[U-Boot] [PATCH v3] apalis_imx6: add device tree to makefile
Add device tree to Makefile to avoid newly introduced error:
Device Tree Source is not correctly specified. Please define 'CONFIG_DEFAULT_DEVICE_TREE' or build with 'DEVICE_TREE=<device_tree>' argument
make[1]: *** [dts/Makefile:28: arch/arm/dts/imx6-apalis.dtb] Error 1 make: *** [Makefile:1009: dts/dt.dtb] Error 2
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Reviewed-by: Igor Opaniuk igor.opaniuk@toradex.com
Changes in v3: - Added Igor's reviewed-by tag.
Changes in v2: - Drop adding the colibri-imx6 device tree as Stefano already pulled v1 75992d0e7dfc ("apalis/colibri_imx6: add device trees to makefile") but somehow dropped adding the apalis-imx6 one as well.
arch/arm/dts/Makefile | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 92074cd8da..13d1d67624 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -548,6 +548,7 @@ dtb-$(CONFIG_MX6ULL) += \ imx6ull-colibri.dtb \
dtb-$(CONFIG_ARCH_MX6) += \ + imx6-apalis.dtb \ imx6-colibri.dtb
dtb-$(CONFIG_MX7) += imx7d-sdb.dtb \
Marcel Ziswiler
