[PATCH v2 0/2] Introduce spl_soc_init() for SoC specific initialization
Currently some vendors use spl_board_init() for their SoC specific initialization. This prohibits board developers from adding board init code using said function. This series introduces a new function in order to separate SoC init code from board init code.
Changes in v2: - Change spl_arch_init() to spl_soc_init()
Lukas Funke (2): spl: Introduce SoC specific init function arm64: zynq(mp): Rename spl_board_init() to spl_soc_init()
arch/arm/Kconfig | 4 ++-- arch/arm/mach-zynq/spl.c | 4 ++-- arch/arm/mach-zynqmp/spl.c | 4 ++-- common/spl/Kconfig | 7 +++++++ common/spl/spl.c | 3 +++ include/spl.h | 8 ++++++++ 6 files changed, 24 insertions(+), 6 deletions(-)
Some architectures use spl_board_init() in their SoC specific implementation. Board developers should be able to add board specific implementation via spl_board_init(). Hence, introduce a spl_soc_init() method which is called right before spl_board_init() for SoC specific implementation.
Signed-off-by: Lukas Funke lukas.funke@weidmueller.com ---
(no changes since v1)
common/spl/Kconfig | 7 +++++++ common/spl/spl.c | 3 +++ include/spl.h | 8 ++++++++ 3 files changed, 18 insertions(+)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 6405374bcc..9b5cc8daa7 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -272,6 +272,13 @@ config SPL_TEXT_BASE help The address in memory that SPL will be running from.
+config SPL_SOC_INIT + bool "Call arch-specific initialization in SPL" + help + If this option is enabled, U-Boot will call the function + spl_soc_init() from board_init_r(). This function should be + provided by the architecture. + config SPL_BOARD_INIT bool "Call board-specific initialization in SPL" help diff --git a/common/spl/spl.c b/common/spl/spl.c index b65c439e7a..9b83c85df5 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -711,6 +711,9 @@ void board_init_r(gd_t *dummy1, ulong dummy2) } }
+ if (CONFIG_IS_ENABLED(SOC_INIT)) + spl_soc_init(); + if (CONFIG_IS_ENABLED(BOARD_INIT)) spl_board_init();
diff --git a/include/spl.h b/include/spl.h index 043875f10f..5dfdf778d2 100644 --- a/include/spl.h +++ b/include/spl.h @@ -816,6 +816,14 @@ int spl_early_init(void); */ int spl_init(void);
+/* + * spl_soc_init() - Do architecture-specific init in SPL + * + * If SPL_SOC_INIT is enabled, this is called from board_init_r() before + * jumping to the next phase. + */ +void spl_soc_init(void); + /* * spl_board_init() - Do board-specific init in SPL *
- bool "Call arch-specific initialization in SPL"
Call SoC specific intialization in SPL
With above change, Reviewed-by: Devarsh Thakkar devarsht@ti.com
Regards Devarsh
- help
- if (CONFIG_IS_ENABLED(SOC_INIT))
spl_soc_init();
- if (CONFIG_IS_ENABLED(BOARD_INIT)) spl_board_init();
- spl_soc_init() - Do architecture-specific init in SPL
- If SPL_SOC_INIT is enabled, this is called from board_init_r() before
- jumping to the next phase.
- spl_board_init() - Do board-specific init in SPL
Rename spl_board_init() to spl_soc_init(). SoC specific implementation should be separated from board specific implementation in order to be extended by board developers.
arch/arm/Kconfig | 4 ++-- arch/arm/mach-zynq/spl.c | 4 ++-- arch/arm/mach-zynqmp/spl.c | 4 ++-- 3 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 01d6556c42..db56db9414 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1275,7 +1275,7 @@ config ARCH_ZYNQ select OF_CONTROL select MTD select SPI - select SPL_BOARD_INIT if SPL + select SPL_SOC_INIT if SPL select SPL_CLK if SPL select SPL_DM if SPL select SPL_DM_SPI if SPL @@ -1318,7 +1318,7 @@ config ARCH_ZYNQMP imply FIRMWARE select GICV2 select OF_CONTROL - select SPL_BOARD_INIT if SPL + select SPL_SOC_INIT if SPL select SPL_CLK if SPL select SPL_DM if SPL select SPL_DM_SPI if SPI && SPL_DM diff --git a/arch/arm/mach-zynq/spl.c b/arch/arm/mach-zynq/spl.c index fea1c9b12a..112b44e2e1 100644 --- a/arch/arm/mach-zynq/spl.c +++ b/arch/arm/mach-zynq/spl.c @@ -32,8 +32,8 @@ void board_init_f(ulong dummy) arch_cpu_init(); }
-#ifdef CONFIG_SPL_BOARD_INIT -void spl_board_init(void) +#ifdef CONFIG_SPL_SOC_INIT +void spl_soc_init(void) { preloader_console_init(); #if defined(CONFIG_ARCH_EARLY_INIT_R) && defined(CONFIG_SPL_FPGA) diff --git a/arch/arm/mach-zynqmp/spl.c b/arch/arm/mach-zynqmp/spl.c index a0f35f36fa..71f9932525 100644 --- a/arch/arm/mach-zynqmp/spl.c +++ b/arch/arm/mach-zynqmp/spl.c @@ -56,8 +56,8 @@ static void ps_mode_reset(ulong mode) # define MODE_RESET PS_MODE1 #endif
-#ifdef CONFIG_SPL_BOARD_INIT -void spl_board_init(void) +#ifdef CONFIG_SPL_SOC_INIT +void spl_soc_init(void) { preloader_console_init(); ps_mode_reset(MODE_RESET);
Devarsh Thakkar
