[U-Boot] [xHCI] Controller failure with USB 3.0 hub
Hello Bin,
I noticed a potential bug in the U-Boot xHCI implementation. I observe this one Renesas RCar Gen3 platform.
If I plug a USB 3.0 hub into the root port, I see the following error: ERROR: Configure Endpoint command returned completion code 5. If I plug a USB 3.0 stick into the root port, I do not get the error and the stick is correctly detected.
Example with the USB 3.0 hub:
=> usb reset resetting USB... USB0: Register 2000120 NbrPorts 2 Starting the controller USB XHCI 1.00 USB1: USB EHCI 1.10 USB2: USB EHCI 1.10 USB3: USB EHCI 1.10 ******** HERE ******** scanning bus 0 for devices... ERROR: Configure Endpoint command returned completion code 5. ******** HERE ******** 1 USB Device(s) found scanning bus 1 for devices... 1 USB Device(s) found scanning bus 2 for devices... 1 USB Device(s) found scanning bus 3 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found => usb tree USB device tree: 1 Hub (5 Gb/s, 0mA) U-Boot XHCI Host Controller
1 Hub (480 Mb/s, 0mA) u-boot EHCI Host Controller
If I revert d228ca362b though, the setup starts working fine. In fact, if I just commend out xhci_update_hub_device() in xhci_usb_ops , it works fine as well.
Moreover, if I use the following patch, it works fine too:
diff --git a/drivers/usb/host/xhci.c b/drivers/usb/host/xhci.c index 3adb0028f2..bd393d92bb 100644 --- a/drivers/usb/host/xhci.c +++ b/drivers/usb/host/xhci.c @@ -1453,7 +1453,7 @@ static int xhci_update_hub_device(struct udevice *dev, struct usb_device *udev) if (udev->speed == USB_SPEED_HIGH) slot_ctx->tt_info |= cpu_to_le32(TT_THINK_TIME(think_time));
- return xhci_configure_endpoints(udev, false); + return xhci_configure_endpoints(udev, true); }
static int xhci_get_max_xfer_size(struct udevice *dev, size_t *size)
That is:
=> usb reset resetting USB... USB0: Register 2000120 NbrPorts 2 Starting the controller USB XHCI 1.00 USB1: USB EHCI 1.10 USB2: USB EHCI 1.10 USB3: USB EHCI 1.10 scanning bus 0 for devices... 5 USB Device(s) found scanning bus 1 for devices... 1 USB Device(s) found scanning bus 2 for devices... 1 USB Device(s) found scanning bus 3 for devices... 1 USB Device(s) found scanning usb for storage devices... 2 Storage Device(s) found => usb tree USB device tree: 1 Hub (5 Gb/s, 0mA) | U-Boot XHCI Host Controller | +-2 Hub (5 Gb/s, 2mA) | | VIA Labs, Inc. 4-Port USB 3.0 Hub | | | +-4 Mass Storage (5 Gb/s, 224mA) | SanDisk Ultra 4C530001110620109113 | +-3 Hub (480 Mb/s, 100mA) | USB2.0 Hub | +-5 Mass Storage (480 Mb/s, 200mA) USB FLASH DRIVE 195A06010623
Do you have an explanation for me ?
Hi Marek,
On Sat, May 19, 2018 at 9:03 AM, Marek Vasut marek.vasut@gmail.com wrote:
Hello Bin,
Completion code 5 means TRB parameter error, guess the Renesas xHC has some checks on the TRB.
Can you try the following patch to see if it makes any difference?
diff --git a/drivers/usb/host/xhci.c b/drivers/usb/host/xhci.c index 3adb002..eec3f64 100644 --- a/drivers/usb/host/xhci.c +++ b/drivers/usb/host/xhci.c @@ -1453,6 +1453,8 @@ static int xhci_update_hub_device(struct udevice *dev, struct usb_device *udev) if (udev->speed == USB_SPEED_HIGH) slot_ctx->tt_info |= cpu_to_le32(TT_THINK_TIME(think_time));
+ slot_ctx->dev_state = 0; + return xhci_configure_endpoints(udev, false); }
That is:
Regards, Bin
On 05/19/2018 01:09 PM, Bin Meng wrote:
Hi Marek,
Hello Bin,
Do you have xhci spec chapter reference/number for me too ? :)
Doesn't make any difference, sorry.
Hi Marek,
Hi Marek,
Hello Bin,
I was looking at xhci spec 1.1 chapter 6.4.5 TRB Completion Codes. I don't have Renesas xHC manual to cross check.
Too bad. Then I don't have any obvious clue so far. The completion code 5 is a helpful sign from xHC to the software that something was wrong in the TRB. Per the xHCI spec, dev_state needs to be cleared. It was working with the x86 xHC though. Changing xhci_configure_endpoints(udev, false) to xhci_configure_endpoints(udev, true) is not correct as the Evaluate Context command is not used with configure the hub attributes.
Regards, Bin
Hi Marek,
On Sat, May 19, 2018 at 7:54 PM, Bin Meng bmeng.cn@gmail.com wrote:
Hi Marek,
Hi Marek,
Hello Bin,
To continue debugging this, could you print out the slot context contents (slot_ctx->*) before calling xhci_configure_endpoints(udev, false)?
Regards, Bin
Bin Meng
