[U-Boot] [PATCH] at91: Update board NAND drivers to current API.
Signed-off-by: Scott Wood scottwood@freescale.com --- I don't have hardware to test, so any help in that regard is appreciated.
Applied to u-boot-nand-flash.
board/atmel/at91cap9adk/nand.c | 37 ++++++++++++++++++------------------- board/atmel/at91sam9260ek/nand.c | 37 ++++++++++++++++++------------------- board/atmel/at91sam9261ek/nand.c | 37 ++++++++++++++++++------------------- board/atmel/at91sam9263ek/nand.c | 37 ++++++++++++++++++------------------- board/atmel/at91sam9rlek/nand.c | 37 ++++++++++++++++++------------------- 5 files changed, 90 insertions(+), 95 deletions(-)
diff --git a/board/atmel/at91cap9adk/nand.c b/board/atmel/at91cap9adk/nand.c index 0432ef1..1dec558 100644 --- a/board/atmel/at91cap9adk/nand.c +++ b/board/atmel/at91cap9adk/nand.c @@ -37,36 +37,35 @@ #define MASK_ALE (1 << 21) /* our ALE is AD21 */ #define MASK_CLE (1 << 22) /* our CLE is AD22 */
-static void at91cap9adk_nand_hwcontrol(struct mtd_info *mtd, int cmd) +static void at91cap9adk_nand_hwcontrol(struct mtd_info *mtd, + int cmd, unsigned int ctrl) { struct nand_chip *this = mtd->priv; - ulong IO_ADDR_W = (ulong) this->IO_ADDR_W;
- IO_ADDR_W &= ~(MASK_ALE|MASK_CLE); - switch (cmd) { - case NAND_CTL_SETCLE: - IO_ADDR_W |= MASK_CLE; - break; - case NAND_CTL_SETALE: - IO_ADDR_W |= MASK_ALE; - break; - case NAND_CTL_CLRNCE: - at91_set_gpio_value(AT91_PIN_PD15, 1); - break; - case NAND_CTL_SETNCE: - at91_set_gpio_value(AT91_PIN_PD15, 0); - break; + if (ctrl & NAND_CTRL_CHANGE) { + ulong IO_ADDR_W = (ulong) this->IO_ADDR_W; + IO_ADDR_W &= ~(MASK_ALE | MASK_CLE); + + if (ctrl & NAND_CLE) + IO_ADDR_W |= MASK_CLE; + if (ctrl & NAND_ALE) + IO_ADDR_W |= MASK_ALE; + + at91_set_gpio_value(AT91_PIN_PD15, !(ctrl & NAND_NCE)); + this->IO_ADDR_W = (void *) IO_ADDR_W; } - this->IO_ADDR_W = (void *) IO_ADDR_W; + + if (cmd != NAND_CMD_NONE) + writeb(cmd, this->IO_ADDR_W); }
int board_nand_init(struct nand_chip *nand) { - nand->eccmode = NAND_ECC_SOFT; + nand->ecc.mode = NAND_ECC_SOFT; #ifdef CFG_NAND_DBW_16 nand->options = NAND_BUSWIDTH_16; #endif - nand->hwcontrol = at91cap9adk_nand_hwcontrol; + nand->cmd_ctrl = at91cap9adk_nand_hwcontrol; nand->chip_delay = 20;
return 0; diff --git a/board/atmel/at91sam9260ek/nand.c b/board/atmel/at91sam9260ek/nand.c index 9738f0f..665e35c 100644 --- a/board/atmel/at91sam9260ek/nand.c +++ b/board/atmel/at91sam9260ek/nand.c @@ -37,27 +37,26 @@ #define MASK_ALE (1 << 21) /* our ALE is AD21 */ #define MASK_CLE (1 << 22) /* our CLE is AD22 */
-static void at91sam9260ek_nand_hwcontrol(struct mtd_info *mtd, int cmd) +static void at91sam9260ek_nand_hwcontrol(struct mtd_info *mtd, + int cmd, unsigned int ctrl) { struct nand_chip *this = mtd->priv; - ulong IO_ADDR_W = (ulong) this->IO_ADDR_W;
- IO_ADDR_W &= ~(MASK_ALE|MASK_CLE); - switch (cmd) { - case NAND_CTL_SETCLE: - IO_ADDR_W |= MASK_CLE; - break; - case NAND_CTL_SETALE: - IO_ADDR_W |= MASK_ALE; - break; - case NAND_CTL_CLRNCE: - at91_set_gpio_value(AT91_PIN_PC14, 1); - break; - case NAND_CTL_SETNCE: - at91_set_gpio_value(AT91_PIN_PC14, 0); - break; + if (ctrl & NAND_CTRL_CHANGE) { + ulong IO_ADDR_W = (ulong) this->IO_ADDR_W; + IO_ADDR_W &= ~(MASK_ALE | MASK_CLE); + + if (ctrl & NAND_CLE) + IO_ADDR_W |= MASK_CLE; + if (ctrl & NAND_ALE) + IO_ADDR_W |= MASK_ALE; + + at91_set_gpio_value(AT91_PIN_PC14, !(ctrl & NAND_NCE)); + this->IO_ADDR_W = (void *) IO_ADDR_W; } - this->IO_ADDR_W = (void *) IO_ADDR_W; + + if (cmd != NAND_CMD_NONE) + writeb(cmd, this->IO_ADDR_W); }
static int at91sam9260ek_nand_ready(struct mtd_info *mtd) @@ -67,11 +66,11 @@ static int at91sam9260ek_nand_ready(struct mtd_info *mtd)
int board_nand_init(struct nand_chip *nand) { - nand->eccmode = NAND_ECC_SOFT; + nand->ecc.mode = NAND_ECC_SOFT; #ifdef CFG_NAND_DBW_16 nand->options = NAND_BUSWIDTH_16; #endif - nand->hwcontrol = at91sam9260ek_nand_hwcontrol; + nand->cmd_ctrl = at91sam9260ek_nand_hwcontrol; nand->dev_ready = at91sam9260ek_nand_ready; nand->chip_delay = 20;
diff --git a/board/atmel/at91sam9261ek/nand.c b/board/atmel/at91sam9261ek/nand.c index 35b26db..fccb9d7 100644 --- a/board/atmel/at91sam9261ek/nand.c +++ b/board/atmel/at91sam9261ek/nand.c @@ -37,27 +37,26 @@ #define MASK_ALE (1 << 22) /* our ALE is AD22 */ #define MASK_CLE (1 << 21) /* our CLE is AD21 */
-static void at91sam9261ek_nand_hwcontrol(struct mtd_info *mtd, int cmd) +static void at91sam9261ek_nand_hwcontrol(struct mtd_info *mtd, + int cmd, unsigned int ctrl) { struct nand_chip *this = mtd->priv; - ulong IO_ADDR_W = (ulong) this->IO_ADDR_W;
static int at91sam9261ek_nand_ready(struct mtd_info *mtd) @@ -67,11 +66,11 @@ static int at91sam9261ek_nand_ready(struct mtd_info *mtd)
int board_nand_init(struct nand_chip *nand) { - nand->eccmode = NAND_ECC_SOFT; + nand->ecc.mode = NAND_ECC_SOFT; #ifdef CFG_NAND_DBW_16 nand->options = NAND_BUSWIDTH_16; #endif - nand->hwcontrol = at91sam9261ek_nand_hwcontrol; + nand->cmd_ctrl = at91sam9261ek_nand_hwcontrol; nand->dev_ready = at91sam9261ek_nand_ready; nand->chip_delay = 20;
diff --git a/board/atmel/at91sam9263ek/nand.c b/board/atmel/at91sam9263ek/nand.c index 5079972..250ec7f 100644 --- a/board/atmel/at91sam9263ek/nand.c +++ b/board/atmel/at91sam9263ek/nand.c @@ -37,27 +37,26 @@ #define MASK_ALE (1 << 21) /* our ALE is AD21 */ #define MASK_CLE (1 << 22) /* our CLE is AD22 */
-static void at91sam9263ek_nand_hwcontrol(struct mtd_info *mtd, int cmd) +static void at91sam9263ek_nand_hwcontrol(struct mtd_info *mtd, + int cmd, unsigned int ctrl) { struct nand_chip *this = mtd->priv; - ulong IO_ADDR_W = (ulong) this->IO_ADDR_W;
static int at91sam9263ek_nand_ready(struct mtd_info *mtd) @@ -67,11 +66,11 @@ static int at91sam9263ek_nand_ready(struct mtd_info *mtd)
int board_nand_init(struct nand_chip *nand) { - nand->eccmode = NAND_ECC_SOFT; + nand->ecc.mode = NAND_ECC_SOFT; #ifdef CFG_NAND_DBW_16 nand->options = NAND_BUSWIDTH_16; #endif - nand->hwcontrol = at91sam9263ek_nand_hwcontrol; + nand->cmd_ctrl = at91sam9263ek_nand_hwcontrol; nand->dev_ready = at91sam9263ek_nand_ready; nand->chip_delay = 20;
diff --git a/board/atmel/at91sam9rlek/nand.c b/board/atmel/at91sam9rlek/nand.c index 5af1a31..eb342b8 100644 --- a/board/atmel/at91sam9rlek/nand.c +++ b/board/atmel/at91sam9rlek/nand.c @@ -37,27 +37,26 @@ #define MASK_ALE (1 << 21) /* our ALE is AD21 */ #define MASK_CLE (1 << 22) /* our CLE is AD22 */
-static void at91sam9rlek_nand_hwcontrol(struct mtd_info *mtd, int cmd) +static void at91sam9rlek_nand_hwcontrol(struct mtd_info *mtd, + int cmd, unsigned int ctrl) { struct nand_chip *this = mtd->priv; - ulong IO_ADDR_W = (ulong) this->IO_ADDR_W;
- IO_ADDR_W &= ~(MASK_ALE|MASK_CLE); - switch (cmd) { - case NAND_CTL_SETCLE: - IO_ADDR_W |= MASK_CLE; - break; - case NAND_CTL_SETALE: - IO_ADDR_W |= MASK_ALE; - break; - case NAND_CTL_CLRNCE: - at91_set_gpio_value(AT91_PIN_PB6, 1); - break; - case NAND_CTL_SETNCE: - at91_set_gpio_value(AT91_PIN_PB6, 0); - break; + if (ctrl & NAND_CTRL_CHANGE) { + ulong IO_ADDR_W = (ulong) this->IO_ADDR_W; + IO_ADDR_W &= ~(MASK_ALE | MASK_CLE); + + if (ctrl & NAND_CLE) + IO_ADDR_W |= MASK_CLE; + if (ctrl & NAND_ALE) + IO_ADDR_W |= MASK_ALE; + + at91_set_gpio_value(AT91_PIN_PB6, !(ctrl & NAND_NCE)); + this->IO_ADDR_W = (void *) IO_ADDR_W; } - this->IO_ADDR_W = (void *) IO_ADDR_W; + + if (cmd != NAND_CMD_NONE) + writeb(cmd, this->IO_ADDR_W); }
static int at91sam9rlek_nand_ready(struct mtd_info *mtd) @@ -67,11 +66,11 @@ static int at91sam9rlek_nand_ready(struct mtd_info *mtd)
int board_nand_init(struct nand_chip *nand) { - nand->eccmode = NAND_ECC_SOFT; + nand->ecc.mode = NAND_ECC_SOFT; #ifdef CFG_NAND_DBW_16 nand->options = NAND_BUSWIDTH_16; #endif - nand->hwcontrol = at91sam9rlek_nand_hwcontrol; + nand->cmd_ctrl = at91sam9rlek_nand_hwcontrol; nand->dev_ready = at91sam9rlek_nand_ready; nand->chip_delay = 20;
I'll test on the at91sam9263ek.
Stelian could test it also please?
Best Regards, J.
Hi Jean-Christophe, Scott and the list,
Le mercredi 13 août 2008 à 23:23 +0200, Jean-Christophe PLAGNIOL-VILLARD a écrit :
Sorry for the delay. Tested it on CAP9, works fine.
Stelian.
Scott Wood
Stelian Pop
