[U-Boot] [PULL u-boot] Please pull u-boot-amlogic-20190731
Hi Tom,
This PR adds support for the Odroid-N2 board and sync the Amlogic G12A DT with Linux 5.3-rc1, removing the local DT in -u-boot.dtsi files. It also includes the last minute fix from Heinrich in the gxbb clock driver.
The CI jobs passed at https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic/pipelines/376
Thanks, Neil
The following changes since commit d0d07ba86afc8074d79e436b1ba4478fa0f0c1b5:
Prepare v2019.10-rc1 (2019-07-29 21:16:16 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic.git tags/u-boot-amlogic-20190731
for you to fetch changes up to 0c0cdc86103a1f579cb9f86a3c7c076abb383542:
clk: meson: remove duplicate logic (2019-07-31 12:11:04 +0200)
---------------------------------------------------------------- - sync Amlogic G12A DT with linux 5.3-rc1 - add support for 4GiB DRAM memory - add support for Amlogic G12B based Odroid-N2 - small duplicate logic fix for gxbb clock driver
---------------------------------------------------------------- Heinrich Schuchardt (1): clk: meson: remove duplicate logic
Neil Armstrong (4): ARM: dts: Sync Amlogic G12A with Linux 5.3-rc1 ARM: dts: add support for Odroid-N2 ARM: meson-g12a: Handle 4GiB DRAM size board: amlogic: add support for Odroid-N2
arch/arm/dts/Makefile | 3 +- arch/arm/dts/meson-g12a-u-boot.dtsi | 216 --- arch/arm/dts/meson-g12a-u200-u-boot.dtsi | 63 - arch/arm/dts/meson-g12a-u200.dts | 122 +- arch/arm/dts/meson-g12a.dtsi | 1825 ++++++++++++++++++++++- arch/arm/dts/meson-g12b-odroid-n2.dts | 386 +++++ arch/arm/dts/meson-g12b.dtsi | 82 + arch/arm/mach-meson/board-g12a.c | 13 +- board/amlogic/w400/MAINTAINERS | 6 + board/amlogic/w400/Makefile | 6 + board/amlogic/w400/README.odroid-n2 | 130 ++ board/amlogic/w400/README.w400 | 130 ++ board/amlogic/w400/w400.c | 18 + configs/odroid-n2_defconfig | 56 + drivers/clk/meson/gxbb.c | 5 +- include/dt-bindings/clock/axg-aoclkc.h | 7 +- include/dt-bindings/clock/axg-audio-clkc.h | 30 +- include/dt-bindings/clock/g12a-clkc.h | 3 +- include/dt-bindings/sound/meson-g12a-tohdmitx.h | 13 + 19 files changed, 2765 insertions(+), 349 deletions(-) delete mode 100644 arch/arm/dts/meson-g12a-u-boot.dtsi delete mode 100644 arch/arm/dts/meson-g12a-u200-u-boot.dtsi create mode 100644 arch/arm/dts/meson-g12b-odroid-n2.dts create mode 100644 arch/arm/dts/meson-g12b.dtsi create mode 100644 board/amlogic/w400/MAINTAINERS create mode 100644 board/amlogic/w400/Makefile create mode 100644 board/amlogic/w400/README.odroid-n2 create mode 100644 board/amlogic/w400/README.w400 create mode 100644 board/amlogic/w400/w400.c create mode 100644 configs/odroid-n2_defconfig create mode 100644 include/dt-bindings/sound/meson-g12a-tohdmitx.h
On Wed, Jul 31, 2019 at 09:57:01PM +0200, Neil Armstrong wrote:
Hi Tom,
Thanks, Neil
Neil Armstrong
