[U-Boot] [PATCH] powerpc/85xx: Fix warning for USB device-fixup
Fix USB device-fixup warning "node not found". This was occuring because of static nature of start_offset variable
Static start_offset was storing offset of last node modified, and was becoming issue if node fixup is carried multiple times, resulting in "node not found" warning
Signed-off-by: Ramneek Mehresh ramneek.mehresh@freescale.com --- arch/powerpc/cpu/mpc8xxx/fdt.c | 24 +++++++++++++----------- 1 files changed, 13 insertions(+), 11 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/fdt.c b/arch/powerpc/cpu/mpc8xxx/fdt.c index 112c603..d07ae1b 100644 --- a/arch/powerpc/cpu/mpc8xxx/fdt.c +++ b/arch/powerpc/cpu/mpc8xxx/fdt.c @@ -87,13 +87,12 @@ void ft_fixup_num_cores(void *blob) { #endif /* defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) */
#ifdef CONFIG_HAS_FSL_DR_USB -static void fdt_fixup_usb_mode_phy_type(void *blob, const char *mode, - const char *phy_type) +static int fdt_fixup_usb_mode_phy_type(void *blob, const char *mode, + const char *phy_type, int start_offset) { const char *compat = "fsl-usb2-dr"; const char *prop_mode = "dr_mode"; const char *prop_type = "phy_type"; - static int start_offset = -1; int node_offset; int err;
@@ -102,7 +101,7 @@ static void fdt_fixup_usb_mode_phy_type(void *blob, const char *mode, if (node_offset < 0) { printf("WARNING: could not find compatible node %s: %s.\n", compat, fdt_strerror(node_offset)); - return; + return -1; }
if (mode) { @@ -121,16 +120,18 @@ static void fdt_fixup_usb_mode_phy_type(void *blob, const char *mode, prop_type, compat, fdt_strerror(err)); }
- start_offset = node_offset; + return node_offset; }
void fdt_fixup_dr_usb(void *blob, bd_t *bd) { const char *modes[] = { "host", "peripheral", "otg" }; - const char *phys[] = { "ulpi", "umti" }; + const char *phys[] = { "ulpi", "utmi" }; const char *mode = NULL; const char *phy_type = NULL; char usb1_defined = 0; + int usb_mode_off = -1; + int usb_phy_off = -1; char str[5]; int i, j;
@@ -153,11 +154,11 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd) } } if (mode_idx >= 0) - fdt_fixup_usb_mode_phy_type(blob, - modes[mode_idx], NULL); + usb_mode_off = fdt_fixup_usb_mode_phy_type(blob, + modes[mode_idx], NULL, usb_mode_off); if (phy_idx >= 0) - fdt_fixup_usb_mode_phy_type(blob, - NULL, phys[phy_idx]); + usb_phy_off = fdt_fixup_usb_mode_phy_type(blob, + NULL, phys[phy_idx], usb_phy_off); if (!strcmp(str, "usb1")) usb1_defined = 1; if (mode_idx < 0 && phy_idx < 0) @@ -165,11 +166,12 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd) } } if (!usb1_defined) { + int usb_off = -1; mode = getenv("usb_dr_mode"); phy_type = getenv("usb_phy_type"); if (!mode && !phy_type) return; - fdt_fixup_usb_mode_phy_type(blob, mode, phy_type); + fdt_fixup_usb_mode_phy_type(blob, mode, phy_type, usb_off); } } #endif /* CONFIG_HAS_FSL_DR_USB */
applied to 85xx
- k
Kumar Gala
Ramneek Mehresh
