[U-Boot] [PATCH v2 0/2] efi_loader: device_path: support Sandbox's host device
Changes in v2 (Sept 12, 2019) * use "vendor device path" with dedicate guid instead of LUN * add patch#2 for pretty printing
AKASHI Takahiro (2): efi_loader: device_path: support Sandbox's "host" devices efi_loader: device_path: show a host device in understandable form
include/efi_loader.h | 8 ++++++ lib/efi_loader/efi_device_path.c | 33 ++++++++++++++++++++++++ lib/efi_loader/efi_device_path_to_text.c | 5 ++++ 3 files changed, 46 insertions(+)
Sandbox's "host" devices are currently described as UCLASS_ROOT udevice with DEV_IF_HOST block device. As the current implementation of efi_device_path doesn't support such a type, any "host" device on sandbox cannot be seen as a distinct object.
For example, => host bind 0 /foo/disk.img
=> efi devices Scanning disk host0... Found 1 disks Device Device Path ================ ==================== 0000000015c19970 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b) 0000000015c19d70 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)
=> efi dh Handle Protocols ================ ==================== 0000000015c19970 Device Path, Device Path To Text, Device Path Utilities, Unicode Collation 2, HII String, HII Database, HII Config Routing 0000000015c19ba0 Driver Binding 0000000015c19c10 Simple Text Output 0000000015c19c80 Simple Text Input, Simple Text Input Ex 0000000015c19d70 Block IO, Device Path, Simple File System
As you can see here, efi_root (0x0000000015c19970) and host0 device (0x0000000015c19d70) has the same representation of device path.
This is not only inconvenient, but also confusing since two different efi objects are associated with the same device path and efi_dp_find_obj() will possibly return a wrong result.
Solution: Each "host" device should be given an additional device path node of "vendor device path" to make it distinguishable.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- include/efi_loader.h | 8 ++++++++ lib/efi_loader/efi_device_path.c | 33 ++++++++++++++++++++++++++++++++ 2 files changed, 41 insertions(+)
diff --git a/include/efi_loader.h b/include/efi_loader.h index 5298ea7997f7..38330f2f5463 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -24,6 +24,10 @@ #define U_BOOT_GUID \ EFI_GUID(0xe61d73b9, 0xa384, 0x4acc, \ 0xae, 0xab, 0x82, 0xe8, 0x28, 0xf3, 0x62, 0x8b) +/* GUID used as host device on sandbox */ +#define U_BOOT_HOST_DEV_GUID \ + EFI_GUID(0xbbe4e671, 0x5773, 0x4ea1, \ + 0x9a, 0xab, 0x3a, 0x7d, 0xbf, 0x40, 0xc4, 0x82)
/* Root node */ extern efi_handle_t efi_root; @@ -121,6 +125,10 @@ uint16_t *efi_dp_str(struct efi_device_path *dp);
/* GUID of the U-Boot root node */ extern const efi_guid_t efi_u_boot_guid; +#ifdef CONFIG_SANDBOX +/* GUID of U-Boot host device on sandbox */ +extern const efi_guid_t efi_guid_host_dev; +#endif /* GUID of the EFI_BLOCK_IO_PROTOCOL */ extern const efi_guid_t efi_block_io_guid; extern const efi_guid_t efi_global_variable_guid; diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index eeeb80683607..611bab514286 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -12,8 +12,13 @@ #include <mmc.h> #include <efi_loader.h> #include <part.h> +#include <sandboxblockdev.h> #include <asm-generic/unaligned.h>
+#ifdef CONFIG_SANDBOX +const efi_guid_t efi_guid_host_dev = U_BOOT_HOST_DEV_GUID; +#endif + /* template END node: */ static const struct efi_device_path END = { .type = DEVICE_PATH_TYPE_END, @@ -445,6 +450,16 @@ static unsigned dp_size(struct udevice *dev) case UCLASS_MMC: return dp_size(dev->parent) + sizeof(struct efi_device_path_sd_mmc_path); +#endif +#ifdef CONFIG_SANDBOX + case UCLASS_ROOT: + /* + * Sandbox's host device will be represented + * as vendor device with extra one byte for + * device number + */ + return dp_size(dev->parent) + + sizeof(struct efi_device_path_vendor) + 1; #endif default: return dp_size(dev->parent); @@ -505,6 +520,24 @@ static void *dp_fill(void *buf, struct udevice *dev) #ifdef CONFIG_BLK case UCLASS_BLK: switch (dev->parent->uclass->uc_drv->id) { +#ifdef CONFIG_SANDBOX + case UCLASS_ROOT: { + /* stop traversing parents at this point: */ + struct efi_device_path_vendor *dp = buf; + struct blk_desc *desc = dev_get_uclass_platdata(dev); + + dp_fill(buf, dev->parent); + dp = buf; + ++dp; + dp->dp.type = DEVICE_PATH_TYPE_HARDWARE_DEVICE; + dp->dp.sub_type = DEVICE_PATH_SUB_TYPE_VENDOR; + dp->dp.length = sizeof(*dp) + 1; + memcpy(&dp->guid, &efi_guid_host_dev, + sizeof(efi_guid_t)); + dp->vendor_data[0] = desc->devnum; + return &dp->vendor_data[1]; + } +#endif #ifdef CONFIG_IDE case UCLASS_IDE: { struct efi_device_path_atapi *dp =
I applied you patch to efi/efi-2019-10 and executed 'bootefi selftest'
Without host:
Installed device path protocols: /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)
/VenHw(dbca4c98-6cb0-694d-0872-819c650cb7b8)/HD(1,MBR,0xd1535d21,0x1,0x7f)
/VenHw(dbca4c98-6cb0-694d-0872-819c650cbbb1)
/VenHw(dbca4c98-6cb0-694d-0872-819c650cbbb1)/VenHw(dbca4c98-6cb0-694d-0872-819c650cbba2)
/VenHw(dbca4c98-6cb0-694d-0872-819c650cbbb1)/VenHw(dbca4c98-6cb0-694d-0872-819c650cbba2)/VenHw(dbca4c98-6cb0-694d-0872-819c650cbbc3)
With host file bound as device:
/VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/VenHw(bbe4e671-5773-4ea1-9aab-3a7dbf40c482,02)
/VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/VenHw(bbe4e671-5773-4ea1-9aab-3a7dbf40c482,02)/HD(1,MBR,0x9b2103f1,0x800,0x3fffe)
=> efidebug devices Scanning disk host2... Found 2 disks Device Device Path ================ ==================== 0000000015e008b0 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b) 0000000015e00ec0 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/VenHw(bbe4e671-5773-4ea1-9aab-3a7dbf40c482,02) 0000000015e01050 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/VenHw(bbe4e671-5773-4ea1-9aab-3a7dbf40c482,02)/HD(1,MBR,0x9b2103f1,0x800,0x3fffe)
This looks ok. Thanks for your contribution.
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
- EFI_GUID(0xbbe4e671, 0x5773, 0x4ea1, \
case UCLASS_ROOT:
* device number
case UCLASS_ROOT: {
dp = buf;
++dp;
It would be better to give a user-friendly text to a host device on sandbox instead of just dumping its guid.
=> host bind 0 /opt/disk/uboot_sandbox_fat.img => efi devices Device Device Path ================ ==================== 0000000015c1f3a0 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b) 0000000015c20f00 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Hostdev(0)
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- lib/efi_loader/efi_device_path_to_text.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/lib/efi_loader/efi_device_path_to_text.c b/lib/efi_loader/efi_device_path_to_text.c index 96fd08971b73..40a06b70e08a 100644 --- a/lib/efi_loader/efi_device_path_to_text.c +++ b/lib/efi_loader/efi_device_path_to_text.c @@ -62,6 +62,11 @@ static char *dp_hardware(char *s, struct efi_device_path *dp) case DEVICE_PATH_SUB_TYPE_VENDOR: { struct efi_device_path_vendor *vdp = (struct efi_device_path_vendor *)dp; +#ifdef CONFIG_SANDBOX + if (!guidcmp(&vdp->guid, &efi_guid_host_dev)) + s += sprintf(s, "Hostdev(%d)", vdp->vendor_data[0]); + else +#endif s += sprintf(s, "VenHw(%pUl)", &vdp->guid); break; }
This does not conform to the UEFI spec.
The purpose of the sandbox is testing. What would make sense to me is checking in a Python test that The VenHw() output contains the GUID and the drive number.
Best regards
Heinrich
else
Okay, so I'd like to change the format again. Instead of 'Vendor' subtype, use 'Controller' subtype. This way, the example above can be seen as:
0000000015c1f3a0 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b) 0000000015c20f00 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Ctrl(0)
Looks nice, doesn't it?
-Takahiro Akashi
Best regards
Heinrich
else
A controller is a handle that bears the EFI_DRIVER_BINDING_PROTOCOL.
Best regards
Heinrich
-Takahiro Akashi
Best regards
Heinrich
else
To my best knowledge, I don't find such a definition in the specification.
For *that* reason, we don't have to stick to strict *standardized* form for Sandbox host device. It would never cause any problems as such a text would never come up on any other platforms.
-Takahiro Akashi
Best regards
Heinrich
else
Heinrich,
Do you have any comments?
Any comments?
-Takahiro Akashi
Best regards
Heinrich
else
On 10/3/19 8:56 AM, AKASHI Takahiro wrote:
Heinrich,
Any comments?
As the Sandbox host device is vendor specific VenHw() is a good fit. I see no benefit in changing the current solution and would prefer not to make this code more complicated.
Best regards
Heinrich
-Takahiro Akashi
Best regards
Heinrich
else
Heinrich,
On 9/12/19 6:52 AM, AKASHI Takahiro wrote: >It would be better to give a user-friendly text to a host device >on sandbox instead of just dumping its guid. > >=> host bind 0 /opt/disk/uboot_sandbox_fat.img >=> efi devices >Device Device Path >================ ==================== >0000000015c1f3a0 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b) >0000000015c20f00 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Hostdev(0) > >Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org >--- > lib/efi_loader/efi_device_path_to_text.c | 5 +++++ > 1 file changed, 5 insertions(+) > >diff --git a/lib/efi_loader/efi_device_path_to_text.c b/lib/efi_loader/efi_device_path_to_text.c >index 96fd08971b73..40a06b70e08a 100644 >--- a/lib/efi_loader/efi_device_path_to_text.c >+++ b/lib/efi_loader/efi_device_path_to_text.c >@@ -62,6 +62,11 @@ static char *dp_hardware(char *s, struct efi_device_path *dp) > case DEVICE_PATH_SUB_TYPE_VENDOR: { > struct efi_device_path_vendor *vdp = > (struct efi_device_path_vendor *)dp; >+#ifdef CONFIG_SANDBOX >+ if (!guidcmp(&vdp->guid, &efi_guid_host_dev)) >+ s += sprintf(s, "Hostdev(%d)", vdp->vendor_data[0]);
Any comments?
Benefit? This notation is intuitive and very easily-understandable instead of super-unfriendly GUID. By knowing a number as a host device, we can easily identify what the device is by "host info." The "reason d'etre" of UEFI's "display format" is for human beings, not machine.
Moreover, the compatibility/portability is not a problem here as host devices appear only on sandbox which is mainly used for test purposes.
-Takahiro Akashi
Best regards
Heinrich
-Takahiro Akashi
Best regards
Heinrich
>+ else >+#endif > s += sprintf(s, "VenHw(%pUl)", &vdp->guid); > break; > } >
AKASHI Takahiro
