[GIT PULL] Please pull u-boot-amlogic-20220427
Hi Tom,
Here's changes for next release, nothing big, no new boards either: - Add AXG support for SARADC, including minimal ao-clk driver - Update Amlogic documentation for Matrix & Jethub D1
The CI job is at https://source.denx.de/u-boot/custodians/u-boot-amlogic/pipelines/11877
Thanks, Neil
The following changes since commit 9bb99fa95826d1a608737ca821977b4136a1a278:
Merge branch '2022-04-22-assorted-updates' (2022-04-23 08:06:28 -0400)
https://source.denx.de/u-boot/custodians/u-boot-amlogic.git tags/u-boot-amlogic-20220427
for you to fetch changes up to 5a9e5922ceccd55dc6427b3cf61b4dc74c7322ab:
doc: boards: amlogic: update jethub d1 specifications (2022-04-26 14:35:27 +0200)
---------------------------------------------------------------- - Add AXG support for SARADC, including minimal ao-clk driver - Update Amlogic documentation for Matrix & Jethub D1
---------------------------------------------------------------- Vyacheslav Bocharov (8): clk: meson: add minimal driver for axg-ao clocks clk: meson: fix driver name for g12a-ao clocks clk: meson: update driver for g12a-ao clocks adc: meson-saradc: add AXG variant board: amlogic: jethub j100: enable saradc in dts board: amlogic: jethub j100: enable saradc in config doc: boards: amlogic: update documentation for ADC support for AXG doc: boards: amlogic: update jethub d1 specifications
.../dts/meson-axg-jethome-jethub-j100-u-boot.dtsi | 10 +++ configs/jethub_j100_defconfig | 5 ++ doc/board/amlogic/index.rst | 2 +- doc/board/amlogic/jethub-j100.rst | 26 ++++--- drivers/adc/meson-saradc.c | 2 + drivers/clk/meson/Makefile | 1 + drivers/clk/meson/axg-ao.c | 86 ++++++++++++++++++++++ drivers/clk/meson/g12a-ao.c | 17 +++-- 8 files changed, 131 insertions(+), 18 deletions(-) create mode 100644 arch/arm/dts/meson-axg-jethome-jethub-j100-u-boot.dtsi create mode 100644 drivers/clk/meson/axg-ao.c
On Wed, Apr 27, 2022 at 09:52:20AM +0200, Neil Armstrong wrote:
Hi Tom,
Thanks, Neil
Neil Armstrong
