[PATCH v2 0/3] Xilinx SPI driver enhancements
This series makes the Xilinx XPS SPI driver compatible with the MMC_SPI driver and also includes an enhacement from the corresponding Linux driver.
Changes in v2: - Improve comment and add reviewed-by tag in patch 3
Mayuresh Chitale (3): drivers: xilinx_spi: Use udevice in start_tranfer drivers: xilinx_spi: Add xfer callback drivers: xilinx_spi: Probe fifo_depth at runtime
drivers/spi/xilinx_spi.c | 68 ++++++++++++++++++++++++++++++---------- 1 file changed, 52 insertions(+), 16 deletions(-)
Modify start_transfer and related functions to take a udevice parameter as input instead of spi_slave. This is needed so that start_transfer can be used directly via the xfer callback. Also fix a compiler warning.
Signed-off-by: Mayuresh Chitale mchitale@ventanamicro.com --- drivers/spi/xilinx_spi.c | 32 ++++++++++++++++---------------- 1 file changed, 16 insertions(+), 16 deletions(-)
diff --git a/drivers/spi/xilinx_spi.c b/drivers/spi/xilinx_spi.c index b58a3f632a..d9faceec18 100644 --- a/drivers/spi/xilinx_spi.c +++ b/drivers/spi/xilinx_spi.c @@ -67,7 +67,7 @@ /* SPI Slave Select Register (spissr), [1] p13, [2] p13 */ #define SPISSR_MASK(cs) (1 << (cs)) #define SPISSR_ACT(cs) ~SPISSR_MASK(cs) -#define SPISSR_OFF ~0UL +#define SPISSR_OFF (~0U)
/* SPI Software Reset Register (ssr) */ #define SPISSR_RESET_VALUE 0x0a @@ -217,9 +217,9 @@ static u32 xilinx_spi_read_rxfifo(struct udevice *bus, u8 *rxp, u32 rxbytes) return i; }
-static int start_transfer(struct spi_slave *spi, const void *dout, void *din, u32 len) +static int start_transfer(struct udevice *dev, const void *dout, void *din, u32 len) { - struct udevice *bus = spi->dev->parent; + struct udevice *bus = dev->parent; struct xilinx_spi_priv *priv = dev_get_priv(bus); struct xilinx_spi_regs *regs = priv->regs; u32 count, txbytes, rxbytes; @@ -259,10 +259,9 @@ static int start_transfer(struct spi_slave *spi, const void *dout, void *din, u3 return 0; }
-static void xilinx_spi_startup_block(struct spi_slave *spi) +static void xilinx_spi_startup_block(struct udevice *dev) { - struct dm_spi_slave_plat *slave_plat = - dev_get_parent_plat(spi->dev); + struct dm_spi_slave_plat *slave_plat = dev_get_parent_plat(dev); unsigned char txp; unsigned char rxp[8];
@@ -270,13 +269,13 @@ static void xilinx_spi_startup_block(struct spi_slave *spi) * Perform a dummy read as a work around for * the startup block issue. */ - spi_cs_activate(spi->dev, slave_plat->cs); + spi_cs_activate(dev, slave_plat->cs); txp = 0x9f; - start_transfer(spi, (void *)&txp, NULL, 1); + start_transfer(dev, (void *)&txp, NULL, 1);
- start_transfer(spi, NULL, (void *)rxp, 6); + start_transfer(dev, NULL, (void *)rxp, 6);
- spi_cs_deactivate(spi->dev); + spi_cs_deactivate(dev); }
static int xilinx_spi_mem_exec_op(struct spi_slave *spi, @@ -294,14 +293,15 @@ static int xilinx_spi_mem_exec_op(struct spi_slave *spi, * as QSPI provides command. So first command fails. */ if (!startup) { - xilinx_spi_startup_block(spi); + xilinx_spi_startup_block(spi->dev); startup++; }
if (op->cmd.opcode) { - ret = start_transfer(spi, (void *)&op->cmd.opcode, NULL, 1); + ret = start_transfer(spi->dev, (void *)&op->cmd.opcode, + NULL, 1); if (ret) goto done; } @@ -313,7 +313,7 @@ static int xilinx_spi_mem_exec_op(struct spi_slave *spi, addr_buf[i] = op->addr.val >> (8 * (op->addr.nbytes - i - 1));
- ret = start_transfer(spi, (void *)addr_buf, NULL, + ret = start_transfer(spi->dev, (void *)addr_buf, NULL, op->addr.nbytes); if (ret) goto done; @@ -322,16 +322,16 @@ static int xilinx_spi_mem_exec_op(struct spi_slave *spi, dummy_len = (op->dummy.nbytes * op->data.buswidth) / op->dummy.buswidth;
- ret = start_transfer(spi, NULL, NULL, dummy_len); + ret = start_transfer(spi->dev, NULL, NULL, dummy_len); if (ret) goto done; } if (op->data.nbytes) { if (op->data.dir == SPI_MEM_DATA_IN) { - ret = start_transfer(spi, NULL, + ret = start_transfer(spi->dev, NULL, op->data.buf.in, op->data.nbytes); } else { - ret = start_transfer(spi, op->data.buf.out, + ret = start_transfer(spi->dev, op->data.buf.out, NULL, op->data.nbytes); } if (ret)
Add the xfer callback which is used by the MMC_SPI driver and generally by the dm_spi_xfer callback.
Signed-off-by: Mayuresh Chitale mchitale@ventanamicro.com --- drivers/spi/xilinx_spi.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/drivers/spi/xilinx_spi.c b/drivers/spi/xilinx_spi.c index d9faceec18..b63cda2091 100644 --- a/drivers/spi/xilinx_spi.c +++ b/drivers/spi/xilinx_spi.c @@ -278,6 +278,18 @@ static void xilinx_spi_startup_block(struct udevice *dev) spi_cs_deactivate(dev); }
+static int xilinx_spi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct dm_spi_slave_plat *slave_plat = dev_get_parent_plat(dev); + int ret; + + spi_cs_activate(dev, slave_plat->cs); + ret = start_transfer(dev, dout, din, bitlen / 8); + spi_cs_deactivate(dev); + return ret; +} + static int xilinx_spi_mem_exec_op(struct spi_slave *spi, const struct spi_mem_op *op) { @@ -427,6 +439,7 @@ static const struct spi_controller_mem_ops xilinx_spi_mem_ops = { static const struct dm_spi_ops xilinx_spi_ops = { .claim_bus = xilinx_spi_claim_bus, .release_bus = xilinx_spi_release_bus, + .xfer = xilinx_spi_xfer, .set_speed = xilinx_spi_set_speed, .set_mode = xilinx_spi_set_mode, .mem_ops = &xilinx_spi_mem_ops,
If the fifo-size DT parameter is not provided then probe the controller's fifo depth at runtime. This is ported from a patch in the Linux Xilinx SPI driver.
Signed-off-by: Mayuresh Chitale mchitale@ventanamicro.com Reviewed-by: Michal Simek michal.simek@amd.com Link: https://lore.kernel.org/r/1422029330-10971-5-git-send-email-ricardo.ribalda@... --- drivers/spi/xilinx_spi.c | 23 +++++++++++++++++++++++ 1 file changed, 23 insertions(+)
diff --git a/drivers/spi/xilinx_spi.c b/drivers/spi/xilinx_spi.c index b63cda2091..94ddf4967e 100644 --- a/drivers/spi/xilinx_spi.c +++ b/drivers/spi/xilinx_spi.c @@ -109,6 +109,27 @@ struct xilinx_spi_priv { u8 startup; };
+static int xilinx_spi_find_buffer_size(struct xilinx_spi_regs *regs) +{ + u8 sr; + int n_words = 0; + + /* + * Before the buffer_size detection reset the core + * to make sure to start with a clean state. + */ + writel(SPISSR_RESET_VALUE, ®s->srr); + + /* Fill the Tx FIFO with as many words as possible */ + do { + writel(0, ®s->spidtr); + sr = readl(®s->spisr); + n_words++; + } while (!(sr & SPISR_TX_FULL)); + + return n_words; +} + static int xilinx_spi_probe(struct udevice *bus) { struct xilinx_spi_priv *priv = dev_get_priv(bus); @@ -116,6 +137,8 @@ static int xilinx_spi_probe(struct udevice *bus)
regs = priv->regs = dev_read_addr_ptr(bus); priv->fifo_depth = dev_read_u32_default(bus, "fifo-size", 0); + if (!priv->fifo_depth) + priv->fifo_depth = xilinx_spi_find_buffer_size(regs);
+Love
Changes in v2:
-----Original Message----- From: Simek, Michal michal.simek@amd.com Sent: 29 November 2023 13:55 To: Mayuresh Chitale mchitale@ventanamicro.com; Jagan Teki jagan@amarulasolutions.com; Kumar, Love love.kumar@amd.com Cc: u-boot@lists.denx.de; Simon Glass sjg@chromium.org; Tom Rini trini@konsulko.com Subject: Re: [PATCH v2 0/3] Xilinx SPI driver enhancements
+Love
driver.
Changes in v2:
Tested-by: Love Kumar love.kumar@amd.com
Changes in v2:
Applied. M
Kumar, Love
Mayuresh Chitale
Michal Simek
