[U-Boot] [PATCH 1/2] mx31: Fix boot hang by avoiding vector relocation
Since commit 3ff46cc42b9d73d0 ("arm: relocate the exception vectors") mx31 does not boot anymore.
Add a specific relocate_vectors macro that skips the vector relocation, as the i.MX31 SoC does not provide RAM at the high vectors address (0xFFFF0000), and (0x00000000) maps to ROM.
This allows mx31 to boot again.
Cc: Anatolij Gustschin agust@denx.de Cc: Magnus Lilja lilja.magnus@gmail.com Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Anatolij/Maguns,
I don't have access to a mx31 board.
Could you please test this patch?
Thanks
arch/arm/cpu/arm1136/mx31/Makefile | 4 ++++ arch/arm/cpu/arm1136/mx31/relocate.S | 23 +++++++++++++++++++++++ 2 files changed, 27 insertions(+) create mode 100644 arch/arm/cpu/arm1136/mx31/relocate.S
diff --git a/arch/arm/cpu/arm1136/mx31/Makefile b/arch/arm/cpu/arm1136/mx31/Makefile index 9670ed9..dcbd570 100644 --- a/arch/arm/cpu/arm1136/mx31/Makefile +++ b/arch/arm/cpu/arm1136/mx31/Makefile @@ -8,3 +8,7 @@ obj-y += generic.o obj-y += timer.o obj-y += devices.o + +ifndef CONFIG_SPL_BUILD +obj-y += relocate.o +endif diff --git a/arch/arm/cpu/arm1136/mx31/relocate.S b/arch/arm/cpu/arm1136/mx31/relocate.S new file mode 100644 index 0000000..1c556df --- /dev/null +++ b/arch/arm/cpu/arm1136/mx31/relocate.S @@ -0,0 +1,23 @@ +/* + * relocate - i.MX31-specific vector relocation + * + * Copyright (c) 2013 Albert ARIBAUD albert.u.boot@aribaud.net + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <linux/linkage.h> + +/* + * The i.MX31 SoC is very specific with respect to exceptions: it + * does not provide RAM at the high vectors address (0xFFFF0000), + * thus only the low address (0x00000000) is useable; but that is + * in ROM, so let's avoid relocating the vectors. + */ + .section .text.relocate_vectors,"ax",%progbits + +ENTRY(relocate_vectors) + + bx lr + +ENDPROC(relocate_vectors)
Since commit 3ff46cc42b9d73d0 ("arm: relocate the exception vectors") mx35 does not boot anymore.
Add a specific relocate_vectors macro that skips the vector relocation, as the i.MX35 SoC does not provide RAM at the high vectors address (0xFFFF0000), and (0x00000000) maps to ROM.
This allows mx35 to boot again.
Cc: Sebastian Priebe sebastian.priebe@cadcon.de Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Sebastian,
I don't have access to a mx35 board.
Thanks
arch/arm/cpu/arm1136/mx35/Makefile | 4 ++++ arch/arm/cpu/arm1136/mx35/relocate.S | 23 +++++++++++++++++++++++ 2 files changed, 27 insertions(+) create mode 100644 arch/arm/cpu/arm1136/mx35/relocate.S
diff --git a/arch/arm/cpu/arm1136/mx35/Makefile b/arch/arm/cpu/arm1136/mx35/Makefile index c533215..796db9c 100644 --- a/arch/arm/cpu/arm1136/mx35/Makefile +++ b/arch/arm/cpu/arm1136/mx35/Makefile @@ -10,3 +10,7 @@ obj-y += generic.o obj-y += timer.o obj-y += mx35_sdram.o + +ifndef CONFIG_SPL_BUILD +obj-y += relocate.o +endif diff --git a/arch/arm/cpu/arm1136/mx35/relocate.S b/arch/arm/cpu/arm1136/mx35/relocate.S new file mode 100644 index 0000000..43003f8 --- /dev/null +++ b/arch/arm/cpu/arm1136/mx35/relocate.S @@ -0,0 +1,23 @@ +/* + * relocate - i.MX35-specific vector relocation + * + * Copyright (c) 2013 Albert ARIBAUD albert.u.boot@aribaud.net + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <linux/linkage.h> + +/* + * The i.MX35 SoC is very specific with respect to exceptions: it + * does not provide RAM at the high vectors address (0xFFFF0000), + * thus only the low address (0x00000000) is useable; but that is + * in ROM, so let's avoid relocating the vectors. + */ + .section .text.relocate_vectors,"ax",%progbits + +ENTRY(relocate_vectors) + + bx lr + +ENDPROC(relocate_vectors)
Hi Fabio,
Sebastian,
Thanks
Thanks for the patch !
I have found again a mx35pdk and I could test your patch. 2015.04-rc1 is running on that.
Tested-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Hi Fabio,
On Mon, 23 Feb 2015 09:09:08 -0300 Fabio Estevam fabio.estevam@freescale.com wrote:
Anatolij/Maguns,
Thanks for the patch! I'll get access to the imx31_phycore board at the beginning of the next week and will test it. Unfortunately I can't test it earlier.
Thanks,
Anatolij
Hi
On 23 February 2015 at 14:03, Anatolij Gustschin agust@denx.de wrote:
Hi Fabio,
Anatolij/Maguns,
I might get around to test it before that but I can't promise that.
Regards, Magnus
Hi Fabio, Magnus, Anatolji, Sebastian,
As boards are currently broken, I think can help if patches are merged even if they are not fully tested. I could at least test on a mx35, and board boots again.
Anatolij Gustschin
Fabio Estevam
Magnus Lilja
Stefano Babic
