[U-Boot] [PATCH] dm: Remove device_probe_child()
This function is not used as the use case for it did not eventuate. Remove it to avoid confusion.
drivers/core/device.c | 9 +-------- include/dm/device-internal.h | 13 ------------- 2 files changed, 1 insertion(+), 21 deletions(-)
diff --git a/drivers/core/device.c b/drivers/core/device.c index f5def35..cb24a61 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -223,7 +223,7 @@ static void *alloc_priv(int size, uint flags) return priv; }
-int device_probe_child(struct udevice *dev, void *parent_priv) +int device_probe(struct udevice *dev) { const struct driver *drv; int size = 0; @@ -270,8 +270,6 @@ int device_probe_child(struct udevice *dev, void *parent_priv) ret = -ENOMEM; goto fail; } - if (parent_priv) - memcpy(dev->parent_priv, parent_priv, size); }
ret = device_probe(dev->parent); @@ -349,11 +347,6 @@ fail: return ret; }
-int device_probe(struct udevice *dev) -{ - return device_probe_child(dev, NULL); -} - void *dev_get_platdata(struct udevice *dev) { if (!dev) { diff --git a/include/dm/device-internal.h b/include/dm/device-internal.h index 9388870..b348ad5 100644 --- a/include/dm/device-internal.h +++ b/include/dm/device-internal.h @@ -66,19 +66,6 @@ int device_bind_by_name(struct udevice *parent, bool pre_reloc_only, int device_probe(struct udevice *dev);
/** - * device_probe() - Probe a child device, activating it - * - * Activate a device so that it is ready for use. All its parents are probed - * first. The child is provided with parent data if parent_priv is not NULL. - * - * @dev: Pointer to device to probe - * @parent_priv: Pointer to parent data. If non-NULL then this is provided to - * the child. - * @return 0 if OK, -ve on error - */ -int device_probe_child(struct udevice *dev, void *parent_priv); - -/** * device_remove() - Remove a device, de-activating it * * De-activate a device so that it is no longer ready for use. All its
Applied to u-boot-dm.
Bin Meng
