[PATCH 1/2] mmc: Check support for TRIM operations
When secure/insecure TRIM operations are supported. When used as erase command argument it applies the erase operation to write blocks instead of erase groups.
Signed-off-by: Loic Poulain loic.poulain@linaro.org --- drivers/mmc/mmc.c | 3 +++ include/mmc.h | 4 ++++ 2 files changed, 7 insertions(+)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 210703ea46..e5f5ccb5f4 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -2432,6 +2432,9 @@ static int mmc_startup_v4(struct mmc *mmc)
mmc->wr_rel_set = ext_csd[EXT_CSD_WR_REL_SET];
+ mmc->can_trim = + !!(ext_csd[EXT_CSD_SEC_FEATURE] & EXT_CSD_SEC_FEATURE_TRIM_EN); + return 0; error: if (mmc->ext_csd) { diff --git a/include/mmc.h b/include/mmc.h index 571fa625d0..f6e23625ca 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -241,6 +241,7 @@ static inline bool mmc_is_tuning_cmd(uint cmdidx) #define EXT_CSD_HC_WP_GRP_SIZE 221 /* RO */ #define EXT_CSD_HC_ERASE_GRP_SIZE 224 /* RO */ #define EXT_CSD_BOOT_MULT 226 /* RO */ +#define EXT_CSD_SEC_FEATURE 231 /* RO */ #define EXT_CSD_GENERIC_CMD6_TIME 248 /* RO */ #define EXT_CSD_BKOPS_SUPPORT 502 /* RO */
@@ -315,6 +316,8 @@ static inline bool mmc_is_tuning_cmd(uint cmdidx) #define EXT_CSD_WR_DATA_REL_USR (1 << 0) /* user data area WR_REL */ #define EXT_CSD_WR_DATA_REL_GP(x) (1 << ((x)+1)) /* GP part (x+1) WR_REL */
+#define EXT_CSD_SEC_FEATURE_TRIM_EN (1 << 4) /* Support secure & insecure trim */ + #define R1_ILLEGAL_COMMAND (1 << 22) #define R1_APP_CMD (1 << 5)
@@ -687,6 +690,7 @@ struct mmc { uint tran_speed; uint legacy_speed; /* speed for the legacy mode provided by the card */ uint read_bl_len; + bool can_trim; #if CONFIG_IS_ENABLED(MMC_WRITE) uint write_bl_len; uint erase_grp_size; /* in 512-byte sectors */
The default erase command applies on erase group unit, and simply round down to erase group size. When the start block is not aligned to erase group size (e.g. erasing partition) it causes unwanted erasing of the previous blocks, part of the same erase group (e.g. owned by other logical partition, or by the partition table itself).
To prevent this issue, a simple solution is to use TRIM as argument of the Erase command, which is usually supported with eMMC > 4.0, and allow to apply erase operation to write blocks instead of erase group
Signed-off-by: Loic Poulain loic.poulain@linaro.org --- drivers/mmc/mmc_write.c | 34 +++++++++++++++++++++++----------- 1 file changed, 23 insertions(+), 11 deletions(-)
diff --git a/drivers/mmc/mmc_write.c b/drivers/mmc/mmc_write.c index 5b7aeeb012..a6f93380dd 100644 --- a/drivers/mmc/mmc_write.c +++ b/drivers/mmc/mmc_write.c @@ -15,7 +15,7 @@ #include <linux/math64.h> #include "mmc_private.h"
-static ulong mmc_erase_t(struct mmc *mmc, ulong start, lbaint_t blkcnt) +static ulong mmc_erase_t(struct mmc *mmc, ulong start, lbaint_t blkcnt, u32 args) { struct mmc_cmd cmd; ulong end; @@ -52,7 +52,7 @@ static ulong mmc_erase_t(struct mmc *mmc, ulong start, lbaint_t blkcnt) goto err_out;
cmd.cmdidx = MMC_CMD_ERASE; - cmd.cmdarg = MMC_ERASE_ARG; + cmd.cmdarg = args ? args : MMC_ERASE_ARG; cmd.resp_type = MMC_RSP_R1b;
err = mmc_send_cmd(mmc, &cmd, NULL); @@ -77,7 +77,7 @@ ulong mmc_berase(struct blk_desc *block_dev, lbaint_t start, lbaint_t blkcnt) #endif int dev_num = block_dev->devnum; int err = 0; - u32 start_rem, blkcnt_rem; + u32 start_rem, blkcnt_rem, erase_args = 0; struct mmc *mmc = find_mmc_device(dev_num); lbaint_t blk = 0, blk_r = 0; int timeout_ms = 1000; @@ -97,13 +97,25 @@ ulong mmc_berase(struct blk_desc *block_dev, lbaint_t start, lbaint_t blkcnt) */ err = div_u64_rem(start, mmc->erase_grp_size, &start_rem); err = div_u64_rem(blkcnt, mmc->erase_grp_size, &blkcnt_rem); - if (start_rem || blkcnt_rem) - printf("\n\nCaution! Your devices Erase group is 0x%x\n" - "The erase range would be change to " - "0x" LBAF "~0x" LBAF "\n\n", - mmc->erase_grp_size, start & ~(mmc->erase_grp_size - 1), - ((start + blkcnt + mmc->erase_grp_size - 1) - & ~(mmc->erase_grp_size - 1)) - 1); + if (start_rem || blkcnt_rem) { + if (mmc->can_trim) { + /* Trim function applies the erase operation to write + * blocks instead of erase groups. + */ + erase_args = MMC_TRIM_ARG; + } else { + /* The card ignores all LSB's below the erase group + * size, rounding down the addess to a erase group + * boundary. + */ + printf("\n\nCaution! Your devices Erase group is 0x%x\n" + "The erase range would be change to " + "0x" LBAF "~0x" LBAF "\n\n", + mmc->erase_grp_size, start & ~(mmc->erase_grp_size - 1), + ((start + blkcnt + mmc->erase_grp_size - 1) + & ~(mmc->erase_grp_size - 1)) - 1); + } + }
while (blk < blkcnt) { if (IS_SD(mmc) && mmc->ssr.au) { @@ -113,7 +125,7 @@ ulong mmc_berase(struct blk_desc *block_dev, lbaint_t start, lbaint_t blkcnt) blk_r = ((blkcnt - blk) > mmc->erase_grp_size) ? mmc->erase_grp_size : (blkcnt - blk); } - err = mmc_erase_t(mmc, start + blk, blk_r); + err = mmc_erase_t(mmc, start + blk, blk_r, erase_args); if (err) break;
Hi Loic,
cmd.cmdarg = args ? args : MMC_ERASE_ARG; cmd.resp_type = MMC_RSP_R1b; err = mmc_send_cmd(mmc, &cmd, NULL);
} else {
* boundary.
} while (blk < blkcnt) { if (IS_SD(mmc) && mmc->ssr.au) {
-- 2.34.1
Can you please add a sandbox test for this in test/dm/mmc.c?
Loic Poulain
