[U-Boot] Pull Request: u-boot-mpc86xx
The following changes since commit 1378174a1351c0285736863a665ab758fe8d5f71: Wolfgang Denk (1): Merge branch 'master' of /home/wd/git/u-boot/custodians
git://www.denx.de/git/u-boot-mpc86xx.git masterges since commit
Becky Bruce (18): mpc8641: Stop supporting non-PCI_PNP configs mpc8641: Make PCI and RIO mutually exclusive, fix non-PCI build powerpc 86xx: Handle CCSR relocation earlier 86xx: Make dram_size a phys_size_t 8641HPCN: Config file cleanup powerpc: change 86xx SMP boot method mpc8641: Remove extra "0" from BR2 define mpc86xx: Move setup_bats into cpu_init_f mpc8641: only define CONFIG_ENV_SIZE once mpc8641: Drop imaginary second flash bank, map 8MB mpc8641: make DIAG_ADDR == FLASH_BASE mpc86xx: Use SRR0/1/rfi to enable address translation, not blr mpc86xx: Change early FLASH mapping to 1M at CONFIG_MONITOR_BASE_EARLY mpc8641: Change 32-bit memory map mpc8641: Support 36-bit physical addressing toplevel Makefile: Add MPC8641HPCN_36BIT target mpc8641: Try to detect old .dts files lib_ppc: Move trap_init to occur earlier
Jon Loeliger (1): Merge commit 'wd/master'
Makefile | 8 +- board/freescale/mpc8610hpcd/mpc8610hpcd.c | 6 +- board/freescale/mpc8641hpcn/config.mk | 2 +- board/freescale/mpc8641hpcn/law.c | 35 ++-- board/freescale/mpc8641hpcn/mpc8641hpcn.c | 66 ++++--- cpu/mpc86xx/Makefile | 4 + cpu/mpc86xx/cpu_init.c | 8 + cpu/mpc86xx/fdt.c | 21 ++ cpu/mpc86xx/mp.c | 68 +++++++ cpu/mpc86xx/mp.h | 7 + cpu/mpc86xx/release.S | 169 +++++++++++++++++ cpu/mpc86xx/start.S | 186 ++++++++----------- doc/README.mpc8641hpcn | 64 +++++-- include/configs/MPC8610HPCD.h | 40 +++- include/configs/MPC8641HPCN.h | 289 ++++++++++++++++++++-------- include/configs/sbc8641d.h | 16 ++ lib_ppc/board.c | 10 +- 17 files changed, 721 insertions(+), 278 deletions(-)
Dear Jon Loeliger,
Applied, thanks.
Jon Loeliger
