[PATCH 1/1] efi_loader: only reserve memory if fdt node enabled
Sub-nodes of /reserved-memory may be disabled. In this case we should not reserve memory in the memory map.
Reported-by: Patrick DELAUNAY patrick.delaunay@st.com Fixes: fef907b2e440 ("efi_loader: create reservations after ft_board_setup") Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/bootefi.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 3bbe2d6a1a..aaed575505 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -199,7 +199,8 @@ static void efi_carve_out_dt_rsv(void *fdt) * The /reserved-memory node may have children with * a size instead of a reg property. */ - if (addr != FDT_ADDR_T_NONE) + if (addr != FDT_ADDR_T_NONE && + fdtdec_get_is_enabled(fdt, subnode)) efi_reserve_memory(addr, size); subnode = fdt_next_subnode(fdt, subnode); } -- 2.25.1
On Mon, Mar 23, 2020 at 11:55 PM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
-- 2.25.1
Reviewed-by: Atish Patra atish.patra@wdc.com
Atish Patra
