[U-Boot-Users] [PATCH] Fix PCI, USB, bootargs for MPC8349E-mITX
PREREQUISITE PATCHES:
* This patch can only be applied after the following patches have been applied:
1) DNX#2006092142000015 "Add support for the MPC8349E-mITX 1/2" 2) DNX#2006092142000024 "Add support for the MPC8349E-mITX 2/2"
CHANGELOG:
* For the 8349E-mITX, fix some size values in pci_init_board(), enable the clock for the 2nd USB board (Linux kernel will hang otherwise), and fix the CONFIG_BOOTARGS macro.
Signed-off-by: Timur Tabi timur@freescale.com --- board/mpc8349itx/pci.c | 14 +++++++------- include/configs/MPC8349ITX.h | 19 +++++++++++-------- 2 files changed, 18 insertions(+), 15 deletions(-)
diff --git a/board/mpc8349itx/pci.c b/board/mpc8349itx/pci.c index 22ab736..c90ccc0 100644 --- a/board/mpc8349itx/pci.c +++ b/board/mpc8349itx/pci.c @@ -153,7 +153,7 @@ #endif pci_law[0].ar = LAWAR_EN | LAWAR_SIZE_1G;
pci_law[1].bar = CFG_PCI1_IO_PHYS & LAWBAR_BAR; - pci_law[1].ar = LAWAR_EN | LAWAR_SIZE_4M; + pci_law[1].ar = LAWAR_EN | LAWAR_SIZE_32M;
/* * Configure PCI Outbound Translation Windows @@ -162,17 +162,17 @@ #endif /* PCI1 mem space - prefetch */ pci_pot[0].potar = (CFG_PCI1_MEM_BASE >> 12) & POTAR_TA_MASK; pci_pot[0].pobar = (CFG_PCI1_MEM_PHYS >> 12) & POBAR_BA_MASK; - pci_pot[0].pocmr = POCMR_EN | POCMR_PREFETCH_EN | (POCMR_CM_256M & POCMR_CM_MASK); + pci_pot[0].pocmr = POCMR_EN | POCMR_PREFETCH_EN | POCMR_CM_256M;
/* PCI1 IO space */ pci_pot[1].potar = (CFG_PCI1_IO_BASE >> 12) & POTAR_TA_MASK; pci_pot[1].pobar = (CFG_PCI1_IO_PHYS >> 12) & POBAR_BA_MASK; - pci_pot[1].pocmr = POCMR_EN | POCMR_IO | (POCMR_CM_1M & POCMR_CM_MASK); + pci_pot[1].pocmr = POCMR_EN | POCMR_IO | POCMR_CM_16M;
/* PCI1 mmio - non-prefetch mem space */ pci_pot[2].potar = (CFG_PCI1_MMIO_BASE >> 12) & POTAR_TA_MASK; pci_pot[2].pobar = (CFG_PCI1_MMIO_PHYS >> 12) & POBAR_BA_MASK; - pci_pot[2].pocmr = POCMR_EN | (POCMR_CM_256M & POCMR_CM_MASK); + pci_pot[2].pocmr = POCMR_EN | POCMR_CM_256M;
/* * Configure PCI Inbound Translation Windows @@ -259,17 +259,17 @@ #ifdef CONFIG_MPC83XX_PCI2 /* PCI2 mem space - prefetch */ pci_pot[3].potar = (CFG_PCI2_MEM_BASE >> 12) & POTAR_TA_MASK; pci_pot[3].pobar = (CFG_PCI2_MEM_PHYS >> 12) & POBAR_BA_MASK; - pci_pot[3].pocmr = POCMR_EN | POCMR_PCI2 | POCMR_PREFETCH_EN | (POCMR_CM_256M & POCMR_CM_MASK); + pci_pot[3].pocmr = POCMR_EN | POCMR_PCI2 | POCMR_PREFETCH_EN | POCMR_CM_256M;
/* PCI2 IO space */ pci_pot[4].potar = (CFG_PCI2_IO_BASE >> 12) & POTAR_TA_MASK; pci_pot[4].pobar = (CFG_PCI2_IO_PHYS >> 12) & POBAR_BA_MASK; - pci_pot[4].pocmr = POCMR_EN | POCMR_PCI2 | POCMR_IO | (POCMR_CM_1M & POCMR_CM_MASK); + pci_pot[4].pocmr = POCMR_EN | POCMR_PCI2 | POCMR_IO | POCMR_CM_16M;
/* PCI2 mmio - non-prefetch mem space */ pci_pot[5].potar = (CFG_PCI2_MMIO_BASE >> 12) & POTAR_TA_MASK; pci_pot[5].pobar = (CFG_PCI2_MMIO_PHYS >> 12) & POBAR_BA_MASK; - pci_pot[5].pocmr = POCMR_EN | POCMR_PCI2 | (POCMR_CM_256M & POCMR_CM_MASK); + pci_pot[5].pocmr = POCMR_EN | POCMR_PCI2 | POCMR_CM_256M;
/* * Configure PCI Inbound Translation Windows diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index aed350f..20f3c6d 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -604,7 +604,7 @@ #define CFG_ACR_RPTCNT 3 /* Arbiter rep
/* System IO Config */ #define CFG_SICRH SICRH_TSOBI1 /* Needed for gigabit to work on TSEC 1 */ -#define CFG_SICRL SICRL_LDP_A +#define CFG_SICRL (SICRL_LDP_A | SICRL_USB1)
#define CFG_HID0_INIT 0x000000000
@@ -701,7 +701,7 @@ #define CONFIG_IPADDR 10.82.19.159 #define CONFIG_SERVERIP 10.82.48.106 #define CONFIG_GATEWAYIP 10.82.19.254 #define CONFIG_NETMASK 255.255.252.0 - +#define CONFIG_NETDEV eth0
#define CONFIG_HOSTNAME mpc8349emitx #define CONFIG_ROOTPATH /nfsroot0/u/timur/itx-ltib/rootfs @@ -722,16 +722,19 @@ #else #define CONFIG_BOOTDELAY -1 /* -1 disables auto-boot */ #endif
-#define CONFIG_BOOTARGS \ - "root=/dev/nfs rw nfsroot=$serverip:$rootpath " \ - "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ - "console=ttyS0,$baudrate $othbootargs" - #define XMK_STR(x) #x #define MK_STR(x) XMK_STR(x)
+#define CONFIG_BOOTARGS \ + "root=/dev/nfs rw" \ + " nfsroot=" MK_STR(CONFIG_SERVERIP) ":" MK_STR(CONFIG_ROOTPATH) \ + " ip=" MK_STR(CONFIG_IPADDR) ":" MK_STR(CONFIG_SERVERIP) ":" \ + MK_STR(CONFIG_GATEWAYIP) ":" MK_STR(CONFIG_NETMASK) ":" \ + MK_STR(CONFIG_HOSTNAME) ":" MK_STR(CONFIG_NETDEV) ":off" \ + " console=ttyS0," MK_STR(CONFIG_BAUDRATE) + #define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0" \ + "netdev=" MK_STR(CONFIG_NETDEV) "\0" \ "tftpflash=tftpboot $loadaddr " MK_STR(CONFIG_UBOOTPATH) "; " \ "erase " MK_STR(CONFIG_UBOOTSTART) " " MK_STR(CONFIG_UBOOTEND) "; " \ "cp.b $loadaddr " MK_STR(CONFIG_UBOOTSTART) " $filesize; " \
timur@freescale.com
