[U-Boot] [PATCH] arm: socfpga: Enable ubi and ubifs support
When QSPI and NAND is enabled, the ubi and ubifs support will be enabled too.
Signed-off-by: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Dinh Nguyen dinh.linux@gmail.com Cc: Pavel Machek pavel@denx.de Cc: Marek Vasut marex@denx.de Cc: Stefan Roese sr@denx.de --- include/configs/socfpga_common.h | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index b3f65b6..a07017b 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -274,6 +274,14 @@ unsigned int cm_get_qspi_controller_clk_hz(void); #define CONFIG_SYS_CONSOLE_ENV_OVERWRITE #define CONFIG_ENV_SIZE 4096
+/* UBIFS support */ +#if defined(CONFIG_CMD_SF) || defined(CONFIG_CMD_NAND) +#define CONFIG_CMD_UBI +#define CONFIG_CMD_UBIFS +#define CONFIG_RBTREE +#define CONFIG_LZO +#endif + /* * SPL * -- 1.9.2.468.g3f0c02a
Hi Marek,
I have issue on ubifsmount my ubinized image. I suspect it might created wrongly. The code is ok based on previous patches and the one you sent to me. Wonder you might able to validate with your working ubinized image?
Thanks in advance! Chin Liang
- SPL
On Friday, December 11, 2015 at 10:25:59 AM, Chin Liang See wrote:
Hi Marek,
Try applying this patch:
[PATCH] arm: Replace test for CONFIG_ARMV7 with CONFIG_CPU_V7
And then erase the SPI flash, reinstall the ubi image and try again. Does it help ?
Best regards, Marek Vasut
Chin Liang See
