[U-Boot] [PATCH]fsl/usb: Move USB internal phy definitions to fsl_usb.h
fsl_usb.h file created to share data bewteen usb platform code and usb ip driver. Internal phy structure definitions moved to this file
Signed-off-by: Ramneek Mehresh ramneek.mehresh@freescale.com --- Applies on git://git.denx.de/u-boot.git (branch master)
arch/powerpc/cpu/mpc85xx/cpu_init.c | 7 +-- arch/powerpc/include/asm/immap_85xx.h | 48 --------------------- include/fsl_usb.h | 80 +++++++++++++++++++++++++++++++++++ 3 files changed, 84 insertions(+), 51 deletions(-) create mode 100644 include/fsl_usb.h
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 25beda2..5aa09c1 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -22,6 +22,7 @@ #include <asm/fsl_law.h> #include <asm/fsl_serdes.h> #include <asm/fsl_srio.h> +#include <fsl_usb.h> #include <hwconfig.h> #include <linux/compiler.h> #include "mp.h" @@ -595,7 +596,7 @@ skip_l2:
#ifdef CONFIG_SYS_FSL_USB1_PHY_ENABLE { - ccsr_usb_phy_t *usb_phy1 = + struct ccsr_usb_phy __iomem *usb_phy1 = (void *)CONFIG_SYS_MPC85xx_USB1_PHY_ADDR; out_be32(&usb_phy1->usb_enable_override, CONFIG_SYS_FSL_USB_ENABLE_OVERRIDE); @@ -603,7 +604,7 @@ skip_l2: #endif #ifdef CONFIG_SYS_FSL_USB2_PHY_ENABLE { - ccsr_usb_phy_t *usb_phy2 = + struct ccsr_usb_phy __iomem *usb_phy2 = (void *)CONFIG_SYS_MPC85xx_USB2_PHY_ADDR; out_be32(&usb_phy2->usb_enable_override, CONFIG_SYS_FSL_USB_ENABLE_OVERRIDE); @@ -625,7 +626,7 @@ skip_l2: #endif
#if defined(CONFIG_SYS_FSL_USB_DUAL_PHY_ENABLE) - ccsr_usb_phy_t *usb_phy = + struct ccsr_usb_phy __iomem *usb_phy = (void *)CONFIG_SYS_MPC85xx_USB1_PHY_ADDR; setbits_be32(&usb_phy->pllprg[1], CONFIG_SYS_FSL_USB_PLLPRG2_PHY2_CLK_EN | diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 81b3322..3bc0708 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -2811,54 +2811,6 @@ typedef struct ccsr_pme { u8 res4[0x400]; } ccsr_pme_t;
-#ifdef CONFIG_SYS_FSL_USB_DUAL_PHY_ENABLE -struct ccsr_usb_port_ctrl { - u32 ctrl; - u32 drvvbuscfg; - u32 pwrfltcfg; - u32 sts; - u8 res_14[0xc]; - u32 bistcfg; - u32 biststs; - u32 abistcfg; - u32 abiststs; - u8 res_30[0x10]; - u32 xcvrprg; - u32 anaprg; - u32 anadrv; - u32 anasts; -}; - -typedef struct ccsr_usb_phy { - u32 id; - struct ccsr_usb_port_ctrl port1; - u8 res_50[0xc]; - u32 tvr; - u32 pllprg[4]; - u8 res_70[0x4]; - u32 anaccfg; - u32 dbg; - u8 res_7c[0x4]; - struct ccsr_usb_port_ctrl port2; - u8 res_dc[0x334]; -} ccsr_usb_phy_t; - -#define CONFIG_SYS_FSL_USB_CTRL_PHY_EN (1 << 0) -#define CONFIG_SYS_FSL_USB_DRVVBUS_CR_EN (1 << 1) -#define CONFIG_SYS_FSL_USB_PWRFLT_CR_EN (1 << 1) -#define CONFIG_SYS_FSL_USB_PLLPRG2_PHY2_CLK_EN (1 << 0) -#define CONFIG_SYS_FSL_USB_PLLPRG2_PHY1_CLK_EN (1 << 1) -#define CONFIG_SYS_FSL_USB_PLLPRG2_MFI (5 << 16) -#define CONFIG_SYS_FSL_USB_PLLPRG2_PLL_EN (1 << 21) -#else -typedef struct ccsr_usb_phy { - u8 res0[0x18]; - u32 usb_enable_override; - u8 res[0xe4]; -} ccsr_usb_phy_t; -#define CONFIG_SYS_FSL_USB_ENABLE_OVERRIDE 1 -#endif - #ifdef CONFIG_SYS_FSL_RAID_ENGINE struct ccsr_raide { u8 res0[0x543]; diff --git a/include/fsl_usb.h b/include/fsl_usb.h new file mode 100644 index 0000000..88d6a1f --- /dev/null +++ b/include/fsl_usb.h @@ -0,0 +1,80 @@ +/* + * Freescale USB Controller + * + * Copyright 2013 Freescale Semiconductor, Inc. + * + * This software may be used and distributed according to the + * terms of the GNU Public License, Version 2, incorporated + * herein by reference. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * Version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _ASM_FSL_USB_H_ +#define _ASM_FSL_USB_H_ + +#ifdef CONFIG_SYS_FSL_USB_DUAL_PHY_ENABLE +struct ccsr_usb_port_ctrl { + u32 ctrl; + u32 drvvbuscfg; + u32 pwrfltcfg; + u32 sts; + u8 res_14[0xc]; + u32 bistcfg; + u32 biststs; + u32 abistcfg; + u32 abiststs; + u8 res_30[0x10]; + u32 xcvrprg; + u32 anaprg; + u32 anadrv; + u32 anasts; +}; + +struct ccsr_usb_phy { + u32 id; + struct ccsr_usb_port_ctrl port1; + u8 res_50[0xc]; + u32 tvr; + u32 pllprg[4]; + u8 res_70[0x4]; + u32 anaccfg; + u32 dbg; + u8 res_7c[0x4]; + struct ccsr_usb_port_ctrl port2; + u8 res_dc[0x334]; +}; + +#define CONFIG_SYS_FSL_USB_CTRL_PHY_EN (1 << 0) +#define CONFIG_SYS_FSL_USB_DRVVBUS_CR_EN (1 << 1) +#define CONFIG_SYS_FSL_USB_PWRFLT_CR_EN (1 << 1) +#define CONFIG_SYS_FSL_USB_PLLPRG1_PHY_DIV (1 << 0) +#define CONFIG_SYS_FSL_USB_PLLPRG2_PHY2_CLK_EN (1 << 0) +#define CONFIG_SYS_FSL_USB_PLLPRG2_PHY1_CLK_EN (1 << 1) +#define CONFIG_SYS_FSL_USB_PLLPRG2_FRAC_LPF_EN (1 << 13) +#define CONFIG_SYS_FSL_USB_PLLPRG2_REF_DIV (1 << 4) +#define CONFIG_SYS_FSL_USB_PLLPRG2_MFI (5 << 16) +#define CONFIG_SYS_FSL_USB_PLLPRG2_PLL_EN (1 << 21) +#define CONFIG_SYS_FSL_USB_SYS_CLK_VALID (1 << 0) +#else +struct ccsr_usb_phy { + u8 res0[0x18]; + u32 usb_enable_override; + u8 res[0xe4]; +}; +#define CONFIG_SYS_FSL_USB_ENABLE_OVERRIDE 1 +#endif + +#endif /*_ASM_FSL_USB_H_ */
On 08/05/2013 03:30 AM, Ramneek Mehresh wrote:
<snip>
- Freescale USB Controller
- Copyright 2013 Freescale Semiconductor, Inc.
- This software may be used and distributed according to the
- terms of the GNU Public License, Version 2, incorporated
- herein by reference.
- modify it under the terms of the GNU General Public License
- Version 2 as published by the Free Software Foundation.
- MA 02111-1307 USA
Mehresh,
I am trying to apply this patch and clean up the license header with SPDX license identifier. I noticed you are using GPL v2. As most of u-boot code uses GPL v2+ (with very few files under GPL v2), do you have a specific reason to stay with v2? If not, I am going to replace it with GPL v2.0+.
Regards,
York
Ramneek Mehresh
York Sun
