[U-Boot] [PATCH] i2c: mxc: Hide kconfig based control in DM_I2C mode
These options only apply when not using DM_I2C. When using device trees, the dt will enable and control the speeds of the I2C controller(s) and these configuration options have no effect.
So disable them in DM_I2C mode. Otherwise they show up as decoys, and make it look like one is enabling I2C controllers and setting the speed when really it's doing nothing.
Cc: Sriram Dash sriram.dash@nxp.com Cc: Priyanka Jain priyanka.jain@nxp.com Cc: Heiko Schocher hs@denx.de Signed-off-by: Trent Piepho tpiepho@impinj.com --- drivers/i2c/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 1ef22e6bcd..df7fc7db0a 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -161,7 +161,7 @@ config SYS_I2C_MXC channels and operating on standard mode upto 100 kbits/s and fast mode upto 400 kbits/s.
-if SYS_I2C_MXC +if SYS_I2C_MXC && !DM_I2C config SYS_I2C_MXC_I2C1 bool "NXP MXC I2C1" help
Hello Trent,
Am 12.04.2019 um 21:19 schrieb Trent Piepho:
Your patch has checkpatch warning:
ERROR: DOS line endings #142: FILE: drivers/i2c/Kconfig:164: +if SYS_I2C_MXC && !DM_I2C^M$
Fixed this locally, please check furhter patches.
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
Hello Trent,
Am 30.04.2019 um 06:24 schrieb Heiko Schocher:
Hello Trent,
Also, your patch breaks travis build, see:
https://travis-ci.org/hsdenx/u-boot-i2c/jobs/526286390
arm: + wandboard +board/wandboard/wandboard.c: In function 'board_init': +board/wandboard/wandboard.c:466:15: error: 'CONFIG_SYS_MXC_I2C1_SPEED' undeclared (first use in this function); did you mean 'CONFIG_SYS_MMC_ENV_DEV'? + setup_i2c(1, CONFIG_SYS_MXC_I2C1_SPEED, 0x7f, &mx6dl_i2c2_pad_info); + ^~~~~~~~~~~~~~~~~~~~~~~~~ + CONFIG_SYS_MMC_ENV_DEV +board/wandboard/wandboard.c:466:15: note: each undeclared identifier is reported only once for each function it appears in +board/wandboard/wandboard.c:469:16: error: 'CONFIG_SYS_MXC_I2C2_SPEED' undeclared (first use in this function); did you mean 'CONFIG_SYS_MXC_I2C1_SPEED'? + setup_i2c(2, CONFIG_SYS_MXC_I2C2_SPEED, 0x7f, &mx6q_i2c3_pad_info); + ^~~~~~~~~~~~~~~~~~~~~~~~~ + CONFIG_SYS_MXC_I2C1_SPEED +make[2]: *** [board/wandboard/wandboard.o] Error 1 +make[1]: *** [board/wandboard] Error 2 +make: *** [sub-make] Error 2
Please check.
bye, Heiko
diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 1ef22e6bcd..df7fc7db0a 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -161,7 +161,7 @@ config SYS_I2C_MXC channels and operating on standard mode upto 100 kbits/s and fast mode upto 400 kbits/s. -if SYS_I2C_MXC +if SYS_I2C_MXC && !DM_I2C config SYS_I2C_MXC_I2C1 bool "NXP MXC I2C1" help
bye, Heiko
arm: + wandboard
- setup_i2c(1, CONFIG_SYS_MXC_I2C1_SPEED, 0x7f, &mx6dl_i2c2_pad_info);
- setup_i2c(2, CONFIG_SYS_MXC_I2C2_SPEED, 0x7f, &mx6q_i2c3_pad_info);
Please check.
This is caused by a conflict with "imx6: wandboard: convert to DM_I2C", which was applied after I sent my patch.
I'm not sure if that commit is correct. Copying Anatolij.
It's the only place where non-DM_I2C code uses the kconfig based configuration of I2C. If we look at the code in question:
Seems a bit odd bus 1 is being configured with i2c*2* pad info? But let's take a look at setup_i2c().
int setup_i2c(unsigned i2c_index, int speed, int slave_addr, struct i2c_pads_info *p) { .... /* Enable i2c clock */ ret = enable_i2c_clk(1, i2c_index); if (ret) goto err_clk;
/* Make sure bus is idle */ ret = force_idle_bus(p); if (ret) goto err_idle;
#ifndef CONFIG_DM_I2C bus_i2c_init(i2c_index, speed, slave_addr, force_idle_bus, p); #endif return 0;
err_idle: err_clk: gpio_free(p->scl.gp); err_req: gpio_free(p->sda.gp);
return ret; }
Nothing in the elided section uses "speed". It's only used in the bus_i2c_init() call, and that call is not made when using DM_I2C!
So while the wandboard code references CONFIG_SYS_MXC_I2C1_SPEED when using DM_i2C, it's never used by anything.
So I believe I'm still correct, even after the wandboard change that CONFIG_SYS_MXC_I2C1_SPEED et al are decoys that aren't used.
Hello Trent,
Am 30.04.2019 um 19:21 schrieb Trent Piepho:
arm: + wandboard
Please check.
Ah!
added also Stefano as imx6 maintainer.
return ret;
Yes, I think you are correct.
@Anatolij: Is this code needed anymore, as board is moved to DM ?
If I look into board/wandboard/wandboard.c
259 static int detect_i2c(struct display_info_t const *dev) 260 { 261 #ifdef CONFIG_DM_I2C 262 struct udevice *bus, *udev; 263 int rc; 264 265 rc = uclass_get_device_by_seq(UCLASS_I2C, dev->bus, &bus); 266 if (rc) 267 return rc; 268 rc = dm_i2c_probe(bus, dev->addr, 0, &udev); 269 if (rc) 270 return 0; 271 return 1; 272 #else 273 return (0 == i2c_set_bus_num(dev->bus)) && 274 (0 == i2c_probe(dev->addr)); 275 #endif 276 }
dm_i2c_probe should initialize the i2c bus completly, also we need not longer the:
and remove the else part ... or ? Can you test this change?
bye, Heiko
Hi Heiko,
On Thu, 2 May 2019 07:39:06 +0200 Heiko Schocher hs@denx.de wrote: ...
The DM conversion is not complete yet and I still need the possibility to revert to non-DM code for various video tests to complete the DM_VIDEO/DM_I2C conversion, so that video related stuff works on i.MX boards similar as before the conversion. Unfortunately, I do not have time for this now, this must wait. Sorry.
Anatolij
On Thu, 2019-05-02 at 08:11 +0200, Anatolij Gustschin wrote:
Hi Heiko,
Anatolij
Would something like this be ok? It will allow removing the MXC hardcoded speeds when using DM_I2C. It also makes it more clear in wandboard.c that the speed is not used when using DM_I2C.
--- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -46,6 +46,15 @@ DECLARE_GLOBAL_DATA_PTR; #define ETH_PHY_AR8035_POWER IMX_GPIO_NR(7, 13) #define REV_DETECTION IMX_GPIO_NR(2, 28)
+/* Speed defined in Kconfig is only applicable when not using DM_I2C. */ +#ifdef CONFIG_DM_I2C +#define I2C1_SPEED_NON_DM 0 +#define I2C2_SPEED_NON_DM 0 +#else +#define I2C1_SPEED_NON_DM CONFIG_SYS_MXC_I2C1_SPEED +#define I2C2_SPEED_NON_DM CONFIG_SYS_MXC_I2C2_SPEED +#endif + static bool with_pmic;
int dram_init(void) @@ -463,13 +472,13 @@ int board_init(void) gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
#if defined(CONFIG_VIDEO_IPUV3) - setup_i2c(1, CONFIG_SYS_MXC_I2C1_SPEED, 0x7f, &mx6dl_i2c2_pad_info); + setup_i2c(1, I2C1_SPEED_NON_DM, 0x7f, &mx6dl_i2c2_pad_info); if (is_mx6dq() || is_mx6dqp()) { - setup_i2c(1, CONFIG_SYS_MXC_I2C1_SPEED, 0x7f, &mx6q_i2c2_pad_info); - setup_i2c(2, CONFIG_SYS_MXC_I2C2_SPEED, 0x7f, &mx6q_i2c3_pad_info); + setup_i2c(1, I2C1_SPEED_NON_DM, 0x7f, &mx6q_i2c2_pad_info); + setup_i2c(2, I2C2_SPEED_NON_DM, 0x7f, &mx6q_i2c3_pad_info); } else { - setup_i2c(1, CONFIG_SYS_MXC_I2C1_SPEED, 0x7f, &mx6dl_i2c2_pad_info); - setup_i2c(2, CONFIG_SYS_MXC_I2C2_SPEED, 0x7f, &mx6dl_i2c3_pad_info); + setup_i2c(1, I2C1_SPEED_NON_DM, 0x7f, &mx6dl_i2c2_pad_info); + setup_i2c(2, I2C2_SPEED_NON_DM, 0x7f, &mx6dl_i2c3_pad_info); }
setup_display();
Hello Trent,
Am 03.05.2019 um 22:16 schrieb Trent Piepho:
Hi Heiko,
Anatolij
int dram_init(void)
setup_i2c(2, I2C2_SPEED_NON_DM, 0x7f, &mx6dl_i2c3_pad_info); } setup_display();
For this special case and for me, this is ok.
If nobody objects here, I would pick this change in conjunction with your original patch ... or you sent a formal v2 ?
Thanks!
bye, Heiko
Anatolij Gustschin
Heiko Schocher
Trent Piepho
