[U-Boot] [PATCH v2] sun50i: a64: Add A64-OLinuXino initial support
OLimex A64-OLinuXino is an open-source hardware board using the Allwinner A64 SOC.
OLimex A64-OLinuXino has - A64 Quad-core Cortex-A53 64bit - 1GB or 2GB RAM DDR3L @ 672Mhz - microSD slot and 4/8/16GB eMMC - Debug TTL UART - HDMI - LCD - IR receiver - 5V DC power supply
Tested-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - Tested on latest - Sync to Linux
arch/arm/dts/Makefile | 1 + arch/arm/dts/sun50i-a64-olinuxino.dts | 84 +++++++++++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 5 +++ configs/a64-olinuxino_defconfig | 15 +++++++ 4 files changed, 105 insertions(+) create mode 100644 arch/arm/dts/sun50i-a64-olinuxino.dts create mode 100644 configs/a64-olinuxino_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 8da32d8..21a8103 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -336,6 +336,7 @@ dtb-$(CONFIG_MACH_SUN50I_H5) += \ dtb-$(CONFIG_MACH_SUN50I) += \ sun50i-a64-bananapi-m64.dtb \ sun50i-a64-nanopi-a64.dtb \ + sun50i-a64-olinuxino.dtb \ sun50i-a64-orangepi-win.dtb \ sun50i-a64-pine64-plus.dtb \ sun50i-a64-pine64.dtb diff --git a/arch/arm/dts/sun50i-a64-olinuxino.dts b/arch/arm/dts/sun50i-a64-olinuxino.dts new file mode 100644 index 0000000..7bd4730 --- /dev/null +++ b/arch/arm/dts/sun50i-a64-olinuxino.dts @@ -0,0 +1,84 @@ +/* + * Copyright (C) 2017 Jagan Teki jteki@openedev.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This library is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This library is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; + +#include "sun50i-a64.dtsi" + +#include <dt-bindings/gpio/gpio.h> + +/ { + model = "Olimex A64-Olinuxino"; + compatible = "olimex,a64-olinuxino", "allwinner,sun50i-a64"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + reg_vcc3v3: vcc3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; + vmmc-supply = <®_vcc3v3>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; + cd-inverted; + disable-wp; + bus-width = <4>; + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 3b8d544..ff6eea2 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -98,6 +98,11 @@ M: Stefan Mavrodiev stefan.mavrodiev@gmail.com S: Maintained F: configs/A33-OLinuXino_defconfig
+A64-OLINUXINO BOARD +M: Jagan Teki jagan@amarulasolutions.com +S: Maintained +F: configs/a64-olinuxino_defconfig + A80 OPTIMUS BOARD M: Chen-Yu Tsai wens@csie.org S: Maintained diff --git a/configs/a64-olinuxino_defconfig b/configs/a64-olinuxino_defconfig new file mode 100644 index 0000000..14f2c3d --- /dev/null +++ b/configs/a64-olinuxino_defconfig @@ -0,0 +1,15 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN50I=y +CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER=y +CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-olinuxino" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SUN8I_EMAC=y +CONFIG_USB_EHCI_HCD=y
Synced ohci0 and ehci0 nodes from Linux for sun50i-a64.dtsi
Here is the Linux last merge tag details: Merge: 0e91f43d e5770b7 Author: Stephen Rothwell sfr@canb.auug.org.au Date: Fri Jun 9 14:59:55 2017 +1000
Merge remote-tracking branch 'staging/staging-next'
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v5: - none
arch/arm/dts/sun50i-a64.dtsi | 22 ++++++++++++++++++++++ 1 file changed, 22 insertions(+)
diff --git a/arch/arm/dts/sun50i-a64.dtsi b/arch/arm/dts/sun50i-a64.dtsi index c7f669f..65a344d 100644 --- a/arch/arm/dts/sun50i-a64.dtsi +++ b/arch/arm/dts/sun50i-a64.dtsi @@ -204,6 +204,28 @@ #phy-cells = <1>; };
+ ehci0: usb@01c1a000 { + compatible = "allwinner,sun50i-a64-ehci", "generic-ehci"; + reg = <0x01c1a000 0x100>; + interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_OHCI0>, + <&ccu CLK_BUS_EHCI0>, + <&ccu CLK_USB_OHCI0>; + resets = <&ccu RST_BUS_OHCI0>, + <&ccu RST_BUS_EHCI0>; + status = "disabled"; + }; + + ohci0: usb@01c1a400 { + compatible = "allwinner,sun50i-a64-ohci", "generic-ohci"; + reg = <0x01c1a400 0x100>; + interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_OHCI0>, + <&ccu CLK_USB_OHCI0>; + resets = <&ccu RST_BUS_OHCI0>; + status = "disabled"; + }; + ehci1: usb@01c1b000 { compatible = "allwinner,sun50i-a64-ehci", "generic-ehci"; reg = <0x01c1b000 0x100>;
Applied to u-boot-sunxi/master
thanks!
NanoPi A64 is a new board of high performance with low cost designed by FriendlyElec., using the Allwinner A64 SOC.
Nanopi A64 features - Allwinner A64, 64-bit Quad-core Cortex-A53@648MHz to 1.152GHz, DVFS - 1GB DDR3 RAM - MicroSD - Gigabit Ethernet (RTL8211E) - Wi-Fi 802.11b/g/n - IR receiver - Audio In/Out - Video In/Out - Serial Debug Port - microUSB 5V 2A DC power-supply
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Tested-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v5: - Sync to Linux Changes for v4: - Added serial1 alias - Fix to use mmc1 for SDIO instead of mmc2 - Replace buswidth by 4 instead of 8 mmc1 - Drop cap-mmc-hw-reset for mmc1 Changes for v3: - Added ohci0, ehci0, ohic1, ehci1, usbphy, mmc1 and uart1 nodes
arch/arm/dts/Makefile | 1 + arch/arm/dts/sun50i-a64-nanopi-a64.dts | 115 +++++++++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 5 ++ configs/nanopi_a64_defconfig | 15 +++++ 4 files changed, 136 insertions(+) create mode 100644 arch/arm/dts/sun50i-a64-nanopi-a64.dts create mode 100644 configs/nanopi_a64_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index c2dc240..8da32d8 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -335,6 +335,7 @@ dtb-$(CONFIG_MACH_SUN50I_H5) += \ sun50i-h5-orangepi-zero-plus2.dtb dtb-$(CONFIG_MACH_SUN50I) += \ sun50i-a64-bananapi-m64.dtb \ + sun50i-a64-nanopi-a64.dtb \ sun50i-a64-orangepi-win.dtb \ sun50i-a64-pine64-plus.dtb \ sun50i-a64-pine64.dtb diff --git a/arch/arm/dts/sun50i-a64-nanopi-a64.dts b/arch/arm/dts/sun50i-a64-nanopi-a64.dts new file mode 100644 index 0000000..778636c --- /dev/null +++ b/arch/arm/dts/sun50i-a64-nanopi-a64.dts @@ -0,0 +1,115 @@ +/* + * Copyright (C) 2017 Jagan Teki jteki@openedev.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This library is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This library is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; + +#include "sun50i-a64.dtsi" + +#include <dt-bindings/gpio/gpio.h> + +/ { + model = "FriendlyARM NanoPi A64"; + compatible = "friendlyarm,nanopi-a64", "allwinner,sun50i-a64"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + reg_vcc3v3: vcc3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; +}; + +&ehci0 { + status = "okay"; +}; + +&ehci1 { + status = "okay"; +}; + +/* i2c1 connected with gpio headers like pine64, bananapi */ +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins>; + status = "disabled"; +}; + +&i2c1_pins { + bias-pull-up; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; + vmmc-supply = <®_vcc3v3>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; + cd-inverted; + disable-wp; + bus-width = <4>; + status = "okay"; +}; + +&ohci0 { + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; + +&usbphy { + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index ed4d4c3..3b8d544 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -272,6 +272,11 @@ M: Jelle van der Waa jelle@vdwaa.nl S: Maintained F: configs/nanopi_neo_air_defconfig
+NANOPI-A64 BOARD +M: Jagan Teki jagan@amarulasolutions.com +S: Maintained +F: configs/nanopi_a64_defconfig + NINTENDO NES CLASSIC EDITION BOARD M: FUKAUMI Naoki naobsd@gmail.com S: Maintained diff --git a/configs/nanopi_a64_defconfig b/configs/nanopi_a64_defconfig new file mode 100644 index 0000000..2f4ed11 --- /dev/null +++ b/configs/nanopi_a64_defconfig @@ -0,0 +1,15 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN50I=y +CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER=y +CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-nanopi-a64" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SUN8I_EMAC=y +CONFIG_USB_EHCI_HCD=y
Nanopi A64 features
- 1GB DDR3 RAM
- MicroSD
- Wi-Fi 802.11b/g/n
- IR receiver
- Audio In/Out
- Video In/Out
- Serial Debug Port
thanks!
- Debug TTL UART
- HDMI
- LCD
- IR receiver
thanks!
Jagan Teki
