[U-Boot] [PATCH] ppc4xx: Flush complete dcache in relocate_code()
When the cache is enabled in SDRAM we need to flush not only the global data area but also the bd_info struct in relocate_code. This patch now flushed the complete dcache (all dcache lines) via flush_dcache() instead of adding a flush_dcache_range() call for bd_info since this is faster.
Signed-off-by: Stefan Roese sr@denx.de --- arch/powerpc/cpu/ppc4xx/start.S | 13 +++++++------ 1 files changed, 7 insertions(+), 6 deletions(-)
diff --git a/arch/powerpc/cpu/ppc4xx/start.S b/arch/powerpc/cpu/ppc4xx/start.S index d77272c..99822d7 100644 --- a/arch/powerpc/cpu/ppc4xx/start.S +++ b/arch/powerpc/cpu/ppc4xx/start.S @@ -1391,8 +1391,8 @@ in32r: relocate_code: #if defined(CONFIG_4xx_DCACHE) || defined(CONFIG_SYS_INIT_DCACHE_CS) /* - * We need to flush the initial global data (gd_t) before the dcache - * will be invalidated. + * We need to flush the initial global data (gd_t) and bd_info + * before the dcache will be invalidated. */
/* Save registers */ @@ -1400,10 +1400,11 @@ relocate_code: mr r10, r4 mr r11, r5
- /* Flush initial global data range */ - mr r3, r4 - addi r4, r4, GENERATED_GBL_DATA_SIZE@l - bl flush_dcache_range + /* + * Flush complete dcache, this is faster than flushing the + * ranges for global_data and bd_info instead. + */ + bl flush_dcache
#if defined(CONFIG_SYS_INIT_DCACHE_CS) /*
Applied to u-boot-ppc4xx/master. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Stefan Roese
