[U-Boot] [PATCH 01/31] 83xx/pcie: fix build error for 83xx pcie
fix the following build error: pcie.c: In function 'mpc83xx_pcie_init_bus': pcie.c:315:34: error: 'PCI_LTSSM' undeclared (first use in this function) pcie.c:315:34: note: each undeclared identifier is reported only once for each function it appears in pcie.c:316:15: error: 'PCI_LTSSM_L0' undeclared (first use in this function) make[1]: *** [pcie.o] Error 1 make: *** [arch/powerpc/cpu/mpc83xx/libmpc83xx.o] Error 2
Signed-off-by: Roy Zang tie-fei.zang@freescale.com --- arch/powerpc/cpu/mpc83xx/pcie.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/powerpc/cpu/mpc83xx/pcie.c b/arch/powerpc/cpu/mpc83xx/pcie.c index 609b133..61d5fa5 100644 --- a/arch/powerpc/cpu/mpc83xx/pcie.c +++ b/arch/powerpc/cpu/mpc83xx/pcie.c @@ -312,6 +312,8 @@ static void mpc83xx_pcie_init_bus(int bus, struct pci_region *reg)
printf("PCIE%d: ", bus);
+#define PCI_LTSSM 0x404 /* PCIe Link Training, Status State Machine */ +#define PCI_LTSSM_L0 0x16 /* L0 state */ reg16 = in_le16(hose_cfg_base + PCI_LTSSM); if (reg16 >= PCI_LTSSM_L0) printf("link\n");
Enable L2 cache parity/ECC error checking.
Signed-off-by: James Yang James.Yang@freescale.com --- arch/powerpc/cpu/mpc85xx/cpu_init.c | 2 +- arch/powerpc/cpu/mpc85xx/start.S | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index b90c8a8..7b1ab26 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -337,7 +337,7 @@ int enable_cluster_l2(void) while ((in_be32(&l2cache->l2csr0) & (L2CSR0_L2FI|L2CSR0_L2LFC)) != 0) ; - out_be32(&l2cache->l2csr0, L2CSR0_L2E); + out_be32(&l2cache->l2csr0, L2CSR0_L2E|L2CSR0_L2PE); } i++; } while (!(cluster & TP_CLUSTER_EOC)); diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index 5542d0a..87168e2 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -734,7 +734,7 @@ enable_l2_cluster_l2: isync and. r1, r0, r4 bne 1b - lis r4, L2CSR0_L2E@h + lis r4, (L2CSR0_L2E|L2CSR0_L2PE)@h sync stw r4, 0(r3) /* enable L2 */ delete_ccsr_l2_tlb:
TN80xx has same PHY ID as TN2020, but it needs different setting to register 30.93 which used to select line, so we read register 30.32 which has bit 15:12 to indicate PHY hardware version, for TN20xx we will get 3 or 2, for TN80xx we will get 5 or 4.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com --- drivers/net/phy/teranetics.c | 15 +++++++++++++-- 1 file changed, 13 insertions(+), 2 deletions(-)
diff --git a/drivers/net/phy/teranetics.c b/drivers/net/phy/teranetics.c index 78447b7..c0f13b8 100644 --- a/drivers/net/phy/teranetics.c +++ b/drivers/net/phy/teranetics.c @@ -34,9 +34,20 @@ int tn2020_config(struct phy_device *phydev) unsigned short restart_an = (MDIO_AN_CTRL1_RESTART | MDIO_AN_CTRL1_ENABLE | MDIO_AN_CTRL1_XNP); + u8 phy_hwversion;
- phy_write(phydev, 30, 93, 2); - phy_write(phydev, MDIO_MMD_AN, MDIO_CTRL1, restart_an); + /* + * bit 15:12 of register 30.32 indicates PHY hardware + * version. It can be used to distinguish TN80xx from + * TN2020. TN2020 needs write 0x2 to 30.93, but TN80xx + * needs 0x1. + */ + phy_hwversion = (phy_read(phydev, 30, 32) >> 12) & 0xf; + if (phy_hwversion <= 3) { + phy_write(phydev, 30, 93, 2); + phy_write(phydev, MDIO_MMD_AN, MDIO_CTRL1, restart_an); + } else + phy_write(phydev, 30, 93, 1); }
Dear York Sun,
In message 1363973369-26110-3-git-send-email-yorksun@freescale.com you wrote:
CHECK: braces {} should be used on all arms of this statement #136: FILE: drivers/net/phy/teranetics.c:46: + if (phy_hwversion <= 3) { [...] + } else [...]
"cpu <num> status" should check if core is disabled before printing the spin table location.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc85xx/mp.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/powerpc/cpu/mpc85xx/mp.c b/arch/powerpc/cpu/mpc85xx/mp.c index 43d4836..861c8e0 100644 --- a/arch/powerpc/cpu/mpc85xx/mp.c +++ b/arch/powerpc/cpu/mpc85xx/mp.c @@ -80,6 +80,8 @@ int cpu_status(int nr) if (nr == id) { table = (u32 *)&__spin_table; printf("table base @ 0x%p\n", table); + } else if (is_core_disabled(nr)) { + puts("Disabled\n"); } else { table = (u32 *)&__spin_table + nr * NUM_BOOT_ENTRY; printf("Running on cpu %d\n", id);
Allow VDD voltage overriding with a command. This is an add-on feasture of VID. To override VDD, use command vdd_override with the value of voltage in mV, for example
vdd_override <voltage in mV, eg. 1050>
The above example will set the VDD to 1.050 volt. Any wrong value out of range of 0.8188 to 1.2125 volt or invalid string is ignored.
In addition to the command, if overriding VDD is needed earlier in booting process, save an variable and reboot:
setenv t4240qds_vdd_mv <voltage in mV> saveenv
Signed-off-by: York Sun yorksun@freescale.com --- board/freescale/t4qds/t4qds.c | 39 +++++++++++++++++++++++++++++++++++++-- doc/README.t4240qds | 24 ++++++++++++++++++++++++ 2 files changed, 61 insertions(+), 2 deletions(-)
diff --git a/board/freescale/t4qds/t4qds.c b/board/freescale/t4qds/t4qds.c index 2f4575b..3eec601 100644 --- a/board/freescale/t4qds/t4qds.c +++ b/board/freescale/t4qds/t4qds.c @@ -234,7 +234,7 @@ static inline int set_voltage(u8 vid) }
-static int adjust_vdd(void) +static int adjust_vdd(ulong vdd_override) { int re_enable = disable_interrupts(); ccsr_gur_t __iomem *gur = @@ -243,6 +243,8 @@ static int adjust_vdd(void) u8 vid, vid_current; int vdd_target, vdd_current, vdd_last; int ret; + unsigned long vdd_string_override; + char *vdd_string; static const uint16_t vdd[32] = { 0, /* unused */ 9875, /* 0.9875V */ @@ -292,6 +294,19 @@ static int adjust_vdd(void) FSL_CORENET_DCFG_FUSESR_ALTVID_MASK; } vdd_target = vdd[vid]; + + /* check override variable for overriding VDD */ + vdd_string = getenv("t4240qds_vdd_mv"); + if (vdd_override == 0 && vdd_string && + !strict_strtoul(vdd_string, 10, &vdd_string_override)) + vdd_override = vdd_string_override; + if (vdd_override >= 819 && vdd_override <= 1212) { + vdd_target = vdd_override * 10; /* convert to 1/10 mV */ + debug("VDD override is %lu\n", vdd_override); + } else if (vdd_override != 0) { + printf("Invalid value.\n"); + } + if (vdd_target == 0) { debug("VID: VID not used\n"); ret = 0; @@ -512,7 +527,7 @@ int board_early_init_r(void) * Adjust core voltage according to voltage ID * This function changes I2C mux to channel 2. */ - if (adjust_vdd()) + if (adjust_vdd(0)) printf("Warning: Adjusting core voltage failed.\n");
/* Configure board SERDES ports crossbar */ @@ -802,3 +817,23 @@ void qixis_dump_switch(void) i + 1, byte_to_binary_mask(sw[i], mask[i], buf), sw[i]); } } + +static int do_vdd_adjust(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + ulong override; + + if (argc < 2) + return CMD_RET_USAGE; + if (!strict_strtoul(argv[1], 10, &override)) + adjust_vdd(override); /* the value is checked by callee */ + else + return CMD_RET_USAGE; + + return 0; +} + +U_BOOT_CMD( + vdd_override, 2, 0, do_vdd_adjust, + "Override VDD", + "- override with the voltage specified in mV, eg. 1050" +); diff --git a/doc/README.t4240qds b/doc/README.t4240qds index 677d120..19e8a8a 100644 --- a/doc/README.t4240qds +++ b/doc/README.t4240qds @@ -96,3 +96,27 @@ The addresses in brackets are physical addresses. 0x0_ffff_f000 (0x0_7fff_fff0) - 0x0_ffff_ffff 4KB Boot page translation for secondary cores
The physical address of the last (boot page translation) varies with the actual DDR size. + +Voltage ID and VDD override +-------------------- +T4240 has a VID feature. U-boot reads the VID efuses and adjust the voltage +accordingly. The voltage can also be override by command vdd_override. The +syntax is + +vdd_override <voltage in mV>, eg. 1050 is for 1.050v. + +Upon success, the actual voltage will be read back. The value is checked +for safety and any invalid value will not adjust the voltage. + +Another way to override VDD is to use environmental variable, in case of using +command is too late for some debugging. The syntax is + +setenv t4240qds_vdd_mv <voltage in mV> +saveenv +reset + +The override voltage takes effect when booting. + +Note: voltage adjustment needs to be done step by step. Changing voltage too +rapidly may cause current surge. The voltage stepping is done by software. +Users can set the final voltage directly.
Dear York Sun,
In message 1363973369-26110-5-git-send-email-yorksun@freescale.com you wrote:
CHECK: Alignment should match open parenthesis #156: FILE: board/freescale/t4qds/t4qds.c:301: + if (vdd_override == 0 && vdd_string && + !strict_strtoul(vdd_string, 10, &vdd_string_override))
WARNING: line over 80 characters #182: FILE: board/freescale/t4qds/t4qds.c:821: +static int do_vdd_adjust(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
Added a default RCW(1_28_6_12) and PBI configure file for T4240, so it can use PBL tool to produce the ramboot image.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com --- board/freescale/t4qds/t4_pbi.cfg | 36 ++++++++++++++++++++++++++++++++++++ board/freescale/t4qds/t4_rcw.cfg | 7 +++++++ include/configs/t4qds.h | 2 ++ 3 files changed, 45 insertions(+) create mode 100644 board/freescale/t4qds/t4_pbi.cfg create mode 100644 board/freescale/t4qds/t4_rcw.cfg
diff --git a/board/freescale/t4qds/t4_pbi.cfg b/board/freescale/t4qds/t4_pbi.cfg new file mode 100644 index 0000000..c598fb5 --- /dev/null +++ b/board/freescale/t4qds/t4_pbi.cfg @@ -0,0 +1,36 @@ +#PBI commands +#Initialize CPC1 +09010000 00200400 +09138000 00000000 +091380c0 00000100 +#512KB SRAM +09010100 00000000 +09010104 fff80009 +09010f00 08000000 +#enable CPC1 +09010000 80000000 +#Configure LAW for CPC1 +09000d00 00000000 +09000d04 fff80000 +09000d08 81000012 +#workaround for IFC bus speed +091241c0 f03f3f3f +091241c4 ff003f3f +09124010 00000101 +09124130 0000000c +#workaround for SERDES A-006031 +090ea000 064740e6 +090ea020 064740e6 +090eb000 064740e6 +090eb020 064740e6 +090ec000 064740e6 +090ec020 064740e6 +090ed000 064740e6 +090ed020 064740e6 +#Configure alternate space +09000010 00000000 +09000014 ff000000 +09000018 81000000 +#Flush PBL data +09138000 00000000 +091380c0 00000000 diff --git a/board/freescale/t4qds/t4_rcw.cfg b/board/freescale/t4qds/t4_rcw.cfg new file mode 100644 index 0000000..6ac95ff --- /dev/null +++ b/board/freescale/t4qds/t4_rcw.cfg @@ -0,0 +1,7 @@ +#PBL preamble and RCW header +aa55aa55 010e0100 +#serdes protocol 1_28_6_12 +14180019 0c101916 00000000 00000000 +04383060 30548c00 6c020000 19000000 +00000000 ee0000ee 00000000 000187fc +00000000 00000000 00000000 00000018 diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index b5462b7..943bf67 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -29,6 +29,8 @@ #ifdef CONFIG_RAMBOOT_PBL #define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc +#define CONFIG_PBLPBI_CONFIG $(SRCTREE)/board/freescale/t4qds/t4_pbi.cfg +#define CONFIG_PBLRCW_CONFIG $(SRCTREE)/board/freescale/t4qds/t4_rcw.cfg #endif
#define CONFIG_CMD_REGINFO
Add e6500 L2 replacement policy selection. This is compile-time config.
Signed-off-by: James Yang James.Yang@freescale.com --- arch/powerpc/cpu/mpc85xx/cpu_init.c | 2 +- arch/powerpc/cpu/mpc85xx/start.S | 1 + arch/powerpc/include/asm/processor.h | 9 +++++++++ 3 files changed, 11 insertions(+), 1 deletion(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 7b1ab26..4d307c8 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -337,7 +337,7 @@ int enable_cluster_l2(void) while ((in_be32(&l2cache->l2csr0) & (L2CSR0_L2FI|L2CSR0_L2LFC)) != 0) ; - out_be32(&l2cache->l2csr0, L2CSR0_L2E|L2CSR0_L2PE); + out_be32(&l2cache->l2csr0, L2CSR0_L2E|L2CSR0_L2PE|L2CSR0_L2REP_MODE); } i++; } while (!(cluster & TP_CLUSTER_EOC)); diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index 87168e2..e413e4a 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -735,6 +735,7 @@ enable_l2_cluster_l2: and. r1, r0, r4 bne 1b lis r4, (L2CSR0_L2E|L2CSR0_L2PE)@h + ori r4, r4, (L2CSR0_L2REP_MODE)@l sync stw r4, 0(r3) /* enable L2 */ delete_ccsr_l2_tlb: diff --git a/arch/powerpc/include/asm/processor.h b/arch/powerpc/include/asm/processor.h index 5c0c438..1760aa1 100644 --- a/arch/powerpc/include/asm/processor.h +++ b/arch/powerpc/include/asm/processor.h @@ -507,6 +507,15 @@ #define L2CSR0_L2IO 0x00100000 /* L2 Cache Instruction Only */ #define L2CSR0_L2DO 0x00010000 /* L2 Cache Data Only */ #define L2CSR0_L2REP 0x00003000 /* L2 Line Replacement Algo */ + +/* e6500 */ +#define L2CSR0_L2REP_SPLRUAGE 0x00000000 /* L2REP Streaming PLRU with Aging */ +#define L2CSR0_L2REP_FIFO 0x00001000 /* L2REP FIFO */ +#define L2CSR0_L2REP_SPLRU 0x00002000 /* L2REP Streaming PLRU */ +#define L2CSR0_L2REP_PLRU 0x00003000 /* L2REP PLRU */ + +#define L2CSR0_L2REP_MODE L2CSR0_L2REP_SPLRUAGE + #define L2CSR0_L2FL 0x00000800 /* L2 Cache Flush */ #define L2CSR0_L2LFC 0x00000400 /* L2 Cache Lock Flash Clear */ #define L2CSR0_L2LOA 0x00000080 /* L2 Cache Lock Overflow Allocate */
Dear York Sun,
In message 1363973369-26110-7-git-send-email-yorksun@freescale.com you wrote:
WARNING: line over 80 characters #125: FILE: arch/powerpc/cpu/mpc85xx/cpu_init.c:340: + out_be32(&l2cache->l2csr0, L2CSR0_L2E|L2CSR0_L2PE|L2CSR0_L2REP_MODE);
WARNING: line over 80 characters #151: FILE: arch/powerpc/include/asm/processor.h:512: +#define L2CSR0_L2REP_SPLRUAGE 0x00000000 /* L2REP Streaming PLRU with Aging */
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com --- boards.cfg | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/boards.cfg b/boards.cfg index 1d44446..efb23e9 100644 --- a/boards.cfg +++ b/boards.cfg @@ -874,6 +874,9 @@ P5020DS_SECURE_BOOT powerpc mpc85xx corenet_ds freesca P5020DS_SPIFLASH powerpc mpc85xx corenet_ds freescale - P5020DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 P5020DS_SRIO_PCIE_BOOT powerpc mpc85xx corenet_ds freescale - P5020DS:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 P5040DS powerpc mpc85xx corenet_ds freescale +P5040DS_NAND powerpc mpc85xx corenet_ds freescale - P5040DS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 +P5040DS_SDCARD powerpc mpc85xx corenet_ds freescale - P5040DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 +P5040DS_SPIFLASH powerpc mpc85xx corenet_ds freescale - P5040DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 BSC9131RDB_SPIFLASH powerpc mpc85xx bsc9131rdb freescale - BSC9131RDB:BSC9131RDB,SPIFLASH BSC9132QDS_NOR_DDRCLK100 powerpc mpc85xx bsc9132qds freescale - BSC9132QDS:BSC9132QDS,SYS_CLK_100_DDR_100 BSC9132QDS_NOR_DDRCLK133 powerpc mpc85xx bsc9132qds freescale - BSC9132QDS:BSC9132QDS,SYS_CLK_100_DDR_133
T4160 is a subset of T4240. Merge them in config_mpc85xx.h to simplify the defines. Also move CONFIG_E6500 out of t4qds.h into config_mpc85xx.h.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/include/asm/config_mpc85xx.h | 44 +++++++---------------------- include/configs/t4qds.h | 1 - 2 files changed, 10 insertions(+), 35 deletions(-)
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 0eb828f..37eb118 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -510,57 +510,33 @@ #define CONFIG_SYS_FSL_ESDHC_P1010_BROKEN_SDCLK #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2"
-#elif defined(CONFIG_PPC_T4240) +#elif defined(CONFIG_PPC_T4240) || defined(CONFIG_PPC_T4160) +#define CONFIG_E6500 #define CONFIG_SYS_PPC64 /* 64-bit core */ #define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_SYS_FSL_QORIQ_CHASSIS2 /* Freescale Chassis generation 2 */ #define CONFIG_SYS_FSL_QMAN_V3 /* QMAN version 3 */ +#ifdef CONFIG_PPC_T4240 #define CONFIG_MAX_CPUS 12 -#define CONFIG_SYS_FSL_NUM_CC_PLLS 5 -#define CONFIG_SYS_FSL_NUM_LAWS 32 -#define CONFIG_SYS_FSL_SRDS_3 -#define CONFIG_SYS_FSL_SRDS_4 -#define CONFIG_SYS_FSL_SEC_COMPAT 4 -#define CONFIG_SYS_NUM_FMAN 2 #define CONFIG_SYS_NUM_FM1_DTSEC 8 #define CONFIG_SYS_NUM_FM1_10GEC 2 #define CONFIG_SYS_NUM_FM2_DTSEC 8 #define CONFIG_SYS_NUM_FM2_10GEC 2 #define CONFIG_NUM_DDR_CONTROLLERS 3 -#define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_7 -#define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 -#define CONFIG_SYS_FMAN_V3 -#define CONFIG_SYS_FM_MURAM_SIZE 0x60000 -#define CONFIG_SYS_FSL_TBCLK_DIV 16 -#define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v3.0" -#define CONFIG_SYS_FSL_SRIO_MAX_PORTS 2 -#define CONFIG_SYS_FSL_SRIO_OB_WIN_NUM 9 -#define CONFIG_SYS_FSL_SRIO_IB_WIN_NUM 5 -#define CONFIG_SYS_FSL_USB_DUAL_PHY_ENABLE -#define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY -#define CONFIG_SYS_FSL_ERRATUM_A004468 -#define CONFIG_SYS_FSL_ERRATUM_A_004934 -#define CONFIG_SYS_FSL_ERRATUM_A005871 -#define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 -#define CONFIG_SYS_FSL_PCI_VER_3_X - -#elif defined(CONFIG_PPC_T4160) -#define CONFIG_SYS_PPC64 /* 64-bit core */ -#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ -#define CONFIG_SYS_FSL_QORIQ_CHASSIS2 /* Freescale Chassis generation 2 */ -#define CONFIG_SYS_FSL_QMAN_V3 /* QMAN version 3 */ +#else #define CONFIG_MAX_CPUS 8 +#define CONFIG_SYS_NUM_FM1_DTSEC 7 +#define CONFIG_SYS_NUM_FM1_10GEC 1 +#define CONFIG_SYS_NUM_FM2_DTSEC 7 +#define CONFIG_SYS_NUM_FM2_10GEC 1 +#define CONFIG_NUM_DDR_CONTROLLERS 2 +#endif #define CONFIG_SYS_FSL_NUM_CC_PLLS 5 #define CONFIG_SYS_FSL_NUM_LAWS 32 #define CONFIG_SYS_FSL_SRDS_3 #define CONFIG_SYS_FSL_SRDS_4 #define CONFIG_SYS_FSL_SEC_COMPAT 4 #define CONFIG_SYS_NUM_FMAN 2 -#define CONFIG_SYS_NUM_FM1_DTSEC 7 -#define CONFIG_SYS_NUM_FM1_10GEC 1 -#define CONFIG_SYS_NUM_FM2_DTSEC 7 -#define CONFIG_SYS_NUM_FM2_10GEC 1 -#define CONFIG_NUM_DDR_CONTROLLERS 2 #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_7 #define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 #define CONFIG_SYS_FMAN_V3 diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index 943bf67..fa1dcc3 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -37,7 +37,6 @@
/* High Level Configuration Options */ #define CONFIG_BOOKE -#define CONFIG_E6500 #define CONFIG_E500 /* BOOKE e500 family */ #define CONFIG_E500MC /* BOOKE e500mc family */ #define CONFIG_SYS_BOOK3E_HV /* Category E.HV supported */
T1040 and variants have e5500 cores and are compliant to QorIQ Chassis Generation 2. The major difference between T1040 and its variants is the number of cores and the number of L2 switch ports.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc85xx/Makefile | 3 + .../cpu/mpc85xx/{b4860_ids.c => t1040_ids.c} | 14 +-- arch/powerpc/cpu/mpc85xx/t1040_serdes.c | 94 ++++++++++++++++++++ arch/powerpc/cpu/mpc8xxx/cpu.c | 6 ++ arch/powerpc/include/asm/config_mpc85xx.h | 26 ++++++ arch/powerpc/include/asm/fsl_serdes.h | 8 ++ arch/powerpc/include/asm/immap_85xx.h | 5 ++ arch/powerpc/include/asm/processor.h | 6 ++ 8 files changed, 149 insertions(+), 13 deletions(-) copy arch/powerpc/cpu/mpc85xx/{b4860_ids.c => t1040_ids.c} (90%) create mode 100644 arch/powerpc/cpu/mpc85xx/t1040_serdes.c
diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index 6e5aec2..2318064 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -88,6 +88,7 @@ COBJS-$(CONFIG_PPC_B4420) += ddr-gen3.o COBJS-$(CONFIG_PPC_B4860) += ddr-gen3.o COBJS-$(CONFIG_BSC9131) += ddr-gen3.o COBJS-$(CONFIG_BSC9132) += ddr-gen3.o +COBJS-$(CONFIG_PPC_T1040) += ddr-gen3.o
COBJS-$(CONFIG_CPM2) += ether_fcc.o COBJS-$(CONFIG_OF_LIBFDT) += fdt.o @@ -106,6 +107,7 @@ COBJS-$(CONFIG_PPC_T4240) += t4240_ids.o COBJS-$(CONFIG_PPC_T4160) += t4240_ids.o COBJS-$(CONFIG_PPC_B4420) += b4860_ids.o COBJS-$(CONFIG_PPC_B4860) += b4860_ids.o +COBJS-$(CONFIG_PPC_T1040) += t1040_ids.o
COBJS-$(CONFIG_QE) += qe_io.o COBJS-$(CONFIG_CPM2) += serial_scc.o @@ -143,6 +145,7 @@ COBJS-$(CONFIG_PPC_T4160) += t4240_serdes.o COBJS-$(CONFIG_PPC_B4420) += b4860_serdes.o COBJS-$(CONFIG_PPC_B4860) += b4860_serdes.o COBJS-$(CONFIG_BSC9132) += bsc9132_serdes.o +COBJS-$(CONFIG_PPC_T1040) += t1040_serdes.o
COBJS-y += cpu.o COBJS-y += cpu_init.o diff --git a/arch/powerpc/cpu/mpc85xx/b4860_ids.c b/arch/powerpc/cpu/mpc85xx/t1040_ids.c similarity index 90% copy from arch/powerpc/cpu/mpc85xx/b4860_ids.c copy to arch/powerpc/cpu/mpc85xx/t1040_ids.c index 0f4e82e..ed61599 100644 --- a/arch/powerpc/cpu/mpc85xx/b4860_ids.c +++ b/arch/powerpc/cpu/mpc85xx/t1040_ids.c @@ -55,13 +55,11 @@ struct qportal_info qp_info[CONFIG_SYS_QMAN_NUM_PORTALS] = { }; #endif
-#ifdef CONFIG_SYS_SRIO struct srio_liodn_id_table srio_liodn_tbl[] = { SET_SRIO_LIODN_1(1, 307), SET_SRIO_LIODN_1(2, 387), }; int srio_liodn_tbl_sz = ARRAY_SIZE(srio_liodn_tbl); -#endif
struct liodn_id_table liodn_tbl[] = { #ifdef CONFIG_SYS_DPAA_QBMAN @@ -73,17 +71,15 @@ struct liodn_id_table liodn_tbl[] = {
SET_USB_LIODN(1, "fsl-usb2-mph", 553),
- SET_PCI_LIODN(CONFIG_SYS_FSL_PCIE_COMPAT, 1, 148), + SET_PCI_LIODN("fsl,qoriq-pcie-v2.2", 1, 148),
SET_DMA_LIODN(1, 147), SET_DMA_LIODN(2, 227),
-#ifndef CONFIG_PPC_B4420 SET_GUTS_LIODN("fsl,rapidio-delta", 199, rio1liodnr, 0), SET_GUTS_LIODN(NULL, 200, rio2liodnr, 0), SET_GUTS_LIODN(NULL, 201, rio1maintliodnr, 0), SET_GUTS_LIODN(NULL, 202, rio2maintliodnr, 0), -#endif
/* SET_NEXUS_LIODN(557), -- not yet implemented */ }; @@ -97,10 +93,8 @@ struct liodn_id_table fman1_liodn_tbl[] = { SET_FMAN_RX_1G_LIODN(1, 3, 91), SET_FMAN_RX_1G_LIODN(1, 4, 92), SET_FMAN_RX_1G_LIODN(1, 5, 93), -#ifndef CONFIG_PPC_B4420 SET_FMAN_RX_10G_LIODN(1, 0, 94), SET_FMAN_RX_10G_LIODN(1, 1, 95), -#endif }; int fman1_liodn_tbl_sz = ARRAY_SIZE(fman1_liodn_tbl); #endif @@ -116,12 +110,6 @@ struct liodn_id_table sec_liodn_tbl[] = { SET_SEC_RTIC_LIODN_ENTRY(d, 551), SET_SEC_DECO_LIODN_ENTRY(0, 541, 610), SET_SEC_DECO_LIODN_ENTRY(1, 542, 611), - SET_SEC_DECO_LIODN_ENTRY(2, 543, 612), - SET_SEC_DECO_LIODN_ENTRY(3, 544, 613), - SET_SEC_DECO_LIODN_ENTRY(4, 545, 614), - SET_SEC_DECO_LIODN_ENTRY(5, 546, 615), - SET_SEC_DECO_LIODN_ENTRY(6, 547, 616), - SET_SEC_DECO_LIODN_ENTRY(7, 548, 617), }; int sec_liodn_tbl_sz = ARRAY_SIZE(sec_liodn_tbl);
diff --git a/arch/powerpc/cpu/mpc85xx/t1040_serdes.c b/arch/powerpc/cpu/mpc85xx/t1040_serdes.c new file mode 100644 index 0000000..0dc50c0 --- /dev/null +++ b/arch/powerpc/cpu/mpc85xx/t1040_serdes.c @@ -0,0 +1,94 @@ +/* + * Copyright 2012 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_serdes.h> +#include <asm/processor.h> +#include <asm/io.h> +#include "fsl_corenet2_serdes.h" + +static u8 serdes_cfg_tbl[MAX_SERDES][0xC4][SRDS_MAX_LANES] = { + { /* SerDes 1 */ + [0x69] = {PCIE1, SGMII_FM1_DTSEC3, QSGMII_SW1_A, QSGMII_SW1_B, + PCIE2, PCIE3, SGMII_FM1_DTSEC4, SATA1}, + [0x66] = {PCIE1, SGMII_FM1_DTSEC3, QSGMII_SW1_A, QSGMII_SW1_B, + PCIE2, PCIE3, PCIE4, SATA1}, + [0x67] = {PCIE1, SGMII_FM1_DTSEC3, QSGMII_SW1_A, QSGMII_SW1_B, + PCIE2, PCIE3, PCIE4, SGMII_FM1_DTSEC5}, + [0x60] = {PCIE1, SGMII_FM1_DTSEC3, QSGMII_SW1_A, QSGMII_SW1_B, + PCIE2, PCIE2, PCIE2, PCIE2}, + [0x8D] = {PCIE1, SGMII_SW1_DTSEC3, SGMII_SW1_DTSEC1, SGMII_SW1_DTSEC2, + PCIE2, SGMII_SW1_DTSEC6, SGMII_SW1_DTSEC4, SGMII_SW1_DTSEC5}, + [0x89] = {PCIE1, SGMII_SW1_DTSEC3, SGMII_SW1_DTSEC1, SGMII_SW1_DTSEC2, + PCIE2, PCIE3, SGMII_SW1_DTSEC4, SATA1}, + [0x86] = {PCIE1, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + PCIE2, PCIE3, PCIE4, SATA1}, + [0x87] = {PCIE1, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + PCIE2, PCIE3, PCIE4, SGMII_FM1_DTSEC5}, + [0xA7] = {PCIE1, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + PCIE2, PCIE3, PCIE4, SGMII_FM1_DTSEC5}, + [0xAA] = {PCIE1, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + PCIE2, PCIE3, SGMII_FM1_DTSEC4, SGMII_FM1_DTSEC5}, + [0x40] = {PCIE1, PCIE1, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + PCIE2, PCIE2, PCIE2, PCIE2}, + [0x06] = {PCIE1, PCIE1, PCIE1, PCIE1, + PCIE2, PCIE3, PCIE4, SATA1}, + [0x08] = {PCIE1, PCIE1, PCIE1, PCIE1, + PCIE2, PCIE3, SATA2, SATA1}, + [0x8F] = {PCIE1, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + AURORA, NONE, SGMII_FM1_DTSEC4, SGMII_FM1_DTSEC5}, + [0x85] = {PCIE1, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + PCIE2, PCIE2, SGMII_FM1_DTSEC4, SGMII_FM1_DTSEC5}, + [0xA5] = {PCIE1, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + PCIE2, PCIE2, SGMII_FM1_DTSEC4, SGMII_FM1_DTSEC5}, + [0x00] = {PCIE1, PCIE1, PCIE1, PCIE1, + PCIE2, PCIE2, PCIE2, PCIE2}, + }, + { + }, + { + }, + { + }, +}; + + +enum srds_prtcl serdes_get_prtcl(int serdes, int cfg, int lane) +{ + + return serdes_cfg_tbl[serdes][cfg][lane]; +} + +int is_serdes_prtcl_valid(int serdes, u32 prtcl) +{ + int i; + + if (prtcl > (ARRAY_SIZE(serdes_cfg_tbl[serdes]))) + return 0; + + for (i = 0; i < SRDS_MAX_LANES; i++) { + if (serdes_cfg_tbl[serdes][prtcl][i] != NONE) + return 1; + } + + return 0; +} diff --git a/arch/powerpc/cpu/mpc8xxx/cpu.c b/arch/powerpc/cpu/mpc8xxx/cpu.c index 0087cd0..23e008e 100644 --- a/arch/powerpc/cpu/mpc8xxx/cpu.c +++ b/arch/powerpc/cpu/mpc8xxx/cpu.c @@ -85,6 +85,12 @@ static struct cpu_type cpu_type_list[] = { CPU_TYPE_ENTRY(G4440, G4440, 0), CPU_TYPE_ENTRY(B4420, B4420, 0), CPU_TYPE_ENTRY(B4220, B4220, 0), + CPU_TYPE_ENTRY(T1040, T1040, 0), + CPU_TYPE_ENTRY(T1041, T1041, 0), + CPU_TYPE_ENTRY(T1042, T1042, 0), + CPU_TYPE_ENTRY(T1020, T1020, 0), + CPU_TYPE_ENTRY(T1021, T1021, 0), + CPU_TYPE_ENTRY(T1022, T1022, 0), CPU_TYPE_ENTRY(BSC9130, 9130, 1), CPU_TYPE_ENTRY(BSC9131, 9131, 1), CPU_TYPE_ENTRY(BSC9132, 9132, 2), diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 37eb118..24b9fc9 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -602,6 +602,32 @@ #define CONFIG_SYS_FSL_ERRATUM_A_004934 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000
+#elif defined(CONFIG_PPC_T1040) +#define CONFIG_E5500 +#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ +#define CONFIG_SYS_FSL_QORIQ_CHASSIS2 /* Freescale Chassis generation 2 */ +#define CONFIG_SYS_FSL_QMAN_V3 /* QMAN version 3 */ +#define CONFIG_MAX_CPUS 4 +#define CONFIG_SYS_FSL_NUM_CC_PLLS 5 +#define CONFIG_SYS_FSL_NUM_LAWS 16 +#define CONFIG_SYS_FSL_SEC_COMPAT 4 +#define CONFIG_SYS_NUM_FMAN 1 +#define CONFIG_SYS_NUM_FM1_DTSEC 5 +#define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_7 +#define CONFIG_SYS_FSL_IFC_BANK_COUNT 4 +#define CONFIG_SYS_FMAN_V3 +#define CONFIG_SYS_FM_MURAM_SIZE 0x28000 +#define CONFIG_SYS_FSL_TBCLK_DIV 32 +#define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.4" +#define CONFIG_SYS_FSL_SRIO_MAX_PORTS 2 +#define CONFIG_SYS_FSL_SRIO_OB_WIN_NUM 9 +#define CONFIG_SYS_FSL_SRIO_IB_WIN_NUM 5 +#define CONFIG_SYS_FSL_USB1_PHY_ENABLE +#define CONFIG_SYS_FSL_USB2_PHY_ENABLE +#define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 + #else #error Processor type not defined for this platform #endif diff --git a/arch/powerpc/include/asm/fsl_serdes.h b/arch/powerpc/include/asm/fsl_serdes.h index 6cd7379..ccb91fb 100644 --- a/arch/powerpc/include/asm/fsl_serdes.h +++ b/arch/powerpc/include/asm/fsl_serdes.h @@ -80,6 +80,14 @@ enum srds_prtcl { XFI_FM2_MAC9, XFI_FM2_MAC10, INTERLAKEN, + SGMII_SW1_DTSEC1, /* SW indicates on L2 switch */ + SGMII_SW1_DTSEC2, + SGMII_SW1_DTSEC3, + SGMII_SW1_DTSEC4, + SGMII_SW1_DTSEC5, + SGMII_SW1_DTSEC6, + QSGMII_SW1_A, /* SW indicates on L2 swtich */ + QSGMII_SW1_B, };
enum srds { diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 65d788a..6de8188 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1845,6 +1845,11 @@ typedef struct ccsr_gur { #define FSL_CORENET2_RCWSR4_SRDS2_PRTCL 0x00ff0000 #define FSL_CORENET2_RCWSR4_SRDS2_PRTCL_SHIFT 16 #define FSL_CORENET_RCWSR6_BOOT_LOC 0x0f800000 +#elif defined(CONFIG_PPC_T1040) +#define FSL_CORENET2_RCWSR4_SRDS1_PRTCL 0xff000000 +#define FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT 24 +#define FSL_CORENET2_RCWSR4_SRDS2_PRTCL 0x00fe0000 +#define FSL_CORENET2_RCWSR4_SRDS2_PRTCL_SHIFT 17 #endif #define FSL_CORENET2_RCWSR5_SRDS_PLL_PD_S1_PLL1 0x00800000 #define FSL_CORENET2_RCWSR5_SRDS_PLL_PD_S1_PLL2 0x00400000 diff --git a/arch/powerpc/include/asm/processor.h b/arch/powerpc/include/asm/processor.h index 1760aa1..5799386 100644 --- a/arch/powerpc/include/asm/processor.h +++ b/arch/powerpc/include/asm/processor.h @@ -1126,6 +1126,12 @@ #define SVR_G4440 0x868101 #define SVR_B4420 0x868102 #define SVR_B4220 0x868103 +#define SVR_T1040 0x852000 +#define SVR_T1041 0x852001 +#define SVR_T1042 0x852002 +#define SVR_T1020 0x852100 +#define SVR_T1021 0x852101 +#define SVR_T1022 0x852102
#define SVR_8610 0x80A000 #define SVR_8641 0x809000
Dear York Sun,
In message 1363973369-26110-10-git-send-email-yorksun@freescale.com you wrote:
CHECK: Blank lines aren't necessary after an open brace '{' #297: FILE: arch/powerpc/cpu/mpc85xx/t1040_serdes.c:77: +{ +
To align with chassis generation 2 spec, all cores are numbered in sequence. The cores may reside across multiple clusters. Each cluster has zero to four cores. The first available core is numbered as core 0. The second available core is numbered as core 1 and so on.
Core clocks are generated by each clusters. To identify the cluster of each core, topology registers are examined.
Cluster clock registers are reorganized to be easily indexed.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc85xx/release.S | 41 +++++++++++----------- arch/powerpc/cpu/mpc85xx/speed.c | 20 +++++------ arch/powerpc/cpu/mpc8xxx/cpu.c | 53 ++++++++++++++++++++++++----- arch/powerpc/include/asm/config_mpc85xx.h | 10 ++++++ arch/powerpc/include/asm/immap_85xx.h | 24 +++++-------- arch/powerpc/include/asm/processor.h | 2 ++ 6 files changed, 92 insertions(+), 58 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/release.S b/arch/powerpc/cpu/mpc85xx/release.S index 467ea10..a4a21b0 100644 --- a/arch/powerpc/cpu/mpc85xx/release.S +++ b/arch/powerpc/cpu/mpc85xx/release.S @@ -154,16 +154,12 @@ __secondary_start_page: ori r3,r3,toreset(__spin_table_addr)@l lwz r3,0(r3)
- /* - * r10 has the base address for the entry. - * we cannot access it yet before setting up a new TLB - */ mfspr r0,SPRN_PIR #ifdef CONFIG_SYS_FSL_QORIQ_CHASSIS2 /* * PIR definition for Chassis 2 * 0-17 Reserved (logic 0s) - * 8-19 CHIP_ID, 2'b00 - SoC 1 + * 18-19 CHIP_ID, 2'b00 - SoC 1 * all others - reserved * 20-24 CLUSTER_ID 5'b00000 - CCM 1 * all others - reserved @@ -177,32 +173,33 @@ __secondary_start_page: * 2'b11 - core 3 * 29-31 THREAD_ID 3'b000 - thread 0 * 3'b001 - thread 1 + * + * Power-on PIR increments threads by 0x01, cores within a cluster by 0x08 + * and clusters by 0x20. + * + * We renumber PIR so that all threads in the system are consecutive. */ - rlwinm r4,r0,29,25,31 + + rlwinm r8,r0,29,0x03 /* r8 = core within cluster */ + srwi r10,r0,5 /* r10 = cluster */ + + mulli r5,r10,CONFIG_SYS_FSL_CORES_PER_CLUSTER + add r5,r5,r8 /* for spin table index */ + mulli r4,r5,CONFIG_SYS_FSL_THREADS_PER_CORE /* for PIR */ #elif defined(CONFIG_E500MC) rlwinm r4,r0,27,27,31 + mr r5,r4 #else mr r4,r0 + mr r5,r4 #endif - slwi r8,r4,6 /* spin table is padded to 64 byte */ - add r10,r3,r8
-#ifdef CONFIG_SYS_FSL_QORIQ_CHASSIS2 - mfspr r0,SPRN_PIR /* - * core 0 thread 0: pir reset value 0x00, new pir 0 - * core 0 thread 1: pir reset value 0x01, new pir 1 - * core 1 thread 0: pir reset value 0x08, new pir 2 - * core 1 thread 1: pir reset value 0x09, new pir 3 - * core 2 thread 0: pir reset value 0x10, new pir 4 - * core 2 thread 1: pir reset value 0x11, new pir 5 - * etc. - * - * Only thread 0 of each core will be running, updating PIR doesn't - * need to deal with the thread bits. + * r10 has the base address for the entry. + * we cannot access it yet before setting up a new TLB */ - rlwinm r4,r0,30,24,30 -#endif + slwi r8,r5,6 /* spin table is padded to 64 byte */ + add r10,r3,r8
mtspr SPRN_PIR,r4 /* write to PIR register */
diff --git a/arch/powerpc/cpu/mpc85xx/speed.c b/arch/powerpc/cpu/mpc85xx/speed.c index f00b1ab..a4d6e9c 100644 --- a/arch/powerpc/cpu/mpc85xx/speed.c +++ b/arch/powerpc/cpu/mpc85xx/speed.c @@ -112,23 +112,20 @@ void get_sys_info (sys_info_t * sysInfo) #ifdef CONFIG_SYS_FSL_QORIQ_CHASSIS2 /* * Each cluster has up to 4 cores, sharing the same PLL selection. - * The cluster assignment is fixed per SoC. There is no way identify the - * assignment so far, presuming the "first configuration" which is to - * fill the lower cluster group first before moving up to next group. - * PLL1, PLL2, PLL3 are cluster group A, feeding core 0~3 on cluster 1 - * and core 4~7 on cluster 2 - * PLL4, PLL5, PLL6 are cluster group B, feeding core 8~11 on cluster 3 - * and core 12~15 on cluster 4 if existing + * The cluster assignment is fixed per SoC. PLL1, PLL2, PLL3 are + * cluster group A, feeding cores on cluster 1 and cluster 2. + * PLL4, PLL5, PLL6 are cluster group B, feeding cores on cluster 3 + * and cluster 4 if existing. */ for_each_cpu(i, cpu, cpu_numcores(), cpu_mask()) { - u32 c_pll_sel = (in_be32(&clk->clkc0csr + (cpu / 4) * 8) >> 27) + int cluster = fsl_qoriq_core_to_cluster(cpu); + u32 c_pll_sel = (in_be32(&clk->clkcsr[cluster].clkcncsr) >> 27) & 0xf; u32 cplx_pll = core_cplx_PLL[c_pll_sel]; if (cplx_pll > 3) printf("Unsupported architecture configuration" " in function %s\n", __func__); - cplx_pll += (cpu / 8) * 3; - + cplx_pll += (cluster / 2) * 3; sysInfo->freqProcessor[cpu] = freqCC_PLL[cplx_pll] / core_cplx_PLL_div[c_pll_sel]; } @@ -240,7 +237,8 @@ void get_sys_info (sys_info_t * sysInfo) #else /* CONFIG_SYS_FSL_QORIQ_CHASSIS2 */
for_each_cpu(i, cpu, cpu_numcores(), cpu_mask()) { - u32 c_pll_sel = (in_be32(&clk->clkc0csr + cpu*8) >> 27) & 0xf; + u32 c_pll_sel = (in_be32(&clk->clkcsr[cpu].clkcncsr) >> 27) + & 0xf; u32 cplx_pll = core_cplx_PLL[c_pll_sel];
sysInfo->freqProcessor[cpu] = diff --git a/arch/powerpc/cpu/mpc8xxx/cpu.c b/arch/powerpc/cpu/mpc8xxx/cpu.c index 23e008e..bc26855 100644 --- a/arch/powerpc/cpu/mpc8xxx/cpu.c +++ b/arch/powerpc/cpu/mpc8xxx/cpu.c @@ -103,35 +103,70 @@ static struct cpu_type cpu_type_list[] = { };
#ifdef CONFIG_SYS_FSL_QORIQ_CHASSIS2 +static inline u32 init_type(u32 cluster, int init_id) +{ + ccsr_gur_t *gur = (void __iomem *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 idx = (cluster >> (init_id * 8)) & TP_CLUSTER_INIT_MASK; + u32 type = in_be32(&gur->tp_ityp[idx]); + + if (type & TP_ITYP_AV) + return type; + + return 0; +} + u32 compute_ppc_cpumask(void) { - ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + ccsr_gur_t *gur = (void __iomem *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); int i = 0, count = 0; - u32 cluster, mask = 0; + u32 cluster, type, mask = 0;
do { int j; - cluster = in_be32(&gur->tp_cluster[i++].lower); - for (j = 0; j < 4; j++) { - u32 idx = (cluster >> (j*8)) & TP_CLUSTER_INIT_MASK; - u32 type = in_be32(&gur->tp_ityp[idx]); - - if (type & TP_ITYP_AV) { + cluster = in_be32(&gur->tp_cluster[i].lower); + for (j = 0; j < TP_INIT_PER_CLUSTER; j++) { + type = init_type(cluster, j); + if (type) { if (TP_ITYP_TYPE(type) == TP_ITYP_TYPE_PPC) mask |= 1 << count; + count++; } - count++; } + i++; } while ((cluster & TP_CLUSTER_EOC) != TP_CLUSTER_EOC);
return mask; } + +int fsl_qoriq_core_to_cluster(unsigned int core) +{ + ccsr_gur_t *gur = (void __iomem *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + int i = 0, count = 0; + u32 cluster; + + do { + int j; + cluster = in_be32(&gur->tp_cluster[i].lower); + for (j = 0; j < TP_INIT_PER_CLUSTER; j++) { + if (init_type(cluster, j)) { + if (count == core) + return i; + count++; + } + } + i++; + } while ((cluster & TP_CLUSTER_EOC) != TP_CLUSTER_EOC); + + return -1; /* cannot identify the cluster */ +} + #else /* CONFIG_SYS_FSL_QORIQ_CHASSIS2 */ /* * Before chassis genenration 2, the cpumask should be hard-coded. * In case of cpu type unknown or cpumask unset, use 1 as fail save. */ #define compute_ppc_cpumask() 1 +#define fsl_qoriq_core_to_cluster(x) x #endif /* CONFIG_SYS_FSL_QORIQ_CHASSIS2 */
static struct cpu_type cpu_type_unknown = CPU_TYPE_ENTRY(Unknown, Unknown, 0); diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 24b9fc9..e92cdb9 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -515,6 +515,7 @@ #define CONFIG_SYS_PPC64 /* 64-bit core */ #define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_SYS_FSL_QORIQ_CHASSIS2 /* Freescale Chassis generation 2 */ +#define CONFIG_SYS_FSL_CORES_PER_CLUSTER 4 #define CONFIG_SYS_FSL_QMAN_V3 /* QMAN version 3 */ #ifdef CONFIG_PPC_T4240 #define CONFIG_MAX_CPUS 12 @@ -558,6 +559,7 @@ #define CONFIG_SYS_PPC64 /* 64-bit core */ #define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_SYS_FSL_QORIQ_CHASSIS2 /* Freescale Chassis generation 2 */ +#define CONFIG_SYS_FSL_CORES_PER_CLUSTER 4 #define CONFIG_SYS_FSL_QMAN_V3 /* QMAN version 3 */ #define CONFIG_MAX_CPUS 2 #define CONFIG_SYS_FSL_NUM_CC_PLLS 4 @@ -580,6 +582,7 @@ #define CONFIG_SYS_PPC64 /* 64-bit core */ #define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_SYS_FSL_QORIQ_CHASSIS2 /* Freescale Chassis generation 2 */ +#define CONFIG_SYS_FSL_CORES_PER_CLUSTER 4 #define CONFIG_SYS_FSL_QMAN_V3 /* QMAN version 3 */ #define CONFIG_MAX_CPUS 4 #define CONFIG_SYS_FSL_NUM_CC_PLLS 4 @@ -606,6 +609,7 @@ #define CONFIG_E5500 #define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_SYS_FSL_QORIQ_CHASSIS2 /* Freescale Chassis generation 2 */ +#define CONFIG_SYS_FSL_CORES_PER_CLUSTER 1 #define CONFIG_SYS_FSL_QMAN_V3 /* QMAN version 3 */ #define CONFIG_MAX_CPUS 4 #define CONFIG_SYS_FSL_NUM_CC_PLLS 5 @@ -636,4 +640,10 @@ #error "CONFIG_SYS_CCSRBAR_DEFAULT is not defined for this platform." #endif
+#ifdef CONFIG_E6500 +#define CONFIG_SYS_FSL_THREADS_PER_CORE 2 +#else +#define CONFIG_SYS_FSL_THREADS_PER_CORE 1 +#endif + #endif /* _ASM_MPC85xx_CONFIG_H_ */ diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 6de8188..67e4c46 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1997,6 +1997,7 @@ typedef struct ccsr_gur {
#define TP_CLUSTER_EOC 0x80000000 /* end of clusters */ #define TP_CLUSTER_INIT_MASK 0x0000003f /* initiator mask */ +#define TP_INIT_PER_CLUSTER 4
#define FSL_CORENET_DCSR_SZ_MASK 0x00000003 #define FSL_CORENET_DCSR_SZ_4M 0x0 @@ -2009,22 +2010,13 @@ typedef struct ccsr_gur { #define rmuliodnr rio1maintliodnr
typedef struct ccsr_clk { - u32 clkc0csr; /* 0x000 Core 0 Clock control/status */ - u8 res1[0x1c]; - u32 clkc1csr; /* 0x020 Core 1 Clock control/status */ - u8 res2[0x1c]; - u32 clkc2csr; /* 0x040 Core 2 Clock control/status */ - u8 res3[0x1c]; - u32 clkc3csr; /* 0x060 Core 3 Clock control/status */ - u8 res4[0x1c]; - u32 clkc4csr; /* 0x080 Core 4 Clock control/status */ - u8 res5[0x1c]; - u32 clkc5csr; /* 0x0a0 Core 5 Clock control/status */ - u8 res6[0x1c]; - u32 clkc6csr; /* 0x0c0 Core 6 Clock control/status */ - u8 res7[0x1c]; - u32 clkc7csr; /* 0x0e0 Core 7 Clock control/status */ - u8 res8[0x71c]; + struct { + u32 clkcncsr; /* core cluster n clock control status */ + u8 res_004[0x0c]; + u32 clkcgnhwacsr;/* clock generator n hardware accelerator */ + u8 res_014[0x0c]; + } clkcsr[8]; + u8 res_100[0x700]; /* 0x100 */ u32 pllc1gsr; /* 0x800 Cluster PLL 1 General Status */ u8 res10[0x1c]; u32 pllc2gsr; /* 0x820 Cluster PLL 2 General Status */ diff --git a/arch/powerpc/include/asm/processor.h b/arch/powerpc/include/asm/processor.h index 5799386..56b22d8 100644 --- a/arch/powerpc/include/asm/processor.h +++ b/arch/powerpc/include/asm/processor.h @@ -1200,6 +1200,8 @@ struct cpu_type { struct cpu_type *identify_cpu(u32 ver); int fixup_cpu(void);
+int fsl_qoriq_core_to_cluster(unsigned int core); + #if defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) #define CPU_TYPE_ENTRY(n, v, nc) \ { .name = #n, .soc_ver = SVR_##v, .num_cores = (nc), \
Allow DDR clock runs faster than SPD specifes. This may cause memory failure, but the user should know what is going to happen when using higher than expected DDR clock.
Signed-off-by: Ed Swarthout Ed.Swarthout@freescale.com Signed-off-by: York Sun yorksun@freescale.com --- .../cpu/mpc8xxx/ddr/lc_common_dimm_params.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/lc_common_dimm_params.c b/arch/powerpc/cpu/mpc8xxx/ddr/lc_common_dimm_params.c index 9adde31..e958e13 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/lc_common_dimm_params.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/lc_common_dimm_params.c @@ -44,7 +44,6 @@ compute_cas_latency_ddr3(const dimm_params_t *dimm_params, printf("DDR clock (MCLK cycle %u ps) is faster than " "the slowest DIMM(s) (tCKmin %u ps) can support.\n", mclk_ps, tCKmin_X_ps); - return 1; } /* determine the acutal cas latency */ caslat_actual = (tAAmin_ps + mclk_ps - 1) / mclk_ps; @@ -60,7 +59,6 @@ compute_cas_latency_ddr3(const dimm_params_t *dimm_params, if (caslat_actual * mclk_ps > 20000) { printf("The choosen cas latency %d is too large\n", caslat_actual); - return 1; } outpdimm->lowest_common_SPD_caslat = caslat_actual;
QIXIS includes frequency measurement functions for each major processor clock input. After reset (and after clocks are stable), QIXIS measures the clocks against a reference frequency and stores the results in CLK_FREQ registers. A base register supplies a multiplier which allows directly obtaining the measured value, without requiring knowledge of the target system or QIXIS core frequency.
Signed-off-by: Ed Swarthout Ed.Swarthout@freescale.com Signed-off-by: York Sun yorksun@freescale.com --- board/freescale/common/qixis.h | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/board/freescale/common/qixis.h b/board/freescale/common/qixis.h index 8d914d5..2cf8738 100644 --- a/board/freescale/common/qixis.h +++ b/board/freescale/common/qixis.h @@ -78,7 +78,11 @@ struct qixis { u8 trig_stat; u8 res12[3]; u8 trig_ctr[4]; - u8 res13[48]; + u8 res13[16]; + u8 clk_freq[6]; /* Clock Measurement Registers */ + u8 res_c6[8]; + u8 clk_base[2]; /* Clock Frequency Base Reg */ + u8 res_d0[16]; u8 aux2[4]; /* Auxiliary Registers,0xE0 */ u8 res14[10]; u8 aux_ad;
Use QIXIS measurement registers to obtain sysclk and ddr clock. This allows using non-standard clock speeds, set by directly writing to clock chip or store the values in qixis clock data eeprom.
Signed-off-by: Ed Swarthout Ed.Swarthout@freescale.com Signed-off-by: York Sun yorksun@freescale.com --- board/freescale/t4qds/t4qds.c | 30 ++++++++++++++++++++++++++++++ 1 file changed, 30 insertions(+)
diff --git a/board/freescale/t4qds/t4qds.c b/board/freescale/t4qds/t4qds.c index 3eec601..5571a00 100644 --- a/board/freescale/t4qds/t4qds.c +++ b/board/freescale/t4qds/t4qds.c @@ -541,6 +541,21 @@ int board_early_init_r(void) unsigned long get_board_sys_clk(void) { u8 sysclk_conf = QIXIS_READ(brdcfg[1]); +#ifdef CONFIG_FSL_QIXIS_CLOCK_MEASUREMENT + /* use accurate clock measurement */ + int freq = QIXIS_READ(clk_freq[0]) << 8 | QIXIS_READ(clk_freq[1]); + int base = QIXIS_READ(clk_base[0]) << 8 | QIXIS_READ(clk_base[1]); + u32 val; + + val = freq * base; + if (val) { + debug("SYS Clock measurement is: %d\n", val); + return val; + } else { + printf("Warning: SYS clock measurement is invalid, " + "using value from brdcfg1.\n"); + } +#endif
switch (sysclk_conf & 0x0F) { case QIXIS_SYSCLK_83: @@ -564,6 +579,21 @@ unsigned long get_board_sys_clk(void) unsigned long get_board_ddr_clk(void) { u8 ddrclk_conf = QIXIS_READ(brdcfg[1]); +#ifdef CONFIG_FSL_QIXIS_CLOCK_MEASUREMENT + /* use accurate clock measurement */ + int freq = QIXIS_READ(clk_freq[2]) << 8 | QIXIS_READ(clk_freq[3]); + int base = QIXIS_READ(clk_base[0]) << 8 | QIXIS_READ(clk_base[1]); + u32 val; + + val = freq * base; + if (val) { + debug("DDR Clock measurement is: %d\n", val); + return val; + } else { + printf("Warning: DDR clock measurement is invalid, " + "using value from brdcfg1.\n"); + } +#endif
switch ((ddrclk_conf & 0x30) >> 4) { case QIXIS_DDRCLK_100:
Dear York Sun,
In message 1363973369-26110-14-git-send-email-yorksun@freescale.com you wrote:
WARNING: quoted string split across lines #139: FILE: board/freescale/t4qds/t4qds.c:556: + printf("Warning: SYS clock measurement is invalid, " + "using value from brdcfg1.\n");
WARNING: quoted string split across lines #161: FILE: board/freescale/t4qds/t4qds.c:594: + printf("Warning: DDR clock measurement is invalid, " + "using value from brdcfg1.\n");
Provided a default RCW for P5040, then it can use PBL to build ramboot image.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com --- board/freescale/corenet_ds/rcw_p5040ds.cfg | 11 +++++++++++ include/configs/corenet_ds.h | 2 ++ 2 files changed, 13 insertions(+) create mode 100644 board/freescale/corenet_ds/rcw_p5040ds.cfg
diff --git a/board/freescale/corenet_ds/rcw_p5040ds.cfg b/board/freescale/corenet_ds/rcw_p5040ds.cfg new file mode 100644 index 0000000..82fa741 --- /dev/null +++ b/board/freescale/corenet_ds/rcw_p5040ds.cfg @@ -0,0 +1,11 @@ +# +# Default RCW for P5040DS. +# + +#PBL preamble and RCW header +aa55aa55 010e0100 +#64 bytes RCW data +0c580000 00000000 22121200 00000000 +089c4400 00283000 58000000 61000000 +00000000 00000000 00000000 10070000 +00000000 00000000 00000000 00000000 diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 5cc9b5a..2e2d439 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -38,6 +38,8 @@ #define CONFIG_PBLRCW_CONFIG $(SRCTREE)/board/freescale/corenet_ds/rcw_p4080ds.cfg #elif defined(CONFIG_P5020DS) #define CONFIG_PBLRCW_CONFIG $(SRCTREE)/board/freescale/corenet_ds/rcw_p5020ds.cfg +#elif defined(CONFIG_P5040DS) +#define CONFIG_PBLRCW_CONFIG $(SRCTREE)/board/freescale/corenet_ds/rcw_p5040ds.cfg #endif #endif
Debug trace buffers are memory mapped in DCSR space beyond 4M.
Signed-off-by: Stephen George stephen.george@freescale.com --- board/freescale/b4860qds/law.c | 3 ++- board/freescale/b4860qds/tlb.c | 2 +- board/freescale/t4qds/law.c | 3 ++- board/freescale/t4qds/tlb.c | 2 +- doc/README.b4860qds | 4 ++-- doc/README.t4240qds | 2 +- 6 files changed, 9 insertions(+), 7 deletions(-)
diff --git a/board/freescale/b4860qds/law.c b/board/freescale/b4860qds/law.c index 4142e01..abaad7a 100644 --- a/board/freescale/b4860qds/law.c +++ b/board/freescale/b4860qds/law.c @@ -34,7 +34,8 @@ struct law_entry law_table[] = { #endif SET_LAW(QIXIS_BASE_PHYS, LAW_SIZE_4K, LAW_TRGT_IF_IFC), #ifdef CONFIG_SYS_DCSRBAR_PHYS - SET_LAW(CONFIG_SYS_DCSRBAR_PHYS, LAW_SIZE_4M, LAW_TRGT_IF_DCSR), + /* Limit DCSR to 32M to access NPC Trace Buffer */ + SET_LAW(CONFIG_SYS_DCSRBAR_PHYS, LAW_SIZE_32M, LAW_TRGT_IF_DCSR), #endif #ifdef CONFIG_SYS_NAND_BASE_PHYS SET_LAW(CONFIG_SYS_NAND_BASE_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_IFC), diff --git a/board/freescale/b4860qds/tlb.c b/board/freescale/b4860qds/tlb.c index 0ea4976..3572b44 100644 --- a/board/freescale/b4860qds/tlb.c +++ b/board/freescale/b4860qds/tlb.c @@ -115,7 +115,7 @@ struct fsl_e_tlb_entry tlb_table[] = { #ifdef CONFIG_SYS_DCSRBAR_PHYS SET_TLB_ENTRY(1, CONFIG_SYS_DCSRBAR, CONFIG_SYS_DCSRBAR_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 10, BOOKE_PAGESZ_4M, 1), + 0, 10, BOOKE_PAGESZ_32M, 1), #endif #ifdef CONFIG_SYS_NAND_BASE /* diff --git a/board/freescale/t4qds/law.c b/board/freescale/t4qds/law.c index 6f2c5c8..f3848f3 100644 --- a/board/freescale/t4qds/law.c +++ b/board/freescale/t4qds/law.c @@ -37,7 +37,8 @@ struct law_entry law_table[] = { #endif SET_LAW(QIXIS_BASE_PHYS, LAW_SIZE_4K, LAW_TRGT_IF_IFC), #ifdef CONFIG_SYS_DCSRBAR_PHYS - SET_LAW(CONFIG_SYS_DCSRBAR_PHYS, LAW_SIZE_4M, LAW_TRGT_IF_DCSR), + /* Limit DCSR to 32M to access NPC Trace Buffer */ + SET_LAW(CONFIG_SYS_DCSRBAR_PHYS, LAW_SIZE_32M, LAW_TRGT_IF_DCSR), #endif #ifdef CONFIG_SYS_NAND_BASE_PHYS SET_LAW(CONFIG_SYS_NAND_BASE_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_IFC), diff --git a/board/freescale/t4qds/tlb.c b/board/freescale/t4qds/tlb.c index 80eb511..92c01cf 100644 --- a/board/freescale/t4qds/tlb.c +++ b/board/freescale/t4qds/tlb.c @@ -115,7 +115,7 @@ struct fsl_e_tlb_entry tlb_table[] = { #ifdef CONFIG_SYS_DCSRBAR_PHYS SET_TLB_ENTRY(1, CONFIG_SYS_DCSRBAR, CONFIG_SYS_DCSRBAR_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 13, BOOKE_PAGESZ_4M, 1), + 0, 13, BOOKE_PAGESZ_32M, 1), #endif #ifdef CONFIG_SYS_NAND_BASE /* diff --git a/doc/README.b4860qds b/doc/README.b4860qds index f6c5ff8..bd10a6d 100644 --- a/doc/README.b4860qds +++ b/doc/README.b4860qds @@ -185,7 +185,7 @@ Start Address End Address Description Size 0xF_A0C0_0000 0xF_DFFF_FFFF Free 1012 MB 0xF_A000_0000 0xF_A0BF_FFFF MAPLE0/1/2 12 MB 0xF_0040_0000 0xF_9FFF_FFFF Free 12 GB -0xF_0000_0000 0xF_003F_FFFF DCSR 4 MB +0xF_0000_0000 0xF_01FF_FFFF DCSR 32 MB 0xC_4000_0000 0xE_FFFF_FFFF Free 11 GB 0xC_3000_0000 0xC_3FFF_FFFF sRIO-2 I/O 256 MB 0xC_2000_0000 0xC_2FFF_FFFF sRIO-1 I/O 256 MB @@ -215,7 +215,7 @@ Start Address End Address Description Size 0xF_A0C0_0000 0xF_DFFF_FFFF Free 1012 MB 0xF_A000_0000 0xF_A0BF_FFFF MAPLE0/1/2 12 MB 0xF_0040_0000 0xF_9FFF_FFFF Free 12 GB -0xF_0000_0000 0xF_003F_FFFF DCSR 4 MB +0xF_0000_0000 0xF_01FF_FFFF DCSR 32 MB 0xC_4000_0000 0xE_FFFF_FFFF Free 11 GB 0xC_3000_0000 0xC_3FFF_FFFF sRIO-2 I/O 256 MB 0xC_2000_0000 0xC_2FFF_FFFF sRIO-1 I/O 256 MB diff --git a/doc/README.t4240qds b/doc/README.t4240qds index 19e8a8a..a9841fb 100644 --- a/doc/README.t4240qds +++ b/doc/README.t4240qds @@ -86,7 +86,7 @@ The addresses in brackets are physical addresses.
0x0_0000_0000 (0x0_0000_0000) - 0x0_7fff_ffff 2GB DDR (more than 2GB is initialized but not mapped under with TLB) 0x0_8000_0000 (0xc_0000_0000) - 0x0_dfff_ffff 1.5GB PCIE memory -0x0_f000_0000 (0xf_0000_0000) - 0x0_f03f_ffff 4MB DCSR +0x0_f000_0000 (0xf_0000_0000) - 0x0_f1ff_ffff 32MB DCSR (includes trace buffers) 0x0_f400_0000 (0xf_f400_0000) - 0x0_f5ff_ffff 32MB BMan 0x0_f600_0000 (0xf_f600_0000) - 0x0_f7ff_ffff 32MB QMan 0x0_f800_0000 (0xf_f800_0000) - 0x0_f803_ffff 256KB PCIE IO
- Added SERDES2 PRTCLs = 0x98, 0x9E - Default Phy Addresses for Teranetics PHY on XAUI card The PHY addresses of Teranetics PHY on XAUI riser card are assigned based on the slot it is in. Switches SW4[2:4] and SW6[2:4] on AMC2PEX-2S On B4860QDS, AMC2PEX card decide the PHY addresses on slot1 and slot2 - Configure MDIO for 10Gig Mac
Signed-off-by: Suresh Gupta suresh.gupta@freescale.com --- board/freescale/b4860qds/eth_b4860qds.c | 38 +++++++++++++++++++++++++++++++ drivers/net/fm/b4860.c | 4 +++- include/configs/B4860QDS.h | 6 ++++- 3 files changed, 46 insertions(+), 2 deletions(-)
diff --git a/board/freescale/b4860qds/eth_b4860qds.c b/board/freescale/b4860qds/eth_b4860qds.c index 68e2725..0e151dd 100644 --- a/board/freescale/b4860qds/eth_b4860qds.c +++ b/board/freescale/b4860qds/eth_b4860qds.c @@ -275,6 +275,27 @@ int board_eth_init(bd_t *bis) fm_info_set_phy_address(FM1_DTSEC4, CONFIG_SYS_FM1_DTSEC2_RISER_PHY_ADDR); break; + case 0x98: + /* XAUI in Slot1 and Slot2 */ + debug("Setting phy addresses on B4860 QDS AMC2PEX-2S" + "for FM1_10GEC1: %x\n", + CONFIG_SYS_FM1_10GEC1_PHY_ADDR); + fm_info_set_phy_address(FM1_10GEC1, + CONFIG_SYS_FM1_10GEC1_PHY_ADDR); + debug("Setting phy addresses on B4860 QDS AMC2PEX-2S" + "for FM1_10GEC2: %x\n", + CONFIG_SYS_FM1_10GEC2_PHY_ADDR); + fm_info_set_phy_address(FM1_10GEC2, + CONFIG_SYS_FM1_10GEC2_PHY_ADDR); + break; + case 0x9E: + /* XAUI in Slot2 */ + debug("Setting phy addresses on B4860 QDS AMC2PEX-2S" + "for FM1_10GEC2: %x\n", + CONFIG_SYS_FM1_10GEC2_PHY_ADDR); + fm_info_set_phy_address(FM1_10GEC2, + CONFIG_SYS_FM1_10GEC2_PHY_ADDR); + break; default: printf("Fman: Unsupported SerDes2 Protocol 0x%02x\n", serdes2_prtcl); @@ -300,6 +321,23 @@ int board_eth_init(bd_t *bis) } }
+ for (i = FM1_10GEC1; i < FM1_10GEC1 + CONFIG_SYS_NUM_FM1_10GEC; i++) { + int idx = i - FM1_10GEC1; + + switch (fm_info_get_enet_if(i)) { + case PHY_INTERFACE_MODE_XGMII: + fm_info_set_mdio(i, + miiphy_get_dev_by_name(DEFAULT_FM_TGEC_MDIO_NAME)); + break; + default: + printf("Fman1: 10GSEC%u set to unknown interface %i\n", + idx + 1, fm_info_get_enet_if(i)); + fm_info_set_phy_address(i, 0); + break; + } + } + + cpu_eth_init(bis); #endif
diff --git a/drivers/net/fm/b4860.c b/drivers/net/fm/b4860.c index 8cde7af..a247ccc 100644 --- a/drivers/net/fm/b4860.c +++ b/drivers/net/fm/b4860.c @@ -55,8 +55,10 @@ phy_interface_t fman_port_enet_if(enum fm_port port) if (is_device_disabled(port)) return PHY_INTERFACE_MODE_NONE;
+ /*B4860 has two 10Gig Mac*/ if ((port == FM1_10GEC1 || port == FM1_10GEC2) - && (is_serdes_configured(XAUI_FM1))) + && ((is_serdes_configured(XAUI_FM1_MAC9)) + || (is_serdes_configured(XAUI_FM1_MAC10)))) return PHY_INTERFACE_MODE_XGMII;
/* Fix me need to handle RGMII here first */ diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 00ee5ac..22cd808 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -646,7 +646,11 @@ unsigned long get_board_ddr_clk(void); #ifdef CONFIG_FMAN_ENET #define CONFIG_SYS_FM1_DTSEC5_PHY_ADDR 0x10 #define CONFIG_SYS_FM1_DTSEC6_PHY_ADDR 0x11 -#define CONFIG_SYS_FM1_10GEC1_PHY_ADDR 4 + +/*B4860 QDS AMC2PEX-2S default PHY_ADDR */ +#define CONFIG_SYS_FM1_10GEC1_PHY_ADDR 0x7 /*SLOT 1*/ +#define CONFIG_SYS_FM1_10GEC2_PHY_ADDR 0x6 /*SLOT 2*/ +
#define CONFIG_SYS_FM1_DTSEC1_RISER_PHY_ADDR 0x1c #define CONFIG_SYS_FM1_DTSEC2_RISER_PHY_ADDR 0x1d
Dear York Sun,
In message 1363973369-26110-17-git-send-email-yorksun@freescale.com you wrote:
WARNING: quoted string split across lines #134: FILE: board/freescale/b4860qds/eth_b4860qds.c:281: + debug("Setting phy addresses on B4860 QDS AMC2PEX-2S" + "for FM1_10GEC1: %x\n",
CHECK: Alignment should match open parenthesis #137: FILE: board/freescale/b4860qds/eth_b4860qds.c:284: + fm_info_set_phy_address(FM1_10GEC1, + CONFIG_SYS_FM1_10GEC1_PHY_ADDR);
WARNING: quoted string split across lines #139: FILE: board/freescale/b4860qds/eth_b4860qds.c:286: + debug("Setting phy addresses on B4860 QDS AMC2PEX-2S" + "for FM1_10GEC2: %x\n",
CHECK: Alignment should match open parenthesis #142: FILE: board/freescale/b4860qds/eth_b4860qds.c:289: + fm_info_set_phy_address(FM1_10GEC2, + CONFIG_SYS_FM1_10GEC2_PHY_ADDR);
WARNING: quoted string split across lines #147: FILE: board/freescale/b4860qds/eth_b4860qds.c:294: + debug("Setting phy addresses on B4860 QDS AMC2PEX-2S" + "for FM1_10GEC2: %x\n",
CHECK: Alignment should match open parenthesis #150: FILE: board/freescale/b4860qds/eth_b4860qds.c:297: + fm_info_set_phy_address(FM1_10GEC2, + CONFIG_SYS_FM1_10GEC2_PHY_ADDR);
CHECK: Alignment should match open parenthesis #165: FILE: board/freescale/b4860qds/eth_b4860qds.c:330: + fm_info_set_mdio(i, + miiphy_get_dev_by_name(DEFAULT_FM_TGEC_MDIO_NAME));
CHECK: Alignment should match open parenthesis #169: FILE: board/freescale/b4860qds/eth_b4860qds.c:334: + printf("Fman1: 10GSEC%u set to unknown interface %i\n", + idx + 1, fm_info_get_enet_if(i));
CHECK: Logical continuations should be on the previous line #190: FILE: drivers/net/fm/b4860.c:60: if ((port == FM1_10GEC1 || port == FM1_10GEC2) + && ((is_serdes_configured(XAUI_FM1_MAC9))
CHECK: Logical continuations should be on the previous line #191: FILE: drivers/net/fm/b4860.c:61: + && ((is_serdes_configured(XAUI_FM1_MAC9)) + || (is_serdes_configured(XAUI_FM1_MAC10))))
SW7[4] is the new bit which controls the mapping of eMMC vs SDHC.
Signed-off-by: York Sun yorksun@freescale.com --- board/freescale/t4qds/t4qds.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/board/freescale/t4qds/t4qds.c b/board/freescale/t4qds/t4qds.c index 5571a00..a9c3173 100644 --- a/board/freescale/t4qds/t4qds.c +++ b/board/freescale/t4qds/t4qds.c @@ -804,7 +804,7 @@ void qixis_dump_switch(void) * Any bit with 1 means that bit cannot be reverse engineered. * It will be displayed as _ in binary format. */ - static const u8 mask[] = {0, 0, 0, 0, 0, 0x1, 0xdf, 0x3f, 0x1f}; + static const u8 mask[] = {0, 0, 0, 0, 0, 0x1, 0xcf, 0x3f, 0x1f}; char buf[10]; u8 brdcfg[16], dutcfg[16];
@@ -835,7 +835,8 @@ void qixis_dump_switch(void) sw[5] = ((brdcfg[0] & 0x0f) << 4) | \ ((QIXIS_READ(rst_ctl) & 0x30) >> 2) | \ ((brdcfg[0] & 0x40) >> 5); - sw[6] = (brdcfg[11] & 0x20); + sw[6] = (brdcfg[11] & 0x20) | \ + ((brdcfg[5] & 0x02) << 3); sw[7] = (((~QIXIS_READ(rst_ctl)) & 0x40) << 1) | \ ((brdcfg[5] & 0x10) << 2); sw[8] = ((brdcfg[12] & 0x08) << 4) | \
Dear York Sun,
In message 1363973369-26110-18-git-send-email-yorksun@freescale.com you wrote:
WARNING: Avoid unnecessary line continuations #131: FILE: board/freescale/t4qds/t4qds.c:838: + sw[6] = (brdcfg[11] & 0x20) | \
T4 can support the feature of Boot from SRIO/PCIE, and the macro "CONFIG_SRIO_PCIE_BOOT_MASTER" will enable the master module of this feature when building the u-boot image.
You can get some description about this macro in README file, and for more information about the feature of Boot from SRIO/PCIE, please refer to the document doc/README.srio-pcie-boot-corenet.
Signed-off-by: Liu Gang Gang.Liu@freescale.com --- include/configs/t4qds.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index fa1dcc3..f153dde 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -65,6 +65,7 @@ #define CONFIG_SYS_SRIO #define CONFIG_SRIO1 /* SRIO port 1 */ #define CONFIG_SRIO2 /* SRIO port 2 */ +#define CONFIG_SRIO_PCIE_BOOT_MASTER
#define CONFIG_FSL_LAW /* Use common FSL init code */
When a T4 board boots from SRIO or PCIE, it needs to finish these processes: 1. Set the boot location to one PCIE or SRIO interface by RCW. 2. Set a specific TLB entry for the boot process. 3. Set a LAW entry with the TargetID of one PCIE or SRIO for the boot. 4. Set a specific TLB entry in order to fetch ucode and ENV from master. 5. Set a LAW entry with the TargetID one of the PCIE ports for ucode and ENV. 6. Slave's u-boot image should be generated specifically by make xxxx_SRIO_PCIE_BOOT_config. This will set SYS_TEXT_BASE=0xFFF80000 and other configurations.
For more information about the feature of Boot from SRIO/PCIE, please refer to the document doc/README.srio-pcie-boot-corenet.
Signed-off-by: Liu Gang Gang.Liu@freescale.com --- arch/powerpc/include/asm/immap_85xx.h | 1 + board/freescale/t4qds/tlb.c | 19 ++++++++++++++++++ boards.cfg | 2 ++ include/configs/t4qds.h | 34 ++++++++++++++++++++++++++------- 4 files changed, 49 insertions(+), 7 deletions(-)
diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 67e4c46..3433e18 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1839,6 +1839,7 @@ typedef struct ccsr_gur { #define FSL_CORENET2_RCWSR4_SRDS3_PRTCL_SHIFT 11 #define FSL_CORENET2_RCWSR4_SRDS4_PRTCL 0x000000f8 #define FSL_CORENET2_RCWSR4_SRDS4_PRTCL_SHIFT 3 +#define FSL_CORENET_RCWSR6_BOOT_LOC 0x0f800000 #elif defined(CONFIG_PPC_B4860) || defined(CONFIG_PPC_B4420) #define FSL_CORENET2_RCWSR4_SRDS1_PRTCL 0xfe000000 #define FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT 25 diff --git a/board/freescale/t4qds/tlb.c b/board/freescale/t4qds/tlb.c index 92c01cf..2a2e3d6 100644 --- a/board/freescale/t4qds/tlb.c +++ b/board/freescale/t4qds/tlb.c @@ -55,6 +55,15 @@ struct fsl_e_tlb_entry tlb_table[] = { SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L3_ADDR, CONFIG_SYS_INIT_L3_ADDR, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 0, BOOKE_PAGESZ_1M, 1), +#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) + /* + * SRIO_PCIE_BOOT-SLAVE. When slave boot, the address of the + * space is at 0xfff00000, it covered the 0xfffff000. + */ + SET_TLB_ENTRY(1, CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR, + CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_W|MAS2_G, + 0, 0, BOOKE_PAGESZ_1M, 1), #else SET_TLB_ENTRY(1, 0xfffff000, 0xfffff000, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, @@ -130,6 +139,16 @@ struct fsl_e_tlb_entry tlb_table[] = { SET_TLB_ENTRY(1, QIXIS_BASE, QIXIS_BASE_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 17, BOOKE_PAGESZ_4K, 1), +#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE + /* + * SRIO_PCIE_BOOT-SLAVE. 1M space from 0xffe00000 for + * fetching ucode and ENV from master + */ + SET_TLB_ENTRY(1, CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR, + CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_G, + 0, 18, BOOKE_PAGESZ_1M, 1), +#endif
diff --git a/boards.cfg b/boards.cfg index efb23e9..55c6aad 100644 --- a/boards.cfg +++ b/boards.cfg @@ -890,9 +890,11 @@ stxssa_4M powerpc mpc85xx stxssa stx T4240QDS powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4240 T4240QDS_SDCARD powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4240,RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 T4240QDS_SPIFLASH powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4240,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 +T4240QDS_SRIO_PCIE_BOOT powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4240,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 T4160QDS powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4160 T4160QDS_SDCARD powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4160,RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 T4160QDS_SPIFLASH powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4160,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 +T4160QDS_SRIO_PCIE_BOOT powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4160,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 B4860QDS powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4860 B4860QDS_NAND powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4860,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 B4860QDS_SPIFLASH powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4860,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index f153dde..e80a757 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -33,6 +33,15 @@ #define CONFIG_PBLRCW_CONFIG $(SRCTREE)/board/freescale/t4qds/t4_rcw.cfg #endif
+#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE +/* Set 1M boot space */ +#define CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR (CONFIG_SYS_TEXT_BASE & 0xfff00000) +#define CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR_PHYS \ + (0x300000000ull | CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR) +#define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc +#define CONFIG_SYS_NO_FLASH +#endif + #define CONFIG_CMD_REGINFO
/* High Level Configuration Options */ @@ -72,14 +81,15 @@ #define CONFIG_ENV_OVERWRITE
#ifdef CONFIG_SYS_NO_FLASH +#if !defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) && !defined(CONFIG_RAMBOOT_PBL) #define CONFIG_ENV_IS_NOWHERE +#endif #else #define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_FLASH_CFI #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE #endif
-#ifndef CONFIG_SYS_NO_FLASH #if defined(CONFIG_SPIFLASH) #define CONFIG_SYS_EXTRA_ENV_RELOC #define CONFIG_ENV_IS_IN_SPI_FLASH @@ -101,18 +111,18 @@ #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_OFFSET (5 * CONFIG_SYS_NAND_BLOCK_SIZE) +#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) +#define CONFIG_ENV_IS_IN_REMOTE +#define CONFIG_ENV_ADDR 0xffe20000 +#define CONFIG_ENV_SIZE 0x2000 +#elif defined(CONFIG_ENV_IS_NOWHERE) +#define CONFIG_ENV_SIZE 0x2000 #else #define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif -#else /* CONFIG_SYS_NO_FLASH */ -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ -#endif - -
#define CONFIG_SYS_CLK_FREQ get_board_sys_clk() #define CONFIG_DDR_CLK_FREQ get_board_ddr_clk() @@ -634,6 +644,16 @@ unsigned long get_board_ddr_clk(void); #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND #define CONFIG_SYS_QE_FMAN_FW_ADDR (6 * CONFIG_SYS_NAND_BLOCK_SIZE) +#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) +/* + * Slave has no ucode locally, it can fetch this from remote. When implementing + * in two corenet boards, slave's ucode could be stored in master's memory + * space, the address can be mapped from slave TLB->slave LAW-> + * slave SRIO or PCIE outbound window->master inbound window-> + * master LAW->the ucode address in master's memory space. + */ +#define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xFFE00000 #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR #define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF40000
Dear York Sun,
In message 1363973369-26110-20-git-send-email-yorksun@freescale.com you wrote:
- Set the boot location to one PCIE or SRIO interface by RCW.
- Set a specific TLB entry for the boot process.
- Set a LAW entry with the TargetID of one PCIE or SRIO for the boot.
- Set a specific TLB entry in order to fetch ucode and ENV from master.
- Set a LAW entry with the TargetID one of the PCIE ports for ucode and ENV.
- Slave's u-boot image should be generated specifically by make xxxx_SRIO_PCIE_BOOT_config. This will set SYS_TEXT_BASE=0xFFF80000 and other configurations.
CHECK: Alignment should match open parenthesis #157: FILE: board/freescale/t4qds/tlb.c:64: + SET_TLB_ENTRY(1, CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR, + CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR_PHYS,
CHECK: Alignment should match open parenthesis #173: FILE: board/freescale/t4qds/tlb.c:148: + SET_TLB_ENTRY(1, CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR, + CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS,
QSGMII card has different PHY address against previous SGMII card. We check the type of card in slots and set correct PHY address to avoid complainning "PHY reset timed out" during u-boot booting up.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- board/freescale/t4qds/eth.c | 19 +++++++++++++++++-- 1 file changed, 17 insertions(+), 2 deletions(-)
diff --git a/board/freescale/t4qds/eth.c b/board/freescale/t4qds/eth.c index ec0afce..316f7dc 100644 --- a/board/freescale/t4qds/eth.c +++ b/board/freescale/t4qds/eth.c @@ -365,24 +365,40 @@ static void initialize_qsgmiiphy_fix(void) qsgmiiphy_fix[FM1_DTSEC6] = 1; qsgmiiphy_fix[FM1_DTSEC9] = 1; qsgmiiphy_fix[FM1_DTSEC10] = 1; + slot_qsgmii_phyaddr[1][0] = SGMII_CARD_PORT1_PHY_ADDR; + slot_qsgmii_phyaddr[1][1] = SGMII_CARD_PORT2_PHY_ADDR; + slot_qsgmii_phyaddr[1][2] = SGMII_CARD_PORT3_PHY_ADDR; + slot_qsgmii_phyaddr[1][3] = SGMII_CARD_PORT4_PHY_ADDR; break; case 2: qsgmiiphy_fix[FM1_DTSEC1] = 1; qsgmiiphy_fix[FM1_DTSEC2] = 1; qsgmiiphy_fix[FM1_DTSEC3] = 1; qsgmiiphy_fix[FM1_DTSEC4] = 1; + slot_qsgmii_phyaddr[2][0] = SGMII_CARD_PORT1_PHY_ADDR; + slot_qsgmii_phyaddr[2][1] = SGMII_CARD_PORT2_PHY_ADDR; + slot_qsgmii_phyaddr[2][2] = SGMII_CARD_PORT3_PHY_ADDR; + slot_qsgmii_phyaddr[2][3] = SGMII_CARD_PORT4_PHY_ADDR; break; case 3: qsgmiiphy_fix[FM2_DTSEC5] = 1; qsgmiiphy_fix[FM2_DTSEC6] = 1; qsgmiiphy_fix[FM2_DTSEC9] = 1; qsgmiiphy_fix[FM2_DTSEC10] = 1; + slot_qsgmii_phyaddr[3][0] = SGMII_CARD_PORT1_PHY_ADDR; + slot_qsgmii_phyaddr[3][1] = SGMII_CARD_PORT2_PHY_ADDR; + slot_qsgmii_phyaddr[3][2] = SGMII_CARD_PORT3_PHY_ADDR; + slot_qsgmii_phyaddr[3][3] = SGMII_CARD_PORT4_PHY_ADDR; break; case 4: qsgmiiphy_fix[FM2_DTSEC1] = 1; qsgmiiphy_fix[FM2_DTSEC2] = 1; qsgmiiphy_fix[FM2_DTSEC3] = 1; qsgmiiphy_fix[FM2_DTSEC4] = 1; + slot_qsgmii_phyaddr[4][0] = SGMII_CARD_PORT1_PHY_ADDR; + slot_qsgmii_phyaddr[4][1] = SGMII_CARD_PORT2_PHY_ADDR; + slot_qsgmii_phyaddr[4][2] = SGMII_CARD_PORT3_PHY_ADDR; + slot_qsgmii_phyaddr[4][3] = SGMII_CARD_PORT4_PHY_ADDR; break; default: break; @@ -435,6 +451,7 @@ int board_eth_init(bd_t *bis) t4240qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT7); t4240qds_mdio_init(DEFAULT_FM_TGEC_MDIO_NAME, EMI2);
+ initialize_qsgmiiphy_fix();
switch (srds_prtcl_s1) { case 1: @@ -702,8 +719,6 @@ int board_eth_init(bd_t *bis) } #endif /* CONFIG_SYS_NUM_FMAN */
- initialize_qsgmiiphy_fix(); - cpu_eth_init(bis); #endif /* CONFIG_FMAN_ENET */
Misalignment will be found in the doc/README.srio-pcie-boot-corenet file when the tabs are set to 8 characters. And the standard for u-boot should be 8 character tabs!
Signed-off-by: Liu Gang Gang.Liu@freescale.com --- doc/README.srio-pcie-boot-corenet | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/doc/README.srio-pcie-boot-corenet b/doc/README.srio-pcie-boot-corenet index cd7e7ee..7e68174 100644 --- a/doc/README.srio-pcie-boot-corenet +++ b/doc/README.srio-pcie-boot-corenet @@ -21,13 +21,13 @@ Environment of the SRIO or PCIE boot: e) Slave's RCW should configure the SerDes for SRIO or PCIE boot port, set the boot location to SRIO or PCIE, and holdoff all the cores.
- ---------- ----------- ----------- - | | | | | | - | | | | | | + ----------- ----------- ----------- + | | | | | | + | | | | | | | NorFlash|<----->| Master |SRIO or PCIE | Slave |<---->[EEPROM] - | | | |<===========>| | - | | | | | | - ---------- ----------- ----------- + | | | |<===========>| | + | | | | | | + ----------- ----------- -----------
The example based on P4080DS platform: Two P4080DS platforms can be used to implement the boot from SRIO or PCIE.
Crossbar switches were wrongly programmed to route the CPRI lanes to SFP as the connectivity table was not correct. Modified it correctly for SFPs connections.
Signed-off-by: Shaveta Leekha shaveta@freescale.com --- board/freescale/b4860qds/b4860qds.c | 6 +++-- board/freescale/b4860qds/b4860qds_crossbar_con.h | 31 +++++++++++++++------- 2 files changed, 25 insertions(+), 12 deletions(-)
diff --git a/board/freescale/b4860qds/b4860qds.c b/board/freescale/b4860qds/b4860qds.c index 41887c2..a39c17a 100644 --- a/board/freescale/b4860qds/b4860qds.c +++ b/board/freescale/b4860qds/b4860qds.c @@ -166,11 +166,13 @@ int configure_vsc3316_3308(void) ret = select_i2c_ch_pca(I2C_CH_VSC3316); if (!ret) { ret = vsc3316_config(VSC3316_TX_ADDRESS, - vsc16_tx_sgmii_lane_ab, num_vsc16_con); + vsc16_tx_4sfp_sgmii_12_56, + num_vsc16_con); if (ret) return ret; ret = vsc3316_config(VSC3316_RX_ADDRESS, - vsc16_rx_sgmii_lane_ab, num_vsc16_con); + vsc16_rx_4sfp_sgmii_12_56, + num_vsc16_con); if (ret) return ret; } else { diff --git a/board/freescale/b4860qds/b4860qds_crossbar_con.h b/board/freescale/b4860qds/b4860qds_crossbar_con.h index 994dec5..c2b6c44 100644 --- a/board/freescale/b4860qds/b4860qds_crossbar_con.h +++ b/board/freescale/b4860qds/b4860qds_crossbar_con.h @@ -26,42 +26,53 @@ static const int8_t vsc16_tx_amc[8][2] = { {15, 3}, {0, 2}, {7, 4}, {9, 10}, {5, 11}, {4, 5}, {2, 6}, {12, 9} };
-static const int8_t vsc16_tx_sfp[8][2] = { {15, 8}, {0, 0}, {7, 7}, {9, 1}, - {5, 15}, {4, 14}, {2, 12}, {12, 13} }; +static const int8_t vsc16_tx_sfp[8][2] = { {15, 7}, {0, 1}, {7, 8}, {9, 0}, + {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1} };
-static const int8_t vsc16_tx_sgmii_lane_ab[8][2] = { {2, 14}, {12, 15}, - {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1} }; +static const int8_t vsc16_tx_4sfp_sgmii_12_56[8][2] = { {15, 7}, {0, 1}, + {7, 8}, {9, 0}, {2, 14}, {12, 15}, + {-1, -1}, {-1, -1} }; + +static const int8_t vsc16_tx_4sfp_sgmii_34[8][2] = { {15, 7}, {0, 1}, + {7, 8}, {9, 0}, {5, 14}, {4, 15}, + {-1, -1}, {-1, -1} };
#ifdef CONFIG_PPC_B4420 static const int8_t vsc16_tx_sgmii_lane_cd[8][2] = { {5, 14}, {4, 15}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1} }; #endif + static const int8_t vsc16_tx_aurora[8][2] = { {2, 13}, {12, 12}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1} };
static const int8_t vsc16_rx_amc[8][2] = { {3, 15}, {2, 1}, {4, 8}, {10, 9}, {11, 11}, {5, 10}, {6, 3}, {9, 12} };
-static const int8_t vsc16_rx_sfp[8][2] = { {0, 15}, {8, 1}, {1, 8}, {7, 9}, +static const int8_t vsc16_rx_sfp[8][2] = { {8, 15}, {0, 1}, {7, 8}, {1, 9}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1} };
-static const int8_t vsc16_rx_sgmii_lane_ab[8][2] = { {14, 3}, {15, 12}, - {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1} }; +static const int8_t vsc16_rx_4sfp_sgmii_12_56[8][2] = { {8, 15}, {0, 1}, + {7, 8}, {1, 9}, {14, 3}, {15, 12}, + {-1, -1}, {-1, -1} }; + +static const int8_t vsc16_rx_4sfp_sgmii_34[8][2] = { {8, 15}, {0, 1}, + {7, 8}, {1, 9}, {14, 11}, {15, 10}, + {-1, -1}, {-1, -1} };
#ifdef CONFIG_PPC_B4420 static const int8_t vsc16_rx_sgmii_lane_cd[8][2] = { {14, 11}, {15, 10}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1} }; #endif
-static const int8_t vsc16_rx_aurora[8][2] = { {12, 3}, {13, 12}, {-1, -1}, +static const int8_t vsc16_rx_aurora[8][2] = { {13, 3}, {12, 12}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1} };
static const int8_t vsc08_tx_amc[4][2] = { {2, 2}, {3, 3}, {7, 4}, {1, 5} };
-static const int8_t vsc08_tx_sfp[4][2] = { {2, 6}, {3, 7}, {7, 1}, {1, 0} }; +static const int8_t vsc08_tx_sfp[4][2] = { {2, 1}, {3, 0}, {7, 6}, {1, 7} };
static const int8_t vsc08_rx_amc[4][2] = { {2, 3}, {3, 4}, {4, 7}, {5, 1} };
-static const int8_t vsc08_rx_sfp[4][2] = { {6, 3}, {7, 4}, {1, 7}, {0, 1} }; +static const int8_t vsc08_rx_sfp[4][2] = { {1, 3}, {0, 4}, {6, 7}, {7, 1} };
#endif
Set the device tree property associated with the mpic source frequency. The frequency is used for mpic timer. the mpic timer use CCB/2 frequency on freescale corenet platform, other freescale platform use CCB frequency.
Signed-off-by: Wang Dongsheng dongsheng.wang@freescale.com --- arch/powerpc/cpu/mpc85xx/fdt.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/powerpc/cpu/mpc85xx/fdt.c b/arch/powerpc/cpu/mpc85xx/fdt.c index cda6ad6..288f7b2 100644 --- a/arch/powerpc/cpu/mpc85xx/fdt.c +++ b/arch/powerpc/cpu/mpc85xx/fdt.c @@ -665,6 +665,11 @@ void ft_cpu_setup(void *blob, bd_t *bd) "clock-frequency", CONFIG_SYS_CLK_FREQ, 1); do_fixup_by_compat_u32(blob, "fsl,qoriq-clockgen-2", "clock-frequency", CONFIG_SYS_CLK_FREQ, 1); + do_fixup_by_compat_u32(blob, "fsl,mpic", + "clock-frequency", get_bus_freq(0)/2, 1); +#else + do_fixup_by_compat_u32(blob, "fsl,mpic", + "clock-frequency", get_bus_freq(0), 1); #endif
fdt_fixup_memory(blob, (u64)bd->bi_memstart, (u64)bd->bi_memsize);
Dear York Sun,
In message 1363973369-26110-24-git-send-email-yorksun@freescale.com you wrote:
CHECK: Alignment should match open parenthesis #128: FILE: arch/powerpc/cpu/mpc85xx/fdt.c:669: + do_fixup_by_compat_u32(blob, "fsl,mpic", + "clock-frequency", get_bus_freq(0)/2, 1);
CHECK: Alignment should match open parenthesis #131: FILE: arch/powerpc/cpu/mpc85xx/fdt.c:672: + do_fixup_by_compat_u32(blob, "fsl,mpic", + "clock-frequency", get_bus_freq(0), 1);
PC board has different serdes clock setting with PB board, it uses same serdes frequency setting on bank2 as on bank1. PC board can be distingushed from PB board by checking CPLD version, if running on PC board, then fix the serdes reference clock frequency of bank2.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com --- board/freescale/p2041rdb/p2041rdb.c | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/board/freescale/p2041rdb/p2041rdb.c b/board/freescale/p2041rdb/p2041rdb.c index a706a6d..9352fab 100644 --- a/board/freescale/p2041rdb/p2041rdb.c +++ b/board/freescale/p2041rdb/p2041rdb.c @@ -227,6 +227,17 @@ int misc_init_r(void) "'00' is unsupported\n"); else actual[i] = freq[i][clock]; + + /* + * PC board uses a different CPLD with PB board, this CPLD + * has cpld_ver_sub = 1, and pcba_ver = 5. But CPLD on PB + * board has cpld_ver_sub = 0, and pcba_ver = 4. + */ + if ((i == 1) && (CPLD_READ(cpld_ver_sub) == 1) + && (CPLD_READ(pcba_ver) == 5)) { + /* PC board bank2 frequency */ + actual[i] = freq[i-1][clock]; + } }
for (i = 0; i < NUM_SRDS_BANKS; i++) {
Dear York Sun,
In message 1363973369-26110-25-git-send-email-yorksun@freescale.com you wrote:
CHECK: Logical continuations should be on the previous line #134: FILE: board/freescale/p2041rdb/p2041rdb.c:237: + if ((i == 1) && (CPLD_READ(cpld_ver_sub) == 1) + && (CPLD_READ(pcba_ver) == 5)) {
SPANSION recommend S25FL128S supersedes S25FL129P, and the two flash memory have the same device ID and Memory architecture. So they can use the same config parameters.
Signed-off-by: Xie Xiaobo X.Xie@freescale.com --- drivers/mtd/spi/spansion.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/spansion.c b/drivers/mtd/spi/spansion.c index 9288672..a2bfd86 100644 --- a/drivers/mtd/spi/spansion.c +++ b/drivers/mtd/spi/spansion.c @@ -94,7 +94,7 @@ static const struct spansion_spi_flash_params spansion_spi_flash_table[] = { .idcode2 = 0x4d01, .pages_per_sector = 256, .nr_sectors = 256, - .name = "S25FL129P_64K", + .name = "S25FL129P_64K/S25FL128S", }, { .idcode1 = 0x0219,
B4420 is a subset of B4860. Merge them in config_mpc85xx.h to simplify the defines. - Removed #define CONFIG_SYS_FSL_NUM_CLUSTERS as this is used nowhere. - defined CONFIG_SYS_NUM_FM1_10GEC to 0 for B4420 as it does not have 10G.
Also move CONFIG_E6500 out of B4860QDSds.h into config_mpc85xx.h.
Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com --- arch/powerpc/include/asm/config_mpc85xx.h | 36 ++++++++++------------------- include/configs/B4860QDS.h | 1 - 2 files changed, 12 insertions(+), 25 deletions(-)
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index e92cdb9..51395dd 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -555,22 +555,18 @@ #define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 #define CONFIG_SYS_FSL_PCI_VER_3_X
-#elif defined(CONFIG_PPC_B4420) +#elif defined(CONFIG_PPC_B4860) || defined(CONFIG_PPC_B4420) +#define CONFIG_E6500 #define CONFIG_SYS_PPC64 /* 64-bit core */ #define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_SYS_FSL_QORIQ_CHASSIS2 /* Freescale Chassis generation 2 */ -#define CONFIG_SYS_FSL_CORES_PER_CLUSTER 4 #define CONFIG_SYS_FSL_QMAN_V3 /* QMAN version 3 */ -#define CONFIG_MAX_CPUS 2 -#define CONFIG_SYS_FSL_NUM_CC_PLLS 4 #define CONFIG_SYS_FSL_NUM_LAWS 32 #define CONFIG_SYS_FSL_SEC_COMPAT 4 #define CONFIG_SYS_NUM_FMAN 1 -#define CONFIG_SYS_NUM_FM1_DTSEC 4 -#define CONFIG_NUM_DDR_CONTROLLERS 1 #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_7 -#define CONFIG_SYS_FSL_IFC_BANK_COUNT 4 #define CONFIG_SYS_FMAN_V3 +#define CONFIG_SYS_FSL_IFC_BANK_COUNT 4 #define CONFIG_SYS_FM_MURAM_SIZE 0x60000 #define CONFIG_SYS_FSL_TBCLK_DIV 16 #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.4" @@ -578,32 +574,24 @@ #define CONFIG_SYS_FSL_ERRATUM_A_004934 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000
-#elif defined(CONFIG_PPC_B4860) -#define CONFIG_SYS_PPC64 /* 64-bit core */ -#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ -#define CONFIG_SYS_FSL_QORIQ_CHASSIS2 /* Freescale Chassis generation 2 */ +#ifdef CONFIG_PPC_B4860 #define CONFIG_SYS_FSL_CORES_PER_CLUSTER 4 -#define CONFIG_SYS_FSL_QMAN_V3 /* QMAN version 3 */ #define CONFIG_MAX_CPUS 4 #define CONFIG_SYS_FSL_NUM_CC_PLLS 4 -#define CONFIG_SYS_FSL_NUM_LAWS 32 -#define CONFIG_SYS_FSL_SEC_COMPAT 4 -#define CONFIG_SYS_NUM_FMAN 1 #define CONFIG_SYS_NUM_FM1_DTSEC 6 #define CONFIG_SYS_NUM_FM1_10GEC 2 #define CONFIG_NUM_DDR_CONTROLLERS 2 -#define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_7 -#define CONFIG_SYS_FSL_IFC_BANK_COUNT 4 -#define CONFIG_SYS_FMAN_V3 -#define CONFIG_SYS_FM_MURAM_SIZE 0x60000 -#define CONFIG_SYS_FSL_TBCLK_DIV 16 -#define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.4" #define CONFIG_SYS_FSL_SRIO_MAX_PORTS 2 #define CONFIG_SYS_FSL_SRIO_OB_WIN_NUM 9 #define CONFIG_SYS_FSL_SRIO_IB_WIN_NUM 5 -#define CONFIG_SYS_FSL_USB1_PHY_ENABLE -#define CONFIG_SYS_FSL_ERRATUM_A_004934 -#define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 +#else +#define CONFIG_MAX_CPUS 2 +#define CONFIG_SYS_FSL_CORES_PER_CLUSTER 2 +#define CONFIG_SYS_FSL_NUM_CC_PLLS 4 +#define CONFIG_SYS_NUM_FM1_DTSEC 4 +#define CONFIG_SYS_NUM_FM1_10GEC 0 +#define CONFIG_NUM_DDR_CONTROLLERS 1 +#endif
#elif defined(CONFIG_PPC_T1040) #define CONFIG_E5500 diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 22cd808..e871a70 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -45,7 +45,6 @@
/* High Level Configuration Options */ #define CONFIG_BOOKE -#define CONFIG_E6500 #define CONFIG_E500 /* BOOKE e500 family */ #define CONFIG_E500MC /* BOOKE e500mc family */ #define CONFIG_SYS_BOOK3E_HV /* Category E.HV supported */
Current driver of p5040 assumes 10G port follows 1G port DTSEC5 in eth port enum structure, it will assign mdio mux depend on this assumption. This is not true with Fman V3, which added more 1G ports after port DTSEC5 in eth port enum structure, then 10G ports on p5040 will have wrong mdio mux. So we use dynamic index for 10G ports instead of hardcoded enum value when doing mdio mux for 10G ports.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com --- board/freescale/corenet_ds/eth_superhydra.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/board/freescale/corenet_ds/eth_superhydra.c b/board/freescale/corenet_ds/eth_superhydra.c index ef9de25..ae07073 100644 --- a/board/freescale/corenet_ds/eth_superhydra.c +++ b/board/freescale/corenet_ds/eth_superhydra.c @@ -605,8 +605,8 @@ int board_eth_init(bd_t *bis) lane = serdes_get_first_lane(XAUI_FM1); if (lane >= 0) { debug("FM1@TGEC1 expects XAUI in slot %u\n", lane_to_slot[lane]); - mdio_mux[FM1_10GEC1].mask = BRDCFG1_EMI2_SEL_MASK; - mdio_mux[FM1_10GEC1].val = BRDCFG1_EMI2_SEL_SLOT2; + mdio_mux[i].mask = BRDCFG1_EMI2_SEL_MASK; + mdio_mux[i].val = BRDCFG1_EMI2_SEL_SLOT2; super_hydra_mdio_set_mux("SUPER_HYDRA_FM1_TGEC_MDIO", mdio_mux[i].mask, mdio_mux[i].val); } @@ -704,8 +704,8 @@ int board_eth_init(bd_t *bis) lane = serdes_get_first_lane(XAUI_FM2); if (lane >= 0) { debug("FM2@TGEC1 expects XAUI in slot %u\n", lane_to_slot[lane]); - mdio_mux[FM2_10GEC1].mask = BRDCFG1_EMI2_SEL_MASK; - mdio_mux[FM2_10GEC1].val = BRDCFG1_EMI2_SEL_SLOT1; + mdio_mux[i].mask = BRDCFG1_EMI2_SEL_MASK; + mdio_mux[i].val = BRDCFG1_EMI2_SEL_SLOT1; super_hydra_mdio_set_mux("SUPER_HYDRA_FM2_TGEC_MDIO", mdio_mux[i].mask, mdio_mux[i].val); }
From: Ramneek Mehresh ramneek.mehresh@freescale.com
Fix USB device-tree fixup to properly handle device-tree fixup and print appropriate message when wrong/junk "dr_mode" or "phy_type" are mentioned in hwconfig string
Signed-off-by: Ramneek Mehresh ramneek.mehresh@freescale.com --- arch/powerpc/cpu/mpc8xxx/fdt.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/powerpc/cpu/mpc8xxx/fdt.c b/arch/powerpc/cpu/mpc8xxx/fdt.c index 2847094..413e184 100644 --- a/arch/powerpc/cpu/mpc8xxx/fdt.c +++ b/arch/powerpc/cpu/mpc8xxx/fdt.c @@ -167,6 +167,12 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd) } }
+ if (mode_idx < 0 || phy_idx < 0) { + printf("WARNING: wrong usb mode/phy" + " defined!!\n"); + return; + } + dr_mode_type = modes[mode_idx]; dr_phy_type = phys[phy_idx];
Dear York Sun,
In message 1363973369-26110-29-git-send-email-yorksun@freescale.com you wrote:
WARNING: quoted string split across lines #126: FILE: arch/powerpc/cpu/mpc8xxx/fdt.c:172: + printf("WARNING: wrong usb mode/phy" + " defined!!\n");
Some legacy RGMII phys don't have in band signaling for the speed information. so set the RGMII MAC mode according to the speed got from PHY.
Signed-off-by: Roy Zang tie-fei.zang@freescale.com Reported-by: John Traill john.traill@freescale.com --- arch/powerpc/include/asm/fsl_memac.h | 4 ++++ drivers/net/fm/memac.c | 15 +++++++++++++++ 2 files changed, 19 insertions(+)
diff --git a/arch/powerpc/include/asm/fsl_memac.h b/arch/powerpc/include/asm/fsl_memac.h index d6b60e6..69f95d1 100644 --- a/arch/powerpc/include/asm/fsl_memac.h +++ b/arch/powerpc/include/asm/fsl_memac.h @@ -222,6 +222,10 @@ struct memac {
/* IF_MODE - Interface Mode Register */ #define IF_MODE_EN_AUTO 0x00008000 /* 1 - Enable automatic speed selection */ +#define IF_MODE_SETSP_100M 0x00000000 /* 00 - 100Mbps RGMII */ +#define IF_MODE_SETSP_10M 0x00002000 /* 01 - 10Mbps RGMII */ +#define IF_MODE_SETSP_1000M 0x00004000 /* 10 - 1000Mbps RGMII */ +#define IF_MODE_SETSP_MASK 0x00006000 /* setsp mask bits */ #define IF_MODE_XGMII 0x00000000 /* 00- XGMII(10) interface mode */ #define IF_MODE_GMII 0x00000002 /* 10- GMII interface mode */ #define IF_MODE_MASK 0x00000003 /* mask for mode interface mode */ diff --git a/drivers/net/fm/memac.c b/drivers/net/fm/memac.c index 32c7054..fa14113 100644 --- a/drivers/net/fm/memac.c +++ b/drivers/net/fm/memac.c @@ -112,6 +112,21 @@ static void memac_set_interface_mode(struct fsl_enet_mac *mac, /* Enable automatic speed selection */ if_mode |= IF_MODE_EN_AUTO;
+ if (type == PHY_INTERFACE_MODE_RGMII) { + if_mode &= ~IF_MODE_EN_AUTO; + if_mode &= ~IF_MODE_SETSP_MASK; + switch (speed) { + case SPEED_1000: + if_mode |= IF_MODE_SETSP_1000M; + case SPEED_100: + if_mode |= IF_MODE_SETSP_100M; + case SPEED_10: + if_mode |= IF_MODE_SETSP_10M; + default: + break; + } + } + debug(" %s, if_mode = %x\n", __func__, if_mode); debug(" %s, if_status = %x\n", __func__, if_status); out_be32(®s->if_mode, if_mode);
Signed-off-by: Shaveta Leekha shaveta@freescale.com --- arch/powerpc/include/asm/fsl_law.h | 2 ++ board/freescale/b4860qds/law.c | 3 +++ include/configs/B4860QDS.h | 9 +++++++++ 3 files changed, 14 insertions(+)
diff --git a/arch/powerpc/include/asm/fsl_law.h b/arch/powerpc/include/asm/fsl_law.h index f9cec8e..90b264d 100644 --- a/arch/powerpc/include/asm/fsl_law.h +++ b/arch/powerpc/include/asm/fsl_law.h @@ -70,6 +70,8 @@ enum law_trgt_if { LAW_TRGT_IF_DCSR = 0x1d, LAW_TRGT_IF_LBC = 0x1f, LAW_TRGT_IF_QMAN = 0x3c, + + LAW_TRGT_IF_MAPLE = 0x50, }; #define LAW_TRGT_IF_DDR LAW_TRGT_IF_DDR_1 #define LAW_TRGT_IF_IFC LAW_TRGT_IF_LBC diff --git a/board/freescale/b4860qds/law.c b/board/freescale/b4860qds/law.c index abaad7a..b26725b 100644 --- a/board/freescale/b4860qds/law.c +++ b/board/freescale/b4860qds/law.c @@ -33,6 +33,9 @@ struct law_entry law_table[] = { SET_LAW(CONFIG_SYS_QMAN_MEM_PHYS, LAW_SIZE_32M, LAW_TRGT_IF_QMAN), #endif SET_LAW(QIXIS_BASE_PHYS, LAW_SIZE_4K, LAW_TRGT_IF_IFC), +#ifdef CONFIG_SYS_MAPLE_MEM_PHYS + SET_LAW(CONFIG_SYS_MAPLE_MEM_PHYS, LAW_SIZE_16M, LAW_TRGT_IF_MAPLE), +#endif #ifdef CONFIG_SYS_DCSRBAR_PHYS /* Limit DCSR to 32M to access NPC Trace Buffer */ SET_LAW(CONFIG_SYS_DCSRBAR_PHYS, LAW_SIZE_32M, LAW_TRGT_IF_DCSR), diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index e871a70..c745fac 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -540,6 +540,15 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SF_DEFAULT_MODE 0
/* + * MAPLE + */ +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_MAPLE_MEM_PHYS 0xFA0000000ull +#else +#define CONFIG_SYS_MAPLE_MEM_PHYS 0xA0000000 +#endif + +/* * General PCI * Memory space is mapped 1-1, but I/O space must start from 0. */
York Sun
