then" \ + " mmcinfo; setenv mmc_started '1';fi;fi;" \ + " if itest.s $devn -eq usb; then" \ + " if itest.s $usb_started -ne 1; then" \ + " usb start; setenv usb_started '1';fi;fi;" \ + " if itest.s $devn -eq ide; then" \ + " if itest.s $ide_started -ne 1; then" \ + " ide reset; setenv ide_started '1';fi;fi;" \ + " if ${fs}load ${devn} 0:${part} ${loadaddr} ${dir}${bootscript}; then" \ + " source ${loadaddr}; fi;" \ + " if itest.s $devn -eq usb; then" \ + " echo ===> Executing ${fs}load ${devn} 1:${part} ${loadaddr} ${dir}${bootscript};" \ + " if ${fs}load ${devn} 1:${part} ${loadaddr} ${dir}${bootscript}; then" \ + " source ${loadaddr}; fi;" \ + " fi;" \ + " done;" \ + " done;" \ + " done;" \ + "done;" \ + "tftp ${loadaddr} ${bootscript};" \ + "source ${loadaddr};" + +/* + * Ethernet Driver configuration + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_MVGBE_PORTS {1} /* enable port 0 */ +#define CONFIG_PHY_BASE_ADR 1 +#define CONFIG_PHYLIB +#define CONFIG_PHY_MARVELL +#endif /* CONFIG_CMD_NET */ + +#ifdef CONFIG_CMD_IDE +#undef CONFIG_IDE_LED +#undef CONFIG_SYS_IDE_MAXBUS +#define CONFIG_SYS_IDE_MAXBUS 1 +#undef CONFIG_SYS_IDE_MAXDEVICE +#define CONFIG_SYS_IDE_MAXDEVICE 1 +#define CONFIG_SYS_ATA_IDE0_OFFSET MV_SATA_PORT0_OFFSET +#endif + +/* + * File system + */ +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_EXT4 +#define CONFIG_CMD_FAT +#define CONFIG_RBTREE +#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_MTDPARTS +#define CONFIG_LZO + +#endif /* _CONFIG_CUBOX_H */
On Dove kwboot can also be used to boot an u-boot image into RAM. In contrast to Kirkwood, Dove does not support the UART boot mode sequence but requires the UART boot mode to be selected through strap pins. The SolidRun CuBox has a push button to allow uart boot mode but fails on the boot sequence sent by kwboot.
This patch adds another cmdline option to allow to send a boot image without the boot sequence and adds support for Dove.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Changelog: v1->v2: - also update kwboot.1 manpage
Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Luka Perkov luka@openwrt.org --- doc/kwboot.1 | 13 ++++++++++--- tools/Makefile | 2 ++ tools/kwboot.c | 44 ++++++++++++++++++++++++++++++++++++++++---- 3 files changed, 52 insertions(+), 7 deletions(-)
diff --git a/doc/kwboot.1 b/doc/kwboot.1 index ed08398..3e26acc 100644 --- a/doc/kwboot.1 +++ b/doc/kwboot.1 @@ -1,17 +1,18 @@ -.TH KWBOOT 1 "2012-05-19" +.TH KWBOOT 1 "2012-12-02"
.SH NAME -kwboot - Boot Marvell Kirkwood SoCs over a serial link. +kwboot - Boot Marvell Kirkwood/Dove SoCs over a serial link. .SH SYNOPSIS .B kwboot .RB [ "-b \fIimage\fP" ] .RB [ "-p" ] .RB [ "-t" ] +.RB [ "-u" ] .RB [ "-B \fIbaudrate\fP" ] .RB \fITTY\fP .SH "DESCRIPTION"
-The \fBmkimage\fP program boots boards based on Marvell's Kirkwood +The \fBmkimage\fP program boots boards based on Marvell's Kirkwood/Dove platform over their integrated UART. Boot image files will typically contain a second stage boot loader, such as U-Boot. The image file must conform to Marvell's BootROM firmware image format @@ -68,6 +69,12 @@ If standard I/O streams connect to a console, this mode will terminate after receiving 'ctrl-\' followed by 'c' from console input.
.TP +.BI "-u" +Disables the UART boot mode sequence for platforms that do not support +it (e.g. Dove). Usually, the UART boot mode can be selected by pressing +a push button on power-up. + +.TP .BI "-B \fIbaudrate\fP" Adjust the baud rate on \fITTY\fP. Default rate is 115200.
diff --git a/tools/Makefile b/tools/Makefile index 686840a..845384f 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -73,6 +73,7 @@ BIN_FILES-$(CONFIG_MX28) += mxsboot$(SFX) BIN_FILES-$(CONFIG_NETCONSOLE) += ncb$(SFX) BIN_FILES-$(CONFIG_SHA1_CHECK_UB_IMG) += ubsha1$(SFX) BIN_FILES-$(CONFIG_KIRKWOOD) += kwboot$(SFX) +BIN_FILES-$(CONFIG_DOVE) += kwboot$(SFX)
# Source files which exist outside the tools directory EXT_OBJ_FILES-$(CONFIG_BUILD_ENVCRC) += common/env_embedded.o @@ -104,6 +105,7 @@ NOPED_OBJ_FILES-y += os_support.o OBJ_FILES-$(CONFIG_SHA1_CHECK_UB_IMG) += ubsha1.o NOPED_OBJ_FILES-y += ublimage.o OBJ_FILES-$(CONFIG_KIRKWOOD) += kwboot.o +OBJ_FILES-$(CONFIG_DOVE) += kwboot.o
# Don't build by default #ifeq ($(ARCH),ppc) diff --git a/tools/kwboot.c b/tools/kwboot.c index e773f01..199678a 100644 --- a/tools/kwboot.c +++ b/tools/kwboot.c @@ -293,6 +293,30 @@ kwboot_bootmsg(int tty, void *msg) }
static int +kwboot_bootmsg_uartmode(int tty) +{ + int rc; + char c; + + kwboot_printv("Please reboot the target into UART boot mode..."); + + do { + rc = tcflush(tty, TCIOFLUSH); + if (rc) + break; + + rc = kwboot_tty_recv(tty, &c, 1, KWBOOT_MSG_RSP_TIMEO); + + kwboot_spinner(); + + } while (rc || c != NAK); + + kwboot_printv("\n"); + + return rc; +} + +static int kwboot_xm_makeblock(struct kwboot_block *block, const void *data, size_t size, int pnum) { @@ -601,10 +625,11 @@ static void kwboot_usage(FILE *stream, char *progname) { fprintf(stream, - "Usage: %s -b <image> [ -p ] [ -t ] " + "Usage: %s -b <image> [ -p ] [ -t ] [ -u ] " "[-B <baud> ] <TTY>\n", progname); fprintf(stream, "\n"); fprintf(stream, " -b <image>: boot <image>\n"); + fprintf(stream, " -u: target requires UART boot mode (e.g. Dove)\n"); fprintf(stream, " -p: patch <image> to type 0x69 (uart boot)\n"); fprintf(stream, "\n"); fprintf(stream, " -t: mini terminal\n"); @@ -617,7 +642,7 @@ int main(int argc, char **argv) { const char *ttypath, *imgpath; - int rv, rc, tty, term, prot, patch; + int rv, rc, tty, uartmode, term, prot, patch; void *bootmsg; void *img; size_t size; @@ -628,6 +653,7 @@ main(int argc, char **argv) bootmsg = NULL; imgpath = NULL; img = NULL; + uartmode = 0; term = 0; patch = 0; size = 0; @@ -636,7 +662,7 @@ main(int argc, char **argv) kwboot_verbose = isatty(STDOUT_FILENO);
do { - int c = getopt(argc, argv, "hb:ptB:"); + int c = getopt(argc, argv, "hb:ptuB:"); if (c < 0) break;
@@ -654,6 +680,10 @@ main(int argc, char **argv) term = 1; break;
+ case 'u': + uartmode = 1; + break; + case 'B': speed = kwboot_tty_speed(atoi(optarg)); if (speed == -1) @@ -702,7 +732,13 @@ main(int argc, char **argv) } }
- if (bootmsg) { + if (uartmode) { + rc = kwboot_bootmsg_uartmode(tty); + if (rc) { + perror("bootmsg"); + goto out; + } + } else if (bootmsg) { rc = kwboot_bootmsg(tty, bootmsg); if (rc) { perror("bootmsg");
-----Original Message----- From: Sebastian Hesselbarth [mailto:sebastian.hesselbarth@gmail.com] Sent: 04 December 2012 14:02 To: Sebastian Hesselbarth Cc: u-boot@lists.denx.de; Rabeeh Khoury; Albert Aribaud; Prafulla Wadaskar; Andy Fleming; Joe Hershberger; Daniel Stodden; Luka Perkov Subject: [PATCH v2 00/10] Add Marvell Dove and SolidRun CuBox
This patch set add support for the Marvell Dove 88AP510 SoC and the SolidRun CuBox board based on that SoC. The patch set is divided into the four following sections:
(1) Patches 1-5: Add support for the Dove SoC and related drivers. Where possible drivers from Marvell Kirkwood are reused (mvsata, mvgbe), or forked to allow more generic usage (SPI, GPIO). The SDHCI driver is different and a new driver is added for it. The forked drivers can also be reused on Kirkwood but that would have required patching existing boards.
(2) Patches 6-8: Allow mvgbe to use the phylib API, add support for 88E1310 PHY and allow Dove to use the driver.
(3) Patch 9 Add the SolidRun CuBox as the first board based on Marvell Dove SoC.
(4) Patch 10 Add support for different UART boot mode found on Dove.
Changelog: v1->v2: respect review comments by Luka Perkov
- fix commenting styles and typos
Sebastian Hesselbarth (10): ARM: dove: add support for Marvell Dove SoC GPIO: add gpio driver for Orion SoCs MMC: sdhci: Add support for dove sdhci SPI: Add Orion SPI driver block: mvsata: add dove include NET: phy: add 88E1310 PHY initialization NET: mvgbe: add phylib support NET: mvgbe: add support for Dove Boards: Add support for SolidRun CuBox tools: Add support for Dove to kwboot
MAINTAINERS | 4 + arch/arm/cpu/armv7/dove/Makefile | 49 +++++ arch/arm/cpu/armv7/dove/cpu.c | 266 ++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/dram.c | 118 ++++++++++++ arch/arm/cpu/armv7/dove/lowlevel_init.S | 83 ++++++++ arch/arm/cpu/armv7/dove/mpp.c | 318 +++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/timer.c | 176 +++++++++++++++++ arch/arm/cpu/armv7/dove/usb.c | 101 ++++++++++ arch/arm/include/asm/arch-dove/config.h | 153 +++++++++++++++ arch/arm/include/asm/arch-dove/cpu.h | 204 ++++++++++++++++++++ arch/arm/include/asm/arch-dove/dove.h | 93 +++++++++ arch/arm/include/asm/arch-dove/gpio.h | 35 ++++ arch/arm/include/asm/arch-dove/mpp.h | 283 +++++++++++++++++++++++++++ board/solidrun/cubox/Makefile | 45 +++++ board/solidrun/cubox/cubox.c | 141 ++++++++++++++ board/solidrun/cubox/kwbimage.cfg | 76 ++++++++ boards.cfg | 1 + doc/kwboot.1 | 13 +- drivers/block/mvsata_ide.c | 2 + drivers/gpio/Makefile | 1 + drivers/gpio/orion_gpio.c | 167 ++++++++++++++++ drivers/mmc/Makefile | 1 + drivers/mmc/dove_sdhci.c | 101 ++++++++++ drivers/net/mvgbe.c | 70 ++++++- drivers/net/mvgbe.h | 7 + drivers/net/phy/marvell.c | 48 +++++ drivers/spi/Makefile | 1 + drivers/spi/orion_spi.c | 217 +++++++++++++++++++++ include/configs/cubox.h | 175 +++++++++++++++++ include/orion_gpio.h | 64 +++++++ tools/Makefile | 2 + tools/kwboot.c | 44 ++++- 32 files changed, 3048 insertions(+), 11 deletions(-) create mode 100644 arch/arm/cpu/armv7/dove/Makefile create mode 100644 arch/arm/cpu/armv7/dove/cpu.c create mode 100644 arch/arm/cpu/armv7/dove/dram.c create mode 100644 arch/arm/cpu/armv7/dove/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/dove/mpp.c create mode 100644 arch/arm/cpu/armv7/dove/timer.c create mode 100644 arch/arm/cpu/armv7/dove/usb.c create mode 100644 arch/arm/include/asm/arch-dove/config.h create mode 100644 arch/arm/include/asm/arch-dove/cpu.h create mode 100644 arch/arm/include/asm/arch-dove/dove.h create mode 100644 arch/arm/include/asm/arch-dove/gpio.h create mode 100644 arch/arm/include/asm/arch-dove/mpp.h create mode 100644 board/solidrun/cubox/Makefile create mode 100644 board/solidrun/cubox/cubox.c create mode 100644 board/solidrun/cubox/kwbimage.cfg create mode 100644 drivers/gpio/orion_gpio.c create mode 100644 drivers/mmc/dove_sdhci.c create mode 100644 drivers/spi/orion_spi.c create mode 100644 include/configs/cubox.h create mode 100644 include/orion_gpio.h
Hi Sebastian First of all thanks for this patch series. FYI: I'll review and provide the comments towards the end of this week.
Changelog: v1->v2: - respect review comments by Luka Perkov - fix commenting styles and typos - add MAINTAINERS entry - also update kwboot.1 manpage
v2->v3: - integrate kwboot patch from Daniel Stodden - rebase on release v2013.01
MAINTAINERS | 4 + arch/arm/cpu/armv7/dove/Makefile | 49 +++++ arch/arm/cpu/armv7/dove/cpu.c | 266 ++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/dram.c | 118 ++++++++++++ arch/arm/cpu/armv7/dove/lowlevel_init.S | 83 ++++++++ arch/arm/cpu/armv7/dove/mpp.c | 318 +++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/timer.c | 176 +++++++++++++++++ arch/arm/cpu/armv7/dove/usb.c | 101 ++++++++++ arch/arm/include/asm/arch-dove/config.h | 153 +++++++++++++++ arch/arm/include/asm/arch-dove/cpu.h | 204 ++++++++++++++++++++ arch/arm/include/asm/arch-dove/dove.h | 93 +++++++++ arch/arm/include/asm/arch-dove/gpio.h | 35 ++++ arch/arm/include/asm/arch-dove/mpp.h | 283 +++++++++++++++++++++++++++ board/solidrun/cubox/Makefile | 45 +++++ board/solidrun/cubox/cubox.c | 141 ++++++++++++++ board/solidrun/cubox/kwbimage.cfg | 76 ++++++++ boards.cfg | 1 + doc/kwboot.1 | 13 +- drivers/block/mvsata_ide.c | 2 + drivers/gpio/Makefile | 1 + drivers/gpio/orion_gpio.c | 167 ++++++++++++++++ drivers/mmc/Makefile | 1 + drivers/mmc/dove_sdhci.c | 101 ++++++++++ drivers/net/mvgbe.c | 70 ++++++- drivers/net/mvgbe.h | 7 + drivers/net/phy/marvell.c | 48 +++++ drivers/spi/Makefile | 1 + drivers/spi/orion_spi.c | 217 +++++++++++++++++++++ include/configs/cubox.h | 175 +++++++++++++++++ include/orion_gpio.h | 64 +++++++ tools/Makefile | 2 + tools/kwboot.c | 25 ++- 32 files changed, 3027 insertions(+), 13 deletions(-) create mode 100644 arch/arm/cpu/armv7/dove/Makefile create mode 100644 arch/arm/cpu/armv7/dove/cpu.c create mode 100644 arch/arm/cpu/armv7/dove/dram.c create mode 100644 arch/arm/cpu/armv7/dove/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/dove/mpp.c create mode 100644 arch/arm/cpu/armv7/dove/timer.c create mode 100644 arch/arm/cpu/armv7/dove/usb.c create mode 100644 arch/arm/include/asm/arch-dove/config.h create mode 100644 arch/arm/include/asm/arch-dove/cpu.h create mode 100644 arch/arm/include/asm/arch-dove/dove.h create mode 100644 arch/arm/include/asm/arch-dove/gpio.h create mode 100644 arch/arm/include/asm/arch-dove/mpp.h create mode 100644 board/solidrun/cubox/Makefile create mode 100644 board/solidrun/cubox/cubox.c create mode 100644 board/solidrun/cubox/kwbimage.cfg create mode 100644 drivers/gpio/orion_gpio.c create mode 100644 drivers/mmc/dove_sdhci.c create mode 100644 drivers/spi/orion_spi.c create mode 100644 include/configs/cubox.h create mode 100644 include/orion_gpio.h
This patch adds initial support for the armv7-based Marvell Dove SoC (88AP510).
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Luka Perkov luka@openwrt.org --- arch/arm/cpu/armv7/dove/Makefile | 49 +++++ arch/arm/cpu/armv7/dove/cpu.c | 266 ++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/dram.c | 118 ++++++++++++ arch/arm/cpu/armv7/dove/lowlevel_init.S | 83 ++++++++ arch/arm/cpu/armv7/dove/mpp.c | 318 +++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/timer.c | 176 +++++++++++++++++ arch/arm/cpu/armv7/dove/usb.c | 101 ++++++++++ arch/arm/include/asm/arch-dove/config.h | 153 +++++++++++++++ arch/arm/include/asm/arch-dove/cpu.h | 204 ++++++++++++++++++++ arch/arm/include/asm/arch-dove/dove.h | 93 +++++++++ arch/arm/include/asm/arch-dove/gpio.h | 35 ++++ arch/arm/include/asm/arch-dove/mpp.h | 283 +++++++++++++++++++++++++++ 12 files changed, 1879 insertions(+) create mode 100644 arch/arm/cpu/armv7/dove/Makefile create mode 100644 arch/arm/cpu/armv7/dove/cpu.c create mode 100644 arch/arm/cpu/armv7/dove/dram.c create mode 100644 arch/arm/cpu/armv7/dove/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/dove/mpp.c create mode 100644 arch/arm/cpu/armv7/dove/timer.c create mode 100644 arch/arm/cpu/armv7/dove/usb.c create mode 100644 arch/arm/include/asm/arch-dove/config.h create mode 100644 arch/arm/include/asm/arch-dove/cpu.h create mode 100644 arch/arm/include/asm/arch-dove/dove.h create mode 100644 arch/arm/include/asm/arch-dove/gpio.h create mode 100644 arch/arm/include/asm/arch-dove/mpp.h
diff --git a/arch/arm/cpu/armv7/dove/Makefile b/arch/arm/cpu/armv7/dove/Makefile new file mode 100644 index 0000000..127d67e --- /dev/null +++ b/arch/arm/cpu/armv7/dove/Makefile @@ -0,0 +1,49 @@ +# +# Marvell Dove SoC Makefile +# +# Sebastian Hesselbarth sebastian.hesselbarth@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).o + +SOBJS += lowlevel_init.o +COBJS-y := cpu.o dram.o timer.o mpp.o +COBJS-$(CONFIG_USB_EHCI_MARVELL) += usb.o + +COBJS := $(COBJS-y) +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/arm/cpu/armv7/dove/cpu.c b/arch/arm/cpu/armv7/dove/cpu.c new file mode 100644 index 0000000..b9e708c --- /dev/null +++ b/arch/arm/cpu/armv7/dove/cpu.c @@ -0,0 +1,266 @@ +/* + * Marvell Dove SoC cpu related functions + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <netdev.h> +#include <asm/cache.h> +#include <u-boot/md5.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> +#include <hush.h> + +void reset_cpu(unsigned long ignored) +{ + struct dovecpu_registers *cpureg = + (struct dovecpu_registers *)DOVE_CPU_REG_BASE; + + /* Enable soft reset to assert RSTOUTn */ + writel(readl(&cpureg->rstoutn_mask) | (1 << 2), + &cpureg->rstoutn_mask); + /* Assert soft reset */ + writel(readl(&cpureg->sys_soft_rst) | 1, + &cpureg->sys_soft_rst); + do {} while (1); +} + +#if defined(CONFIG_DISPLAY_CPUINFO) +int dove_print_cpu(void) +{ + char *cpu; + u32 idreg; + u16 part, rev; + + __asm__ __volatile__("mrc p15, 0, %0, c0, c0, 0" : "=r"(idreg)); + + part = (idreg >> ARM_ID_PARTNUM_OFFSET) & ARM_ID_PARTNUM_MASK; + rev = (idreg >> ARM_ID_REVISION_OFFSET) & ARM_ID_REVISION_MASK; + + switch (part) { + case DOVECPU_PART_SHEEVA: + cpu = "Marvell Sheeva"; + break; + default: + cpu = "Unknown CPU"; + } + + printf("CPU: %s (rev %d)\n", cpu, rev); + return 0; +} + +int dove_print_soc(void) +{ + char *soc, *rev; + u16 devid = (readl(DOVE_REG_PCIE_DEVID) >> 16) & 0xffff; + u8 revid = readl(DOVE_REG_PCIE_REVID) & 0xff; + + switch (devid) { + case DOVESOC_DEVID_AP510: + soc = "AP510"; + break; + case DOVESOC_DEVID_F6781: + soc = "F6781"; + break; + default: + printf("ERROR.. %s: Unsupported SoC %04x\n", __func__, devid); + return -1; + } + + switch (revid) { + case DOVESOC_REVID_Z0: + rev = "Z0"; + break; + case DOVESOC_REVID_Z1: + rev = "Z1"; + break; + case DOVESOC_REVID_Y0: + rev = "Y0"; + break; + case DOVESOC_REVID_Y1: + rev = "Y1"; + break; + case DOVESOC_REVID_X0: + rev = "X0"; + break; + case DOVESOC_REVID_A0: + rev = "A0"; + break; + case DOVESOC_REVID_A1: + rev = "A1"; + break; + default: + rev = "Unknown revision"; + }; + + printf("SoC: Dove 88%s (%s)\n", soc, rev); + return 0; +} + +int print_cpuinfo(void) +{ + if (dove_print_soc()) + return -1; + if (dove_print_cpu()) + return -1; + return 0; +} +#endif /* CONFIG_DISPLAY_CPUINFO */ + +/* + * dove_init_gpio - initial GPIO configuration + */ +void dove_init_gpio(struct dove_gpio_init *gpp) +{ + struct dovegpio_registers *gpio0reg = + (struct dovegpio_registers *)DOVE_GPIO0_BASE; + struct dovegpio_registers *gpio1reg = + (struct dovegpio_registers *)DOVE_GPIO1_BASE; + struct dovegpio_registers *gpio2reg = + (struct dovegpio_registers *)DOVE_GPIO2_BASE; + + /* Init GPIOS to default values as per board requirement */ + writel(gpp->val0, &gpio0reg->dout); + writel(gpp->val1, &gpio1reg->dout); + writel(gpp->val2, &gpio2reg->dout); + writel(gpp->oe0_n, &gpio0reg->oe); + writel(gpp->oe1_n, &gpio1reg->oe); + writel(gpp->oe2_n, &gpio2reg->oe); +} + +/* + * Window Size + * Used with the Base register to set the address window size and location. + * Must be programmed from LSB to MSB as sequence of ones followed by + * sequence of zeros. The number of ones specifies the size of the window in + * 64 KByte granularity (e.g., a value of 0x00FF specifies 256 = 16 MByte). + * NOTE: A value of 0x0 specifies 64-KByte size. + */ +unsigned int dove_winctrl_calcsize(unsigned int sizeval) +{ + int i; + unsigned int j = 0; + u32 val = sizeval >> 1; + + for (i = 0; val >= 0x10000; i++) { + j |= (1 << i); + val = val >> 1; + } + return 0x0000ffff & j; +} + +/* + * dove_config_adr_windows - Configure address Windows + * + * There are 8 address windows supported by Dove Soc to addess different + * devices. Windows 0-3 can be configured for size, BAR and remap addr. + * Windows 4-7 can be configured for size and BAR. + * Below configuration is standard for most of the cases + * + * If remap function not used, remap_lo must be set as base + */ +int dove_config_adr_windows(void) +{ + struct dovewin_registers *winregs = + (struct dovewin_registers *)DOVE_CPU_WIN_BASE; + + /* Window 0: 1M PCIE0 IO address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_1M, DOVECPU_TARGET_PCIE0, + DOVECPU_ATTR_PCIE_IO, DOVECPU_WIN_ENABLE), &winregs[0].ctrl); + + writel(DOVE_DEFADR_PCIE0_IO, &winregs[0].base); + writel(DOVE_DEFADR_PCIE0_IO_REMAP, &winregs[0].remap_lo); + writel(0x0, &winregs[0].remap_hi); + + /* Window 1: 1M PCIE1 IO address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_1M, DOVECPU_TARGET_PCIE1, + DOVECPU_ATTR_PCIE_IO, DOVECPU_WIN_ENABLE), &winregs[1].ctrl); + + writel(DOVE_DEFADR_PCIE1_IO, &winregs[1].base); + writel(DOVE_DEFADR_PCIE1_IO_REMAP, &winregs[1].remap_lo); + writel(0x0, &winregs[1].remap_hi); + + /* Window 2: 128M PCIE0 MEM address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_128M, DOVECPU_TARGET_PCIE0, + DOVECPU_ATTR_PCIE_MEM, DOVECPU_WIN_ENABLE), &winregs[2].ctrl); + + writel(DOVE_DEFADR_PCIE0_MEM, &winregs[2].base); + writel(DOVE_DEFADR_PCIE0_MEM, &winregs[2].remap_lo); + writel(0x0, &winregs[2].remap_hi); + + /* Window 3: 128M PCIE1 MEM address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_128M, DOVECPU_TARGET_PCIE1, + DOVECPU_ATTR_PCIE_MEM, DOVECPU_WIN_ENABLE), &winregs[3].ctrl); + + writel(DOVE_DEFADR_PCIE1_MEM, &winregs[3].base); + writel(DOVE_DEFADR_PCIE1_MEM, &winregs[3].remap_lo); + writel(0x0, &winregs[3].remap_hi); + + /* Window 4: 1M Cryptographic SRAM address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_1M, DOVECPU_TARGET_SASRAM, + DOVECPU_ATTR_SASRAM, DOVECPU_WIN_ENABLE), &winregs[4].ctrl); + writel(DOVE_DEFADR_SASRAM, &winregs[4].base); + + /* Window 5: 128M Bootrom address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_128M, DOVECPU_TARGET_BOOTROM, + DOVECPU_ATTR_BOOTROM, DOVECPU_WIN_ENABLE), &winregs[5].ctrl); + writel(DOVE_DEFADR_BOOTROM, &winregs[5].base); + + /* Window 6: 1M PMU Scratchpad address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_1M, DOVECPU_TARGET_PMURAM, + DOVECPU_ATTR_PMURAM, DOVECPU_WIN_ENABLE), &winregs[6].ctrl); + writel(DOVE_DEFADR_PMURAM, &winregs[6].base); + + /* Window 7: Disabled */ + writel(DOVECPU_WIN_DISABLE, &winregs[7].ctrl); + + return 0; +} + +#ifdef CONFIG_ARCH_CPU_INIT +int arch_cpu_init(void) +{ + dove_config_adr_windows(); +#ifdef CONFIG_USB_EHCI_MARVELL + dove_ehci_phy_init(0); + dove_ehci_phy_init(1); +#endif /* CONFIG_USB_EHCI_MARVELL */ + return 0; +} +#endif /* CONFIG_ARCH_CPU_INIT */ + +void enable_caches(void) +{ +#ifndef CONFIG_SYS_DCACHE_OFF + /* Enable D-cache. I-cache is already enabled in lowlevel_init.S */ + dcache_enable(); +#endif /* CONFIG_SYS_DCACHE_OFF */ +} + +#ifdef CONFIG_MVGBE +int cpu_eth_init(bd_t *bis) +{ + mvgbe_initialize(bis); + return 0; +} +#endif /* CONFIG_MVGBE */ diff --git a/arch/arm/cpu/armv7/dove/dram.c b/arch/arm/cpu/armv7/dove/dram.c new file mode 100644 index 0000000..437263c --- /dev/null +++ b/arch/arm/cpu/armv7/dove/dram.c @@ -0,0 +1,118 @@ +/* + * Marvell Dove SoC DRAM initialization + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <config.h> +#include <common.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define DOVE_REG_DRAM_MAP(x) (DOVE_REGISTER(0x800100) + (x * 0x10)) +#define DRAM_START_MASK 0xff800000 +#define DRAM_SIZE_MASK 0xf +#define DRAM_SIZE_SHIFT 16 + +/* + * dove_sdram_start - reads start from Memory Address Map Register n + */ +u32 dove_dram_start(enum memory_bank bank) +{ + u32 reg = readl(DOVE_REG_DRAM_MAP(bank)); + u32 enable = 0x01 & reg; + + if ((!enable) || (bank > BANK1)) + return 0; + + return reg & DRAM_START_MASK; +} + +/* + * dove_sdram_size - reads size from Memory Address Map Register n + */ +u32 dove_dram_size(enum memory_bank bank) +{ + u32 reg = readl(DOVE_REG_DRAM_MAP(bank)); + u32 enable = 0x01 & reg; + u32 size; + + if ((!enable) || (bank > BANK1)) + return 0; + + /* + * area_length: 7 = 8M, 8 = 16M, ..., 15 = 2048M + * size = 1 << (area_length + 16) + */ + size = (reg >> DRAM_SIZE_SHIFT) & DRAM_SIZE_MASK; + size = 1 << (size + 16); + return size; +} + +#ifndef CONFIG_SYS_BOARD_DRAM_INIT +int dram_init(void) +{ + int i; + + gd->ram_size = 0; + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + gd->bd->bi_dram[i].start = dove_dram_start(i); + gd->bd->bi_dram[i].size = dove_dram_size(i); + + /* + * It is assumed that all memory banks are consecutive + * and without gaps. + * If the gap is found, ram_size will be reported for + * consecutive memory only + */ + if (gd->bd->bi_dram[i].start != gd->ram_size) + break; + + gd->ram_size += gd->bd->bi_dram[i].size; + + } + + for (; i < CONFIG_NR_DRAM_BANKS; i++) { + /* + * If above loop terminated prematurely, we need to set + * remaining banks' start address & size as 0. Otherwise other + * u-boot functions and Linux kernel gets wrong values which + * could result in crash + */ + gd->bd->bi_dram[i].start = 0; + gd->bd->bi_dram[i].size = 0; + } + + return 0; +} + +/* + * If this function is not defined here, + * board.c alters dram bank zero configuration defined above. + */ +void dram_init_banksize(void) +{ + dram_init(); +} +#endif /* CONFIG_SYS_BOARD_DRAM_INIT */ diff --git a/arch/arm/cpu/armv7/dove/lowlevel_init.S b/arch/arm/cpu/armv7/dove/lowlevel_init.S new file mode 100644 index 0000000..105d12d --- /dev/null +++ b/arch/arm/cpu/armv7/dove/lowlevel_init.S @@ -0,0 +1,83 @@ +/* + * Marvell Dove SoC icache and reg base low level init + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm/arch/dove.h> +#include <generated/asm-offsets.h> +#include <linux/linkage.h> + +/* + * Enable Tauros2 L2 ICache + */ +.macro init_l2cc + mrc 15, 0, r0, c1, c0, 1 + orr r0, r0, #0x2 + mcr 15, 0, r0, c1, c0, 1 +.endm /* init_l2cc */ + +/* + * Init internal register base addresses + */ +.macro init_reg_base + /* set SB reg base to 0xf1000000 */ + ldr r1, =(DOVE_PREMAP_INT_REGS_BASE_ADDR) + ldr r6, =DOVE_SB_REGS_PHYS_BASE + str r6, [r1] + + /* set NB reg base to 0xf1800000 */ + ldr r1, =(DOVE_CPU_CTRL_REG) + ldr r4, =0xffff0000 + ldr r6, [r1] + and r6, r6, r4 + ldr r4, =DOVE_NB_REGS_PHYS_BASE + lsr r4, r6, #16 + orr r6, r6, r4 + str r6, [r1] + + /* Set AXI bridge address mapping to 0xf1800000 */ + ldr r1, =(DOVE_AXI_CTRL_REG) + ldr r4, =0x007fffff + ldr r6, [r1] + and r6, r6, r4 + ldr r4, =DOVE_NB_REGS_PHYS_BASE + orr r6, r6, r4 + str r6, [r1] + + /* set MC configuration register decode address to 0xf1800000 */ + ldr r1, =(DOVE_PREMAP_MC_DECODE_REG) + ldr r4, =0x0000ffff + ldr r6, [r1] + and r6, r6, r4 + ldr r4, =DOVE_NB_REGS_PHYS_BASE + orr r6, r6, r4 + str r6, [r1] + +.endm /* init_reg_base */ + +.section ".text.init", "x" + +ENTRY(lowlevel_init) + init_l2cc + init_reg_base + + /* r12 saved upper lr*/ + mov pc,lr +ENDPROC(lowlevel_init) diff --git a/arch/arm/cpu/armv7/dove/mpp.c b/arch/arm/cpu/armv7/dove/mpp.c new file mode 100644 index 0000000..ed24b38 --- /dev/null +++ b/arch/arm/cpu/armv7/dove/mpp.c @@ -0,0 +1,318 @@ +/* + * Marvell Dove SoC MPP pinmux + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> +#include <asm/arch/mpp.h> +#include <asm/arch/gpio.h> + +#define MPP_BITS 4 +#define MPP_MASK 0xf +#define MPPS_PER_REG 8 + +#define MPP_NUM(_x) ((_x) & 0xff) +#define MPP_SEL(_x) (((_x) >> 8) & 0x1f) +#define MPP_GPIO(_x) ((_x) & (1 << 15)) + +#define MPP_CTRL(i) (DOVE_MPP_BASE + (i * MPP_BITS)) +#define MPP_PMU_GENERAL_CTRL (DOVE_MPP_BASE + 0x010) +#define PMUG_AUDIO0_AC97_SEL (1 << 16) +#define MPP4_CTRL (DOVE_MPP_BASE + 0x240) +#define MPP4_SDIO0_GPIO_SEL (1 << 0) +#define MPP4_SDIO1_GPIO_SEL (1 << 1) +#define MPP4_CAMERA_GPIO_SEL (1 << 2) +#define MPP4_AUDIO1_GPIO_SEL (1 << 3) +#define MPP4_UART1_GPIO_SEL (1 << 4) +#define MPP4_SPI_GPIO_SEL (1 << 5) +#define MPP_GENERAL_CTRL (DOVE_PDMA_BASE + 0x403c) +#define MPPG_NAND_GPIO_SEL (1 << 0) +#define MPPG_AUDIO1_SPDIFO_GPIO_SEL (1 << 1) +#define GENERAL_CONFIG_1 (DOVE_PDMA_BASE + 0x002c) +#define GENERAL_TWSI_MUXEN_OPTION1 (1 << 7) +#define GENERAL_CONFIG_2 (DOVE_PDMA_BASE + 0x0030) +#define GENERAL_TWSI_OPTION3_SEL (1 << 22) +#define GENERAL_TWSI_MUXEN_OPTION3 (1 << 21) +#define GENERAL_TWSI_MUXEN_OPTION2 (1 << 20) +#define SSP_CONFIG_STATUS_1 (DOVE_PDMA_BASE + 0x0034) +#define SSP_SSP_ON_AUDIO1 (1 << 0) + +/* + * MPP0-23 have standard MPP register layout + */ +static void dove_mpp_std_set(u16 config) +{ + u8 num = MPP_NUM(config); + u32 off = (num / MPPS_PER_REG) * MPP_BITS; + u32 shift = (num % MPPS_PER_REG) * MPP_BITS; + u32 reg; + + /* configure standard MPP pin */ + reg = readl(MPP_CTRL(off)); + reg &= ~(MPP_MASK << shift); + reg |= MPP_SEL(config) << shift; + writel(reg, MPP_CTRL(off)); + + /* configure gpio capabilities */ + if (MPP_GPIO(config)) + orion_gpio_set_valid(num, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + else + orion_gpio_set_valid(num, 0); +} + +/* + * MPP0-15 also allow to mux PMU functions + */ +static void dove_mpp_pmu_set(u16 config) +{ + u8 num = MPP_NUM(config); + + if (MPP_SEL(config) == PMU) { + /* enable PMU on MPP */ + writel(readl(MPP_PMU_GENERAL_CTRL) | (1 << num), + MPP_PMU_GENERAL_CTRL); + /* disable gpio capabilities */ + orion_gpio_set_valid(num, 0); + } else { + /* disable PMU on MPP */ + writel(readl(MPP_PMU_GENERAL_CTRL) & ~(1 << num), + MPP_PMU_GENERAL_CTRL); + /* configure MPP */ + dove_mpp_std_set(config); + } +} + +/* + * MPP groups on MPP4_CTRL have different register layout + * and allow GPIO or special function only + */ +static void dove_mpp4_set(u16 config) +{ + u32 reg = readl(MPP4_CTRL); + u32 mask; + u8 n, nmin, nmax; + int gpio; + + switch (MPP_NUM(config)) { + case MPP_CAMERA: + mask = MPP4_CAMERA_GPIO_SEL; + nmin = MPP_CAMERA; + nmax = MPP_CAMERA_MAX; + break; + case MPP_SDIO0: + mask = MPP4_SDIO0_GPIO_SEL; + nmin = MPP_SDIO0; + nmax = MPP_SDIO0_MAX; + break; + case MPP_SDIO1: + mask = MPP4_SDIO1_GPIO_SEL; + nmin = MPP_SDIO1; + nmax = MPP_SDIO1_MAX; + break; + case MPP_SPI: + mask = MPP4_SPI_GPIO_SEL; + nmin = MPP_SPI; + nmax = MPP_SPI_MAX; + break; + case MPP_UART1: + mask = MPP4_UART1_GPIO_SEL; + nmin = MPP_UART1; + nmax = MPP_UART1_MAX; + break; + default: + return; + } + + reg &= ~mask; + if (MPP_SEL(config)) + reg |= mask; + writel(reg, MPP4_CTRL); + + /* configure gpio capabilities */ + gpio = 0; + if (MPP_GPIO(config)) + gpio = GPIO_INPUT_OK | GPIO_OUTPUT_OK; + for (n = nmin; n <= nmax; n++) + orion_gpio_set_valid(n, gpio); +} + +/* + * MPP_GENERAL_CTRL allows GPIO on NAND pins + */ +static void dove_mpp_nand_set(u16 config) +{ + u32 reg = readl(MPP_GENERAL_CTRL); + u8 n; + int gpio; + + reg &= ~MPPG_NAND_GPIO_SEL; + if (config == MPP_NAND_GPO) + reg |= MPPG_NAND_GPIO_SEL; + writel(reg, MPP_GENERAL_CTRL); + + /* configure gpio capabilities */ + gpio = (config == MPP_NAND_GPO) ? GPIO_OUTPUT_OK : 0; + for (n = MPP_NAND; n <= MPP_NAND_MAX; n++) + orion_gpio_set_valid(n, gpio); +} + +/* + * Dedicated audio1 pins can carry i2s, spdif, ssp or twsi + * and gpio in various combinations + */ +#define AUDIO1_TWSI (1 << 0) +#define AUDIO1_SPDIFO (1 << 1) +#define AUDIO1_SSP (1 << 2) +#define AUDIO1_GPIO (1 << 3) + +static void dove_mpp_audio1_set(u16 config) +{ + u32 mpp4 = readl(MPP4_CTRL); + u32 sspc1 = readl(SSP_CONFIG_STATUS_1); + u32 gmpp = readl(MPP_GENERAL_CTRL); + u32 gcfg2 = readl(GENERAL_CONFIG_2); + u8 n, sel = MPP_SEL(config); + int gpio; + + gcfg2 &= ~GENERAL_TWSI_OPTION3_SEL; + gmpp &= ~MPPG_AUDIO1_SPDIFO_GPIO_SEL; + sspc1 &= ~SSP_SSP_ON_AUDIO1; + mpp4 &= ~MPP4_AUDIO1_GPIO_SEL; + if (sel & AUDIO1_TWSI) + gcfg2 |= GENERAL_TWSI_OPTION3_SEL; + if (sel & AUDIO1_SPDIFO) + gmpp |= MPPG_AUDIO1_SPDIFO_GPIO_SEL; + if (sel & AUDIO1_SSP) + sspc1 |= SSP_SSP_ON_AUDIO1; + if (sel & AUDIO1_GPIO) + mpp4 |= MPP4_AUDIO1_GPIO_SEL; + + writel(mpp4, MPP4_CTRL); + writel(sspc1, SSP_CONFIG_STATUS_1); + writel(gmpp, MPP_GENERAL_CTRL); + writel(gcfg2, GENERAL_CONFIG_2); + + /* gpio allows gpio on all audio1 mpp pins */ + gpio = 0; + if (config == MPP_AUDIO1_GPIO) + gpio = GPIO_INPUT_OK | GPIO_OUTPUT_OK; + + for (n = MPP_AUDIO1; n <= MPP_AUDIO1_MAX; n++) + orion_gpio_set_valid(n, gpio); + + switch (config) { + /* spdifo and twsi allow gpio on mpp[52:55] */ + case MPP_AUDIO1_SPDIFO: + case MPP_AUDIO1_TWSI: + orion_gpio_set_valid(52, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + orion_gpio_set_valid(53, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + orion_gpio_set_valid(54, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + orion_gpio_set_valid(55, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + break; + /* i2s and ssp allow gpio on mpp[56:57] */ + case MPP_AUDIO1_I2S: + case MPP_AUDIO1_SSP: + orion_gpio_set_valid(56, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + orion_gpio_set_valid(57, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + break; + } +} + +/* + * MPP PMU switches audio0 pins to ac97 or i2s0 + */ +static void dove_mpp_audio0_set(u16 config) +{ + /* switch i2s or ac97 to audio0 */ + u32 reg = readl(MPP_PMU_GENERAL_CTRL); + + reg &= ~PMUG_AUDIO0_AC97_SEL; + if (config == MPP_AUDIO0_AC97) + reg |= PMUG_AUDIO0_AC97_SEL; + writel(reg, MPP_PMU_GENERAL_CTRL); +} + +/* + * TWSI has 3 optional pin sets that can be switched during runtime + */ +static void dove_mpp_twsi_set(u16 config) +{ + u32 gcfg1 = readl(GENERAL_CONFIG_1); + u32 gcfg2 = readl(GENERAL_CONFIG_2); + + gcfg1 &= ~GENERAL_TWSI_MUXEN_OPTION1; + gcfg2 &= ~(GENERAL_TWSI_MUXEN_OPTION2 | GENERAL_TWSI_MUXEN_OPTION3); + + switch (config) { + case MPP_TWSI_OPTION1: + gcfg1 |= GENERAL_TWSI_MUXEN_OPTION1; + break; + case MPP_TWSI_OPTION2: + gcfg2 |= GENERAL_TWSI_MUXEN_OPTION2; + break; + case MPP_TWSI_OPTION3: + gcfg2 |= GENERAL_TWSI_MUXEN_OPTION3; + break; + } + + writel(gcfg1, GENERAL_CONFIG_1); + writel(gcfg2, GENERAL_CONFIG_2); +} + +void dove_mpp_conf(u16 *mpp_list) +{ + while (*mpp_list) { + u8 num = MPP_NUM(*mpp_list); + + if (num <= MPP_PMU_MAX) + dove_mpp_pmu_set(*mpp_list); + else if (num <= MPP_STD_MAX) + dove_mpp_std_set(*mpp_list); + else { + switch (num) { + case MPP_CAMERA: + case MPP_SDIO0: + case MPP_SDIO1: + case MPP_SPI: + case MPP_UART1: + dove_mpp4_set(*mpp_list); + break; + case MPP_NAND: + dove_mpp_nand_set(*mpp_list); + break; + case MPP_AUDIO0: + dove_mpp_audio0_set(*mpp_list); + break; + case MPP_AUDIO1: + dove_mpp_audio1_set(*mpp_list); + break; + case MPP_TWSI: + dove_mpp_twsi_set(*mpp_list); + break; + } + } + mpp_list++; + } +} diff --git a/arch/arm/cpu/armv7/dove/timer.c b/arch/arm/cpu/armv7/dove/timer.c new file mode 100644 index 0000000..3be9b78 --- /dev/null +++ b/arch/arm/cpu/armv7/dove/timer.c @@ -0,0 +1,176 @@ +/* + * Marvell Dove SoC timer + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/dove.h> + +#define UBOOT_CNTR 0 /* counter to use for uboot timer */ + +/* Timer reload and current value registers */ +struct dovetmr_val { + u32 reload; /* Timer reload reg */ + u32 val; /* Timer value reg */ +}; + +/* Timer registers */ +struct dovetmr_registers { + u32 ctrl; /* Timer control reg */ + u32 pad[3]; + struct dovetmr_val tmr[2]; + u32 wdt_reload; + u32 wdt_val; +}; + +struct dovetmr_registers *dovetmr_regs = + (struct dovetmr_registers *)DOVE_TIMER_BASE; + +/* + * ARM Timers Registers Map + */ +#define CNTMR_CTRL_REG &dovetmr_regs->ctrl +#define CNTMR_RELOAD_REG(tmrnum) &dovetmr_regs->tmr[tmrnum].reload +#define CNTMR_VAL_REG(tmrnum) &dovetmr_regs->tmr[tmrnum].val + +/* + * ARM Timers Control Register + * CPU_TIMERS_CTRL_REG (CTCR) + */ +#define CTCR_ARM_TIMER_EN_OFFS(cntr) (cntr * 2) +#define CTCR_ARM_TIMER_EN_MASK(cntr) (1 << CTCR_ARM_TIMER_EN_OFFS) +#define CTCR_ARM_TIMER_EN(cntr) (1 << CTCR_ARM_TIMER_EN_OFFS(cntr)) +#define CTCR_ARM_TIMER_DIS(cntr) (0 << CTCR_ARM_TIMER_EN_OFFS(cntr)) + +#define CTCR_ARM_TIMER_AUTO_OFFS(cntr) ((cntr * 2) + 1) +#define CTCR_ARM_TIMER_AUTO_MASK(cntr) (1 << 1) +#define CTCR_ARM_TIMER_AUTO_EN(cntr) (1 << CTCR_ARM_TIMER_AUTO_OFFS(cntr)) +#define CTCR_ARM_TIMER_AUTO_DIS(cntr) (0 << CTCR_ARM_TIMER_AUTO_OFFS(cntr)) + +/* + * ARM Timer\Watchdog Reload Register + * CNTMR_RELOAD_REG (TRR) + */ +#define TRG_ARM_TIMER_REL_OFFS 0 +#define TRG_ARM_TIMER_REL_MASK 0xffffffff + +/* + * ARM Timer\Watchdog Register + * CNTMR_VAL_REG (TVRG) + */ +#define TVR_ARM_TIMER_OFFS 0 +#define TVR_ARM_TIMER_MASK 0xffffffff +#define TVR_ARM_TIMER_MAX 0xffffffff +#define TIMER_LOAD_VAL 0xffffffff + +#define READ_TIMER (readl(CNTMR_VAL_REG(UBOOT_CNTR)) / \ + (CONFIG_SYS_TCLK / 1000)) + +DECLARE_GLOBAL_DATA_PTR; + +#define timestamp gd->tbl +#define lastdec gd->lastinc + +ulong get_timer_masked(void) +{ + ulong now = READ_TIMER; + + if (lastdec >= now) { + /* normal mode */ + timestamp += lastdec - now; + } else { + /* we have an overflow ... */ + timestamp += lastdec + + (TIMER_LOAD_VAL / (CONFIG_SYS_TCLK / 1000)) - now; + } + lastdec = now; + + return timestamp; +} + +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +void __udelay(unsigned long usec) +{ + uint current; + ulong delayticks; + + current = readl(CNTMR_VAL_REG(UBOOT_CNTR)); + delayticks = (usec * (CONFIG_SYS_TCLK / 1000000)); + + if (current < delayticks) { + delayticks -= current; + do {} while (readl(CNTMR_VAL_REG(UBOOT_CNTR)) < current); + do {} while ((TIMER_LOAD_VAL - delayticks) < + readl(CNTMR_VAL_REG(UBOOT_CNTR))); + } else { + do {} while (readl(CNTMR_VAL_REG(UBOOT_CNTR)) > + (current - delayticks)); + } +} + +/* + * init the counter + */ +int timer_init(void) +{ + unsigned int cntmrctrl; + + /* load value into timer */ + writel(TIMER_LOAD_VAL, CNTMR_RELOAD_REG(UBOOT_CNTR)); + writel(TIMER_LOAD_VAL, CNTMR_VAL_REG(UBOOT_CNTR)); + + /* enable timer in auto reload mode */ + cntmrctrl = readl(CNTMR_CTRL_REG); + cntmrctrl |= CTCR_ARM_TIMER_EN(UBOOT_CNTR); + cntmrctrl |= CTCR_ARM_TIMER_AUTO_EN(UBOOT_CNTR); + writel(cntmrctrl, CNTMR_CTRL_REG); + + /* init the timestamp and lastdec value */ + lastdec = READ_TIMER; + timestamp = 0; + + return 0; +} + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On ARM it just returns the timer value. + */ +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + return (ulong)CONFIG_SYS_HZ; +} diff --git a/arch/arm/cpu/armv7/dove/usb.c b/arch/arm/cpu/armv7/dove/usb.c new file mode 100644 index 0000000..1b932db --- /dev/null +++ b/arch/arm/cpu/armv7/dove/usb.c @@ -0,0 +1,101 @@ +/* + * Marvell Dove SoC USB PHY init + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> + +/* Dove USB2.0 PHY registers */ +#define USB20_POWER_CTRL ((base) + 0x400) +#define USB20_PHY_PLL_CTRL ((base) + 0x410) +#define PHY_PLL_VCO_RECALIBRATE (1 << 21) +#define USB20_PHY_TX_CTRL ((base) + 0x420) +#define PHY_TX_HS_STRESS_CTRL (1 << 31) +#define PHY_TX_BLOCK_EN (1 << 21) +#define PHY_TX_IMP_CAL_VTH(x) (x << 14) +#define PHY_TX_IMP_CAL_VTH_MASK PHY_TX_IMP_CAL_VTH(0x7) +#define PHY_TX_RCAL_START (1 << 12) +#define PHY_TX_LOWVDD_EN (1 << 11) +#define USB20_PHY_RX_CTRL ((base) + 0x430) +#define PHY_RX_EDGE_DET(x) (x << 26) +#define PHY_RX_EDGE_DET_MASK PHY_RX_EDGE_DET(0x3) +#define PHY_RX_CDR_FASTLOCK_EN (1 << 21) +#define PHY_RX_SQ_LENGTH(x) (x << 15) +#define PHY_RX_SQ_LENGTH_MASK PHY_RX_SQ_LENGTH(0x3) +#define PHY_RX_SQ_THRESH(x) (x << 4) +#define PHY_RX_SQ_THRESH_MASK PHY_RX_SQ_THRESH(0xf) +#define PHY_RX_LPF_COEFF(x) (x << 2) +#define PHY_RX_LPF_COEFF_MASK PHY_RX_LPF_COEFF(0x3) +#define USB20_PHY_IVREF_CTRL ((base) + 0x440) +#define PHY_IVREF_TXVDD12(x) (x << 8) +#define PHY_IVREF_TXVDD12_MASK PHY_IVREF_TXVDD12(0x3) +#define USB20_PHY_TESTGRP_CTRL ((base) + 0x450) +#define PHY_TESTGRP_SQ_RST (1 << 15) + +void dove_ehci_phy_init(int port) +{ + u32 base = (port == 0) ? DOVE_USB20_0_BASE : DOVE_USB20_1_BASE; + u32 reg; + + /* USB PHY PLL control */ + reg = readl(USB20_PHY_PLL_CTRL); + writel(reg | PHY_PLL_VCO_RECALIBRATE, USB20_PHY_PLL_CTRL); + udelay(100); + writel(reg & ~PHY_PLL_VCO_RECALIBRATE, USB20_PHY_PLL_CTRL); + + /* USB PHY Tx control */ + reg = readl(USB20_PHY_TX_CTRL); + reg &= ~PHY_TX_IMP_CAL_VTH_MASK; + reg |= PHY_TX_IMP_CAL_VTH(0x5); + reg |= PHY_TX_LOWVDD_EN; + reg |= PHY_TX_RCAL_START; + reg |= PHY_TX_BLOCK_EN; + reg |= PHY_TX_HS_STRESS_CTRL; + writel(reg, USB20_PHY_TX_CTRL); + udelay(100); + writel(reg & ~PHY_TX_RCAL_START, USB20_PHY_TX_CTRL); + + /* USB PHY RX control */ + reg = readl(USB20_PHY_RX_CTRL); + reg &= ~(PHY_RX_LPF_COEFF_MASK | PHY_RX_SQ_THRESH_MASK | + PHY_RX_SQ_LENGTH_MASK | PHY_RX_EDGE_DET_MASK); + reg |= PHY_RX_LPF_COEFF(0x1); + reg |= PHY_RX_SQ_THRESH(0xc); + reg |= PHY_RX_SQ_LENGTH(0x1); + reg |= PHY_RX_EDGE_DET(0x0); + reg &= ~PHY_RX_CDR_FASTLOCK_EN; + writel(reg, USB20_PHY_RX_CTRL); + + /* USB PHY IVREF control */ + reg = readl(USB20_PHY_IVREF_CTRL); + reg &= ~PHY_IVREF_TXVDD12_MASK; + reg |= PHY_IVREF_TXVDD12(0x3); + writel(reg, USB20_PHY_IVREF_CTRL); + + /* USB PHY TEST GROUP control */ + reg = readl(USB20_PHY_TESTGRP_CTRL); + reg &= ~PHY_TESTGRP_SQ_RST; + writel(reg, USB20_PHY_TESTGRP_CTRL); +} diff --git a/arch/arm/include/asm/arch-dove/config.h b/arch/arm/include/asm/arch-dove/config.h new file mode 100644 index 0000000..2d94a48 --- /dev/null +++ b/arch/arm/include/asm/arch-dove/config.h @@ -0,0 +1,153 @@ +/* + * Marvell SoC config + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVE_CONFIG_H +#define _DOVE_CONFIG_H + +#include <asm/arch/dove.h> + +#define CONFIG_ARMV7 /* Basic Architecture */ +#define CONFIG_DOVE /* SOC Family Name */ +#define CONFIG_SHEEVA_88SV581 /* CPU Core subversion */ +#define CONFIG_SYS_CACHELINE_SIZE 32 + /* default Dcache Line length for Dove */ +#define CONFIG_SYS_ARM_CACHE_WRITETHROUGH +#define CONFIG_SYS_DCACHE_OFF /* Disable DCache by default */ + +/* + * By default kwbimage.cfg from board specific folder is used + * If for some board, different configuration file need to be used, + * CONFIG_SYS_KWD_CONFIG should be defined in board specific header file + */ +#ifndef CONFIG_SYS_KWD_CONFIG +#define CONFIG_SYS_KWD_CONFIG $(SRCTREE)/$(CONFIG_BOARDDIR)/kwbimage.cfg +#endif /* CONFIG_SYS_KWD_CONFIG */ + +/* Dove has 2k of Security SRAM, use it for SP */ +#define CONFIG_SYS_INIT_SP_ADDR 0xC8012000 +#define CONFIG_NR_DRAM_BANKS_MAX 2 + +#define CONFIG_I2C_MVTWSI_BASE DOVE_TWSI_BASE +#define MV_UART_CONSOLE_BASE DOVE_UART0_BASE +#define MV_SATA_BASE DOVE_SATA_BASE +#define MV_SATA_PORT0_OFFSET DOVE_SATA_PORT0_OFFSET + +/* + * NAND configuration + */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_KIRKWOOD 1 +#define CONFIG_SYS_NAND_BASE 0xD8000000 /* MV_DEFADR_NANDF */ +#define NAND_ALLOW_ERASE_ALL 1 +#endif + +/* + * SPI Flash configuration + */ +#ifdef CONFIG_CMD_SF +#define CONFIG_HARD_SPI 1 +#define CONFIG_ORION_SPI 1 +#define ORION_SPI_BASE DOVE_SPI_BASE +#ifndef CONFIG_ENV_SPI_BUS +# define CONFIG_ENV_SPI_BUS 0 +#endif +#ifndef CONFIG_ENV_SPI_CS +# define CONFIG_ENV_SPI_CS 0 +#endif +#ifndef CONFIG_ENV_SPI_MAX_HZ +# define CONFIG_ENV_SPI_MAX_HZ 25000000 +#endif +#endif + +/* + * Ethernet Driver configuration + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_CMD_MII +#define CONFIG_NETCONSOLE /* include NetConsole support */ +#define CONFIG_PHYLIB +#define CONFIG_MVGBE /* Enable Marvell Gbe Controller Driver */ +#define CONFIG_SYS_FAULT_ECHO_LINK_DOWN /* detect link using phy */ +#define CONFIG_ENV_OVERWRITE /* ethaddr can be reprogrammed */ +#endif /* CONFIG_CMD_NET */ + +/* + * SDHCI + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_MMC +#define CONFIG_MMC_SDMA +#define CONFIG_SDHCI +#define CONFIG_DOVE_SDHCI /* Enable Dove SDHCI controller driver */ +#define CONFIG_MMC_SDHCI_IO_ACCESSORS +#define CONFIG_SYS_MMC_MAX_DEVICE 2 +#endif + +/* + * USB/EHCI + */ +#ifdef CONFIG_CMD_USB +#define CONFIG_USB_EHCI_MARVELL +#define CONFIG_EHCI_IS_TDI +#endif /* CONFIG_CMD_USB */ + +/* + * IDE Support on SATA ports + */ +#ifdef CONFIG_CMD_IDE +#define __io +#define CONFIG_CMD_EXT2 +#define CONFIG_MVSATA_IDE +#define CONFIG_IDE_PREINIT +#define CONFIG_MVSATA_IDE_USE_PORT1 +/* Needs byte-swapping for ATA data register */ +#define CONFIG_IDE_SWAP_IO +/* Data, registers and alternate blocks are at the same offset */ +#define CONFIG_SYS_ATA_DATA_OFFSET (0x0100) +#define CONFIG_SYS_ATA_REG_OFFSET (0x0100) +#define CONFIG_SYS_ATA_ALT_OFFSET (0x0100) +/* Each 8-bit ATA register is aligned to a 4-bytes address */ +#define CONFIG_SYS_ATA_STRIDE 4 +/* Controller supports 48-bits LBA addressing */ +#define CONFIG_LBA48 +/* CONFIG_CMD_IDE requires some #defines for ATA registers */ +#define CONFIG_SYS_IDE_MAXBUS 2 +#define CONFIG_SYS_IDE_MAXDEVICE 2 +/* ATA registers base is at SATA controller base */ +#define CONFIG_SYS_ATA_BASE_ADDR MV_SATA_BASE +#endif /* CONFIG_CMD_IDE */ + +/* + * I2C related stuff + */ +#ifdef CONFIG_CMD_I2C +#ifndef CONFIG_SOFT_I2C +#define CONFIG_I2C_MVTWSI +#endif +#define CONFIG_SYS_I2C_SLAVE 0x0 +#define CONFIG_SYS_I2C_SPEED 100000 +#endif + +#endif /* _DOVE_CONFIG_H */ diff --git a/arch/arm/include/asm/arch-dove/cpu.h b/arch/arm/include/asm/arch-dove/cpu.h new file mode 100644 index 0000000..718dd59 --- /dev/null +++ b/arch/arm/include/asm/arch-dove/cpu.h @@ -0,0 +1,204 @@ +/* + * Marvell Dove SoC CPU + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVECPU_H +#define _DOVECPU_H + +#include <asm/system.h> + +#ifndef __ASSEMBLY__ + +#define DOVECPU_WIN_CTRL_DATA(size, target, attr, en) (en | (target << 4) \ + | (attr << 8) | (dove_winctrl_calcsize(size) << 16)) + +#define DOVEGBE_PORT_SERIAL_CONTROL1_REG (DOVE_EGIGA_BASE + 0x44c) +#define DOVE_REG_PCIE_DEVID (DOVE_REG_PCIE0_BASE + 0x00) +#define DOVE_REG_PCIE_REVID (DOVE_REG_PCIE0_BASE + 0x08) +#define DOVE_REG_SYSRST_CNT (DOVE_MPP_BASE + 0x50) +#define SYSRST_CNT_1SEC_VAL (25*1000000) +#define DOVE_REG_MPP_OUT_DRV_REG (DOVE_MPP_BASE + 0xE0) + +enum memory_bank { + BANK0, + BANK1, +}; + +enum dovecpu_winen { + DOVECPU_WIN_DISABLE, + DOVECPU_WIN_ENABLE +}; + +enum dovecpu_target { + DOVECPU_TARGET_DRAM = 0x0, + DOVECPU_TARGET_SASRAM = 0x3, + DOVECPU_TARGET_NAND = 0xc, + DOVECPU_TARGET_PMURAM = 0xd, + DOVECPU_TARGET_PCIE0 = 0x4, + DOVECPU_TARGET_PCIE1 = 0x8, + DOVECPU_TARGET_SPI = 0x1, + DOVECPU_TARGET_BOOTROM = 0x1, +}; + +enum dovecpu_attrib { + DOVECPU_ATTR_DRAM = 0x00, + DOVECPU_ATTR_SASRAM = 0x00, + DOVECPU_ATTR_NAND = 0x00, + DOVECPU_ATTR_PMURAM = 0x00, + DOVECPU_ATTR_PCIE_IO = 0xe0, + DOVECPU_ATTR_PCIE_MEM = 0xe8, + DOVECPU_ATTR_SPI0 = 0xfe, + DOVECPU_ATTR_SPI1 = 0xfb, + DOVECPU_ATTR_BOOTROM = 0xfd, +}; + +enum dovecpu_part { + DOVECPU_PART_SHEEVA = 0x581, +}; + +enum dovesoc_devid { + DOVESOC_DEVID_F6781 = 0x6781, + DOVESOC_DEVID_AP510 = 0x0510, +}; + +enum dovesoc_revid { + DOVESOC_REVID_Z0 = 0, + DOVESOC_REVID_Z1 = 1, + DOVESOC_REVID_Y0 = 2, + DOVESOC_REVID_Y1 = 3, + DOVESOC_REVID_X0 = 4, + DOVESOC_REVID_A0 = 6, + DOVESOC_REVID_A1 = 7, +}; + +/* + * Default Device Address MAP BAR values + */ +#define DOVE_DEFADR_PCIE0_MEM 0xe0000000 +#define DOVE_DEFADR_PCIE0_IO 0xf2000000 +#define DOVE_DEFADR_PCIE0_IO_REMAP 0x00000000 +#define DOVE_DEFADR_PCIE1_MEM 0xe8000000 +#define DOVE_DEFADR_PCIE1_IO 0xf2100000 +#define DOVE_DEFADR_PCIE1_IO_REMAP 0x00100000 +#define DOVE_DEFADR_SASRAM 0xc8000000 +#define DOVE_DEFADR_BOOTROM 0xf8000000 +#define DOVE_DEFADR_PMURAM 0xf0000000 + +/* + * ARM CPUID register + */ +#define ARM_ID_REVISION_OFFSET 0 +#define ARM_ID_REVISION_MASK 0xf +#define ARM_ID_PARTNUM_OFFSET 4 +#define ARM_ID_PARTNUM_MASK 0xfff +#define ARM_ID_ARCH_OFFSET 16 +#define ARM_ID_ARCH_MASK 0xf +#define ARM_ID_VAR_OFFSET 20 +#define ARM_ID_VAR_MASK 0xf +#define ARM_ID_ASCII_OFFSET 24 +#define ARM_ID_ASCII_MASK 0xff + +/* + * read feroceon/sheeva core extra feature register + * using co-proc instruction + */ +static inline unsigned int readfr_extra_feature_reg(void) +{ + unsigned int val; + asm volatile ("mrc p15, 1, %0, c15, c1, 0 @ readfr exfr" : "=r" + (val) : : "cc"); + return val; +} + +/* + * write feroceon/sheeva core extra feature register + * using co-proc instruction + */ +static inline void writefr_extra_feature_reg(unsigned int val) +{ + asm volatile ("mcr p15, 1, %0, c15, c1, 0 @ writefr exfr" : : "r" + (val) : "cc"); + isb(); +} + +/* + * Downstream Bridge Registers + */ +struct dovewin_registers { + u32 ctrl; + u32 base; + u32 remap_lo; + u32 remap_hi; +}; + +/* + * CPU control and status Registers + */ +struct dovecpu_registers { + u32 config; /* 0x20100 */ + u32 ctrl_stat; /* 0x20104 */ + u32 rstoutn_mask; /* 0x20108 */ + u32 sys_soft_rst; /* 0x2010C */ + u32 bridge_cause_irq; /* 0x20110 */ + u32 bridge_mask_irq; /* 0x20114 */ + u32 pad1; + u32 pmu_ctrl; /* 0x2011c */ +}; + +/* + * GPIO 0/1 Registers + * GPIO 2 Registers (no datain/irq) + */ +struct dovegpio_registers { + u32 dout; + u32 oe; + u32 blink_en; + u32 din_pol; + u32 din; + u32 irq_cause; + u32 irq_mask; + u32 irq_level; +}; + +struct dove_gpio_init { + u32 val0; + u32 val1; + u32 val2; + u32 oe0_n; + u32 oe1_n; + u32 oe2_n; +}; + +/* + * functions + */ +void reset_cpu(unsigned long ignored); +unsigned char get_random_hex(void); +u32 dove_dram_start(enum memory_bank bank); +u32 dove_dram_size(enum memory_bank bank); +int dove_config_adr_windows(void); +void dove_init_gpio(struct dove_gpio_init *); +unsigned int dove_winctrl_calcsize(unsigned int sizeval); + +#endif /* __ASSEMBLY__ */ +#endif /* _DOVECPU_H */ diff --git a/arch/arm/include/asm/arch-dove/dove.h b/arch/arm/include/asm/arch-dove/dove.h new file mode 100644 index 0000000..da5011b --- /dev/null +++ b/arch/arm/include/asm/arch-dove/dove.h @@ -0,0 +1,93 @@ +/* + * Marvell Dove SoC register offsets and config + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVE_H +#define _DOVE_H + +/* Dove TCLK is fixed to 166MHz */ +#define CONFIG_SYS_TCLK 166666667 + +/* SOC specific definitions */ +#define DOVE_PREMAP_REGS_PHYS_BASE 0xd0000000 +#define DOVE_PREMAP_INT_REGS_BASE_ADDR (DOVE_PREMAP_REGS_PHYS_BASE + 0x20080) +#define DOVE_PREMAP_MC_DECODE_REG (DOVE_PREMAP_REGS_PHYS_BASE + 0x800010) + +#define DOVE_SB_REGS_PHYS_BASE 0xf1000000 +#define DOVE_NB_REGS_PHYS_BASE 0xf1800000 +#define DOVE_REGISTER(x) (DOVE_SB_REGS_PHYS_BASE + x) + +#define DOVE_AXI_CTRL_REG (DOVE_REGISTER(0xd0224)) +#define DOVE_CPU_CTRL_REG (DOVE_REGISTER(0xd025c)) +#define DOVE_MC_CTRL_REG (DOVE_REGISTER(0xd0260)) +#define DOVE_MC_DECODE_REG (DOVE_REGISTER(0x800010)) + +#define DOVE_SPI_BASE (DOVE_REGISTER(0x10600)) +#define DOVE_TWSI_BASE (DOVE_REGISTER(0x11000)) +#define DOVE_UART0_BASE (DOVE_REGISTER(0x12000)) +#define DOVE_UART1_BASE (DOVE_REGISTER(0x12100)) +#define DOVE_UART2_BASE (DOVE_REGISTER(0x12200)) +#define DOVE_UART3_BASE (DOVE_REGISTER(0x12300)) +#define DOVE_CPU_WIN_BASE (DOVE_REGISTER(0x20000)) +#define DOVE_CPU_REG_BASE (DOVE_REGISTER(0x20100)) +#define DOVE_TIMER_BASE (DOVE_REGISTER(0x20300)) +#define DOVE_REG_PCIE0_BASE (DOVE_REGISTER(0x40000)) +#define DOVE_REG_PCIE1_BASE (DOVE_REGISTER(0x80000)) +#define DOVE_USB20_0_BASE (DOVE_REGISTER(0x50000)) +#define DOVE_USB20_1_BASE (DOVE_REGISTER(0x51000)) +#define DOVE_EGIGA_BASE (DOVE_REGISTER(0x72000)) +#define DOVE_SDIO1_BASE (DOVE_REGISTER(0x90000)) +#define DOVE_SDIO0_BASE (DOVE_REGISTER(0x92000)) +#define DOVE_CAMERA_BASE (DOVE_REGISTER(0x94000)) +#define DOVE_SATA_BASE (DOVE_REGISTER(0xa0000)) +#define DOVE_NANDF_BASE (DOVE_REGISTER(0xc0000)) +#define DOVE_PMU_BASE (DOVE_REGISTER(0xd0000)) +#define DOVE_MPP_BASE (DOVE_REGISTER(0xd0200)) +#define DOVE_GPIO0_BASE (DOVE_REGISTER(0xd0400)) +#define DOVE_GPIO1_BASE (DOVE_REGISTER(0xd0420)) +#define DOVE_RTC_BASE (DOVE_REGISTER(0xd8500)) +#define DOVE_AC97_BASE (DOVE_REGISTER(0xe0000)) +#define DOVE_PDMA_BASE (DOVE_REGISTER(0xe4000)) +#define DOVE_GPIO2_BASE (DOVE_REGISTER(0xe8400)) +#define DOVE_SSP_BASE (DOVE_REGISTER(0xec000)) + +/* Dove Sata controller has one port */ +#define DOVE_SATA_PORT0_OFFSET 0x2000 + +/* Dove GbE controller has one port */ +#define MAX_MVGBE_DEVS 1 +#define MVGBE0_BASE DOVE_EGIGA_BASE + +/* Dove USB Host controller */ +#define MVUSB0_BASE DOVE_USB20_0_BASE +#define MVUSB0_CPU_ATTR_DRAM_CS0 DOVECPU_ATTR_DRAM +#define MVUSB0_CPU_ATTR_DRAM_CS1 DOVECPU_ATTR_DRAM +#define MVUSB0_CPU_ATTR_DRAM_CS2 DOVECPU_WIN_DISABLE +#define MVUSB0_CPU_ATTR_DRAM_CS3 DOVECPU_WIN_DISABLE + +/* Dove CPU memory windows */ +#define MVCPU_WIN_CTRL_DATA DOVECPU_WIN_CTRL_DATA +#define MVCPU_WIN_ENABLE DOVECPU_WIN_ENABLE +#define MVCPU_WIN_DISABLE DOVECPU_WIN_DISABLE + +#endif diff --git a/arch/arm/include/asm/arch-dove/gpio.h b/arch/arm/include/asm/arch-dove/gpio.h new file mode 100644 index 0000000..71bef8e --- /dev/null +++ b/arch/arm/include/asm/arch-dove/gpio.h @@ -0,0 +1,35 @@ +/* + * Marvell Dove SoC gpio + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef __DOVE_GPIO_H +#define __DOVE_GPIO_H + +#include <orion_gpio.h> + +#define GPIO_MAX 70 +#define GPIO_BASE(pin) (((pin) >= 64) ? DOVE_GPIO2_BASE : \ + ((pin) >= 32) ? DOVE_GPIO1_BASE : \ + DOVE_GPIO0_BASE) + +#endif diff --git a/arch/arm/include/asm/arch-dove/mpp.h b/arch/arm/include/asm/arch-dove/mpp.h new file mode 100644 index 0000000..1279ac2 --- /dev/null +++ b/arch/arm/include/asm/arch-dove/mpp.h @@ -0,0 +1,283 @@ +/* + * Marvell Dove SoC pinmux + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVE_MPP_H +#define _DOVE_MPP_H + +#define DOVE_GPI (1 << 0) +#define DOVE_GPO (1 << 1) +#define DOVE_GPIO (DOVE_GPO | DOVE_GPI) + +#define MPP(_num, _sel, _gpio) ( \ + /* MPP number */ ((_num) & 0xff) | \ + /* MPP select value */ (((_sel) & 0x1f) << 8) | \ + /* is gpio config */ ((!!(_gpio)) << 15)) + +/* MPP0-15 allow PMU function */ +#define MPP_PMU_MAX 15 +#define PMU (0x10) +/* MPP0-23 have standard mpp register layout */ +#define MPP_STD_MAX 23 + +#define MPP0 0 +#define MPP0_GPIO MPP(0, 0x0, 1) +#define MPP0_UART2_RTS MPP(0, 0x2, 0) +#define MPP0_SDIO0_CD MPP(0, 0x3, 0) +#define MPP0_LCD0_PWM MPP(0, 0xf, 0) +#define MPP0_PMU MPP(0, PMU, 0) + +#define MPP1 1 +#define MPP1_GPIO MPP(1, 0x0, 1) +#define MPP1_UART2_CTS MPP(1, 0x2, 0) +#define MPP1_SDIO0_WP MPP(1, 0x3, 0) +#define MPP1_LCD1_PWM MPP(1, 0xf, 0) +#define MPP1_PMU MPP(1, PMU, 0) + +#define MPP2 2 +#define MPP2_GPIO MPP(2, 0x0, 1) +#define MPP2_SATA_PRSNT MPP(2, 0x1, 0) +#define MPP2_UART2_TXD MPP(2, 0x2, 0) +#define MPP2_SDIO0_BUSPWR MPP(2, 0x3, 0) +#define MPP2_UART1_RTS MPP(2, 0x4, 0) +#define MPP2_PMU MPP(2, PMU, 0) + +#define MPP3 3 +#define MPP3_GPIO MPP(3, 0x0, 1) +#define MPP3_SATA_ACT MPP(3, 0x1, 0) +#define MPP3_UART2_RXD MPP(3, 0x2, 0) +#define MPP3_SDIO0_LEDCTRL MPP(3, 0x3, 0) +#define MPP3_UART1_CTS MPP(3, 0x4, 0) +#define MPP3_LCD_SPI_CS1 MPP(3, 0xf, 0) +#define MPP3_PMU MPP(3, PMU, 0) + +#define MPP4 4 +#define MPP4_GPIO MPP(4, 0x0, 1) +#define MPP4_UART3_RTS MPP(4, 0x2, 0) +#define MPP4_SDIO1_CD MPP(4, 0x3, 0) +#define MPP4_SPI1_MISO MPP(4, 0x4, 0) +#define MPP4_PMU MPP(4, PMU, 0) + +#define MPP5 5 +#define MPP5_GPIO MPP(5, 0x0, 1) +#define MPP5_UART3_CTS MPP(5, 0x2, 0) +#define MPP5_SDIO1_WP MPP(5, 0x3, 0) +#define MPP5_SPI1_CS MPP(5, 0x4, 0) +#define MPP5_PMU MPP(5, PMU, 0) + +#define MPP6 6 +#define MPP6_GPIO MPP(6, 0x0, 1) +#define MPP6_UART3_TXD MPP(6, 0x2, 0) +#define MPP6_SDIO1_BUSPWR MPP(6, 0x3, 0) +#define MPP6_SPI1_MOSI MPP(6, 0x4, 0) +#define MPP6_PMU MPP(6, PMU, 0) + +#define MPP7 7 +#define MPP7_GPIO MPP(7, 0x0, 1) +#define MPP7_UART3_RXD MPP(7, 0x2, 0) +#define MPP7_SDIO1_LEDCTRL MPP(7, 0x3, 0) +#define MPP7_SPI1_SCK MPP(7, 0x4, 0) +#define MPP7_PMU MPP(7, PMU, 0) + +#define MPP8 8 +#define MPP8_GPIO MPP(8, 0x0, 1) +#define MPP8_WATCHDOG_RSTOUT MPP(8, 0x1, 0) +#define MPP8_PMU MPP(8, PMU, 0) + +#define MPP9 9 +#define MPP9_GPIO MPP(9, 0x0, 1) +#define MPP9_PEX1_CLKREQ MPP(9, 0x5, 0) +#define MPP9_PMU MPP(9, PMU, 0) + +#define MPP10 10 +#define MPP10_GPIO MPP(10, 0x0, 1) +#define MPP10_SSP_SCLK MPP(10, 0x5, 0) +#define MPP10_PMU MPP(10, PMU, 0) + +#define MPP11 11 +#define MPP11_GPIO MPP(11, 0x0, 1) +#define MPP11_SATA_PRSNT MPP(11, 0x1, 0) +#define MPP11_SATA_ACT MPP(11, 0x2, 0) +#define MPP11_SDIO0_LEDCTRL MPP(11, 0x3, 0) +#define MPP11_SDIO1_LEDCTRL MPP(11, 0x4, 0) +#define MPP11_PEX0_CLKREQ MPP(11, 0x5, 0) +#define MPP11_PMU MPP(11, PMU, 0) + +#define MPP12 12 +#define MPP12_GPIO MPP(12, 0x0, 1) +#define MPP12_SATA_ACT MPP(12, 0x1, 0) +#define MPP12_UART2_RTS MPP(12, 0x2, 0) +#define MPP12_AUDIO0_EXTCLK MPP(12, 0x3, 0) +#define MPP12_SDIO1_CD MPP(12, 0x4, 0) +#define MPP12_PMU MPP(12, PMU, 0) + +#define MPP13 13 +#define MPP13_GPIO MPP(13, 0x0, 1) +#define MPP13_UART2_CTS MPP(13, 0x2, 0) +#define MPP13_AUDIO1_EXTCLK MPP(13, 0x3, 0) +#define MPP13_SDIO1_WP MPP(13, 0x4, 0) +#define MPP13_SSP_EXTCLK MPP(13, 0x5, 0) +#define MPP13_PMU MPP(13, PMU, 0) + +#define MPP14 14 +#define MPP14_GPIO MPP(14, 0x0, 1) +#define MPP14_UART2_TXD MPP(14, 0x2, 0) +#define MPP14_SDIO1_BUSPWR MPP(14, 0x4, 0) +#define MPP14_SSP_TXD MPP(14, 0x5, 0) +#define MPP14_PMU MPP(14, PMU, 0) + +#define MPP15 15 +#define MPP15_GPIO MPP(15, 0x0, 1) +#define MPP15_UART2_RXD MPP(15, 0x2, 0) +#define MPP15_SDIO1_LEDCTRL MPP(15, 0x4, 0) +#define MPP15_SSP_SFRM MPP(15, 0x5, 0) +#define MPP15_PMU MPP(15, PMU, 0) + +#define MPP16 16 +#define MPP16_GPIO MPP(16, 0x0, 1) +#define MPP16_UART3_RTS MPP(16, 0x2, 0) +#define MPP16_SDIO0_CD MPP(16, 0x3, 0) +#define MPP16_LCD_SPI_CS1 MPP(16, 0x4, 0) +#define MPP16_AC97_SDI1 MPP(16, 0x5, 0) + +#define MPP17 17 +#define MPP17_GPIO MPP(17, 0x0, 1) +#define MPP17_AC97_SYSCLKO MPP(17, 0x1, 0) +#define MPP17_UART3_CTS MPP(17, 0x2, 0) +#define MPP17_SDIO0_WP MPP(17, 0x3, 0) +#define MPP17_TWSI_SDA MPP(17, 0x4, 0) +#define MPP17_AC97_SDI2 MPP(17, 0x5, 0) + +#define MPP18 18 +#define MPP18_GPIO MPP(18, 0x0, 1) +#define MPP18_UART3_TXD MPP(18, 0x2, 0) +#define MPP18_SDIO0_BUSPWR MPP(18, 0x3, 0) +#define MPP18_LCD0_PWM MPP(18, 0x4, 0) +#define MPP18_AC97_SDI3 MPP(18, 0x5, 0) + +#define MPP19 19 +#define MPP19_GPIO MPP(19, 0x0, 1) +#define MPP19_UART3_RXD MPP(19, 0x2, 0) +#define MPP19_SDIO0_LEDCTRL MPP(19, 0x3, 0) +#define MPP19_TWSI_SCK MPP(19, 0x4, 0) + +#define MPP20 20 +#define MPP20_GPIO MPP(20, 0x0, 1) +#define MPP20_AC97_SYSCLKO MPP(20, 0x1, 0) +#define MPP20_LCD_SPI_MISO MPP(20, 0x2, 0) +#define MPP20_SDIO1_CD MPP(20, 0x3, 0) +#define MPP20_SDIO0_CD MPP(20, 0x5, 0) +#define MPP20_SPI1_MISO MPP(20, 0x6, 0) + +#define MPP21 21 +#define MPP21_GPIO MPP(21, 0x0, 1) +#define MPP21_UART1_RTS MPP(21, 0x1, 0) +#define MPP21_LCD_SPI_CS0 MPP(21, 0x2, 0) +#define MPP21_SDIO1_WP MPP(21, 0x3, 0) +#define MPP21_SSP_SFRM MPP(21, 0x4, 0) +#define MPP21_SDIO0_WP MPP(21, 0x5, 0) +#define MPP21_SPI1_CS MPP(21, 0x6, 0) + +#define MPP22 22 +#define MPP22_GPIO MPP(22, 0x0, 1) +#define MPP22_UART1_CTS MPP(22, 0x1, 0) +#define MPP22_LCD_SPI_MOSI MPP(22, 0x2, 0) +#define MPP22_SDIO1_BUSPWR MPP(22, 0x3, 0) +#define MPP22_SSP_TXD MPP(22, 0x4, 0) +#define MPP22_SDIO0_BUSPWR MPP(22, 0x5, 0) +#define MPP22_SPI1_MOSI MPP(22, 0x6, 0) + +#define MPP23 23 +#define MPP23_GPIO MPP(23, 0x0, 1) +#define MPP23_LCD_SPI_SCK MPP(23, 0x2, 0) +#define MPP23_SDIO1_LEDCTRL MPP(23, 0x3, 0) +#define MPP23_SSP_SCLK MPP(23, 0x4, 0) +#define MPP23_SDIO0_LEDCTRL MPP(23, 0x5, 0) +#define MPP23_SPI1_SCK MPP(23, 0x6, 0) + +/* MPP_CAMERA = MPP[24:39] */ +#define MPP_CAMERA 24 +#define MPP_CAMERA_CAMERA MPP(24, 0x0, 0) +#define MPP_CAMERA_GPIO MPP(24, 0x1, 1) +#define MPP_CAMERA_MAX 39 + +/* MPP_SDIO0 = MPP[40:45] */ +#define MPP_SDIO0 40 +#define MPP_SDIO0_SDIO MPP(40, 0x0, 0) +#define MPP_SDIO0_GPIO MPP(40, 0x1, 1) +#define MPP_SDIO0_MAX 45 + +/* MPP_SDIO1 = MPP[46:51] */ +#define MPP_SDIO1 46 +#define MPP_SDIO1_SDIO MPP(46, 0x0, 0) +#define MPP_SDIO1_GPIO MPP(46, 0x1, 1) +#define MPP_SDIO1_MAX 51 + +/* MPP_AUDIO1 = MPP[52:57] */ +#define MPP_AUDIO1 52 +#define MPP_AUDIO1_I2S_SPDIFO MPP(52, 0x0, 0) +#define MPP_AUDIO1_I2S MPP(52, 0x2, 0) +#define MPP_AUDIO1_SPDIFO MPP(52, 0x8, 0) +#define MPP_AUDIO1_GPIO MPP(52, 0xa, 1) +#define MPP_AUDIO1_TWSI MPP(52, 0xb, 0) +#define MPP_AUDIO1_SSP_SPDIFO MPP(52, 0xc, 0) +#define MPP_AUDIO1_SSP MPP(52, 0xe, 0) +#define MPP_AUDIO1_SSP_TWSI MPP(52, 0xf, 0) +#define MPP_AUDIO1_MAX 57 + +/* MPP_SPI = MPP[58:61] */ +#define MPP_SPI 58 +#define MPP_SPI_SPI MPP(58, 0x0, 0) +#define MPP_SPI_GPIO MPP(58, 0x1, 1) +#define MPP_SPI_MAX 61 + +/* MPP_UART1 = MPP[62:63] */ +#define MPP_UART1 62 +#define MPP_UART1_UART1 MPP(62, 0x0, 0) +#define MPP_UART1_GPIO MPP(62, 0x1, 1) +#define MPP_UART1_MAX 63 + +/* MPP_NAND = MPP[64:71] */ +#define MPP_NAND 64 +#define MPP_NAND_NAND MPP(64, 0x0, 0) +#define MPP_NAND_GPO MPP(64, 0x1, 1) +#define MPP_NAND_MAX 71 + +/* MPP_AUDIO0 = Internal AC97/I2S mux for audio0 pins */ +#define MPP_AUDIO0 72 +#define MPP_AUDIO0_I2S MPP(72, 0x0, 0) +#define MPP_AUDIO0_AC97 MPP(72, 0x1, 0) + +/* MPP_TWSI = Internal TWSI option mux */ +#define MPP_TWSI 73 +#define MPP_TWSI_NONE MPP(73, 0x0, 0) +#define MPP_TWSI_OPTION1 MPP(73, 0x1, 0) +#define MPP_TWSI_OPTION2 MPP(73, 0x2, 0) +#define MPP_TWSI_OPTION3 MPP(73, 0x3, 0) + +#define MPP_MAX MPP_TWSI + +u8 dove_mpp_get_gpio_caps(u8 num); +void dove_mpp_conf(u16 *mpp_list); + +#endif
This adds a gpio driver for Marvell Orion SoCs, i.e. orion5x, kirkwood, dove. This is based on kw_gpio but as gpio capabilities depend heavily on the mpp configuration for dove, it allows to set gpi/gpo capabilities from mpp. This should be compatible with the current kw_gpio and porting mpp of kirkwood and orion5x is appreciated.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Luka Perkov luka@openwrt.org --- drivers/gpio/Makefile | 1 + drivers/gpio/orion_gpio.c | 167 +++++++++++++++++++++++++++++++++++++++++++++ include/orion_gpio.h | 64 +++++++++++++++++ 3 files changed, 232 insertions(+) create mode 100644 drivers/gpio/orion_gpio.c create mode 100644 include/orion_gpio.h
diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 2d97b4f..b0ad2b5 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -27,6 +27,7 @@ LIB := $(obj)libgpio.o
COBJS-$(CONFIG_AT91_GPIO) += at91_gpio.o COBJS-$(CONFIG_INTEL_ICH6_GPIO) += intel_ich6_gpio.o +COBJS-$(CONFIG_ORION_GPIO) += orion_gpio.o COBJS-$(CONFIG_KIRKWOOD_GPIO) += kw_gpio.o COBJS-$(CONFIG_MARVELL_GPIO) += mvgpio.o COBJS-$(CONFIG_MARVELL_MFP) += mvmfp.o diff --git a/drivers/gpio/orion_gpio.c b/drivers/gpio/orion_gpio.c new file mode 100644 index 0000000..209354d --- /dev/null +++ b/drivers/gpio/orion_gpio.c @@ -0,0 +1,167 @@ +/* + * Marvell Orion SoC GPIO handling. + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * Based on (mostly copied from) plat-orion based Linux 2.6 kernel driver. + * Removed orion_gpiochip struct and kernel level irq handling. + * Dieter Kiermaier dk-arm-linux@gmx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <asm/bitops.h> +#include <asm/io.h> +#include <asm/arch/gpio.h> +#include <orion_gpio.h> + +static unsigned long gpio_valid_input[BITS_TO_LONGS(GPIO_MAX)]; +static unsigned long gpio_valid_output[BITS_TO_LONGS(GPIO_MAX)]; + +void __set_direction(unsigned pin, int input) +{ + u32 base = GPIO_BASE(pin); + u32 u; + + u = readl(GPIO_IO_CONF(base)); + if (input) + u |= 1 << (pin & 31); + else + u &= ~(1 << (pin & 31)); + writel(u, GPIO_IO_CONF(base)); + + u = readl(GPIO_IO_CONF(base)); +} + +void __set_level(unsigned pin, int high) +{ + u32 base = GPIO_BASE(pin); + u32 u; + + u = readl(GPIO_OUT(base)); + if (high) + u |= 1 << (pin & 31); + else + u &= ~(1 << (pin & 31)); + writel(u, GPIO_OUT(base)); +} + +void __set_blinking(unsigned pin, int blink) +{ + u32 base = GPIO_BASE(pin); + u32 u; + + u = readl(GPIO_BLINK_EN(base)); + if (blink) + u |= 1 << (pin & 31); + else + u &= ~(1 << (pin & 31)); + writel(u, GPIO_BLINK_EN(base)); +} + +int orion_gpio_is_valid(unsigned pin, int mode) +{ + if (pin < GPIO_MAX) { + if ((mode & GPIO_INPUT_OK) && + !test_bit(pin, gpio_valid_input)) + goto err_out; + + if ((mode & GPIO_OUTPUT_OK) && + !test_bit(pin, gpio_valid_output)) + goto err_out; + return 0; + } + +err_out: + printf("%s: invalid GPIO %d/%d\n", __func__, pin, GPIO_MAX); + return 1; +} + +void orion_gpio_set_valid(unsigned pin, int mode) +{ + if (mode & GPIO_INPUT_OK) + __set_bit(pin, gpio_valid_input); + else + __clear_bit(pin, gpio_valid_input); + if (mode & GPIO_OUTPUT_OK) + __set_bit(pin, gpio_valid_output); + else + __clear_bit(pin, gpio_valid_output); +} + +/* + * GENERIC_GPIO primitives. + */ +int orion_gpio_direction_input(unsigned pin) +{ + if (orion_gpio_is_valid(pin, GPIO_INPUT_OK) != 0) + return 1; + + /* Configure GPIO direction. */ + __set_direction(pin, 1); + + return 0; +} + +int orion_gpio_direction_output(unsigned pin, int value) +{ + if (orion_gpio_is_valid(pin, GPIO_OUTPUT_OK) != 0) { + printf("%s: invalid GPIO %d\n", __func__, pin); + return 1; + } + + __set_blinking(pin, 0); + + /* Configure GPIO output value. */ + __set_level(pin, value); + + /* Configure GPIO direction. */ + __set_direction(pin, 0); + + return 0; +} + +int orion_gpio_get_value(unsigned pin) +{ + u32 base = GPIO_BASE(pin); + int val; + + if (readl(GPIO_IO_CONF(base)) & (1 << (pin & 31))) + val = readl(GPIO_DATA_IN(base)) ^ readl(GPIO_IN_POL(base)); + else + val = readl(GPIO_OUT(base)); + + return (val >> (pin & 31)) & 1; +} + +void orion_gpio_set_value(unsigned pin, int value) +{ + /* Configure GPIO output value. */ + __set_level(pin, value); +} + +void orion_gpio_set_blink(unsigned pin, int blink) +{ + /* Set output value to zero. */ + __set_level(pin, 0); + + /* Set blinking. */ + __set_blinking(pin, blink); +} diff --git a/include/orion_gpio.h b/include/orion_gpio.h new file mode 100644 index 0000000..ba67068 --- /dev/null +++ b/include/orion_gpio.h @@ -0,0 +1,64 @@ +/* + * Marvell Orion SoCs common gpio + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef __ORION_GPIO_H +#define __ORION_GPIO_H + +/* + * SoC-specific gpio.h defines + * GPIO_MAX and GPIO_BASE(pin) macro + */ + +#define GPIO_INPUT_OK (1 << 0) +#define GPIO_OUTPUT_OK (1 << 1) +#define GPIO_LOW 0 +#define GPIO_HIGH 1 + +/* got from kernel include/linux/bitops.h */ +#define BITS_PER_BYTE 8 +#define BITS_TO_LONGS(nr) DIV_ROUND_UP(nr, BITS_PER_BYTE * sizeof(long)) + +#define GPIO_OUT(base) ((base) + 0x00) +#define GPIO_IO_CONF(base) ((base) + 0x04) +#define GPIO_BLINK_EN(base) ((base) + 0x08) +#define GPIO_IN_POL(base) ((base) + 0x0c) +#define GPIO_DATA_IN(base) ((base) + 0x10) +#define GPIO_EDGE_CAUSE(base) ((base) + 0x14) +#define GPIO_EDGE_MASK(base) ((base) + 0x18) +#define GPIO_LEVEL_MASK(base) ((base) + 0x1c) + +/* + * Orion-specific GPIO API + */ + +void orion_gpio_set_valid(unsigned pin, int mode); +int orion_gpio_is_valid(unsigned pin, int mode); +int orion_gpio_direction_input(unsigned pin); +int orion_gpio_direction_output(unsigned pin, int value); +int orion_gpio_get_value(unsigned pin); +void orion_gpio_set_value(unsigned pin, int value); +void orion_gpio_set_blink(unsigned pin, int blink); +void orion_gpio_set_unused(unsigned pin); + +#endif
-----Original Message----- From: Sebastian Hesselbarth [mailto:sebastian.hesselbarth@gmail.com] Sent: 17 January 2013 00:55 To: Sebastian Hesselbarth Cc: u-boot@lists.denx.de; Rabeeh Khoury; Albert Aribaud; Prafulla Wadaskar; Andy Fleming; Joe Hershberger; Daniel Stodden; Luka Perkov Subject: [PATCH v3 02/10] GPIO: add gpio driver for Orion SoCs
Nack, your patch series is for dove, you shouldn't add for orion, unless you are using it. If you think this is common framework can be used across the other marvell SoCs, we have strategy to name it like mv_***
So you may name this driver as mv_gpio
Regards... Prafulla . . .
Prafulla,
I still think that mv_ as a prefix is too short. Remember that Marvell also has pxa SoCs and with latest SoCs handling of gpio may change dramatically.
We should rather stick to orion_ for Orion5x, Kirkwood, Dove or move to mvebu_ for above plus Armada XP/370.
Sebastian
-----Original Message----- From: Sebastian Hesselbarth [mailto:sebastian.hesselbarth@gmail.com] Sent: 03 March 2013 17:07 To: Prafulla Wadaskar Cc: u-boot@lists.denx.de; Rabeeh Khoury; Albert Aribaud; Andy Fleming; Joe Hershberger; Daniel Stodden; Luka Perkov Subject: Re: [PATCH v3 02/10] GPIO: add gpio driver for Orion SoCs
Hesselbarth
Orion SoCs
name it like mv_***
Prafulla,
Dear Sabastian, We already have code with this naming convention sitting in u-boot from long, so to sync with that we should use "mv".
Pxa is handled separately at this moment, it is outside our scope at this moment. In case if it conflicts pxa developer may consider a prefix "mvpxa"
Orion_, Kirkwood_ fine with me, but mvebu doesn't sound good for dove (ebu is business unit name), if "dv" does not sound good then you can use "dove" prefix.
Shorter names gives smaller source code :-)
Sebastian
This adds a driver for the sdhci controller found on Dove SoCs.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Luka Perkov luka@openwrt.org --- drivers/mmc/Makefile | 1 + drivers/mmc/dove_sdhci.c | 101 ++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 102 insertions(+) create mode 100644 drivers/mmc/dove_sdhci.c
diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 65791aa..f7c731f 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -31,6 +31,7 @@ endif
COBJS-$(CONFIG_BFIN_SDH) += bfin_sdh.o COBJS-$(CONFIG_DAVINCI_MMC) += davinci_mmc.o +COBJS-$(CONFIG_DOVE_SDHCI) += dove_sdhci.o COBJS-$(CONFIG_FSL_ESDHC) += fsl_esdhc.o COBJS-$(CONFIG_FTSDC010) += ftsdc010_esdhc.o COBJS-$(CONFIG_GENERIC_MMC) += mmc.o diff --git a/drivers/mmc/dove_sdhci.c b/drivers/mmc/dove_sdhci.c new file mode 100644 index 0000000..ac15fd7 --- /dev/null +++ b/drivers/mmc/dove_sdhci.c @@ -0,0 +1,101 @@ +/* + * + * Marvell Dove SDHCI driver + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * Based on linux drivers/mmc/host/sdhci-dove.c + * by: Saeed Bishara saeed@marvell.com + * Mike Rapoport mike@compulab.co.il + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ + +#include <common.h> +#include <malloc.h> +#include <sdhci.h> +#include <asm/arch/dove.h> + +static u16 dove_sdhci_readw(struct sdhci_host *host, int reg) +{ + u16 ret; + + switch (reg) { + case SDHCI_HOST_VERSION: + case SDHCI_SLOT_INT_STATUS: + /* those registers don't exist */ + return 0; + default: + ret = readw(host->ioaddr + reg); + } + + return ret; +} + +static u32 dove_sdhci_readl(struct sdhci_host *host, int reg) +{ + u32 ret; + + switch (reg) { + case SDHCI_CAPABILITIES: + ret = readl(host->ioaddr + reg); + /* Mask the support for 3.0V */ + ret &= ~SDHCI_CAN_VDD_300; + break; + default: + ret = readl(host->ioaddr + reg); + } + + return ret; +} + +static struct sdhci_ops dove_sdhci_ops = { + .read_w = dove_sdhci_readw, + .read_l = dove_sdhci_readl, +}; + +static struct sdhci_host hosts[2] = { + { + .name = "Dove SDHCI0", + .ioaddr = (void *)DOVE_SDIO0_BASE, + }, + { + .name = "Dove SDHCI1", + .ioaddr = (void *)DOVE_SDIO1_BASE, + }, +}; + +int dove_sdhci_init(int num) +{ + struct sdhci_host *host; + + if (num < 0 || num > 1) + return 1; + + host = &hosts[num]; + + if (host->version) + return 1; + + host->quirks = + SDHCI_QUIRK_NO_HISPD_BIT | + SDHCI_QUIRK_BROKEN_R1B | + SDHCI_QUIRK_32BIT_DMA_ADDR; + host->version = SDHCI_SPEC_200; + host->ops = &dove_sdhci_ops; + + add_sdhci(host, 50000000, 4000000); + return 0; +}
This adds an SPI driver found on Marvell Orion SoCs. This driver is taken from kirkwood_spi but removes mpp configuration as dove has dedicated spi pins. To have a common driver for orion5x, kirkwood, and dove, mpp configuration should be handled in some cpu/board-specific setup.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Luka Perkov luka@openwrt.org --- drivers/spi/Makefile | 1 + drivers/spi/orion_spi.c | 217 +++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 218 insertions(+) create mode 100644 drivers/spi/orion_spi.c
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 824d357..624bb72 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -35,6 +35,7 @@ COBJS-$(CONFIG_CF_SPI) += cf_spi.o COBJS-$(CONFIG_CF_QSPI) += cf_qspi.o COBJS-$(CONFIG_DAVINCI_SPI) += davinci_spi.o COBJS-$(CONFIG_EXYNOS_SPI) += exynos_spi.o +COBJS-$(CONFIG_ORION_SPI) += orion_spi.o COBJS-$(CONFIG_KIRKWOOD_SPI) += kirkwood_spi.o COBJS-$(CONFIG_MPC52XX_SPI) += mpc52xx_spi.o COBJS-$(CONFIG_MPC8XXX_SPI) += mpc8xxx_spi.o diff --git a/drivers/spi/orion_spi.c b/drivers/spi/orion_spi.c new file mode 100644 index 0000000..8a50531 --- /dev/null +++ b/drivers/spi/orion_spi.c @@ -0,0 +1,217 @@ +/* + * Marvell Orion SoCs common spi driver + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * based on kirkwood_spi.c written by + * Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <malloc.h> +#include <spi.h> +#include <asm/io.h> +#include <asm/arch/config.h> + +/* SPI Registers on orion SOC */ +struct orionspi_registers { + u32 ctrl; /* 0x00 */ + u32 cfg; /* 0x04 */ + u32 dout; /* 0x08 */ + u32 din; /* 0x0c */ + u32 irq_cause; /* 0x10 */ + u32 irq_mask; /* 0x14 */ +}; + +#define ORIONSPI_CLKPRESCL_MASK 0x1f +#define ORIONSPI_CLKPRESCL_MIN 0x12 +#define ORIONSPI_CSN_ACT 1 /* Activates serial memory interface */ +#define ORIONSPI_SMEMRDY (1 << 1) /* SerMem Data xfer ready */ +#define ORIONSPI_IRQUNMASK 1 /* unmask SPI interrupt */ +#define ORIONSPI_IRQMASK 0 /* mask SPI interrupt */ +#define ORIONSPI_SMEMRDIRQ 1 /* SerMem data xfer ready irq */ +#define ORIONSPI_XFERLEN_1BYTE 0 +#define ORIONSPI_XFERLEN_2BYTE (1 << 5) +#define ORIONSPI_XFERLEN_MASK (1 << 5) +#define ORIONSPI_ADRLEN_1BYTE 0 +#define ORIONSPI_ADRLEN_2BYTE (1 << 8) +#define ORIONSPI_ADRLEN_3BYTE (2 << 8) +#define ORIONSPI_ADRLEN_4BYTE (3 << 8) +#define ORIONSPI_ADRLEN_MASK (3 << 8) +#define ORIONSPI_TIMEOUT 10000 + +static struct orionspi_registers *spireg = + (struct orionspi_registers *)ORION_SPI_BASE; + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct spi_slave *slave; + u32 data; + u32 kwspi_mpp_config[] = { 0, 0 }; + + if (!spi_cs_is_valid(bus, cs)) + return NULL; + + slave = malloc(sizeof(struct spi_slave)); + if (!slave) + return NULL; + + slave->bus = bus; + slave->cs = cs; + + writel(~ORIONSPI_CSN_ACT | ORIONSPI_SMEMRDY, &spireg->ctrl); + + /* calculate spi clock prescaller using max_hz */ + data = ((CONFIG_SYS_TCLK / 2) / max_hz) + 0x10; + data = data < ORIONSPI_CLKPRESCL_MIN ? ORIONSPI_CLKPRESCL_MIN : data; + data = data > ORIONSPI_CLKPRESCL_MASK ? ORIONSPI_CLKPRESCL_MASK : data; + + /* program spi clock prescaller using max_hz */ + writel(ORIONSPI_ADRLEN_3BYTE | data, &spireg->cfg); + debug("data = 0x%08x\n", data); + + writel(ORIONSPI_SMEMRDIRQ, &spireg->irq_cause); + writel(ORIONSPI_IRQMASK, &spireg->irq_mask); + + return slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + free(slave); +} + +#if defined(CONFIG_SYS_KW_SPI_MPP) +u32 spi_mpp_backup[4]; +#endif + +__attribute__((weak)) int board_spi_claim_bus(struct spi_slave *slave) +{ + return 0; +} + +int spi_claim_bus(struct spi_slave *slave) +{ + return board_spi_claim_bus(slave); +} + +__attribute__((weak)) void board_spi_release_bus(struct spi_slave *slave) +{ +} + +void spi_release_bus(struct spi_slave *slave) +{ + board_spi_release_bus(slave); +} + +#ifndef CONFIG_SPI_CS_IS_VALID +/* + * you can define this function board specific + * define above CONFIG in board specific config file and + * provide the function in board specific src file + */ +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return (bus == 0 && (cs == 0 || cs == 1)); +} +#endif + +void spi_init(void) +{ +} + +void spi_cs_activate(struct spi_slave *slave) +{ + writel(readl(&spireg->ctrl) | ORIONSPI_IRQUNMASK, &spireg->ctrl); +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + writel(readl(&spireg->ctrl) & ORIONSPI_IRQMASK, &spireg->ctrl); +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, + void *din, unsigned long flags) +{ + unsigned int tmpdout, tmpdin; + int tm, isread = 0; + + debug("spi_xfer: slave %u:%u dout %p din %p bitlen %u\n", + slave->bus, slave->cs, dout, din, bitlen); + + if (flags & SPI_XFER_BEGIN) + spi_cs_activate(slave); + + /* + * handle data in 8-bit chunks + * TBD: 2byte xfer mode to be enabled + */ + writel(((readl(&spireg->cfg) & ~ORIONSPI_XFERLEN_MASK) | + ORIONSPI_XFERLEN_1BYTE), &spireg->cfg); + + while (bitlen > 4) { + debug("loopstart bitlen %d\n", bitlen); + tmpdout = 0; + + /* Shift data so it's msb-justified */ + if (dout) + tmpdout = *(u32 *) dout & 0x0ff; + + writel(~ORIONSPI_SMEMRDIRQ, &spireg->irq_cause); + writel(tmpdout, &spireg->dout); /* Write the data out */ + debug("*** spi_xfer: ... %08x written, bitlen %d\n", + tmpdout, bitlen); + + /* + * Wait for SPI transmit to get out + * or time out (1 second = 1000 ms) + * The NE event must be read and cleared first + */ + for (tm = 0, isread = 0; tm < ORIONSPI_TIMEOUT; ++tm) { + if (readl(&spireg->irq_cause) & ORIONSPI_SMEMRDIRQ) { + isread = 1; + tmpdin = readl(&spireg->din); + debug + ("spi_xfer: din %p..%08x read\n", + din, tmpdin); + + if (din) { + *((u8 *) din) = (u8) tmpdin; + din += 1; + } + if (dout) + dout += 1; + bitlen -= 8; + } + if (isread) + break; + } + if (tm >= ORIONSPI_TIMEOUT) + printf("*** spi_xfer: Time out during SPI transfer\n"); + + debug("loopend bitlen %d\n", bitlen); + } + + if (flags & SPI_XFER_END) + spi_cs_deactivate(slave); + + return 0; +}
-----Original Message----- From: Sebastian Hesselbarth [mailto:sebastian.hesselbarth@gmail.com] Sent: 17 January 2013 00:55 To: Sebastian Hesselbarth Cc: u-boot@lists.denx.de; Rabeeh Khoury; Albert Aribaud; Prafulla Wadaskar; Andy Fleming; Joe Hershberger; Daniel Stodden; Luka Perkov Subject: [PATCH v3 04/10] SPI: Add Orion SPI driver
This adds an SPI driver found on Marvell Orion SoCs. This driver is taken from kirkwood_spi but removes mpp configuration as dove has dedicated spi pins. To have a common driver for orion5x, kirkwood, and dove, mpp configuration should be handled in some cpu/board- specific
the proposal of having common driver will be greatly appreciated. Pls go ahead and do it if possible for you
I think adding orion_spi.c to enable dove support doesn't sound good.
Does this tested on hw, please re-base the tree and send the next version patch. Let me know if it ok to review under current tree.
-- Thanks, Jagan.
On Mon, Feb 11, 2013 at 9:09 AM, Prafulla Wadaskar prafulla@marvell.com wrote:
Regards... Prafulla . . . _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Dear Jagan,
Jagan Teki jagannadh.teki@gmail.com writes:
I'd appreciate a review of the latest patch [1,2]. There have been no changes in master to the files touched by the patch since I sent it. After rebasing the entire series on today's master (d6639d1) I've successfully verified SPI flash functionality on CuBox Pro.
Sascha
[1] mid:1369593423-19763-6-git-send-email-t-uboot@infra-silbe.de [2] http://patchwork.ozlabs.org/patch/246468/
On Mon, Jun 3, 2013 at 11:01 PM, Sascha Silbe t-uboot@infra-silbe.de wrote:
Dear Jagan,
Sascha
Thank you, means this v4 is the latest one? http://patchwork.ozlabs.org/patch/246468/
-- Thanks, Jagan.
Dear Jagan,
I'd appreciate a review of the latest patch [1,2]. [...] [1] mid:1369593423-19763-6-git-send-email-t-uboot@infra-silbe.de [2] http://patchwork.ozlabs.org/patch/246468/
Yes, it is.
Sascha
On 06/03/2013 07:31 PM, Sascha Silbe wrote:
From: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com
This adds an SPI driver for Marvell Dove SoCs. This driver is taken from kirkwood_spi but removes mpp configuration as dove has dedicated spi pins.
As a future clean-up step, the code for orion5x, kirkwood and dove could be merged, with MPP configuration being be handled as part of cpu/board-specific setup.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Signed-off-by: Sascha Silbe t-uboot@infra-silbe.de
v3->v4: renamed to dove, adjusted description, removed unused variable, made checkpatch clean
Sascha,
renaming it to dove_spi to obfuscate it is actually a copy of kirkwood_spi that will also work for orion5x and mv78x00 does _not_ match my intention when I posted this driver. Feel free to pick up the patches but it should remain generic for all Orion SoCs.
kirkwood_spi has mpp stuff inside that is totally wrong there, move it to board setup and just rename kirkwood_spi to something more generic.
Sebastian
Dove SoC also uses mvsata, therefore add a SoC specific include to allow to reuse the mvsata ide driver.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Luka Perkov luka@openwrt.org -- drivers/block/mvsata_ide.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/block/mvsata_ide.c b/drivers/block/mvsata_ide.c index a88d0f7..9918f80 100644 --- a/drivers/block/mvsata_ide.c +++ b/drivers/block/mvsata_ide.c @@ -29,6 +29,8 @@ #include <asm/arch/orion5x.h> #elif defined(CONFIG_KIRKWOOD) #include <asm/arch/kirkwood.h> +#elif defined(CONFIG_DOVE) +#include <asm/arch/dove.h> #endif
/* SATA port registers */
-----Original Message----- From: Sebastian Hesselbarth [mailto:sebastian.hesselbarth@gmail.com] Sent: 17 January 2013 00:55 To: Sebastian Hesselbarth Cc: u-boot@lists.denx.de; Rabeeh Khoury; Albert Aribaud; Prafulla Wadaskar; Andy Fleming; Joe Hershberger; Daniel Stodden; Luka Perkov Subject: [PATCH v3 05/10] block: mvsata: add dove include
Acked-By: Prafulla Wadaskar prafulla@marvell.com
This adds PHY initialization for Marvell Alaska 88E1310 PHY.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Luka Perkov luka@openwrt.org --- drivers/net/phy/marvell.c | 48 +++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 48 insertions(+)
diff --git a/drivers/net/phy/marvell.c b/drivers/net/phy/marvell.c index 4b27198..1205166 100644 --- a/drivers/net/phy/marvell.c +++ b/drivers/net/phy/marvell.c @@ -89,6 +89,12 @@
#define MIIM_88E1149_PHY_PAGE 29
+/* 88E1310 PHY defines */ +#define MIIM_88E1310_PHY_LED_CTRL 16 +#define MIIM_88E1310_PHY_IRQ_EN 18 +#define MIIM_88E1310_PHY_RGMII_CTRL 21 +#define MIIM_88E1310_PHY_PAGE 22 + /* Marvell 88E1011S */ static int m88e1011s_config(struct phy_device *phydev) { @@ -394,6 +400,37 @@ static int m88e1149_config(struct phy_device *phydev) return 0; }
+/* Marvell 88E1310 */ +static int m88e1310_config(struct phy_device *phydev) +{ + u16 reg; + + /* LED link and activity */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_PAGE, 0x0003); + reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_LED_CTRL); + reg = (reg & ~0xf) | 0x1; + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_LED_CTRL, reg); + + /* Set LED2/INT to INT mode, low active */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_PAGE, 0x0003); + reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_IRQ_EN); + reg = (reg & 0x77ff) | 0x0880; + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_IRQ_EN, reg); + + /* Set RGMII delay */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_PAGE, 0x0002); + reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_RGMII_CTRL); + reg |= 0x0030; + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_RGMII_CTRL, reg); + + /* Ensure to return to page 0 */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_PAGE, 0x0000); + + genphy_config_aneg(phydev); + phy_reset(phydev); + + return 0; +}
static struct phy_driver M88E1011S_driver = { .name = "Marvell 88E1011S", @@ -465,8 +502,19 @@ static struct phy_driver M88E1149S_driver = { .shutdown = &genphy_shutdown, };
+static struct phy_driver M88E1310_driver = { + .name = "Marvell 88E1310", + .uid = 0x01410e90, + .mask = 0xffffff0, + .features = PHY_GBIT_FEATURES, + .config = &m88e1310_config, + .startup = &m88e1011s_startup, + .shutdown = &genphy_shutdown, +}; + int phy_marvell_init(void) { + phy_register(&M88E1310_driver); phy_register(&M88E1149S_driver); phy_register(&M88E1145_driver); phy_register(&M88E1121R_driver);
-----Original Message----- From: Sebastian Hesselbarth [mailto:sebastian.hesselbarth@gmail.com] Sent: 17 January 2013 00:55 To: Sebastian Hesselbarth Cc: u-boot@lists.denx.de; Rabeeh Khoury; Albert Aribaud; Prafulla Wadaskar; Andy Fleming; Joe Hershberger; Daniel Stodden; Luka Perkov Subject: [PATCH v3 06/10] NET: phy: add 88E1310 PHY initialization
- u16 reg;
- /* LED link and activity */
- phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_PAGE, 0x0003);
- reg = phy_read(phydev, MDIO_DEVAD_NONE,
- reg = (reg & ~0xf) | 0x1;
- phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_LED_CTRL,
reg);
- /* Set LED2/INT to INT mode, low active */
- reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_IRQ_EN);
- reg = (reg & 0x77ff) | 0x0880;
- phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_IRQ_EN, reg);
- /* Set RGMII delay */
- phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_PAGE, 0x0002);
- reg |= 0x0030;
- phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_RGMII_CTRL,
reg);
- /* Ensure to return to page 0 */
- phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_PAGE, 0x0000);
- genphy_config_aneg(phydev);
- phy_reset(phydev);
- .name = "Marvell 88E1310",
- .uid = 0x01410e90,
- .mask = 0xffffff0,
- .features = PHY_GBIT_FEATURES,
- .config = &m88e1310_config,
- .startup = &m88e1011s_startup,
- .shutdown = &genphy_shutdown,
- phy_register(&M88E1310_driver);
Please maintain an order here.
phy_register(&M88E1149S_driver); phy_register(&M88E1145_driver); phy_register(&M88E1121R_driver); -- 1.7.10.4
This add phylib support to the Marvell GBE driver.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Luka Perkov luka@openwrt.org --- drivers/net/mvgbe.c | 68 ++++++++++++++++++++++++++++++++++++++++++++++++--- 1 file changed, 64 insertions(+), 4 deletions(-)
diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index 47bf27c..192c989 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -52,7 +52,7 @@ DECLARE_GLOBAL_DATA_PTR; #define MV_PHY_ADR_REQUEST 0xee #define MVGBE_SMI_REG (((struct mvgbe_registers *)MVGBE0_BASE)->smi)
-#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) +#if defined(CONFIG_PHYLIB) || defined(CONFIG_MII) || defined(CONFIG_CMD_MII) /* * smi_reg_read - miiphy_read callback function. * @@ -184,6 +184,24 @@ static int smi_reg_write(const char *devname, u8 phy_adr, u8 reg_ofs, u16 data) } #endif
+#if defined(CONFIG_PHYLIB) +int mvgbe_phy_read(struct mii_dev *bus, int phyAddr, int devAddr, int regAddr) +{ + u16 data; + int ret; + ret = smi_reg_read(bus->name, phyAddr, regAddr, &data); + if (ret) + return ret; + return data; +} + +int mvgbe_phy_write(struct mii_dev *bus, int phyAddr, int devAddr, int regAddr, + u16 data) +{ + return smi_reg_write(bus->name, phyAddr, regAddr, data); +} +#endif + /* Stop and checks all queues */ static void stop_queue(u32 * qreg) { @@ -467,8 +485,9 @@ static int mvgbe_init(struct eth_device *dev) /* Enable port Rx. */ MVGBE_REG_WR(regs->rqc, (1 << RXUQ));
-#if (defined (CONFIG_MII) || defined (CONFIG_CMD_MII)) \ - && defined (CONFIG_SYS_FAULT_ECHO_LINK_DOWN) +#if (defined(CONFIG_MII) || defined(CONFIG_CMD_MII)) \ + && !defined(CONFIG_PHYLIB) \ + && defined(CONFIG_SYS_FAULT_ECHO_LINK_DOWN) /* Wait up to 5s for the link status */ for (i = 0; i < 5; i++) { u16 phyadr; @@ -647,6 +666,45 @@ static int mvgbe_recv(struct eth_device *dev) return 0; }
+#if defined(CONFIG_PHYLIB) +int mvgbe_phylib_init(struct eth_device *dev, int phyid) +{ + struct mii_dev *bus; + struct phy_device *phydev; + int ret; + + bus = mdio_alloc(); + if (!bus) { + printf("mdio_alloc failed\n"); + return -ENOMEM; + } + bus->read = mvgbe_phy_read; + bus->write = mvgbe_phy_write; + sprintf(bus->name, dev->name); + + ret = mdio_register(bus); + if (ret) { + printf("mdio_register failed\n"); + free(bus); + return -ENOMEM; + } + + /* Set phy address of the port */ + mvgbe_phy_write(bus, MV_PHY_ADR_REQUEST, 0, MV_PHY_ADR_REQUEST, phyid); + + phydev = phy_connect(bus, phyid, dev, PHY_INTERFACE_MODE_RGMII); + if (!phydev) { + printf("phy_connect failed\n"); + return -ENODEV; + } + + phy_config(phydev); + phy_startup(phydev); + + return 0; +} +#endif + int mvgbe_initialize(bd_t *bis) { struct mvgbe_device *dmvgbe; @@ -729,7 +787,9 @@ error1:
eth_register(dev);
-#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) +#if defined(CONFIG_PHYLIB) + mvgbe_phylib_init(dev, PHY_BASE_ADR + devnum); +#elif defined(CONFIG_MII) || defined(CONFIG_CMD_MII) miiphy_register(dev->name, smi_reg_read, smi_reg_write); /* Set phy address of the port */ miiphy_write(dev->name, MV_PHY_ADR_REQUEST,
-----Original Message----- From: Sebastian Hesselbarth [mailto:sebastian.hesselbarth@gmail.com] Sent: 17 January 2013 00:55 To: Sebastian Hesselbarth Cc: u-boot@lists.denx.de; Rabeeh Khoury; Albert Aribaud; Prafulla Wadaskar; Andy Fleming; Joe Hershberger; Daniel Stodden; Luka Perkov Subject: [PATCH v3 07/10] NET: mvgbe: add phylib support
- smi_reg_read - miiphy_read callback function.
- u16 data;
- int ret;
- ret = smi_reg_read(bus->name, phyAddr, regAddr, &data);
- if (ret)
return ret;
- return data;
- u16 data)
- return smi_reg_write(bus->name, phyAddr, regAddr, data);
+} +#endif
- && !defined(CONFIG_PHYLIB) \
- && defined(CONFIG_SYS_FAULT_ECHO_LINK_DOWN) /* Wait up to 5s for the link status */ for (i = 0; i < 5; i++) { u16 phyadr;
- struct mii_dev *bus;
- struct phy_device *phydev;
- int ret;
- bus = mdio_alloc();
- if (!bus) {
return -ENOMEM;
- bus->read = mvgbe_phy_read;
- bus->write = mvgbe_phy_write;
- sprintf(bus->name, dev->name);
- ret = mdio_register(bus);
- if (ret) {
free(bus);
return -ENOMEM;
- /* Set phy address of the port */
- mvgbe_phy_write(bus, MV_PHY_ADR_REQUEST, 0, MV_PHY_ADR_REQUEST,
phyid);
- phydev = phy_connect(bus, phyid, dev, PHY_INTERFACE_MODE_RGMII);
- if (!phydev) {
return -ENODEV;
- phy_config(phydev);
- phy_startup(phydev);
+} +#endif
eth_register(dev);
+#elif defined(CONFIG_MII) || defined(CONFIG_CMD_MII) miiphy_register(dev->name, smi_reg_read, smi_reg_write); /* Set phy address of the port */ miiphy_write(dev->name, MV_PHY_ADR_REQUEST, --
This patch do not have any dependency. I suggest to detach this patch and send it as standalone patch so that Joe can pull it earliest.
Marvell Dove also uses mvgbe as ethernet driver, therefore add support for Dove to reuse the current driver.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Luka Perkov luka@openwrt.org --- drivers/net/mvgbe.c | 2 ++ drivers/net/mvgbe.h | 7 +++++++ 2 files changed, 9 insertions(+)
diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index 192c989..590ea0b 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -43,6 +43,8 @@ #include <asm/arch/kirkwood.h> #elif defined(CONFIG_ORION5X) #include <asm/arch/orion5x.h> +#elif defined(CONFIG_DOVE) +#include <asm/arch/dove.h> #endif
#include "mvgbe.h" diff --git a/drivers/net/mvgbe.h b/drivers/net/mvgbe.h index d8a5429..7f5d98f 100644 --- a/drivers/net/mvgbe.h +++ b/drivers/net/mvgbe.h @@ -308,10 +308,17 @@ #define EBAR_TARGET_GUNIT 0x00000007
/* Window attrib */ +#if defined(CONFIG_DOVE) +#define EBAR_DRAM_CS0 0x00000000 +#define EBAR_DRAM_CS1 0x00000000 +#define EBAR_DRAM_CS2 0x00000000 +#define EBAR_DRAM_CS3 0x00000000 +#else #define EBAR_DRAM_CS0 0x00000E00 #define EBAR_DRAM_CS1 0x00000D00 #define EBAR_DRAM_CS2 0x00000B00 #define EBAR_DRAM_CS3 0x00000700 +#endif
/* DRAM Target interface */ #define EBAR_DRAM_NO_CACHE_COHERENCY 0x00000000
-----Original Message----- From: Sebastian Hesselbarth [mailto:sebastian.hesselbarth@gmail.com] Sent: 17 January 2013 00:55 To: Sebastian Hesselbarth Cc: u-boot@lists.denx.de; Rabeeh Khoury; Albert Aribaud; Prafulla Wadaskar; Andy Fleming; Joe Hershberger; Daniel Stodden; Luka Perkov Subject: [PATCH v3 08/10] NET: mvgbe: add support for Dove
What does this means? May you please explain?
Signed-off-by: Sebastian Hesselbarthsebastian.hesselbarth@gmail.com
Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarthsebastian.hesselbarth@gmail.com Cc: Rabeeh Khouryrabeeh@solid-run.com Cc: Albert Aribaudalbert.u.boot@aribaud.net Cc: Prafulla Wadaskarprafulla@marvell.com Cc: Andy Flemingafleming@gmail.com Cc: Joe Hershbergerjoe.hershberger@gmail.com Cc: Daniel Stoddendaniel.stodden@gmail.com Cc: Luka Perkovluka@openwrt.org
diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index 192c989..590ea0b 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -43,6 +43,8 @@ #include<asm/arch/kirkwood.h> #elif defined(CONFIG_ORION5X) #include<asm/arch/orion5x.h> +#elif defined(CONFIG_DOVE) +#include<asm/arch/dove.h> #endif
These are ORed with other BAR values within mvgbe and control access of mvgbe bus master to sdram. In contrast to Kirkwood, Dove has only one sdram target interface with attribute 0x0 while Kirkwood has four different target IDs each for one sdram bank.
Sebastian
-----Original Message----- From: Sebastian Hesselbarth [mailto:sebastian.hesselbarth@gmail.com] Sent: 03 March 2013 17:14 To: Prafulla Wadaskar Cc: u-boot@lists.denx.de; Rabeeh Khoury; Albert Aribaud; Andy Fleming; Joe Hershberger; Daniel Stodden; Luka Perkov Subject: Re: [PATCH v3 08/10] NET: mvgbe: add support for Dove
Aribaud; Prafulla
for Dove
Dear Sebastian Since dove has only one SDRAM bank You should do #undef EBAR_DRAM_CS1/2/3 instead of defining them zero, and manage the same effectively in the code.
To me, defining unavailable banks doesn't sound good.
With latest support for Marvell Dove SoC, add the SolidRun CuBox as the very first board with that SoC.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Luka Perkov luka@openwrt.org --- MAINTAINERS | 4 + board/solidrun/cubox/Makefile | 45 ++++++++++ board/solidrun/cubox/cubox.c | 141 ++++++++++++++++++++++++++++++ board/solidrun/cubox/kwbimage.cfg | 76 ++++++++++++++++ boards.cfg | 1 + include/configs/cubox.h | 175 +++++++++++++++++++++++++++++++++++++ 6 files changed, 442 insertions(+) create mode 100644 board/solidrun/cubox/Makefile create mode 100644 board/solidrun/cubox/cubox.c create mode 100644 board/solidrun/cubox/kwbimage.cfg create mode 100644 include/configs/cubox.h
diff --git a/MAINTAINERS b/MAINTAINERS index 28c052d..6fc8618 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -684,6 +684,10 @@ Stefan Herbrechtsmeier stefan@code.herbrechtsmeier.net
dns325 ARM926EJS (Kirkwood SoC)
+Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + + cubox ARM ARMV7 (Dove SoC) + Vaibhav Hiremath hvaibhav@ti.com
am3517_evm ARM ARMV7 (AM35x SoC) diff --git a/board/solidrun/cubox/Makefile b/board/solidrun/cubox/Makefile new file mode 100644 index 0000000..c771d72 --- /dev/null +++ b/board/solidrun/cubox/Makefile @@ -0,0 +1,45 @@ +# +# SolidRun CuBox Makefile +# +# Sebastian Hesselbarth sebastian.hesselbarth@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := cubox.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/solidrun/cubox/cubox.c b/board/solidrun/cubox/cubox.c new file mode 100644 index 0000000..70c016f --- /dev/null +++ b/board/solidrun/cubox/cubox.c @@ -0,0 +1,141 @@ +/* + * SolidRun CuBox board support + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <miiphy.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> +#include <asm/arch/mpp.h> +#include <orion_gpio.h> + +DECLARE_GLOBAL_DATA_PTR; + +static u16 mpp_config[] = { + MPP0_GPIO, + MPP1_GPIO, /* USB power enable */ + MPP2_GPIO, /* USB over-current indication */ + MPP3_GPIO, /* micro button beneath eSATA port */ + MPP4_GPIO, + MPP5_GPIO, + MPP6_GPIO, + MPP7_GPIO, + + MPP8_GPIO, + MPP9_GPIO, + MPP10_GPIO, + MPP11_GPIO, + MPP12_GPIO, /* SDIO0 card detect */ + MPP13_AUDIO1_EXTCLK, /* Si5351a audio clock output */ + MPP14_GPIO, + MPP15_GPIO, + + MPP16_GPIO, + MPP17_GPIO, + MPP18_GPIO, /* Red front LED */ + MPP19_UART3_RXD, /* IR sensor */ + MPP20_GPIO, + MPP21_GPIO, + MPP22_GPIO, + MPP23_GPIO, + + MPP_CAMERA_GPIO, + MPP_SDIO0_SDIO, /* SDIO0 */ + MPP_SDIO1_GPIO, + MPP_AUDIO1_I2S_SPDIFO, /* SPDIF and HDMI audio */ + MPP_SPI_SPI, /* SPI */ + MPP_UART1_GPIO, + MPP_NAND_GPO, + + MPP_AUDIO0_I2S, + MPP_TWSI_OPTION1, /* TWSI on dedicated pins */ + 0 }; + +int board_early_init_f(void) +{ + struct dove_gpio_init gpp = { + .val0 = 0x00010186, + .oe0_n = 0xffffffff, + .val1 = 0x018000c0, + .oe1_n = 0xffffffff, + .val2 = 0x00000000, + .oe2_n = 0xffffffff, + }; + + dove_init_gpio(&gpp); + + return 0; +} + +int board_init(void) +{ + /* adress of boot parameters */ + gd->bd->bi_boot_params = dove_dram_start(0) + 0x100; + + /* configure mpp */ + dove_mpp_conf(mpp_config); + + /* usb power enable */ + orion_gpio_direction_output(MPP1, GPIO_HIGH); + + /* blink led */ + orion_gpio_direction_output(MPP18, GPIO_HIGH); + orion_gpio_set_blink(MPP18, 1); + + return 0; +} + +#ifdef CONFIG_MMC +int board_mmc_init(bd_t *bis) +{ + dove_sdhci_init(0); + return 0; +} +#endif + +#ifdef CONFIG_RESET_PHY_R +void dove_eth_phy_init(char *name) +{ + u16 devadr; + + if (miiphy_set_current_dev(name)) + return; + + /* command to read PHY dev address */ + if (miiphy_read(name, 0xEE, 0xEE, (u16 *) &devadr)) { + printf("Err..%s could not read PHY dev address\n", + __func__); + return; + } + + /* reset the phy */ + miiphy_reset(name, devadr); + + printf("%s PHY initialized\n", name); +} + +void reset_phy(void) +{ + dove_eth_phy_init("egiga0"); +} +#endif /* CONFIG_RESET_PHY_R */ diff --git a/board/solidrun/cubox/kwbimage.cfg b/board/solidrun/cubox/kwbimage.cfg new file mode 100644 index 0000000..c3f1ad9 --- /dev/null +++ b/board/solidrun/cubox/kwbimage.cfg @@ -0,0 +1,76 @@ +# +# Marvell BootROM config for SolidRun CuBox +# +# Sebastian Hesselbarth sebastian.hesselbarth@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# +# Refer docs/README.kwimage for more details about how-to configure +# and create kirkwood boot image +# + +# Boot Media configurations +BOOT_FROM spi + +# SOC registers configuration using bootrom header extension +# Maximum KWBIMAGE_MAX_CONFIG configurations allowed + +DATA 0xd0020104 0x00000000 # CPU Control and Status register + +# SDRAM initalization +DATA 0xd0800020 0x00022430 # SDRAM Configuration register 0 +DATA 0xd0800030 0x00022430 # SDRAM Configuration register 1 +DATA 0xd0800050 0x911500c3 # SDRAM Timing register 1 +DATA 0xd0800060 0x646602c4 # SDRAM Timing register 2 +DATA 0xd0800190 0xc2003053 # SDRAM Timing register 3 +DATA 0xd08001c0 0x34f4a187 # SDRAM Timing register 4 +DATA 0xd0800650 0x000f0121 # SDRAM Timing register 5 +DATA 0xd0800660 0x04040200 # SDRAM Timing register 6 +DATA 0xd0800080 0x00000000 # SDRAM Control register 1 +DATA 0xd0800090 0x00080000 # SDRAM Control register 2 +DATA 0xd08000f0 0xc0000000 # SDRAM Control register 3 +DATA 0xd08001a0 0x20c0c009 # SDRAM Control register 4 +DATA 0xd0800280 0x010e0202 # SDRAM Control register 5 +DATA 0xd0800760 0x00000000 # SDRAM Control register 6 +DATA 0xd0800770 0x0000000a # SDRAM Control register 7 +DATA 0xd0800140 0x20004044 # SDRAM PHY control register 3 +DATA 0xd08001d0 0x133c2339 # SDRAM PHY control register 7 +DATA 0xd08001e0 0x07700330 # SDRAM PHY control register 8 +DATA 0xd08001f0 0x00000033 # SDRAM PHY control register 9 +DATA 0xd0800200 0x0011311c # SDRAM PHY control register 10 +DATA 0xd0800210 0x00300000 # SDRAM PHY control register 11 +DATA 0xd0800240 0x80000000 # SDRAM PHY control register 14 +DATA 0xd0800510 0x010e0101 # SDRAM MCB control register 1 +DATA 0xd0800230 0x2028006a # SDRAM PHY control register 13 +DATA 0xd0800e10 0x00280062 # SDRAM PHY DLL control registers 2 +DATA 0xd0800e20 0x00280062 # SDRAM PHY DLL control registers 3 +DATA 0xd0800e30 0x00280062 # SDRAM PHY DLL control registers 4 + +# SDRAM memory map (2x512MB) +DATA 0xd0800100 0x000d0001 # SDRAM Memory Address Map register 1 +DATA 0xd0800110 0x200d0001 # SDRAM Memory Address Map register 1 + +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register + +# End of Header extension +DATA 0x0 0x0 diff --git a/boards.cfg b/boards.cfg index e4b0d44..b13407e 100644 --- a/boards.cfg +++ b/boards.cfg @@ -293,6 +293,7 @@ whistler arm armv7:arm720t whistler nvidia colibri_t20_iris arm armv7:arm720t colibri_t20_iris toradex tegra20 u8500_href arm armv7 u8500 st-ericsson u8500 snowball arm armv7 snowball st-ericsson u8500 +cubox arm armv7 cubox solidrun dove kzm9g arm armv7 kzm9g kmc rmobile armadillo-800eva arm armv7 armadillo-800eva atmark-techno rmobile zynq arm armv7 zynq xilinx zynq diff --git a/include/configs/cubox.h b/include/configs/cubox.h new file mode 100644 index 0000000..88a2fda --- /dev/null +++ b/include/configs/cubox.h @@ -0,0 +1,175 @@ +/* + * SolidRun CuBox config + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _CONFIG_CUBOX_H +#define _CONFIG_CUBOX_H +#include <asm/sizes.h> + +/* + * Version number information + */ +#define CONFIG_IDENT_STRING "\SolidRun CuBox" + +/* + * High Level Configuration Options + */ +#define CONFIG_MACH_SOLIDRUN_CUBOX /* Machine type */ +#define CONFIG_SHOW_BOOT_PROGRESS +#define CONFIG_ORION_GPIO /* Orion GPIO driver */ + +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +/* + * Enable u-boot API for standalone programs. + */ +#define CONFIG_API + +/* + * Enable device tree support + */ +#define CONFIG_OF_LIBFDT + +/* + * Commands configuration + */ +#include <config_cmd_default.h> +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ELF +#define CONFIG_CMD_ENV +#define CONFIG_CMD_IDE +#define CONFIG_CMD_PING +#define CONFIG_CMD_SF +#define CONFIG_CMD_SPI +#define CONFIG_CMD_USB +#define CONFIG_CMD_MMC + +#define CONFIG_DOS_PARTITION +#define CONFIG_EFT_PARTITION + +/* + * mv-common.h should be defined after CMD configs since it used them + * to enable certain macros + */ +#include "mv-common.h" + +/* + * redefine mv-common.h macros for armv7/cubox + */ +#undef CONFIG_SYS_PROMPT /* previously defined in mv-common.h */ +#define CONFIG_SYS_PROMPT "CuBox> " /* Command Prompt */ + +/* There is no arch_misc_init on armv7 */ +#undef CONFIG_ARCH_MISC_INIT + +#undef CONFIG_SYS_MALLOC_LEN +#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) /* 4MiB for malloc() */ + +/* + * Environment variables configurations + */ +#if defined(CONFIG_CMD_SF) +#define CONFIG_SPI_FLASH_WINBOND +#define CONFIG_ENV_IS_IN_SPI_FLASH 1 +#define CONFIG_ENV_SECT_SIZE 0x1000 /* 4k */ +#define CONFIG_ENV_SIZE 0x20000 /* 128k */ +#define CONFIG_ENV_OFFSET 0xc0000 /* env starts here */ +#else +#define CONFIG_ENV_IS_NOWHERE 1 /* if env in SDRAM */ +#endif + +/* + * Default CuBox bootscript environment + */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "bootscript=boot.scr\0" \ + "loadaddr=0x02000000\0" \ + "mmc_started=0\0" \ + "ide_started=0\0" \ + "usb_started=0\0" \ + "mtdparts=mtdparts=spi0.0:768k(u-boot)ro,128k(uboot_env),128k(fdt),-(empty)\0" \ + "ethaddr=00:50:43:15:17:17\0" + +#define CONFIG_BOOTCOMMAND \ + "for devn in usb mmc ide ; do " \ + " for part in 0 1; do " \ + " for dir in / /boot/;do " \ + " for fs in ext2 fat; do " \ + " echo ===> Executing ${fs}load ${devn} 0:${part} ${loadaddr} ${dir}${bootscript};" \ + " if itest.s $devn -eq mmc; then" \ + " if itest.s $mmc_started -ne 1; then" \ + " mmcinfo; setenv mmc_started '1';fi;fi;" \ + " if itest.s $devn -eq usb; then" \ + " if itest.s $usb_started -ne 1; then" \ + " usb start; setenv usb_started '1';fi;fi;" \ + " if itest.s $devn -eq ide; then" \ + " if itest.s $ide_started -ne 1; then" \ + " ide reset; setenv ide_started '1';fi;fi;" \ + " if ${fs}load ${devn} 0:${part} ${loadaddr} ${dir}${bootscript}; then" \ + " source ${loadaddr}; fi;" \ + " if itest.s $devn -eq usb; then" \ + " echo ===> Executing ${fs}load ${devn} 1:${part} ${loadaddr} ${dir}${bootscript};" \ + " if ${fs}load ${devn} 1:${part} ${loadaddr} ${dir}${bootscript}; then" \ + " source ${loadaddr}; fi;" \ + " fi;" \ + " done;" \ + " done;" \ + " done;" \ + "done;" \ + "tftp ${loadaddr} ${bootscript};" \ + "source ${loadaddr};" + +/* + * Ethernet Driver configuration + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_MVGBE_PORTS {1} /* enable port 0 */ +#define CONFIG_PHY_BASE_ADR 1 +#define CONFIG_PHYLIB +#define CONFIG_PHY_MARVELL +#endif /* CONFIG_CMD_NET */ + +#ifdef CONFIG_CMD_IDE +#undef CONFIG_IDE_LED +#undef CONFIG_SYS_IDE_MAXBUS +#define CONFIG_SYS_IDE_MAXBUS 1 +#undef CONFIG_SYS_IDE_MAXDEVICE +#define CONFIG_SYS_IDE_MAXDEVICE 1 +#define CONFIG_SYS_ATA_IDE0_OFFSET MV_SATA_PORT0_OFFSET +#endif + +/* + * File system + */ +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_EXT4 +#define CONFIG_CMD_FAT +#define CONFIG_RBTREE +#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_MTDPARTS +#define CONFIG_LZO + +#endif /* _CONFIG_CUBOX_H */
-----Original Message----- From: Sebastian Hesselbarth [mailto:sebastian.hesselbarth@gmail.com] Sent: 17 January 2013 00:55 To: Sebastian Hesselbarth Cc: u-boot@lists.denx.de; Rabeeh Khoury; Albert Aribaud; Prafulla Wadaskar; Andy Fleming; Joe Hershberger; Daniel Stodden; Luka Perkov Subject: [PATCH v3 09/10] Boards: Add support for SolidRun CuBox
Pls rename this as dvbimage.cfg
+COBJS := cubox.o
+##################################################################### #### diff --git a/board/solidrun/cubox/cubox.c b/board/solidrun/cubox/cubox.c new file mode 100644 index 0000000..70c016f --- /dev/null +++ b/board/solidrun/cubox/cubox.c @@ -0,0 +1,141 @@ +/*
- SolidRun CuBox board support
- Sebastian Hesselbarth sebastian.hesselbarth@gmail.com
- project.
- Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston,
- MA 02110-1301 USA
MPP0_GPIO,
MPP4_GPIO,
MPP5_GPIO,
MPP6_GPIO,
MPP7_GPIO,
May you please comment about functionality associated with uncommented GPIOs being configured here, If you don't use these GPIOs at all on your board then you can remove them from this configuration.
MPP8_GPIO,
MPP9_GPIO,
MPP10_GPIO,
MPP11_GPIO,
MPP14_GPIO,
MPP15_GPIO,
MPP16_GPIO,
MPP17_GPIO,
MPP20_GPIO,
MPP21_GPIO,
MPP22_GPIO,
MPP23_GPIO,
MPP_CAMERA_GPIO,
On which MPP this function is loaded? Is it MPP24? Then naming it as MPP24_XX makes sense to me.
MPP_SDIO1_GPIO,
MPP_UART1_GPIO,
MPP_NAND_GPO,
MPP_AUDIO0_I2S,
0 };
.val0 = 0x00010186,
.val1 = 0x018000c0,
.val2 = 0x00000000,
/* configure mpp */
/* blink led */
dove_sdhci_init(0);
+} +#endif
u16 devadr;
return;
__func__);
return;
/* reset the phy */
Have you purposely repeated above lines? Why?
Please check it is in order
- SolidRun CuBox config
- project.
- MA 02110-1301 USA
- Version number information
- High Level Configuration Options
- Enable u-boot API for standalone programs.
+#define CONFIG_API
- Enable device tree support
- Commands configuration
- mv-common.h should be defined after CMD configs since it used them
- to enable certain macros
- redefine mv-common.h macros for armv7/cubox
- Environment variables configurations
- Default CuBox bootscript environment
"mmc_started=0\0" \
"ide_started=0\0" \
"usb_started=0\0" \
NACK: hard coding Ethernet address not allowed.
" fi;" \
" done;" \
" done;" \
" done;" \
"done;" \
- Ethernet Driver configuration
- File system
1.7.10.4
On Dove kwboot can also be used to boot an u-boot image into RAM. In contrast to Kirkwood, Dove does not support the UART boot mode sequence but requires the UART boot mode to be selected through strap pins. The SolidRun CuBox has a push button to allow uart boot mode but fails on the boot sequence sent by kwboot.
This patch adds another cmdline option to allow to send a boot image without the boot sequence and adds support for Dove.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Signed-off-by: Daniel Stodden daniel.stodden@gmail.com --- Cc: u-boot@lists.denx.de Cc: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Daniel Stodden daniel.stodden@gmail.com Cc: Luka Perkov luka@openwrt.org --- doc/kwboot.1 | 13 ++++++++++--- tools/Makefile | 2 ++ tools/kwboot.c | 25 +++++++++++++++++++------ 3 files changed, 31 insertions(+), 9 deletions(-)
diff --git a/doc/kwboot.1 b/doc/kwboot.1 index 25fe69a..ab4551b 100644 --- a/doc/kwboot.1 +++ b/doc/kwboot.1 @@ -1,17 +1,18 @@ -.TH KWBOOT 1 "2012-05-19" +.TH KWBOOT 1 "2013-01-16"
.SH NAME -kwboot - Boot Marvell Kirkwood SoCs over a serial link. +kwboot - Boot Marvell Kirkwood/Dove SoCs over a serial link. .SH SYNOPSIS .B kwboot .RB [ "-b \fIimage\fP" ] +.RB [ "-n" ] .RB [ "-p" ] .RB [ "-t" ] .RB [ "-B \fIbaudrate\fP" ] .RB \fITTY\fP .SH "DESCRIPTION"
-The \fBmkimage\fP program boots boards based on Marvell's Kirkwood +The \fBmkimage\fP program boots boards based on Marvell's Kirkwood/Dove platform over their integrated UART. Boot image files will typically contain a second stage boot loader, such as U-Boot. The image file must conform to Marvell's BootROM firmware image format @@ -68,6 +69,12 @@ If standard I/O streams connect to a console, this mode will terminate after receiving 'ctrl-\' followed by 'c' from console input.
.TP +.BI "-u" +Disables the UART boot mode sequence for platforms that do not support +it (e.g. Dove). Usually, the UART boot mode must be selected by pressing +a push button on power-up. + +.TP .BI "-B \fIbaudrate\fP" Adjust the baud rate on \fITTY\fP. Default rate is 115200.
diff --git a/tools/Makefile b/tools/Makefile index 686840a..4816812 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -72,6 +72,7 @@ BIN_FILES-$(CONFIG_SMDK5250) += mksmdk5250spl$(SFX) BIN_FILES-$(CONFIG_MX28) += mxsboot$(SFX) BIN_FILES-$(CONFIG_NETCONSOLE) += ncb$(SFX) BIN_FILES-$(CONFIG_SHA1_CHECK_UB_IMG) += ubsha1$(SFX) +BIN_FILES-$(CONFIG_DOVE) += kwboot$(SFX) BIN_FILES-$(CONFIG_KIRKWOOD) += kwboot$(SFX)
# Source files which exist outside the tools directory @@ -103,6 +104,7 @@ OBJ_FILES-$(CONFIG_NETCONSOLE) += ncb.o NOPED_OBJ_FILES-y += os_support.o OBJ_FILES-$(CONFIG_SHA1_CHECK_UB_IMG) += ubsha1.o NOPED_OBJ_FILES-y += ublimage.o +OBJ_FILES-$(CONFIG_DOVE) += kwboot.o OBJ_FILES-$(CONFIG_KIRKWOOD) += kwboot.o
# Don't build by default diff --git a/tools/kwboot.c b/tools/kwboot.c index e773f01..1e4edb6 100644 --- a/tools/kwboot.c +++ b/tools/kwboot.c @@ -37,6 +37,10 @@ static unsigned char kwboot_msg_boot[] = { 0xBB, 0x11, 0x22, 0x33, 0x44, 0x55, 0x66, 0x77 };
+static unsigned char kwboot_msg_none[] = { + 0x00 +}; + #define KWBOOT_MSG_REQ_DELAY 10 /* ms */ #define KWBOOT_MSG_RSP_TIMEO 50 /* ms */
@@ -268,17 +272,21 @@ kwboot_bootmsg(int tty, void *msg) int rc; char c;
- kwboot_printv("Sending boot message. Please reboot the target..."); + kwboot_printv(msg != kwboot_msg_none + ? "Sending boot message. Please reboot the target..." + : "Sensing target. Please reboot target into UART mode...");
do { rc = tcflush(tty, TCIOFLUSH); if (rc) break;
- rc = kwboot_tty_send(tty, msg, 8); - if (rc) { - usleep(KWBOOT_MSG_REQ_DELAY * 1000); - continue; + if (msg != kwboot_msg_none) { + rc = kwboot_tty_send(tty, msg, 8); + if (rc) { + usleep(KWBOOT_MSG_REQ_DELAY * 1000); + continue; + } }
rc = kwboot_tty_recv(tty, &c, 1, KWBOOT_MSG_RSP_TIMEO); @@ -607,6 +615,7 @@ kwboot_usage(FILE *stream, char *progname) fprintf(stream, " -b <image>: boot <image>\n"); fprintf(stream, " -p: patch <image> to type 0x69 (uart boot)\n"); fprintf(stream, "\n"); + fprintf(stream, " -n: don't send boot message\n"); fprintf(stream, " -t: mini terminal\n"); fprintf(stream, "\n"); fprintf(stream, " -B <baud>: set baud rate\n"); @@ -636,7 +645,7 @@ main(int argc, char **argv) kwboot_verbose = isatty(STDOUT_FILENO);
do { - int c = getopt(argc, argv, "hb:ptB:"); + int c = getopt(argc, argv, "hb:nptB:"); if (c < 0) break;
@@ -646,6 +655,10 @@ main(int argc, char **argv) imgpath = optarg; break;
+ case 'n': + bootmsg = kwboot_msg_none; + break; + case 'p': patch = 1; break;
-----Original Message----- From: Sebastian Hesselbarth [mailto:sebastian.hesselbarth@gmail.com] Sent: 17 January 2013 00:55 To: Sebastian Hesselbarth Cc: Daniel Stodden; u-boot@lists.denx.de; Rabeeh Khoury; Albert Aribaud; Prafulla Wadaskar; Andy Fleming; Joe Hershberger; Luka Perkov Subject: [PATCH v3 10/10] tools: Add support for Dove to kwboot
- 0x00
target...");
if (rc) {
continue;
if (rc) {
continue;
- fprintf(stream, " -n: don't send boot message\n"); fprintf(stream, " -t: mini terminal\n"); fprintf(stream, "\n"); fprintf(stream, " -B <baud>: set baud rate\n");
do {
if (c < 0) break;int c = getopt(argc, argv, "hb:nptB:");
case 'n':
break;
- case 'p': patch = 1; break;
-- 1.7.10.4
-----Original Message----- From: Sebastian Hesselbarth [mailto:sebastian.hesselbarth@gmail.com] Sent: 17 January 2013 00:55 To: Sebastian Hesselbarth Cc: u-boot@lists.denx.de; Rabeeh Khoury; Albert Aribaud; Prafulla Wadaskar; Andy Fleming; Joe Hershberger; Daniel Stodden; Luka Perkov Subject: [PATCH v3 00/10] Add Marvell Dove and SolidRun CuBox
This patch set add support for the Marvell Dove 88AP510 SoC and the SolidRun CuBox board based on that SoC. The patch set is divided into the four following sections:
Dear Sabastian First of all I express my thanks for initiating this Soc Support in the u-boot. Secondly I express my apology since I could not review then immediately. Please find my comments for entire patch series
(1) Patches 1-5:
I have suggestions to break down your patches as mentioned below
Add support for the Dove SoC and related drivers. Where possible drivers from Marvell Kirkwood are reused (mvsata, mvgbe), or forked to allow more generic usage (SPI, GPIO). The SDHCI driver is different and a new driver is added for it. The forked drivers can also be reused on Kirkwood but that would have required patching existing boards.
(2) Patches 6-8: Allow mvgbe to use the phylib API, add support for 88E1310 PHY and allow Dove to use the driver.
(3) Patch 9 Add the SolidRun CuBox as the first board based on Marvell Dove SoC.
(4) Patch 10 Add support for different UART boot mode found on Dove.
Changelog: v1->v2:
- respect review comments by Luka Perkov
- fix commenting styles and typos
- add MAINTAINERS entry
- also update kwboot.1 manpage
v2->v3:
- integrate kwboot patch from Daniel Stodden
- rebase on release v2013.01
Sebastian Hesselbarth (10): ARM: dove: add support for Marvell Dove SoC GPIO: add gpio driver for Orion SoCs MMC: sdhci: Add support for dove sdhci SPI: Add Orion SPI driver block: mvsata: add dove include NET: phy: add 88E1310 PHY initialization NET: mvgbe: add phylib support NET: mvgbe: add support for Dove Boards: Add support for SolidRun CuBox tools: Add support for Dove to kwboot
MAINTAINERS | 4 + arch/arm/cpu/armv7/dove/Makefile | 49 +++++ arch/arm/cpu/armv7/dove/cpu.c | 266 ++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/dram.c | 118 ++++++++++++ arch/arm/cpu/armv7/dove/lowlevel_init.S | 83 ++++++++ arch/arm/cpu/armv7/dove/mpp.c | 318 +++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/timer.c | 176 +++++++++++++++++ arch/arm/cpu/armv7/dove/usb.c | 101 ++++++++++ arch/arm/include/asm/arch-dove/config.h | 153 +++++++++++++++ arch/arm/include/asm/arch-dove/cpu.h | 204 ++++++++++++++++++++ arch/arm/include/asm/arch-dove/dove.h | 93 +++++++++ arch/arm/include/asm/arch-dove/gpio.h | 35 ++++ arch/arm/include/asm/arch-dove/mpp.h | 283
Basic Dove support (one patch series)
drivers/gpio/Makefile | 1 + include/dove or mv_gpio.h | 64 +++++++ drivers/gpio/dove or mv_gpio.c | 167 ++++++++++++++++
GPIO driver support for Dove
drivers/spi/Makefile | 1 + drivers/spi/dove_spi.c | 217
Spi driver support for dove
drivers/block/mvsata_ide.c | 2 + drivers/mmc/Makefile | 1 + drivers/mmc/dove_sdhci.c | 101 ++++++++++ drivers/net/mvgbe.c | 70 ++++++- drivers/net/mvgbe.h | 7 + drivers/net/phy/marvell.c | 48 +++++
Other driver supports for dove (explain supported drivers)
+++++++++++++++++++++++++++ board/solidrun/cubox/Makefile | 45 +++++ board/solidrun/cubox/cubox.c | 141 ++++++++++++++ board/solidrun/cubox/kwbimage.cfg | 76 ++++++++ boards.cfg | 1 + include/configs/cubox.h | 175 +++++++++++++++++
Board support patches
doc/kwboot.1 | 13 +-
tools/Makefile | 2 + tools/kwboot.c | 25 ++-
Add dove support for boot tool.
FYI: I have gone through all patches in this series
Prafulla,
thanks for the detailled review! I will quickly give some comments about some of your review questions and will do a full re-review later.
* About the orion/dove/kirkwood naming convention in linux kernel (that this patch set picks up):
When I started hacking on linux and marvell SoCs in particular there was support for orion5x, mv78xx0, kirkwood, and dove. As those SoCs share a bunch of internal peripherals (you might know better) the drivers shared between those SoCs were prepended with "orion_" that should reflect the family of SoCs with that peripherals. I personally find the naming collision with orion5x "unlucky" but that is the way it is.
Then there came some effort to also mainline Armada 370/XP series that of course also share "orion" drivers. The final name for all SoCs (including "orion") was mvebu as it is the only common naming scheme that fit (mvebu stands for some business unit within Marvell).
Plans for using just "marvell" or "mv" were rejected because there are also pxa SoCs from marvell sitting in the kernel tree. They likely share some of the internal peripherals but that is not reflected within kernel tree, as there are two different hacking communities I guess.
New drivers that fit all SoCs (namely pinctrl and gpio, because linux API changes required new drivers from scratch) get mvebu_, drivers that still fit in "orion" get orion_, new soc specific ones get either dove_, kirkwood_, armada_370_, or whatever the code name of that SoC is. Old driver names remain untouched even if they are reused on Armada 370/XP.
Whenever I used orion_ in this patch set this refers to orion as in SoC family, not orion5x that you might have been irritated with.
* About the kwboot/kwbimage patches: u-boot has kwboot for kirkwood since ages, but the general functionality to boot through UART boot mode also applies to above SoCs. I took kwbimage to reflect that kwboot should be used for booting this image. IMHO introducing new abbreviated image names like dvbimage will just distract people from using the correct tool to boot it. kwboot will not be renamed, will it?
* About the ordering of patches/patch sets:
(1) Patches 1-5:
Changelog: v1->v2:
v2->v3:
Ok. Just to make sure, you want me to leave driver specific stuff, e.g. orion_spi_* out of this patch set and re-add the calls within the corresponding driver patches?
With the above comments about SoC naming, I'd like to stick with either orion_ or mvebu_ if the basic driver framework can be reused on Armada 370/XP (when they get mainline support in u-boot).
Ditto.
Ack.
Ack.
Ack.
Thanks for that again! I will flip through all the individual patches later and give detailled comments for sure.
Regards, Sebastian
I don't mind if we rename kwboot to lets say mvebu-boot. That name would fit for kirkwood, dove and armada SoCs in the future...
Luka
-----Original Message----- From: Luka Perkov [mailto:luka@openwrt.org] Sent: 11 February 2013 02:08 To: Sebastian Hesselbarth Cc: Prafulla Wadaskar; u-boot@lists.denx.de; Rabeeh Khoury; Albert Aribaud; Andy Fleming; Joe Hershberger; Daniel Stodden Subject: Re: [PATCH v3 00/10] Add Marvell Dove and SolidRun CuBox
functionality
image.
not
That's good idea. I vote for renaming kwboot as "mvboot", that will inline with predefined file naming strategy.
functionality
image.
not
Is kwboot practically extensible to mmp and pxa?
thx,
Jason.
functionality
image.
not
If those have a similar mechanism, and it happens to be based on Xmodem, then there's probably sharable ground.
The boot message protocol on Marvell chips is a fairly ad-hoc construct.
Daniel
functionality
image.
not
right, I was more concerned with the naming convention. At least in the kernel, mvebu includes all Marvell SoCs _except_ mmp and pxa. I would presume mv would be an all-inclusive name.
I didn't really have a strong opinion on it, so I'm fine either way. In hindsight, I'd prefer not to type 'mvebu-boot'...
thx,
Jason.
-----Original Message----- From: Jason Cooper [mailto:jason@lakedaemon.net] Sent: 14 February 2013 13:44 To: Daniel Stodden Cc: Prafulla Wadaskar; Luka Perkov; Sebastian Hesselbarth; Rabeeh Khoury; u-boot@lists.denx.de; Andy@theia.denx.de; Fleming Subject: Re: [U-Boot] [PATCH v3 00/10] Add Marvell Dove and SolidRun CuBox
Albert
CuBox
functionality
took
this
image.
will just
kwboot will
not
name
Xmodem,
construct.
If the code or tool is being shared between more that one Marvell SoCs, it makes sense to use mv_** naming convention. This is to inline with the Marvell's naming strategy implemented so far in u-boot code.
Whereas, we can always have <soc>_<functionality> type of naming conventions for specific implementation.
At present, kwboot is specific to Kirkwood, the support is being extended for Dove and latter few more.. so it makes sense to rename it as mvboot.
I need to check whether kwboot is practically extensible to mmp and pxa, but it makes sense to rename it as mvboot since it supports more than Kirkwood.
Regards.. Prafulla . . .
Sebastian Hesselbarth sebastian.hesselbarth@gmail.com writes:
What's the state of this? I tried applying your patch series on top of current master and getting it to work on a CuBox Pro (2GiB SDRAM instead of 1GiB), but with no success so far. I changed kwbimage.cfg to match dramregs_cubox_2gb.txt in Rabeeh's tree and fixed arch/arm/cpu/armv7/dove/timer.c to work with the generic global_data (introduced by baa1e53 and 50b1fa3). However there seems to be something else missing or broken as there's no output whatsoever on the serial console after booting the new image via UART. The same boot procedure works fine with an image built using Rabeeh's tree.
Sascha
Got this to work. The problem was that I didn't know about "make u-boot.kwb", so I tried invoking mkimage using the load address and entry point used in Rabeeh's tree. For some reason, the entry point is different in mainline U-Boot.
Changes compared to v3 from Sebastian: - rebased on master (using generic global_data) - added support for CuBox Pro and UART boot - second USB port works now - drives > 2TiB work now - using dove_* naming convention rather than orion_* (mv is already taken, at least for GPIO) - removed EBAR_DRAM_CS* for dove (dove doesn't encode SDRAM bank in attributes) - removed hard-coded ethaddr - general clean-ups (checkpatch clean except for one spot now)
I'm assuming Sebastian (CC'ed) is still willing to be the maintainer.
Sascha Silbe (1): usb: ehci-marvell: add support for second USB controller
Sebastian Hesselbarth (9): ARM: dove: add support for Marvell Dove SoC GPIO: add gpio driver for Dove SoCs MMC: sdhci: Add support for dove sdhci SPI: Add Dove SPI driver block: mvsata: add dove include NET: phy: add 88E1310 PHY initialization NET: mvgbe: add phylib support NET: mvgbe: add support for Dove Boards: Add support for SolidRun CuBox
MAINTAINERS | 4 + arch/arm/cpu/armv7/dove/Makefile | 49 +++++ arch/arm/cpu/armv7/dove/cpu.c | 274 +++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/dram.c | 117 +++++++++++ arch/arm/cpu/armv7/dove/lowlevel_init.S | 83 ++++++++ arch/arm/cpu/armv7/dove/mpp.c | 318 ++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/timer.c | 176 +++++++++++++++++ arch/arm/cpu/armv7/dove/usb.c | 101 ++++++++++ arch/arm/include/asm/arch-dove/config.h | 153 ++++++++++++++ arch/arm/include/asm/arch-dove/cpu.h | 204 +++++++++++++++++++ arch/arm/include/asm/arch-dove/dove.h | 98 +++++++++ arch/arm/include/asm/arch-dove/gpio.h | 35 ++++ arch/arm/include/asm/arch-dove/mmc.h | 27 +++ arch/arm/include/asm/arch-dove/mpp.h | 283 ++++++++++++++++++++++++++ arch/arm/include/asm/arch-dove/usb.h | 27 +++ board/solidrun/cubox/Makefile | 45 +++++ board/solidrun/cubox/cubox.c | 142 +++++++++++++ board/solidrun/cubox/kwbimage-spi-1gb.cfg | 76 +++++++ board/solidrun/cubox/kwbimage-spi-2gb.cfg | 76 +++++++ board/solidrun/cubox/kwbimage-uart.cfg | 76 +++++++ boards.cfg | 3 + drivers/block/mvsata_ide.c | 2 + drivers/gpio/Makefile | 1 + drivers/gpio/dove_gpio.c | 167 ++++++++++++++++ drivers/mmc/Makefile | 1 + drivers/mmc/dove_sdhci.c | 101 ++++++++++ drivers/net/mvgbe.c | 83 +++++++- drivers/net/mvgbe.h | 2 + drivers/net/phy/marvell.c | 48 +++++ drivers/spi/Makefile | 1 + drivers/spi/dove_spi.c | 212 ++++++++++++++++++++ drivers/usb/host/ehci-marvell.c | 35 ++-- include/configs/cubox.h | 185 +++++++++++++++++ include/dove_gpio.h | 64 ++++++ 34 files changed, 3251 insertions(+), 18 deletions(-) create mode 100644 arch/arm/cpu/armv7/dove/Makefile create mode 100644 arch/arm/cpu/armv7/dove/cpu.c create mode 100644 arch/arm/cpu/armv7/dove/dram.c create mode 100644 arch/arm/cpu/armv7/dove/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/dove/mpp.c create mode 100644 arch/arm/cpu/armv7/dove/timer.c create mode 100644 arch/arm/cpu/armv7/dove/usb.c create mode 100644 arch/arm/include/asm/arch-dove/config.h create mode 100644 arch/arm/include/asm/arch-dove/cpu.h create mode 100644 arch/arm/include/asm/arch-dove/dove.h create mode 100644 arch/arm/include/asm/arch-dove/gpio.h create mode 100644 arch/arm/include/asm/arch-dove/mmc.h create mode 100644 arch/arm/include/asm/arch-dove/mpp.h create mode 100644 arch/arm/include/asm/arch-dove/usb.h create mode 100644 board/solidrun/cubox/Makefile create mode 100644 board/solidrun/cubox/cubox.c create mode 100644 board/solidrun/cubox/kwbimage-spi-1gb.cfg create mode 100644 board/solidrun/cubox/kwbimage-spi-2gb.cfg create mode 100644 board/solidrun/cubox/kwbimage-uart.cfg create mode 100644 drivers/gpio/dove_gpio.c create mode 100644 drivers/mmc/dove_sdhci.c create mode 100644 drivers/spi/dove_spi.c create mode 100644 include/configs/cubox.h create mode 100644 include/dove_gpio.h
This patch adds initial support for the armv7-based Marvell Dove SoC (88AP510).
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Signed-off-by: Sascha Silbe t-uboot@infra-silbe.de --- v3->v4: added second USB port; added support for hard disks > 2TiB; adapted to generic global_data; added usb.h to define dove_ehci_phy_init for cpu.c; made checkpatch clean
arch/arm/cpu/armv7/dove/Makefile | 49 +++++ arch/arm/cpu/armv7/dove/cpu.c | 274 +++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/dram.c | 117 ++++++++++++ arch/arm/cpu/armv7/dove/lowlevel_init.S | 83 +++++++++ arch/arm/cpu/armv7/dove/mpp.c | 318 ++++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/timer.c | 176 ++++++++++++++++++ arch/arm/cpu/armv7/dove/usb.c | 101 ++++++++++ arch/arm/include/asm/arch-dove/config.h | 153 +++++++++++++++ arch/arm/include/asm/arch-dove/cpu.h | 204 ++++++++++++++++++++ arch/arm/include/asm/arch-dove/dove.h | 98 ++++++++++ arch/arm/include/asm/arch-dove/gpio.h | 35 ++++ arch/arm/include/asm/arch-dove/mpp.h | 283 ++++++++++++++++++++++++++++ arch/arm/include/asm/arch-dove/usb.h | 27 +++ 13 files changed, 1918 insertions(+) create mode 100644 arch/arm/cpu/armv7/dove/Makefile create mode 100644 arch/arm/cpu/armv7/dove/cpu.c create mode 100644 arch/arm/cpu/armv7/dove/dram.c create mode 100644 arch/arm/cpu/armv7/dove/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/dove/mpp.c create mode 100644 arch/arm/cpu/armv7/dove/timer.c create mode 100644 arch/arm/cpu/armv7/dove/usb.c create mode 100644 arch/arm/include/asm/arch-dove/config.h create mode 100644 arch/arm/include/asm/arch-dove/cpu.h create mode 100644 arch/arm/include/asm/arch-dove/dove.h create mode 100644 arch/arm/include/asm/arch-dove/gpio.h create mode 100644 arch/arm/include/asm/arch-dove/mpp.h create mode 100644 arch/arm/include/asm/arch-dove/usb.h
diff --git a/arch/arm/cpu/armv7/dove/Makefile b/arch/arm/cpu/armv7/dove/Makefile new file mode 100644 index 0000000..127d67e --- /dev/null +++ b/arch/arm/cpu/armv7/dove/Makefile @@ -0,0 +1,49 @@ +# +# Marvell Dove SoC Makefile +# +# Sebastian Hesselbarth sebastian.hesselbarth@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).o + +SOBJS += lowlevel_init.o +COBJS-y := cpu.o dram.o timer.o mpp.o +COBJS-$(CONFIG_USB_EHCI_MARVELL) += usb.o + +COBJS := $(COBJS-y) +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/arm/cpu/armv7/dove/cpu.c b/arch/arm/cpu/armv7/dove/cpu.c new file mode 100644 index 0000000..b5320b7 --- /dev/null +++ b/arch/arm/cpu/armv7/dove/cpu.c @@ -0,0 +1,274 @@ +/* + * Marvell Dove SoC cpu related functions + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <netdev.h> +#include <asm/cache.h> +#include <u-boot/md5.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> +#include <asm/arch/usb.h> +#include <hush.h> + +void reset_cpu(unsigned long ignored) +{ + struct dovecpu_registers *cpureg = + (struct dovecpu_registers *)DOVE_CPU_REG_BASE; + + /* Enable soft reset to assert RSTOUTn */ + writel(readl(&cpureg->rstoutn_mask) | (1 << 2), + &cpureg->rstoutn_mask); + /* Assert soft reset */ + writel(readl(&cpureg->sys_soft_rst) | 1, + &cpureg->sys_soft_rst); + do {} while (1); +} + +#if defined(CONFIG_DISPLAY_CPUINFO) +int dove_print_cpu(void) +{ + char *cpu; + u32 idreg; + u16 part, rev; + + __asm__ __volatile__("mrc p15, 0, %0, c0, c0, 0" : "=r"(idreg)); + + part = (idreg >> ARM_ID_PARTNUM_OFFSET) & ARM_ID_PARTNUM_MASK; + rev = (idreg >> ARM_ID_REVISION_OFFSET) & ARM_ID_REVISION_MASK; + + switch (part) { + case DOVECPU_PART_SHEEVA: + cpu = "Marvell Sheeva"; + break; + default: + cpu = "Unknown CPU"; + } + + printf("CPU: %s (rev %d)\n", cpu, rev); + return 0; +} + +int dove_print_soc(void) +{ + char *soc, *rev; + u16 devid = (readl(DOVE_REG_PCIE_DEVID) >> 16) & 0xffff; + u8 revid = readl(DOVE_REG_PCIE_REVID) & 0xff; + + switch (devid) { + case DOVESOC_DEVID_AP510: + soc = "AP510"; + break; + case DOVESOC_DEVID_F6781: + soc = "F6781"; + break; + default: + printf("ERROR.. %s: Unsupported SoC %04x\n", __func__, devid); + return -1; + } + + switch (revid) { + case DOVESOC_REVID_Z0: + rev = "Z0"; + break; + case DOVESOC_REVID_Z1: + rev = "Z1"; + break; + case DOVESOC_REVID_Y0: + rev = "Y0"; + break; + case DOVESOC_REVID_Y1: + rev = "Y1"; + break; + case DOVESOC_REVID_X0: + rev = "X0"; + break; + case DOVESOC_REVID_A0: + rev = "A0"; + break; + case DOVESOC_REVID_A1: + rev = "A1"; + break; + default: + rev = "Unknown revision"; + }; + + printf("SoC: Dove 88%s (%s)\n", soc, rev); + return 0; +} + +int print_cpuinfo(void) +{ + if (dove_print_soc()) + return -1; + if (dove_print_cpu()) + return -1; + return 0; +} +#endif /* CONFIG_DISPLAY_CPUINFO */ + +/* + * dove_init_gpio - initial GPIO configuration + */ +void dove_init_gpio(struct dove_gpio_init *gpp) +{ + struct dovegpio_registers *gpio0reg = + (struct dovegpio_registers *)DOVE_GPIO0_BASE; + struct dovegpio_registers *gpio1reg = + (struct dovegpio_registers *)DOVE_GPIO1_BASE; + struct dovegpio_registers *gpio2reg = + (struct dovegpio_registers *)DOVE_GPIO2_BASE; + + /* Init GPIOS to default values as per board requirement */ + writel(gpp->val0, &gpio0reg->dout); + writel(gpp->val1, &gpio1reg->dout); + writel(gpp->val2, &gpio2reg->dout); + writel(gpp->oe0_n, &gpio0reg->oe); + writel(gpp->oe1_n, &gpio1reg->oe); + writel(gpp->oe2_n, &gpio2reg->oe); +} + +/* + * Window Size + * Used with the Base register to set the address window size and location. + * Must be programmed from LSB to MSB as sequence of ones followed by + * sequence of zeros. The number of ones specifies the size of the window in + * 64 KByte granularity (e.g., a value of 0x00FF specifies 256 = 16 MByte). + * NOTE: A value of 0x0 specifies 64-KByte size. + */ +unsigned int dove_winctrl_calcsize(unsigned int sizeval) +{ + int i; + unsigned int j = 0; + u32 val = sizeval >> 1; + + for (i = 0; val >= 0x10000; i++) { + j |= (1 << i); + val = val >> 1; + } + return 0x0000ffff & j; +} + +/* + * dove_config_adr_windows - Configure address Windows + * + * There are 8 address windows supported by Dove Soc to addess different + * devices. Windows 0-3 can be configured for size, BAR and remap addr. + * Windows 4-7 can be configured for size and BAR. + * Below configuration is standard for most of the cases + * + * If remap function not used, remap_lo must be set as base + */ +int dove_config_adr_windows(void) +{ + struct dovewin_registers *winregs = + (struct dovewin_registers *)DOVE_CPU_WIN_BASE; + + /* Window 0: 1M PCIE0 IO address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_1M, DOVECPU_TARGET_PCIE0, + DOVECPU_ATTR_PCIE_IO, DOVECPU_WIN_ENABLE), + &winregs[0].ctrl); + + writel(DOVE_DEFADR_PCIE0_IO, &winregs[0].base); + writel(DOVE_DEFADR_PCIE0_IO_REMAP, &winregs[0].remap_lo); + writel(0x0, &winregs[0].remap_hi); + + /* Window 1: 1M PCIE1 IO address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_1M, DOVECPU_TARGET_PCIE1, + DOVECPU_ATTR_PCIE_IO, DOVECPU_WIN_ENABLE), + &winregs[1].ctrl); + + writel(DOVE_DEFADR_PCIE1_IO, &winregs[1].base); + writel(DOVE_DEFADR_PCIE1_IO_REMAP, &winregs[1].remap_lo); + writel(0x0, &winregs[1].remap_hi); + + /* Window 2: 128M PCIE0 MEM address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_128M, DOVECPU_TARGET_PCIE0, + DOVECPU_ATTR_PCIE_MEM, DOVECPU_WIN_ENABLE), + &winregs[2].ctrl); + + writel(DOVE_DEFADR_PCIE0_MEM, &winregs[2].base); + writel(DOVE_DEFADR_PCIE0_MEM, &winregs[2].remap_lo); + writel(0x0, &winregs[2].remap_hi); + + /* Window 3: 128M PCIE1 MEM address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_128M, DOVECPU_TARGET_PCIE1, + DOVECPU_ATTR_PCIE_MEM, DOVECPU_WIN_ENABLE), + &winregs[3].ctrl); + + writel(DOVE_DEFADR_PCIE1_MEM, &winregs[3].base); + writel(DOVE_DEFADR_PCIE1_MEM, &winregs[3].remap_lo); + writel(0x0, &winregs[3].remap_hi); + + /* Window 4: 1M Cryptographic SRAM address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_1M, DOVECPU_TARGET_SASRAM, + DOVECPU_ATTR_SASRAM, DOVECPU_WIN_ENABLE), + &winregs[4].ctrl); + writel(DOVE_DEFADR_SASRAM, &winregs[4].base); + + /* Window 5: 128M Bootrom address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_128M, DOVECPU_TARGET_BOOTROM, + DOVECPU_ATTR_BOOTROM, DOVECPU_WIN_ENABLE), + &winregs[5].ctrl); + writel(DOVE_DEFADR_BOOTROM, &winregs[5].base); + + /* Window 6: 1M PMU Scratchpad address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_1M, DOVECPU_TARGET_PMURAM, + DOVECPU_ATTR_PMURAM, DOVECPU_WIN_ENABLE), + &winregs[6].ctrl); + writel(DOVE_DEFADR_PMURAM, &winregs[6].base); + + /* Window 7: Disabled */ + writel(DOVECPU_WIN_DISABLE, &winregs[7].ctrl); + + return 0; +} + +#ifdef CONFIG_ARCH_CPU_INIT +int arch_cpu_init(void) +{ + dove_config_adr_windows(); +#ifdef CONFIG_USB_EHCI_MARVELL + dove_ehci_phy_init(0); + dove_ehci_phy_init(1); +#endif /* CONFIG_USB_EHCI_MARVELL */ + return 0; +} +#endif /* CONFIG_ARCH_CPU_INIT */ + +void enable_caches(void) +{ +#ifndef CONFIG_SYS_DCACHE_OFF + /* Enable D-cache. I-cache is already enabled in lowlevel_init.S */ + dcache_enable(); +#endif /* CONFIG_SYS_DCACHE_OFF */ +} + +#ifdef CONFIG_MVGBE +int cpu_eth_init(bd_t *bis) +{ + mvgbe_initialize(bis); + return 0; +} +#endif /* CONFIG_MVGBE */ diff --git a/arch/arm/cpu/armv7/dove/dram.c b/arch/arm/cpu/armv7/dove/dram.c new file mode 100644 index 0000000..ce535f3 --- /dev/null +++ b/arch/arm/cpu/armv7/dove/dram.c @@ -0,0 +1,117 @@ +/* + * Marvell Dove SoC DRAM initialization + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <config.h> +#include <common.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define DOVE_REG_DRAM_MAP(x) (DOVE_REGISTER(0x800100) + (x * 0x10)) +#define DRAM_START_MASK 0xff800000 +#define DRAM_SIZE_MASK 0xf +#define DRAM_SIZE_SHIFT 16 + +/* + * dove_sdram_start - reads start from Memory Address Map Register n + */ +u32 dove_dram_start(enum memory_bank bank) +{ + u32 reg = readl(DOVE_REG_DRAM_MAP(bank)); + u32 enable = 0x01 & reg; + + if ((!enable) || (bank > BANK1)) + return 0; + + return reg & DRAM_START_MASK; +} + +/* + * dove_sdram_size - reads size from Memory Address Map Register n + */ +u32 dove_dram_size(enum memory_bank bank) +{ + u32 reg = readl(DOVE_REG_DRAM_MAP(bank)); + u32 enable = 0x01 & reg; + u32 size; + + if ((!enable) || (bank > BANK1)) + return 0; + + /* + * area_length: 7 = 8M, 8 = 16M, ..., 15 = 2048M + * size = 1 << (area_length + 16) + */ + size = (reg >> DRAM_SIZE_SHIFT) & DRAM_SIZE_MASK; + size = 1 << (size + 16); + return size; +} + +#ifndef CONFIG_SYS_BOARD_DRAM_INIT +int dram_init(void) +{ + int i; + + gd->ram_size = 0; + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + gd->bd->bi_dram[i].start = dove_dram_start(i); + gd->bd->bi_dram[i].size = dove_dram_size(i); + + /* + * It is assumed that all memory banks are consecutive + * and without gaps. + * If the gap is found, ram_size will be reported for + * consecutive memory only + */ + if (gd->bd->bi_dram[i].start != gd->ram_size) + break; + + gd->ram_size += gd->bd->bi_dram[i].size; + } + + for (; i < CONFIG_NR_DRAM_BANKS; i++) { + /* + * If above loop terminated prematurely, we need to set + * remaining banks' start address & size as 0. Otherwise other + * u-boot functions and Linux kernel gets wrong values which + * could result in crash + */ + gd->bd->bi_dram[i].start = 0; + gd->bd->bi_dram[i].size = 0; + } + + return 0; +} + +/* + * If this function is not defined here, + * board.c alters dram bank zero configuration defined above. + */ +void dram_init_banksize(void) +{ + dram_init(); +} +#endif /* CONFIG_SYS_BOARD_DRAM_INIT */ diff --git a/arch/arm/cpu/armv7/dove/lowlevel_init.S b/arch/arm/cpu/armv7/dove/lowlevel_init.S new file mode 100644 index 0000000..105d12d --- /dev/null +++ b/arch/arm/cpu/armv7/dove/lowlevel_init.S @@ -0,0 +1,83 @@ +/* + * Marvell Dove SoC icache and reg base low level init + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.+ * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm/arch/dove.h> +#include <generated/asm-offsets.h> +#include <linux/linkage.h> + +/* + * Enable Tauros2 L2 ICache + */ +.macro init_l2cc + mrc 15, 0, r0, c1, c0, 1 + orr r0, r0, #0x2 + mcr 15, 0, r0, c1, c0, 1 +.endm /* init_l2cc */ + +/* + * Init internal register base addresses + */ +.macro init_reg_base + /* set SB reg base to 0xf1000000 */ + ldr r1, =(DOVE_PREMAP_INT_REGS_BASE_ADDR) + ldr r6, =DOVE_SB_REGS_PHYS_BASE + str r6, [r1] + + /* set NB reg base to 0xf1800000 */ + ldr r1, =(DOVE_CPU_CTRL_REG) + ldr r4, =0xffff0000 + ldr r6, [r1] + and r6, r6, r4 + ldr r4, =DOVE_NB_REGS_PHYS_BASE + lsr r4, r6, #16 + orr r6, r6, r4 + str r6, [r1] + + /* Set AXI bridge address mapping to 0xf1800000 */ + ldr r1, =(DOVE_AXI_CTRL_REG) + ldr r4, =0x007fffff + ldr r6, [r1] + and r6, r6, r4 + ldr r4, =DOVE_NB_REGS_PHYS_BASE + orr r6, r6, r4 + str r6, [r1] + + /* set MC configuration register decode address to 0xf1800000 */ + ldr r1, =(DOVE_PREMAP_MC_DECODE_REG) + ldr r4, =0x0000ffff + ldr r6, [r1] + and r6, r6, r4 + ldr r4, =DOVE_NB_REGS_PHYS_BASE + orr r6, r6, r4 + str r6, [r1] + +.endm /* init_reg_base */ + +.section ".text.init", "x" + +ENTRY(lowlevel_init) + init_l2cc + init_reg_base + + /* r12 saved upper lr*/ + mov pc,lr +ENDPROC(lowlevel_init) diff --git a/arch/arm/cpu/armv7/dove/mpp.c b/arch/arm/cpu/armv7/dove/mpp.c new file mode 100644 index 0000000..55311c5 --- /dev/null +++ b/arch/arm/cpu/armv7/dove/mpp.c @@ -0,0 +1,318 @@ +/* + * Marvell Dove SoC MPP pinmux + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> +#include <asm/arch/mpp.h> +#include <asm/arch/gpio.h> + +#define MPP_BITS 4 +#define MPP_MASK 0xf +#define MPPS_PER_REG 8 + +#define MPP_NUM(_x) ((_x) & 0xff) +#define MPP_SEL(_x) (((_x) >> 8) & 0x1f) +#define MPP_GPIO(_x) ((_x) & (1 << 15)) + +#define MPP_CTRL(i) (DOVE_MPP_BASE + (i * MPP_BITS)) +#define MPP_PMU_GENERAL_CTRL (DOVE_MPP_BASE + 0x010) +#define PMUG_AUDIO0_AC97_SEL (1 << 16) +#define MPP4_CTRL (DOVE_MPP_BASE + 0x240) +#define MPP4_SDIO0_GPIO_SEL (1 << 0) +#define MPP4_SDIO1_GPIO_SEL (1 << 1) +#define MPP4_CAMERA_GPIO_SEL (1 << 2) +#define MPP4_AUDIO1_GPIO_SEL (1 << 3) +#define MPP4_UART1_GPIO_SEL (1 << 4) +#define MPP4_SPI_GPIO_SEL (1 << 5) +#define MPP_GENERAL_CTRL (DOVE_PDMA_BASE + 0x403c) +#define MPPG_NAND_GPIO_SEL (1 << 0) +#define MPPG_AUDIO1_SPDIFO_GPIO_SEL (1 << 1) +#define GENERAL_CONFIG_1 (DOVE_PDMA_BASE + 0x002c) +#define GENERAL_TWSI_MUXEN_OPTION1 (1 << 7) +#define GENERAL_CONFIG_2 (DOVE_PDMA_BASE + 0x0030) +#define GENERAL_TWSI_OPTION3_SEL (1 << 22) +#define GENERAL_TWSI_MUXEN_OPTION3 (1 << 21) +#define GENERAL_TWSI_MUXEN_OPTION2 (1 << 20) +#define SSP_CONFIG_STATUS_1 (DOVE_PDMA_BASE + 0x0034) +#define SSP_SSP_ON_AUDIO1 (1 << 0) + +/* + * MPP0-23 have standard MPP register layout + */ +static void dove_mpp_std_set(u16 config) +{ + u8 num = MPP_NUM(config); + u32 off = (num / MPPS_PER_REG) * MPP_BITS; + u32 shift = (num % MPPS_PER_REG) * MPP_BITS; + u32 reg; + + /* configure standard MPP pin */ + reg = readl(MPP_CTRL(off)); + reg &= ~(MPP_MASK << shift); + reg |= MPP_SEL(config) << shift; + writel(reg, MPP_CTRL(off)); + + /* configure gpio capabilities */ + if (MPP_GPIO(config)) + dove_gpio_set_valid(num, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + else + dove_gpio_set_valid(num, 0); +} + +/* + * MPP0-15 also allow to mux PMU functions + */ +static void dove_mpp_pmu_set(u16 config) +{ + u8 num = MPP_NUM(config); + + if (MPP_SEL(config) == PMU) { + /* enable PMU on MPP */ + writel(readl(MPP_PMU_GENERAL_CTRL) | (1 << num), + MPP_PMU_GENERAL_CTRL); + /* disable gpio capabilities */ + dove_gpio_set_valid(num, 0); + } else { + /* disable PMU on MPP */ + writel(readl(MPP_PMU_GENERAL_CTRL) & ~(1 << num), + MPP_PMU_GENERAL_CTRL); + /* configure MPP */ + dove_mpp_std_set(config); + } +} + +/* + * MPP groups on MPP4_CTRL have different register layout + * and allow GPIO or special function only + */ +static void dove_mpp4_set(u16 config) +{ + u32 reg = readl(MPP4_CTRL); + u32 mask; + u8 n, nmin, nmax; + int gpio; + + switch (MPP_NUM(config)) { + case MPP_CAMERA: + mask = MPP4_CAMERA_GPIO_SEL; + nmin = MPP_CAMERA; + nmax = MPP_CAMERA_MAX; + break; + case MPP_SDIO0: + mask = MPP4_SDIO0_GPIO_SEL; + nmin = MPP_SDIO0; + nmax = MPP_SDIO0_MAX; + break; + case MPP_SDIO1: + mask = MPP4_SDIO1_GPIO_SEL; + nmin = MPP_SDIO1; + nmax = MPP_SDIO1_MAX; + break; + case MPP_SPI: + mask = MPP4_SPI_GPIO_SEL; + nmin = MPP_SPI; + nmax = MPP_SPI_MAX; + break; + case MPP_UART1: + mask = MPP4_UART1_GPIO_SEL; + nmin = MPP_UART1; + nmax = MPP_UART1_MAX; + break; + default: + return; + } + + reg &= ~mask; + if (MPP_SEL(config)) + reg |= mask; + writel(reg, MPP4_CTRL); + + /* configure gpio capabilities */ + gpio = 0; + if (MPP_GPIO(config)) + gpio = GPIO_INPUT_OK | GPIO_OUTPUT_OK; + for (n = nmin; n <= nmax; n++) + dove_gpio_set_valid(n, gpio); +} + +/* + * MPP_GENERAL_CTRL allows GPIO on NAND pins + */ +static void dove_mpp_nand_set(u16 config) +{ + u32 reg = readl(MPP_GENERAL_CTRL); + u8 n; + int gpio; + + reg &= ~MPPG_NAND_GPIO_SEL; + if (config == MPP_NAND_GPO) + reg |= MPPG_NAND_GPIO_SEL; + writel(reg, MPP_GENERAL_CTRL); + + /* configure gpio capabilities */ + gpio = (config == MPP_NAND_GPO) ? GPIO_OUTPUT_OK : 0; + for (n = MPP_NAND; n <= MPP_NAND_MAX; n++) + dove_gpio_set_valid(n, gpio); +} + +/* + * Dedicated audio1 pins can carry i2s, spdif, ssp or twsi + * and gpio in various combinations + */ +#define AUDIO1_TWSI (1 << 0) +#define AUDIO1_SPDIFO (1 << 1) +#define AUDIO1_SSP (1 << 2) +#define AUDIO1_GPIO (1 << 3) + +static void dove_mpp_audio1_set(u16 config) +{ + u32 mpp4 = readl(MPP4_CTRL); + u32 sspc1 = readl(SSP_CONFIG_STATUS_1); + u32 gmpp = readl(MPP_GENERAL_CTRL); + u32 gcfg2 = readl(GENERAL_CONFIG_2); + u8 n, sel = MPP_SEL(config); + int gpio; + + gcfg2 &= ~GENERAL_TWSI_OPTION3_SEL; + gmpp &= ~MPPG_AUDIO1_SPDIFO_GPIO_SEL; + sspc1 &= ~SSP_SSP_ON_AUDIO1; + mpp4 &= ~MPP4_AUDIO1_GPIO_SEL; + if (sel & AUDIO1_TWSI) + gcfg2 |= GENERAL_TWSI_OPTION3_SEL; + if (sel & AUDIO1_SPDIFO) + gmpp |= MPPG_AUDIO1_SPDIFO_GPIO_SEL; + if (sel & AUDIO1_SSP) + sspc1 |= SSP_SSP_ON_AUDIO1; + if (sel & AUDIO1_GPIO) + mpp4 |= MPP4_AUDIO1_GPIO_SEL; + + writel(mpp4, MPP4_CTRL); + writel(sspc1, SSP_CONFIG_STATUS_1); + writel(gmpp, MPP_GENERAL_CTRL); + writel(gcfg2, GENERAL_CONFIG_2); + + /* gpio allows gpio on all audio1 mpp pins */ + gpio = 0; + if (config == MPP_AUDIO1_GPIO) + gpio = GPIO_INPUT_OK | GPIO_OUTPUT_OK; + + for (n = MPP_AUDIO1; n <= MPP_AUDIO1_MAX; n++) + dove_gpio_set_valid(n, gpio); + + switch (config) { + /* spdifo and twsi allow gpio on mpp[52:55] */ + case MPP_AUDIO1_SPDIFO: + case MPP_AUDIO1_TWSI: + dove_gpio_set_valid(52, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + dove_gpio_set_valid(53, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + dove_gpio_set_valid(54, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + dove_gpio_set_valid(55, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + break; + /* i2s and ssp allow gpio on mpp[56:57] */ + case MPP_AUDIO1_I2S: + case MPP_AUDIO1_SSP: + dove_gpio_set_valid(56, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + dove_gpio_set_valid(57, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + break; + } +} + +/* + * MPP PMU switches audio0 pins to ac97 or i2s0 + */ +static void dove_mpp_audio0_set(u16 config) +{ + /* switch i2s or ac97 to audio0 */ + u32 reg = readl(MPP_PMU_GENERAL_CTRL); + + reg &= ~PMUG_AUDIO0_AC97_SEL; + if (config == MPP_AUDIO0_AC97) + reg |= PMUG_AUDIO0_AC97_SEL; + writel(reg, MPP_PMU_GENERAL_CTRL); +} + +/* + * TWSI has 3 optional pin sets that can be switched during runtime + */ +static void dove_mpp_twsi_set(u16 config) +{ + u32 gcfg1 = readl(GENERAL_CONFIG_1); + u32 gcfg2 = readl(GENERAL_CONFIG_2); + + gcfg1 &= ~GENERAL_TWSI_MUXEN_OPTION1; + gcfg2 &= ~(GENERAL_TWSI_MUXEN_OPTION2 | GENERAL_TWSI_MUXEN_OPTION3); + + switch (config) { + case MPP_TWSI_OPTION1: + gcfg1 |= GENERAL_TWSI_MUXEN_OPTION1; + break; + case MPP_TWSI_OPTION2: + gcfg2 |= GENERAL_TWSI_MUXEN_OPTION2; + break; + case MPP_TWSI_OPTION3: + gcfg2 |= GENERAL_TWSI_MUXEN_OPTION3; + break; + } + + writel(gcfg1, GENERAL_CONFIG_1); + writel(gcfg2, GENERAL_CONFIG_2); +} + +void dove_mpp_conf(u16 *mpp_list) +{ + while (*mpp_list) { + u8 num = MPP_NUM(*mpp_list); + + if (num <= MPP_PMU_MAX) { + dove_mpp_pmu_set(*mpp_list); + } else if (num <= MPP_STD_MAX) { + dove_mpp_std_set(*mpp_list); + } else { + switch (num) { + case MPP_CAMERA: + case MPP_SDIO0: + case MPP_SDIO1: + case MPP_SPI: + case MPP_UART1: + dove_mpp4_set(*mpp_list); + break; + case MPP_NAND: + dove_mpp_nand_set(*mpp_list); + break; + case MPP_AUDIO0: + dove_mpp_audio0_set(*mpp_list); + break; + case MPP_AUDIO1: + dove_mpp_audio1_set(*mpp_list); + break; + case MPP_TWSI: + dove_mpp_twsi_set(*mpp_list); + break; + } + } + mpp_list++; + } +} diff --git a/arch/arm/cpu/armv7/dove/timer.c b/arch/arm/cpu/armv7/dove/timer.c new file mode 100644 index 0000000..3055369 --- /dev/null +++ b/arch/arm/cpu/armv7/dove/timer.c @@ -0,0 +1,176 @@ +/* + * Marvell Dove SoC timer + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/dove.h> + +#define UBOOT_CNTR 0 /* counter to use for uboot timer */ + +/* Timer reload and current value registers */ +struct dovetmr_val { + u32 reload; /* Timer reload reg */ + u32 val; /* Timer value reg */ +}; + +/* Timer registers */ +struct dovetmr_registers { + u32 ctrl; /* Timer control reg */ + u32 pad[3]; + struct dovetmr_val tmr[2]; + u32 wdt_reload; + u32 wdt_val; +}; + +struct dovetmr_registers *dovetmr_regs = + (struct dovetmr_registers *)DOVE_TIMER_BASE; + +/* + * ARM Timers Registers Map + */ +#define CNTMR_CTRL_REG &dovetmr_regs->ctrl +#define CNTMR_RELOAD_REG(tmrnum) &dovetmr_regs->tmr[tmrnum].reload +#define CNTMR_VAL_REG(tmrnum) &dovetmr_regs->tmr[tmrnum].val + +/* + * ARM Timers Control Register + * CPU_TIMERS_CTRL_REG (CTCR) + */ +#define CTCR_ARM_TIMER_EN_OFFS(cntr) (cntr * 2) +#define CTCR_ARM_TIMER_EN_MASK(cntr) (1 << CTCR_ARM_TIMER_EN_OFFS) +#define CTCR_ARM_TIMER_EN(cntr) (1 << CTCR_ARM_TIMER_EN_OFFS(cntr)) +#define CTCR_ARM_TIMER_DIS(cntr) (0 << CTCR_ARM_TIMER_EN_OFFS(cntr)) + +#define CTCR_ARM_TIMER_AUTO_OFFS(cntr) ((cntr * 2) + 1) +#define CTCR_ARM_TIMER_AUTO_MASK(cntr) (1 << 1) +#define CTCR_ARM_TIMER_AUTO_EN(cntr) (1 << CTCR_ARM_TIMER_AUTO_OFFS(cntr)) +#define CTCR_ARM_TIMER_AUTO_DIS(cntr) (0 << CTCR_ARM_TIMER_AUTO_OFFS(cntr)) + +/* + * ARM Timer\Watchdog Reload Register + * CNTMR_RELOAD_REG (TRR) + */ +#define TRG_ARM_TIMER_REL_OFFS 0 +#define TRG_ARM_TIMER_REL_MASK 0xffffffff + +/* + * ARM Timer\Watchdog Register + * CNTMR_VAL_REG (TVRG) + */ +#define TVR_ARM_TIMER_OFFS 0 +#define TVR_ARM_TIMER_MASK 0xffffffff +#define TVR_ARM_TIMER_MAX 0xffffffff +#define TIMER_LOAD_VAL 0xffffffff + +#define READ_TIMER (readl(CNTMR_VAL_REG(UBOOT_CNTR)) / \ + (CONFIG_SYS_TCLK / 1000)) + +DECLARE_GLOBAL_DATA_PTR; + +#define timestamp gd->arch.tbl +#define lastdec gd->arch.lastinc + +ulong get_timer_masked(void) +{ + ulong now = READ_TIMER; + + if (lastdec >= now) { + /* normal mode */ + timestamp += lastdec - now; + } else { + /* we have an overflow ... */ + timestamp += lastdec + + (TIMER_LOAD_VAL / (CONFIG_SYS_TCLK / 1000)) - now; + } + lastdec = now; + + return timestamp; +} + +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +void __udelay(unsigned long usec) +{ + uint current; + ulong delayticks; + + current = readl(CNTMR_VAL_REG(UBOOT_CNTR)); + delayticks = (usec * (CONFIG_SYS_TCLK / 1000000)); + + if (current < delayticks) { + delayticks -= current; + do {} while (readl(CNTMR_VAL_REG(UBOOT_CNTR)) < current); + do {} while ((TIMER_LOAD_VAL - delayticks) < + readl(CNTMR_VAL_REG(UBOOT_CNTR))); + } else { + do {} while (readl(CNTMR_VAL_REG(UBOOT_CNTR)) > + (current - delayticks)); + } +} + +/* + * init the counter + */ +int timer_init(void) +{ + unsigned int cntmrctrl; + + /* load value into timer */ + writel(TIMER_LOAD_VAL, CNTMR_RELOAD_REG(UBOOT_CNTR)); + writel(TIMER_LOAD_VAL, CNTMR_VAL_REG(UBOOT_CNTR)); + + /* enable timer in auto reload mode */ + cntmrctrl = readl(CNTMR_CTRL_REG); + cntmrctrl |= CTCR_ARM_TIMER_EN(UBOOT_CNTR); + cntmrctrl |= CTCR_ARM_TIMER_AUTO_EN(UBOOT_CNTR); + writel(cntmrctrl, CNTMR_CTRL_REG); + + /* init the timestamp and lastdec value */ + lastdec = READ_TIMER; + timestamp = 0; + + return 0; +} + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On ARM it just returns the timer value. + */ +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + return (ulong)CONFIG_SYS_HZ; +} diff --git a/arch/arm/cpu/armv7/dove/usb.c b/arch/arm/cpu/armv7/dove/usb.c new file mode 100644 index 0000000..1b932db --- /dev/null +++ b/arch/arm/cpu/armv7/dove/usb.c @@ -0,0 +1,101 @@ +/* + * Marvell Dove SoC USB PHY init + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> + +/* Dove USB2.0 PHY registers */ +#define USB20_POWER_CTRL ((base) + 0x400) +#define USB20_PHY_PLL_CTRL ((base) + 0x410) +#define PHY_PLL_VCO_RECALIBRATE (1 << 21) +#define USB20_PHY_TX_CTRL ((base) + 0x420) +#define PHY_TX_HS_STRESS_CTRL (1 << 31) +#define PHY_TX_BLOCK_EN (1 << 21) +#define PHY_TX_IMP_CAL_VTH(x) (x << 14) +#define PHY_TX_IMP_CAL_VTH_MASK PHY_TX_IMP_CAL_VTH(0x7) +#define PHY_TX_RCAL_START (1 << 12) +#define PHY_TX_LOWVDD_EN (1 << 11) +#define USB20_PHY_RX_CTRL ((base) + 0x430) +#define PHY_RX_EDGE_DET(x) (x << 26) +#define PHY_RX_EDGE_DET_MASK PHY_RX_EDGE_DET(0x3) +#define PHY_RX_CDR_FASTLOCK_EN (1 << 21) +#define PHY_RX_SQ_LENGTH(x) (x << 15) +#define PHY_RX_SQ_LENGTH_MASK PHY_RX_SQ_LENGTH(0x3) +#define PHY_RX_SQ_THRESH(x) (x << 4) +#define PHY_RX_SQ_THRESH_MASK PHY_RX_SQ_THRESH(0xf) +#define PHY_RX_LPF_COEFF(x) (x << 2) +#define PHY_RX_LPF_COEFF_MASK PHY_RX_LPF_COEFF(0x3) +#define USB20_PHY_IVREF_CTRL ((base) + 0x440) +#define PHY_IVREF_TXVDD12(x) (x << 8) +#define PHY_IVREF_TXVDD12_MASK PHY_IVREF_TXVDD12(0x3) +#define USB20_PHY_TESTGRP_CTRL ((base) + 0x450) +#define PHY_TESTGRP_SQ_RST (1 << 15) + +void dove_ehci_phy_init(int port) +{ + u32 base = (port == 0) ? DOVE_USB20_0_BASE : DOVE_USB20_1_BASE; + u32 reg; + + /* USB PHY PLL control */ + reg = readl(USB20_PHY_PLL_CTRL); + writel(reg | PHY_PLL_VCO_RECALIBRATE, USB20_PHY_PLL_CTRL); + udelay(100); + writel(reg & ~PHY_PLL_VCO_RECALIBRATE, USB20_PHY_PLL_CTRL); + + /* USB PHY Tx control */ + reg = readl(USB20_PHY_TX_CTRL); + reg &= ~PHY_TX_IMP_CAL_VTH_MASK; + reg |= PHY_TX_IMP_CAL_VTH(0x5); + reg |= PHY_TX_LOWVDD_EN; + reg |= PHY_TX_RCAL_START; + reg |= PHY_TX_BLOCK_EN; + reg |= PHY_TX_HS_STRESS_CTRL; + writel(reg, USB20_PHY_TX_CTRL); + udelay(100); + writel(reg & ~PHY_TX_RCAL_START, USB20_PHY_TX_CTRL); + + /* USB PHY RX control */ + reg = readl(USB20_PHY_RX_CTRL); + reg &= ~(PHY_RX_LPF_COEFF_MASK | PHY_RX_SQ_THRESH_MASK | + PHY_RX_SQ_LENGTH_MASK | PHY_RX_EDGE_DET_MASK); + reg |= PHY_RX_LPF_COEFF(0x1); + reg |= PHY_RX_SQ_THRESH(0xc); + reg |= PHY_RX_SQ_LENGTH(0x1); + reg |= PHY_RX_EDGE_DET(0x0); + reg &= ~PHY_RX_CDR_FASTLOCK_EN; + writel(reg, USB20_PHY_RX_CTRL); + + /* USB PHY IVREF control */ + reg = readl(USB20_PHY_IVREF_CTRL); + reg &= ~PHY_IVREF_TXVDD12_MASK; + reg |= PHY_IVREF_TXVDD12(0x3); + writel(reg, USB20_PHY_IVREF_CTRL); + + /* USB PHY TEST GROUP control */ + reg = readl(USB20_PHY_TESTGRP_CTRL); + reg &= ~PHY_TESTGRP_SQ_RST; + writel(reg, USB20_PHY_TESTGRP_CTRL); +} diff --git a/arch/arm/include/asm/arch-dove/config.h b/arch/arm/include/asm/arch-dove/config.h new file mode 100644 index 0000000..3cb71b1 --- /dev/null +++ b/arch/arm/include/asm/arch-dove/config.h @@ -0,0 +1,153 @@ +/* + * Marvell SoC config + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVE_CONFIG_H +#define _DOVE_CONFIG_H + +#include <asm/arch/dove.h> + +#define CONFIG_ARMV7 /* Basic Architecture */ +#define CONFIG_DOVE /* SOC Family Name */ +#define CONFIG_SHEEVA_88SV581 /* CPU Core subversion */ +#define CONFIG_SYS_CACHELINE_SIZE 32 + /* default Dcache Line length for Dove */ +#define CONFIG_SYS_ARM_CACHE_WRITETHROUGH +#define CONFIG_SYS_DCACHE_OFF /* Disable DCache by default */ + +/* + * By default kwbimage.cfg from board specific folder is used + * If for some board, different configuration file need to be used, + * CONFIG_SYS_KWD_CONFIG should be defined in board specific header file + */ +#ifndef CONFIG_SYS_KWD_CONFIG +#define CONFIG_SYS_KWD_CONFIG $(SRCTREE)/$(CONFIG_BOARDDIR)/kwbimage.cfg +#endif /* CONFIG_SYS_KWD_CONFIG */ + +/* Dove has 2k of Security SRAM, use it for SP */ +#define CONFIG_SYS_INIT_SP_ADDR 0xC8012000 +#define CONFIG_NR_DRAM_BANKS_MAX 2 + +#define CONFIG_I2C_MVTWSI_BASE DOVE_TWSI_BASE +#define MV_UART_CONSOLE_BASE DOVE_UART0_BASE +#define MV_SATA_BASE DOVE_SATA_BASE +#define MV_SATA_PORT0_OFFSET DOVE_SATA_PORT0_OFFSET + +/* + * NAND configuration + */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_KIRKWOOD 1 +#define CONFIG_SYS_NAND_BASE 0xD8000000 /* MV_DEFADR_NANDF */ +#define NAND_ALLOW_ERASE_ALL 1 +#endif + +/* + * SPI Flash configuration + */ +#ifdef CONFIG_CMD_SF +#define CONFIG_HARD_SPI 1 +#define CONFIG_DOVE_SPI 1 +#ifndef CONFIG_ENV_SPI_BUS +# define CONFIG_ENV_SPI_BUS 0 +#endif +#ifndef CONFIG_ENV_SPI_CS +# define CONFIG_ENV_SPI_CS 0 +#endif +#ifndef CONFIG_ENV_SPI_MAX_HZ +# define CONFIG_ENV_SPI_MAX_HZ 25000000 +#endif +#endif + +/* + * Ethernet Driver configuration + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_CMD_MII +#define CONFIG_NETCONSOLE /* include NetConsole support */ +#define CONFIG_PHYLIB +#define CONFIG_MVGBE /* Enable Marvell Gbe Controller Driver */ +#define CONFIG_SYS_FAULT_ECHO_LINK_DOWN /* detect link using phy */ +#define CONFIG_ENV_OVERWRITE /* ethaddr can be reprogrammed */ +#endif /* CONFIG_CMD_NET */ + +/* + * SDHCI + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_MMC +#define CONFIG_MMC_SDMA +#define CONFIG_SDHCI +#define CONFIG_DOVE_SDHCI /* Enable Dove SDHCI controller driver */ +#define CONFIG_MMC_SDHCI_IO_ACCESSORS +#define CONFIG_SYS_MMC_MAX_DEVICE 2 +#endif + +/* + * USB/EHCI + */ +#ifdef CONFIG_CMD_USB +#define CONFIG_USB_EHCI_MARVELL +#define CONFIG_EHCI_IS_TDI +#endif /* CONFIG_CMD_USB */ + +/* + * IDE Support on SATA ports + */ +#ifdef CONFIG_CMD_IDE +#define __io +#define CONFIG_CMD_EXT2 +#define CONFIG_MVSATA_IDE +#define CONFIG_IDE_PREINIT +#define CONFIG_MVSATA_IDE_USE_PORT1 +/* Needs byte-swapping for ATA data register */ +#define CONFIG_IDE_SWAP_IO +/* Data, registers and alternate blocks are at the same offset */ +#define CONFIG_SYS_ATA_DATA_OFFSET (0x0100) +#define CONFIG_SYS_ATA_REG_OFFSET (0x0100) +#define CONFIG_SYS_ATA_ALT_OFFSET (0x0100) +/* Each 8-bit ATA register is aligned to a 4-bytes address */ +#define CONFIG_SYS_ATA_STRIDE 4 +/* Controller supports 48-bits LBA addressing */ +#define CONFIG_LBA48 +#define CONFIG_SYS_64BIT_LBA +/* CONFIG_CMD_IDE requires some #defines for ATA registers */ +#define CONFIG_SYS_IDE_MAXBUS 2 +#define CONFIG_SYS_IDE_MAXDEVICE 2 +/* ATA registers base is at SATA controller base */ +#define CONFIG_SYS_ATA_BASE_ADDR MV_SATA_BASE +#endif /* CONFIG_CMD_IDE */ + +/* + * I2C related stuff + */ +#ifdef CONFIG_CMD_I2C +#ifndef CONFIG_SOFT_I2C +#define CONFIG_I2C_MVTWSI +#endif +#define CONFIG_SYS_I2C_SLAVE 0x0 +#define CONFIG_SYS_I2C_SPEED 100000 +#endif + +#endif /* _DOVE_CONFIG_H */ diff --git a/arch/arm/include/asm/arch-dove/cpu.h b/arch/arm/include/asm/arch-dove/cpu.h new file mode 100644 index 0000000..718dd59 --- /dev/null +++ b/arch/arm/include/asm/arch-dove/cpu.h @@ -0,0 +1,204 @@ +/* + * Marvell Dove SoC CPU + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVECPU_H +#define _DOVECPU_H + +#include <asm/system.h> + +#ifndef __ASSEMBLY__ + +#define DOVECPU_WIN_CTRL_DATA(size, target, attr, en) (en | (target << 4) \ + | (attr << 8) | (dove_winctrl_calcsize(size) << 16)) + +#define DOVEGBE_PORT_SERIAL_CONTROL1_REG (DOVE_EGIGA_BASE + 0x44c) +#define DOVE_REG_PCIE_DEVID (DOVE_REG_PCIE0_BASE + 0x00) +#define DOVE_REG_PCIE_REVID (DOVE_REG_PCIE0_BASE + 0x08) +#define DOVE_REG_SYSRST_CNT (DOVE_MPP_BASE + 0x50) +#define SYSRST_CNT_1SEC_VAL (25*1000000) +#define DOVE_REG_MPP_OUT_DRV_REG (DOVE_MPP_BASE + 0xE0) + +enum memory_bank { + BANK0, + BANK1, +}; + +enum dovecpu_winen { + DOVECPU_WIN_DISABLE, + DOVECPU_WIN_ENABLE +}; + +enum dovecpu_target { + DOVECPU_TARGET_DRAM = 0x0, + DOVECPU_TARGET_SASRAM = 0x3, + DOVECPU_TARGET_NAND = 0xc, + DOVECPU_TARGET_PMURAM = 0xd, + DOVECPU_TARGET_PCIE0 = 0x4, + DOVECPU_TARGET_PCIE1 = 0x8, + DOVECPU_TARGET_SPI = 0x1, + DOVECPU_TARGET_BOOTROM = 0x1, +}; + +enum dovecpu_attrib { + DOVECPU_ATTR_DRAM = 0x00, + DOVECPU_ATTR_SASRAM = 0x00, + DOVECPU_ATTR_NAND = 0x00, + DOVECPU_ATTR_PMURAM = 0x00, + DOVECPU_ATTR_PCIE_IO = 0xe0, + DOVECPU_ATTR_PCIE_MEM = 0xe8, + DOVECPU_ATTR_SPI0 = 0xfe, + DOVECPU_ATTR_SPI1 = 0xfb, + DOVECPU_ATTR_BOOTROM = 0xfd, +}; + +enum dovecpu_part { + DOVECPU_PART_SHEEVA = 0x581, +}; + +enum dovesoc_devid { + DOVESOC_DEVID_F6781 = 0x6781, + DOVESOC_DEVID_AP510 = 0x0510, +}; + +enum dovesoc_revid { + DOVESOC_REVID_Z0 = 0, + DOVESOC_REVID_Z1 = 1, + DOVESOC_REVID_Y0 = 2, + DOVESOC_REVID_Y1 = 3, + DOVESOC_REVID_X0 = 4, + DOVESOC_REVID_A0 = 6, + DOVESOC_REVID_A1 = 7, +}; + +/* + * Default Device Address MAP BAR values + */ +#define DOVE_DEFADR_PCIE0_MEM 0xe0000000 +#define DOVE_DEFADR_PCIE0_IO 0xf2000000 +#define DOVE_DEFADR_PCIE0_IO_REMAP 0x00000000 +#define DOVE_DEFADR_PCIE1_MEM 0xe8000000 +#define DOVE_DEFADR_PCIE1_IO 0xf2100000 +#define DOVE_DEFADR_PCIE1_IO_REMAP 0x00100000 +#define DOVE_DEFADR_SASRAM 0xc8000000 +#define DOVE_DEFADR_BOOTROM 0xf8000000 +#define DOVE_DEFADR_PMURAM 0xf0000000 + +/* + * ARM CPUID register + */ +#define ARM_ID_REVISION_OFFSET 0 +#define ARM_ID_REVISION_MASK 0xf +#define ARM_ID_PARTNUM_OFFSET 4 +#define ARM_ID_PARTNUM_MASK 0xfff +#define ARM_ID_ARCH_OFFSET 16 +#define ARM_ID_ARCH_MASK 0xf +#define ARM_ID_VAR_OFFSET 20 +#define ARM_ID_VAR_MASK 0xf +#define ARM_ID_ASCII_OFFSET 24 +#define ARM_ID_ASCII_MASK 0xff + +/* + * read feroceon/sheeva core extra feature register + * using co-proc instruction + */ +static inline unsigned int readfr_extra_feature_reg(void) +{ + unsigned int val; + asm volatile ("mrc p15, 1, %0, c15, c1, 0 @ readfr exfr" : "=r" + (val) : : "cc"); + return val; +} + +/* + * write feroceon/sheeva core extra feature register + * using co-proc instruction + */ +static inline void writefr_extra_feature_reg(unsigned int val) +{ + asm volatile ("mcr p15, 1, %0, c15, c1, 0 @ writefr exfr" : : "r" + (val) : "cc"); + isb(); +} + +/* + * Downstream Bridge Registers + */ +struct dovewin_registers { + u32 ctrl; + u32 base; + u32 remap_lo; + u32 remap_hi; +}; + +/* + * CPU control and status Registers + */ +struct dovecpu_registers { + u32 config; /* 0x20100 */ + u32 ctrl_stat; /* 0x20104 */ + u32 rstoutn_mask; /* 0x20108 */ + u32 sys_soft_rst; /* 0x2010C */ + u32 bridge_cause_irq; /* 0x20110 */ + u32 bridge_mask_irq; /* 0x20114 */ + u32 pad1; + u32 pmu_ctrl; /* 0x2011c */ +}; + +/* + * GPIO 0/1 Registers + * GPIO 2 Registers (no datain/irq) + */ +struct dovegpio_registers { + u32 dout; + u32 oe; + u32 blink_en; + u32 din_pol; + u32 din; + u32 irq_cause; + u32 irq_mask; + u32 irq_level; +}; + +struct dove_gpio_init { + u32 val0; + u32 val1; + u32 val2; + u32 oe0_n; + u32 oe1_n; + u32 oe2_n; +}; + +/* + * functions + */ +void reset_cpu(unsigned long ignored); +unsigned char get_random_hex(void); +u32 dove_dram_start(enum memory_bank bank); +u32 dove_dram_size(enum memory_bank bank); +int dove_config_adr_windows(void); +void dove_init_gpio(struct dove_gpio_init *); +unsigned int dove_winctrl_calcsize(unsigned int sizeval); + +#endif /* __ASSEMBLY__ */ +#endif /* _DOVECPU_H */ diff --git a/arch/arm/include/asm/arch-dove/dove.h b/arch/arm/include/asm/arch-dove/dove.h new file mode 100644 index 0000000..f310719 --- /dev/null +++ b/arch/arm/include/asm/arch-dove/dove.h @@ -0,0 +1,98 @@ +/* + * Marvell Dove SoC register offsets and config + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVE_H +#define _DOVE_H + +/* Dove TCLK is fixed to 166MHz */ +#define CONFIG_SYS_TCLK 166666667 + +/* SOC specific definitions */ +#define DOVE_PREMAP_REGS_PHYS_BASE 0xd0000000 +#define DOVE_PREMAP_INT_REGS_BASE_ADDR (DOVE_PREMAP_REGS_PHYS_BASE + 0x20080) +#define DOVE_PREMAP_MC_DECODE_REG (DOVE_PREMAP_REGS_PHYS_BASE + 0x800010) + +#define DOVE_SB_REGS_PHYS_BASE 0xf1000000 +#define DOVE_NB_REGS_PHYS_BASE 0xf1800000 +#define DOVE_REGISTER(x) (DOVE_SB_REGS_PHYS_BASE + x) + +#define DOVE_AXI_CTRL_REG (DOVE_REGISTER(0xd0224)) +#define DOVE_CPU_CTRL_REG (DOVE_REGISTER(0xd025c)) +#define DOVE_MC_CTRL_REG (DOVE_REGISTER(0xd0260)) +#define DOVE_MC_DECODE_REG (DOVE_REGISTER(0x800010)) + +#define DOVE_SPI_BASE (DOVE_REGISTER(0x10600)) +#define DOVE_TWSI_BASE (DOVE_REGISTER(0x11000)) +#define DOVE_UART0_BASE (DOVE_REGISTER(0x12000)) +#define DOVE_UART1_BASE (DOVE_REGISTER(0x12100)) +#define DOVE_UART2_BASE (DOVE_REGISTER(0x12200)) +#define DOVE_UART3_BASE (DOVE_REGISTER(0x12300)) +#define DOVE_CPU_WIN_BASE (DOVE_REGISTER(0x20000)) +#define DOVE_CPU_REG_BASE (DOVE_REGISTER(0x20100)) +#define DOVE_TIMER_BASE (DOVE_REGISTER(0x20300)) +#define DOVE_REG_PCIE0_BASE (DOVE_REGISTER(0x40000)) +#define DOVE_REG_PCIE1_BASE (DOVE_REGISTER(0x80000)) +#define DOVE_USB20_0_BASE (DOVE_REGISTER(0x50000)) +#define DOVE_USB20_1_BASE (DOVE_REGISTER(0x51000)) +#define DOVE_EGIGA_BASE (DOVE_REGISTER(0x72000)) +#define DOVE_SDIO1_BASE (DOVE_REGISTER(0x90000)) +#define DOVE_SDIO0_BASE (DOVE_REGISTER(0x92000)) +#define DOVE_CAMERA_BASE (DOVE_REGISTER(0x94000)) +#define DOVE_SATA_BASE (DOVE_REGISTER(0xa0000)) +#define DOVE_NANDF_BASE (DOVE_REGISTER(0xc0000)) +#define DOVE_PMU_BASE (DOVE_REGISTER(0xd0000)) +#define DOVE_MPP_BASE (DOVE_REGISTER(0xd0200)) +#define DOVE_GPIO0_BASE (DOVE_REGISTER(0xd0400)) +#define DOVE_GPIO1_BASE (DOVE_REGISTER(0xd0420)) +#define DOVE_RTC_BASE (DOVE_REGISTER(0xd8500)) +#define DOVE_AC97_BASE (DOVE_REGISTER(0xe0000)) +#define DOVE_PDMA_BASE (DOVE_REGISTER(0xe4000)) +#define DOVE_GPIO2_BASE (DOVE_REGISTER(0xe8400)) +#define DOVE_SSP_BASE (DOVE_REGISTER(0xec000)) + +/* Dove Sata controller has one port */ +#define DOVE_SATA_PORT0_OFFSET 0x2000 + +/* Dove GbE controller has one port */ +#define MAX_MVGBE_DEVS 1 +#define MVGBE0_BASE DOVE_EGIGA_BASE + +/* Dove USB Host controller */ +#define MVUSB0_BASE DOVE_USB20_0_BASE +#define MVUSB0_CPU_ATTR_DRAM_CS0 DOVECPU_ATTR_DRAM +#define MVUSB0_CPU_ATTR_DRAM_CS1 DOVECPU_ATTR_DRAM +#define MVUSB0_CPU_ATTR_DRAM_CS2 DOVECPU_WIN_DISABLE +#define MVUSB0_CPU_ATTR_DRAM_CS3 DOVECPU_WIN_DISABLE +#define MVUSB1_BASE DOVE_USB20_1_BASE +#define MVUSB1_CPU_ATTR_DRAM_CS0 DOVECPU_ATTR_DRAM +#define MVUSB1_CPU_ATTR_DRAM_CS1 DOVECPU_ATTR_DRAM +#define MVUSB1_CPU_ATTR_DRAM_CS2 DOVECPU_WIN_DISABLE +#define MVUSB1_CPU_ATTR_DRAM_CS3 DOVECPU_WIN_DISABLE + +/* Dove CPU memory windows */ +#define MVCPU_WIN_CTRL_DATA DOVECPU_WIN_CTRL_DATA +#define MVCPU_WIN_ENABLE DOVECPU_WIN_ENABLE +#define MVCPU_WIN_DISABLE DOVECPU_WIN_DISABLE + +#endif diff --git a/arch/arm/include/asm/arch-dove/gpio.h b/arch/arm/include/asm/arch-dove/gpio.h new file mode 100644 index 0000000..363d7d2 --- /dev/null +++ b/arch/arm/include/asm/arch-dove/gpio.h @@ -0,0 +1,35 @@ +/* + * Marvell Dove SoC gpio + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef __ARCH_DOVE_GPIO_H +#define __ARCH_DOVE_GPIO_H + +#include <dove_gpio.h> + +#define GPIO_MAX 70 +#define GPIO_BASE(pin) (((pin) >= 64) ? DOVE_GPIO2_BASE : \ + ((pin) >= 32) ? DOVE_GPIO1_BASE : \ + DOVE_GPIO0_BASE) + +#endif diff --git a/arch/arm/include/asm/arch-dove/mpp.h b/arch/arm/include/asm/arch-dove/mpp.h new file mode 100644 index 0000000..1279ac2 --- /dev/null +++ b/arch/arm/include/asm/arch-dove/mpp.h @@ -0,0 +1,283 @@ +/* + * Marvell Dove SoC pinmux + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVE_MPP_H +#define _DOVE_MPP_H + +#define DOVE_GPI (1 << 0) +#define DOVE_GPO (1 << 1) +#define DOVE_GPIO (DOVE_GPO | DOVE_GPI) + +#define MPP(_num, _sel, _gpio) ( \ + /* MPP number */ ((_num) & 0xff) | \ + /* MPP select value */ (((_sel) & 0x1f) << 8) | \ + /* is gpio config */ ((!!(_gpio)) << 15)) + +/* MPP0-15 allow PMU function */ +#define MPP_PMU_MAX 15 +#define PMU (0x10) +/* MPP0-23 have standard mpp register layout */ +#define MPP_STD_MAX 23 + +#define MPP0 0 +#define MPP0_GPIO MPP(0, 0x0, 1) +#define MPP0_UART2_RTS MPP(0, 0x2, 0) +#define MPP0_SDIO0_CD MPP(0, 0x3, 0) +#define MPP0_LCD0_PWM MPP(0, 0xf, 0) +#define MPP0_PMU MPP(0, PMU, 0) + +#define MPP1 1 +#define MPP1_GPIO MPP(1, 0x0, 1) +#define MPP1_UART2_CTS MPP(1, 0x2, 0) +#define MPP1_SDIO0_WP MPP(1, 0x3, 0) +#define MPP1_LCD1_PWM MPP(1, 0xf, 0) +#define MPP1_PMU MPP(1, PMU, 0) + +#define MPP2 2 +#define MPP2_GPIO MPP(2, 0x0, 1) +#define MPP2_SATA_PRSNT MPP(2, 0x1, 0) +#define MPP2_UART2_TXD MPP(2, 0x2, 0) +#define MPP2_SDIO0_BUSPWR MPP(2, 0x3, 0) +#define MPP2_UART1_RTS MPP(2, 0x4, 0) +#define MPP2_PMU MPP(2, PMU, 0) + +#define MPP3 3 +#define MPP3_GPIO MPP(3, 0x0, 1) +#define MPP3_SATA_ACT MPP(3, 0x1, 0) +#define MPP3_UART2_RXD MPP(3, 0x2, 0) +#define MPP3_SDIO0_LEDCTRL MPP(3, 0x3, 0) +#define MPP3_UART1_CTS MPP(3, 0x4, 0) +#define MPP3_LCD_SPI_CS1 MPP(3, 0xf, 0) +#define MPP3_PMU MPP(3, PMU, 0) + +#define MPP4 4 +#define MPP4_GPIO MPP(4, 0x0, 1) +#define MPP4_UART3_RTS MPP(4, 0x2, 0) +#define MPP4_SDIO1_CD MPP(4, 0x3, 0) +#define MPP4_SPI1_MISO MPP(4, 0x4, 0) +#define MPP4_PMU MPP(4, PMU, 0) + +#define MPP5 5 +#define MPP5_GPIO MPP(5, 0x0, 1) +#define MPP5_UART3_CTS MPP(5, 0x2, 0) +#define MPP5_SDIO1_WP MPP(5, 0x3, 0) +#define MPP5_SPI1_CS MPP(5, 0x4, 0) +#define MPP5_PMU MPP(5, PMU, 0) + +#define MPP6 6 +#define MPP6_GPIO MPP(6, 0x0, 1) +#define MPP6_UART3_TXD MPP(6, 0x2, 0) +#define MPP6_SDIO1_BUSPWR MPP(6, 0x3, 0) +#define MPP6_SPI1_MOSI MPP(6, 0x4, 0) +#define MPP6_PMU MPP(6, PMU, 0) + +#define MPP7 7 +#define MPP7_GPIO MPP(7, 0x0, 1) +#define MPP7_UART3_RXD MPP(7, 0x2, 0) +#define MPP7_SDIO1_LEDCTRL MPP(7, 0x3, 0) +#define MPP7_SPI1_SCK MPP(7, 0x4, 0) +#define MPP7_PMU MPP(7, PMU, 0) + +#define MPP8 8 +#define MPP8_GPIO MPP(8, 0x0, 1) +#define MPP8_WATCHDOG_RSTOUT MPP(8, 0x1, 0) +#define MPP8_PMU MPP(8, PMU, 0) + +#define MPP9 9 +#define MPP9_GPIO MPP(9, 0x0, 1) +#define MPP9_PEX1_CLKREQ MPP(9, 0x5, 0) +#define MPP9_PMU MPP(9, PMU, 0) + +#define MPP10 10 +#define MPP10_GPIO MPP(10, 0x0, 1) +#define MPP10_SSP_SCLK MPP(10, 0x5, 0) +#define MPP10_PMU MPP(10, PMU, 0) + +#define MPP11 11 +#define MPP11_GPIO MPP(11, 0x0, 1) +#define MPP11_SATA_PRSNT MPP(11, 0x1, 0) +#define MPP11_SATA_ACT MPP(11, 0x2, 0) +#define MPP11_SDIO0_LEDCTRL MPP(11, 0x3, 0) +#define MPP11_SDIO1_LEDCTRL MPP(11, 0x4, 0) +#define MPP11_PEX0_CLKREQ MPP(11, 0x5, 0) +#define MPP11_PMU MPP(11, PMU, 0) + +#define MPP12 12 +#define MPP12_GPIO MPP(12, 0x0, 1) +#define MPP12_SATA_ACT MPP(12, 0x1, 0) +#define MPP12_UART2_RTS MPP(12, 0x2, 0) +#define MPP12_AUDIO0_EXTCLK MPP(12, 0x3, 0) +#define MPP12_SDIO1_CD MPP(12, 0x4, 0) +#define MPP12_PMU MPP(12, PMU, 0) + +#define MPP13 13 +#define MPP13_GPIO MPP(13, 0x0, 1) +#define MPP13_UART2_CTS MPP(13, 0x2, 0) +#define MPP13_AUDIO1_EXTCLK MPP(13, 0x3, 0) +#define MPP13_SDIO1_WP MPP(13, 0x4, 0) +#define MPP13_SSP_EXTCLK MPP(13, 0x5, 0) +#define MPP13_PMU MPP(13, PMU, 0) + +#define MPP14 14 +#define MPP14_GPIO MPP(14, 0x0, 1) +#define MPP14_UART2_TXD MPP(14, 0x2, 0) +#define MPP14_SDIO1_BUSPWR MPP(14, 0x4, 0) +#define MPP14_SSP_TXD MPP(14, 0x5, 0) +#define MPP14_PMU MPP(14, PMU, 0) + +#define MPP15 15 +#define MPP15_GPIO MPP(15, 0x0, 1) +#define MPP15_UART2_RXD MPP(15, 0x2, 0) +#define MPP15_SDIO1_LEDCTRL MPP(15, 0x4, 0) +#define MPP15_SSP_SFRM MPP(15, 0x5, 0) +#define MPP15_PMU MPP(15, PMU, 0) + +#define MPP16 16 +#define MPP16_GPIO MPP(16, 0x0, 1) +#define MPP16_UART3_RTS MPP(16, 0x2, 0) +#define MPP16_SDIO0_CD MPP(16, 0x3, 0) +#define MPP16_LCD_SPI_CS1 MPP(16, 0x4, 0) +#define MPP16_AC97_SDI1 MPP(16, 0x5, 0) + +#define MPP17 17 +#define MPP17_GPIO MPP(17, 0x0, 1) +#define MPP17_AC97_SYSCLKO MPP(17, 0x1, 0) +#define MPP17_UART3_CTS MPP(17, 0x2, 0) +#define MPP17_SDIO0_WP MPP(17, 0x3, 0) +#define MPP17_TWSI_SDA MPP(17, 0x4, 0) +#define MPP17_AC97_SDI2 MPP(17, 0x5, 0) + +#define MPP18 18 +#define MPP18_GPIO MPP(18, 0x0, 1) +#define MPP18_UART3_TXD MPP(18, 0x2, 0) +#define MPP18_SDIO0_BUSPWR MPP(18, 0x3, 0) +#define MPP18_LCD0_PWM MPP(18, 0x4, 0) +#define MPP18_AC97_SDI3 MPP(18, 0x5, 0) + +#define MPP19 19 +#define MPP19_GPIO MPP(19, 0x0, 1) +#define MPP19_UART3_RXD MPP(19, 0x2, 0) +#define MPP19_SDIO0_LEDCTRL MPP(19, 0x3, 0) +#define MPP19_TWSI_SCK MPP(19, 0x4, 0) + +#define MPP20 20 +#define MPP20_GPIO MPP(20, 0x0, 1) +#define MPP20_AC97_SYSCLKO MPP(20, 0x1, 0) +#define MPP20_LCD_SPI_MISO MPP(20, 0x2, 0) +#define MPP20_SDIO1_CD MPP(20, 0x3, 0) +#define MPP20_SDIO0_CD MPP(20, 0x5, 0) +#define MPP20_SPI1_MISO MPP(20, 0x6, 0) + +#define MPP21 21 +#define MPP21_GPIO MPP(21, 0x0, 1) +#define MPP21_UART1_RTS MPP(21, 0x1, 0) +#define MPP21_LCD_SPI_CS0 MPP(21, 0x2, 0) +#define MPP21_SDIO1_WP MPP(21, 0x3, 0) +#define MPP21_SSP_SFRM MPP(21, 0x4, 0) +#define MPP21_SDIO0_WP MPP(21, 0x5, 0) +#define MPP21_SPI1_CS MPP(21, 0x6, 0) + +#define MPP22 22 +#define MPP22_GPIO MPP(22, 0x0, 1) +#define MPP22_UART1_CTS MPP(22, 0x1, 0) +#define MPP22_LCD_SPI_MOSI MPP(22, 0x2, 0) +#define MPP22_SDIO1_BUSPWR MPP(22, 0x3, 0) +#define MPP22_SSP_TXD MPP(22, 0x4, 0) +#define MPP22_SDIO0_BUSPWR MPP(22, 0x5, 0) +#define MPP22_SPI1_MOSI MPP(22, 0x6, 0) + +#define MPP23 23 +#define MPP23_GPIO MPP(23, 0x0, 1) +#define MPP23_LCD_SPI_SCK MPP(23, 0x2, 0) +#define MPP23_SDIO1_LEDCTRL MPP(23, 0x3, 0) +#define MPP23_SSP_SCLK MPP(23, 0x4, 0) +#define MPP23_SDIO0_LEDCTRL MPP(23, 0x5, 0) +#define MPP23_SPI1_SCK MPP(23, 0x6, 0) + +/* MPP_CAMERA = MPP[24:39] */ +#define MPP_CAMERA 24 +#define MPP_CAMERA_CAMERA MPP(24, 0x0, 0) +#define MPP_CAMERA_GPIO MPP(24, 0x1, 1) +#define MPP_CAMERA_MAX 39 + +/* MPP_SDIO0 = MPP[40:45] */ +#define MPP_SDIO0 40 +#define MPP_SDIO0_SDIO MPP(40, 0x0, 0) +#define MPP_SDIO0_GPIO MPP(40, 0x1, 1) +#define MPP_SDIO0_MAX 45 + +/* MPP_SDIO1 = MPP[46:51] */ +#define MPP_SDIO1 46 +#define MPP_SDIO1_SDIO MPP(46, 0x0, 0) +#define MPP_SDIO1_GPIO MPP(46, 0x1, 1) +#define MPP_SDIO1_MAX 51 + +/* MPP_AUDIO1 = MPP[52:57] */ +#define MPP_AUDIO1 52 +#define MPP_AUDIO1_I2S_SPDIFO MPP(52, 0x0, 0) +#define MPP_AUDIO1_I2S MPP(52, 0x2, 0) +#define MPP_AUDIO1_SPDIFO MPP(52, 0x8, 0) +#define MPP_AUDIO1_GPIO MPP(52, 0xa, 1) +#define MPP_AUDIO1_TWSI MPP(52, 0xb, 0) +#define MPP_AUDIO1_SSP_SPDIFO MPP(52, 0xc, 0) +#define MPP_AUDIO1_SSP MPP(52, 0xe, 0) +#define MPP_AUDIO1_SSP_TWSI MPP(52, 0xf, 0) +#define MPP_AUDIO1_MAX 57 + +/* MPP_SPI = MPP[58:61] */ +#define MPP_SPI 58 +#define MPP_SPI_SPI MPP(58, 0x0, 0) +#define MPP_SPI_GPIO MPP(58, 0x1, 1) +#define MPP_SPI_MAX 61 + +/* MPP_UART1 = MPP[62:63] */ +#define MPP_UART1 62 +#define MPP_UART1_UART1 MPP(62, 0x0, 0) +#define MPP_UART1_GPIO MPP(62, 0x1, 1) +#define MPP_UART1_MAX 63 + +/* MPP_NAND = MPP[64:71] */ +#define MPP_NAND 64 +#define MPP_NAND_NAND MPP(64, 0x0, 0) +#define MPP_NAND_GPO MPP(64, 0x1, 1) +#define MPP_NAND_MAX 71 + +/* MPP_AUDIO0 = Internal AC97/I2S mux for audio0 pins */ +#define MPP_AUDIO0 72 +#define MPP_AUDIO0_I2S MPP(72, 0x0, 0) +#define MPP_AUDIO0_AC97 MPP(72, 0x1, 0) + +/* MPP_TWSI = Internal TWSI option mux */ +#define MPP_TWSI 73 +#define MPP_TWSI_NONE MPP(73, 0x0, 0) +#define MPP_TWSI_OPTION1 MPP(73, 0x1, 0) +#define MPP_TWSI_OPTION2 MPP(73, 0x2, 0) +#define MPP_TWSI_OPTION3 MPP(73, 0x3, 0) + +#define MPP_MAX MPP_TWSI + +u8 dove_mpp_get_gpio_caps(u8 num); +void dove_mpp_conf(u16 *mpp_list); + +#endif diff --git a/arch/arm/include/asm/arch-dove/usb.h b/arch/arm/include/asm/arch-dove/usb.h new file mode 100644 index 0000000..f288489 --- /dev/null +++ b/arch/arm/include/asm/arch-dove/usb.h @@ -0,0 +1,27 @@ +/* + * Marvell Dove SoC USB + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVEUSB_H +#define _DOVEUSB_H + +void dove_ehci_phy_init(int port); +#endif /* _DOVEUSB_H */
Marvell 88AP510 (Armada 510, dove) has two separate USB controllers. Use the index parameter that already gets passed in to calculate the base address of the controller.
Signed-off-by: Sascha Silbe t-uboot@infra-silbe.de --- v3->v4: new patch
drivers/usb/host/ehci-marvell.c | 35 ++++++++++++++++++++++++----------- 1 file changed, 24 insertions(+), 11 deletions(-)
diff --git a/drivers/usb/host/ehci-marvell.c b/drivers/usb/host/ehci-marvell.c index 2b73e4a..d2cf026 100644 --- a/drivers/usb/host/ehci-marvell.c +++ b/drivers/usb/host/ehci-marvell.c @@ -28,7 +28,9 @@ #include "ehci.h" #include <asm/arch/cpu.h>
-#if defined(CONFIG_KIRKWOOD) +#if defined(CONFIG_DOVE) +#include <asm/arch/dove.h> +#elif defined(CONFIG_KIRKWOOD) #include <asm/arch/kirkwood.h> #elif defined(CONFIG_ORION5X) #include <asm/arch/orion5x.h> @@ -36,8 +38,8 @@
-#define rdl(off) readl(MVUSB0_BASE + (off)) -#define wrl(off, val) writel((val), MVUSB0_BASE + (off)) +#define rdl(base, off) readl((base) + (off)) +#define wrl(base, off, val) writel((val), (base) + (off))
#define USB_WINDOW_CTRL(i) (0x320 + ((i) << 4)) #define USB_WINDOW_BASE(i) (0x324 + ((i) << 4)) @@ -46,10 +48,15 @@ DECLARE_GLOBAL_DATA_PTR; /* * USB 2.0 Bridge Address Decoding registers setup */ -static void usb_brg_adrdec_setup(void) +static void usb_brg_adrdec_setup(int index) { int i; u32 size, base, attrib; +#ifdef MVUSB1_BASE + u32 usb_base = (index == 0) ? MVUSB0_BASE : MVUSB1_BASE; +#else + u32 usb_base = MVUSB0_BASE; +#endif
@@ -76,13 +83,13 @@ static void usb_brg_adrdec_setup(void) size = gd->bd->bi_dram[i].size; base = gd->bd->bi_dram[i].start; if ((size) && (attrib)) - wrl(USB_WINDOW_CTRL(i), - MVCPU_WIN_CTRL_DATA(size, USB_TARGET_DRAM, - attrib, MVCPU_WIN_ENABLE)); + wrl(usb_base, USB_WINDOW_CTRL(i), + MVCPU_WIN_CTRL_DATA(size, USB_TARGET_DRAM, + attrib, MVCPU_WIN_ENABLE)); else - wrl(USB_WINDOW_CTRL(i), MVCPU_WIN_DISABLE); + wrl(usb_base, USB_WINDOW_CTRL(i), MVCPU_WIN_DISABLE);
- wrl(USB_WINDOW_BASE(i), base); + wrl(usb_base, USB_WINDOW_BASE(i), base); } }
@@ -92,9 +99,15 @@ static void usb_brg_adrdec_setup(void) */ int ehci_hcd_init(int index, struct ehci_hccr **hccr, struct ehci_hcor **hcor) { - usb_brg_adrdec_setup(); +#ifdef MVUSB1_BASE + u32 usb_base = (index == 0) ? MVUSB0_BASE : MVUSB1_BASE; +#else + u32 usb_base = MVUSB0_BASE; +#endif
- *hccr = (struct ehci_hccr *)(MVUSB0_BASE + 0x100); + usb_brg_adrdec_setup(index); + + *hccr = (struct ehci_hccr *)(usb_base + 0x100); *hcor = (struct ehci_hcor *)((uint32_t) *hccr + HC_LENGTH(ehci_readl(&(*hccr)->cr_capbase)));
From: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com
This adds a gpio driver for Marvell Dove SoCs. It is based on kw_gpio; but as gpio capabilities depend heavily on the mpp configuration for dove, it allows to set gpi/gpo capabilities from mpp.
While it's currently targeted at Dove SoCs only, the driver should in large parts be compatible with orion5x and kirkwood. As a future clean-up step, the MPP and GPIO code for the three platforms could be merged.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Signed-off-by: Sascha Silbe t-uboot@infra-silbe.de --- v3->v4: renamed to dove_gpio, adjusted description
drivers/gpio/Makefile | 1 + drivers/gpio/dove_gpio.c | 167 +++++++++++++++++++++++++++++++++++++++++++++++ include/dove_gpio.h | 64 ++++++++++++++++++ 3 files changed, 232 insertions(+) create mode 100644 drivers/gpio/dove_gpio.c create mode 100644 include/dove_gpio.h
diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 830e8e6..6d44bfd 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -26,6 +26,7 @@ include $(TOPDIR)/config.mk LIB := $(obj)libgpio.o
COBJS-$(CONFIG_AT91_GPIO) += at91_gpio.o +COBJS-$(CONFIG_DOVE_GPIO) += dove_gpio.o COBJS-$(CONFIG_INTEL_ICH6_GPIO) += intel_ich6_gpio.o COBJS-$(CONFIG_KIRKWOOD_GPIO) += kw_gpio.o COBJS-$(CONFIG_MARVELL_GPIO) += mvgpio.o diff --git a/drivers/gpio/dove_gpio.c b/drivers/gpio/dove_gpio.c new file mode 100644 index 0000000..d16e641 --- /dev/null +++ b/drivers/gpio/dove_gpio.c @@ -0,0 +1,167 @@ +/* + * Marvell Dove SoC GPIO handling. + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * Based on (mostly copied from) plat-orion based Linux 2.6 kernel driver. + * Removed orion_gpiochip struct and kernel level irq handling. + * Dieter Kiermaier dk-arm-linux@gmx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <asm/bitops.h> +#include <asm/io.h> +#include <asm/arch/gpio.h> +#include <dove_gpio.h> + +static unsigned long gpio_valid_input[BITS_TO_LONGS(GPIO_MAX)]; +static unsigned long gpio_valid_output[BITS_TO_LONGS(GPIO_MAX)]; + +void __set_direction(unsigned pin, int input) +{ + u32 base = GPIO_BASE(pin); + u32 u; + + u = readl(GPIO_IO_CONF(base)); + if (input) + u |= 1 << (pin & 31); + else + u &= ~(1 << (pin & 31)); + writel(u, GPIO_IO_CONF(base)); + + u = readl(GPIO_IO_CONF(base)); +} + +void __set_level(unsigned pin, int high) +{ + u32 base = GPIO_BASE(pin); + u32 u; + + u = readl(GPIO_OUT(base)); + if (high) + u |= 1 << (pin & 31); + else + u &= ~(1 << (pin & 31)); + writel(u, GPIO_OUT(base)); +} + +void __set_blinking(unsigned pin, int blink) +{ + u32 base = GPIO_BASE(pin); + u32 u; + + u = readl(GPIO_BLINK_EN(base)); + if (blink) + u |= 1 << (pin & 31); + else + u &= ~(1 << (pin & 31)); + writel(u, GPIO_BLINK_EN(base)); +} + +int dove_gpio_is_valid(unsigned pin, int mode) +{ + if (pin < GPIO_MAX) { + if ((mode & GPIO_INPUT_OK) && + !test_bit(pin, gpio_valid_input)) + goto err_out; + + if ((mode & GPIO_OUTPUT_OK) && + !test_bit(pin, gpio_valid_output)) + goto err_out; + return 0; + } + +err_out: + printf("%s: invalid GPIO %d/%d\n", __func__, pin, GPIO_MAX); + return 1; +} + +void dove_gpio_set_valid(unsigned pin, int mode) +{ + if (mode & GPIO_INPUT_OK) + __set_bit(pin, gpio_valid_input); + else + __clear_bit(pin, gpio_valid_input); + if (mode & GPIO_OUTPUT_OK) + __set_bit(pin, gpio_valid_output); + else + __clear_bit(pin, gpio_valid_output); +} + +/* + * GENERIC_GPIO primitives. + */ +int dove_gpio_direction_input(unsigned pin) +{ + if (dove_gpio_is_valid(pin, GPIO_INPUT_OK) != 0) + return 1; + + /* Configure GPIO direction. */ + __set_direction(pin, 1); + + return 0; +} + +int dove_gpio_direction_output(unsigned pin, int value) +{ + if (dove_gpio_is_valid(pin, GPIO_OUTPUT_OK) != 0) { + printf("%s: invalid GPIO %d\n", __func__, pin); + return 1; + } + + __set_blinking(pin, 0); + + /* Configure GPIO output value. */ + __set_level(pin, value); + + /* Configure GPIO direction. */ + __set_direction(pin, 0); + + return 0; +} + +int dove_gpio_get_value(unsigned pin) +{ + u32 base = GPIO_BASE(pin); + int val; + + if (readl(GPIO_IO_CONF(base)) & (1 << (pin & 31))) + val = readl(GPIO_DATA_IN(base)) ^ readl(GPIO_IN_POL(base)); + else + val = readl(GPIO_OUT(base)); + + return (val >> (pin & 31)) & 1; +} + +void dove_gpio_set_value(unsigned pin, int value) +{ + /* Configure GPIO output value. */ + __set_level(pin, value); +} + +void dove_gpio_set_blink(unsigned pin, int blink) +{ + /* Set output value to zero. */ + __set_level(pin, 0); + + /* Set blinking. */ + __set_blinking(pin, blink); +} diff --git a/include/dove_gpio.h b/include/dove_gpio.h new file mode 100644 index 0000000..ab356bc --- /dev/null +++ b/include/dove_gpio.h @@ -0,0 +1,64 @@ +/* + * Marvell Dove SoCs common gpio + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef __DOVE_GPIO_H +#define __DOVE_GPIO_H + +/* + * SoC-specific gpio.h defines + * GPIO_MAX and GPIO_BASE(pin) macro + */ + +#define GPIO_INPUT_OK (1 << 0) +#define GPIO_OUTPUT_OK (1 << 1) +#define GPIO_LOW 0 +#define GPIO_HIGH 1 + +/* got from kernel include/linux/bitops.h */ +#define BITS_PER_BYTE 8 +#define BITS_TO_LONGS(nr) DIV_ROUND_UP(nr, BITS_PER_BYTE * sizeof(long)) + +#define GPIO_OUT(base) ((base) + 0x00) +#define GPIO_IO_CONF(base) ((base) + 0x04) +#define GPIO_BLINK_EN(base) ((base) + 0x08) +#define GPIO_IN_POL(base) ((base) + 0x0c) +#define GPIO_DATA_IN(base) ((base) + 0x10) +#define GPIO_EDGE_CAUSE(base) ((base) + 0x14) +#define GPIO_EDGE_MASK(base) ((base) + 0x18) +#define GPIO_LEVEL_MASK(base) ((base) + 0x1c) + +/* + * Dove-specific GPIO API + */ + +void dove_gpio_set_valid(unsigned pin, int mode); +int dove_gpio_is_valid(unsigned pin, int mode); +int dove_gpio_direction_input(unsigned pin); +int dove_gpio_direction_output(unsigned pin, int value); +int dove_gpio_get_value(unsigned pin); +void dove_gpio_set_value(unsigned pin, int value); +void dove_gpio_set_blink(unsigned pin, int blink); +void dove_gpio_set_unused(unsigned pin); + +#endif
This adds a driver for the sdhci controller found on Dove SoCs.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Signed-off-by: Sascha Silbe t-uboot@infra-silbe.de --- v3->v4: added header file with exported function
arch/arm/include/asm/arch-dove/mmc.h | 27 ++++++++++ drivers/mmc/Makefile | 1 + drivers/mmc/dove_sdhci.c | 101 +++++++++++++++++++++++++++++++++++ 3 files changed, 129 insertions(+) create mode 100644 arch/arm/include/asm/arch-dove/mmc.h create mode 100644 drivers/mmc/dove_sdhci.c
diff --git a/arch/arm/include/asm/arch-dove/mmc.h b/arch/arm/include/asm/arch-dove/mmc.h new file mode 100644 index 0000000..579396c --- /dev/null +++ b/arch/arm/include/asm/arch-dove/mmc.h @@ -0,0 +1,27 @@ +/* + * Marvell Dove SoC SDHCI + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVEMMC_H +#define _DOVEMMC_H + +int dove_sdhci_init(int num); +#endif /* _DOVEMMC_H */ diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index fb6b502..cdff33d 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -31,6 +31,7 @@ endif
COBJS-$(CONFIG_BFIN_SDH) += bfin_sdh.o COBJS-$(CONFIG_DAVINCI_MMC) += davinci_mmc.o +COBJS-$(CONFIG_DOVE_SDHCI) += dove_sdhci.o COBJS-$(CONFIG_FSL_ESDHC) += fsl_esdhc.o COBJS-$(CONFIG_FTSDC010) += ftsdc010_esdhc.o COBJS-$(CONFIG_GENERIC_MMC) += mmc.o diff --git a/drivers/mmc/dove_sdhci.c b/drivers/mmc/dove_sdhci.c new file mode 100644 index 0000000..ac15fd7 --- /dev/null +++ b/drivers/mmc/dove_sdhci.c @@ -0,0 +1,101 @@ +/* + * + * Marvell Dove SDHCI driver + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * Based on linux drivers/mmc/host/sdhci-dove.c + * by: Saeed Bishara saeed@marvell.com + * Mike Rapoport mike@compulab.co.il + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ + +#include <common.h> +#include <malloc.h> +#include <sdhci.h> +#include <asm/arch/dove.h> + +static u16 dove_sdhci_readw(struct sdhci_host *host, int reg) +{ + u16 ret; + + switch (reg) { + case SDHCI_HOST_VERSION: + case SDHCI_SLOT_INT_STATUS: + /* those registers don't exist */ + return 0; + default: + ret = readw(host->ioaddr + reg); + } + + return ret; +} + +static u32 dove_sdhci_readl(struct sdhci_host *host, int reg) +{ + u32 ret; + + switch (reg) { + case SDHCI_CAPABILITIES: + ret = readl(host->ioaddr + reg); + /* Mask the support for 3.0V */ + ret &= ~SDHCI_CAN_VDD_300; + break; + default: + ret = readl(host->ioaddr + reg); + } + + return ret; +} + +static struct sdhci_ops dove_sdhci_ops = { + .read_w = dove_sdhci_readw, + .read_l = dove_sdhci_readl, +}; + +static struct sdhci_host hosts[2] = { + { + .name = "Dove SDHCI0", + .ioaddr = (void *)DOVE_SDIO0_BASE, + }, + { + .name = "Dove SDHCI1", + .ioaddr = (void *)DOVE_SDIO1_BASE, + }, +}; + +int dove_sdhci_init(int num) +{ + struct sdhci_host *host; + + if (num < 0 || num > 1) + return 1; + + host = &hosts[num]; + + if (host->version) + return 1; + + host->quirks = + SDHCI_QUIRK_NO_HISPD_BIT | + SDHCI_QUIRK_BROKEN_R1B | + SDHCI_QUIRK_32BIT_DMA_ADDR; + host->version = SDHCI_SPEC_200; + host->ops = &dove_sdhci_ops; + + add_sdhci(host, 50000000, 4000000); + return 0; +}
This adds an SPI driver for Marvell Dove SoCs. This driver is taken from kirkwood_spi but removes mpp configuration as dove has dedicated spi pins.
As a future clean-up step, the code for orion5x, kirkwood and dove could be merged, with MPP configuration being be handled as part of cpu/board-specific setup.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Signed-off-by: Sascha Silbe t-uboot@infra-silbe.de --- v3->v4: renamed to dove, adjusted description, removed unused variable, made checkpatch clean
drivers/spi/Makefile | 1 + drivers/spi/dove_spi.c | 212 +++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 213 insertions(+) create mode 100644 drivers/spi/dove_spi.c
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index d08609e..62ad970 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -38,6 +38,7 @@ COBJS-$(CONFIG_BFIN_SPI6XX) += bfin_spi6xx.o COBJS-$(CONFIG_CF_SPI) += cf_spi.o COBJS-$(CONFIG_CF_QSPI) += cf_qspi.o COBJS-$(CONFIG_DAVINCI_SPI) += davinci_spi.o +COBJS-$(CONFIG_DOVE_SPI) += dove_spi.o COBJS-$(CONFIG_EXYNOS_SPI) += exynos_spi.o COBJS-$(CONFIG_ICH_SPI) += ich.o COBJS-$(CONFIG_KIRKWOOD_SPI) += kirkwood_spi.o diff --git a/drivers/spi/dove_spi.c b/drivers/spi/dove_spi.c new file mode 100644 index 0000000..c61ba89 --- /dev/null +++ b/drivers/spi/dove_spi.c @@ -0,0 +1,212 @@ +/* + * Marvell Dove SoCs common spi driver + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * based on kirkwood_spi.c written by + * Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <malloc.h> +#include <spi.h> +#include <asm/io.h> +#include <asm/arch/config.h> + +/* SPI Registers on dove SOC */ +struct dovespi_registers { + u32 ctrl; /* 0x00 */ + u32 cfg; /* 0x04 */ + u32 dout; /* 0x08 */ + u32 din; /* 0x0c */ + u32 irq_cause; /* 0x10 */ + u32 irq_mask; /* 0x14 */ +}; + +#define DOVESPI_CLKPRESCL_MASK 0x1f +#define DOVESPI_CLKPRESCL_MIN 0x12 +#define DOVESPI_CSN_ACT 1 /* Activates serial memory interface */ +#define DOVESPI_SMEMRDY (1 << 1) /* SerMem Data xfer ready */ +#define DOVESPI_IRQUNMASK 1 /* unmask SPI interrupt */ +#define DOVESPI_IRQMASK 0 /* mask SPI interrupt */ +#define DOVESPI_SMEMRDIRQ 1 /* SerMem data xfer ready irq */ +#define DOVESPI_XFERLEN_1BYTE 0 +#define DOVESPI_XFERLEN_2BYTE (1 << 5) +#define DOVESPI_XFERLEN_MASK (1 << 5) +#define DOVESPI_ADRLEN_1BYTE 0 +#define DOVESPI_ADRLEN_2BYTE (1 << 8) +#define DOVESPI_ADRLEN_3BYTE (2 << 8) +#define DOVESPI_ADRLEN_4BYTE (3 << 8) +#define DOVESPI_ADRLEN_MASK (3 << 8) +#define DOVESPI_TIMEOUT 10000 + +static struct dovespi_registers *spireg = + (struct dovespi_registers *)DOVE_SPI_BASE; + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct spi_slave *slave; + u32 data; + + if (!spi_cs_is_valid(bus, cs)) + return NULL; + + slave = malloc(sizeof(struct spi_slave)); + if (!slave) + return NULL; + + slave->bus = bus; + slave->cs = cs; + + writel(~DOVESPI_CSN_ACT | DOVESPI_SMEMRDY, &spireg->ctrl); + + /* calculate spi clock prescaller using max_hz */ + data = ((CONFIG_SYS_TCLK / 2) / max_hz) + 0x10; + data = data < DOVESPI_CLKPRESCL_MIN ? DOVESPI_CLKPRESCL_MIN : data; + data = data > DOVESPI_CLKPRESCL_MASK ? DOVESPI_CLKPRESCL_MASK : data; + + /* program spi clock prescaller using max_hz */ + writel(DOVESPI_ADRLEN_3BYTE | data, &spireg->cfg); + debug("data = 0x%08x\n", data); + + writel(DOVESPI_SMEMRDIRQ, &spireg->irq_cause); + writel(DOVESPI_IRQMASK, &spireg->irq_mask); + + return slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + free(slave); +} + +__attribute__((weak)) int board_spi_claim_bus(struct spi_slave *slave) +{ + return 0; +} + +int spi_claim_bus(struct spi_slave *slave) +{ + return board_spi_claim_bus(slave); +} + +__attribute__((weak)) void board_spi_release_bus(struct spi_slave *slave) +{ +} + +void spi_release_bus(struct spi_slave *slave) +{ + board_spi_release_bus(slave); +} + +#ifndef CONFIG_SPI_CS_IS_VALID +/* + * you can define this function board specific + * define above CONFIG in board specific config file and + * provide the function in board specific src file + */ +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return (bus == 0 && (cs == 0 || cs == 1)); +} +#endif + +void spi_init(void) +{ +} + +void spi_cs_activate(struct spi_slave *slave) +{ + writel(readl(&spireg->ctrl) | DOVESPI_IRQUNMASK, &spireg->ctrl); +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + writel(readl(&spireg->ctrl) & DOVESPI_IRQMASK, &spireg->ctrl); +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, + void *din, unsigned long flags) +{ + unsigned int tmpdout, tmpdin; + int tm, isread = 0; + + debug("spi_xfer: slave %u:%u dout %p din %p bitlen %u\n", + slave->bus, slave->cs, dout, din, bitlen); + + if (flags & SPI_XFER_BEGIN) + spi_cs_activate(slave); + + /* + * handle data in 8-bit chunks + * TBD: 2byte xfer mode to be enabled + */ + writel(((readl(&spireg->cfg) & ~DOVESPI_XFERLEN_MASK) | + DOVESPI_XFERLEN_1BYTE), &spireg->cfg); + + while (bitlen > 4) { + debug("loopstart bitlen %d\n", bitlen); + tmpdout = 0; + + /* Shift data so it's msb-justified */ + if (dout) + tmpdout = *(u32 *)dout & 0x0ff; + + writel(~DOVESPI_SMEMRDIRQ, &spireg->irq_cause); + writel(tmpdout, &spireg->dout); /* Write the data out */ + debug("*** spi_xfer: ... %08x written, bitlen %d\n", + tmpdout, bitlen); + + /* + * Wait for SPI transmit to get out + * or time out (1 second = 1000 ms) + * The NE event must be read and cleared first + */ + for (tm = 0, isread = 0; tm < DOVESPI_TIMEOUT; ++tm) { + if (readl(&spireg->irq_cause) & DOVESPI_SMEMRDIRQ) { + isread = 1; + tmpdin = readl(&spireg->din); + debug + ("spi_xfer: din %p..%08x read\n", + din, tmpdin); + + if (din) { + *((u8 *)din) = (u8)tmpdin; + din += 1; + } + if (dout) + dout += 1; + bitlen -= 8; + } + if (isread) + break; + } + if (tm >= DOVESPI_TIMEOUT) + printf("*** spi_xfer: Time out during SPI transfer\n"); + + debug("loopend bitlen %d\n", bitlen); + } + + if (flags & SPI_XFER_END) + spi_cs_deactivate(slave); + + return 0; +}
Looks ok to me as per coding style after a quick look.
- Marvell Dove SoCs common spi driver
- Sebastian Hesselbarth sebastian.hesselbarth@gmail.com
- based on kirkwood_spi.c written by
- Prafulla Wadaskar prafulla@marvell.com
- project.
- Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston,
- MA 02110-1301 USA
u32 cfg; /* 0x04 */
u32 din; /* 0x0c */
u32 data;
return NULL;
Done use the below tag code instead go for spi_alloc_slave() see the sample code on "drivers/spi/exynos_spi.c"
----------------------- TAG+
if (!slave)
return NULL;
slave->bus = bus;
slave->cs = cs;
--------------------- TAG-
return slave;
free(slave);
Why your using __attribute__((weak)) here, may be use to pre-load the symbol library but what is the use case here?
-- Thanks, Jagan.
- project.
- MA 02110-1301 USA
u32 cfg; /* 0x04 */
u32 din; /* 0x0c */
u32 data;
return NULL;
if (!slave)
return NULL;
slave->bus = bus;
slave->cs = cs;
return slave;
free(slave);
-- Thanks, Jagan.
Any update on this.
Thanks, Jagan.
Looks ok to me as per coding style after a quick look. On Mon, May 27, 2013 at 12:06 AM, Sascha Silbe t-uboot@infra-silbe.de wrote:
Any update on this.
Is any of you even listening? Please do _not_ name it after Dove! It is compatible with _at least_ Kirkwood, Orion5x and MV78x00. Now is the chance to have a common name or you will end up with either non-sense naming or four copies of that very driver.
Originally, it was named after the Linux group of SoCs compatible with Dove (orion-spi), IIRC Prafulla suggested mv-spi.
Sebastian
On Thu, Jun 13, 2013 at 12:56 AM, Sebastian Hesselbarth sebastian.hesselbarth@gmail.com wrote:
Any update on this.
Sebastian
Common to use means orion_spi instead of Dove?
-- Thanks, Jagan.
Either orion_spi as it was named originally, or mv_spi as Prafulla suggested. Then move mpp (pinctrl) from kirkwood_spi to corresponding boards, switch to orion_/mv_spi, and remove kirkwood_spi.
I suggest orion_spi, but Prafulla had his word so it should be mv_spi I guess.
Sebastian
Sebastian Hesselbarth sebastian.hesselbarth@gmail.com writes:
I've given it a try and modified the Kirkwood GPIO and SPI drivers rather than duplicating their code. As I neither know the Dove SoCs nor have any hardware using them, I don't feel comfortable merging this with any existing orion code. For similar reasons and also for a lack of time I've left the MPP support code in place, just protected with CONFIG_KIRKWOOD.
As for the naming: there's already a GPIO driver called mvgpio that looks quite different from the Kirkwood / Dove one. Naming the latter one mv_gpio would work for the build tools, but needlessly cause confusion to developers. Therefore I chose to keep the current names of the Kirkwood drivers (kw_gpio, kirkwood_spi). If anyone has a better suggestion, I'm happy to change the names.
Sebastian, does the resulting code still match your intentions or would you like me to remove your Signed-off-by from those two patches when posting the updated patch series?
Sascha
On 06/25/2013 09:33 PM, Sascha Silbe wrote:
Sebastian Hesselbarthsebastian.hesselbarth@gmail.com writes:
Sascha,
I was under the impression that you resent the patches because you have a CuBox you want to get supported. Anyway, I will not get back to u-boot Dove support anytime soon. It just takes to long to get any valuable review/ack from Marvell maintainer.
Naming was the main discussion of this patch set back then, there have been some "???" on the mpp stuff. I suggested several times not to use "mv" as I knew that Marvell PXA also uses "mv" as prefix all over.
The PXA SPI controller is based on different IP. Unfortunately PXA naming is not consitent over SoCs, Dove is also nick-named PXA510 sometimes.
Actually, we are merging Orion SoCs and Armada 370/XP to mach-mvebu - so the best name would be mvebu_spi as the spi controller is also in Armada 370/XP.
But Prafulla is u-boot Marvell maintainer, he said to use mv prefix - not my call anymore.
Uhm, did you forget to send code?
I will not likely get back to Dove support on u-boot. I cannot really re-test on Kirkwood and it just takes to long to get feedback. I suggest to remove my Signed-off-by and especially the MAINTAINERS entry.
Sebastian
Exactly. I'd like to see support for CuBox enter mainline U-Boot. However, there's also a limit to the amount of time I can afford to spend on it (both per week and in total). TBH, I would have hoped the _vendor_ (SolidRun) would take a more active role in this. For that reason I'm now going to evaluate a Wandboard Quad, where more effort seems to get spent on upstreaming (not to mention that the schematics are available, which makes working on board support a lot easier). When I ordered the CuBox Pro, the then-existing Wandboard variants (Solo and DualLite) lacked SATA support, but the Quad meets my requirements.
You're confusing me even more than I already was. :)
It's probably best to leave this reorganisation to someone else who better knows the relationships between the several SoC families from Marvell.
No, I was holding back until I knew whether you still feel comfortable being associated with the patches. I'll send them out now.
OK, will do. Sorry you feel that way.
Sascha
On 06/25/2013 10:38 PM, Sascha Silbe wrote:
Sebastian Hesselbarthsebastian.hesselbarth@gmail.com writes: [...]
From what I know, Rabeeh would love to add support for CuBox to u-boot. But I guess his spare time is very limited, too.
Linux has some good overview of the non-PXA Marvell SoCs. Naming is a mess and IP is reused often. But from what I can say, Orion matches Dove, Kirkwood, Orion5x, and Discovery Innovation (mv78x00). Armada 370/XP share some of the peripheral IP but especially irq is different.
With respect to SPI, mvebu (Orion + Armada 370/XP) maybe matches best as it is used in all of them with minor differences. PXA type SoCs use a different IP for SPI.
Ok, I will try to give it a review at least.
Sebastian
Changes from v4: - some patches got included in master, so they've been dropped from the series - removed Sebastian Hesselbarth's Signed-off-by and MAINTAINERS entry on his request - modified Kirkwood GPIO and SPI drivers rather than duplicating them
This version has only been tested (lightly) on CuBox Pro, not on OpenRD (Kirkwood). The latter box is in production use, so I'd like to know whether the current approach is acceptable before I spend considerable time on testing.
Sascha Silbe (8): ARM: dove: add support for Marvell Dove SoC usb: ehci-marvell: add support for second USB controller GPIO: add Dove support to Kirkwood GPIO driver MMC: sdhci: Add support for dove sdhci SPI: add Dove support to Kirkwood SPI driver block: mvsata: add dove include NET: mvgbe: avoid unused variable warning when used without phylib support Boards: Add support for SolidRun CuBox
arch/arm/cpu/armv7/dove/Makefile | 49 ++++ arch/arm/cpu/armv7/dove/cpu.c | 274 ++++++++++++++++++ arch/arm/cpu/armv7/dove/dram.c | 117 ++++++++ arch/arm/cpu/armv7/dove/lowlevel_init.S | 83 ++++++ arch/arm/cpu/armv7/dove/mpp.c | 318 +++++++++++++++++++++ arch/arm/cpu/armv7/dove/timer.c | 176 ++++++++++++ arch/arm/cpu/armv7/dove/usb.c | 101 +++++++ arch/arm/include/asm/arch-dove/config.h | 153 ++++++++++ arch/arm/include/asm/arch-dove/cpu.h | 204 +++++++++++++ arch/arm/include/asm/arch-dove/dove.h | 98 +++++++ arch/arm/include/asm/arch-dove/gpio.h | 35 +++ arch/arm/include/asm/arch-dove/mmc.h | 27 ++ arch/arm/include/asm/arch-dove/mpp.h | 283 ++++++++++++++++++ arch/arm/include/asm/arch-dove/usb.h | 27 ++ arch/arm/include/asm/arch-kirkwood/gpio.h | 42 +-- arch/arm/include/asm/arch-kirkwood/spi.h | 27 -- board/solidrun/cubox/Makefile | 45 +++ board/solidrun/cubox/cubox.c | 142 +++++++++ board/solidrun/cubox/kwbimage-spi-1gb.cfg | 76 +++++ board/solidrun/cubox/kwbimage-spi-2gb.cfg | 76 +++++ board/solidrun/cubox/kwbimage-uart.cfg | 76 +++++ boards.cfg | 3 + drivers/block/mvsata_ide.c | 2 + drivers/gpio/kw_gpio.c | 43 +-- drivers/mmc/Makefile | 1 + drivers/mmc/dove_sdhci.c | 101 +++++++ drivers/net/mvgbe.c | 5 +- drivers/spi/kirkwood_spi.c | 47 ++- drivers/usb/host/ehci-marvell.c | 35 ++- include/configs/cubox.h | 185 ++++++++++++ .../asm/arch-kirkwood/gpio.h => include/kw_gpio.h | 43 ++- 31 files changed, 2769 insertions(+), 125 deletions(-) create mode 100644 arch/arm/cpu/armv7/dove/Makefile create mode 100644 arch/arm/cpu/armv7/dove/cpu.c create mode 100644 arch/arm/cpu/armv7/dove/dram.c create mode 100644 arch/arm/cpu/armv7/dove/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/dove/mpp.c create mode 100644 arch/arm/cpu/armv7/dove/timer.c create mode 100644 arch/arm/cpu/armv7/dove/usb.c create mode 100644 arch/arm/include/asm/arch-dove/config.h create mode 100644 arch/arm/include/asm/arch-dove/cpu.h create mode 100644 arch/arm/include/asm/arch-dove/dove.h create mode 100644 arch/arm/include/asm/arch-dove/gpio.h create mode 100644 arch/arm/include/asm/arch-dove/mmc.h create mode 100644 arch/arm/include/asm/arch-dove/mpp.h create mode 100644 arch/arm/include/asm/arch-dove/usb.h create mode 100644 board/solidrun/cubox/Makefile create mode 100644 board/solidrun/cubox/cubox.c create mode 100644 board/solidrun/cubox/kwbimage-spi-1gb.cfg create mode 100644 board/solidrun/cubox/kwbimage-spi-2gb.cfg create mode 100644 board/solidrun/cubox/kwbimage-uart.cfg create mode 100644 drivers/mmc/dove_sdhci.c create mode 100644 include/configs/cubox.h copy arch/arm/include/asm/arch-kirkwood/gpio.h => include/kw_gpio.h (60%)
This patch adds initial support for the armv7-based Marvell Dove SoC (88AP510).
Signed-off-by: Sascha Silbe t-uboot@infra-silbe.de --- v4->v5: some adjustments for the GPIO and SPI driver changes
arch/arm/cpu/armv7/dove/Makefile | 49 +++++ arch/arm/cpu/armv7/dove/cpu.c | 274 +++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/dram.c | 117 ++++++++++++ arch/arm/cpu/armv7/dove/lowlevel_init.S | 83 +++++++++ arch/arm/cpu/armv7/dove/mpp.c | 318 ++++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/timer.c | 176 ++++++++++++++++++ arch/arm/cpu/armv7/dove/usb.c | 101 ++++++++++ arch/arm/include/asm/arch-dove/config.h | 153 +++++++++++++++ arch/arm/include/asm/arch-dove/cpu.h | 204 ++++++++++++++++++++ arch/arm/include/asm/arch-dove/dove.h | 98 ++++++++++ arch/arm/include/asm/arch-dove/gpio.h | 35 ++++ arch/arm/include/asm/arch-dove/mpp.h | 283 ++++++++++++++++++++++++++++ arch/arm/include/asm/arch-dove/usb.h | 27 +++ 13 files changed, 1918 insertions(+)
diff --git a/arch/arm/cpu/armv7/dove/Makefile b/arch/arm/cpu/armv7/dove/Makefile new file mode 100644 index 0000000..127d67e --- /dev/null +++ b/arch/arm/cpu/armv7/dove/Makefile @@ -0,0 +1,49 @@ +# +# Marvell Dove SoC Makefile +# +# Sebastian Hesselbarth sebastian.hesselbarth@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).o + +SOBJS += lowlevel_init.o +COBJS-y := cpu.o dram.o timer.o mpp.o +COBJS-$(CONFIG_USB_EHCI_MARVELL) += usb.o + +COBJS := $(COBJS-y) +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/arm/cpu/armv7/dove/cpu.c b/arch/arm/cpu/armv7/dove/cpu.c new file mode 100644 index 0000000..b5320b7 --- /dev/null +++ b/arch/arm/cpu/armv7/dove/cpu.c @@ -0,0 +1,274 @@ +/* + * Marvell Dove SoC cpu related functions + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <netdev.h> +#include <asm/cache.h> +#include <u-boot/md5.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> +#include <asm/arch/usb.h> +#include <hush.h> + +void reset_cpu(unsigned long ignored) +{ + struct dovecpu_registers *cpureg = + (struct dovecpu_registers *)DOVE_CPU_REG_BASE; + + /* Enable soft reset to assert RSTOUTn */ + writel(readl(&cpureg->rstoutn_mask) | (1 << 2), + &cpureg->rstoutn_mask); + /* Assert soft reset */ + writel(readl(&cpureg->sys_soft_rst) | 1, + &cpureg->sys_soft_rst); + do {} while (1); +} + +#if defined(CONFIG_DISPLAY_CPUINFO) +int dove_print_cpu(void) +{ + char *cpu; + u32 idreg; + u16 part, rev; + + __asm__ __volatile__("mrc p15, 0, %0, c0, c0, 0" : "=r"(idreg)); + + part = (idreg >> ARM_ID_PARTNUM_OFFSET) & ARM_ID_PARTNUM_MASK; + rev = (idreg >> ARM_ID_REVISION_OFFSET) & ARM_ID_REVISION_MASK; + + switch (part) { + case DOVECPU_PART_SHEEVA: + cpu = "Marvell Sheeva"; + break; + default: + cpu = "Unknown CPU"; + } + + printf("CPU: %s (rev %d)\n", cpu, rev); + return 0; +} + +int dove_print_soc(void) +{ + char *soc, *rev; + u16 devid = (readl(DOVE_REG_PCIE_DEVID) >> 16) & 0xffff; + u8 revid = readl(DOVE_REG_PCIE_REVID) & 0xff; + + switch (devid) { + case DOVESOC_DEVID_AP510: + soc = "AP510"; + break; + case DOVESOC_DEVID_F6781: + soc = "F6781"; + break; + default: + printf("ERROR.. %s: Unsupported SoC %04x\n", __func__, devid); + return -1; + } + + switch (revid) { + case DOVESOC_REVID_Z0: + rev = "Z0"; + break; + case DOVESOC_REVID_Z1: + rev = "Z1"; + break; + case DOVESOC_REVID_Y0: + rev = "Y0"; + break; + case DOVESOC_REVID_Y1: + rev = "Y1"; + break; + case DOVESOC_REVID_X0: + rev = "X0"; + break; + case DOVESOC_REVID_A0: + rev = "A0"; + break; + case DOVESOC_REVID_A1: + rev = "A1"; + break; + default: + rev = "Unknown revision"; + }; + + printf("SoC: Dove 88%s (%s)\n", soc, rev); + return 0; +} + +int print_cpuinfo(void) +{ + if (dove_print_soc()) + return -1; + if (dove_print_cpu()) + return -1; + return 0; +} +#endif /* CONFIG_DISPLAY_CPUINFO */ + +/* + * dove_init_gpio - initial GPIO configuration + */ +void dove_init_gpio(struct dove_gpio_init *gpp) +{ + struct dovegpio_registers *gpio0reg = + (struct dovegpio_registers *)DOVE_GPIO0_BASE; + struct dovegpio_registers *gpio1reg = + (struct dovegpio_registers *)DOVE_GPIO1_BASE; + struct dovegpio_registers *gpio2reg = + (struct dovegpio_registers *)DOVE_GPIO2_BASE; + + /* Init GPIOS to default values as per board requirement */ + writel(gpp->val0, &gpio0reg->dout); + writel(gpp->val1, &gpio1reg->dout); + writel(gpp->val2, &gpio2reg->dout); + writel(gpp->oe0_n, &gpio0reg->oe); + writel(gpp->oe1_n, &gpio1reg->oe); + writel(gpp->oe2_n, &gpio2reg->oe); +} + +/* + * Window Size + * Used with the Base register to set the address window size and location. + * Must be programmed from LSB to MSB as sequence of ones followed by + * sequence of zeros. The number of ones specifies the size of the window in + * 64 KByte granularity (e.g., a value of 0x00FF specifies 256 = 16 MByte). + * NOTE: A value of 0x0 specifies 64-KByte size. + */ +unsigned int dove_winctrl_calcsize(unsigned int sizeval) +{ + int i; + unsigned int j = 0; + u32 val = sizeval >> 1; + + for (i = 0; val >= 0x10000; i++) { + j |= (1 << i); + val = val >> 1; + } + return 0x0000ffff & j; +} + +/* + * dove_config_adr_windows - Configure address Windows + * + * There are 8 address windows supported by Dove Soc to addess different + * devices. Windows 0-3 can be configured for size, BAR and remap addr. + * Windows 4-7 can be configured for size and BAR. + * Below configuration is standard for most of the cases + * + * If remap function not used, remap_lo must be set as base + */ +int dove_config_adr_windows(void) +{ + struct dovewin_registers *winregs = + (struct dovewin_registers *)DOVE_CPU_WIN_BASE; + + /* Window 0: 1M PCIE0 IO address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_1M, DOVECPU_TARGET_PCIE0, + DOVECPU_ATTR_PCIE_IO, DOVECPU_WIN_ENABLE), + &winregs[0].ctrl); + + writel(DOVE_DEFADR_PCIE0_IO, &winregs[0].base); + writel(DOVE_DEFADR_PCIE0_IO_REMAP, &winregs[0].remap_lo); + writel(0x0, &winregs[0].remap_hi); + + /* Window 1: 1M PCIE1 IO address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_1M, DOVECPU_TARGET_PCIE1, + DOVECPU_ATTR_PCIE_IO, DOVECPU_WIN_ENABLE), + &winregs[1].ctrl); + + writel(DOVE_DEFADR_PCIE1_IO, &winregs[1].base); + writel(DOVE_DEFADR_PCIE1_IO_REMAP, &winregs[1].remap_lo); + writel(0x0, &winregs[1].remap_hi); + + /* Window 2: 128M PCIE0 MEM address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_128M, DOVECPU_TARGET_PCIE0, + DOVECPU_ATTR_PCIE_MEM, DOVECPU_WIN_ENABLE), + &winregs[2].ctrl); + + writel(DOVE_DEFADR_PCIE0_MEM, &winregs[2].base); + writel(DOVE_DEFADR_PCIE0_MEM, &winregs[2].remap_lo); + writel(0x0, &winregs[2].remap_hi); + + /* Window 3: 128M PCIE1 MEM address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_128M, DOVECPU_TARGET_PCIE1, + DOVECPU_ATTR_PCIE_MEM, DOVECPU_WIN_ENABLE), + &winregs[3].ctrl); + + writel(DOVE_DEFADR_PCIE1_MEM, &winregs[3].base); + writel(DOVE_DEFADR_PCIE1_MEM, &winregs[3].remap_lo); + writel(0x0, &winregs[3].remap_hi); + + /* Window 4: 1M Cryptographic SRAM address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_1M, DOVECPU_TARGET_SASRAM, + DOVECPU_ATTR_SASRAM, DOVECPU_WIN_ENABLE), + &winregs[4].ctrl); + writel(DOVE_DEFADR_SASRAM, &winregs[4].base); + + /* Window 5: 128M Bootrom address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_128M, DOVECPU_TARGET_BOOTROM, + DOVECPU_ATTR_BOOTROM, DOVECPU_WIN_ENABLE), + &winregs[5].ctrl); + writel(DOVE_DEFADR_BOOTROM, &winregs[5].base); + + /* Window 6: 1M PMU Scratchpad address space */ + writel(DOVECPU_WIN_CTRL_DATA(SZ_1M, DOVECPU_TARGET_PMURAM, + DOVECPU_ATTR_PMURAM, DOVECPU_WIN_ENABLE), + &winregs[6].ctrl); + writel(DOVE_DEFADR_PMURAM, &winregs[6].base); + + /* Window 7: Disabled */ + writel(DOVECPU_WIN_DISABLE, &winregs[7].ctrl); + + return 0; +} + +#ifdef CONFIG_ARCH_CPU_INIT +int arch_cpu_init(void) +{ + dove_config_adr_windows(); +#ifdef CONFIG_USB_EHCI_MARVELL + dove_ehci_phy_init(0); + dove_ehci_phy_init(1); +#endif /* CONFIG_USB_EHCI_MARVELL */ + return 0; +} +#endif /* CONFIG_ARCH_CPU_INIT */ + +void enable_caches(void) +{ +#ifndef CONFIG_SYS_DCACHE_OFF + /* Enable D-cache. I-cache is already enabled in lowlevel_init.S */ + dcache_enable(); +#endif /* CONFIG_SYS_DCACHE_OFF */ +} + +#ifdef CONFIG_MVGBE +int cpu_eth_init(bd_t *bis) +{ + mvgbe_initialize(bis); + return 0; +} +#endif /* CONFIG_MVGBE */ diff --git a/arch/arm/cpu/armv7/dove/dram.c b/arch/arm/cpu/armv7/dove/dram.c new file mode 100644 index 0000000..ce535f3 --- /dev/null +++ b/arch/arm/cpu/armv7/dove/dram.c @@ -0,0 +1,117 @@ +/* + * Marvell Dove SoC DRAM initialization + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <config.h> +#include <common.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define DOVE_REG_DRAM_MAP(x) (DOVE_REGISTER(0x800100) + (x * 0x10)) +#define DRAM_START_MASK 0xff800000 +#define DRAM_SIZE_MASK 0xf +#define DRAM_SIZE_SHIFT 16 + +/* + * dove_sdram_start - reads start from Memory Address Map Register n + */ +u32 dove_dram_start(enum memory_bank bank) +{ + u32 reg = readl(DOVE_REG_DRAM_MAP(bank)); + u32 enable = 0x01 & reg; + + if ((!enable) || (bank > BANK1)) + return 0; + + return reg & DRAM_START_MASK; +} + +/* + * dove_sdram_size - reads size from Memory Address Map Register n + */ +u32 dove_dram_size(enum memory_bank bank) +{ + u32 reg = readl(DOVE_REG_DRAM_MAP(bank)); + u32 enable = 0x01 & reg; + u32 size; + + if ((!enable) || (bank > BANK1)) + return 0; + + /* + * area_length: 7 = 8M, 8 = 16M, ..., 15 = 2048M + * size = 1 << (area_length + 16) + */ + size = (reg >> DRAM_SIZE_SHIFT) & DRAM_SIZE_MASK; + size = 1 << (size + 16); + return size; +} + +#ifndef CONFIG_SYS_BOARD_DRAM_INIT +int dram_init(void) +{ + int i; + + gd->ram_size = 0; + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + gd->bd->bi_dram[i].start = dove_dram_start(i); + gd->bd->bi_dram[i].size = dove_dram_size(i); + + /* + * It is assumed that all memory banks are consecutive + * and without gaps. + * If the gap is found, ram_size will be reported for + * consecutive memory only + */ + if (gd->bd->bi_dram[i].start != gd->ram_size) + break; + + gd->ram_size += gd->bd->bi_dram[i].size; + } + + for (; i < CONFIG_NR_DRAM_BANKS; i++) { + /* + * If above loop terminated prematurely, we need to set + * remaining banks' start address & size as 0. Otherwise other + * u-boot functions and Linux kernel gets wrong values which + * could result in crash + */ + gd->bd->bi_dram[i].start = 0; + gd->bd->bi_dram[i].size = 0; + } + + return 0; +} + +/* + * If this function is not defined here, + * board.c alters dram bank zero configuration defined above. + */ +void dram_init_banksize(void) +{ + dram_init(); +} +#endif /* CONFIG_SYS_BOARD_DRAM_INIT */ diff --git a/arch/arm/cpu/armv7/dove/lowlevel_init.S b/arch/arm/cpu/armv7/dove/lowlevel_init.S new file mode 100644 index 0000000..105d12d --- /dev/null +++ b/arch/arm/cpu/armv7/dove/lowlevel_init.S @@ -0,0 +1,83 @@ +/* + * Marvell Dove SoC icache and reg base low level init + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm/arch/dove.h> +#include <generated/asm-offsets.h> +#include <linux/linkage.h> + +/* + * Enable Tauros2 L2 ICache + */ +.macro init_l2cc + mrc 15, 0, r0, c1, c0, 1 + orr r0, r0, #0x2 + mcr 15, 0, r0, c1, c0, 1 +.endm /* init_l2cc */ + +/* + * Init internal register base addresses + */ +.macro init_reg_base + /* set SB reg base to 0xf1000000 */ + ldr r1, =(DOVE_PREMAP_INT_REGS_BASE_ADDR) + ldr r6, =DOVE_SB_REGS_PHYS_BASE + str r6, [r1] + + /* set NB reg base to 0xf1800000 */ + ldr r1, =(DOVE_CPU_CTRL_REG) + ldr r4, =0xffff0000 + ldr r6, [r1] + and r6, r6, r4 + ldr r4, =DOVE_NB_REGS_PHYS_BASE + lsr r4, r6, #16 + orr r6, r6, r4 + str r6, [r1] + + /* Set AXI bridge address mapping to 0xf1800000 */ + ldr r1, =(DOVE_AXI_CTRL_REG) + ldr r4, =0x007fffff + ldr r6, [r1] + and r6, r6, r4 + ldr r4, =DOVE_NB_REGS_PHYS_BASE + orr r6, r6, r4 + str r6, [r1] + + /* set MC configuration register decode address to 0xf1800000 */ + ldr r1, =(DOVE_PREMAP_MC_DECODE_REG) + ldr r4, =0x0000ffff + ldr r6, [r1] + and r6, r6, r4 + ldr r4, =DOVE_NB_REGS_PHYS_BASE + orr r6, r6, r4 + str r6, [r1] + +.endm /* init_reg_base */ + +.section ".text.init", "x" + +ENTRY(lowlevel_init) + init_l2cc + init_reg_base + + /* r12 saved upper lr*/ + mov pc,lr +ENDPROC(lowlevel_init) diff --git a/arch/arm/cpu/armv7/dove/mpp.c b/arch/arm/cpu/armv7/dove/mpp.c new file mode 100644 index 0000000..e929702 --- /dev/null +++ b/arch/arm/cpu/armv7/dove/mpp.c @@ -0,0 +1,318 @@ +/* + * Marvell Dove SoC MPP pinmux + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> +#include <asm/arch/mpp.h> +#include <asm/arch/gpio.h> + +#define MPP_BITS 4 +#define MPP_MASK 0xf +#define MPPS_PER_REG 8 + +#define MPP_NUM(_x) ((_x) & 0xff) +#define MPP_SEL(_x) (((_x) >> 8) & 0x1f) +#define MPP_GPIO(_x) ((_x) & (1 << 15)) + +#define MPP_CTRL(i) (DOVE_MPP_BASE + (i * MPP_BITS)) +#define MPP_PMU_GENERAL_CTRL (DOVE_MPP_BASE + 0x010) +#define PMUG_AUDIO0_AC97_SEL (1 << 16) +#define MPP4_CTRL (DOVE_MPP_BASE + 0x240) +#define MPP4_SDIO0_GPIO_SEL (1 << 0) +#define MPP4_SDIO1_GPIO_SEL (1 << 1) +#define MPP4_CAMERA_GPIO_SEL (1 << 2) +#define MPP4_AUDIO1_GPIO_SEL (1 << 3) +#define MPP4_UART1_GPIO_SEL (1 << 4) +#define MPP4_SPI_GPIO_SEL (1 << 5) +#define MPP_GENERAL_CTRL (DOVE_PDMA_BASE + 0x403c) +#define MPPG_NAND_GPIO_SEL (1 << 0) +#define MPPG_AUDIO1_SPDIFO_GPIO_SEL (1 << 1) +#define GENERAL_CONFIG_1 (DOVE_PDMA_BASE + 0x002c) +#define GENERAL_TWSI_MUXEN_OPTION1 (1 << 7) +#define GENERAL_CONFIG_2 (DOVE_PDMA_BASE + 0x0030) +#define GENERAL_TWSI_OPTION3_SEL (1 << 22) +#define GENERAL_TWSI_MUXEN_OPTION3 (1 << 21) +#define GENERAL_TWSI_MUXEN_OPTION2 (1 << 20) +#define SSP_CONFIG_STATUS_1 (DOVE_PDMA_BASE + 0x0034) +#define SSP_SSP_ON_AUDIO1 (1 << 0) + +/* + * MPP0-23 have standard MPP register layout + */ +static void dove_mpp_std_set(u16 config) +{ + u8 num = MPP_NUM(config); + u32 off = (num / MPPS_PER_REG) * MPP_BITS; + u32 shift = (num % MPPS_PER_REG) * MPP_BITS; + u32 reg; + + /* configure standard MPP pin */ + reg = readl(MPP_CTRL(off)); + reg &= ~(MPP_MASK << shift); + reg |= MPP_SEL(config) << shift; + writel(reg, MPP_CTRL(off)); + + /* configure gpio capabilities */ + if (MPP_GPIO(config)) + kw_gpio_set_valid(num, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + else + kw_gpio_set_valid(num, 0); +} + +/* + * MPP0-15 also allow to mux PMU functions + */ +static void dove_mpp_pmu_set(u16 config) +{ + u8 num = MPP_NUM(config); + + if (MPP_SEL(config) == PMU) { + /* enable PMU on MPP */ + writel(readl(MPP_PMU_GENERAL_CTRL) | (1 << num), + MPP_PMU_GENERAL_CTRL); + /* disable gpio capabilities */ + kw_gpio_set_valid(num, 0); + } else { + /* disable PMU on MPP */ + writel(readl(MPP_PMU_GENERAL_CTRL) & ~(1 << num), + MPP_PMU_GENERAL_CTRL); + /* configure MPP */ + dove_mpp_std_set(config); + } +} + +/* + * MPP groups on MPP4_CTRL have different register layout + * and allow GPIO or special function only + */ +static void dove_mpp4_set(u16 config) +{ + u32 reg = readl(MPP4_CTRL); + u32 mask; + u8 n, nmin, nmax; + int gpio; + + switch (MPP_NUM(config)) { + case MPP_CAMERA: + mask = MPP4_CAMERA_GPIO_SEL; + nmin = MPP_CAMERA; + nmax = MPP_CAMERA_MAX; + break; + case MPP_SDIO0: + mask = MPP4_SDIO0_GPIO_SEL; + nmin = MPP_SDIO0; + nmax = MPP_SDIO0_MAX; + break; + case MPP_SDIO1: + mask = MPP4_SDIO1_GPIO_SEL; + nmin = MPP_SDIO1; + nmax = MPP_SDIO1_MAX; + break; + case MPP_SPI: + mask = MPP4_SPI_GPIO_SEL; + nmin = MPP_SPI; + nmax = MPP_SPI_MAX; + break; + case MPP_UART1: + mask = MPP4_UART1_GPIO_SEL; + nmin = MPP_UART1; + nmax = MPP_UART1_MAX; + break; + default: + return; + } + + reg &= ~mask; + if (MPP_SEL(config)) + reg |= mask; + writel(reg, MPP4_CTRL); + + /* configure gpio capabilities */ + gpio = 0; + if (MPP_GPIO(config)) + gpio = GPIO_INPUT_OK | GPIO_OUTPUT_OK; + for (n = nmin; n <= nmax; n++) + kw_gpio_set_valid(n, gpio); +} + +/* + * MPP_GENERAL_CTRL allows GPIO on NAND pins + */ +static void dove_mpp_nand_set(u16 config) +{ + u32 reg = readl(MPP_GENERAL_CTRL); + u8 n; + int gpio; + + reg &= ~MPPG_NAND_GPIO_SEL; + if (config == MPP_NAND_GPO) + reg |= MPPG_NAND_GPIO_SEL; + writel(reg, MPP_GENERAL_CTRL); + + /* configure gpio capabilities */ + gpio = (config == MPP_NAND_GPO) ? GPIO_OUTPUT_OK : 0; + for (n = MPP_NAND; n <= MPP_NAND_MAX; n++) + kw_gpio_set_valid(n, gpio); +} + +/* + * Dedicated audio1 pins can carry i2s, spdif, ssp or twsi + * and gpio in various combinations + */ +#define AUDIO1_TWSI (1 << 0) +#define AUDIO1_SPDIFO (1 << 1) +#define AUDIO1_SSP (1 << 2) +#define AUDIO1_GPIO (1 << 3) + +static void dove_mpp_audio1_set(u16 config) +{ + u32 mpp4 = readl(MPP4_CTRL); + u32 sspc1 = readl(SSP_CONFIG_STATUS_1); + u32 gmpp = readl(MPP_GENERAL_CTRL); + u32 gcfg2 = readl(GENERAL_CONFIG_2); + u8 n, sel = MPP_SEL(config); + int gpio; + + gcfg2 &= ~GENERAL_TWSI_OPTION3_SEL; + gmpp &= ~MPPG_AUDIO1_SPDIFO_GPIO_SEL; + sspc1 &= ~SSP_SSP_ON_AUDIO1; + mpp4 &= ~MPP4_AUDIO1_GPIO_SEL; + if (sel & AUDIO1_TWSI) + gcfg2 |= GENERAL_TWSI_OPTION3_SEL; + if (sel & AUDIO1_SPDIFO) + gmpp |= MPPG_AUDIO1_SPDIFO_GPIO_SEL; + if (sel & AUDIO1_SSP) + sspc1 |= SSP_SSP_ON_AUDIO1; + if (sel & AUDIO1_GPIO) + mpp4 |= MPP4_AUDIO1_GPIO_SEL; + + writel(mpp4, MPP4_CTRL); + writel(sspc1, SSP_CONFIG_STATUS_1); + writel(gmpp, MPP_GENERAL_CTRL); + writel(gcfg2, GENERAL_CONFIG_2); + + /* gpio allows gpio on all audio1 mpp pins */ + gpio = 0; + if (config == MPP_AUDIO1_GPIO) + gpio = GPIO_INPUT_OK | GPIO_OUTPUT_OK; + + for (n = MPP_AUDIO1; n <= MPP_AUDIO1_MAX; n++) + kw_gpio_set_valid(n, gpio); + + switch (config) { + /* spdifo and twsi allow gpio on mpp[52:55] */ + case MPP_AUDIO1_SPDIFO: + case MPP_AUDIO1_TWSI: + kw_gpio_set_valid(52, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + kw_gpio_set_valid(53, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + kw_gpio_set_valid(54, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + kw_gpio_set_valid(55, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + break; + /* i2s and ssp allow gpio on mpp[56:57] */ + case MPP_AUDIO1_I2S: + case MPP_AUDIO1_SSP: + kw_gpio_set_valid(56, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + kw_gpio_set_valid(57, GPIO_INPUT_OK | GPIO_OUTPUT_OK); + break; + } +} + +/* + * MPP PMU switches audio0 pins to ac97 or i2s0 + */ +static void dove_mpp_audio0_set(u16 config) +{ + /* switch i2s or ac97 to audio0 */ + u32 reg = readl(MPP_PMU_GENERAL_CTRL); + + reg &= ~PMUG_AUDIO0_AC97_SEL; + if (config == MPP_AUDIO0_AC97) + reg |= PMUG_AUDIO0_AC97_SEL; + writel(reg, MPP_PMU_GENERAL_CTRL); +} + +/* + * TWSI has 3 optional pin sets that can be switched during runtime + */ +static void dove_mpp_twsi_set(u16 config) +{ + u32 gcfg1 = readl(GENERAL_CONFIG_1); + u32 gcfg2 = readl(GENERAL_CONFIG_2); + + gcfg1 &= ~GENERAL_TWSI_MUXEN_OPTION1; + gcfg2 &= ~(GENERAL_TWSI_MUXEN_OPTION2 | GENERAL_TWSI_MUXEN_OPTION3); + + switch (config) { + case MPP_TWSI_OPTION1: + gcfg1 |= GENERAL_TWSI_MUXEN_OPTION1; + break; + case MPP_TWSI_OPTION2: + gcfg2 |= GENERAL_TWSI_MUXEN_OPTION2; + break; + case MPP_TWSI_OPTION3: + gcfg2 |= GENERAL_TWSI_MUXEN_OPTION3; + break; + } + + writel(gcfg1, GENERAL_CONFIG_1); + writel(gcfg2, GENERAL_CONFIG_2); +} + +void dove_mpp_conf(u16 *mpp_list) +{ + while (*mpp_list) { + u8 num = MPP_NUM(*mpp_list); + + if (num <= MPP_PMU_MAX) { + dove_mpp_pmu_set(*mpp_list); + } else if (num <= MPP_STD_MAX) { + dove_mpp_std_set(*mpp_list); + } else { + switch (num) { + case MPP_CAMERA: + case MPP_SDIO0: + case MPP_SDIO1: + case MPP_SPI: + case MPP_UART1: + dove_mpp4_set(*mpp_list); + break; + case MPP_NAND: + dove_mpp_nand_set(*mpp_list); + break; + case MPP_AUDIO0: + dove_mpp_audio0_set(*mpp_list); + break; + case MPP_AUDIO1: + dove_mpp_audio1_set(*mpp_list); + break; + case MPP_TWSI: + dove_mpp_twsi_set(*mpp_list); + break; + } + } + mpp_list++; + } +} diff --git a/arch/arm/cpu/armv7/dove/timer.c b/arch/arm/cpu/armv7/dove/timer.c new file mode 100644 index 0000000..3055369 --- /dev/null +++ b/arch/arm/cpu/armv7/dove/timer.c @@ -0,0 +1,176 @@ +/* + * Marvell Dove SoC timer + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/dove.h> + +#define UBOOT_CNTR 0 /* counter to use for uboot timer */ + +/* Timer reload and current value registers */ +struct dovetmr_val { + u32 reload; /* Timer reload reg */ + u32 val; /* Timer value reg */ +}; + +/* Timer registers */ +struct dovetmr_registers { + u32 ctrl; /* Timer control reg */ + u32 pad[3]; + struct dovetmr_val tmr[2]; + u32 wdt_reload; + u32 wdt_val; +}; + +struct dovetmr_registers *dovetmr_regs = + (struct dovetmr_registers *)DOVE_TIMER_BASE; + +/* + * ARM Timers Registers Map + */ +#define CNTMR_CTRL_REG &dovetmr_regs->ctrl +#define CNTMR_RELOAD_REG(tmrnum) &dovetmr_regs->tmr[tmrnum].reload +#define CNTMR_VAL_REG(tmrnum) &dovetmr_regs->tmr[tmrnum].val + +/* + * ARM Timers Control Register + * CPU_TIMERS_CTRL_REG (CTCR) + */ +#define CTCR_ARM_TIMER_EN_OFFS(cntr) (cntr * 2) +#define CTCR_ARM_TIMER_EN_MASK(cntr) (1 << CTCR_ARM_TIMER_EN_OFFS) +#define CTCR_ARM_TIMER_EN(cntr) (1 << CTCR_ARM_TIMER_EN_OFFS(cntr)) +#define CTCR_ARM_TIMER_DIS(cntr) (0 << CTCR_ARM_TIMER_EN_OFFS(cntr)) + +#define CTCR_ARM_TIMER_AUTO_OFFS(cntr) ((cntr * 2) + 1) +#define CTCR_ARM_TIMER_AUTO_MASK(cntr) (1 << 1) +#define CTCR_ARM_TIMER_AUTO_EN(cntr) (1 << CTCR_ARM_TIMER_AUTO_OFFS(cntr)) +#define CTCR_ARM_TIMER_AUTO_DIS(cntr) (0 << CTCR_ARM_TIMER_AUTO_OFFS(cntr)) + +/* + * ARM Timer\Watchdog Reload Register + * CNTMR_RELOAD_REG (TRR) + */ +#define TRG_ARM_TIMER_REL_OFFS 0 +#define TRG_ARM_TIMER_REL_MASK 0xffffffff + +/* + * ARM Timer\Watchdog Register + * CNTMR_VAL_REG (TVRG) + */ +#define TVR_ARM_TIMER_OFFS 0 +#define TVR_ARM_TIMER_MASK 0xffffffff +#define TVR_ARM_TIMER_MAX 0xffffffff +#define TIMER_LOAD_VAL 0xffffffff + +#define READ_TIMER (readl(CNTMR_VAL_REG(UBOOT_CNTR)) / \ + (CONFIG_SYS_TCLK / 1000)) + +DECLARE_GLOBAL_DATA_PTR; + +#define timestamp gd->arch.tbl +#define lastdec gd->arch.lastinc + +ulong get_timer_masked(void) +{ + ulong now = READ_TIMER; + + if (lastdec >= now) { + /* normal mode */ + timestamp += lastdec - now; + } else { + /* we have an overflow ... */ + timestamp += lastdec + + (TIMER_LOAD_VAL / (CONFIG_SYS_TCLK / 1000)) - now; + } + lastdec = now; + + return timestamp; +} + +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +void __udelay(unsigned long usec) +{ + uint current; + ulong delayticks; + + current = readl(CNTMR_VAL_REG(UBOOT_CNTR)); + delayticks = (usec * (CONFIG_SYS_TCLK / 1000000)); + + if (current < delayticks) { + delayticks -= current; + do {} while (readl(CNTMR_VAL_REG(UBOOT_CNTR)) < current); + do {} while ((TIMER_LOAD_VAL - delayticks) < + readl(CNTMR_VAL_REG(UBOOT_CNTR))); + } else { + do {} while (readl(CNTMR_VAL_REG(UBOOT_CNTR)) > + (current - delayticks)); + } +} + +/* + * init the counter + */ +int timer_init(void) +{ + unsigned int cntmrctrl; + + /* load value into timer */ + writel(TIMER_LOAD_VAL, CNTMR_RELOAD_REG(UBOOT_CNTR)); + writel(TIMER_LOAD_VAL, CNTMR_VAL_REG(UBOOT_CNTR)); + + /* enable timer in auto reload mode */ + cntmrctrl = readl(CNTMR_CTRL_REG); + cntmrctrl |= CTCR_ARM_TIMER_EN(UBOOT_CNTR); + cntmrctrl |= CTCR_ARM_TIMER_AUTO_EN(UBOOT_CNTR); + writel(cntmrctrl, CNTMR_CTRL_REG); + + /* init the timestamp and lastdec value */ + lastdec = READ_TIMER; + timestamp = 0; + + return 0; +} + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On ARM it just returns the timer value. + */ +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + return (ulong)CONFIG_SYS_HZ; +} diff --git a/arch/arm/cpu/armv7/dove/usb.c b/arch/arm/cpu/armv7/dove/usb.c new file mode 100644 index 0000000..1b932db --- /dev/null +++ b/arch/arm/cpu/armv7/dove/usb.c @@ -0,0 +1,101 @@ +/* + * Marvell Dove SoC USB PHY init + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> + +/* Dove USB2.0 PHY registers */ +#define USB20_POWER_CTRL ((base) + 0x400) +#define USB20_PHY_PLL_CTRL ((base) + 0x410) +#define PHY_PLL_VCO_RECALIBRATE (1 << 21) +#define USB20_PHY_TX_CTRL ((base) + 0x420) +#define PHY_TX_HS_STRESS_CTRL (1 << 31) +#define PHY_TX_BLOCK_EN (1 << 21) +#define PHY_TX_IMP_CAL_VTH(x) (x << 14) +#define PHY_TX_IMP_CAL_VTH_MASK PHY_TX_IMP_CAL_VTH(0x7) +#define PHY_TX_RCAL_START (1 << 12) +#define PHY_TX_LOWVDD_EN (1 << 11) +#define USB20_PHY_RX_CTRL ((base) + 0x430) +#define PHY_RX_EDGE_DET(x) (x << 26) +#define PHY_RX_EDGE_DET_MASK PHY_RX_EDGE_DET(0x3) +#define PHY_RX_CDR_FASTLOCK_EN (1 << 21) +#define PHY_RX_SQ_LENGTH(x) (x << 15) +#define PHY_RX_SQ_LENGTH_MASK PHY_RX_SQ_LENGTH(0x3) +#define PHY_RX_SQ_THRESH(x) (x << 4) +#define PHY_RX_SQ_THRESH_MASK PHY_RX_SQ_THRESH(0xf) +#define PHY_RX_LPF_COEFF(x) (x << 2) +#define PHY_RX_LPF_COEFF_MASK PHY_RX_LPF_COEFF(0x3) +#define USB20_PHY_IVREF_CTRL ((base) + 0x440) +#define PHY_IVREF_TXVDD12(x) (x << 8) +#define PHY_IVREF_TXVDD12_MASK PHY_IVREF_TXVDD12(0x3) +#define USB20_PHY_TESTGRP_CTRL ((base) + 0x450) +#define PHY_TESTGRP_SQ_RST+ +void dove_ehci_phy_init(int port) +{ + u32 base = (port == 0) ? DOVE_USB20_0_BASE : DOVE_USB20_1_BASE; + u32 reg; + + /* USB PHY PLL control */ + reg = readl(USB20_PHY_PLL_CTRL); + writel(reg | PHY_PLL_VCO_RECALIBRATE, USB20_PHY_PLL_CTRL); + udelay(100); + writel(reg & ~PHY_PLL_VCO_RECALIBRATE, USB20_PHY_PLL_CTRL); + + /* USB PHY Tx control */ + reg = readl(USB20_PHY_TX_CTRL); + reg &= ~PHY_TX_IMP_CAL_VTH_MASK; + reg |= PHY_TX_IMP_CAL_VTH(0x5); + reg |= PHY_TX_LOWVDD_EN; + reg |= PHY_TX_RCAL_START; + reg |= PHY_TX_BLOCK_EN; + reg |= PHY_TX_HS_STRESS_CTRL; + writel(reg, USB20_PHY_TX_CTRL); + udelay(100); + writel(reg & ~PHY_TX_RCAL_START, USB20_PHY_TX_CTRL); + + /* USB PHY RX control */ + reg = readl(USB20_PHY_RX_CTRL); + reg &= ~(PHY_RX_LPF_COEFF_MASK | PHY_RX_SQ_THRESH_MASK | + PHY_RX_SQ_LENGTH_MASK | PHY_RX_EDGE_DET_MASK); + reg |= PHY_RX_LPF_COEFF(0x1); + reg |= PHY_RX_SQ_THRESH(0xc); + reg |= PHY_RX_SQ_LENGTH(0x1); + reg |= PHY_RX_EDGE_DET(0x0); + reg &= ~PHY_RX_CDR_FASTLOCK_EN; + writel(reg, USB20_PHY_RX_CTRL); + + /* USB PHY IVREF control */ + reg = readl(USB20_PHY_IVREF_CTRL); + reg &= ~PHY_IVREF_TXVDD12_MASK; + reg |= PHY_IVREF_TXVDD12(0x3); + writel(reg, USB20_PHY_IVREF_CTRL); + + /* USB PHY TEST GROUP control */ + reg = readl(USB20_PHY_TESTGRP_CTRL); + reg &= ~PHY_TESTGRP_SQ_RST; + writel(reg, USB20_PHY_TESTGRP_CTRL); +} diff --git a/arch/arm/include/asm/arch-dove/config.h b/arch/arm/include/asm/arch-dove/config.h new file mode 100644 index 0000000..38bf6ce --- /dev/null +++ b/arch/arm/include/asm/arch-dove/config.h @@ -0,0 +1,153 @@ +/* + * Marvell SoC config + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVE_CONFIG_H +#define _DOVE_CONFIG_H + +#include <asm/arch/dove.h> + +#define CONFIG_ARMV7 /* Basic Architecture */ +#define CONFIG_DOVE /* SOC Family Name */ +#define CONFIG_SHEEVA_88SV581 /* CPU Core subversion */ +#define CONFIG_SYS_CACHELINE_SIZE 32 + /* default Dcache Line length for Dove */ +#define CONFIG_SYS_ARM_CACHE_WRITETHROUGH +#define CONFIG_SYS_DCACHE_OFF /* Disable DCache by default */ + +/* + * By default kwbimage.cfg from board specific folder is used + * If for some board, different configuration file need to be used, + * CONFIG_SYS_KWD_CONFIG should be defined in board specific header file + */ +#ifndef CONFIG_SYS_KWD_CONFIG +#define CONFIG_SYS_KWD_CONFIG $(SRCTREE)/$(CONFIG_BOARDDIR)/kwbimage.cfg +#endif /* CONFIG_SYS_KWD_CONFIG */ + +/* Dove has 2k of Security SRAM, use it for SP */ +#define CONFIG_SYS_INIT_SP_ADDR 0xC8012000 +#define CONFIG_NR_DRAM_BANKS_MAX 2 + +#define CONFIG_I2C_MVTWSI_BASE DOVE_TWSI_BASE +#define MV_UART_CONSOLE_BASE DOVE_UART0_BASE +#define MV_SATA_BASE DOVE_SATA_BASE +#define MV_SATA_PORT0_OFFSET DOVE_SATA_PORT0_OFFSET + +/* + * NAND configuration + */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_KIRKWOOD 1 +#define CONFIG_SYS_NAND_BASE 0xD8000000 /* MV_DEFADR_NANDF */ +#define NAND_ALLOW_ERASE_ALL 1 +#endif + +/* + * SPI Flash configuration + */ +#ifdef CONFIG_CMD_SF +#define CONFIG_HARD_SPI 1 +#define CONFIG_KIRKWOOD_SPI 1 +#ifndef CONFIG_ENV_SPI_BUS +# define CONFIG_ENV_SPI_BUS 0 +#endif +#ifndef CONFIG_ENV_SPI_CS +# define CONFIG_ENV_SPI_CS 0 +#endif +#ifndef CONFIG_ENV_SPI_MAX_HZ +# define CONFIG_ENV_SPI_MAX_HZ 25000000 +#endif +#endif + +/* + * Ethernet Driver configuration + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_CMD_MII +#define CONFIG_NETCONSOLE /* include NetConsole support */ +#define CONFIG_PHYLIB +#define CONFIG_MVGBE /* Enable Marvell Gbe Controller Driver */ +#define CONFIG_SYS_FAULT_ECHO_LINK_DOWN /* detect link using phy */ +#define CONFIG_ENV_OVERWRITE /* ethaddr can be reprogrammed */ +#endif /* CONFIG_CMD_NET */ + +/* + * SDHCI + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_MMC +#define CONFIG_MMC_SDMA +#define CONFIG_SDHCI +#define CONFIG_DOVE_SDHCI /* Enable Dove SDHCI controller driver */ +#define CONFIG_MMC_SDHCI_IO_ACCESSORS +#define CONFIG_SYS_MMC_MAX_DEVICE 2 +#endif + +/* + * USB/EHCI + */ +#ifdef CONFIG_CMD_USB +#define CONFIG_USB_EHCI_MARVELL +#define CONFIG_EHCI_IS_TDI +#endif /* CONFIG_CMD_USB */ + +/* + * IDE Support on SATA ports + */ +#ifdef CONFIG_CMD_IDE +#define __io +#define CONFIG_CMD_EXT2 +#define CONFIG_MVSATA_IDE +#define CONFIG_IDE_PREINIT +#define CONFIG_MVSATA_IDE_USE_PORT1 +/* Needs byte-swapping for ATA data register */ +#define CONFIG_IDE_SWAP_IO +/* Data, registers and alternate blocks are at the same offset */ +#define CONFIG_SYS_ATA_DATA_OFFSET (0x0100) +#define CONFIG_SYS_ATA_REG_OFFSET (0x0100) +#define CONFIG_SYS_ATA_ALT_OFFSET (0x0100) +/* Each 8-bit ATA register is aligned to a 4-bytes address */ +#define CONFIG_SYS_ATA_STRIDE 4 +/* Controller supports 48-bits LBA addressing */ +#define CONFIG_LBA48 +#define CONFIG_SYS_64BIT_LBA +/* CONFIG_CMD_IDE requires some #defines for ATA registers */ +#define CONFIG_SYS_IDE_MAXBUS 2 +#define CONFIG_SYS_IDE_MAXDEVICE 2 +/* ATA registers base is at SATA controller base */ +#define CONFIG_SYS_ATA_BASE_ADDR MV_SATA_BASE +#endif /* CONFIG_CMD_IDE */ + +/* + * I2C related stuff + */ +#ifdef CONFIG_CMD_I2C +#ifndef CONFIG_SOFT_I2C +#define CONFIG_I2C_MVTWSI +#endif +#define CONFIG_SYS_I2C_SLAVE 0x0 +#define CONFIG_SYS_I2C_SPEED 100000 +#endif + +#endif /* _DOVE_CONFIG_H */ diff --git a/arch/arm/include/asm/arch-dove/cpu.h b/arch/arm/include/asm/arch-dove/cpu.h new file mode 100644 index 0000000..718dd59 --- /dev/null +++ b/arch/arm/include/asm/arch-dove/cpu.h @@ -0,0 +1,204 @@ +/* + * Marvell Dove SoC CPU + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVECPU_H +#define _DOVECPU_H + +#include <asm/system.h> + +#ifndef __ASSEMBLY__ + +#define DOVECPU_WIN_CTRL_DATA(size, target, attr, en) (en | (target << 4) \ + | (attr << 8) | (dove_winctrl_calcsize(size) << 16)) + +#define DOVEGBE_PORT_SERIAL_CONTROL1_REG (DOVE_EGIGA_BASE + 0x44c) +#define DOVE_REG_PCIE_DEVID (DOVE_REG_PCIE0_BASE + 0x00) +#define DOVE_REG_PCIE_REVID (DOVE_REG_PCIE0_BASE + 0x08) +#define DOVE_REG_SYSRST_CNT (DOVE_MPP_BASE + 0x50) +#define SYSRST_CNT_1SEC_VAL (25*1000000) +#define DOVE_REG_MPP_OUT_DRV_REG (DOVE_MPP_BASE + 0xE0) + +enum memory_bank { + BANK0, + BANK1, +}; + +enum dovecpu_winen { + DOVECPU_WIN_DISABLE, + DOVECPU_WIN_ENABLE +}; + +enum dovecpu_target { + DOVECPU_TARGET_DRAM = 0x0, + DOVECPU_TARGET_SASRAM = 0x3, + DOVECPU_TARGET_NAND = 0xc, + DOVECPU_TARGET_PMURAM = 0xd, + DOVECPU_TARGET_PCIE0 = 0x4, + DOVECPU_TARGET_PCIE1 = 0x8, + DOVECPU_TARGET_SPI = 0x1, + DOVECPU_TARGET_BOOTROM = 0x1, +}; + +enum dovecpu_attrib { + DOVECPU_ATTR_DRAM = 0x00, + DOVECPU_ATTR_SASRAM = 0x00, + DOVECPU_ATTR_NAND = 0x00, + DOVECPU_ATTR_PMURAM = 0x00, + DOVECPU_ATTR_PCIE_IO = 0xe0, + DOVECPU_ATTR_PCIE_MEM = 0xe8, + DOVECPU_ATTR_SPI0 = 0xfe, + DOVECPU_ATTR_SPI1 = 0xfb, + DOVECPU_ATTR_BOOTROM = 0xfd, +}; + +enum dovecpu_part { + DOVECPU_PART_SHEEVA = 0x581, +}; + +enum dovesoc_devid { + DOVESOC_DEVID_F6781 = 0x6781, + DOVESOC_DEVID_AP510 = 0x0510, +}; + +enum dovesoc_revid { + DOVESOC_REVID_Z0 = 0, + DOVESOC_REVID_Z1 = 1, + DOVESOC_REVID_Y0 = 2, + DOVESOC_REVID_Y1 = 3, + DOVESOC_REVID_X0 = 4, + DOVESOC_REVID_A0 = 6, + DOVESOC_REVID_A1 = 7, +}; + +/* + * Default Device Address MAP BAR values + */ +#define DOVE_DEFADR_PCIE0_MEM 0xe0000000 +#define DOVE_DEFADR_PCIE0_IO 0xf2000000 +#define DOVE_DEFADR_PCIE0_IO_REMAP 0x00000000 +#define DOVE_DEFADR_PCIE1_MEM 0xe8000000 +#define DOVE_DEFADR_PCIE1_IO 0xf2100000 +#define DOVE_DEFADR_PCIE1_IO_REMAP 0x00100000 +#define DOVE_DEFADR_SASRAM 0xc8000000 +#define DOVE_DEFADR_BOOTROM 0xf8000000 +#define DOVE_DEFADR_PMURAM 0xf0000000 + +/* + * ARM CPUID register + */ +#define ARM_ID_REVISION_OFFSET 0 +#define ARM_ID_REVISION_MASK 0xf +#define ARM_ID_PARTNUM_OFFSET 4 +#define ARM_ID_PARTNUM_MASK 0xfff +#define ARM_ID_ARCH_OFFSET 16 +#define ARM_ID_ARCH_MASK 0xf +#define ARM_ID_VAR_OFFSET 20 +#define ARM_ID_VAR_MASK 0xf +#define ARM_ID_ASCII_OFFSET 24 +#define ARM_ID_ASCII_MASK 0xff + +/* + * read feroceon/sheeva core extra feature register + * using co-proc instruction + */ +static inline unsigned int readfr_extra_feature_reg(void) +{ + unsigned int val; + asm volatile ("mrc p15, 1, %0, c15, c1, 0 @ readfr exfr" : "=r" + (val) : : "cc"); + return val; +} + +/* + * write feroceon/sheeva core extra feature register + * using co-proc instruction + */ +static inline void writefr_extra_feature_reg(unsigned int val) +{ + asm volatile ("mcr p15, 1, %0, c15, c1, 0 @ writefr exfr" : : "r" + (val) : "cc"); + isb(); +} + +/* + * Downstream Bridge Registers + */ +struct dovewin_registers { + u32 ctrl; + u32 base; + u32 remap_lo; + u32 remap_hi; +}; + +/* + * CPU control and status Registers + */ +struct dovecpu_registers { + u32 config; /* 0x20100 */ + u32 ctrl_stat; /* 0x20104 */ + u32 rstoutn_mask; /* 0x20108 */ + u32 sys_soft_rst; /* 0x2010C */ + u32 bridge_cause_irq; /* 0x20110 */ + u32 bridge_mask_irq; /* 0x20114 */ + u32 pad1; + u32 pmu_ctrl; /* 0x2011c */ +}; + +/* + * GPIO 0/1 Registers + * GPIO 2 Registers (no datain/irq) + */ +struct dovegpio_registers { + u32 dout; + u32 oe; + u32 blink_en; + u32 din_pol; + u32 din; + u32 irq_cause; + u32 irq_mask; + u32 irq_level; +}; + +struct dove_gpio_init { + u32 val0; + u32 val1; + u32 val2; + u32 oe0_n; + u32 oe1_n; + u32 oe2_n; +}; + +/* + * functions + */ +void reset_cpu(unsigned long ignored); +unsigned char get_random_hex(void); +u32 dove_dram_start(enum memory_bank bank); +u32 dove_dram_size(enum memory_bank bank); +int dove_config_adr_windows(void); +void dove_init_gpio(struct dove_gpio_init *); +unsigned int dove_winctrl_calcsize(unsigned int sizeval); + +#endif /* __ASSEMBLY__ */ +#endif /* _DOVECPU_H */ diff --git a/arch/arm/include/asm/arch-dove/dove.h b/arch/arm/include/asm/arch-dove/dove.h new file mode 100644 index 0000000..f310719 --- /dev/null +++ b/arch/arm/include/asm/arch-dove/dove.h @@ -0,0 +1,98 @@ +/* + * Marvell Dove SoC register offsets and config + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVE_H +#define _DOVE_H + +/* Dove TCLK is fixed to 166MHz */ +#define CONFIG_SYS_TCLK 166666667 + +/* SOC specific definitions */ +#define DOVE_PREMAP_REGS_PHYS_BASE 0xd0000000 +#define DOVE_PREMAP_INT_REGS_BASE_ADDR (DOVE_PREMAP_REGS_PHYS_BASE + 0x20080) +#define DOVE_PREMAP_MC_DECODE_REG (DOVE_PREMAP_REGS_PHYS_BASE + 0x800010) + +#define DOVE_SB_REGS_PHYS_BASE 0xf1000000 +#define DOVE_NB_REGS_PHYS_BASE 0xf1800000 +#define DOVE_REGISTER(x) (DOVE_SB_REGS_PHYS_BASE + x) + +#define DOVE_AXI_CTRL_REG (DOVE_REGISTER(0xd0224)) +#define DOVE_CPU_CTRL_REG (DOVE_REGISTER(0xd025c)) +#define DOVE_MC_CTRL_REG (DOVE_REGISTER(0xd0260)) +#define DOVE_MC_DECODE_REG (DOVE_REGISTER(0x800010)) + +#define DOVE_SPI_BASE (DOVE_REGISTER(0x10600)) +#define DOVE_TWSI_BASE (DOVE_REGISTER(0x11000)) +#define DOVE_UART0_BASE (DOVE_REGISTER(0x12000)) +#define DOVE_UART1_BASE (DOVE_REGISTER(0x12100)) +#define DOVE_UART2_BASE (DOVE_REGISTER(0x12200)) +#define DOVE_UART3_BASE (DOVE_REGISTER(0x12300)) +#define DOVE_CPU_WIN_BASE (DOVE_REGISTER(0x20000)) +#define DOVE_CPU_REG_BASE (DOVE_REGISTER(0x20100)) +#define DOVE_TIMER_BASE (DOVE_REGISTER(0x20300)) +#define DOVE_REG_PCIE0_BASE (DOVE_REGISTER(0x40000)) +#define DOVE_REG_PCIE1_BASE (DOVE_REGISTER(0x80000)) +#define DOVE_USB20_0_BASE (DOVE_REGISTER(0x50000)) +#define DOVE_USB20_1_BASE (DOVE_REGISTER(0x51000)) +#define DOVE_EGIGA_BASE (DOVE_REGISTER(0x72000)) +#define DOVE_SDIO1_BASE (DOVE_REGISTER(0x90000)) +#define DOVE_SDIO0_BASE (DOVE_REGISTER(0x92000)) +#define DOVE_CAMERA_BASE (DOVE_REGISTER(0x94000)) +#define DOVE_SATA_BASE (DOVE_REGISTER(0xa0000)) +#define DOVE_NANDF_BASE (DOVE_REGISTER(0xc0000)) +#define DOVE_PMU_BASE (DOVE_REGISTER(0xd0000)) +#define DOVE_MPP_BASE (DOVE_REGISTER(0xd0200)) +#define DOVE_GPIO0_BASE (DOVE_REGISTER(0xd0400)) +#define DOVE_GPIO1_BASE (DOVE_REGISTER(0xd0420)) +#define DOVE_RTC_BASE (DOVE_REGISTER(0xd8500)) +#define DOVE_AC97_BASE (DOVE_REGISTER(0xe0000)) +#define DOVE_PDMA_BASE (DOVE_REGISTER(0xe4000)) +#define DOVE_GPIO2_BASE (DOVE_REGISTER(0xe8400)) +#define DOVE_SSP_BASE (DOVE_REGISTER(0xec000)) + +/* Dove Sata controller has one port */ +#define DOVE_SATA_PORT0_OFFSET 0x2000 + +/* Dove GbE controller has one port */ +#define MAX_MVGBE_DEVS 1 +#define MVGBE0_BASE DOVE_EGIGA_BASE + +/* Dove USB Host controller */ +#define MVUSB0_BASE DOVE_USB20_0_BASE +#define MVUSB0_CPU_ATTR_DRAM_CS0 DOVECPU_ATTR_DRAM +#define MVUSB0_CPU_ATTR_DRAM_CS1 DOVECPU_ATTR_DRAM +#define MVUSB0_CPU_ATTR_DRAM_CS2 DOVECPU_WIN_DISABLE +#define MVUSB0_CPU_ATTR_DRAM_CS3 DOVECPU_WIN_DISABLE +#define MVUSB1_BASE DOVE_USB20_1_BASE +#define MVUSB1_CPU_ATTR_DRAM_CS0 DOVECPU_ATTR_DRAM +#define MVUSB1_CPU_ATTR_DRAM_CS1 DOVECPU_ATTR_DRAM +#define MVUSB1_CPU_ATTR_DRAM_CS2 DOVECPU_WIN_DISABLE +#define MVUSB1_CPU_ATTR_DRAM_CS3 DOVECPU_WIN_DISABLE + +/* Dove CPU memory windows */ +#define MVCPU_WIN_CTRL_DATA DOVECPU_WIN_CTRL_DATA +#define MVCPU_WIN_ENABLE DOVECPU_WIN_ENABLE +#define MVCPU_WIN_DISABLE DOVECPU_WIN_DISABLE + +#endif diff --git a/arch/arm/include/asm/arch-dove/gpio.h b/arch/arm/include/asm/arch-dove/gpio.h new file mode 100644 index 0000000..adcc91a --- /dev/null +++ b/arch/arm/include/asm/arch-dove/gpio.h @@ -0,0 +1,35 @@ +/* + * Marvell Dove SoC gpio + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef __ARCH_DOVE_GPIO_H +#define __ARCH_DOVE_GPIO_H + +#include <kw_gpio.h> + +#define GPIO_MAX 70 +#define GPIO_BASE(pin) (((pin) >= 64) ? DOVE_GPIO2_BASE : \ + ((pin) >= 32) ? DOVE_GPIO1_BASE : \ + DOVE_GPIO0_BASE) + +#endif diff --git a/arch/arm/include/asm/arch-dove/mpp.h b/arch/arm/include/asm/arch-dove/mpp.h new file mode 100644 index 0000000..1279ac2 --- /dev/null +++ b/arch/arm/include/asm/arch-dove/mpp.h @@ -0,0 +1,283 @@ +/* + * Marvell Dove SoC pinmux + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVE_MPP_H +#define _DOVE_MPP_H + +#define DOVE_GPI (1 << 0) +#define DOVE_GPO (1 << 1) +#define DOVE_GPIO (DOVE_GPO | DOVE_GPI) + +#define MPP(_num, _sel, _gpio) ( \ + /* MPP number */ ((_num) & 0xff) | \ + /* MPP select value */ (((_sel) & 0x1f) << 8) | \ + /* is gpio config */ ((!!(_gpio)) << 15)) + +/* MPP0-15 allow PMU function */ +#define MPP_PMU_MAX 15 +#define PMU (0x10) +/* MPP0-23 have standard mpp register layout */ +#define MPP_STD_MAX 23 + +#define MPP0 0 +#define MPP0_GPIO MPP(0, 0x0, 1) +#define MPP0_UART2_RTS MPP(0, 0x2, 0) +#define MPP0_SDIO0_CD MPP(0, 0x3, 0) +#define MPP0_LCD0_PWM MPP(0, 0xf, 0) +#define MPP0_PMU MPP(0, PMU, 0) + +#define MPP1 1 +#define MPP1_GPIO MPP(1, 0x0, 1) +#define MPP1_UART2_CTS MPP(1, 0x2, 0) +#define MPP1_SDIO0_WP MPP(1, 0x3, 0) +#define MPP1_LCD1_PWM MPP(1, 0xf, 0) +#define MPP1_PMU MPP(1, PMU, 0) + +#define MPP2 2 +#define MPP2_GPIO MPP(2, 0x0, 1) +#define MPP2_SATA_PRSNT MPP(2, 0x1, 0) +#define MPP2_UART2_TXD MPP(2, 0x2, 0) +#define MPP2_SDIO0_BUSPWR MPP(2, 0x3, 0) +#define MPP2_UART1_RTS MPP(2, 0x4, 0) +#define MPP2_PMU MPP(2, PMU, 0) + +#define MPP3 3 +#define MPP3_GPIO MPP(3, 0x0, 1) +#define MPP3_SATA_ACT MPP(3, 0x1, 0) +#define MPP3_UART2_RXD MPP(3, 0x2, 0) +#define MPP3_SDIO0_LEDCTRL MPP(3, 0x3, 0) +#define MPP3_UART1_CTS MPP(3, 0x4, 0) +#define MPP3_LCD_SPI_CS1 MPP(3, 0xf, 0) +#define MPP3_PMU MPP(3, PMU, 0) + +#define MPP4 4 +#define MPP4_GPIO MPP(4, 0x0, 1) +#define MPP4_UART3_RTS MPP(4, 0x2, 0) +#define MPP4_SDIO1_CD MPP(4, 0x3, 0) +#define MPP4_SPI1_MISO MPP(4, 0x4, 0) +#define MPP4_PMU MPP(4, PMU, 0) + +#define MPP5 5 +#define MPP5_GPIO MPP(5, 0x0, 1) +#define MPP5_UART3_CTS MPP(5, 0x2, 0) +#define MPP5_SDIO1_WP MPP(5, 0x3, 0) +#define MPP5_SPI1_CS MPP(5, 0x4, 0) +#define MPP5_PMU MPP(5, PMU, 0) + +#define MPP6 6 +#define MPP6_GPIO MPP(6, 0x0, 1) +#define MPP6_UART3_TXD MPP(6, 0x2, 0) +#define MPP6_SDIO1_BUSPWR MPP(6, 0x3, 0) +#define MPP6_SPI1_MOSI MPP(6, 0x4, 0) +#define MPP6_PMU MPP(6, PMU, 0) + +#define MPP7 7 +#define MPP7_GPIO MPP(7, 0x0, 1) +#define MPP7_UART3_RXD MPP(7, 0x2, 0) +#define MPP7_SDIO1_LEDCTRL MPP(7, 0x3, 0) +#define MPP7_SPI1_SCK MPP(7, 0x4, 0) +#define MPP7_PMU MPP(7, PMU, 0) + +#define MPP8 8 +#define MPP8_GPIO MPP(8, 0x0, 1) +#define MPP8_WATCHDOG_RSTOUT MPP(8, 0x1, 0) +#define MPP8_PMU MPP(8, PMU, 0) + +#define MPP9 9 +#define MPP9_GPIO MPP(9, 0x0, 1) +#define MPP9_PEX1_CLKREQ MPP(9, 0x5, 0) +#define MPP9_PMU MPP(9, PMU, 0) + +#define MPP10 10 +#define MPP10_GPIO MPP(10, 0x0, 1) +#define MPP10_SSP_SCLK MPP(10, 0x5, 0) +#define MPP10_PMU MPP(10, PMU, 0) + +#define MPP11 11 +#define MPP11_GPIO MPP(11, 0x0, 1) +#define MPP11_SATA_PRSNT MPP(11, 0x1, 0) +#define MPP11_SATA_ACT MPP(11, 0x2, 0) +#define MPP11_SDIO0_LEDCTRL MPP(11, 0x3, 0) +#define MPP11_SDIO1_LEDCTRL MPP(11, 0x4, 0) +#define MPP11_PEX0_CLKREQ MPP(11, 0x5, 0) +#define MPP11_PMU MPP(11, PMU, 0) + +#define MPP12 12 +#define MPP12_GPIO MPP(12, 0x0, 1) +#define MPP12_SATA_ACT MPP(12, 0x1, 0) +#define MPP12_UART2_RTS MPP(12, 0x2, 0) +#define MPP12_AUDIO0_EXTCLK MPP(12, 0x3, 0) +#define MPP12_SDIO1_CD MPP(12, 0x4, 0) +#define MPP12_PMU MPP(12, PMU, 0) + +#define MPP13 13 +#define MPP13_GPIO MPP(13, 0x0, 1) +#define MPP13_UART2_CTS MPP(13, 0x2, 0) +#define MPP13_AUDIO1_EXTCLK MPP(13, 0x3, 0) +#define MPP13_SDIO1_WP MPP(13, 0x4, 0) +#define MPP13_SSP_EXTCLK MPP(13, 0x5, 0) +#define MPP13_PMU MPP(13, PMU, 0) + +#define MPP14 14 +#define MPP14_GPIO MPP(14, 0x0, 1) +#define MPP14_UART2_TXD MPP(14, 0x2, 0) +#define MPP14_SDIO1_BUSPWR MPP(14, 0x4, 0) +#define MPP14_SSP_TXD MPP(14, 0x5, 0) +#define MPP14_PMU MPP(14, PMU, 0) + +#define MPP15 15 +#define MPP15_GPIO MPP(15, 0x0, 1) +#define MPP15_UART2_RXD MPP(15, 0x2, 0) +#define MPP15_SDIO1_LEDCTRL MPP(15, 0x4, 0) +#define MPP15_SSP_SFRM MPP(15, 0x5, 0) +#define MPP15_PMU MPP(15, PMU, 0) + +#define MPP16 16 +#define MPP16_GPIO MPP(16, 0x0, 1) +#define MPP16_UART3_RTS MPP(16, 0x2, 0) +#define MPP16_SDIO0_CD MPP(16, 0x3, 0) +#define MPP16_LCD_SPI_CS1 MPP(16, 0x4, 0) +#define MPP16_AC97_SDI1 MPP(16, 0x5, 0) + +#define MPP17 17 +#define MPP17_GPIO MPP(17, 0x0, 1) +#define MPP17_AC97_SYSCLKO MPP(17, 0x1, 0) +#define MPP17_UART3_CTS MPP(17, 0x2, 0) +#define MPP17_SDIO0_WP MPP(17, 0x3, 0) +#define MPP17_TWSI_SDA MPP(17, 0x4, 0) +#define MPP17_AC97_SDI2 MPP(17, 0x5, 0) + +#define MPP18 18 +#define MPP18_GPIO MPP(18, 0x0, 1) +#define MPP18_UART3_TXD MPP(18, 0x2, 0) +#define MPP18_SDIO0_BUSPWR MPP(18, 0x3, 0) +#define MPP18_LCD0_PWM MPP(18, 0x4, 0) +#define MPP18_AC97_SDI3 MPP(18, 0x5, 0) + +#define MPP19 19 +#define MPP19_GPIO MPP(19, 0x0, 1) +#define MPP19_UART3_RXD MPP(19, 0x2, 0) +#define MPP19_SDIO0_LEDCTRL MPP(19, 0x3, 0) +#define MPP19_TWSI_SCK MPP(19, 0x4, 0) + +#define MPP20 20 +#define MPP20_GPIO MPP(20, 0x0, 1) +#define MPP20_AC97_SYSCLKO MPP(20, 0x1, 0) +#define MPP20_LCD_SPI_MISO MPP(20, 0x2, 0) +#define MPP20_SDIO1_CD MPP(20, 0x3, 0) +#define MPP20_SDIO0_CD MPP(20, 0x5, 0) +#define MPP20_SPI1_MISO MPP(20, 0x6, 0) + +#define MPP21 21 +#define MPP21_GPIO MPP(21, 0x0, 1) +#define MPP21_UART1_RTS MPP(21, 0x1, 0) +#define MPP21_LCD_SPI_CS0 MPP(21, 0x2, 0) +#define MPP21_SDIO1_WP MPP(21, 0x3, 0) +#define MPP21_SSP_SFRM MPP(21, 0x4, 0) +#define MPP21_SDIO0_WP MPP(21, 0x5, 0) +#define MPP21_SPI1_CS MPP(21, 0x6, 0) + +#define MPP22 22 +#define MPP22_GPIO MPP(22, 0x0, 1) +#define MPP22_UART1_CTS MPP(22, 0x1, 0) +#define MPP22_LCD_SPI_MOSI MPP(22, 0x2, 0) +#define MPP22_SDIO1_BUSPWR MPP(22, 0x3, 0) +#define MPP22_SSP_TXD MPP(22, 0x4, 0) +#define MPP22_SDIO0_BUSPWR MPP(22, 0x5, 0) +#define MPP22_SPI1_MOSI MPP(22, 0x6, 0) + +#define MPP23 23 +#define MPP23_GPIO MPP(23, 0x0, 1) +#define MPP23_LCD_SPI_SCK MPP(23, 0x2, 0) +#define MPP23_SDIO1_LEDCTRL MPP(23, 0x3, 0) +#define MPP23_SSP_SCLK MPP(23, 0x4, 0) +#define MPP23_SDIO0_LEDCTRL MPP(23, 0x5, 0) +#define MPP23_SPI1_SCK MPP(23, 0x6, 0) + +/* MPP_CAMERA = MPP[24:39] */ +#define MPP_CAMERA 24 +#define MPP_CAMERA_CAMERA MPP(24, 0x0, 0) +#define MPP_CAMERA_GPIO MPP(24, 0x1, 1) +#define MPP_CAMERA_MAX 39 + +/* MPP_SDIO0 = MPP[40:45] */ +#define MPP_SDIO0 40 +#define MPP_SDIO0_SDIO MPP(40, 0x0, 0) +#define MPP_SDIO0_GPIO MPP(40, 0x1, 1) +#define MPP_SDIO0_MAX 45 + +/* MPP_SDIO1 = MPP[46:51] */ +#define MPP_SDIO1 46 +#define MPP_SDIO1_SDIO MPP(46, 0x0, 0) +#define MPP_SDIO1_GPIO MPP(46, 0x1, 1) +#define MPP_SDIO1_MAX 51 + +/* MPP_AUDIO1 = MPP[52:57] */ +#define MPP_AUDIO1 52 +#define MPP_AUDIO1_I2S_SPDIFO MPP(52, 0x0, 0) +#define MPP_AUDIO1_I2S MPP(52, 0x2, 0) +#define MPP_AUDIO1_SPDIFO MPP(52, 0x8, 0) +#define MPP_AUDIO1_GPIO MPP(52, 0xa, 1) +#define MPP_AUDIO1_TWSI MPP(52, 0xb, 0) +#define MPP_AUDIO1_SSP_SPDIFO MPP(52, 0xc, 0) +#define MPP_AUDIO1_SSP MPP(52, 0xe, 0) +#define MPP_AUDIO1_SSP_TWSI MPP(52, 0xf, 0) +#define MPP_AUDIO1_MAX 57 + +/* MPP_SPI = MPP[58:61] */ +#define MPP_SPI 58 +#define MPP_SPI_SPI MPP(58, 0x0, 0) +#define MPP_SPI_GPIO MPP(58, 0x1, 1) +#define MPP_SPI_MAX 61 + +/* MPP_UART1 = MPP[62:63] */ +#define MPP_UART1 62 +#define MPP_UART1_UART1 MPP(62, 0x0, 0) +#define MPP_UART1_GPIO MPP(62, 0x1, 1) +#define MPP_UART1_MAX 63 + +/* MPP_NAND = MPP[64:71] */ +#define MPP_NAND 64 +#define MPP_NAND_NAND MPP(64, 0x0, 0) +#define MPP_NAND_GPO MPP(64, 0x1, 1) +#define MPP_NAND_MAX 71 + +/* MPP_AUDIO0 = Internal AC97/I2S mux for audio0 pins */ +#define MPP_AUDIO0 72 +#define MPP_AUDIO0_I2S MPP(72, 0x0, 0) +#define MPP_AUDIO0_AC97 MPP(72, 0x1, 0) + +/* MPP_TWSI = Internal TWSI option mux */ +#define MPP_TWSI 73 +#define MPP_TWSI_NONE MPP(73, 0x0, 0) +#define MPP_TWSI_OPTION1 MPP(73, 0x1, 0) +#define MPP_TWSI_OPTION2 MPP(73, 0x2, 0) +#define MPP_TWSI_OPTION3 MPP(73, 0x3, 0) + +#define MPP_MAX MPP_TWSI + +u8 dove_mpp_get_gpio_caps(u8 num); +void dove_mpp_conf(u16 *mpp_list); + +#endif diff --git a/arch/arm/include/asm/arch-dove/usb.h b/arch/arm/include/asm/arch-dove/usb.h new file mode 100644 index 0000000..f288489 --- /dev/null +++ b/arch/arm/include/asm/arch-dove/usb.h @@ -0,0 +1,27 @@ +/* + * Marvell Dove SoC USB + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVEUSB_H +#define _DOVEUSB_H + +void dove_ehci_phy_init(int port); +#endif /* _DOVEUSB_H */
Signed-off-by: Sascha Silbet-uboot@infra-silbe.de
- Marvell SoC config
- Sebastian Hesselbarthsebastian.hesselbarth@gmail.com
- project.
- Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston,
- MA 02110-1301 USA
+#include<asm/arch/dove.h>
- By default kwbimage.cfg from board specific folder is used
- If for some board, different configuration file need to be used,
- CONFIG_SYS_KWD_CONFIG should be defined in board specific header file
Actually, DOVE_DEFADR_SASRAM remaps security SRAM to 0xc8000000. Maybe it just works because addresses are wrapped around each 2k bytes.
I suggest to set the above to 0xc8000800 or use (DOVE_DEFADR_SASRAM | 0x800)
- NAND configuration
Knowing the SoC now better, I can say that NAND controller is kind of different from Kirkwood. Especially, the above NAND_BASE relies on a proper address window remap that is not done yet on Dove init code.
I suggest to remove the whole NAND ifdef above until proper NAND driver is available.
Dove SoC only has a single SATA port, so I guess above defines should be set to 1.
- Marvell Dove SoC CPU
- project.
- MA 02110-1301 USA
+#include<asm/system.h>
+#define DOVECPU_WIN_CTRL_DATA(size, target, attr, en) (en | (target<< 4) \
| (attr<< 8) | (dove_winctrl_calcsize(size)<< 16))
Wherever the above is used or from, don't ask me why I came up with it. Dove has no register to set sysrst_out length.
- Marvell Dove SoC register offsets and config
- project.
- MA 02110-1301 USA
Not entirely true as it is configurable by SAR registers. The only two frequencies allowed are 125MHz and 166MHz above. This is what is given in Dove FS, but there may be other possible (undocumented) frequencies.
DOVE_SPI0_BASE and add DOVE_SPI1_BASE at 0x14600.
Out of curiosity, is the board you are planing to add support for equipped with PCIe slots or anything connected to PCIe?
Thanks for giving the patch set a re-spin.
Sebastian
Dear Sascha Silbe,
In message 1372195668-25496-2-git-send-email-t-uboot@infra-silbe.de you wrote:
This patch adds initial support for the armv7-based Marvell Dove SoC (88AP510).
Signed-off-by: Sascha Silbe t-uboot@infra-silbe.de
v4->v5: some adjustments for the GPIO and SPI driver changes
arch/arm/cpu/armv7/dove/Makefile | 49 +++++ arch/arm/cpu/armv7/dove/cpu.c | 274 +++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/dram.c | 117 ++++++++++++ arch/arm/cpu/armv7/dove/lowlevel_init.S | 83 +++++++++ arch/arm/cpu/armv7/dove/mpp.c | 318 ++++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/dove/timer.c | 176 ++++++++++++++++++ arch/arm/cpu/armv7/dove/usb.c | 101 ++++++++++ arch/arm/include/asm/arch-dove/config.h | 153 +++++++++++++++ arch/arm/include/asm/arch-dove/cpu.h | 204 ++++++++++++++++++++ arch/arm/include/asm/arch-dove/dove.h | 98 ++++++++++ arch/arm/include/asm/arch-dove/gpio.h | 35 ++++ arch/arm/include/asm/arch-dove/mpp.h | 283 ++++++++++++++++++++++++++++ arch/arm/include/asm/arch-dove/usb.h | 27 +++ 13 files changed, 1918 insertions(+)
This patch does not apply:
ERROR: patch seems to be corrupt (line wrapped?) #1269: FILE: arch/arm/include/asm/arch-dove/config.h:100: diff --git a/arch/arm/include/asm/arch-dove/config.h b/arch/arm/include/asm/arch-dove/config.h
Marvell 88AP510 (Armada 510, dove) has two separate USB controllers. Use the index parameter that already gets passed in to calculate the base address of the controller.
Signed-off-by: Sascha Silbe t-uboot@infra-silbe.de --- v4->v5: no changes
drivers/usb/host/ehci-marvell.c | 35 ++++++++++++++++++++++++----------- 1 file changed, 24 insertions(+), 11 deletions(-)
diff --git a/drivers/usb/host/ehci-marvell.c b/drivers/usb/host/ehci-marvell.c index 2b73e4a..d2cf026 100644 --- a/drivers/usb/host/ehci-marvell.c +++ b/drivers/usb/host/ehci-marvell.c @@ -28,7 +28,9 @@ #include "ehci.h" #include <asm/arch/cpu.h>
-#if defined(CONFIG_KIRKWOOD) +#if defined(CONFIG_DOVE) +#include <asm/arch/dove.h> +#elif defined(CONFIG_KIRKWOOD) #include <asm/arch/kirkwood.h> #elif defined(CONFIG_ORION5X) #include <asm/arch/orion5x.h> @@ -36,8 +38,8 @@
-#define rdl(off) readl(MVUSB0_BASE + (off)) -#define wrl(off, val) writel((val), MVUSB0_BASE + (off)) +#define rdl(base, off) readl((base) + (off)) +#define wrl(base, off, val) writel((val), (base) + (off))
#define USB_WINDOW_CTRL(i) (0x320 + ((i) << 4)) #define USB_WINDOW_BASE(i) (0x324 + ((i) << 4)) @@ -46,10 +48,15 @@ DECLARE_GLOBAL_DATA_PTR; /* * USB 2.0 Bridge Address Decoding registers setup */ -static void usb_brg_adrdec_setup(void) +static void usb_brg_adrdec_setup(int index) { int i; u32 size, base, attrib; +#ifdef MVUSB1_BASE + u32 usb_base = (index == 0) ? MVUSB0_BASE : MVUSB1_BASE; +#else + u32 usb_base = MVUSB0_BASE; +#endif
@@ -76,13 +83,13 @@ static void usb_brg_adrdec_setup(void) size = gd->bd->bi_dram[i].size; base = gd->bd->bi_dram[i].start; if ((size) && (attrib)) - wrl(USB_WINDOW_CTRL(i), - MVCPU_WIN_CTRL_DATA(size, USB_TARGET_DRAM, - attrib, MVCPU_WIN_ENABLE)); + wrl(usb_base, USB_WINDOW_CTRL(i), + MVCPU_WIN_CTRL_DATA(size, USB_TARGET_DRAM, + attrib, MVCPU_WIN_ENABLE)); else - wrl(USB_WINDOW_CTRL(i), MVCPU_WIN_DISABLE); + wrl(usb_base, USB_WINDOW_CTRL(i), MVCPU_WIN_DISABLE);
- wrl(USB_WINDOW_BASE(i), base); + wrl(usb_base, USB_WINDOW_BASE(i), base); } }
@@ -92,9 +99,15 @@ static void usb_brg_adrdec_setup(void) */ int ehci_hcd_init(int index, struct ehci_hccr **hccr, struct ehci_hcor **hcor) { - usb_brg_adrdec_setup(); +#ifdef MVUSB1_BASE + u32 usb_base = (index == 0) ? MVUSB0_BASE : MVUSB1_BASE; +#else + u32 usb_base = MVUSB0_BASE; +#endif
- *hccr = (struct ehci_hccr *)(MVUSB0_BASE + 0x100); + usb_brg_adrdec_setup(index); + + *hccr = (struct ehci_hccr *)(usb_base + 0x100); *hcor = (struct ehci_hcor *)((uint32_t) *hccr + HC_LENGTH(ehci_readl(&(*hccr)->cr_capbase)));
Dear Sascha Silbe,
In message 1372195668-25496-3-git-send-email-t-uboot@infra-silbe.de you wrote:
Instead of extending this, can we eventually clean this up and use C structs instead? U-Boot does not allow device accesses through a based plus offset notation.
- u32 usb_base = (index == 0) ? MVUSB0_BASE : MVUSB1_BASE;
+#else
- u32 usb_base = MVUSB0_BASE;
Can we please also avoid this #ifdef's ? Eventually you can use something like "base_0 + index * sizeof(struct usb_something)" ?
Dear Wolfgang Denk,
Wolfgang Denk wd@denx.de writes:
Thanks for the review. I've given the clean-up a stab today, as a separate patch that the CuBox support series can build on.
+#else
The two USB host controllers on Dove are separate entities at different base offsets (0x50000 vs. 0x51000). We could fill up the register struct to have a size of 0x1000, but then the next SoC to be supported could come up with a different offset.
Sascha
Use structs instead of computing offsets for accessing individual registers. The base address of the USB controller is still an offset defined in SoC headers as it can differ between SoCs.
Signed-off-by: Sascha Silbe t-uboot@infra-silbe.de --- Tested on CuBox Pro only.
drivers/usb/host/ehci-marvell.c | 48 +++++++++++++++++++++++++++++------------ 1 file changed, 34 insertions(+), 14 deletions(-)
diff --git a/drivers/usb/host/ehci-marvell.c b/drivers/usb/host/ehci-marvell.c index 2b73e4a..e4d6881 100644 --- a/drivers/usb/host/ehci-marvell.c +++ b/drivers/usb/host/ehci-marvell.c @@ -36,17 +36,35 @@
-#define rdl(off) readl(MVUSB0_BASE + (off)) -#define wrl(off, val) writel((val), MVUSB0_BASE + (off)) - -#define USB_WINDOW_CTRL(i) (0x320 + ((i) << 4)) -#define USB_WINDOW_BASE(i) (0x324 + ((i) << 4)) #define USB_TARGET_DRAM 0x0
+/* USB 2.0 Bridge Address Decoding registers */ +struct mvusb_bad_window_regs { + u32 control; + u32 base; + u32 reserved[2]; +}; + +struct mvusb_bridge_regs { + u32 bridge_control; + u32 reserved1[3]; + u32 int_cause; /* Bridge Interrupt Cause Register */ + u32 int_mask; /* Bridge Interrupt Mask Register */ + u32 reserved2; + u32 error_addr; /* Bridge Error Address Register */ + struct mvusb_bad_window_regs window[4]; +}; + +struct mvusb_regs { + u32 unused1[0x40]; + u32 ehci_regs[0x80]; + struct mvusb_bridge_regs bridge; +}; + /* * USB 2.0 Bridge Address Decoding registers setup */ -static void usb_brg_adrdec_setup(void) +static void usb_brg_adrdec_setup(struct mvusb_regs *usb_base) { int i; u32 size, base, attrib; @@ -75,14 +93,15 @@ static void usb_brg_adrdec_setup(void)
size = gd->bd->bi_dram[i].size; base = gd->bd->bi_dram[i].start; - if ((size) && (attrib)) - wrl(USB_WINDOW_CTRL(i), - MVCPU_WIN_CTRL_DATA(size, USB_TARGET_DRAM, - attrib, MVCPU_WIN_ENABLE)); + if (size && attrib) + writel(MVCPU_WIN_CTRL_DATA(size, USB_TARGET_DRAM, + attrib, MVCPU_WIN_ENABLE), + usb_base->bridge.window[i].control); else - wrl(USB_WINDOW_CTRL(i), MVCPU_WIN_DISABLE); + writel(MVCPU_WIN_DISABLE, + usb_base->bridge.window[i].control);
- wrl(USB_WINDOW_BASE(i), base); + writel(base, usb_base->bridge.window[i].base); } }
@@ -92,9 +111,10 @@ static void usb_brg_adrdec_setup(void) */ int ehci_hcd_init(int index, struct ehci_hccr **hccr, struct ehci_hcor **hcor) { - usb_brg_adrdec_setup(); + struct mvusb_regs *usb_base = (struct mvusb_regs *)MVUSB0_BASE;
- *hccr = (struct ehci_hccr *)(MVUSB0_BASE + 0x100); + usb_brg_adrdec_setup(usb_base); + *hccr = (struct ehci_hccr *)(&usb_base->ehci_regs); *hcor = (struct ehci_hcor *)((uint32_t) *hccr + HC_LENGTH(ehci_readl(&(*hccr)->cr_capbase)));
Dear Sascha Silbe,
- u32 control;
- u32 base;
- u32 reserved[2];
- u32 bridge_control;
- u32 reserved1[3];
- u32 int_cause; /* Bridge Interrupt Cause Register */
- u32 int_mask; /* Bridge Interrupt Mask Register */
- u32 reserved2;
- u32 error_addr; /* Bridge Error Address Register */
- struct mvusb_bad_window_regs window[4];
- u32 unused1[0x40];
- u32 ehci_regs[0x80];
- struct mvusb_bridge_regs bridge;
- USB 2.0 Bridge Address Decoding registers setup
if (size && attrib)
elseusb_base->bridge.window[i].control);
}writel(base, usb_base->bridge.window[i].base);
OK
- struct mvusb_regs *usb_base = (struct mvusb_regs *)MVUSB0_BASE;
- usb_brg_adrdec_setup(usb_base);
- *hccr = (struct ehci_hccr *)(&usb_base->ehci_regs); *hcor = (struct ehci_hcor *)((uint32_t) *hccr + HC_LENGTH(ehci_readl(&(*hccr)->cr_capbase)));
I'd keep this as-is, since the 0x100 is fairy standard offset in the USB case.
Best regards, Marek Vasut
Dear Sascha Silbe,
Dear Wolfgang Denk,
+#ifdef MVUSB1_BASE
+#else
Check drivers/usb/host/ehci-mxs.c for handling of such a case ;-)
The GPIO support of Dove is very similar to that on Kirkwood (and possibly orion5x as well). Instead of duplicating the code, we tweak the Kirkwood driver so it works for Dove, too.
Signed-off-by: Sascha Silbe t-uboot@infra-silbe.de --- v4->v5: Modify Kirkwood driver rather than duplicating it.
The patch description might do with slightly more detail, but I'd like some feedback on the approach first. The patch itself should be pretty self-explanatory.
arch/arm/include/asm/arch-kirkwood/gpio.h | 42 ++------------------- drivers/gpio/kw_gpio.c | 43 +++++++++++----------- .../asm/arch-kirkwood/gpio.h => include/kw_gpio.h | 43 +++++++++++----------- 3 files changed, 47 insertions(+), 81 deletions(-)
diff --git a/arch/arm/include/asm/arch-kirkwood/gpio.h b/arch/arm/include/asm/arch-kirkwood/gpio.h index cd1bc00..8c8f239 100644 --- a/arch/arm/include/asm/arch-kirkwood/gpio.h +++ b/arch/arm/include/asm/arch-kirkwood/gpio.h @@ -20,46 +20,12 @@ * MA 02110-1301 USA */
-/* - * Based on (mostly copied from) plat-orion based Linux 2.6 kernel driver. - * Removed kernel level irq handling. Took some macros from kernel to - * allow build. - * - * Dieter Kiermaier dk-arm-linux@gmx.de - */ +#ifndef __ARCH_KIRKWOOD_GPIO_H +#define __ARCH_KIRKWOOD_GPIO_H
-#ifndef __KIRKWOOD_GPIO_H -#define __KIRKWOOD_GPIO_H - -/* got from kernel include/linux/bitops.h */ -#define BITS_PER_BYTE 8 -#define BITS_TO_LONGS(nr) DIV_ROUND_UP(nr, BITS_PER_BYTE * sizeof(long)) +#include <kw_gpio.h>
#define GPIO_MAX 50 -#define GPIO_OFF(pin) (((pin) >> 5) ? 0x0040 : 0x0000) -#define GPIO_OUT(pin) (KW_GPIO0_BASE + GPIO_OFF(pin) + 0x00) -#define GPIO_IO_CONF(pin) (KW_GPIO0_BASE + GPIO_OFF(pin) + 0x04) -#define GPIO_BLINK_EN(pin) (KW_GPIO0_BASE + GPIO_OFF(pin) + 0x08) -#define GPIO_IN_POL(pin) (KW_GPIO0_BASE + GPIO_OFF(pin) + 0x0c) -#define GPIO_DATA_IN(pin) (KW_GPIO0_BASE + GPIO_OFF(pin) + 0x10) -#define GPIO_EDGE_CAUSE(pin) (KW_GPIO0_BASE + GPIO_OFF(pin) + 0x14) -#define GPIO_EDGE_MASK(pin) (KW_GPIO0_BASE + GPIO_OFF(pin) + 0x18) -#define GPIO_LEVEL_MASK(pin) (KW_GPIO0_BASE + GPIO_OFF(pin) + 0x1c) - -/* - * Kirkwood-specific GPIO API - */ - -void kw_gpio_set_valid(unsigned pin, int mode); -int kw_gpio_is_valid(unsigned pin, int mode); -int kw_gpio_direction_input(unsigned pin); -int kw_gpio_direction_output(unsigned pin, int value); -int kw_gpio_get_value(unsigned pin); -void kw_gpio_set_value(unsigned pin, int value); -void kw_gpio_set_blink(unsigned pin, int blink); -void kw_gpio_set_unused(unsigned pin); - -#define GPIO_INPUT_OK (1 << 0) -#define GPIO_OUTPUT_OK (1 << 1) +#define GPIO_BASE(pin) (((pin) >> 5) ? (KW_GPIO0_BASE + 0x0040) : KW_GPIO0_BASE)
#endif diff --git a/drivers/gpio/kw_gpio.c b/drivers/gpio/kw_gpio.c index 51a826d..d6fdb69 100644 --- a/drivers/gpio/kw_gpio.c +++ b/drivers/gpio/kw_gpio.c @@ -1,7 +1,11 @@ /* - * arch/arm/plat-orion/gpio.c + * Marvell Dove and Kirkwood SoC GPIO handling * - * Marvell Orion SoC GPIO handling. + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * Based on (mostly copied from) plat-orion based Linux 2.6 kernel driver. + * Removed orion_gpiochip struct and kernel level irq handling. + * Dieter Kiermaier dk-arm-linux@gmx.de * * See file CREDITS for list of people who contributed to this * project. @@ -22,58 +26,54 @@ * MA 02110-1301 USA */
-/* - * Based on (mostly copied from) plat-orion based Linux 2.6 kernel driver. - * Removed orion_gpiochip struct and kernel level irq handling. - * - * Dieter Kiermaier dk-arm-linux@gmx.de - */ - #include <common.h> #include <asm/bitops.h> #include <asm/io.h> -#include <asm/arch/kirkwood.h> #include <asm/arch/gpio.h> +#include <kw_gpio.h>
static unsigned long gpio_valid_input[BITS_TO_LONGS(GPIO_MAX)]; static unsigned long gpio_valid_output[BITS_TO_LONGS(GPIO_MAX)];
void __set_direction(unsigned pin, int input) { + u32 base = GPIO_BASE(pin); u32 u;
- u = readl(GPIO_IO_CONF(pin)); + u = readl(GPIO_IO_CONF(base)); if (input) u |= 1 << (pin & 31); else u &= ~(1 << (pin & 31)); - writel(u, GPIO_IO_CONF(pin)); + writel(u, GPIO_IO_CONF(base));
- u = readl(GPIO_IO_CONF(pin)); + u = readl(GPIO_IO_CONF(base)); }
void __set_level(unsigned pin, int high) { + u32 base = GPIO_BASE(pin); u32 u;
- u = readl(GPIO_OUT(pin)); + u = readl(GPIO_OUT(base)); if (high) u |= 1 << (pin & 31); else u &= ~(1 << (pin & 31)); - writel(u, GPIO_OUT(pin)); + writel(u, GPIO_OUT(base)); }
void __set_blinking(unsigned pin, int blink) { + u32 base = GPIO_BASE(pin); u32 u;
- u = readl(GPIO_BLINK_EN(pin)); + u = readl(GPIO_BLINK_EN(base)); if (blink) u |= 1 << (pin & 31); else u &= ~(1 << (pin & 31)); - writel(u, GPIO_BLINK_EN(pin)); + writel(u, GPIO_BLINK_EN(base)); }
int kw_gpio_is_valid(unsigned pin, int mode) @@ -88,7 +88,7 @@ int kw_gpio_is_valid(unsigned pin, int mode) }
err_out: - printf("%s: invalid GPIO %d\n", __func__, pin); + printf("%s: invalid GPIO %d/%d\n", __func__, pin, GPIO_MAX); return 1; }
@@ -140,12 +140,13 @@ int kw_gpio_direction_output(unsigned pin, int value)
int kw_gpio_get_value(unsigned pin) { + u32 base = GPIO_BASE(pin); int val;
- if (readl(GPIO_IO_CONF(pin)) & (1 << (pin & 31))) - val = readl(GPIO_DATA_IN(pin)) ^ readl(GPIO_IN_POL(pin)); + if (readl(GPIO_IO_CONF(base)) & (1 << (pin & 31))) + val = readl(GPIO_DATA_IN(base)) ^ readl(GPIO_IN_POL(base)); else - val = readl(GPIO_OUT(pin)); + val = readl(GPIO_OUT(base));
return (val >> (pin & 31)) & 1; } diff --git a/arch/arm/include/asm/arch-kirkwood/gpio.h b/include/kw_gpio.h similarity index 60% copy from arch/arm/include/asm/arch-kirkwood/gpio.h copy to include/kw_gpio.h index cd1bc00..7e35833 100644 --- a/arch/arm/include/asm/arch-kirkwood/gpio.h +++ b/include/kw_gpio.h @@ -1,5 +1,7 @@ /* - * arch/asm-arm/mach-kirkwood/include/mach/gpio.h + * Marvell Dove and Kirkwood SoCs common gpio + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com * * See file CREDITS for list of people who contributed to this * project. @@ -20,34 +22,34 @@ * MA 02110-1301 USA */
+#ifndef __KW_GPIO_H +#define __KW_GPIO_H + /* - * Based on (mostly copied from) plat-orion based Linux 2.6 kernel driver. - * Removed kernel level irq handling. Took some macros from kernel to - * allow build. - * - * Dieter Kiermaier dk-arm-linux@gmx.de + * SoC-specific gpio.h defines + * GPIO_MAX and GPIO_BASE(pin) macro */
-#ifndef __KIRKWOOD_GPIO_H -#define __KIRKWOOD_GPIO_H +#define GPIO_INPUT_OK (1 << 0) +#define GPIO_OUTPUT_OK (1 << 1) +#define GPIO_LOW 0 +#define GPIO_HIGH 1
/* got from kernel include/linux/bitops.h */ #define BITS_PER_BYTE 8 #define BITS_TO_LONGS(nr) DIV_ROUND_UP(nr, BITS_PER_BYTE * sizeof(long))
-#define GPIO_MAX 50 -#define GPIO_OFF(pin) (((pin) >> 5) ? 0x0040 : 0x0000) -#define GPIO_OUT(pin) (KW_GPIO0_BASE + GPIO_OFF(pin) + 0x00) -#define GPIO_IO_CONF(pin) (KW_GPIO0_BASE + GPIO_OFF(pin) + 0x04) -#define GPIO_BLINK_EN(pin) (KW_GPIO0_BASE + GPIO_OFF(pin) + 0x08) -#define GPIO_IN_POL(pin) (KW_GPIO0_BASE + GPIO_OFF(pin) + 0x0c) -#define GPIO_DATA_IN(pin) (KW_GPIO0_BASE + GPIO_OFF(pin) + 0x10) -#define GPIO_EDGE_CAUSE(pin) (KW_GPIO0_BASE + GPIO_OFF(pin) + 0x14) -#define GPIO_EDGE_MASK(pin) (KW_GPIO0_BASE + GPIO_OFF(pin) + 0x18) -#define GPIO_LEVEL_MASK(pin) (KW_GPIO0_BASE + GPIO_OFF(pin) + 0x1c) +#define GPIO_OUT(base) ((base) + 0x00) +#define GPIO_IO_CONF(base) ((base) + 0x04) +#define GPIO_BLINK_EN(base) ((base) + 0x08) +#define GPIO_IN_POL(base) ((base) + 0x0c) +#define GPIO_DATA_IN(base) ((base) + 0x10) +#define GPIO_EDGE_CAUSE(base) ((base) + 0x14) +#define GPIO_EDGE_MASK(base) ((base) + 0x18) +#define GPIO_LEVEL_MASK(base) ((base) + 0x1c)
/* - * Kirkwood-specific GPIO API + * Dove/Kirkwood-specific GPIO API */
void kw_gpio_set_valid(unsigned pin, int mode); @@ -59,7 +61,4 @@ void kw_gpio_set_value(unsigned pin, int value); void kw_gpio_set_blink(unsigned pin, int blink); void kw_gpio_set_unused(unsigned pin);
-#define GPIO_INPUT_OK (1 << 0) -#define GPIO_OUTPUT_OK (1 << 1) - #endif
- arch/arm/plat-orion/gpio.c
- Marvell Dove and Kirkwood SoC GPIO handling
- Marvell Orion SoC GPIO handling.
- Based on (mostly copied from) plat-orion based Linux 2.6 kernel driver.
- Removed orion_gpiochip struct and kernel level irq handling.
- Dieter Kiermaier dk-arm-linux@gmx.de
err_out:
nit: indent with TAB
Sebastian
Dear Sascha Silbe,
In message 1372195668-25496-4-git-send-email-t-uboot@infra-silbe.de you wrote:
This throws a number of checkpatch warnings and errors (line over 80 characters, code indent should use tabs where possible, please, no spaces at the start of a line). Please fix.
- Removed kernel level irq handling. Took some macros from kernel to
- allow build.
Please never, never ever remove existing Copyright information or information about the origin of the code. This is a strong NAK.
- arch/asm-arm/mach-kirkwood/include/mach/gpio.h
- Marvell Dove and Kirkwood SoCs common gpio
- Sebastian Hesselbarth sebastian.hesselbarth@gmail.com
Which purpose has the mentioning of this name here? If this is supposed to be a copyright claim, it should say so.
- allow build.
Again, this gets dropped. All these changes look pretty much fishy to me.
This adds a driver for the sdhci controller found on Dove SoCs.
arch/arm/include/asm/arch-dove/mmc.h | 27 ++++++++++ drivers/mmc/Makefile | 1 + drivers/mmc/dove_sdhci.c | 101 +++++++++++++++++++++++++++++++++++ 3 files changed, 129 insertions(+)
diff --git a/arch/arm/include/asm/arch-dove/mmc.h b/arch/arm/include/asm/arch-dove/mmc.h new file mode 100644 index 0000000..579396c --- /dev/null +++ b/arch/arm/include/asm/arch-dove/mmc.h @@ -0,0 +1,27 @@ +/* + * Marvell Dove SoC SDHCI + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _DOVEMMC_H +#define _DOVEMMC_H + +int dove_sdhci_init(int num); +#endif /* _DOVEMMC_H */ diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 24648a2..074af75 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -28,6 +28,7 @@ LIB := $(obj)libmmc.o
COBJS-$(CONFIG_BFIN_SDH) += bfin_sdh.o COBJS-$(CONFIG_DAVINCI_MMC) += davinci_mmc.o +COBJS-$(CONFIG_DOVE_SDHCI) += dove_sdhci.o COBJS-$(CONFIG_FSL_ESDHC) += fsl_esdhc.o COBJS-$(CONFIG_FTSDC010) += ftsdc010_mci.o COBJS-$(CONFIG_GENERIC_MMC) += mmc.o diff --git a/drivers/mmc/dove_sdhci.c b/drivers/mmc/dove_sdhci.c new file mode 100644 index 0000000..ac15fd7 --- /dev/null +++ b/drivers/mmc/dove_sdhci.c @@ -0,0 +1,101 @@ +/* + * + * Marvell Dove SDHCI driver + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * Based on linux drivers/mmc/host/sdhci-dove.c + * by: Saeed Bishara saeed@marvell.com + * Mike Rapoport mike@compulab.co.il + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ + +#include <common.h> +#include <malloc.h> +#include <sdhci.h> +#include <asm/arch/dove.h> + +static u16 dove_sdhci_readw(struct sdhci_host *host, int reg) +{ + u16 ret; + + switch (reg) { + case SDHCI_HOST_VERSION: + case SDHCI_SLOT_INT_STATUS: + /* those registers don't exist */ + return 0; + default: + ret = readw(host->ioaddr + reg); + } + + return ret; +} + +static u32 dove_sdhci_readl(struct sdhci_host *host, int reg) +{ + u32 ret; + + switch (reg) { + case SDHCI_CAPABILITIES: + ret = readl(host->ioaddr + reg); + /* Mask the support for 3.0V */ + ret &= ~SDHCI_CAN_VDD_300; + break; + default: + ret = readl(host->ioaddr + reg); + } + + return ret; +} + +static struct sdhci_ops dove_sdhci_ops = { + .read_w = dove_sdhci_readw, + .read_l = dove_sdhci_readl, +}; + +static struct sdhci_host hosts[2] = { + { + .name = "Dove SDHCI0", + .ioaddr = (void *)DOVE_SDIO0_BASE, + }, + { + .name = "Dove SDHCI1", + .ioaddr = (void *)DOVE_SDIO1_BASE, + }, +}; + +int dove_sdhci_init(int num) +{ + struct sdhci_host *host; + + if (num < 0 || num > 1) + return 1; + + host = &hosts[num]; + + if (host->version) + return 1; + + host->quirks = + SDHCI_QUIRK_NO_HISPD_BIT | + SDHCI_QUIRK_BROKEN_R1B | + SDHCI_QUIRK_32BIT_DMA_ADDR; + host->version = SDHCI_SPEC_200; + host->ops = &dove_sdhci_ops; + + add_sdhci(host, 50000000, 4000000); + return 0; +}
I have a few comments.
I myself not convenient with the capital letters on commit header, IMHO "MMC: dove_sdhci: " ==> "mmc: dove_sdhci: "
perhaps not much an issue we are taking about.
v4->v5: no changes
- Marvell Dove SoC SDHCI
- project.
- MA 02110-1301 USA
Do you really require this file just for a single func deceleration. I have a another thought like..just directly call dove_sdhci_init from board file.
- Marvell Dove SDHCI driver
- Based on linux drivers/mmc/host/sdhci-dove.c
- by: Saeed Bishara saeed@marvell.com
Mike Rapoport <mike@compulab.co.il>
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
u16 ret;
switch (reg) {
default:
return ret;
u32 ret;
switch (reg) {
break;
default:
return ret;
return 1;
What exactly this logic is for, are you able to detect the sdhci host at runtime out of 2. if not so may be you directly call dove_sdhci_init from board file with respective base.
host = &hosts[num];
if (host->version)
return 1;
host->quirks =
Better to read the version using sdhci_readw() instead of direct assignment.
-- Thanks, Jagan.
1.8.2.1
The SPI support on Dove is very similar to that on Kirkwood (and possibly orion5x as well). Instead of duplicating the code, we tweak the Kirkwood driver so it works for Dove, too.
arch/arm/include/asm/arch-kirkwood/spi.h | 27 ------------------ drivers/spi/kirkwood_spi.c | 47 +++++++++++++++++++++++++++++--- 2 files changed, 43 insertions(+), 31 deletions(-)
diff --git a/arch/arm/include/asm/arch-kirkwood/spi.h b/arch/arm/include/asm/arch-kirkwood/spi.h index 113f258..4145f62 100644 --- a/arch/arm/include/asm/arch-kirkwood/spi.h +++ b/arch/arm/include/asm/arch-kirkwood/spi.h @@ -27,16 +27,6 @@ #ifndef __KW_SPI_H__ #define __KW_SPI_H__
-/* SPI Registers on kirkwood SOC */ -struct kwspi_registers { - u32 ctrl; /* 0x10600 */ - u32 cfg; /* 0x10604 */ - u32 dout; /* 0x10608 */ - u32 din; /* 0x1060c */ - u32 irq_cause; /* 0x10610 */ - u32 irq_mask; /* 0x10614 */ -}; - /* They are used to define CONFIG_SYS_KW_SPI_MPP * each of the below #defines selects which mpp is * configured for each SPI signal in spi_claim_bus @@ -48,21 +38,4 @@ struct kwspi_registers { #define SCK_MPP10 (1 << 1) #define MISO_MPP11 (1 << 2)
-#define KWSPI_CLKPRESCL_MASK 0x1f -#define KWSPI_CLKPRESCL_MIN 0x12 -#define KWSPI_CSN_ACT 1 /* Activates serial memory interface */ -#define KWSPI_SMEMRDY (1 << 1) /* SerMem Data xfer ready */ -#define KWSPI_IRQUNMASK 1 /* unmask SPI interrupt */ -#define KWSPI_IRQMASK 0 /* mask SPI interrupt */ -#define KWSPI_SMEMRDIRQ 1 /* SerMem data xfer ready irq */ -#define KWSPI_XFERLEN_1BYTE 0 -#define KWSPI_XFERLEN_2BYTE (1 << 5) -#define KWSPI_XFERLEN_MASK (1 << 5) -#define KWSPI_ADRLEN_1BYTE 0 -#define KWSPI_ADRLEN_2BYTE 1 << 8 -#define KWSPI_ADRLEN_3BYTE 2 << 8 -#define KWSPI_ADRLEN_4BYTE 3 << 8 -#define KWSPI_ADRLEN_MASK 3 << 8 -#define KWSPI_TIMEOUT 10000 - #endif /* __KW_SPI_H__ */ diff --git a/drivers/spi/kirkwood_spi.c b/drivers/spi/kirkwood_spi.c index caa91e3..4e4c814 100644 --- a/drivers/spi/kirkwood_spi.c +++ b/drivers/spi/kirkwood_spi.c @@ -28,23 +28,58 @@ #include <malloc.h> #include <spi.h> #include <asm/io.h> -#include <asm/arch/kirkwood.h> -#include <asm/arch/spi.h> -#include <asm/arch/mpp.h> +#include <asm/arch/config.h>
-static struct kwspi_registers *spireg = (struct kwspi_registers *)KW_SPI_BASE; +/* SPI Registers on Dove/Kirkwood SOC */ +struct kwspi_registers { + u32 ctrl; /* 0x00 */ + u32 cfg; /* 0x04 */ + u32 dout; /* 0x08 */ + u32 din; /* 0x0c */ + u32 irq_cause; /* 0x10 */ + u32 irq_mask; /* 0x14 */ +};
+#if defined(CONFIG_KIRKWOOD) +static struct kwspi_registers *spireg = + (struct kwspi_registers *)KW_SPI_BASE; +#elif defined(CONFIG_DOVE) +static struct kwspi_registers *spireg = + (struct kwspi_registers *)DOVE_SPI_BASE; +#endif + +#define KWSPI_CLKPRESCL_MASK 0x1f +#define KWSPI_CLKPRESCL_MIN 0x12 +#define KWSPI_CSN_ACT 1 /* Activates serial memory interface */ +#define KWSPI_SMEMRDY (1 << 1) /* SerMem Data xfer ready */ +#define KWSPI_IRQUNMASK 1 /* unmask SPI interrupt */ +#define KWSPI_IRQMASK 0 /* mask SPI interrupt */ +#define KWSPI_SMEMRDIRQ 1 /* SerMem data xfer ready irq */ +#define KWSPI_XFERLEN_1BYTE 0 +#define KWSPI_XFERLEN_2BYTE (1 << 5) +#define KWSPI_XFERLEN_MASK (1 << 5) +#define KWSPI_ADRLEN_1BYTE 0 +#define KWSPI_ADRLEN_2BYTE (1 << 8) +#define KWSPI_ADRLEN_3BYTE (2 << 8) +#define KWSPI_ADRLEN_4BYTE (3 << 8) +#define KWSPI_ADRLEN_MASK (3 << 8) +#define KWSPI_TIMEOUT 10000 + +#if defined(CONFIG_KIRKWOOD) u32 cs_spi_mpp_back[2]; +#endif
struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, unsigned int max_hz, unsigned int mode) { struct spi_slave *slave; u32 data; +#if defined(CONFIG_KIRKWOOD) static const u32 kwspi_mpp_config[2][2] = { { MPP0_SPI_SCn, 0 }, /* if cs == 0 */ { MPP7_SPI_SCn, 0 } /* if cs != 0 */ }; +#endif
if (!spi_cs_is_valid(bus, cs)) return NULL; @@ -67,15 +102,19 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, writel(KWSPI_SMEMRDIRQ, &spireg->irq_cause); writel(KWSPI_IRQMASK, &spireg->irq_mask);
+#if defined(CONFIG_KIRKWOOD) /* program mpp registers to select SPI_CSn */ kirkwood_mpp_conf(kwspi_mpp_config[cs ? 1 : 0], cs_spi_mpp_back); +#endif
return slave; }
void spi_free_slave(struct spi_slave *slave) { +#if defined(CONFIG_KIRKWOOD) kirkwood_mpp_conf(cs_spi_mpp_back, NULL); +#endif free(slave); }
- each of the below #defines selects which mpp is
- configured for each SPI signal in spi_claim_bus
@@ -48,21 +38,4 @@ struct kwspi_registers { #define SCK_MPP10 (1<< 1) #define MISO_MPP11 (1<< 2)
-#define KWSPI_CLKPRESCL_MASK 0x1f -#define KWSPI_CLKPRESCL_MIN 0x12 -#define KWSPI_CSN_ACT 1 /* Activates serial memory interface */ -#define KWSPI_SMEMRDY (1<< 1) /* SerMem Data xfer ready */ -#define KWSPI_IRQUNMASK 1 /* unmask SPI interrupt */ -#define KWSPI_IRQMASK 0 /* mask SPI interrupt */ -#define KWSPI_SMEMRDIRQ 1 /* SerMem data xfer ready irq */ -#define KWSPI_XFERLEN_1BYTE 0 -#define KWSPI_XFERLEN_2BYTE (1<< 5) -#define KWSPI_XFERLEN_MASK (1<< 5) -#define KWSPI_ADRLEN_1BYTE 0 -#define KWSPI_ADRLEN_2BYTE 1<< 8 -#define KWSPI_ADRLEN_3BYTE 2<< 8 -#define KWSPI_ADRLEN_4BYTE 3<< 8 -#define KWSPI_ADRLEN_MASK 3<< 8 -#define KWSPI_TIMEOUT 10000
diff --git a/drivers/spi/kirkwood_spi.c b/drivers/spi/kirkwood_spi.c index caa91e3..4e4c814 100644 --- a/drivers/spi/kirkwood_spi.c +++ b/drivers/spi/kirkwood_spi.c @@ -28,23 +28,58 @@ #include<malloc.h> #include<spi.h> #include<asm/io.h> -#include<asm/arch/kirkwood.h> -#include<asm/arch/spi.h> -#include<asm/arch/mpp.h> +#include<asm/arch/config.h>
- u32 ctrl; /* 0x00 */
- u32 cfg; /* 0x04 */
- u32 dout; /* 0x08 */
- u32 din; /* 0x0c */
- u32 irq_cause; /* 0x10 */
- u32 irq_mask; /* 0x14 */
After I looked deeper in Dove FS SPI registers today, I can now say that Dove SPI allows some more prescaler settings. Nothing critical, as kirkwood_spi finds the closest spi clock rate less that requested frequency. By not using the extended prescaler, you may end up with spi clock running slower than possible but it will not break anything.
Sebastian
Dear Sascha Silbe,
In message 1372195668-25496-6-git-send-email-t-uboot@infra-silbe.de you wrote:
Not checkpatch clean: 2 errors, 2 warnings. Please fix.
Hi Sascha Silbe,
On Wed, Jun 26, 2013 at 7:41 PM, Wolfgang Denk wd@denx.de wrote:
Dear Sascha Silbe,
Any inputs on this.
On Sat, Dec 21, 2013 at 12:35 AM, Jagan Teki jagannadh.teki@gmail.com wrote:
Hi Sascha Silbe,
Dear Sascha Silbe,
Any inputs on this.
Last ping!
Dove SoC also uses mvsata, therefore add a SoC specific include to allow to reuse the mvsata ide driver.
Signed-off-by: Sascha Silbe t-uboot@infra-silbe.de Acked-by: Prafulla Wadaskar prafulla@marvell.com --- v4->v5: no changes
drivers/block/mvsata_ide.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/block/mvsata_ide.c b/drivers/block/mvsata_ide.c index 42c177f..500f13c 100644 --- a/drivers/block/mvsata_ide.c +++ b/drivers/block/mvsata_ide.c @@ -29,6 +29,8 @@ #include <asm/arch/orion5x.h> #elif defined(CONFIG_KIRKWOOD) #include <asm/arch/kirkwood.h> +#elif defined(CONFIG_DOVE) +#include <asm/arch/dove.h> #endif
/* SATA port registers */
Dear Sascha Silbe,
In message 1372195668-25496-7-git-send-email-t-uboot@infra-silbe.de you wrote:
v4->v5: no changes
Please keep such lists sorted. Thanks.
Avoid a recently introduced unused variable warning for boards that use mvgbe but not phylib.
Signed-off-by: Sascha Silbe t-uboot@infra-silbe.de --- v4->v5: Most of the original patch ("NET: mvgbe: add phylib support") was merged to master, only this clean-up remains.
drivers/net/mvgbe.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index 319fe8a..e19696a 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -436,8 +436,9 @@ static int mvgbe_init(struct eth_device *dev) { struct mvgbe_device *dmvgbe = to_mvgbe(dev); struct mvgbe_registers *regs = dmvgbe->regs; -#if (defined (CONFIG_MII) || defined (CONFIG_CMD_MII)) \ - && defined (CONFIG_SYS_FAULT_ECHO_LINK_DOWN) +#if (defined(CONFIG_MII) || defined(CONFIG_CMD_MII)) && \ + !defined(CONFIG_PHYLIB) && \ + defined(CONFIG_SYS_FAULT_ECHO_LINK_DOWN) int i; #endif /* setup RX rings */
With latest support for Marvell Dove SoC, add the SolidRun CuBox as the very first board with that SoC.
Three variants are provided:
1. A regular SPI boot image for CuBox (1GiB)
The CuBox (without "Pro") has 1GiB of memory.
2. A regular SPI boot image for CuBox Pro (2GiB)
The CuBox Pro has 2GiB of memory. Because larger SDRAM chips are used, tRFC needs to be longer than on the 1GiB variant.
3. A UART boot image for both CuBox and CuBox Pro
This is just for recovery purposes, so the smaller memory map (on CuBox Pro) and slower SDRAM access (on CuBox) doesn't matter. Having a single image that works on both hardware variants is quite convenient during recovery.
Signed-off-by: Sascha Silbe t-uboot@infra-silbe.de --- v4->v5: - dropped MAINTAINERS entry on Sebastian Hesselbarth's request - some adjustments to account for GPIO and SPI driver changes
board/solidrun/cubox/Makefile | 45 ++++++++ board/solidrun/cubox/cubox.c | 142 +++++++++++++++++++++++ board/solidrun/cubox/kwbimage-spi-1gb.cfg | 76 ++++++++++++ board/solidrun/cubox/kwbimage-spi-2gb.cfg | 76 ++++++++++++ board/solidrun/cubox/kwbimage-uart.cfg | 76 ++++++++++++ boards.cfg | 3 + include/configs/cubox.h | 185 ++++++++++++++++++++++++++++++ 7 files changed, 603 insertions(+)
diff --git a/board/solidrun/cubox/Makefile b/board/solidrun/cubox/Makefile new file mode 100644 index 0000000..c771d72 --- /dev/null +++ b/board/solidrun/cubox/Makefile @@ -0,0 +1,45 @@ +# +# SolidRun CuBox Makefile +# +# Sebastian Hesselbarth sebastian.hesselbarth@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := cubox.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/solidrun/cubox/cubox.c b/board/solidrun/cubox/cubox.c new file mode 100644 index 0000000..7d265e4 --- /dev/null +++ b/board/solidrun/cubox/cubox.c @@ -0,0 +1,142 @@ +/* + * SolidRun CuBox board support + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <miiphy.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> +#include <asm/arch/mpp.h> +#include <asm/arch/mmc.h> +#include <kw_gpio.h> + +DECLARE_GLOBAL_DATA_PTR; + +static u16 mpp_config[] = { + MPP0_GPIO, + MPP1_GPIO, /* USB power enable */ + MPP2_GPIO, /* USB over-current indication */ + MPP3_GPIO, /* micro button beneath eSATA port */ + MPP4_GPIO, + MPP5_GPIO, + MPP6_GPIO, + MPP7_GPIO, + + MPP8_GPIO, + MPP9_GPIO, + MPP10_GPIO, + MPP11_GPIO, + MPP12_GPIO, /* SDIO0 card detect */ + MPP13_AUDIO1_EXTCLK, /* Si5351a audio clock output */ + MPP14_GPIO, + MPP15_GPIO, + + MPP16_GPIO, + MPP17_GPIO, + MPP18_GPIO, /* Red front LED */ + MPP19_UART3_RXD, /* IR sensor */ + MPP20_GPIO, + MPP21_GPIO, + MPP22_GPIO, + MPP23_GPIO, + + MPP_CAMERA_GPIO, + MPP_SDIO0_SDIO, /* SDIO0 */ + MPP_SDIO1_GPIO, + MPP_AUDIO1_I2S_SPDIFO, /* SPDIF and HDMI audio */ + MPP_SPI_SPI, /* SPI */ + MPP_UART1_GPIO, + MPP_NAND_GPO, + + MPP_AUDIO0_I2S, + MPP_TWSI_OPTION1, /* TWSI on dedicated pins */ + 0 }; + +int board_early_init_f(void) +{ + struct dove_gpio_init gpp = { + .val0 = 0x00010186, + .oe0_n = 0xffffffff, + .val1 = 0x018000c0, + .oe1_n = 0xffffffff, + .val2 = 0x00000000, + .oe2_n = 0xffffffff, + }; + + dove_init_gpio(&gpp); + + return 0; +} + +int board_init(void) +{ + /* adress of boot parameters */ + gd->bd->bi_boot_params = dove_dram_start(0) + 0x100; + + /* configure mpp */ + dove_mpp_conf(mpp_config); + + /* usb power enable */ + kw_gpio_direction_output(MPP1, GPIO_HIGH); + + /* blink led */ + kw_gpio_direction_output(MPP18, GPIO_HIGH); + kw_gpio_set_blink(MPP18, 1); + + return 0; +} + +#ifdef CONFIG_MMC +int board_mmc_init(bd_t *bis) +{ + dove_sdhci_init(0); + return 0; +} +#endif + +#ifdef CONFIG_RESET_PHY_R +void dove_eth_phy_init(char *name) +{ + u16 devadr; + + if (miiphy_set_current_dev(name)) + return; + + /* command to read PHY dev address */ + if (miiphy_read(name, 0xEE, 0xEE, (u16 *)&devadr)) { + printf("Err..%s could not read PHY dev address\n", + __func__); + return; + } + + /* reset the phy */ + miiphy_reset(name, devadr); + + printf("%s PHY initialized\n", name); +} + +void reset_phy(void) +{ + dove_eth_phy_init("egiga0"); +} +#endif /* CONFIG_RESET_PHY_R */ diff --git a/board/solidrun/cubox/kwbimage-spi-1gb.cfg b/board/solidrun/cubox/kwbimage-spi-1gb.cfg new file mode 100644 index 0000000..c3f1ad9 --- /dev/null +++ b/board/solidrun/cubox/kwbimage-spi-1gb.cfg @@ -0,0 +1,76 @@ +# +# Marvell BootROM config for SolidRun CuBox +# +# Sebastian Hesselbarth sebastian.hesselbarth@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# +# Refer docs/README.kwimage for more details about how-to configure +# and create kirkwood boot image +# + +# Boot Media configurations +BOOT_FROM spi + +# SOC registers configuration using bootrom header extension +# Maximum KWBIMAGE_MAX_CONFIG configurations allowed + +DATA 0xd0020104 0x00000000 # CPU Control and Status register + +# SDRAM initalization +DATA 0xd0800020 0x00022430 # SDRAM Configuration register 0 +DATA 0xd0800030 0x00022430 # SDRAM Configuration register 1 +DATA 0xd0800050 0x911500c3 # SDRAM Timing register 1 +DATA 0xd0800060 0x646602c4 # SDRAM Timing register 2 +DATA 0xd0800190 0xc2003053 # SDRAM Timing register 3 +DATA 0xd08001c0 0x34f4a187 # SDRAM Timing register 4 +DATA 0xd0800650 0x000f0121 # SDRAM Timing register 5 +DATA 0xd0800660 0x04040200 # SDRAM Timing register 6 +DATA 0xd0800080 0x00000000 # SDRAM Control register 1 +DATA 0xd0800090 0x00080000 # SDRAM Control register 2 +DATA 0xd08000f0 0xc0000000 # SDRAM Control register 3 +DATA 0xd08001a0 0x20c0c009 # SDRAM Control register 4 +DATA 0xd0800280 0x010e0202 # SDRAM Control register 5 +DATA 0xd0800760 0x00000000 # SDRAM Control register 6 +DATA 0xd0800770 0x0000000a # SDRAM Control register 7 +DATA 0xd0800140 0x20004044 # SDRAM PHY control register 3 +DATA 0xd08001d0 0x133c2339 # SDRAM PHY control register 7 +DATA 0xd08001e0 0x07700330 # SDRAM PHY control register 8 +DATA 0xd08001f0 0x00000033 # SDRAM PHY control register 9 +DATA 0xd0800200 0x0011311c # SDRAM PHY control register 10 +DATA 0xd0800210 0x00300000 # SDRAM PHY control register 11 +DATA 0xd0800240 0x80000000 # SDRAM PHY control register 14 +DATA 0xd0800510 0x010e0101 # SDRAM MCB control register 1 +DATA 0xd0800230 0x2028006a # SDRAM PHY control register 13 +DATA 0xd0800e10 0x00280062 # SDRAM PHY DLL control registers 2 +DATA 0xd0800e20 0x00280062 # SDRAM PHY DLL control registers 3 +DATA 0xd0800e30 0x00280062 # SDRAM PHY DLL control registers 4 + +# SDRAM memory map (2x512MB) +DATA 0xd0800100 0x000d0001 # SDRAM Memory Address Map register 1 +DATA 0xd0800110 0x200d0001 # SDRAM Memory Address Map register 1 + +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register + +# End of Header extension +DATA 0x0 0x0 diff --git a/board/solidrun/cubox/kwbimage-spi-2gb.cfg b/board/solidrun/cubox/kwbimage-spi-2gb.cfg new file mode 100644 index 0000000..7113c66 --- /dev/null +++ b/board/solidrun/cubox/kwbimage-spi-2gb.cfg @@ -0,0 +1,76 @@ +# +# Marvell BootROM config for SolidRun CuBox +# +# Sebastian Hesselbarth sebastian.hesselbarth@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# +# Refer docs/README.kwimage for more details about how-to configure +# and create kirkwood boot image +# + +# Boot Media configurations +BOOT_FROM spi + +# SOC registers configuration using bootrom header extension +# Maximum KWBIMAGE_MAX_CONFIG configurations allowed + +DATA 0xd0020104 0x00000000 # CPU Control and Status register + +# SDRAM initalization +DATA 0xd0800020 0x00022530 # SDRAM Configuration register 0 +DATA 0xd0800030 0x00022530 # SDRAM Configuration register 1 +DATA 0xd0800050 0x911500c3 # SDRAM Timing register 1 +DATA 0xd0800060 0x64660784 # SDRAM Timing register 2 +DATA 0xd0800190 0xc2003053 # SDRAM Timing register 3 +DATA 0xd08001c0 0x34f4a187 # SDRAM Timing register 4 +DATA 0xd0800650 0x000f0121 # SDRAM Timing register 5 +DATA 0xd0800660 0x04040200 # SDRAM Timing register 6 +DATA 0xd0800080 0x00000000 # SDRAM Control register 1 +DATA 0xd0800090 0x00080000 # SDRAM Control register 2 +DATA 0xd08000f0 0xc0000000 # SDRAM Control register 3 +DATA 0xd08001a0 0x20c0c009 # SDRAM Control register 4 +DATA 0xd0800280 0x010e0202 # SDRAM Control register 5 +DATA 0xd0800760 0x00000000 # SDRAM Control register 6 +DATA 0xd0800770 0x0000000a # SDRAM Control register 7 +DATA 0xd0800140 0x20004044 # SDRAM PHY control register 3 +DATA 0xd08001d0 0x133c2339 # SDRAM PHY control register 7 +DATA 0xd08001e0 0x07700330 # SDRAM PHY control register 8 +DATA 0xd08001f0 0x00000033 # SDRAM PHY control register 9 +DATA 0xd0800200 0x0011311c # SDRAM PHY control register 10 +DATA 0xd0800210 0x00300000 # SDRAM PHY control register 11 +DATA 0xd0800240 0x80000000 # SDRAM PHY control register 14 +DATA 0xd0800510 0x010e0101 # SDRAM MCB control register 1 +DATA 0xd0800230 0x2028006a # SDRAM PHY control register 13 +DATA 0xd0800e10 0x00280062 # SDRAM PHY DLL control registers 2 +DATA 0xd0800e20 0x00280062 # SDRAM PHY DLL control registers 3 +DATA 0xd0800e30 0x00280062 # SDRAM PHY DLL control registers 4 + +# SDRAM memory map (2x1GiB) +DATA 0xd0800100 0x000e0001 # SDRAM Memory Address Map register 1 +DATA 0xd0800110 0x400e0001 # SDRAM Memory Address Map register 1 + +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register + +# End of Header extension +DATA 0x0 0x0 diff --git a/board/solidrun/cubox/kwbimage-uart.cfg b/board/solidrun/cubox/kwbimage-uart.cfg new file mode 100644 index 0000000..0077615 --- /dev/null +++ b/board/solidrun/cubox/kwbimage-uart.cfg @@ -0,0 +1,76 @@ +# +# Marvell BootROM config for SolidRun CuBox +# +# Sebastian Hesselbarth sebastian.hesselbarth@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# +# Refer docs/README.kwimage for more details about how-to configure +# and create kirkwood boot image +# + +# Boot Media configurations +BOOT_FROM uart + +# SOC registers configuration using bootrom header extension +# Maximum KWBIMAGE_MAX_CONFIG configurations allowed + +DATA 0xd0020104 0x00000000 # CPU Control and Status register + +# SDRAM initalization +DATA 0xd0800020 0x00022430 # SDRAM Configuration register 0 +DATA 0xd0800030 0x00022430 # SDRAM Configuration register 1 +DATA 0xd0800050 0x911500c3 # SDRAM Timing register 1 +DATA 0xd0800060 0x64660784 # SDRAM Timing register 2 +DATA 0xd0800190 0xc2003053 # SDRAM Timing register 3 +DATA 0xd08001c0 0x34f4a187 # SDRAM Timing register 4 +DATA 0xd0800650 0x000f0121 # SDRAM Timing register 5 +DATA 0xd0800660 0x04040200 # SDRAM Timing register 6 +DATA 0xd0800080 0x00000000 # SDRAM Control register 1 +DATA 0xd0800090 0x00080000 # SDRAM Control register 2 +DATA 0xd08000f0 0xc0000000 # SDRAM Control register 3 +DATA 0xd08001a0 0x20c0c009 # SDRAM Control register 4 +DATA 0xd0800280 0x010e0202 # SDRAM Control register 5 +DATA 0xd0800760 0x00000000 # SDRAM Control register 6 +DATA 0xd0800770 0x0000000a # SDRAM Control register 7 +DATA 0xd0800140 0x20004044 # SDRAM PHY control register 3 +DATA 0xd08001d0 0x133c2339 # SDRAM PHY control register 7 +DATA 0xd08001e0 0x07700330 # SDRAM PHY control register 8 +DATA 0xd08001f0 0x00000033 # SDRAM PHY control register 9 +DATA 0xd0800200 0x0011311c # SDRAM PHY control register 10 +DATA 0xd0800210 0x00300000 # SDRAM PHY control register 11 +DATA 0xd0800240 0x80000000 # SDRAM PHY control register 14 +DATA 0xd0800510 0x010e0101 # SDRAM MCB control register 1 +DATA 0xd0800230 0x2028006a # SDRAM PHY control register 13 +DATA 0xd0800e10 0x00280062 # SDRAM PHY DLL control registers 2 +DATA 0xd0800e20 0x00280062 # SDRAM PHY DLL control registers 3 +DATA 0xd0800e30 0x00280062 # SDRAM PHY DLL control registers 4 + +# SDRAM memory map (2x512MB) +DATA 0xd0800100 0x000d0001 # SDRAM Memory Address Map register 1 +DATA 0xd0800110 0x200d0001 # SDRAM Memory Address Map register 1 + +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register + +# End of Header extension +DATA 0x0 0x0 diff --git a/boards.cfg b/boards.cfg index c0c4282..3605d3a 100644 --- a/boards.cfg +++ b/boards.cfg @@ -331,6 +331,9 @@ dalmore arm armv7:arm720t dalmore nvidia colibri_t20_iris arm armv7:arm720t colibri_t20_iris toradex tegra20 u8500_href arm armv7 u8500 st-ericsson u8500 snowball arm armv7 snowball st-ericsson u8500 +cubox arm armv7 cubox solidrun dove cubox:CUBOX_1GB +cubox_pro arm armv7 cubox solidrun dove cubox:CUBOX_2GB +cubox_uart arm armv7 cubox solidrun dove cubox:CUBOX_UART_BOOT kzm9g arm armv7 kzm9g kmc rmobile armadillo-800eva arm armv7 armadillo-800eva atmark-techno rmobile zynq arm armv7 zynq xilinx zynq diff --git a/include/configs/cubox.h b/include/configs/cubox.h new file mode 100644 index 0000000..7d5845c --- /dev/null +++ b/include/configs/cubox.h @@ -0,0 +1,185 @@ +/* + * SolidRun CuBox config + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _CONFIG_CUBOX_H +#define _CONFIG_CUBOX_H +#include <asm/sizes.h> + +/* + * Version number information + */ +#define CONFIG_IDENT_STRING "SolidRun CuBox" + +#undef CONFIG_SYS_KWD_CONFIG +#if defined(CONFIG_CUBOX_UART_BOOT) +#define CONFIG_SYS_KWD_CONFIG $(SRCTREE)/$(CONFIG_BOARDDIR)/kwbimage-uart.cfg +#elif defined(CONFIG_CUBOX_1GB) +#define CONFIG_SYS_KWD_CONFIG $(SRCTREE)/$(CONFIG_BOARDDIR)/kwbimage-spi-1gb.cfg +#elif defined(CONFIG_CUBOX_2GB) +#define CONFIG_SYS_KWD_CONFIG $(SRCTREE)/$(CONFIG_BOARDDIR)/kwbimage-spi-2gb.cfg +#endif + +/* + * High Level Configuration Options + */ +#define CONFIG_MACH_SOLIDRUN_CUBOX /* Machine type */ +#define CONFIG_SHOW_BOOT_PROGRESS +#define CONFIG_KIRKWOOD_GPIO + +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +/* + * Enable u-boot API for standalone programs. + */ +#define CONFIG_API + +/* + * Enable device tree support + */ +#define CONFIG_OF_LIBFDT + +/* + * Commands configuration + */ +#include <config_cmd_default.h> +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ELF +#define CONFIG_CMD_ENV +#define CONFIG_CMD_IDE +#define CONFIG_CMD_PING +#define CONFIG_CMD_SF +#define CONFIG_CMD_SPI +#define CONFIG_CMD_USB +#define CONFIG_CMD_MMC + +#define CONFIG_DOS_PARTITION +#define CONFIG_EFI_PARTITION + +/* + * mv-common.h should be defined after CMD configs since it used them + * to enable certain macros + */ +#include "mv-common.h" + +/* + * redefine mv-common.h macros for armv7/cubox + */ +#undef CONFIG_SYS_PROMPT /* previously defined in mv-common.h */ +#define CONFIG_SYS_PROMPT "CuBox> " /* Command Prompt */ + +/* There is no arch_misc_init on armv7 */ +#undef CONFIG_ARCH_MISC_INIT + +#undef CONFIG_SYS_MALLOC_LEN +#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) /* 4MiB for malloc() */ + +/* + * Environment variables configurations + */ +#if defined(CONFIG_CMD_SF) +#define CONFIG_SPI_FLASH_WINBOND +#define CONFIG_ENV_IS_IN_SPI_FLASH 1 +#define CONFIG_ENV_SECT_SIZE 0x1000 /* 4k */ +#define CONFIG_ENV_SIZE 0x20000 /* 128k */ +#define CONFIG_ENV_OFFSET 0xc0000 /* env starts here */ +#else +#define CONFIG_ENV_IS_NOWHERE 1 /* if env in SDRAM */ +#endif + +/* + * Default CuBox bootscript environment + */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "bootscript=boot.scr\0" \ + "loadaddr=0x02000000\0" \ + "mmc_started=0\0" \ + "ide_started=0\0" \ + "usb_started=0\0" \ + "mtdparts=mtdparts=spi0.0:768k(u-boot)ro,128k(uboot_env),128k(fdt),-(empty)\0" + +#define CONFIG_BOOTCOMMAND \ + "for devn in usb mmc ide ; do " \ + " for part in 0 1; do " \ + " for dir in / /boot/;do " \ + " for fs in ext2 fat; do " \ + " echo ===> Executing ${fs}load ${devn} 0:${part} ${loadaddr} ${dir}${bootscript};" \ + " if itest.s $devn -eq mmc; then" \ + " if itest.s $mmc_started -ne 1; then" \ + " mmcinfo; setenv mmc_started '1';fi;fi;" \ + " if itest.s $devn -eq usb; then" \ + " if itest.s $usb_started -ne 1; then" \ + " usb start; setenv usb_started '1';fi;fi;" \ + " if itest.s $devn -eq ide; then" \ + " if itest.s $ide_started -ne 1; then" \ + " ide reset; setenv ide_started '1';fi;fi;" \ + " if ${fs}load ${devn} 0:${part} ${loadaddr} ${dir}${bootscript}; then" \ + " source ${loadaddr}; fi;" \ + " if itest.s $devn -eq usb; then" \ + " echo ===> Executing ${fs}load ${devn} 1:${part} ${loadaddr} ${dir}${bootscript};" \ + " if ${fs}load ${devn} 1:${part} ${loadaddr} ${dir}${bootscript}; then" \ + " source ${loadaddr}; fi;" \ + " fi;" \ + " done;" \ + " done;" \ + " done;" \ + "done;" \ + "tftp ${loadaddr} ${bootscript};" \ + "source ${loadaddr};" + +/* + * Ethernet Driver configuration + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_MVGBE_PORTS {1} /* enable port 0 */ +#define CONFIG_PHY_BASE_ADR 1 +#define CONFIG_PHYLIB +#define CONFIG_PHY_MARVELL +#endif /* CONFIG_CMD_NET */ + +#ifdef CONFIG_CMD_IDE +#undef CONFIG_IDE_LED +#undef CONFIG_SYS_IDE_MAXBUS +#define CONFIG_SYS_IDE_MAXBUS 1 +#undef CONFIG_SYS_IDE_MAXDEVICE +#define CONFIG_SYS_IDE_MAXDEVICE 1 +#define CONFIG_SYS_ATA_IDE0_OFFSET MV_SATA_PORT0_OFFSET +#endif + +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 + +/* + * File system + */ +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_EXT4 +#define CONFIG_CMD_FAT +#define CONFIG_RBTREE +#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_MTDPARTS +#define CONFIG_LZO + +#endif /* _CONFIG_CUBOX_H */
How about CUBOX_SPI_1GB, CUBOX_SPI_2GB, CUBOX_UART ? Also, sort order in boards.cfg should be ARCH (arm), CPU (armv7), SoC (dove), Vendor (solidrun), Target
- SolidRun CuBox config
- project.
- MA 02110-1301 USA
+#ifndef _CONFIG_CUBOX_H +#define _CONFIG_CUBOX_H +#include<asm/sizes.h>
- Version number information
ditto wrt to CONFIG_CUBOX_*
Sebastian
Dear Sascha Silbe,
In message 1372195668-25496-9-git-send-email-t-uboot@infra-silbe.de you wrote:
Not checkpatch clean: 4 x line over 80 characters; please fix.
This makes no sense. You add a new board, and this must have a matching entry in the MAINTAINERS file.
Hello Jagan,
Jagan Teki jagannadh.teki@gmail.com writes:
Any update on this.
The Wandboard Quad is working well for my purposes and much easier to work with (schematics and very extensive data sheets available, mainline support in both U-Boot and Linux). As a result, I'm focusing my limited resources on the Wandboard rather than the Cubox.
Sascha
Any update on this.
Cubox-i has been merged in current mainline; so it may be good a recheck ;-)
Hello Jagan,
Looks ok to me as per coding style after a quick look.
Done use the below tag code instead go for spi_alloc_slave() see the sample code on "drivers/spi/exynos_spi.c"
----------------------- TAG+
slave = malloc(sizeof(struct spi_slave));
if (!slave)
return NULL;
slave->bus = bus;
slave->cs = cs;
--------------------- TAG-
That's going to be fixed in the next version which builds directly on kirkwood_spi (rather than duplicating it), which already uses spi_alloc_slave().
+__attribute__((weak)) int board_spi_claim_bus(struct spi_slave *slave)
Why your using __attribute__((weak)) here, may be use to pre-load the symbol library but what is the use case here?
That's coming from kirkwood_spi. The Keymile boards apparently use it to select between NAND and SPI flash (see board/keymile/km_arm/km_arm.c).
Sascha
From: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Acked-by: Prafulla Wadaskar prafulla@marvell.com --- drivers/block/mvsata_ide.c | 2 ++ 1 file changed, 2 insertions(+)
This adds PHY initialization for Marvell Alaska 88E1310 PHY.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com --- drivers/net/phy/marvell.c | 48 +++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 48 insertions(+)
diff --git a/drivers/net/phy/marvell.c b/drivers/net/phy/marvell.c index 4b27198..1205166 100644 --- a/drivers/net/phy/marvell.c +++ b/drivers/net/phy/marvell.c @@ -89,6 +89,12 @@
#define MIIM_88E1149_PHY_PAGE 29
+/* 88E1310 PHY defines */ +#define MIIM_88E1310_PHY_LED_CTRL 16 +#define MIIM_88E1310_PHY_IRQ_EN 18 +#define MIIM_88E1310_PHY_RGMII_CTRL 21 +#define MIIM_88E1310_PHY_PAGE 22 + /* Marvell 88E1011S */ static int m88e1011s_config(struct phy_device *phydev) { @@ -394,6 +400,37 @@ static int m88e1149_config(struct phy_device *phydev) return 0; }
+/* Marvell 88E1310 */ +static int m88e1310_config(struct phy_device *phydev) +{ + u16 reg; + + /* LED link and activity */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_PAGE, 0x0003); + reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_LED_CTRL); + reg = (reg & ~0xf) | 0x1; + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_LED_CTRL, reg); + + /* Set LED2/INT to INT mode, low active */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_PAGE, 0x0003); + reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_IRQ_EN); + reg = (reg & 0x77ff) | 0x0880; + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_IRQ_EN, reg); + + /* Set RGMII delay */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_PAGE, 0x0002); + reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_RGMII_CTRL); + reg |= 0x0030; + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_RGMII_CTRL, reg); + + /* Ensure to return to page 0 */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_PAGE, 0x0000); + + genphy_config_aneg(phydev); + phy_reset(phydev); + + return 0; +}
static struct phy_driver M88E1011S_driver = { .name = "Marvell 88E1011S", @@ -465,8 +502,19 @@ static struct phy_driver M88E1149S_driver = { .shutdown = &genphy_shutdown, };
+static struct phy_driver M88E1310_driver = { + .name = "Marvell 88E1310", + .uid = 0x01410e90, + .mask = 0xffffff0, + .features = PHY_GBIT_FEATURES, + .config = &m88e1310_config, + .startup = &m88e1011s_startup, + .shutdown = &genphy_shutdown, +}; + int phy_marvell_init(void) { + phy_register(&M88E1310_driver); phy_register(&M88E1149S_driver); phy_register(&M88E1145_driver); phy_register(&M88E1121R_driver);
Applied, Thanks. -Joe
This add phylib support to the Marvell GBE driver.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Acked-by: Prafulla Wadaskar prafulla@marvell.com Signed-off-by: Sascha Silbe t-uboot@infra-silbe.de --- v3->v4: avoided unused variable warning; made checkpatch clean
drivers/net/mvgbe.c | 74 ++++++++++++++++++++++++++++++++++++++++++++++++----- 1 file changed, 68 insertions(+), 6 deletions(-)
diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index 47bf27c..7f0ddf5 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -52,7 +52,7 @@ DECLARE_GLOBAL_DATA_PTR; #define MV_PHY_ADR_REQUEST 0xee #define MVGBE_SMI_REG (((struct mvgbe_registers *)MVGBE0_BASE)->smi)
-#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) +#if defined(CONFIG_PHYLIB) || defined(CONFIG_MII) || defined(CONFIG_CMD_MII) /* * smi_reg_read - miiphy_read callback function. * @@ -184,6 +184,25 @@ static int smi_reg_write(const char *devname, u8 phy_adr, u8 reg_ofs, u16 data) } #endif
+#if defined(CONFIG_PHYLIB) +int mvgbe_phy_read(struct mii_dev *bus, int phy_addr, int dev_addr, + int reg_addr) +{ + u16 data; + int ret; + ret = smi_reg_read(bus->name, phy_addr, reg_addr, &data); + if (ret) + return ret; + return data; +} + +int mvgbe_phy_write(struct mii_dev *bus, int phy_addr, int dev_addr, + int reg_addr, u16 data) +{ + return smi_reg_write(bus->name, phy_addr, reg_addr, data); +} +#endif + /* Stop and checks all queues */ static void stop_queue(u32 * qreg) { @@ -415,8 +434,9 @@ static int mvgbe_init(struct eth_device *dev) { struct mvgbe_device *dmvgbe = to_mvgbe(dev); struct mvgbe_registers *regs = dmvgbe->regs; -#if (defined (CONFIG_MII) || defined (CONFIG_CMD_MII)) \ - && defined (CONFIG_SYS_FAULT_ECHO_LINK_DOWN) +#if (defined(CONFIG_MII) || defined(CONFIG_CMD_MII)) && \ + !defined(CONFIG_PHYLIB) && \ + defined(CONFIG_SYS_FAULT_ECHO_LINK_DOWN) int i; #endif /* setup RX rings */ @@ -467,8 +487,9 @@ static int mvgbe_init(struct eth_device *dev) /* Enable port Rx. */ MVGBE_REG_WR(regs->rqc, (1 << RXUQ));
-#if (defined (CONFIG_MII) || defined (CONFIG_CMD_MII)) \ - && defined (CONFIG_SYS_FAULT_ECHO_LINK_DOWN) +#if (defined(CONFIG_MII) || defined(CONFIG_CMD_MII)) && \ + !defined(CONFIG_PHYLIB) && \ + defined(CONFIG_SYS_FAULT_ECHO_LINK_DOWN) /* Wait up to 5s for the link status */ for (i = 0; i < 5; i++) { u16 phyadr; @@ -647,6 +668,45 @@ static int mvgbe_recv(struct eth_device *dev) return 0; }
+#if defined(CONFIG_PHYLIB) +int mvgbe_phylib_init(struct eth_device *dev, int phyid) +{ + struct mii_dev *bus; + struct phy_device *phydev; + int ret; + + bus = mdio_alloc(); + if (!bus) { + printf("mdio_alloc failed\n"); + return -ENOMEM; + } + bus->read = mvgbe_phy_read; + bus->write = mvgbe_phy_write; + sprintf(bus->name, dev->name); + + ret = mdio_register(bus); + if (ret) { + printf("mdio_register failed\n"); + free(bus); + return -ENOMEM; + } + + /* Set phy address of the port */ + mvgbe_phy_write(bus, MV_PHY_ADR_REQUEST, 0, MV_PHY_ADR_REQUEST, phyid); + + phydev = phy_connect(bus, phyid, dev, PHY_INTERFACE_MODE_RGMII); + if (!phydev) { + printf("phy_connect failed\n"); + return -ENODEV; + } + + phy_config(phydev); + phy_startup(phydev); + + return 0; +} +#endif + int mvgbe_initialize(bd_t *bis) { struct mvgbe_device *dmvgbe; @@ -729,7 +789,9 @@ error1:
eth_register(dev);
-#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) +#if defined(CONFIG_PHYLIB) + mvgbe_phylib_init(dev, PHY_BASE_ADR + devnum); +#elif defined(CONFIG_MII) || defined(CONFIG_CMD_MII) miiphy_register(dev->name, smi_reg_read, smi_reg_write); /* Set phy address of the port */ miiphy_write(dev->name, MV_PHY_ADR_REQUEST,
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot- bounces@lists.denx.de] On Behalf Of Sascha Silbe Sent: 27 May 2013 00:07 To: u-boot@lists.denx.de Cc: Rabeeh Khoury; Luka Perkov; Daniel Stodden; Andy Fleming Subject: [U-Boot] [PATCH v4 08/10] NET: mvgbe: add phylib support
- smi_reg_read - miiphy_read callback function.
- int reg_addr)
- u16 data;
- int ret;
- ret = smi_reg_read(bus->name, phy_addr, reg_addr,
&data);
- if (ret)
return ret;
- return data;
- int reg_addr, u16 data)
- return smi_reg_write(bus->name, phy_addr, reg_addr,
data); +} +#endif
- !defined(CONFIG_PHYLIB) && \
- defined(CONFIG_SYS_FAULT_ECHO_LINK_DOWN) int i;
- defined(CONFIG_SYS_FAULT_ECHO_LINK_DOWN) /* Wait up to 5s for the link status */ for (i = 0; i < 5; i++) { u16 phyadr;
- struct mii_dev *bus;
- struct phy_device *phydev;
- int ret;
- bus = mdio_alloc();
- if (!bus) {
return -ENOMEM;
- bus->read = mvgbe_phy_read;
- bus->write = mvgbe_phy_write;
- sprintf(bus->name, dev->name);
- ret = mdio_register(bus);
- if (ret) {
free(bus);
return -ENOMEM;
- /* Set phy address of the port */
- mvgbe_phy_write(bus, MV_PHY_ADR_REQUEST, 0,
- phydev = phy_connect(bus, phyid, dev,
- if (!phydev) {
return -ENODEV;
- phy_config(phydev);
- phy_startup(phydev);
+} +#endif
eth_register(dev);
+#elif defined(CONFIG_MII) || defined(CONFIG_CMD_MII) miiphy_register(dev->name, smi_reg_read, smi_reg_write); /* Set phy address of the port */ miiphy_write(dev->name, MV_PHY_ADR_REQUEST, -- 1.8.2.1
Regards... Prafulla . . .
Marvell Dove also uses mvgbe as ethernet driver, therefore add support for Dove to reuse the current driver.
Signed-off-by: Sebastian Hesselbarth sebastian.hesselbarth@gmail.com Signed-off-by: Sascha Silbe t-uboot@infra-silbe.de --- v3->v4: removed EBAR_DRAM_CS* for Dove
drivers/net/mvgbe.c | 9 ++++++++- drivers/net/mvgbe.h | 2 ++ 2 files changed, 10 insertions(+), 1 deletion(-)
diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index 7f0ddf5..57692e3 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -43,6 +43,8 @@ #include <asm/arch/kirkwood.h> #elif defined(CONFIG_ORION5X) #include <asm/arch/orion5x.h> +#elif defined(CONFIG_DOVE) +#include <asm/arch/dove.h> #endif
#include "mvgbe.h" @@ -286,7 +288,11 @@ static void set_dram_access(struct mvgbe_registers *regs) else win_param.enable = 1; /* Enable the access */
- /* Enable DRAM bank */ +#ifdef CONFIG_DOVE + /* Choose DRAM as target */ + win_param.attrib = 0; +#else + /* Choose one DRAM bank (chip select line) as target */ switch (i) { case 0: win_param.attrib = EBAR_DRAM_CS0; @@ -306,6 +312,7 @@ static void set_dram_access(struct mvgbe_registers *regs) win_param.attrib = 0; break; } +#endif /* Set the access control for address window(EPAPR) RD/WR */ set_access_control(regs, &win_param); } diff --git a/drivers/net/mvgbe.h b/drivers/net/mvgbe.h index d8a5429..22b571e 100644 --- a/drivers/net/mvgbe.h +++ b/drivers/net/mvgbe.h @@ -308,10 +308,12 @@ #define EBAR_TARGET_GUNIT 0x00000007
/* Window attrib */ +#if !defined(CONFIG_DOVE) #define EBAR_DRAM_CS0 0x00000E00 #define EBAR_DRAM_CS1 0x00000D00 #define EBAR_DRAM_CS2 0x00000B00 #define EBAR_DRAM_CS3 0x00000700 +#endif
/* DRAM Target interface */ #define EBAR_DRAM_NO_CACHE_COHERENCY 0x00000000
--- v3->v4: added second USB port; added 2GiB and UART variants; removed hardcoded MAC address; fixed some typos; made checkpatch clean
Tested on CuBox Pro (SPI and UART boot).
MAINTAINERS | 4 + board/solidrun/cubox/Makefile | 45 ++++++++ board/solidrun/cubox/cubox.c | 142 +++++++++++++++++++++++ board/solidrun/cubox/kwbimage-spi-1gb.cfg | 76 ++++++++++++ board/solidrun/cubox/kwbimage-spi-2gb.cfg | 76 ++++++++++++ board/solidrun/cubox/kwbimage-uart.cfg | 76 ++++++++++++ boards.cfg | 3 + include/configs/cubox.h | 185 ++++++++++++++++++++++++++++++ 8 files changed, 607 insertions(+) create mode 100644 board/solidrun/cubox/Makefile create mode 100644 board/solidrun/cubox/cubox.c create mode 100644 board/solidrun/cubox/kwbimage-spi-1gb.cfg create mode 100644 board/solidrun/cubox/kwbimage-spi-2gb.cfg create mode 100644 board/solidrun/cubox/kwbimage-uart.cfg create mode 100644 include/configs/cubox.h
diff --git a/MAINTAINERS b/MAINTAINERS index 643a5ac..07faf39 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -693,6 +693,10 @@ Lauri Hintsala lauri.hintsala@bluegiga.com
apx4devkit i.MX28
+Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + + cubox ARM ARMV7 (Dove SoC) + Vaibhav Hiremath hvaibhav@ti.com
am3517_evm ARM ARMV7 (AM35x SoC) diff --git a/board/solidrun/cubox/Makefile b/board/solidrun/cubox/Makefile new file mode 100644 index 0000000..c771d72 --- /dev/null +++ b/board/solidrun/cubox/Makefile @@ -0,0 +1,45 @@ +# +# SolidRun CuBox Makefile +# +# Sebastian Hesselbarth sebastian.hesselbarth@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := cubox.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/solidrun/cubox/cubox.c b/board/solidrun/cubox/cubox.c new file mode 100644 index 0000000..3d8140d --- /dev/null +++ b/board/solidrun/cubox/cubox.c @@ -0,0 +1,142 @@ +/* + * SolidRun CuBox board support + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <miiphy.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dove.h> +#include <asm/arch/mpp.h> +#include <asm/arch/mmc.h> +#include <dove_gpio.h> + +DECLARE_GLOBAL_DATA_PTR; + +static u16 mpp_config[] = { + MPP0_GPIO, + MPP1_GPIO, /* USB power enable */ + MPP2_GPIO, /* USB over-current indication */ + MPP3_GPIO, /* micro button beneath eSATA port */ + MPP4_GPIO, + MPP5_GPIO, + MPP6_GPIO, + MPP7_GPIO, + + MPP8_GPIO, + MPP9_GPIO, + MPP10_GPIO, + MPP11_GPIO, + MPP12_GPIO, /* SDIO0 card detect */ + MPP13_AUDIO1_EXTCLK, /* Si5351a audio clock output */ + MPP14_GPIO, + MPP15_GPIO, + + MPP16_GPIO, + MPP17_GPIO, + MPP18_GPIO, /* Red front LED */ + MPP19_UART3_RXD, /* IR sensor */ + MPP20_GPIO, + MPP21_GPIO, + MPP22_GPIO, + MPP23_GPIO, + + MPP_CAMERA_GPIO, + MPP_SDIO0_SDIO, /* SDIO0 */ + MPP_SDIO1_GPIO, + MPP_AUDIO1_I2S_SPDIFO, /* SPDIF and HDMI audio */ + MPP_SPI_SPI, /* SPI */ + MPP_UART1_GPIO, + MPP_NAND_GPO, + + MPP_AUDIO0_I2S, + MPP_TWSI_OPTION1, /* TWSI on dedicated pins */ + 0 }; + +int board_early_init_f(void) +{ + struct dove_gpio_init gpp = { + .val0 = 0x00010186, + .oe0_n = 0xffffffff, + .val1 = 0x018000c0, + .oe1_n = 0xffffffff, + .val2 = 0x00000000, + .oe2_n = 0xffffffff, + }; + + dove_init_gpio(&gpp); + + return 0; +} + +int board_init(void) +{ + /* adress of boot parameters */ + gd->bd->bi_boot_params = dove_dram_start(0) + 0x100; + + /* configure mpp */ + dove_mpp_conf(mpp_config); + + /* usb power enable */ + dove_gpio_direction_output(MPP1, GPIO_HIGH); + + /* blink led */ + dove_gpio_direction_output(MPP18, GPIO_HIGH); + dove_gpio_set_blink(MPP18, 1); + + return 0; +} + +#ifdef CONFIG_MMC +int board_mmc_init(bd_t *bis) +{ + dove_sdhci_init(0); + return 0; +} +#endif + +#ifdef CONFIG_RESET_PHY_R +void dove_eth_phy_init(char *name) +{ + u16 devadr; + + if (miiphy_set_current_dev(name)) + return; + + /* command to read PHY dev address */ + if (miiphy_read(name, 0xEE, 0xEE, (u16 *)&devadr)) { + printf("Err..%s could not read PHY dev address\n", + __func__); + return; + } + + /* reset the phy */ + miiphy_reset(name, devadr); + + printf("%s PHY initialized\n", name); +} + +void reset_phy(void) +{ + dove_eth_phy_init("egiga0"); +} +#endif /* CONFIG_RESET_PHY_R */ diff --git a/board/solidrun/cubox/kwbimage-spi-1gb.cfg b/board/solidrun/cubox/kwbimage-spi-1gb.cfg new file mode 100644 index 0000000..c3f1ad9 --- /dev/null +++ b/board/solidrun/cubox/kwbimage-spi-1gb.cfg @@ -0,0 +1,76 @@ +# +# Marvell BootROM config for SolidRun CuBox +# +# Sebastian Hesselbarth sebastian.hesselbarth@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# +# Refer docs/README.kwimage for more details about how-to configure +# and create kirkwood boot image +# + +# Boot Media configurations +BOOT_FROM spi + +# SOC registers configuration using bootrom header extension +# Maximum KWBIMAGE_MAX_CONFIG configurations allowed + +DATA 0xd0020104 0x00000000 # CPU Control and Status register + +# SDRAM initalization +DATA 0xd0800020 0x00022430 # SDRAM Configuration register 0 +DATA 0xd0800030 0x00022430 # SDRAM Configuration register 1 +DATA 0xd0800050 0x911500c3 # SDRAM Timing register 1 +DATA 0xd0800060 0x646602c4 # SDRAM Timing register 2 +DATA 0xd0800190 0xc2003053 # SDRAM Timing register 3 +DATA 0xd08001c0 0x34f4a187 # SDRAM Timing register 4 +DATA 0xd0800650 0x000f0121 # SDRAM Timing register 5 +DATA 0xd0800660 0x04040200 # SDRAM Timing register 6 +DATA 0xd0800080 0x00000000 # SDRAM Control register 1 +DATA 0xd0800090 0x00080000 # SDRAM Control register 2 +DATA 0xd08000f0 0xc0000000 # SDRAM Control register 3 +DATA 0xd08001a0 0x20c0c009 # SDRAM Control register 4 +DATA 0xd0800280 0x010e0202 # SDRAM Control register 5 +DATA 0xd0800760 0x00000000 # SDRAM Control register 6 +DATA 0xd0800770 0x0000000a # SDRAM Control register 7 +DATA 0xd0800140 0x20004044 # SDRAM PHY control register 3 +DATA 0xd08001d0 0x133c2339 # SDRAM PHY control register 7 +DATA 0xd08001e0 0x07700330 # SDRAM PHY control register 8 +DATA 0xd08001f0 0x00000033 # SDRAM PHY control register 9 +DATA 0xd0800200 0x0011311c # SDRAM PHY control register 10 +DATA 0xd0800210 0x00300000 # SDRAM PHY control register 11 +DATA 0xd0800240 0x80000000 # SDRAM PHY control register 14 +DATA 0xd0800510 0x010e0101 # SDRAM MCB control register 1 +DATA 0xd0800230 0x2028006a # SDRAM PHY control register 13 +DATA 0xd0800e10 0x00280062 # SDRAM PHY DLL control registers 2 +DATA 0xd0800e20 0x00280062 # SDRAM PHY DLL control registers 3 +DATA 0xd0800e30 0x00280062 # SDRAM PHY DLL control registers 4 + +# SDRAM memory map (2x512MB) +DATA 0xd0800100 0x000d0001 # SDRAM Memory Address Map register 1 +DATA 0xd0800110 0x200d0001 # SDRAM Memory Address Map register 1 + +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register + +# End of Header extension +DATA 0x0 0x0 diff --git a/board/solidrun/cubox/kwbimage-spi-2gb.cfg b/board/solidrun/cubox/kwbimage-spi-2gb.cfg new file mode 100644 index 0000000..7113c66 --- /dev/null +++ b/board/solidrun/cubox/kwbimage-spi-2gb.cfg @@ -0,0 +1,76 @@ +# +# Marvell BootROM config for SolidRun CuBox +# +# Sebastian Hesselbarth sebastian.hesselbarth@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# +# Refer docs/README.kwimage for more details about how-to configure +# and create kirkwood boot image +# + +# Boot Media configurations +BOOT_FROM spi + +# SOC registers configuration using bootrom header extension +# Maximum KWBIMAGE_MAX_CONFIG configurations allowed + +DATA 0xd0020104 0x00000000 # CPU Control and Status register + +# SDRAM initalization +DATA 0xd0800020 0x00022530 # SDRAM Configuration register 0 +DATA 0xd0800030 0x00022530 # SDRAM Configuration register 1 +DATA 0xd0800050 0x911500c3 # SDRAM Timing register 1 +DATA 0xd0800060 0x64660784 # SDRAM Timing register 2 +DATA 0xd0800190 0xc2003053 # SDRAM Timing register 3 +DATA 0xd08001c0 0x34f4a187 # SDRAM Timing register 4 +DATA 0xd0800650 0x000f0121 # SDRAM Timing register 5 +DATA 0xd0800660 0x04040200 # SDRAM Timing register 6 +DATA 0xd0800080 0x00000000 # SDRAM Control register 1 +DATA 0xd0800090 0x00080000 # SDRAM Control register 2 +DATA 0xd08000f0 0xc0000000 # SDRAM Control register 3 +DATA 0xd08001a0 0x20c0c009 # SDRAM Control register 4 +DATA 0xd0800280 0x010e0202 # SDRAM Control register 5 +DATA 0xd0800760 0x00000000 # SDRAM Control register 6 +DATA 0xd0800770 0x0000000a # SDRAM Control register 7 +DATA 0xd0800140 0x20004044 # SDRAM PHY control register 3 +DATA 0xd08001d0 0x133c2339 # SDRAM PHY control register 7 +DATA 0xd08001e0 0x07700330 # SDRAM PHY control register 8 +DATA 0xd08001f0 0x00000033 # SDRAM PHY control register 9 +DATA 0xd0800200 0x0011311c # SDRAM PHY control register 10 +DATA 0xd0800210 0x00300000 # SDRAM PHY control register 11 +DATA 0xd0800240 0x80000000 # SDRAM PHY control register 14 +DATA 0xd0800510 0x010e0101 # SDRAM MCB control register 1 +DATA 0xd0800230 0x2028006a # SDRAM PHY control register 13 +DATA 0xd0800e10 0x00280062 # SDRAM PHY DLL control registers 2 +DATA 0xd0800e20 0x00280062 # SDRAM PHY DLL control registers 3 +DATA 0xd0800e30 0x00280062 # SDRAM PHY DLL control registers 4 + +# SDRAM memory map (2x1GiB) +DATA 0xd0800100 0x000e0001 # SDRAM Memory Address Map register 1 +DATA 0xd0800110 0x400e0001 # SDRAM Memory Address Map register 1 + +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register + +# End of Header extension +DATA 0x0 0x0 diff --git a/board/solidrun/cubox/kwbimage-uart.cfg b/board/solidrun/cubox/kwbimage-uart.cfg new file mode 100644 index 0000000..0077615 --- /dev/null +++ b/board/solidrun/cubox/kwbimage-uart.cfg @@ -0,0 +1,76 @@ +# +# Marvell BootROM config for SolidRun CuBox +# +# Sebastian Hesselbarth sebastian.hesselbarth@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# +# Refer docs/README.kwimage for more deta+# and create kirkwood boot image +# + +# Boot Media configurations +BOOT_FROM uart + +# SOC registers configuration using bootrom header extension +# Maximum KWBIMAGE_MAX_CONFIG configurations allowed + +DATA 0xd0020104 0x00000000 # CPU Control and Status register + +# SDRAM initalization +DATA 0xd0800020 0x00022430 # SDRAM Configuration register 0 +DATA 0xd0800030 0x00022430 # SDRAM Configuration register 1 +DATA 0xd0800050 0x911500c3 # SDRAM Timing register 1 +DATA 0xd0800060 0x64660784 # SDRAM Timing register 2 +DATA 0xd0800190 0xc2003053 # SDRAM Timing register 3 +DATA 0xd08001c0 0x34f4a187 # SDRAM Timing register 4 +DATA 0xd0800650 0x000f0121 # SDRAM Timing register 5 +DATA 0xd0800660 0x04040200 # SDRAM Timing register 6 +DATA 0xd0800080 0x00000000 # SDRAM Control register 1 +DATA 0xd0800090 0x00080000 # SDRAM Control register 2 +DATA 0xd08000f0 0xc0000000 # SDRAM Control register 3 +DATA 0xd08001a0 0x20c0c009 # SDRAM Control register 4 +DATA 0xd0800280 0x010e0202 # SDRAM Control register 5 +DATA 0xd0800760 0x00000000 # SDRAM Control register 6 +DATA 0xd0800770 0x0000000a # SDRAM Control register 7 +DATA 0xd0800140 0x20004044 # SDRAM PHY control register 3 +DATA 0xd08001d0 0x133c2339 # SDRAM PHY control register 7 +DATA 0xd08001e0 0x07700330 # SDRAM PHY control register 8 +DATA 0xd08001f0 0x00000033 # SDRAM PHY control register 9 +DATA 0xd0800200 0x0011311c # SDRAM PHY control register 10 +DATA 0xd0800210 0x00300000 # SDRAM PHY control register 11 +DATA 0xd0800240 0x80000000 # SDRAM PHY control register 14 +DATA 0xd0800510 0x010e0101 # SDRAM MCB control register 1 +DATA 0xd0800230 0x2028006a # SDRAM PHY control register 13 +DATA 0xd0800e10 0x00280062 # SDRAM PHY DLL control registers 2 +DATA 0xd0800e20 0x00280062 # SDRAM PHY DLL control registers 3 +DATA 0xd0800e30 0x00280062 # SDRAM PHY DLL control registers 4 + +# SDRAM memory map (2x512MB) +DATA 0xd0800100 0x000d0001 # SDRAM Memory Address Map register 1 +DATA 0xd0800110 0x200d0001 # SDRAM Memory Address Map register 1 + +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register +DATA 0xd0020104 0x00000000 # CPU Control and Status register + +# End of Header extension +DATA 0x0 0x0 diff --git a/boards.cfg b/boards.cfg index 5d78064..425b5c5 100644 --- a/boards.cfg +++ b/boards.cfg @@ -316,6 +316,9 @@ dalmore arm armv7:arm720t dalmore nvidia colibri_t20_iris arm armv7:arm720t colibri_t20_iris toradex tegra20 u8500_href arm armv7 u8500 st-ericsson u8500 snowball arm armv7 snowball st-ericsson u8500 +cubox arm armv7 cubox solidrun dove cubox:CUBOX_1GB +cubox_pro arm armv7 cubox solidrun dove cubox:CUBOX_2GB +cubox_uart arm armv7 cubox solidrun dove cubox:CUBOX_UART_BOOT kzm9g arm armv7 kzm9g kmc rmobile armadillo-800eva arm armv7 armadillo-800eva atmark-techno rmobile zynq arm armv7 zynq xilinx zynq diff --git a/include/configs/cubox.h b/include/configs/cubox.h new file mode 100644 index 0000000..ab94cc5 --- /dev/null +++ b/include/configs/cubox.h @@ -0,0 +1,185 @@ +/* + * SolidRun CuBox config + * + * Sebastian Hesselbarth sebastian.hesselbarth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _CONFIG_CUBOX_H +#define _CONFIG_CUBOX_H +#include <asm/sizes.h> + +/* + * Version number information + */ +#define CONFIG_IDENT_STRING "SolidRun CuBox" + +#undef CONFIG_SYS_KWD_CONFIG +#if defined(CONFIG_CUBOX_UART_BOOT) +#define CONFIG_SYS_KWD_CONFIG $(SRCTREE)/$(CONFIG_BOARDDIR)/kwbimage-uart.cfg +#elif defined(CONFIG_CUBOX_1GB) +#define CONFIG_SYS_KWD_CONFIG $(SRCTREE)/$(CONFIG_BOARDDIR)/kwbimage-spi-1gb.cfg +#elif defined(CONFIG_CUBOX_2GB) +#define CONFIG_SYS_KWD_CONFIG $(SRCTREE)/$(CONFIG_BOARDDIR)/kwbimage-spi-2gb.cfg +#endif + +/* + * High Level Configuration Options + */ +#define CONFIG_MACH_SOLIDRUN_CUBOX /* Machine type */ +#define CONFIG_SHOW_BOOT_PROGRESS +#define CONFIG_DOVE_GPIO + +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +/* + * Enable u-boot API for standalone programs. + */ +#define CONFIG_API + +/* + * Enable device tree support + */ +#define CONFIG_OF_LIBFDT + +/* + * Commands configuration + */ +#include <config_cmd_default.h> +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ELF +#define CONFIG_CMD_ENV +#define CONFIG_CMD_IDE +#define CONFIG_CMD_PING +#define CONFIG_CMD_SF +#define CONFIG_CMD_SPI +#define CONFIG_CMD_USB +#define CONFIG_CMD_MMC + +#define CONFIG_DOS_PARTITION +#define CONFIG_EFI_PARTITION + +/* + * mv-common.h should be defined after CMD configs since it used them + * to enable certain macros + */ +#include "mv-common.h" + +/* + * redefine mv-common.h macros for armv7/cubox + */ +#undef CONFIG_SYS_PROMPT /* previously defined in mv-common.h */ +#define CONFIG_SYS_PROMPT "CuBox> " /* Command Prompt */ + +/* There is no arch_misc_init on armv7 */ +#undef CONFIG_ARCH_MISC_INIT + +#undef CONFIG_SYS_MALLOC_LEN +#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) /* 4MiB for malloc() */ + +/* + * Environment variables configurations + */ +#if defined(CONFIG_CMD_SF) +#define CONFIG_SPI_FLASH_WINBOND +#define CONFIG_ENV_IS_IN_SPI_FLASH 1 +#define CONFIG_ENV_SECT_SIZE 0x1000 /* 4k */ +#define CONFIG_ENV_SIZE 0x20000 /* 128k */ +#define CONFIG_ENV_OFFSET 0xc0000 /* env starts here */ +#else +#define CONFIG_ENV_IS_NOWHERE 1 /* if env in SDRAM */ +#endif + +/* + * Default CuBox bootscript environment + */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "bootscript=boot.scr\0" \ + "loadaddr=0x02000000\0" \ + "mmc_started=0\0" \ + "ide_started=0\0" \ + "usb_started=0\0" \ + "mtdparts=mtdparts=spi0.0:768k(u-boot)ro,128k(uboot_env),128k(fdt),-(empty)\0" + +#define CONFIG_BOOTCOMMAND \ + "for devn in usb mmc ide ; do " \ + " for part in 0 1; do " \ + " for dir in / /boot/;do " \ + " for fs in ext2 fat; do " \ + " echo ===> Executing ${fs}load ${devn} 0:${part} ${loadaddr} ${dir}${bootscript};" \ + " if itest.s $devn -eq mmc; then" \ + " if itest.s $mmc_started -ne 1; then" \ + " mmcinfo; setenv mmc_started '1';fi;fi;" \ + " if itest.s $devn -eq usb; then" \ + " if itest.s $usb_started -ne 1; then" \ + " usb start; setenv usb_started '1';fi;fi;" \ + " if itest.s $devn -eq ide; then" \ + " if itest.s $ide_started -ne 1; then" \ + " ide reset; setenv ide_started '1';fi;fi;" \ + " if ${fs}load ${devn} 0:${part} ${loadaddr} ${dir}${bootscript}; then" \ + " source ${loadaddr}; fi;" \ + " if itest.s $devn -eq usb; then" \ + " echo ===> Executing ${fs}load ${devn} 1:${part} ${loadaddr} ${dir}${bootscript};" \ + " if ${fs}load ${devn} 1:${part} ${loadaddr} ${dir}${bootscript}; then" \ + " source ${loadaddr}; fi;" \ + " fi;" \ + " done;" \ + " done;" \ + " done;" \ + "done;" \ + "tftp ${loadaddr} ${bootscript};" \ + "source ${loadaddr};" + +/* + * Ethernet Driver configuration + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_MVGBE_PORTS {1} /* enable port 0 */ +#define CONFIG_PHY_BASE_ADR 1 +#define CONFIG_PHYLIB +#define CONFIG_PHY_MARVELL +#endif /* CONFIG_CMD_NET */ + +#ifdef CONFIG_CMD_IDE +#undef CONFIG_IDE_LED +#undef CONFIG_SYS_IDE_MAXBUS +#define CONFIG_SYS_IDE_MAXBUS 1 +#undef CONFIG_SYS_IDE_MAXDEVICE +#define CONFIG_SYS_IDE_MAXDEVICE 1 +#define CONFIG_SYS_ATA_IDE0_OFFSET MV_SATA_PORT0_OFFSET +#endif + +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 + +/* + * File system + */ +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_EXT4 +#define CONFIG_CMD_FAT +#define CONFIG_RBTREE +#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_MTDPARTS +#define CONFIG_LZO + +#endif /* _CONFIG_CUBOX_H */
Hi Sebastian,
On Sun, 2 Dec 2012 15:36:12 +0100, Sebastian Hesselbarth sebastian.hesselbarth@gmail.com wrote:
This patch set add support for the Marvell Dove 88AP510 SoC and the SolidRun CuBox board based on that SoC. The patch set is divided into the four following sections:
(1) Patches 1-5: Add support for the Dove SoC and related drivers. Where possible drivers from Marvell Kirkwood are reused (mvsata, mvgbe), or forked to allow more generic usage (SPI, GPIO). The SDHCI driver is different and a new driver is added for it. The forked drivers can also be reused on Kirkwood but that would have required patching existing boards.
(2) Patches 6-8: Allow mvgbe to use the phylib API, add support for 88E1310 PHY and allow Dove to use the driver.
(3) Patch 9 Add the SolidRun CuBox as the first board based on Marvell Dove SoC.
(4) Patch 10 Add support for different UART boot mode found on Dove.
Sebastian Hesselbarth (10): ARM: dove: add support for Marvell Dove SoC GPIO: add gpio driver for Orion SoCs MMC: sdhci: Add support for dove sdhci SPI: Add Orion SPI driver block: mvsata: add dove include NET: phy: add 88E1310 PHY initialization NET: mvgbe: add phylib support NET: mvgbe: add support for Dove Boards: Add support for SolidRun CuBox tools: Add support for Dove to kwboot
Just a general remark: as this is a new support patch, it will only go in during next merge window; so when kirkwood or ARM pull requests are sent, make sure your patch set still applies to the new tree tip and if not, fix and submit a new version that does apply.
(mentioning this because you're touching files that I'm pretty sure are being modified by changes that *will* go in 2013.01)
Amicalement,
participants (14)
Albert ARIBAUD
Daniel Stodden
Jagan Teki
Jason Cooper
Jason Cooper
Joe Hershberger
Luka Perkov
Otavio Salvador
Prafulla Wadaskar
Sascha Silbe
Sascha Silbe
